QualityMetricTest Member List
This is the complete list of members for QualityMetricTest, including all inherited members.
compare_gradient(QualityMetric &qm, PatchData &pd, size_t sample, double value, const std::vector< size_t > &indices, const std::vector< Vector3D > &grad)QualityMetricTest
compare_indices(QualityMetric &qm, PatchData &pd, size_t sample, double value, const std::vector< size_t > &indices)QualityMetricTest
CPPUNIT_TEST(test_fixed_vertex_list)QualityMetricTest [private]
CPPUNIT_TEST(test_remove_fixed_gradients)QualityMetricTest [private]
CPPUNIT_TEST(test_remove_fixed_hessians)QualityMetricTest [private]
CPPUNIT_TEST(test_gradient_constant)QualityMetricTest [private]
CPPUNIT_TEST(test_gradient_linear)QualityMetricTest [private]
CPPUNIT_TEST(test_gradient_parabolic)QualityMetricTest [private]
CPPUNIT_TEST(test_gradient_tau)QualityMetricTest [private]
CPPUNIT_TEST(test_Hessian_constant)QualityMetricTest [private]
CPPUNIT_TEST(test_Hessian_linear)QualityMetricTest [private]
CPPUNIT_TEST(test_Hessian_parabolic)QualityMetricTest [private]
CPPUNIT_TEST(test_Hessian_tau)QualityMetricTest [private]
CPPUNIT_TEST(test_diagonal_constant)QualityMetricTest [private]
CPPUNIT_TEST(test_diagonal_linear)QualityMetricTest [private]
CPPUNIT_TEST(test_diagonal_parabolic)QualityMetricTest [private]
CPPUNIT_TEST(test_diagonal_tau)QualityMetricTest [private]
CPPUNIT_TEST_SUITE(QualityMetricTest)QualityMetricTest [private]
CPPUNIT_TEST_SUITE_END()QualityMetricTest [private]
setUp()QualityMetricTest
test_diagonal_constant()QualityMetricTest
test_diagonal_linear()QualityMetricTest
test_diagonal_parabolic()QualityMetricTest
test_diagonal_tau()QualityMetricTest
test_fixed_vertex_list()QualityMetricTest
test_gradient_constant()QualityMetricTest
test_gradient_linear()QualityMetricTest
test_gradient_parabolic()QualityMetricTest
test_gradient_tau()QualityMetricTest
test_Hessian_constant()QualityMetricTest
test_Hessian_linear()QualityMetricTest
test_Hessian_parabolic()QualityMetricTest
test_Hessian_tau()QualityMetricTest
test_remove_fixed_gradients()QualityMetricTest
test_remove_fixed_hessians()QualityMetricTest
tri_pdQualityMetricTest [private]
