buffer | MBMesquite::FileTokenizer | [private] |
bufferEnd | MBMesquite::FileTokenizer | [private] |
eof() const | MBMesquite::FileTokenizer | |
filePtr | MBMesquite::FileTokenizer | [private] |
FileTokenizer(std::FILE *file_ptr) | MBMesquite::FileTokenizer | |
get_boolean_internal(bool &result, MsqError &err) | MBMesquite::FileTokenizer | [private] |
get_booleans(size_t count, bool *array, MsqError &err) | MBMesquite::FileTokenizer | |
get_byte_internal(unsigned char &result, MsqError &err) | MBMesquite::FileTokenizer | [private] |
get_bytes(size_t count, unsigned char *array, MsqError &err) | MBMesquite::FileTokenizer | |
get_double_internal(double &result, MsqError &err) | MBMesquite::FileTokenizer | [private] |
get_doubles(size_t count, double *array, MsqError &err) | MBMesquite::FileTokenizer | |
get_float_internal(float &result, MsqError &err) | MBMesquite::FileTokenizer | [private] |
get_floats(size_t count, float *array, MsqError &err) | MBMesquite::FileTokenizer | |
get_integer_internal(int &result, MsqError &err) | MBMesquite::FileTokenizer | [private] |
get_integers(size_t count, int *array, MsqError &err) | MBMesquite::FileTokenizer | |
get_long_int_internal(long &result, MsqError &err) | MBMesquite::FileTokenizer | [private] |
get_long_ints(size_t count, long *array, MsqError &err) | MBMesquite::FileTokenizer | |
get_newline(MsqError &err) | MBMesquite::FileTokenizer | |
get_short_int_internal(short &result, MsqError &err) | MBMesquite::FileTokenizer | [private] |
get_short_ints(size_t count, short *array, MsqError &err) | MBMesquite::FileTokenizer | |
get_string(MsqError &err) | MBMesquite::FileTokenizer | |
lastChar | MBMesquite::FileTokenizer | [private] |
line_number() const | MBMesquite::FileTokenizer | [inline] |
lineNumber | MBMesquite::FileTokenizer | [private] |
match_token(const char *string, MsqError &err) | MBMesquite::FileTokenizer | |
match_token(const char *const *string_list, MsqError &err) | MBMesquite::FileTokenizer | |
nextToken | MBMesquite::FileTokenizer | [private] |
unget_token() | MBMesquite::FileTokenizer | |
~FileTokenizer() | MBMesquite::FileTokenizer | |
