MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include "moab/HomXform.hpp" 00017 #include <cassert> 00018 #include <iostream> 00019 00020 using namespace moab; 00021 00022 // unit test for the HomCoord and HomXform classes 00023 // 00024 int test_get_set(); 00025 int test_coord_operators(); 00026 int test_xform_operators(); 00027 int test_xform_functions(); 00028 int test_coord_xform_operators(); 00029 00030 int main( int /*argc*/, char** /*argv*/ ) 00031 { 00032 // first test HomCoord 00033 00034 // constructors 00035 // following shouldn't compile, since bare constructor is private 00036 00037 int errors = 0; 00038 00039 errors += test_get_set(); 00040 errors += test_coord_operators(); 00041 errors += test_xform_operators(); 00042 errors += test_xform_functions(); 00043 errors += test_coord_xform_operators(); 00044 00045 if( errors > 0 ) 00046 std::cout << errors << " errors found." << std::endl; 00047 else 00048 std::cout << "All tests passed." << std::endl; 00049 00050 return errors; 00051 } 00052 00053 int test_get_set() 00054 { 00055 int errors = 0; 00056 00057 // other constructors 00058 int coordsa[4] = { 1, 2, 3, 1 }; 00059 int coordsb[4] = { 4, 3, 2, 1 }; 00060 00061 HomCoord coords1( coordsa ); 00062 HomCoord coords2( 4, 3, 2, 1 ); 00063 HomCoord coords3( 4, 3, 2 ); 00064 HomCoord coords4( 1, 1, 1, 1 ); 00065 00066 // set 00067 coords2.set( coordsb ); 00068 00069 // hom_coord() 00070 for( int i = 0; i < 4; i++ ) 00071 { 00072 if( coords2.hom_coord()[i] != coordsb[i] ) 00073 { 00074 std::cout << "Get test failed." << std::endl; 00075 errors++; 00076 } 00077 } 00078 00079 // ijkh 00080 if( coords2.i() != coordsb[0] || coords2.j() != coordsb[1] || coords2.k() != coordsb[2] || 00081 coords2.h() != coordsb[3] ) 00082 { 00083 std::cout << "ijkh test failed." << std::endl; 00084 errors++; 00085 } 00086 00087 // set 00088 coords2.set( 3, 3, 3 ); 00089 00090 // hom_coord() 00091 if( coords2.hom_coord()[0] != 3 || coords2.hom_coord()[1] != 3 || coords2.hom_coord()[2] != 3 || 00092 coords2.hom_coord()[3] != 1 ) 00093 { 00094 std::cout << "Set (int) test failed." << std::endl; 00095 errors++; 00096 } 00097 00098 return errors; 00099 } 00100 00101 int test_coord_operators() 00102 { 00103 int errors = 0; 00104 00105 HomCoord coords1( 1, 2, 3, 1 ); 00106 HomCoord coords2( 4, 3, 2, 1 ); 00107 HomCoord coords3( 4, 3, 2 ); 00108 HomCoord coords4( 1, 1, 1, 1 ); 00109 00110 // operator>= 00111 bool optest = ( coords2 >= coords4 && coords2 >= coords3 && coords3 >= coords2 ); 00112 if( !optest ) 00113 { 00114 std::cout << "Test failed for operator >=." << std::endl; 00115 errors++; 00116 } 00117 00118 optest = ( coords4 <= coords2 && coords2 <= coords3 && coords3 <= coords2 ); 00119 if( !optest ) 00120 { 00121 std::cout << "Test failed for operator <=." << std::endl; 00122 errors++; 00123 } 00124 00125 // operator> 00126 optest = ( coords2 > coords4 && !( coords2 > coords3 ) && !( coords3 > coords2 ) ); 00127 if( !optest ) 00128 { 00129 std::cout << "Test failed for operator >." << std::endl; 00130 errors++; 00131 } 00132 00133 optest = ( coords4 < coords2 && !( coords2 < coords3 ) && !