, including all inherited members.
CPPUNIT_TEST(test_linear_hex_coeff_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_hex_coeff_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_hex_coeff_faces) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_hex_coeff_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_quad_coeff_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_quad_coeff_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_quad_coeff_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tet_coeff_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tet_coeff_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tet_coeff_faces) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tet_coeff_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tri_coeff_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tri_coeff_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tri_coeff_faces) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tri_coeff_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_prism_coeff_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_prism_coeff_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_prism_coeff_faces) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_prism_coeff_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_pyr_coeff_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_pyr_coeff_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_pyr_coeff_faces) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_pyr_coeff_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_hex_deriv_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_hex_deriv_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_hex_deriv_faces) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_hex_deriv_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_quad_deriv_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_quad_deriv_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_quad_deriv_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tet_deriv_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tet_deriv_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tet_deriv_faces) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tet_deriv_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tri_deriv_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tri_deriv_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tri_deriv_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_prism_deriv_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_prism_deriv_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_prism_deriv_faces) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_prism_deriv_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_pyr_deriv_corners) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_pyr_deriv_edges) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_pyr_deriv_faces) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_pyr_deriv_center) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_hex_ideal) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_quad_ideal) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tet_ideal) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_tri_ideal) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST(test_linear_prism_ideal) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST_SUITE(LinearMappingFunctionTest) | LinearMappingFunctionTest | [private] |
CPPUNIT_TEST_SUITE_END() | LinearMappingFunctionTest | [private] |
do_coeff_test(MappingFunction &mf, unsigned subdim, map_func mf2, unsigned count, double *xi) | LinearMappingFunctionTest | [private] |
do_deriv_test(MappingFunction2D &mf, unsigned subdim, map_func mf2, unsigned count, double *xi) | LinearMappingFunctionTest | [private] |
do_deriv_test(MappingFunction3D &mf, unsigned subdim, map_func mf2, unsigned count, double *xi) | LinearMappingFunctionTest | [private] |
do_ideal_test(MappingFunction2D &mf) | LinearMappingFunctionTest | [private] |
do_ideal_test(MappingFunction3D &mf) | LinearMappingFunctionTest | [private] |
hex | LinearMappingFunctionTest | [private] |
hex_coeff(double xi[3], double coeff[8]) | LinearMappingFunctionTest | [private, static] |
hex_deriv(double xi[3], double coeff_deriv[24]) | LinearMappingFunctionTest | [private, static] |
map_func typedef | LinearMappingFunctionTest | [private] |
prism | LinearMappingFunctionTest | [private] |
prism_coeff(double xi[3], double coeff[6]) | LinearMappingFunctionTest | [private, static] |
prism_deriv(double xi[3], double coeff_deriv[18]) | LinearMappingFunctionTest | [private, static] |
pyr | LinearMappingFunctionTest | [private] |
pyr_coeff(double xi[3], double coeff[5]) | LinearMappingFunctionTest | [private, static] |
