, including all inherited members.
| assign_parametric_coordinates(int num_nodes, const double *src, double *tgt) | moab::SimplexTemplateRefiner | [protected] |
| best_tets(int *alternates, double *[14], int, int) | moab::SimplexTemplateRefiner | [inline, protected] |
| compare_Hopf_cross_string_dist(const double *v00, const double *v01, const double *v10, const double *v11) | moab::SimplexTemplateRefiner | [protected, static] |
| coord_heap | moab::EntityRefiner | [protected] |
| corner_coords | moab::SimplexTemplateRefiner | [protected] |
| corner_handles | moab::SimplexTemplateRefiner | [protected] |
| corner_tags | moab::SimplexTemplateRefiner | [protected] |
| current_coord | moab::EntityRefiner | [protected] |
| current_tag | moab::EntityRefiner | [protected] |
| edge_size_evaluator | moab::EntityRefiner | [protected] |
| EntityRefiner() | moab::EntityRefiner | |
| get_edge_size_evaluator() | moab::EntityRefiner | [inline] |
| get_heap_size_bound(int max_recursions) const | moab::SimplexTemplateRefiner | [inline, virtual] |
| get_maximum_number_of_subdivisions() const | moab::EntityRefiner | [inline] |
| get_minimum_number_of_subdivisions() const | moab::EntityRefiner | [inline] |
| get_output_functor() | moab::EntityRefiner | [inline] |
| get_tag_assigner() const | moab::SimplexTemplateRefiner | [inline] |
| heap_coord_storage() | moab::EntityRefiner | [protected] |
| heap_tag_storage() | moab::EntityRefiner | [protected] |
| input_is_output | moab::SimplexTemplateRefiner | [protected] |
| maximum_number_of_subdivisions | moab::EntityRefiner | [protected] |
| mesh_in | moab::EntityRefiner | [protected] |
| minimum_number_of_subdivisions | moab::EntityRefiner | [protected] |
| output_functor | moab::EntityRefiner | [protected] |
| permutations_from_index | moab::SimplexTemplateRefiner | [protected, static] |
| prepare(RefinerTagManager *tmgr, EntityRefinerOutputFunctor *ofunc) | moab::SimplexTemplateRefiner | [virtual] |
| refine_0_simplex(const double *v0, const void *t0, EntityHandle h0) | moab::SimplexTemplateRefiner | [protected] |
| refine_1_simplex(int max_depth, const double *v0, const void *t0, EntityHandle h0, const double *v1, const void *t1, EntityHandle h1) | moab::SimplexTemplateRefiner | [protected] |
| refine_2_simplex(int max_depth, int move, const double *v0, const void *t0, EntityHandle h0, const double *v1, const void *t1, EntityHandle h1, const double *v2, const void *t2, EntityHandle h2) | moab::SimplexTemplateRefiner | [protected] |
| refine_3_simplex(int max_depth, double *v0, void *t0, EntityHandle h0, double *v1, void *t1, EntityHandle h1, double *v2, void *t2, EntityHandle h2, double *v3, void *t3, EntityHandle h3) | moab::SimplexTemplateRefiner | [protected] |
| refine_entity(EntityType etyp, EntityHandle entity) | moab::SimplexTemplateRefiner | [virtual] |
| reset_heap_pointers() | moab::EntityRefiner | [protected] |
| set_edge_size_evaluator(EdgeSizeEvaluator *) | moab::EntityRefiner | [virtual] |
| set_maximum_number_of_subdivisions(int mx) | moab::EntityRefiner | [virtual] |
| set_minimum_number_of_subdivisions(int mn) | moab::EntityRefiner | [virtual] |
| set_output_functor(EntityRefinerOutputFunctor *func_obj) | moab::EntityRefiner | [virtual] |
| set_tag_assigner(SimplexTemplateTagAssigner *ta) | moab::SimplexTemplateRefiner | [virtual] |
| SimplexTemplateRefiner() | moab::SimplexTemplateRefiner | |
| tag_assigner | moab::SimplexTemplateRefiner | [protected] |
| tag_heap | moab::EntityRefiner | [protected] |
| tag_manager | moab::SimplexTemplateRefiner | [protected] |
| template_index | moab::SimplexTemplateRefiner | [protected, static] |
| templates | moab::SimplexTemplateRefiner | [protected, static] |
| update_heap_size() | moab::EntityRefiner | [protected] |
| ~EntityRefiner() | moab::EntityRefiner | [virtual] |
| ~SimplexTemplateRefiner() | moab::SimplexTemplateRefiner | [virtual] |
