, including all inherited members.
| A_is_in_B(const EntityHandle volume_A, const EntityHandle volume_B, GeomQueryTool *GQT) | moab::GeomTopoTool | [private] |
| add_geo_set(EntityHandle set, int dimension, int global_id=0) | moab::GeomTopoTool | |
| check_edge_sense_tags(bool create=false) | moab::GeomTopoTool | [private] |
| check_face_sense_tag(bool create=false) | moab::GeomTopoTool | [private] |
| check_geom_tag(bool create=false) | moab::GeomTopoTool | [private] |
| check_gid_tag(bool create=false) | moab::GeomTopoTool | [private] |
| check_model() | moab::GeomTopoTool | |
| construct_obb_tree(EntityHandle eh) | moab::GeomTopoTool | |
| construct_obb_trees(bool make_one_vol=false) | moab::GeomTopoTool | |
| construct_vertex_ranges(const Range &geom_sets, const Tag verts_tag) | moab::GeomTopoTool | [private] |
| delete_all_obb_trees() | moab::GeomTopoTool | |
| delete_obb_tree(EntityHandle gset, bool vol_only=false) | moab::GeomTopoTool | |
| dimension(EntityHandle this_set) | moab::GeomTopoTool | |
| duplicate_model(GeomTopoTool *&duplicate, std::vector< EntityHandle > *pvGEnts=NULL) | moab::GeomTopoTool | |
| entity_by_id(int dimension, int id) | moab::GeomTopoTool | |
| find_geomsets(Range *ranges=NULL) | moab::GeomTopoTool | |
| generate_implicit_complement(EntityHandle &implicit_complement_set) | moab::GeomTopoTool | [private] |
| geometrize_surface_set(EntityHandle surface, EntityHandle &output) | moab::GeomTopoTool | |
| geomRanges | moab::GeomTopoTool | [private] |
| geomTag | moab::GeomTopoTool | [private] |
| GeomTopoTool(Interface *impl, bool find_geoments=false, EntityHandle modelRootSet=0, bool p_rootSets_vector=true, bool restore_rootSets=true) | moab::GeomTopoTool | |
| geoRanges() | moab::GeomTopoTool | [inline] |
| get_bounding_coords(EntityHandle volume, double minPt[3], double maxPt[3]) | moab::GeomTopoTool | |
| get_ct_children_by_dimension(const EntityHandle parent, const int desired_dimension) | moab::GeomTopoTool | [private] |
| get_geom_tag() | moab::GeomTopoTool | [inline] |
| get_gid_tag() | moab::GeomTopoTool | [inline] |
| get_gsets_by_dimension(int dim, Range &gset) | moab::GeomTopoTool | |
| get_implicit_complement(EntityHandle &implicit_complement) | moab::GeomTopoTool | |
| get_moab_instance() | moab::GeomTopoTool | [inline] |
| get_obb(EntityHandle volume, double center[3], double axis1[3], double axis2[3], double axis3[3]) | moab::GeomTopoTool | |
| get_one_vol_root() | moab::GeomTopoTool | [inline] |
| get_root(EntityHandle vol_or_surf, EntityHandle &root) | moab::GeomTopoTool | [inline] |
| get_root_model_set() | moab::GeomTopoTool | [inline] |
| get_sense(EntityHandle entity, EntityHandle wrt_entity, int &sense) | moab::GeomTopoTool | |
| get_sense_tag() | moab::GeomTopoTool | [inline] |
| get_senses(EntityHandle entity, std::vector< EntityHandle > &wrt_entities, std::vector< int > &senses) | moab::GeomTopoTool | |
| get_surface_senses(EntityHandle volume, int num_surfs, const EntityHandle *surfs, int *senses_out) | moab::GeomTopoTool | |
| get_surface_senses(EntityHandle surface_ent, EntityHandle &forward_vol, EntityHandle &reverse_vol) | moab::GeomTopoTool | |
| gidTag | moab::GeomTopoTool | [private] |
| global_id(EntityHandle this_set) | moab::GeomTopoTool | |
| have_obb_tree() | moab::GeomTopoTool | |
| impl_compl_handle | moab::GeomTopoTool | [private] |
| insert_in_tree(const EntityHandle ct_root, const EntityHandle volume, GeomQueryTool *GQT) | moab::GeomTopoTool | [private] |
| is_implicit_complement(EntityHandle volume) | moab::GeomTopoTool | [inline] |
| is_owned_set(EntityHandle eh) | moab::GeomTopoTool | |
| m_rootSets_vector | moab::GeomTopoTool | [private] |
| mapRootSets | moab::GeomTopoTool | [private] |
| maxGlobalId | moab::GeomTopoTool | [private] |
| mdbImpl | moab::GeomTopoTool | [private] |
| modelSet | moab::GeomTopoTool | [private] |
| nameTag | moab::GeomTopoTool | [private] |
| next_vol(EntityHandle surface, EntityHandle old_volume, EntityHandle &new_volume) | moab::GeomTopoTool | |
| num_ents_of_dim(int dim) | moab::GeomTopoTool | [inline] |
| obb_tree() | moab::GeomTopoTool | [inline] |
| obbGsetTag | moab::GeomTopoTool | [private] |
| obbRootTag | moab::GeomTopoTool | [private] |
| obbTree | moab::GeomTopoTool | [private] |
| oneVolRootSet | moab::GeomTopoTool | [private] |
| other_entity(EntityHandle bounded, EntityHandle not_this, EntityHandle across, EntityHandle &other) | moab::GeomTopoTool | |
| remove_root(EntityHandle vol_or_surf) | moab::GeomTopoTool | |
| resize_rootSets() | moab::GeomTopoTool | [private] |
| restore_obb_index() | moab::GeomTopoTool | |
| restore_topology_from_adjacency() | moab::GeomTopoTool | |
| restore_topology_from_geometric_inclusion(const Range &flat_volumes) | moab::GeomTopoTool | |
| rootSets | moab::GeomTopoTool | [private] |
| sense2Tag | moab::GeomTopoTool | [private] |
| senseNEntsTag | moab::GeomTopoTool | [private] |
| senseNSensesTag | moab::GeomTopoTool | [private] |
| separate_by_dimension(const Range &geom_sets) | moab::GeomTopoTool | [private] |
| set_root_set(EntityHandle vol_or_surf, EntityHandle root) | moab::GeomTopoTool | [private] |
| set_sense(EntityHandle entity, EntityHandle wrt_entity, int sense) | moab::GeomTopoTool | |
| set_senses(EntityHandle entity, std::vector< EntityHandle > &wrt_entities, std::vector< int > &senses) | moab::GeomTopoTool | |
| set_surface_senses(EntityHandle surface_ent, EntityHandle forward_vol, EntityHandle reverse_vol) | moab::GeomTopoTool | |
| setOffset | moab::GeomTopoTool | [private] |
| setup_implicit_complement() | moab::GeomTopoTool | |
| updated | moab::GeomTopoTool | [private] |
| ~GeomTopoTool() | moab::GeomTopoTool | |
