, including all inherited members.
compare_diagonal_gradient(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_diagonal_gradient(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_hessian_diagonal(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_hessian_diagonal(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_hessian_gradient(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_hessian_gradient(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_numerical_gradient(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_numerical_gradient(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_numerical_hessian(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_numerical_hessian(ObjectiveFunction *of, bool diagonal_only) | ObjectiveFunctionTests | [static] |
compare_numerical_hessian_diagonal(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
CPPUNIT_TEST(test_eval_OF_value_LPtoP_L1) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_grad_OF_value_LPtoP_L1) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_diag_OF_value_LPtoP_L1) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_hess_OF_value_LPtoP_L1) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_eval_OF_value_LPtoP_L2) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_grad_OF_value_LPtoP_L2) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_diag_OF_value_LPtoP_L2) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_hess_OF_value_LPtoP_L2) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_eval_OF_value_LPtoP_scaled) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_grad_OF_value_LPtoP_scaled) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_diag_OF_value_LPtoP_scaled) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_hess_OF_value_LPtoP_scaled) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_eval_OF_value_LInf) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_eval_OF_value_max) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_compute_gradient_LPtoPTemplate_L1) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_compute_gradient_LPtoPTemplate_L2) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_compute_gradient_LPtoPTemplate_L2_scaled) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_hessian_gradient_LPtoPTemplate_L1) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_hessian_gradient_LPtoPTemplate_L2) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_hessian_gradient_LPtoPTemplate_L2_scaled) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_diagonal_gradient_LPtoPTemplate_L1) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_diagonal_gradient_LPtoPTemplate_L2) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_diagonal_gradient_LPtoPTemplate_L2_scaled) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_hessian_diagonal_LPtoPTemplate_L1) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_hessian_diagonal_LPtoPTemplate_L2) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_hessian_diagonal_LPtoPTemplate_L2_scaled) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_compute_ana_hessian_tet) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_compute_ana_hessian_tet_scaled) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_invalid_qm_eval) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_invalid_qm_grad) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_invalid_qm_diag) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_invalid_qm_hess) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LInf_invalid_qm_eval) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_max_invalid_qm_eval) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_qm_error_eval) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_qm_error_grad) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_qm_error_diag) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_qm_error_hess) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LInf_qm_error_eval) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_max_qm_error_eval) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_eval_calc) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_eval_accum) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_eval_save) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_eval_update) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_eval_temp) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_grad_calc) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_grad_save) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_grad_update) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_grad_temp) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_diag_calc) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_diag_save) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_diag_update) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_diag_temp) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_hess_calc) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_hess_save) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_hess_update) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_hess_temp) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_clone_L1) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_clone_L2) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LInf_clone) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_max_clone) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_negate_flag_eval) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_negate_flag_grad) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_negate_flag_diag) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LPtoP_negate_flag_hess) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_LInf_negate_flag_eval) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST(test_max_negate_flag_eval) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST_SUITE(ObjectiveFunctionTest) | ObjectiveFunctionTest | [private] |
