MBMesquite::ParallelHelper Member List
This is the complete list of members for MBMesquite::ParallelHelper, including all inherited members.
communicate_all_true(bool &value, MsqError &err) const =0MBMesquite::ParallelHelper [protected, pure virtual]
communicate_any_true(bool &value, MsqError &err) const =0MBMesquite::ParallelHelper [protected, pure virtual]
communicate_first_independent_set(MsqError &)=0MBMesquite::ParallelHelper [protected, pure virtual]
communicate_histogram_to_zero(std::vector< int > &histogram, MsqError &) const =0MBMesquite::ParallelHelper [protected, pure virtual]
communicate_min_max_to_all(double *minimum, double *maximum, MsqError &) const =0MBMesquite::ParallelHelper [protected, pure virtual]
communicate_min_max_to_zero(double *minimum, double *maximum, MsqError &) const =0MBMesquite::ParallelHelper [protected, pure virtual]
communicate_next_independent_set(MsqError &)=0MBMesquite::ParallelHelper [protected, pure virtual]
communicate_power_sum_to_zero(double *pMean, MsqError &) const =0MBMesquite::ParallelHelper [protected, pure virtual]
communicate_sums_to_zero(size_t *freeElementCount, int *invertedElementCount, size_t *elementCount, int *invertedSampleCount, size_t *sampleCount, long unsigned int *count, long unsigned int *invalid, double *sum, double *sqrSum, MsqError &) const =0MBMesquite::ParallelHelper [protected, pure virtual]
compute_first_independent_set(std::vector< Mesh::VertexHandle > &fixed_vertices)=0MBMesquite::ParallelHelper [protected, pure virtual]
compute_next_independent_set()=0MBMesquite::ParallelHelper [protected, pure virtual]
get_next_partition_boundary_vertex(MBMesquite::Mesh::VertexHandle &vertex_handle)=0MBMesquite::ParallelHelper [protected, pure virtual]
get_nprocs() const =0MBMesquite::ParallelHelper [protected, pure virtual]
get_rank() const =0MBMesquite::ParallelHelper [protected, pure virtual]
is_our_element(Mesh::ElementHandle element_handle, MsqError &) const =0MBMesquite::ParallelHelper [protected, pure virtual]
is_our_vertex(Mesh::VertexHandle vertex_handle, MsqError &) const =0MBMesquite::ParallelHelper [protected, pure virtual]
QualityAssessor classMBMesquite::ParallelHelper [friend]
set_communication_model(int model, MsqError &)=0MBMesquite::ParallelHelper [pure virtual]
set_communicator(size_t comm)=0MBMesquite::ParallelHelper [pure virtual]
set_generate_random_numbers(int grn, MsqError &)=0MBMesquite::ParallelHelper [pure virtual]
set_parallel_mesh(ParallelMesh *mesh)=0MBMesquite::ParallelHelper [pure virtual]
smoothing_close(MsqError &)=0MBMesquite::ParallelHelper [protected, pure virtual]
smoothing_init(MsqError &)=0MBMesquite::ParallelHelper [protected, pure virtual]
VertexMover classMBMesquite::ParallelHelper [friend]
~ParallelHelper()MBMesquite::ParallelHelper [inline, virtual]
