center_qm | TMPQualityMetricTest< TQualityMetric > | [protected] |
centerOnly | TMPQualityMetricTest< TQualityMetric > | [protected] |
compare_analytical_and_numerical_diagonals() | TMPQualityMetricTest< TQualityMetric > | [inline] |
compare_analytical_and_numerical_diagonals(QualityMetric *qm) | TMPQualityMetricTest< TQualityMetric > | |
compare_analytical_and_numerical_gradient() | TMPQualityMetricTest< TQualityMetric > | [inline] |
compare_analytical_and_numerical_gradients(QualityMetric *qm) | TMPQualityMetricTest< TQualityMetric > | [inline] |
compare_analytical_and_numerical_gradients(QualityMetric *qm, PatchData &, int dim) | TMPQualityMetricTest< TQualityMetric > | |
compare_analytical_and_numerical_hessians() | TMPQualityMetricTest< TQualityMetric > | [inline] |
compare_analytical_and_numerical_hessians(QualityMetric *qm) | TMPQualityMetricTest< TQualityMetric > | |
compare_gradient_and_diagonal() | TMPQualityMetricTest< TQualityMetric > | [inline] |
compare_gradient_and_hessian() | TMPQualityMetricTest< TQualityMetric > | [inline] |
compare_indices_and_diagonal() | TMPQualityMetricTest< TQualityMetric > | [inline] |
compare_indices_and_gradient() | TMPQualityMetricTest< TQualityMetric > | [inline] |
compare_indices_and_hessian() | TMPQualityMetricTest< TQualityMetric > | [inline] |
CPPUNIT_TEST(test_inverse_mean_ratio_grad) | TQualityMetricTest | [private] |
CPPUNIT_TEST(test_inverse_mean_ratio_hess) | TQualityMetricTest | [private] |
CPPUNIT_TEST(test_inverse_mean_ratio_hess_diag) | TQualityMetricTest | [private] |
CPPUNIT_TEST(regression_inverse_mean_ratio_grad) | TQualityMetricTest | [private] |
CPPUNIT_TEST(regression_inverse_mean_ratio_hess) | TQualityMetricTest | [private] |
CPPUNIT_TEST_SUITE(TQualityMetricTest) | TQualityMetricTest | [private] |
CPPUNIT_TEST_SUITE_END() | TQualityMetricTest | [private] |
e_weight | TMPQualityMetricTest< TQualityMetric > | [protected] |
faux_pi | TMPQualityMetricTest< TQualityMetric > | [protected] |
faux_two | TMPQualityMetricTest< TQualityMetric > | [protected] |
faux_zero | TMPQualityMetricTest< TQualityMetric > | [protected] |
get_nonideal_element(EntityTopology type, PatchData &pd) | TMPQualityMetricTest< TQualityMetric > | [inline] |
hexCenter | TMPQualityMetricTest< TQualityMetric > | [protected] |
ideal | TMPQualityMetricTest< TQualityMetric > | [protected] |
num_metric | TMPQualityMetricTest< TQualityMetric > | [protected] |
priCenter | TMPQualityMetricTest< TQualityMetric > | [protected] |
pyrCenter | TMPQualityMetricTest< TQualityMetric > | [protected] |
quadCenter | TMPQualityMetricTest< TQualityMetric > | [protected] |
regression_inverse_mean_ratio_grad() | TQualityMetricTest | |
regression_inverse_mean_ratio_hess() | TQualityMetricTest | |
settings | TMPQualityMetricTest< TQualityMetric > | [protected] |
surf_target | TMPQualityMetricTest< TQualityMetric > | [protected] |
test_2d_eval_ortho_quad() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_3d_eval_ortho_hex() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_diagonal_with_fixed_vertices() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_evaluate_2D() | TMPQualityMetricTest< TQualityMetric > | |
test_evaluate_2D_weight() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_evaluate_3D() | TMPQualityMetricTest< TQualityMetric > | |
test_evaluate_3D_weight() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_evaluate_fixed_indices() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_evaluate_surface() | TMPQualityMetricTest< TQualityMetric > | |
test_evaluate_surface_weight() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_evaluate_with_indices() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_get_element_evaluations() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_get_evaluations() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_gradient_2D() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_gradient_3D() | TMPQualityMetricTest< TQualityMetric > | |
test_gradient_common(TargetCalculator *tc) | TMPQualityMetricTest< TQualityMetric > | |
test_gradient_surface() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_gradient_with_fixed_vertices() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_hessian_with_fixed_vertices() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_ideal_element_gradient() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_inverse_mean_ratio_grad() | TQualityMetricTest | |
test_inverse_mean_ratio_hess() | TQualityMetricTest | |
test_inverse_mean_ratio_hess_diag() | TQualityMetricTest | |
test_metric | TMPQualityMetricTest< TQualityMetric > | [protected] |
test_negate_flag() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_qm | TMPQualityMetricTest< TQualityMetric > | [protected] |
test_qm_surf | TMPQualityMetricTest< TQualityMetric > | [protected] |
test_sample_indices() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_supported_types() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_surf_eval_ortho_quad() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_symmetric_hessian_diagonal() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_weighted_diagonals() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_weighted_gradients() | TMPQualityMetricTest< TQualityMetric > | [inline] |
test_weighted_hessians() | TMPQualityMetricTest< TQualityMetric > | [inline] |
tester | TMPQualityMetricTest< TQualityMetric > | [protected] |
tetCenter | TMPQualityMetricTest< TQualityMetric > | [protected] |
TMPQualityMetricTest() | TMPQualityMetricTest< TQualityMetric > | [inline] |
triCenter | TMPQualityMetricTest< TQualityMetric > | [protected] |
weight_qm | TMPQualityMetricTest< TQualityMetric > | [protected] |
zero_qm | TMPQualityMetricTest< TQualityMetric > | [protected] |
