MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 diachin2@llnl.gov, djmelan@sandia.gov, mbrewer@sandia.gov, 00024 pknupp@sandia.gov, tleurent@mcs.anl.gov, tmunson@mcs.anl.gov 00025 00026 ***************************************************************** */ 00027 // 00028 // SUMMARY: 00029 // USAGE: 00030 // 00031 // ORIG-DATE: 19-Feb-02 at 10:57:52 00032 // LAST-MOD: 18-Oct-04 by J.Kraftcheck 00033 // 00034 // 00035 // DESCRIPTION: 00036 // ============ 00037 /*! \file main.cpp 00038 00039 describe main.cpp here 00040 00041 */ 00042 // DESCRIP-END. 00043 // 00044 00045 #include <iostream> 00046 using std::cerr; 00047 using std::cout; 00048 using std::endl; 00049 #include <cstdlib> 00050 00051 #include "Mesquite.hpp" 00052 #include "MeshImpl.hpp" 00053 #include "MsqError.hpp" 00054 #include "InstructionQueue.hpp" 00055 #include "TerminationCriterion.hpp" 00056 #include "QualityAssessor.hpp" 00057 00058 // algorithms 00059 #include "IdealWeightInverseMeanRatio.hpp" 00060 #include "EdgeLengthQualityMetric.hpp" 00061 #include "LPtoPTemplate.hpp" 00062 #include "FeasibleNewton.hpp" 00063 #include "ConjugateGradient.hpp" 00064 #include "TestUtil.hpp" 00065 00066 using namespace MBMesquite; 00067 00068 void usage() 00069 { 00070 cerr << "Usage: main [filename] [objective function val]" << endl; 00071 exit( 1 ); 00072 } 00073 00074 int main( int argc, char* argv[] ) 00075 { 00076 MBMesquite::MsqPrintError err( cout ); 00077 00078 std::string file_name = TestDir + "/3D/vtk/hexes/untangled/large_box_hex_1000.vtk"; 00079 double OF_value = 0.; 00080 00081 if( argc == 1 ) { cerr << "Warning: No file specified, using default: " << file_name << endl; } 00082 00083 if( argc > 1 ) { file_name = argv[1]; } 00084 if( argc > 2 ) 00085 { 00086 char* end_ptr; 00087 OF_value = strtod( argv[2], &end_ptr ); 00088 if( !*argv[2] || *end_ptr ) usage(); 00089 } 00090 if( argc > 3 ) { usage(); } 00091 00092 MBMesquite::MeshImpl mesh; 00093 mesh.read_vtk( file_name.c_str(), err ); 00094 if( err ) return 1; 00095 00096 // creates an intruction queue 00097 InstructionQueue queue1; 00098 00099 // creates a mean ratio quality metric ... 00100 // SmoothnessQualityMetric* mean_ratio = new EdgeLengthQualityMetric; 00101 IdealWeightInverseMeanRatio mean_ratio( err ); 00102 if( err ) return 1; 00103 // mean_ratio->set_gradient_type(QualityMetric::NUMERICAL_GRADIENT); 00104 // mean_ratio->set_hessian_type(QualityMetric::NUMERICAL_HESSIAN); 00105 mean_ratio.set_averaging_method( QualityMetric::SUM ); 00106 00107 // ... and builds an objective function with it 00108 LPtoPTemplate obj_func( &mean_ratio, 1, err ); 00109 if( err ) return 1; 00110 00111 // creates the steepest descentfeas newt optimization procedures 00112 // ConjugateGradient* pass1 = new ConjugateGradient( obj_func, err ); 00113 FeasibleNewton pass1( &obj_func ); 00114 pass1.use_global_patch(); 00115 if( err ) return 1; 00116 00117 QualityAssessor stop_qa = QualityAssessor( &mean_ratio ); 00118 00119 // **************Set stopping criterion**************** 00120 TerminationCriterion tc_inner; 00121 if( OF_value != 0 ) 00122 { 00123 tc_inner.add_absolute_quality_improvement( OF_value ); 00124 pass1.set_inner_termination_criterion( &tc_inner ); 00125 } 00126 TerminationCriterion tc_outer; 00127 tc_outer.add_iteration_limit( 1 ); 00128 pass1.set_outer_termination_criterion( &tc_outer ); 00129 00130 queue1.add_quality_assessor( &stop_qa, err ); 00131 if( err ) return 1; 00132 00133 // adds 1 pass of pass1 to mesh_set1 00134 queue1.set_master_quality_improver( &pass1, err ); 00135 if( err ) return 1; 00136 00137 queue1.add_quality_assessor( &stop_qa, err ); 00138 if( err ) return 1; 00139 00140 // mesh.write_vtk("original_mesh",err); MSQ_CHKERR(err); 00141 00142 // launches optimization on mesh_set1 00143 queue1.run_instructions( &mesh, err ); 00144 if( err ) return 1; 00145 00146 // mesh.write_vtk("smoothed_mesh", err); MSQ_CHKERR(err); 00147 print_timing_diagnostics( cout ); 00148 return 0; 00149 }