( coords3 < coords2 ) ); 00134 if( !optest ) 00135 { 00136 std::cout << "Test failed for operator <." << std::endl; 00137 errors++; 00138 } 00139 00140 // operator[] 00141 for( int i = 0; i < 3; i++ ) 00142 { 00143 if( coords1[i] != coords2[3 - i] ) 00144 { 00145 std::cout << "Test failed for operator[]." << std::endl; 00146 errors++; 00147 } 00148 } 00149 00150 // operator+ 00151 HomCoord coords5( 2 * coords1[0], 2 * coords1[1], 2 * coords1[2] ); 00152 HomCoord coords6 = coords1 + coords1; 00153 if( coords5 != coords6 ) 00154 { 00155 std::cout << "Test failed for operator+." << std::endl; 00156 errors++; 00157 } 00158 00159 // operator- 00160 if( coords5 - coords1 != coords1 ) 00161 { 00162 std::cout << "Test failed for operator-." << std::endl; 00163 errors++; 00164 } 00165 00166 return errors; 00167 } 00168 00169 int test_xform_constructors() 00170 { 00171 int errors = 0; 00172 00173 // integer constructor 00174 int test_int[] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15 }; 00175 HomXform xform( test_int ); 00176 for( int i = 0; i < 16; i++ ) 00177 { 00178 if( xform[i] != i ) 00179 { 00180 std::cout << "HomXform integer array constructor failed." << std::endl; 00181 errors++; 00182 } 00183 } 00184 00185 HomXform xform3( test_int[0], test_int[1], test_int[2], test_int[3], test_int[4], test_int[5], test_int[6], 00186 test_int[7], test_int[8], test_int[9], test_int[10], test_int[11], test_int[12], test_int[13], 00187 test_int[14], test_int[15] ); 00188 for( int i = 0; i < 16; i++ ) 00189 { 00190 if( xform3[i] != i ) 00191 { 00192 std::cout << "HomXform integer constructor failed." << std::endl; 00193 errors++; 00194 } 00195 } 00196 00197 // sample rotation, translation, and scaling matrices/vectors 00198 int rotate[] = { 0, 1, 0, -1, 0, 0, 0, 0, 1 }; 00199 int translate[] = { 4, 5, 6 }; 00200 int scale[] = { 1, 1, 1 }; 00201 00202 // construct an xform matrix based on those 00203 HomXform xform2( rotate, scale, translate ); 00204 00205 // test where those went in the xform 00206 if( !( xform2[XFORM_INDEX( 0, 0 )] == rotate[0] && xform2[XFORM_INDEX( 0, 1 )] == rotate[1] && 00207 xform2[XFORM_INDEX( 0, 2 )] == rotate[2] && xform2[XFORM_INDEX( 1, 0 )] == rotate[3] && 00208 xform2[XFORM_INDEX( 1, 1 )] == rotate[4] && xform2[XFORM_INDEX( 1, 2 )] == rotate[5] && 00209 xform2[XFORM_INDEX( 2, 0 )] == rotate[6] && xform2[XFORM_INDEX( 2, 1 )] == rotate[7] && 00210 xform2[XFORM_INDEX( 2, 2 )] == rotate[8] && xform2[XFORM_INDEX( 3, 0 )] == translate[0] && 00211 xform2[XFORM_INDEX( 3, 1 )] == translate[1] && xform2[XFORM_INDEX( 3, 2 )] == translate[2] && 00212 xform2[XFORM_INDEX( 0, 3 )] == 0 && xform2[XFORM_INDEX( 1, 3 )] == 0 && xform2[XFORM_INDEX( 2, 3 )] == 0 && 00213 xform2[XFORM_INDEX( 3, 3 )] == 1 ) ) 00214 { 00215 std::cout << "HomXform rotate, scale, translate constructor failed." << std::endl; 00216 errors++; 00217 } 00218 00219 return errors; 00220 } 00221 00222 int test_xform_operators() 00223 { 00224 int errors = 0; 00225 00226 // sample rotation, translation, and scaling matrices/vectors 00227 int rotate[] = { 0, 1, 0, -1, 0, 0, 0, 0, 1 }; 00228 int translate[] = { 4, 5, 6 }; 00229 int scale[] = { 1, 1, 1 }; 00230 00231 // construct an xform matrix based on those 00232 HomXform xform1( rotate, scale, translate ); 00233 HomXform xform1a( rotate, scale, translate ); 00234 00235 // test operator== 00236 if( !( xform1 == xform1a ) ) 00237 { 00238 std::cout << "HomXform operator== failed." << std::endl; 00239 errors++; 00240 } 00241 00242 // test operator!= 00243 xform1a[1] = 0; 00244 if( !( xform1 != xform1a ) ) 00245 { 00246 std::cout << "HomXform operator!= failed." << std::endl; 00247 errors++; 00248 } 00249 00250 // test operator= 00251 HomXform xform1c = xform1; 00252 if( !