, including all inherited members.
| close_and_compress(const char *filename, CCMIOID rootID) | moab::WriteCCMIO | [private] |
| create_ccmio_structure(CCMIOID rootID, CCMIOID &stateID, CCMIOID &processorID) | moab::WriteCCMIO | [private] |
| factory(Interface *) | moab::WriteCCMIO | [static] |
| fileName | moab::WriteCCMIO | [private] |
| gather_matset_info(std::vector< EntityHandle > &matsets, std::vector< MaterialSetData > &matset_data, Range &all_verts) | moab::WriteCCMIO | [private] |
| gather_neuset_info(std::vector< EntityHandle > &neusets, std::vector< NeumannSetData > &neuset_data) | moab::WriteCCMIO | [private] |
| get_gids(const Range &ents, int *&gids, int &minid, int &maxid) | moab::WriteCCMIO | [private] |
| get_neuset_elems(EntityHandle neuset, int current_sense, Range &forward_elems, Range &reverse_elems) | moab::WriteCCMIO | [private] |
| get_sets(const EntityHandle *ent_handles, int num_sets, std::vector< EntityHandle > &matsets, std::vector< EntityHandle > &dirsets, std::vector< EntityHandle > &neusets, std::vector< EntityHandle > &partsets) | moab::WriteCCMIO | [private] |
| get_valid_sides(Range &elems, const int sense, WriteCCMIO::NeumannSetData &neuset_data) | moab::WriteCCMIO | [private] |
| initialize_file(MeshInfo &mesh_info) | moab::WriteCCMIO | [private] |
| mbImpl | moab::WriteCCMIO | [private] |
| mBoundaryTypeTag | moab::WriteCCMIO | [private] |
| mColorIdxTag | moab::WriteCCMIO | [private] |
| mCreatingProgramTag | moab::WriteCCMIO | [private] |
| mCurrentMeshHandle | moab::WriteCCMIO | [private] |
| mDimension | moab::WriteCCMIO | [private] |
| mDirichletSetTag | moab::WriteCCMIO | [private] |
| mEntityMark | moab::WriteCCMIO | [private] |
| mFreeSurfaceMaterialTag | moab::WriteCCMIO | [private] |
| mGlobalIdTag | moab::WriteCCMIO | [private] |
| mGroupIdTag | moab::WriteCCMIO | [private] |
| mHasMidNodesTag | moab::WriteCCMIO | [private] |
| mLightMaterialTag | moab::WriteCCMIO | [private] |
| mMaterialIdTag | moab::WriteCCMIO | [private] |
| mMaterialSetTag | moab::WriteCCMIO | [private] |
| mMaterialTypeTag | moab::WriteCCMIO | [private] |
| mNameTag | moab::WriteCCMIO | [private] |
| mNeumannSetTag | moab::WriteCCMIO | [private] |
| moab_to_ccmio_type(EntityType etype, int has_mid_nodes[]) | moab::WriteCCMIO | [private] |
| mPartitionSetTag | moab::WriteCCMIO | [private] |
| mPorosityIdTag | moab::WriteCCMIO | [private] |
| mProcessorIdTag | moab::WriteCCMIO | [private] |
| mProstarRegionNumberTag | moab::WriteCCMIO | [private] |
| mRadiationTag | moab::WriteCCMIO | [private] |
| mSpinIdTag | moab::WriteCCMIO | [private] |
| mThicknessTag | moab::WriteCCMIO | [private] |
| mWholeMesh | moab::WriteCCMIO | [private] |
| mWriteIface | moab::WriteCCMIO | [private] |
| open_file(const char *filename, bool overwrite, CCMIOID &rootID) | moab::WriteCCMIO | [protected] |
| reset_matset(std::vector< MaterialSetData > &matset_info) | moab::WriteCCMIO | [private] |
| transform_coords(const int dimension, const int num_nodes, double *coords) | moab::WriteCCMIO | [private] |
| write_cells_and_faces(CCMIOID rootID, std::vector< WriteCCMIO::MaterialSetData > &matset_data, std::vector< WriteCCMIO::NeumannSetData > &neuset_data, Range &verts, CCMIOID &topologyID) | moab::WriteCCMIO | [private] |
| write_dbl_option(const char *opt_name, EntityHandle seth, Tag &tag, CCMIOID &node) | moab::WriteCCMIO | [private] |
| write_external_faces(CCMIOID rootID, CCMIOID topologyID, int set_num, Range &facets) | moab::WriteCCMIO | [private] |
| write_file(const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3) | moab::WriteCCMIO | [virtual] |
| write_int_option(const char *opt_name, EntityHandle seth, Tag &tag, CCMIOID &node) | moab::WriteCCMIO | [private] |
| write_meshes(MeshInfo &mesh_info, std::vector< MaterialSetData > &matset_data, std::vector< NeumannSetData > &neuset_data, Range &verts, const int *vgids) | moab::WriteCCMIO | [private] |
| write_nodes(CCMIOID rootID, const Range &nodes, const int dimension, CCMIOID &verticesID) | moab::WriteCCMIO | [private] |
| write_problem_description(CCMIOID rootID, CCMIOID stateID, CCMIOID &problemID, CCMIOID processorID, std::vector< MaterialSetData > &matset_data, std::vector< NeumannSetData > &neuset_data) | moab::WriteCCMIO | [private] |
| write_processor(CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID) | moab::WriteCCMIO | [private] |
| write_solution_data() | moab::WriteCCMIO | [private] |
| write_str_option(const char *opt_name, EntityHandle seth, Tag &tag, CCMIOID &node, const char *other_name=NULL) | moab::WriteCCMIO | [private] |
| WriteCCMIO(Interface *impl) | moab::WriteCCMIO | |
| ~WriteCCMIO() | moab::WriteCCMIO | [virtual] |
| ~WriterIface() | moab::WriterIface | [inline, virtual] |
