, including all inherited members.
| append_memory_use(EntityHandle first, EntityHandle last, const SequenceData *data, unsigned long long &entity_storage, unsigned long long &total_storage) const | moab::TypeSequenceManager | [private] |
| availableList | moab::TypeSequenceManager | [private] |
| begin() const | moab::TypeSequenceManager | [inline] |
| begin() | moab::TypeSequenceManager | [inline] |
| check_merge_next(iterator i) | moab::TypeSequenceManager | [private] |
| check_merge_prev(iterator i) | moab::TypeSequenceManager | [private] |
| check_valid_data(const EntitySequence *seq) const | moab::TypeSequenceManager | [private] |
| check_valid_handles(Error *error_handler, EntityHandle first, EntityHandle last) const | moab::TypeSequenceManager | |
| const_iterator typedef | moab::TypeSequenceManager | |
| data_iterator typedef | moab::TypeSequenceManager | |
| data_set_type typedef | moab::TypeSequenceManager | |
| empty() const | moab::TypeSequenceManager | [inline] |
| end() const | moab::TypeSequenceManager | [inline] |
| end() | moab::TypeSequenceManager | [inline] |
| erase(iterator i) | moab::TypeSequenceManager | [private] |
| erase(Error *error_handler, EntityHandle first, EntityHandle last) | moab::TypeSequenceManager | |
| erase(Error *error_handler, EntityHandle entity) | moab::TypeSequenceManager | |
| find(EntityHandle h) const | moab::TypeSequenceManager | [inline] |
| find(EntityHandle h) | moab::TypeSequenceManager | [inline] |
| find(EntityHandle h, EntitySequence *&) | moab::TypeSequenceManager | [inline] |
| find(EntityHandle h, const EntitySequence *&) const | moab::TypeSequenceManager | [inline] |
| find_free_block(EntityID num_entities, EntityHandle min_start_handle, EntityHandle max_end_handle) | moab::TypeSequenceManager | |
| find_free_handle(EntityHandle min_start_handle, EntityHandle max_end_handle, bool &append_out, int values_per_ent=0) | moab::TypeSequenceManager | |
| find_free_sequence(EntityID num_entities, EntityHandle min_start_handle, EntityHandle max_end_handle, SequenceData *&sequence_data_out, EntityID &sequence_data_size, int values_per_ent=0) | moab::TypeSequenceManager | |
| get_entities(Range &entities_out) const | moab::TypeSequenceManager | [inline] |
| get_entities(std::vector< EntityHandle > &entities_out) const | moab::TypeSequenceManager | [inline] |
| get_last_accessed() const | moab::TypeSequenceManager | [inline] |
| get_memory_use(unsigned long long &total_entity_storage, unsigned long long &total_storage) const | moab::TypeSequenceManager | |
| get_memory_use(EntityHandle start, EntityHandle end, unsigned long long &total_entity_storage, unsigned long long &total_amortized_storage) const | moab::TypeSequenceManager | |
| get_number_entities() const | moab::TypeSequenceManager | [inline] |
| get_occupied_size(const SequenceData *) const | moab::TypeSequenceManager | |
| get_sequence_count() const | moab::TypeSequenceManager | [inline] |
| insert_sequence(EntitySequence *seq_ptr) | moab::TypeSequenceManager | |
| is_free_handle(EntityHandle handle, iterator &seq_ptr_out, SequenceData *&data_ptr_out, EntityHandle &block_start, EntityHandle &block_end, int values_per_ent=0) | moab::TypeSequenceManager | |
| is_free_sequence(EntityHandle start_handle, EntityID num_entities, SequenceData *&sequence_data_out, int values_per_ent=0) | moab::TypeSequenceManager | |
| last_free_handle(EntityHandle after_this) const | moab::TypeSequenceManager | |
| lastReferenced | moab::TypeSequenceManager | [mutable, private] |
| lower_bound(EntityHandle h) const | moab::TypeSequenceManager | [inline] |
| lower_bound(EntityHandle h) | moab::TypeSequenceManager | [inline] |
| merge_internal(iterator keep, iterator dead) | moab::TypeSequenceManager | [private] |
| notify_appended(iterator seq) | moab::TypeSequenceManager | |
| notify_prepended(iterator seq) | moab::TypeSequenceManager | |
| remove_sequence(const EntitySequence *seq_ptr, bool &is_last_user_of_sequence_data) | moab::TypeSequenceManager | |
| replace_subsequence(EntitySequence *seq_ptr, const int *tag_sizes, int num_tag_sizes) | moab::TypeSequenceManager | |
| sequenceSet | moab::TypeSequenceManager | [private] |
| split_sequence(iterator i, EntityHandle h) | moab::TypeSequenceManager | [private] |
| TypeSequenceManager() | moab::TypeSequenceManager | [inline] |
| upper_bound(EntityHandle h) const | moab::TypeSequenceManager | [inline] |
| ~TypeSequenceManager() | moab::TypeSequenceManager | |
