This is the complete list of members for
moab::ReadUtil, including all inherited members.
| assign_ids(Tag id_tag, const Range &ents, int start=0) | moab::ReadUtil | [virtual] |
| assign_ids(Tag id_tag, const EntityHandle *ents, size_t num_ents, int start=0) | moab::ReadUtil | [virtual] |
| create_entity_sets(EntityID num_sets, const unsigned *set_flags, EntityID preffered_start_id, EntityHandle &actual_start_handle) | moab::ReadUtil | [virtual] |
| create_gather_set(EntityHandle &gather_set) | moab::ReadUtil | [virtual] |
| gather_related_ents(Range &partition, Range &related_ents, EntityHandle *file_set=NULL) | moab::ReadUtil | [virtual] |
| get_element_connect(const int num_elements, const int verts_per_element, const EntityType mdb_type, const int preferred_start_id, EntityHandle &actual_start_handle, EntityHandle *&array, int sequence_size=-1) | moab::ReadUtil | [virtual] |
| get_gather_set(EntityHandle &gather_set) | moab::ReadUtil | [virtual] |
| get_node_coords(const int num_arrays, const int num_nodes, const int preferred_start_id, EntityHandle &actual_start_handle, std::vector< double * > &arrays, int sequence_size=-1) | moab::ReadUtil | [virtual] |
| get_ordered_vertices(EntityHandle *bound_ents, int *sense, int num_bound, int dim, EntityHandle *bound_verts, EntityType &etype) | moab::ReadUtil | [virtual] |
| mMB | moab::ReadUtil | [private] |
| ReadUtil(Core *mdb, Error *error_handler) | moab::ReadUtil | |
| ReadUtilIface() | moab::ReadUtilIface | [inline] |
| reorder(const int *order, EntityHandle *conn, int num_elem, int node_per_elem) | moab::ReadUtilIface | [inline, static] |
| update_adjacencies(const EntityHandle start_handle, const int number_elements, const int number_vertices_per_element, const EntityHandle *conn_array) | moab::ReadUtil | [virtual] |
| ~ReadUtil() | moab::ReadUtil | [inline] |
| ~ReadUtilIface() | moab::ReadUtilIface | [inline, virtual] |
