, including all inherited members.
| check_valid_sizes(const int *sizes, int num_sizes) const | moab::TagInfo | |
| clear_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *value_ptr, int value_len=0)=0 | moab::TagInfo | [pure virtual] |
| clear_data(SequenceManager *seqman, Error *error_handler, const Range &entities, const void *value_ptr, int value_len=0)=0 | moab::TagInfo | [pure virtual] |
| dataType | moab::TagInfo | [private] |
| equals_default_value(const void *data, int size=-1) const | moab::TagInfo | |
| find_entities_with_value(const SequenceManager *seqman, Error *error_handler, Range &output_entities, const void *value, int value_bytes=0, EntityType type=MBMAXTYPE, const Range *intersect_entities=0) const =0 | moab::TagInfo | [pure virtual] |
| get_data(const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void *data) const =0 | moab::TagInfo | [pure virtual] |
| get_data(const SequenceManager *seqman, Error *error_handler, const Range &entities, void *data) const =0 | moab::TagInfo | [pure virtual] |
| get_data(const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void **data_ptrs, int *data_lengths) const =0 | moab::TagInfo | [pure virtual] |
| get_data(const SequenceManager *seqman, Error *error_handler, const Range &entities, const void **data_ptrs, int *data_lengths) const =0 | moab::TagInfo | [pure virtual] |
| get_data_type() const | moab::TagInfo | [inline] |
| get_default_value() const | moab::TagInfo | [inline] |
| get_default_value_size() const | moab::TagInfo | [inline] |
| get_memory_use(const SequenceManager *seqman, unsigned long &total, unsigned long &per_entity) const =0 | moab::TagInfo | [pure virtual] |
| get_memory_use() const | moab::TagInfo | [inline, protected] |
| get_name() const | moab::TagInfo | [inline] |
| get_size() const | moab::TagInfo | [inline] |
| get_storage_type() const =0 | moab::TagInfo | [pure virtual] |
| get_tagged_entities(const SequenceManager *seqman, Range &output_entities, EntityType type=MBMAXTYPE, const Range *intersect=0) const =0 | moab::TagInfo | [pure virtual] |
| is_tagged(const SequenceManager *seqman, EntityHandle entity) const =0 | moab::TagInfo | [pure virtual] |
| mDataSize | moab::TagInfo | [private] |
| mDefaultValue | moab::TagInfo | [private] |
| mDefaultValueSize | moab::TagInfo | [private] |
| mMeshValue | moab::TagInfo | [private] |
| mMeshValueSize | moab::TagInfo | [private] |
| mTagName | moab::TagInfo | [private] |
| num_tagged_entities(const SequenceManager *seqman, size_t &output_count, EntityType type=MBMAXTYPE, const Range *intersect=0) const =0 | moab::TagInfo | [pure virtual] |
| operator=(const TagInfo ©) | moab::TagInfo | [private] |
| release_all_data(SequenceManager *seqman, Error *error_handler, bool tag_delete_pending)=0 | moab::TagInfo | [pure virtual] |
| remove_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities)=0 | moab::TagInfo | [pure virtual] |
| remove_data(SequenceManager *seqman, Error *error_handler, const Range &entities)=0 | moab::TagInfo | [pure virtual] |
| set_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *data)=0 | moab::TagInfo | [pure virtual] |
| set_data(SequenceManager *seqman, Error *error_handler, const Range &entities, const void *data)=0 | moab::TagInfo | [pure virtual] |
| set_data(SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void const *const *data_ptrs, const int *data_lengths)=0 | moab::TagInfo | [pure virtual] |
| set_data(SequenceManager *seqman, Error *error_handler, const Range &entities, void const *const *data_ptrs, const int *data_lengths)=0 | moab::TagInfo | [pure virtual] |
| set_name(const std::string &name) | moab::TagInfo | [inline] |
| size_from_data_type(DataType t) | moab::TagInfo | [static] |
| tag_iterate(SequenceManager *seqman, Error *error_handler, Range::iterator &iter, const Range::iterator &end, void *&data_ptr, bool allocate=true)=0 | moab::TagInfo | [pure virtual] |
| TagInfo() | moab::TagInfo | [inline] |
| TagInfo(const char *name, int size, DataType type, const void *default_value, int default_value_size) | moab::TagInfo | |
| TagInfo(const TagInfo ©) | moab::TagInfo | [private] |
| validate_lengths(Error *error_handler, const int *lengths, size_t num_lengths) const | moab::TagInfo | |
| variable_length() const | moab::TagInfo | [inline] |
| ~TagInfo() | moab::TagInfo | [virtual] |