CPPUNIT_TEST_SUITE_END() | ObjectiveFunctionTest | [private] |
DIAG enum value | ObjectiveFunctionTests | |
EVAL enum value | ObjectiveFunctionTests | |
GRAD enum value | ObjectiveFunctionTests | |
HESS enum value | ObjectiveFunctionTests | |
ObjectiveFunctionTest() | ObjectiveFunctionTest | [inline] |
OFTestMode enum name | ObjectiveFunctionTests | |
patch() | ObjectiveFunctionTests | [static] |
setUp() | ObjectiveFunctionTest | [inline] |
test_clone(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_compute_ana_hessian_tet() | ObjectiveFunctionTest | |
test_compute_ana_hessian_tet_scaled() | ObjectiveFunctionTest | |
test_compute_gradient_LPtoPTemplate_L1() | ObjectiveFunctionTest | [inline] |
test_compute_gradient_LPtoPTemplate_L2() | ObjectiveFunctionTest | [inline] |
test_compute_gradient_LPtoPTemplate_L2_scaled() | ObjectiveFunctionTest | [inline] |
test_diag_OF_value_LPtoP_L1() | ObjectiveFunctionTest | [inline] |
test_diag_OF_value_LPtoP_L2() | ObjectiveFunctionTest | [inline] |
test_diag_OF_value_LPtoP_scaled() | ObjectiveFunctionTest | [inline] |
test_diagonal_gradient_LPtoPTemplate_L1() | ObjectiveFunctionTest | [inline] |
test_diagonal_gradient_LPtoPTemplate_L2() | ObjectiveFunctionTest | [inline] |
test_diagonal_gradient_LPtoPTemplate_L2_scaled() | ObjectiveFunctionTest | [inline] |
test_eval_OF_value_LInf() | ObjectiveFunctionTest | [inline] |
test_eval_OF_value_LPtoP_L1() | ObjectiveFunctionTest | [inline] |
test_eval_OF_value_LPtoP_L2() | ObjectiveFunctionTest | [inline] |
test_eval_OF_value_LPtoP_scaled() | ObjectiveFunctionTest | [inline] |
test_eval_OF_value_max() | ObjectiveFunctionTest | [inline] |
test_eval_type(ObjectiveFunction::EvalType, OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_grad_OF_value_LPtoP_L1() | ObjectiveFunctionTest | [inline] |
test_grad_OF_value_LPtoP_L2() | ObjectiveFunctionTest | [inline] |
test_grad_OF_value_LPtoP_scaled() | ObjectiveFunctionTest | [inline] |
test_handles_invalid_qm(OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_handles_qm_error(OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_hess_OF_value_LPtoP_L1() | ObjectiveFunctionTest | [inline] |
test_hess_OF_value_LPtoP_L2() | ObjectiveFunctionTest | [inline] |
test_hess_OF_value_LPtoP_scaled() | ObjectiveFunctionTest | [inline] |
test_hessian_diagonal_LPtoPTemplate_L1() | ObjectiveFunctionTest | [inline] |
test_hessian_diagonal_LPtoPTemplate_L2() | ObjectiveFunctionTest | [inline] |
test_hessian_diagonal_LPtoPTemplate_L2_scaled() | ObjectiveFunctionTest | [inline] |
test_hessian_gradient_LPtoPTemplate_L1() | ObjectiveFunctionTest | [inline] |
test_hessian_gradient_LPtoPTemplate_L2() | ObjectiveFunctionTest | [inline] |
test_hessian_gradient_LPtoPTemplate_L2_scaled() | ObjectiveFunctionTest | [inline] |
test_LInf_clone() | ObjectiveFunctionTest | [inline] |
test_LInf_invalid_qm_eval() | ObjectiveFunctionTest | [inline] |
test_LInf_negate_flag_eval() | ObjectiveFunctionTest | [inline] |
test_LInf_qm_error_eval() | ObjectiveFunctionTest | [inline] |
test_LInf_value(const std::vector< double > &values) | ObjectiveFunctionTest | [private] |
test_LPtoP_clone_L1() | ObjectiveFunctionTest | [inline] |
test_LPtoP_clone_L2() | ObjectiveFunctionTest | [inline] |
test_LPtoP_diag_calc() | ObjectiveFunctionTest | [inline] |
test_LPtoP_diag_save() | ObjectiveFunctionTest | [inline] |
test_LPtoP_diag_temp() | ObjectiveFunctionTest | [inline] |
test_LPtoP_diag_update() | ObjectiveFunctionTest | [inline] |
test_LPtoP_eval_accum() | ObjectiveFunctionTest | [inline] |
test_LPtoP_eval_calc() | ObjectiveFunctionTest | [inline] |
test_LPtoP_eval_save() | ObjectiveFunctionTest | [inline] |
test_LPtoP_eval_temp() | ObjectiveFunctionTest | [inline] |
test_LPtoP_eval_update() | ObjectiveFunctionTest | [inline] |
test_LPtoP_grad_calc() | ObjectiveFunctionTest | [inline] |
test_LPtoP_grad_save() | ObjectiveFunctionTest | [inline] |
test_LPtoP_grad_temp() | ObjectiveFunctionTest | [inline] |
test_LPtoP_grad_update() | ObjectiveFunctionTest | [inline] |
test_LPtoP_hess_calc() | ObjectiveFunctionTest | [inline] |
test_LPtoP_hess_save() | ObjectiveFunctionTest | [inline] |
test_LPtoP_hess_temp() | ObjectiveFunctionTest | [inline] |
test_LPtoP_hess_update() | ObjectiveFunctionTest | [inline] |
test_LPtoP_invalid_qm_diag() | ObjectiveFunctionTest | [inline] |
test_LPtoP_invalid_qm_eval() | ObjectiveFunctionTest | [inline] |
test_LPtoP_invalid_qm_grad() | ObjectiveFunctionTest | [inline] |
test_LPtoP_invalid_qm_hess() | ObjectiveFunctionTest | [inline] |
test_LPtoP_negate_flag_diag() | ObjectiveFunctionTest | [inline] |
test_LPtoP_negate_flag_eval() | ObjectiveFunctionTest | [inline] |
test_LPtoP_negate_flag_grad() | ObjectiveFunctionTest | [inline] |
test_LPtoP_negate_flag_hess() | ObjectiveFunctionTest | [inline] |
test_LPtoP_qm_error_diag() | ObjectiveFunctionTest | [inline] |
test_LPtoP_qm_error_eval() | ObjectiveFunctionTest | [inline] |
test_LPtoP_qm_error_grad() | ObjectiveFunctionTest | [inline] |
test_LPtoP_qm_error_hess() | ObjectiveFunctionTest | [inline] |
test_LPtoP_value(short P, bool scale, const std::vector< double > &values, OFTestMode mode) | ObjectiveFunctionTest | [private] |
test_max_clone() | ObjectiveFunctionTest | [inline] |
test_max_invalid_qm_eval() | ObjectiveFunctionTest | [inline] |
test_max_negate_flag(ObjectiveFunctionTemplate &OF) | ObjectiveFunctionTest | [private] |
test_max_negate_flag_eval() | ObjectiveFunctionTest | [inline] |
test_max_qm_error_eval() | ObjectiveFunctionTest | [inline] |
test_max_value(const std::vector< double > &values) | ObjectiveFunctionTest | [private] |
test_negate_flag(OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_value(const double *input_values, unsigned num_input_values, double expected_value, OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
values1 | ObjectiveFunctionTest | [private] |
values2 | ObjectiveFunctionTest | [private] |
