check_result(PatchData &pd, double power, double value, Vector3D *gradient=0, Matrix3D *Hessian=0) | PMeanPTemplateTest | [private] |
compare_diagonal_gradient(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_diagonal_gradient(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_diagonal_gradient_arithmatic() | PMeanPTemplateTest | [inline] |
compare_diagonal_gradient_rms() | PMeanPTemplateTest | [inline] |
compare_gradient_arithmatic() | PMeanPTemplateTest | [inline] |
compare_gradient_rms() | PMeanPTemplateTest | [inline] |
compare_hessian_arithmatic() | PMeanPTemplateTest | [inline] |
compare_hessian_diag_arithmatic() | PMeanPTemplateTest | [inline] |
compare_hessian_diag_rms() | PMeanPTemplateTest | [inline] |
compare_hessian_diagonal(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_hessian_diagonal(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_hessian_diagonal_arithmatic() | PMeanPTemplateTest | [inline] |
compare_hessian_diagonal_rms() | PMeanPTemplateTest | [inline] |
compare_hessian_gradient(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_hessian_gradient(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_hessian_gradient_arithmatic() | PMeanPTemplateTest | [inline] |
compare_hessian_gradient_rms() | PMeanPTemplateTest | [inline] |
compare_hessian_rms() | PMeanPTemplateTest | [inline] |
compare_numerical_gradient(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_numerical_gradient(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_numerical_hessian(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_numerical_hessian(ObjectiveFunction *of, bool diagonal_only) | ObjectiveFunctionTests | [static] |
compare_numerical_hessian_diagonal(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
CPPUNIT_TEST(test_eval_calc) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_eval_accum) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_eval_save) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_eval_update) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_eval_temp) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_grad_calc) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_grad_save) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_grad_update) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_grad_temp) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_diag_calc) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_diag_save) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_diag_update) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_diag_temp) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_Hess_calc) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_Hess_save) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_Hess_update) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_Hess_temp) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_clone) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_failed_metric_in_eval) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_failed_metric_in_grad) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_failed_metric_in_diag) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_failed_metric_in_Hess) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_false_metric_in_eval) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_false_metric_in_grad) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_false_metric_in_diag) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_false_metric_in_Hess) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_evaluate_arithmatic) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_evaluate_rms) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_gradient_arithmatic) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_gradient_rms) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_Hessian_arithmatic) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_Hessian_rms) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_gradient_arithmatic) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_gradient_rms) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_diagonal_gradient_arithmatic) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_diagonal_gradient_rms) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_hessian_gradient_arithmatic) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_hessian_gradient_rms) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_hessian_diagonal_arithmatic) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_hessian_diagonal_rms) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_hessian_arithmatic) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_hessian_rms) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_hessian_diag_arithmatic) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(compare_hessian_diag_rms) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_negate_eval) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_negate_grad) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_negate_diag) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST(test_negate_hess) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST_SUITE(PMeanPTemplateTest) | PMeanPTemplateTest | [private] |
CPPUNIT_TEST_SUITE_END() | PMeanPTemplateTest | [private] |
DIAG enum value | ObjectiveFunctionTests | |
EVAL enum value | ObjectiveFunctionTests | |
GRAD enum value | ObjectiveFunctionTests | |
HESS enum value | ObjectiveFunctionTests | |
mPatch | PMeanPTemplateTest | [private] |
OFTestMode enum name | ObjectiveFunctionTests | |
patch() | ObjectiveFunctionTests | [static] |
setUp() | PMeanPTemplateTest | |
test_clone() | PMeanPTemplateTest | [inline] |
ObjectiveFunctionTests::test_clone(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_diag_calc() | PMeanPTemplateTest | [inline] |
test_diag_save() | PMeanPTemplateTest | [inline] |
test_diag_temp() | PMeanPTemplateTest | [inline] |
test_diag_update() | PMeanPTemplateTest | [inline] |
test_diagonal(double power) | PMeanPTemplateTest | [private] |
test_diagonal_arithmatic() | PMeanPTemplateTest | [inline] |
test_diagonal_rms() | PMeanPTemplateTest | [inline] |
test_eval_accum() | PMeanPTemplateTest | [inline] |
test_eval_calc() | PMeanPTemplateTest | [inline] |
test_eval_save() | PMeanPTemplateTest | [inline] |
test_eval_temp() | PMeanPTemplateTest | [inline] |
test_eval_type(OFTestMode eval_func, ObjectiveFunction::EvalType type) | PMeanPTemplateTest | [private] |
ObjectiveFunctionTests::test_eval_type(ObjectiveFunction::EvalType, OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_eval_update() | PMeanPTemplateTest | [inline] |
test_evaluate(double power) | PMeanPTemplateTest | [private] |
test_evaluate_arithmatic() | PMeanPTemplateTest | [inline] |
test_evaluate_rms() | PMeanPTemplateTest | [inline] |
test_failed_metric_in_diag() | PMeanPTemplateTest | [inline] |
test_failed_metric_in_eval() | PMeanPTemplateTest | [inline] |
test_failed_metric_in_grad() | PMeanPTemplateTest | [inline] |
test_failed_metric_in_Hess() | PMeanPTemplateTest | [inline] |
test_false_metric_in_diag() | PMeanPTemplateTest | [inline] |
test_false_metric_in_eval() | PMeanPTemplateTest | [inline] |
test_false_metric_in_grad() | PMeanPTemplateTest | [inline] |
test_false_metric_in_Hess() | PMeanPTemplateTest | [inline] |
test_grad_calc() | PMeanPTemplateTest | [inline] |
test_grad_save() | PMeanPTemplateTest | [inline] |
test_grad_temp() | PMeanPTemplateTest | [inline] |
test_grad_update() | PMeanPTemplateTest | [inline] |
test_gradient(double power) | PMeanPTemplateTest | [private] |
test_gradient_arithmatic() | PMeanPTemplateTest | [inline] |
test_gradient_rms() | PMeanPTemplateTest | [inline] |
test_handles_invalid_qm(OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_handles_qm_error(OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_Hess_calc() | PMeanPTemplateTest | [inline] |
test_Hess_save() | PMeanPTemplateTest | [inline] |
test_Hess_temp() | PMeanPTemplateTest | [inline] |
test_Hess_update() | PMeanPTemplateTest | [inline] |
test_Hessian(double power) | PMeanPTemplateTest | [private] |
test_Hessian_arithmatic() | PMeanPTemplateTest | [inline] |
test_Hessian_rms() | PMeanPTemplateTest | [inline] |
test_negate_diag() | PMeanPTemplateTest | [inline] |
test_negate_eval() | PMeanPTemplateTest | [inline] |
test_negate_flag(OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_negate_grad() | PMeanPTemplateTest | [inline] |
test_negate_hess() | PMeanPTemplateTest | [inline] |
test_value(const double *input_values, unsigned num_input_values, double expected_value, OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
