TMetricTest< Metric, DIM > Member List
This is the complete list of members for TMetricTest< Metric, DIM >, including all inherited members.
ATMetricTest< Metric, DIM >
BTMetricTest< Metric, DIM >
BarrierTMetricTest< Metric, DIM > [private]
CTMetricTest< Metric, DIM >
compare_anaytic_and_numeric_grads()TMetricTest< Metric, DIM >
compare_anaytic_and_numeric_hess()TMetricTest< Metric, DIM >
compare_eval_and_eval_with_grad()TMetricTest< Metric, DIM >
compare_eval_with_grad_and_eval_with_hess()TMetricTest< Metric, DIM >
CPPUNIT_TEST(test_numerical_gradient_2D)TMetricTest< Metric, DIM > [private]
CPPUNIT_TEST(test_numerical_hessian_2D)TMetricTest< Metric, DIM > [private]
CPPUNIT_TEST(test_numerical_gradient_3D)TMetricTest< Metric, DIM > [private]
CPPUNIT_TEST(test_numerical_hessian_3D)TMetricTest< Metric, DIM > [private]
CPPUNIT_TEST_SUITE(TMetricTest)TMetricTest< Metric, DIM > [private]
CPPUNIT_TEST_SUITE_END()TMetricTest< Metric, DIM > [private]
eval(TMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqError &err)TMetricTest< Metric, DIM > [inline, private]
eval(AWMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqError &err)TMetricTest< Metric, DIM > [inline, private]
grad(TMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqMatrix< DIM, DIM > &dmdA, MsqError &err)TMetricTest< Metric, DIM > [inline, private]
grad(AWMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqMatrix< DIM, DIM > &dmdA, MsqError &err)TMetricTest< Metric, DIM > [inline, private]
hess(TMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqMatrix< DIM, DIM > &dmdA, MsqMatrix< DIM, DIM > d2mdA2[3], MsqError &err)TMetricTest< Metric, DIM > [inline, private]
hess(AWMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqMatrix< DIM, DIM > &dmdA, MsqMatrix< DIM, DIM > d2mdA2[3], MsqError &err)TMetricTest< Metric, DIM > [inline, private]
ITMetricTest< Metric, DIM >
idealValTMetricTest< Metric, DIM > [private]
Matrix typedefTMetricTest< Metric, DIM >
num_grad(TMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqMatrix< DIM, DIM > &dmdA, MsqError &err)TMetricTest< Metric, DIM > [inline, private]
num_grad(AWMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqMatrix< DIM, DIM > &dmdA, MsqError &err)TMetricTest< Metric, DIM > [inline, private]
num_hess(TMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqMatrix< DIM, DIM > &dmdA, MsqMatrix< DIM, DIM > d2mdA2[3], MsqError &err)TMetricTest< Metric, DIM > [inline, private]
num_hess(AWMetric &metric, MsqMatrix< DIM, DIM > A, MsqMatrix< DIM, DIM > W, double &value, MsqMatrix< DIM, DIM > &dmdA, MsqMatrix< DIM, DIM > d2mdA2[3], MsqError &err)TMetricTest< Metric, DIM > [inline, private]
orientInvariantTMetricTest< Metric, DIM > [private]
shapeInvariantTMetricTest< Metric, DIM > [private]
sizeInvariantTMetricTest< Metric, DIM > [private]
test_ideal_eval()TMetricTest< Metric, DIM >
test_ideal_gradient()TMetricTest< Metric, DIM >
test_inverted()TMetricTest< Metric, DIM >
test_non_ideal(bool sensitive, Matrix A, Matrix W)TMetricTest< Metric, DIM > [private]
test_numerical_gradient_2D()TMetricTest< Metric, DIM >
test_numerical_gradient_3D()TMetricTest< Metric, DIM >
test_numerical_hessian_2D()TMetricTest< Metric, DIM >
test_numerical_hessian_3D()TMetricTest< Metric, DIM >
test_orient()TMetricTest< Metric, DIM >
test_scale()TMetricTest< Metric, DIM >
test_shape()TMetricTest< Metric, DIM >
testMetricTMetricTest< Metric, DIM > [private]
TMetricTest(bool shape_invariant, bool size_invariant, bool orient_invariant, bool barrier, double ideal_val)TMetricTest< Metric, DIM > [inline]
ZeroTMetricTest< Metric, DIM >
