MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 // Parts of this test have been taken from MFEM and HPCG benchmark example 00002 00003 #include "moab/Core.hpp" 00004 #include "HypreSolver.hpp" 00005 00006 #include <iostream> 00007 using namespace std; 00008 00009 #undef DEBUG 00010 00011 moab::ErrorCode GenerateTestMatrixAndVectors( int nx, 00012 int ny, 00013 int nz, 00014 moab::HypreParMatrix& A, 00015 moab::HypreParVector& sol, 00016 moab::HypreParVector& rhs, 00017 moab::HypreParVector& exactsol ); 00018 00019 int main( int argc, char* argv[] ) 00020 { 00021 // double norm, d; 00022 int ierr = 0; 00023 double times[5]; 00024 int nx = 5, ny = 5, nz = 5; 00025 #ifdef MOAB_HAVE_MPI 00026 MPI_Init( &argc, &argv ); 00027 int size, rank; // Number of MPI processes, My process ID 00028 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00029 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00030 #else 00031 int size = 1; // Serial case (not using MPI) 00032 int rank = 0; 00033 #endif 00034 MPI_Comm comm = MPI_COMM_WORLD; 00035 00036 moab::Core mbCore; 00037 moab::Interface& mb = mbCore; 00038 00039 // rval = mb.load_file(example.c_str(), &euler_set, opts.c_str()); 00040 00041 moab::ParallelComm* pcomm = new moab::ParallelComm( &mb, comm ); 00042 00043 moab::HypreParMatrix A( pcomm ); 00044 moab::HypreParVector x( pcomm ), b( pcomm ), xexact( pcomm ); 00045 #ifdef DEBUG 00046 00047 if( rank == 0 ) 00048 { 00049 int junk = 0; 00050 cout << "Press enter to continue" << endl; 00051 cin >> junk; 00052 } 00053 00054 MPI_Barrier( MPI_COMM_WORLD ); 00055 #endif 00056 00057 if( argc > 4 ) 00058 { 00059 if( rank == 0 ) 00060 cerr << "Usage:" << endl 00061 << "\t" << argv[0] << " nx ny nz" << endl 00062 << " where nx, ny and nz are the local sub-block dimensions, or" << endl; 00063 00064 exit( 1 ); 00065 } 00066 else 00067 { 00068 if( rank == 0 ) 00069 cout << "Using command:" 00070 << "\t" << argv[0] << " nx ny nz" << endl; 00071 } 00072 00073 times[0] = MPI_Wtime(); // Initialize it (if needed) 00074 00075 if( argc == 4 ) 00076 { 00077 nx = atoi( argv[1] ); 00078 ny = atoi( argv[2] ); 00079 nz = atoi( argv[3] ); 00080 } 00081 00082 GenerateTestMatrixAndVectors( nx, ny, nz, A, x, b, xexact ); 00083 00084 times[1] = MPI_Wtime() - times[0]; // operator creation time 00085 const bool useCG = true; // TODO make into command line option 00086 const bool useAMG = false; // TODO make into command line option 00087 int niters = 0; 00088 double normr = 0; 00089 int max_iter = 150; 00090 double tolerance = 1e-15; // Set tolerance to zero to make all runs do max_iter iterations 00091 times[2] = MPI_Wtime(); // reset 00092 moab::HypreSolver *lsSolver, *psSolver; 00093 00094 if( useCG ) 00095 { 00096 lsSolver = new moab::HyprePCG( A ); 00097 moab::HyprePCG* cgSolver = dynamic_cast< moab::HyprePCG* >( lsSolver ); 00098 cgSolver->SetTol( tolerance ); 00099 cgSolver->SetMaxIter( max_iter ); 00100 cgSolver->SetLogging( 1 ); 00101 cgSolver->Verbosity( 1 ); 00102 cgSolver->SetResidualConvergenceOptions( 3, 0.0 ); 00103 } 00104 else 00105 { 00106 lsSolver = new moab::HypreGMRES( A ); 00107 moab::HypreGMRES* gmresSolver = dynamic_cast< moab::HypreGMRES* >( lsSolver ); 00108 gmresSolver->SetTol( tolerance, normr ); 00109 gmresSolver->SetMaxIter( max_iter ); 00110 gmresSolver->SetLogging( 1 ); 00111 