, including all inherited members.
| add_element_tag(Tag tag_handle) | moab::RefinerTagManager | |
| add_vertex_tag(Tag tag_handle) | moab::RefinerTagManager | |
| assign_element_tags(EntityHandle ent_output) | moab::RefinerTagManager | |
| copy_gid(EntityHandle ent_input, EntityHandle ent_output) | moab::RefinerTagManager | |
| create_output_tags() | moab::RefinerTagManager | |
| create_tag_internal(Tag, int) | moab::RefinerTagManager | [protected] |
| current_element_procs | moab::RefinerTagManager | [protected] |
| current_shared_procs | moab::RefinerTagManager | [protected] |
| element_size | moab::RefinerTagManager | [protected] |
| element_tag_data | moab::RefinerTagManager | [protected] |
| get_common_processes(int num, const EntityHandle *src, ProcessSet &common_shared_procs, bool on_output_mesh=true) | moab::RefinerTagManager | |
| get_element_procs() | moab::RefinerTagManager | [inline] |
| get_element_tag_size() const | moab::RefinerTagManager | [inline] |
| get_input_element_tag(int i, Tag &tag, int &byte_offset) | moab::RefinerTagManager | |
| get_input_gids(int n, const EntityHandle *ents, std::vector< int > &gids) | moab::RefinerTagManager | |
| get_input_mesh() | moab::RefinerTagManager | [inline] |
| get_input_vertex_tag(int i, Tag &tag, int &byte_offset) | moab::RefinerTagManager | |
| get_number_of_element_tags() const | moab::RefinerTagManager | [inline] |
| get_number_of_vertex_tags() const | moab::RefinerTagManager | [inline] |
| get_output_element_tag(int i, Tag &tag, int &byte_offset) | moab::RefinerTagManager | |
| get_output_gids(int n, const EntityHandle *ents, std::vector< int > &gids) | moab::RefinerTagManager | |
| get_output_mesh() | moab::RefinerTagManager | [inline] |
| get_output_vertex_tag(int i, Tag &tag, int &byte_offset) | moab::RefinerTagManager | |
| get_vertex_tag_size() const | moab::RefinerTagManager | [inline] |
| input_element_tags | moab::RefinerTagManager | [protected] |
| input_mesh | moab::RefinerTagManager | [protected] |
| input_parallel_status() | moab::RefinerTagManager | [inline] |
| input_shared_proc() | moab::RefinerTagManager | [inline] |
| input_shared_procs() | moab::RefinerTagManager | [inline] |
| input_vertex_tags | moab::RefinerTagManager | [protected] |
| output_element_tags | moab::RefinerTagManager | [protected] |
| output_mesh | moab::RefinerTagManager | [protected] |
| output_vertex_tags | moab::RefinerTagManager | [protected] |
| rank | moab::RefinerTagManager | [protected] |
| RefinerTagManager(Interface *in_mesh, Interface *out_mesh) | moab::RefinerTagManager | |
| reset_element_tags() | moab::RefinerTagManager | |
| reset_vertex_tags() | moab::RefinerTagManager | |
| set_element_procs_from_ent(EntityHandle ent_input) | moab::RefinerTagManager | [inline] |
| set_element_sharing(EntityHandle ent_output) | moab::RefinerTagManager | [inline] |
| set_element_tags_from_ent(EntityHandle ent_input) | moab::RefinerTagManager | |
| set_gid(EntityHandle ent, int gid) | moab::RefinerTagManager | |
| set_sharing(EntityHandle ent_handle, ProcessSet &procs) | moab::RefinerTagManager | |
| shared_procs_in | moab::RefinerTagManager | [protected] |
| shared_procs_out | moab::RefinerTagManager | [protected] |
| tag_igid | moab::RefinerTagManager | [protected] |
| tag_ipshand | moab::RefinerTagManager | [protected] |
| tag_ipshands | moab::RefinerTagManager | [protected] |
| tag_ipsproc | moab::RefinerTagManager | [protected] |
| tag_ipsprocs | moab::RefinerTagManager | [protected] |
| tag_ipstatus | moab::RefinerTagManager | [protected] |
| tag_ogid | moab::RefinerTagManager | [protected] |
| tag_opshand | moab::RefinerTagManager | [protected] |
| tag_opshands | moab::RefinerTagManager | [protected] |
| tag_opsproc | moab::RefinerTagManager | [protected] |
| tag_opsprocs | moab::RefinerTagManager | [protected] |
| tag_opstatus | moab::RefinerTagManager | [protected] |
| vertex_size | moab::RefinerTagManager | [protected] |
| ~RefinerTagManager() | moab::RefinerTagManager | [virtual] |