( xform1c == xform1 ) ) 00253 { 00254 std::cout << "HomXform operator= failed." << std::endl; 00255 errors++; 00256 } 00257 00258 HomXform xform3 = xform1 * HomXform::IDENTITY; 00259 if( xform3 != xform1 ) 00260 { 00261 std::cout << "HomXform operator * failed." << std::endl; 00262 errors++; 00263 } 00264 00265 // test operator*= 00266 xform3 *= HomXform::IDENTITY; 00267 if( xform3 != xform1 ) 00268 { 00269 std::cout << "HomXform operator *= failed." << std::endl; 00270 errors++; 00271 } 00272 00273 return errors; 00274 } 00275 00276 int test_xform_functions() 00277 { 00278 int errors = 0; 00279 00280 // HomCoord functions 00281 // length() and length_squared() 00282 HomCoord coord1( 3, 4, 5 ); 00283 if( coord1.length_squared() != 50 || coord1.length() != 7 ) 00284 { 00285 std::cout << "HomCoord length() or length_squared() failed." << std::endl; 00286 errors++; 00287 } 00288 00289 // normalize() 00290 coord1.normalize(); 00291 HomCoord coord2( 3, 0, 0 ); 00292 coord2.normalize(); 00293 if( coord1.length_squared() != 0 || coord2.length_squared() != 1 ) 00294 { 00295 std::cout << "HomCoord normalize failed." << std::endl; 00296 errors++; 00297 } 00298 00299 // sample rotation, translation, and scaling matrices/vectors 00300 int inv_int[] = { 0, 1, 0, 0, -1, 0, 0, 0, 0, 0, 1, 0, 7, 5, 0, 1 }; 00301 00302 // construct an xform matrix based on those 00303 HomXform xform1( inv_int ); 00304 00305 HomXform xform1_inv = xform1.inverse(); 00306 00307 HomXform xform2 = xform1 * xform1_inv; 00308 if( xform2 != HomXform::IDENTITY ) 00309 { 00310 std::cout << "HomXform inverse failed." << std::endl; 00311 errors++; 00312 } 00313 00314 return errors; 00315 } 00316 00317 int test_coord_xform_operators() 00318 { 00319 int errors = 0; 00320 00321 // sample pt 00322 HomCoord test_pt( 1, 2, 3 ); 00323 00324 HomCoord test_pt2 = test_pt * HomXform::IDENTITY; 00325 if( test_pt2 != test_pt ) 00326 { 00327 std::cout << "Coord-xform operator* failed." << std::endl; 00328 errors++; 00329 } 00330 00331 // get an inverse transform quickly 00332 int rotate[] = { 0, 1, 0, -1, 0, 0, 0, 0, 1 }; 00333 int translate[] = { 4, 5, 6 }; 00334 int scale[] = { 1, 1, 1 }; 00335 HomXform xform2( rotate, scale, translate ); 00336 00337 // operator* 00338 HomCoord ident( 1, 1, 1, 1 ); 00339 HomCoord test_pt3 = ident * HomXform::IDENTITY; 00340 if( test_pt3 != ident ) 00341 { 00342 std::cout << "Coord-xform operator* failed." << std::endl; 00343 errors++; 00344 } 00345 00346 // operator/ 00347 test_pt2 = ( test_pt * xform2 ) / xform2; 00348 if( test_pt2 != test_pt ) 00349 { 00350 std::cout << "Coord-xform operator/ failed." << std::endl; 00351 errors++; 00352 } 00353 00354 // test three_pt_xform; use known transforms in most cases 00355 HomXform xform; 00356 00357 // first test: i = j, j = -i, k = k, t = (7,5,0) 00358 xform.three_pt_xform( HomCoord( 0, 0, 0, 1 ), HomCoord( 7, 5, 0, 1 ), HomCoord( 0, 3, 0, 1 ), 00359 HomCoord( 4, 5, 0, 1 ), HomCoord( 0, 0, 3, 1 ), HomCoord( 7, 5, 3, 1 ) ); 00360 00361 HomXform solution( 0, 1, 0, 0, -1, 0, 0, 0, 0, 0, 1, 0, 7, 5, 0, 1 ); 00362 if( xform != solution ) 00363 { 00364 std::cout << "Three-pt transform (general) test failed." << std::endl; 00365 errors++; 00366 } 00367 00368 // now test 1d 00369 xform.three_pt_xform( HomCoord( 0, 0, 0, 1 ), HomCoord( 7, 5, 0, 1 ), HomCoord( 6, 0, 0, 1 ), 00370 HomCoord( 7, 11, 0, 1 ), HomCoord( 0, 0, 0, 1 ), HomCoord( 7, 5, 0, 1 ) ); 00371 00372 solution = HomXform( 0, 1, 0, 0, 1, 0, 0, 0, 0, 0, -1, 0, 7, 5, 0, 1 ); 00373 if( xform != solution ) 00374 { 00375 std::cout << "Three-pt transform (1d) test failed." << std::endl; 00376 errors++; 00377 } 00378 00379 return errors; 00380 }
