QualityMetricTester Member List
This is the complete list of members for QualityMetricTester, including all inherited members.
ALL enum valueQualityMetricTester
ALL_FE enum valueQualityMetricTester
ALL_FE_EXCEPT_SEPTAHEDRON enum valueQualityMetricTester
compare_analytical_and_numerical_diagonals(QualityMetric *qm)QualityMetricTester
compare_analytical_and_numerical_diagonals(QualityMetric *qm, PatchData &pd)QualityMetricTester
compare_analytical_and_numerical_gradients(QualityMetric *qm)QualityMetricTester
compare_analytical_and_numerical_gradients(QualityMetric *qm, PatchData &pd)QualityMetricTester
compare_analytical_and_numerical_hessians(QualityMetric *qm)QualityMetricTester
compare_analytical_and_numerical_hessians(QualityMetric *qm, PatchData &pd)QualityMetricTester
compare_eval_and_eval_with_indices(QualityMetric *qm)QualityMetricTester
compare_eval_and_eval_with_indices(QualityMetric *qm, PatchData &pd)QualityMetricTester
compare_eval_with_diag_and_eval_with_hessian(QualityMetric *qm)QualityMetricTester
compare_eval_with_diag_and_eval_with_hessian(QualityMetric *qm, PatchData &pd)QualityMetricTester
compare_eval_with_grad_and_eval_with_diagonal(QualityMetric *qm)QualityMetricTester
compare_eval_with_grad_and_eval_with_diagonal(QualityMetric *qm, PatchData &pd)QualityMetricTester
compare_eval_with_grad_and_eval_with_hessian(QualityMetric *qm)QualityMetricTester
compare_eval_with_grad_and_eval_with_hessian(QualityMetric *qm, PatchData &pd)QualityMetricTester
compare_eval_with_indices_and_eval_with_diagonal(QualityMetric *qm)QualityMetricTester
compare_eval_with_indices_and_eval_with_diagonal(QualityMetric *qm, PatchData &pd)QualityMetricTester
compare_eval_with_indices_and_eval_with_gradient(QualityMetric *qm)QualityMetricTester
compare_eval_with_indices_and_eval_with_gradient(QualityMetric *qm, PatchData &pd)QualityMetricTester
compare_eval_with_indices_and_eval_with_hessian(QualityMetric *qm)QualityMetricTester
compare_eval_with_indices_and_eval_with_hessian(QualityMetric *qm, PatchData &pd)QualityMetricTester
degenHexPyramidQualityMetricTester [private]
ElemTypeGroup enum nameQualityMetricTester
geomPlaneQualityMetricTester [private]
get_degenerate_element(EntityTopology type, PatchData &pd)QualityMetricTester
get_ideal_element(EntityTopology type, bool unit_area, PatchData &pd, bool first_vertex_fixed=false)QualityMetricTester
get_ideal_element(EntityTopology type, bool unit_area, PatchData &pd, int free_vertex_index)QualityMetricTester
get_ideal_hexes(PatchData &pd)QualityMetricTester
get_ideal_quads(PatchData &pd)QualityMetricTester
get_ideal_tris(PatchData &pd, bool unit_area)QualityMetricTester
get_inverted_element(EntityTopology type, PatchData &pd)QualityMetricTester
get_nonideal_element(EntityTopology type, PatchData &pd, bool first_vertex_fixed=false)QualityMetricTester
get_nonideal_element(EntityTopology type, PatchData &pd, int free_vertex_index)QualityMetricTester
get_zero_element(EntityTopology type, PatchData &pd)QualityMetricTester
ideal_pyramid_base_equals_height(bool flag)QualityMetricTester [inline]
mSettingsQualityMetricTester [private]
NON_MIXED_FE enum valueQualityMetricTester
QualityMetricTester(ElemTypeGroup group, const Settings *set=0)QualityMetricTester
QualityMetricTester(const EntityTopology *supported_elem_types, size_t supported_elem_types_len, const Settings *set=0)QualityMetricTester
SIMPLICIES enum valueQualityMetricTester
test_diagonal_with_fixed_vertex(QualityMetric *qm, const Settings *settings=0)QualityMetricTester
test_diagonal_with_fixed_vertex(EntityTopology type, QualityMetric *qm, const Settings *settings=0)QualityMetricTester
test_domain_deviation_gradient(QualityMetric *qm)QualityMetricTester
test_domain_deviation_quality(QualityMetric *qm)QualityMetricTester
test_evaluate_degenerate_element(QualityMetric *qm, bool should_succeed)QualityMetricTester
test_evaluate_inverted_element(QualityMetric *qm, bool should_succeed)QualityMetricTester
test_evaluate_unit_edge_element(QualityMetric *qm, EntityTopology type, double value)QualityMetricTester
