MBMesquite::TerminationCriterion Member List
This is the complete list of members for MBMesquite::TerminationCriterion, including all inherited members.
accumulate_inner(PatchData &pd, OFEvaluator &eval, MsqError &err)MBMesquite::TerminationCriterion
accumulate_inner(PatchData &pd, double of_value, Vector3D *of_grads, MsqError &err)MBMesquite::TerminationCriterion
accumulate_outer(Mesh *ms, MeshDomain *dm, OFEvaluator &eval, const Settings *settings, MsqError &err)MBMesquite::TerminationCriterion
accumulate_patch(PatchData &pd, MsqError &err)MBMesquite::TerminationCriterion
add_absolute_gradient_inf_norm(double value)MBMesquite::TerminationCriterion
add_absolute_gradient_L2_norm(double value)MBMesquite::TerminationCriterion
add_absolute_quality_improvement(double value)MBMesquite::TerminationCriterion
add_absolute_successive_improvement(double value)MBMesquite::TerminationCriterion
add_absolute_vertex_movement(double value)MBMesquite::TerminationCriterion
add_absolute_vertex_movement_edge_length(double value)MBMesquite::TerminationCriterion
add_bounded_vertex_movement(double value)MBMesquite::TerminationCriterion
add_cpu_time(double seconds)MBMesquite::TerminationCriterion
add_iteration_limit(unsigned int max_iterations)MBMesquite::TerminationCriterion
add_relative_gradient_inf_norm(double value)MBMesquite::TerminationCriterion
add_relative_gradient_L2_norm(double value)MBMesquite::TerminationCriterion
add_relative_quality_improvement(double value)MBMesquite::TerminationCriterion
add_relative_successive_improvement(double value)MBMesquite::TerminationCriterion
add_relative_vertex_movement(double value)MBMesquite::TerminationCriterion
add_untangled_mesh()MBMesquite::TerminationCriterion
boundedVertexMovementEpsMBMesquite::TerminationCriterion [private]
cleanup(Mesh *ms, MeshDomain *domain, MsqError &err)MBMesquite::TerminationCriterion
count_inverted(PatchData &pd, MsqError &err)MBMesquite::TerminationCriterion [protected, static]
criterion_is_set()MBMesquite::TerminationCriterion
cull_for_global_patch(bool val=true)MBMesquite::TerminationCriterion
cull_on_absolute_quality_improvement(double limit)MBMesquite::TerminationCriterion
cull_on_absolute_successive_improvement(double limit)MBMesquite::TerminationCriterion
cull_on_absolute_vertex_movement(double limit)MBMesquite::TerminationCriterion
cull_on_absolute_vertex_movement_edge_length(double value)MBMesquite::TerminationCriterion
cull_on_relative_quality_improvement(double limit)MBMesquite::TerminationCriterion
cull_on_relative_successive_improvement(double limit)MBMesquite::TerminationCriterion
cull_on_relative_vertex_movement(double limit)MBMesquite::TerminationCriterion
cull_untangled_mesh()MBMesquite::TerminationCriterion
cull_vertices(PatchData &pd, OFEvaluator &obj_ptr, MsqError &err)MBMesquite::TerminationCriterion
cull_vertices_global(PatchData &global_patch, Mesh *mesh, MeshDomain *domain, const Settings *settings, OFEvaluator &of_eval, MsqError &err)MBMesquite::TerminationCriterion
cullingEpsMBMesquite::TerminationCriterion [private]
cullingGlobalPatchMBMesquite::TerminationCriterion [private]
cullingMethodFlagMBMesquite::TerminationCriterion [private]
currentGradInfNormMBMesquite::TerminationCriterion [private]
currentGradL2NormSquaredMBMesquite::TerminationCriterion [private]
currentOFValueMBMesquite::TerminationCriterion [private]
debugLevelMBMesquite::TerminationCriterion [private]
get_current_function_value()MBMesquite::TerminationCriterion [inline]
get_iteration_count() const MBMesquite::TerminationCriterion [inline]
globalInvertedCountMBMesquite::TerminationCriterion [private]
GNUPLOT enum valueMBMesquite::TerminationCriterion
gradInfNormAbsoluteEpsMBMesquite::TerminationCriterion [private]
