check_higher_order_vertices_slaved(Mesh *mesh, Settings::HigherOrderSlaveMode mode, const std::map< Mesh::VertexHandle, bool > &expected) | PatchDataTest | [private] |
check_sub_patch(unsigned vtx, unsigned layers, PatchData &pd, PatchData &sub) | PatchDataTest | |
CPPUNIT_TEST(test_num_corners) | PatchDataTest | [private] |
CPPUNIT_TEST(test_get_element_vertex_indices) | PatchDataTest | [private] |
CPPUNIT_TEST(test_get_vertex_element_indices) | PatchDataTest | [private] |
CPPUNIT_TEST(test_get_element_vertex_coordinates) | PatchDataTest | [private] |
CPPUNIT_TEST(test_move_free_vertices_constrained) | PatchDataTest | [private] |
CPPUNIT_TEST(test_movement_function) | PatchDataTest | [private] |
CPPUNIT_TEST(test_get_adj_elems_2d) | PatchDataTest | [private] |
CPPUNIT_TEST(test_get_minmax_element_area) | PatchDataTest | [private] |
CPPUNIT_TEST(test_sub_patch) | PatchDataTest | [private] |
CPPUNIT_TEST(test_fill) | PatchDataTest | [private] |
CPPUNIT_TEST(test_reorder) | PatchDataTest | [private] |
CPPUNIT_TEST(test_update_slave_node_coords) | PatchDataTest | [private] |
CPPUNIT_TEST(test_patch_data_fill_slaved_ho_nodes) | PatchDataTest | [private] |
CPPUNIT_TEST(test_patch_reorder_ho_nodes) | PatchDataTest | [private] |
CPPUNIT_TEST(test_patch_data_fill_free_ho_nodes) | PatchDataTest | [private] |
CPPUNIT_TEST(test_patch_data_mesh_slaved_ho_nodes) | PatchDataTest | [private] |
CPPUNIT_TEST(test_patch_data_mesh_free_ho_nodes) | PatchDataTest | [private] |
CPPUNIT_TEST(test_patch_data_mesh_calcualted_ho_nodes) | PatchDataTest | [private] |
CPPUNIT_TEST(test_patch_data_mesh_flagged_ho_nodes) | PatchDataTest | [private] |
CPPUNIT_TEST(test_vertex_verts_fixed) | PatchDataTest | [private] |
CPPUNIT_TEST(test_curve_verts_fixed) | PatchDataTest | [private] |
CPPUNIT_TEST(test_surf_verts_fixed) | PatchDataTest | [private] |
CPPUNIT_TEST_SUITE(PatchDataTest) | PatchDataTest | [private] |
CPPUNIT_TEST_SUITE_END() | PatchDataTest | [private] |
get_higher_order_vertices(Mesh *mesh, std::map< Mesh::VertexHandle, bool > &ho_verts, bool initial_value=false, bool non_fixed_only=true) | PatchDataTest | [private] |
get_quad8_mesh(Mesh *&mesh_out) | PatchDataTest | [private] |
get_quad8_mesh_and_domain(Mesh *&mesh_out, MeshDomain *&domain_out) | PatchDataTest | [private] |
mPatch2D | PatchDataTest | [private] |
PatchDataTest() | PatchDataTest | [inline] |
quad1 | PatchDataTest | [private] |
setUp() | PatchDataTest | [inline] |
tearDown() | PatchDataTest | [inline] |
test_curve_verts_fixed() | PatchDataTest | [inline] |
test_fill() | PatchDataTest | [inline] |
test_fixed_by_geom_dim(unsigned dim) | PatchDataTest | |
test_get_adj_elems_2d() | PatchDataTest | [inline] |
test_get_element_vertex_coordinates() | PatchDataTest | [inline] |
test_get_element_vertex_indices() | PatchDataTest | [inline] |
test_get_minmax_element_area() | PatchDataTest | [inline] |
test_get_vertex_element_indices() | PatchDataTest | [inline] |
test_move_free_vertices_constrained() | PatchDataTest | [inline] |
test_movement_function() | PatchDataTest | [inline] |
test_num_corners() | PatchDataTest | [inline] |
test_patch_contents(bool reorder) | PatchDataTest | |
test_patch_data_fill_free_ho_nodes() | PatchDataTest | [inline] |
test_patch_data_fill_slaved_ho_nodes() | PatchDataTest | [inline] |
test_patch_data_mesh_calcualted_ho_nodes() | PatchDataTest | |
test_patch_data_mesh_flagged_ho_nodes() | PatchDataTest | |
test_patch_data_mesh_free_ho_nodes() | PatchDataTest | |
test_patch_data_mesh_slaved_ho_nodes() | PatchDataTest | |
test_patch_reorder_ho_nodes() | PatchDataTest | [inline] |
test_quad8_patch(bool reorder, bool ho_nodes_slaved) | PatchDataTest | [private] |
test_reorder() | PatchDataTest | [inline] |
test_sub_patch() | PatchDataTest | |
test_surf_verts_fixed() | PatchDataTest | [inline] |
test_update_slave_node_coords() | PatchDataTest | |
test_vertex_verts_fixed() | PatchDataTest | [inline] |
tri1 | PatchDataTest | [private] |
tri2 | PatchDataTest | [private] |
vtx_0_0 | PatchDataTest | [private] |
vtx_0_1 | PatchDataTest | [private] |
vtx_1_0 | PatchDataTest | [private] |
vtx_1_1 | PatchDataTest | [private] |
vtx_2_0 | PatchDataTest | [private] |
vtx_2_1 | PatchDataTest | [private] |