test_evaluate_unit_edge_tris_about_vertex(QualityMetric *qm, double expected_val)QualityMetricTester
test_evaluate_unit_element(QualityMetric *qm, EntityTopology type, double value)QualityMetricTester
test_evaluate_unit_hexes_about_vertex(QualityMetric *qm, double expected_val)QualityMetricTester
test_evaluate_unit_quads_about_vertex(QualityMetric *qm, double expected_val)QualityMetricTester
test_evaluate_unit_tris_about_vertex(QualityMetric *qm, double expected_val)QualityMetricTester
test_evaluate_zero_element(QualityMetric *qm, bool should_succeed)QualityMetricTester
test_get_edge_evaluations(EdgeQM *qm)QualityMetricTester
test_get_edge_indices(EdgeQM *qm)QualityMetricTester
test_get_element_evaluations(QualityMetric *qm)QualityMetricTester
test_get_element_indices(QualityMetric *qm)QualityMetricTester
test_get_in_element_evaluations(ElemSampleQM *qm)QualityMetricTester
test_get_indices_fixed(QualityMetric *qm)QualityMetricTester
test_get_sample_evaluations(QualityMetric *qm)QualityMetricTester
test_get_sample_indices(QualityMetric *qm)QualityMetricTester
test_get_vertex_evaluations(QualityMetric *qm)QualityMetricTester
test_get_vertex_indices(QualityMetric *qm)QualityMetricTester
test_grad_location_invariant(QualityMetric *qm, bool untangler=false)QualityMetricTester
test_grad_orient_invariant(QualityMetric *qm, bool untangler=false)QualityMetricTester
test_grad_transform_invariant(QualityMetric *qm, PatchXform &transform, bool untangler)QualityMetricTester
test_gradient_reflects_quality(QualityMetric *qm)QualityMetricTester
test_gradient_with_fixed_vertex(QualityMetric *qm, const Settings *settings=0)QualityMetricTester
test_gradient_with_fixed_vertex(EntityTopology type, QualityMetric *qm, const Settings *settings=0)QualityMetricTester
test_hessian_location_invariant(QualityMetric *qm, bool untangler=false)QualityMetricTester
test_hessian_transform_invariant(QualityMetric *qm, PatchXform &transform, bool untangler)QualityMetricTester
test_hessian_with_fixed_vertex(QualityMetric *qm, const Settings *settings=0)QualityMetricTester
test_hessian_with_fixed_vertex(EntityTopology type, QualityMetric *qm, const Settings *settings=0)QualityMetricTester
test_ideal_element_positive_definite_Hessian(QualityMetric *qm, bool unit_area)QualityMetricTester
test_ideal_element_zero_gradient(QualityMetric *qm, bool unit_area)QualityMetricTester
test_ideal_element_zero_vertex_gradient(QualityMetric *qm, bool unit_area)QualityMetricTester
test_location_invariant(QualityMetric *qm, bool untangler=false)QualityMetricTester
test_measures_in_plane_orientation(QualityMetric *qm)QualityMetricTester
test_measures_out_of_plane_orientation(QualityMetric *qm)QualityMetricTester
test_measures_quality(QualityMetric *qm)QualityMetricTester
test_measures_size(QualityMetric *qm, bool unit_area)QualityMetricTester
test_measures_transform(QualityMetric *qm, PatchXform &transform, bool unit_area)QualityMetricTester
test_measures_vertex_quality(QualityMetric *qm)QualityMetricTester
test_orient_invariant(QualityMetric *qm, bool untangler=false)QualityMetricTester
test_scale_invariant(QualityMetric *qm, bool untangler=false)QualityMetricTester
test_supported_element_types(QualityMetric *qm)QualityMetricTester
test_symmetric_Hessian_diagonal_blocks(QualityMetric *qm)QualityMetricTester
test_transform_invariant(QualityMetric *qm, PatchXform &transform, bool untangler)QualityMetricTester
test_type_is_not_supported(EntityTopology type, QualityMetric *qm)QualityMetricTester [private]
test_type_is_supported(EntityTopology type, QualityMetric *qm)QualityMetricTester [private]
test_vertex_gradient_reflects_quality(QualityMetric *qm)QualityMetricTester
THREE_D enum valueQualityMetricTester
THREE_D_FE enum valueQualityMetricTester
THREE_D_FE_EXCEPT_SEPTAHEDRON enum valueQualityMetricTester
THREE_D_NON_MIXED_FE enum valueQualityMetricTester
TWO_D enum valueQualityMetricTester
TWO_D_FE enum valueQualityMetricTester
type_is_supported(EntityTopology type)QualityMetricTester [inline, private]
typesQualityMetricTester [private]
