, including all inherited members.
| add_child(EntityHandle child) | moab::MeshSet | |
| add_entities(const EntityHandle *entity_handles, const int num_entities, EntityHandle my_handle, AEntityFactory *adjacencies) | moab::MeshSet | [inline] |
| add_entities(const Range &entities, EntityHandle my_handle, AEntityFactory *adjacencies) | moab::MeshSet | [inline] |
| add_parent(EntityHandle parent) | moab::MeshSet | |
| childMeshSets | moab::MeshSet | [private] |
| clear(EntityHandle myhandle, AEntityFactory *adjacencies) | moab::MeshSet | [inline] |
| clear_all(EntityHandle myhandle, AEntityFactory *adjacencies) | moab::MeshSet | [inline] |
| contains_entities(const EntityHandle *entities, int num_entities, const int op) const | moab::MeshSet | [inline] |
| contentList | moab::MeshSet | [private] |
| convert(unsigned flags, EntityHandle my_handle, AEntityFactory *adj) | moab::MeshSet | [protected] |
| Count enum name | moab::MeshSet | |
| create_adjacencies(EntityHandle myhandle, AEntityFactory *adjacencies) | moab::MeshSet | [protected] |
| DIM_FROM_HANDLE(EntityHandle h) | moab::MeshSet | [inline, static] |
| empty() const | moab::MeshSet | [inline] |
| FIRST_OF_DIM(int dim) | moab::MeshSet | [inline, static] |
| flags() const | moab::MeshSet | [inline] |
| get_children(int &count_out) const | moab::MeshSet | [inline] |
| get_contents(size_t &count_out) const | moab::MeshSet | [inline] |
| get_contents(size_t &count_out) | moab::MeshSet | [inline] |
| get_entities(std::vector< EntityHandle > &entities) const | moab::MeshSet | [inline] |
| get_entities(Range &entities) const | moab::MeshSet | [inline] |
| get_entities_by_dimension(int dimension, std::vector< EntityHandle > &entity_list) const | moab::MeshSet | [inline] |
| get_entities_by_dimension(int dimension, Range &entity_list) const | moab::MeshSet | [inline] |
| get_entities_by_type(EntityType entity_type, std::vector< EntityHandle > &entity_list) const | moab::MeshSet | [inline] |
| get_entities_by_type(EntityType type, Range &entity_list) const | moab::MeshSet | [inline] |
| get_memory_use() const | moab::MeshSet | |
| get_non_set_entities(Range &range) const | moab::MeshSet | [inline] |
| get_parents(int &count_out) const | moab::MeshSet | [inline] |
| insert_entity_ranges(const EntityHandle *range_vect, size_t len, EntityHandle my_h, AEntityFactory *adj) | moab::MeshSet | [protected] |
| insert_entity_ranges(const Range &range, EntityHandle my_h, AEntityFactory *adj) | moab::MeshSet | [protected] |
| insert_entity_vector(const EntityHandle *vect, size_t len, EntityHandle my_h, AEntityFactory *adj) | moab::MeshSet | [protected] |
| intersect(const MeshSet *meshset_2, EntityHandle my_handle, AEntityFactory *adjacencies) | moab::MeshSet | |
| LAST_OF_DIM(int dim) | moab::MeshSet | [inline, static] |
| MANY enum value | moab::MeshSet | |
| mChildCount | moab::MeshSet | [private] |
| mContentCount | moab::MeshSet | [private] |
| MeshSet() | moab::MeshSet | [inline] |
| MeshSet(unsigned flags) | moab::MeshSet | [inline] |
| mFlags | moab::MeshSet | [private] |
| mParentCount | moab::MeshSet | [private] |
| num_children() const | moab::MeshSet | [inline] |
| num_entities() const | moab::MeshSet | [inline] |
| num_entities_by_dimension(int dimension) const | moab::MeshSet | [inline] |
| num_entities_by_type(EntityType type) const | moab::MeshSet | [inline] |
| num_parents() const | moab::MeshSet | [inline] |
| ONE enum value | moab::MeshSet | |
| ordered() const | moab::MeshSet | [inline] |
| parentMeshSets | moab::MeshSet | [private] |
| remove_adjacencies(EntityHandle myhandle, AEntityFactory *adjacencies) | moab::MeshSet | [protected] |
| remove_child(EntityHandle child) | moab::MeshSet | |
| remove_entities(const Range &entities, EntityHandle my_handle, AEntityFactory *adjacencies) | moab::MeshSet | [inline] |
| remove_entities(const EntityHandle *entities, const int num_entities, EntityHandle my_handle, AEntityFactory *adjacencies) | moab::MeshSet | [inline] |
| remove_entity_ranges(const EntityHandle *range_vect, size_t len, EntityHandle my_h, AEntityFactory *adj) | moab::MeshSet | [protected] |
| remove_entity_ranges(const Range &range, EntityHandle my_h, AEntityFactory *adj) | moab::MeshSet | [protected] |
| remove_entity_vector(const EntityHandle *vect, size_t len, EntityHandle my_h, AEntityFactory *adj) | moab::MeshSet | [protected] |
| remove_parent(EntityHandle parent) | moab::MeshSet | |
| replace_entities(EntityHandle my_handle, const EntityHandle *old_entities, const EntityHandle *new_entities, size_t num_entities, AEntityFactory *mAdjFact) | moab::MeshSet | |
| set() const | moab::MeshSet | [inline] |
| set_flags(unsigned flags, EntityHandle my_handle, AEntityFactory *adjacencies) | moab::MeshSet | [inline] |
| subtract(const MeshSet *meshset_2, EntityHandle my_handle, AEntityFactory *adjacencies) | moab::MeshSet | [inline] |
| tracking() const | moab::MeshSet | [inline] |
| TWO enum value | moab::MeshSet | |
| unite(const MeshSet *meshset_2, EntityHandle my_handle, AEntityFactory *adjacencies) | moab::MeshSet | [inline] |
| vector_based() const | moab::MeshSet | [inline] |
| ZERO enum value | moab::MeshSet | |
| ~MeshSet() | moab::MeshSet | [inline] |
