, including all inherited members.
compare_diagonal_gradient(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_diagonal_gradient(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_hessian_diagonal(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_hessian_diagonal(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_hessian_gradient(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_hessian_gradient(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_numerical_gradient(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_numerical_gradient(ObjectiveFunction *of) | ObjectiveFunctionTests | [static] |
compare_numerical_hessian(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
compare_numerical_hessian(ObjectiveFunction *of, bool diagonal_only) | ObjectiveFunctionTests | [static] |
compare_numerical_hessian_diagonal(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [inline, static] |
CPPUNIT_TEST(test_eval_calc) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_accum) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_save) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_update) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_temp) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_calc_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_accum_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_save_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_update_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_temp_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_calc) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_save) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_update) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_temp) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_calc_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_save_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_update_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_temp_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_calc) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_save) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_update) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_temp) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_calc_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_save_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_update_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_temp_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_hessian_fails) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_hessian_fails_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_failed_metric_in_eval) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_failed_metric_in_grad) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_failed_metric_in_eval_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_failed_metric_in_grad_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_false_metric_in_eval) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_false_metric_in_grad) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_false_metric_in_eval_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_false_metric_in_grad_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_evaluate) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_evaluate_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_numerical_gradient) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_numerical_gradient_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diagonal_gradient) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diagonal_gradient_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_hessian_diag) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_hessian_diag_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_clone) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_clone_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_negate) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_eval_negate_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_negate) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_grad_negate_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_negate) | StdDevTemplateTest | [private] |
CPPUNIT_TEST(test_diag_negate_sqr) | StdDevTemplateTest | [private] |
CPPUNIT_TEST_SUITE(StdDevTemplateTest) | StdDevTemplateTest | [private] |
CPPUNIT_TEST_SUITE_END() | StdDevTemplateTest | [private] |
DIAG enum value | ObjectiveFunctionTests | |
EVAL enum value | ObjectiveFunctionTests | |
GRAD enum value | ObjectiveFunctionTests | |
HESS enum value | ObjectiveFunctionTests | |
OFTestMode enum name | ObjectiveFunctionTests | |
patch() | ObjectiveFunctionTests | [static] |
test_clone() | StdDevTemplateTest | [inline] |
ObjectiveFunctionTests::test_clone(ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_clone_sqr() | StdDevTemplateTest | [inline] |
test_diag_accum() | StdDevTemplateTest | [inline] |
test_diag_accum_sqr() | StdDevTemplateTest | [inline] |
test_diag_calc() | StdDevTemplateTest | [inline] |
test_diag_calc_sqr() | StdDevTemplateTest | [inline] |
test_diag_negate() | StdDevTemplateTest | [inline] |
test_diag_negate_sqr() | StdDevTemplateTest | [inline] |
test_diag_save() | StdDevTemplateTest | [inline] |
test_diag_save_sqr() | StdDevTemplateTest | [inline] |
test_diag_temp() | StdDevTemplateTest | [inline] |
test_diag_temp_sqr() | StdDevTemplateTest | [inline] |
test_diag_update() | StdDevTemplateTest | [inline] |
test_diag_update_sqr() | StdDevTemplateTest | [inline] |
test_diagonal_gradient() | StdDevTemplateTest | [inline] |
test_diagonal_gradient_sqr() | StdDevTemplateTest | [inline] |
test_eval_accum() | StdDevTemplateTest | [inline] |
test_eval_accum_sqr() | StdDevTemplateTest | [inline] |
test_eval_calc() | StdDevTemplateTest | [inline] |
test_eval_calc_sqr() | StdDevTemplateTest | [inline] |
test_eval_negate() | StdDevTemplateTest | [inline] |
test_eval_negate_sqr() | StdDevTemplateTest | [inline] |
test_eval_save() | StdDevTemplateTest | [inline] |
test_eval_save_sqr() | StdDevTemplateTest | [inline] |
test_eval_temp() | StdDevTemplateTest | [inline] |
test_eval_temp_sqr() | StdDevTemplateTest | [inline] |
test_eval_type(ObjectiveFunction::EvalType, OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_eval_update() | StdDevTemplateTest | [inline] |
test_eval_update_sqr() | StdDevTemplateTest | [inline] |
test_evaluate() | StdDevTemplateTest | |
test_evaluate_sqr() | StdDevTemplateTest | |
test_failed_metric_in_eval() | StdDevTemplateTest | [inline] |
test_failed_metric_in_eval_sqr() | StdDevTemplateTest | [inline] |
test_failed_metric_in_grad() | StdDevTemplateTest | [inline] |
test_failed_metric_in_grad_sqr() | StdDevTemplateTest | [inline] |
test_false_metric_in_eval() | StdDevTemplateTest | [inline] |
test_false_metric_in_eval_sqr() | StdDevTemplateTest | [inline] |
test_false_metric_in_grad() | StdDevTemplateTest | [inline] |
test_false_metric_in_grad_sqr() | StdDevTemplateTest | [inline] |
test_grad_accum() | StdDevTemplateTest | [inline] |
test_grad_accum_sqr() | StdDevTemplateTest | [inline] |
test_grad_calc() | StdDevTemplateTest | [inline] |
test_grad_calc_sqr() | StdDevTemplateTest | [inline] |
test_grad_negate() | StdDevTemplateTest | [inline] |
test_grad_negate_sqr() | StdDevTemplateTest | [inline] |
test_grad_save() | StdDevTemplateTest | [inline] |
test_grad_save_sqr() | StdDevTemplateTest | [inline] |
test_grad_temp() | StdDevTemplateTest | [inline] |
test_grad_temp_sqr() | StdDevTemplateTest | [inline] |
test_grad_update() | StdDevTemplateTest | [inline] |
test_grad_update_sqr() | StdDevTemplateTest | [inline] |
test_handles_invalid_qm(OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_handles_qm_error(OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_hessian_diag() | StdDevTemplateTest | [inline] |
test_hessian_diag_sqr() | StdDevTemplateTest | [inline] |
test_hessian_fails() | StdDevTemplateTest | |
test_hessian_fails_sqr() | StdDevTemplateTest | |
test_negate_flag(OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
test_numerical_gradient() | StdDevTemplateTest | [inline] |
test_numerical_gradient_sqr() | StdDevTemplateTest | [inline] |
test_value(const double *input_values, unsigned num_input_values, double expected_value, OFTestMode test_mode, ObjectiveFunctionTemplate *of) | ObjectiveFunctionTests | [static] |
