MOAB: Mesh Oriented datABase
(version 5.4.0)
#include <iostream>
#include <cstdlib>
#include "Mesquite.hpp"
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "InstructionQueue.hpp"
#include "TerminationCriterion.hpp"
#include "QualityAssessor.hpp"
#include "IdealWeightInverseMeanRatio.hpp"
#include "EdgeLengthQualityMetric.hpp"
#include "LPtoPTemplate.hpp"
#include "FeasibleNewton.hpp"
#include "ConjugateGradient.hpp"
#include "TestUtil.hpp"
Functions | |
void | usage () |
int | main (int argc, char *argv[]) |
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 74 of file feasible_newton_test.cpp.
References MBMesquite::TerminationCriterion::add_absolute_quality_improvement(), MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::InstructionQueue::add_quality_assessor(), mesh, MBMesquite::print_timing_diagnostics(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::AveragingQM::set_averaging_method(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::QualityImprover::set_outer_termination_criterion(), MBMesquite::QualityMetric::SUM, usage, and MBMesquite::PatchSetUser::use_global_patch().
{ MBMesquite::MsqPrintError err( cout ); std::string file_name = TestDir + "unittest/mesquite/3D/vtk/hexes/untangled/large_box_hex_1000.vtk"; double OF_value = 0.; if( argc == 1 ) { cerr << "Warning: No file specified, using default: " << file_name << endl; } if( argc > 1 ) { file_name = argv[1]; } if( argc > 2 ) { char* end_ptr; OF_value = strtod( argv[2], &end_ptr ); if( !*argv[2] || *end_ptr ) usage(); } if( argc > 3 ) { usage(); } MBMesquite::MeshImpl mesh; mesh.read_vtk( file_name.c_str(), err ); if( err ) return 1; // creates an intruction queue InstructionQueue queue1; // creates a mean ratio quality metric ... // SmoothnessQualityMetric* mean_ratio = new EdgeLengthQualityMetric; IdealWeightInverseMeanRatio mean_ratio( err ); if( err ) return 1; // mean_ratio->set_gradient_type(QualityMetric::NUMERICAL_GRADIENT); // mean_ratio->set_hessian_type(QualityMetric::NUMERICAL_HESSIAN); mean_ratio.set_averaging_method( QualityMetric::SUM ); // ... and builds an objective function with it LPtoPTemplate obj_func( &mean_ratio, 1, err ); if( err ) return 1; // creates the steepest descentfeas newt optimization procedures // ConjugateGradient* pass1 = new ConjugateGradient( obj_func, err ); FeasibleNewton pass1( &obj_func ); pass1.use_global_patch(); if( err ) return 1; QualityAssessor stop_qa = QualityAssessor( &mean_ratio ); // **************Set stopping criterion**************** TerminationCriterion tc_inner; if( OF_value != 0 ) { tc_inner.add_absolute_quality_improvement( OF_value ); pass1.set_inner_termination_criterion( &tc_inner ); } TerminationCriterion tc_outer; tc_outer.add_iteration_limit( 1 ); pass1.set_outer_termination_criterion( &tc_outer ); queue1.add_quality_assessor( &stop_qa, err ); if( err ) return 1; // adds 1 pass of pass1 to mesh_set1 queue1.set_master_quality_improver( &pass1, err ); if( err ) return 1; queue1.add_quality_assessor( &stop_qa, err ); if( err ) return 1; // mesh.write_vtk("original_mesh",err); MSQ_CHKERR(err); // launches optimization on mesh_set1 queue1.run_instructions( &mesh, err ); if( err ) return 1; // mesh.write_vtk("smoothed_mesh", err); MSQ_CHKERR(err); print_timing_diagnostics( cout ); return 0; }
void usage | ( | ) |
Definition at line 68 of file feasible_newton_test.cpp.
cerr << "Usage: main [filename] [objective function val]" << endl;
exit( 1 );