pyr_deriv(double xi[3], double coeff_deriv[15]) | LinearMappingFunctionTest | [private, static] |
quad | LinearMappingFunctionTest | [private] |
quad_coeff(double xi[2], double coeff[4]) | LinearMappingFunctionTest | [private, static] |
quad_deriv(double xi[2], double coeff_deriv[8]) | LinearMappingFunctionTest | [private, static] |
setUp() | LinearMappingFunctionTest | |
tearDown() | LinearMappingFunctionTest | |
test_coeff_fail(MappingFunction &mf, unsigned subdim) | LinearMappingFunctionTest | [private] |
test_deriv_fail(MappingFunction2D &mf, unsigned subdim) | LinearMappingFunctionTest | [private] |
test_deriv_fail(MappingFunction3D &mf, unsigned subdim) | LinearMappingFunctionTest | [private] |
test_linear_hex_coeff_center() | LinearMappingFunctionTest | |
test_linear_hex_coeff_corners() | LinearMappingFunctionTest | |
test_linear_hex_coeff_edges() | LinearMappingFunctionTest | |
test_linear_hex_coeff_faces() | LinearMappingFunctionTest | |
test_linear_hex_deriv_center() | LinearMappingFunctionTest | |
test_linear_hex_deriv_corners() | LinearMappingFunctionTest | |
test_linear_hex_deriv_edges() | LinearMappingFunctionTest | |
test_linear_hex_deriv_faces() | LinearMappingFunctionTest | |
test_linear_hex_ideal() | LinearMappingFunctionTest | [inline] |
test_linear_prism_coeff_center() | LinearMappingFunctionTest | |
test_linear_prism_coeff_corners() | LinearMappingFunctionTest | |
test_linear_prism_coeff_edges() | LinearMappingFunctionTest | |
test_linear_prism_coeff_faces() | LinearMappingFunctionTest | |
test_linear_prism_deriv_center() | LinearMappingFunctionTest | |
test_linear_prism_deriv_corners() | LinearMappingFunctionTest | |
test_linear_prism_deriv_edges() | LinearMappingFunctionTest | |
test_linear_prism_deriv_faces() | LinearMappingFunctionTest | |
test_linear_prism_ideal() | LinearMappingFunctionTest | [inline] |
test_linear_pyr_coeff_center() | LinearMappingFunctionTest | |
test_linear_pyr_coeff_corners() | LinearMappingFunctionTest | |
test_linear_pyr_coeff_edges() | LinearMappingFunctionTest | |
test_linear_pyr_coeff_faces() | LinearMappingFunctionTest | |
test_linear_pyr_deriv_center() | LinearMappingFunctionTest | |
test_linear_pyr_deriv_corners() | LinearMappingFunctionTest | |
test_linear_pyr_deriv_edges() | LinearMappingFunctionTest | |
test_linear_pyr_deriv_faces() | LinearMappingFunctionTest | |
test_linear_quad_coeff_center() | LinearMappingFunctionTest | |
test_linear_quad_coeff_corners() | LinearMappingFunctionTest | |
test_linear_quad_coeff_edges() | LinearMappingFunctionTest | |
test_linear_quad_deriv_center() | LinearMappingFunctionTest | |
test_linear_quad_deriv_corners() | LinearMappingFunctionTest | |
test_linear_quad_deriv_edges() | LinearMappingFunctionTest | |
test_linear_quad_ideal() | LinearMappingFunctionTest | [inline] |
test_linear_tet_coeff_center() | LinearMappingFunctionTest | |
test_linear_tet_coeff_corners() | LinearMappingFunctionTest | |
test_linear_tet_coeff_edges() | LinearMappingFunctionTest | |
test_linear_tet_coeff_faces() | LinearMappingFunctionTest | |
test_linear_tet_deriv_center() | LinearMappingFunctionTest | |
test_linear_tet_deriv_corners() | LinearMappingFunctionTest | |
test_linear_tet_deriv_edges() | LinearMappingFunctionTest | |
test_linear_tet_deriv_faces() | LinearMappingFunctionTest | |
test_linear_tet_ideal() | LinearMappingFunctionTest | [inline] |
test_linear_tri_coeff_center() | LinearMappingFunctionTest | |
test_linear_tri_coeff_corners() | LinearMappingFunctionTest | |
test_linear_tri_coeff_edges() | LinearMappingFunctionTest | |
test_linear_tri_coeff_faces() | LinearMappingFunctionTest | |
test_linear_tri_deriv_center() | LinearMappingFunctionTest | |
test_linear_tri_deriv_corners() | LinearMappingFunctionTest | |
test_linear_tri_deriv_edges() | LinearMappingFunctionTest | |
test_linear_tri_ideal() | LinearMappingFunctionTest | [inline] |
tet | LinearMappingFunctionTest | [private] |
tet_coeff(double xi[3], double coeff[4]) | LinearMappingFunctionTest | [private, static] |
tet_deriv(double xi[3], double coeff_deriv[12]) | LinearMappingFunctionTest | [private, static] |
tri | LinearMappingFunctionTest | [private] |
tri_coeff(double xi[2], double coeff[3]) | LinearMappingFunctionTest | [private, static] |
tri_deriv(double xi[2], double coeff_deriv[6]) | LinearMappingFunctionTest | [private, static] |
xi_at_corners(EntityTopology type, double *xi, const int *corners) | LinearMappingFunctionTest | [private] |
xi_at_edges(EntityTopology type, double *xi, const int *corners) | LinearMappingFunctionTest | [private] |
xi_at_faces(EntityTopology type, double *xi, const int *corners) | LinearMappingFunctionTest | [private] |