gradInfNormRelativeEpsMBMesquite::TerminationCriterion [private]
gradL2NormAbsoluteEpsSquaredMBMesquite::TerminationCriterion [private]
gradL2NormRelativeEpsSquaredMBMesquite::TerminationCriterion [private]
initialGradInfNormMBMesquite::TerminationCriterion [private]
initialGradL2NormSquaredMBMesquite::TerminationCriterion [private]
initialize_queue(MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err)MBMesquite::TerminationCriterion
initialOFValueMBMesquite::TerminationCriterion [private]
initialVerticesMementoMBMesquite::TerminationCriterion [private]
InnerOuterType enum nameMBMesquite::TerminationCriterion
innerOuterTypeMBMesquite::TerminationCriterion [private]
iterationBoundMBMesquite::TerminationCriterion [private]
iterationCounterMBMesquite::TerminationCriterion [private]
lowerOFBoundMBMesquite::TerminationCriterion [private]
maxSquaredInitialMovementMBMesquite::TerminationCriterion [private]
maxSquaredMovementMBMesquite::TerminationCriterion [private]
mGradMBMesquite::TerminationCriterion [private]
monikerMBMesquite::TerminationCriterion [private]
mTimerMBMesquite::TerminationCriterion [private]
NOTYPE enum valueMBMesquite::TerminationCriterion
par_string()MBMesquite::TerminationCriterion [protected]
patchInvertedCountMBMesquite::TerminationCriterion [private]
plotFileMBMesquite::TerminationCriterion [private]
previousOFValueMBMesquite::TerminationCriterion [private]
previousVerticesMementoMBMesquite::TerminationCriterion [private]
qualityImprovementAbsoluteEpsMBMesquite::TerminationCriterion [private]
qualityImprovementRelativeEpsMBMesquite::TerminationCriterion [private]
remove_all_criteria()MBMesquite::TerminationCriterion
remove_culling()MBMesquite::TerminationCriterion
reset_inner(PatchData &pd, OFEvaluator &of, MsqError &err)MBMesquite::TerminationCriterion
reset_outer(Mesh *ms, MeshDomain *dm, OFEvaluator &of, const Settings *settings, MsqError &err)MBMesquite::TerminationCriterion
reset_patch(PatchData &pd, MsqError &err)MBMesquite::TerminationCriterion
set_debug_output_level(int i)MBMesquite::TerminationCriterion [inline]
successiveImprovementsAbsoluteEpsMBMesquite::TerminationCriterion [private]
successiveImprovementsRelativeEpsMBMesquite::TerminationCriterion [private]
terminate()MBMesquite::TerminationCriterion
TerminationCriterion(std::string name="", InnerOuterType innerOuterType=TYPE_UNKNOWN)MBMesquite::TerminationCriterion
terminationCriterionFlagMBMesquite::TerminationCriterion [private]
timeBoundMBMesquite::TerminationCriterion [private]
timeStepFileNameMBMesquite::TerminationCriterion [private]
timeStepFileTypeMBMesquite::TerminationCriterion [private]
TimeStepFileType enum nameMBMesquite::TerminationCriterion
TYPE_INNER enum valueMBMesquite::TerminationCriterion
TYPE_OUTER enum valueMBMesquite::TerminationCriterion
TYPE_UNKNOWN enum valueMBMesquite::TerminationCriterion
vertexMovementAbsoluteAvgEdgeMBMesquite::TerminationCriterion [private]
vertexMovementAbsoluteEpsMBMesquite::TerminationCriterion [private]
vertexMovementAvgBetaMBMesquite::TerminationCriterion [private]
vertexMovementExceedsBoundMBMesquite::TerminationCriterion [private]
vertexMovementRelativeEpsMBMesquite::TerminationCriterion [private]
VertexMover classMBMesquite::TerminationCriterion [friend]
VTK enum valueMBMesquite::TerminationCriterion
write_iterations(const char *filename, MsqError &err)MBMesquite::TerminationCriterion
write_mesh_steps(const char *filename, TimeStepFileType type=VTK)MBMesquite::TerminationCriterion [inline]
write_timestep(PatchData &pd, const Vector3D *gradient, MsqError &err)MBMesquite::TerminationCriterion [protected]
~TerminationCriterion()MBMesquite::TerminationCriterion [inline]