gmresSolver->Verbosity( 5 ); 00112 gmresSolver->SetKDim( 30 ); 00113 } 00114 00115 if( useAMG ) 00116 { 00117 psSolver = new moab::HypreBoomerAMG( A ); 00118 dynamic_cast< moab::HypreBoomerAMG* >( psSolver )->SetSystemsOptions( 3 ); 00119 } 00120 else 00121 { 00122 psSolver = new moab::HypreParaSails( A ); 00123 dynamic_cast< moab::HypreParaSails* >( psSolver )->SetSymmetry( 1 ); 00124 } 00125 00126 if( psSolver ) lsSolver->SetPreconditioner( *psSolver ); 00127 00128 times[2] = MPI_Wtime() - times[2]; // solver setup time 00129 /* Now let us solve the linear system */ 00130 times[3] = MPI_Wtime(); // reset 00131 ierr = lsSolver->Solve( b, x ); 00132 00133 if( ierr ) cerr << "Error in call to CG/GMRES HYPRE Solver: " << ierr << ".\n" << endl; 00134 00135 times[3] = MPI_Wtime() - times[3]; // solver time 00136 lsSolver->GetNumIterations( niters ); 00137 lsSolver->GetFinalResidualNorm( normr ); 00138 times[4] = MPI_Wtime() - times[0]; 00139 // x.Print ( "solution.out" ); 00140 #ifdef MOAB_HAVE_MPI 00141 double t4 = times[3]; 00142 double t4min = 0.0; 00143 double t4max = 0.0; 00144 double t4avg = 0.0; 00145 MPI_Allreduce( &t4, &t4min, 1, MPI_DOUBLE, MPI_MIN, MPI_COMM_WORLD ); 00146 MPI_Allreduce( &t4, &t4max, 1, MPI_DOUBLE, MPI_MAX, MPI_COMM_WORLD ); 00147 MPI_Allreduce( &t4, &t4avg, 1, MPI_DOUBLE, MPI_SUM, MPI_COMM_WORLD ); 00148 t4avg = t4avg / ( (double)size ); 00149 #endif 00150 00151 if( rank == 0 ) 00152 { // Only PE 0 needs to compute and report timing results 00153 // double fniters = niters; 00154 // double fnrow = A.NNZ(); 00155 // double fnnz = A.M(); 00156 // double fnops_ddot = fniters * 4 * fnrow; 00157 // double fnops_waxpby = fniters * 6 * fnrow; 00158 // double fnops_sparsemv = fniters * 2 * fnnz; 00159 // double fnops = fnops_ddot + fnops_waxpby + fnops_sparsemv; 00160 std::cout << "Testing Laplace problem solver with HYPRE interface\n"; 00161 { 00162 std::cout << "\tParallelism\n"; 00163 #ifdef MOAB_HAVE_MPI 00164 std::cout << "Number of MPI ranks: \t" << size << std::endl; 00165 #else 00166 std::cout << "MPI not enabled\n"; 00167 #endif 00168 } 00169 std::cout << "Dimensions (nx*ny*nz): \t(" << nx << "*" << ny << "*" << nz << ")\n"; 00170 std::cout << "Number of iterations: \t" << niters << std::endl; 00171 std::cout << "Final residual: \t" << normr << std::endl; 00172 std::cout << "************ Performance Summary (times in sec) *************" << std::endl; 00173 { 00174 std::cout << "\nTime Summary" << std::endl; 00175 std::cout << "Total \t" << times[4] << std::endl; 00176 std::cout << "Operator Creation \t" << times[1] << std::endl; 00177 std::cout << "Solver Setup \t" << times[2] << std::endl; 00178 std::cout << "HYPRE Solver \t" << times[3] << std::endl; 00179 std::cout << "Avg. Solver \t" << t4avg << std::endl; 00180 } 00181 } 00182 00183 // Compute difference between known exact solution and computed solution 00184 // All processors are needed here. 00185 // double residual = 0; 00186 // if ((ierr = ComputeLinfError(x, xexact, &residual))) 00187 // cerr << "Error in call to ComputeLinfError: " << ierr << ".\n" << endl; 00188 // if (rank==0) 00189 // cout << "Difference between computed and exact = " 00190 // << residual << ".\n" << endl; 00191 delete lsSolver; 00192 // Finish up 00193 #ifdef MOAB_HAVE_MPI 00194 MPI_Finalize(); 00195 #endif 00196 return 0; 00197 } 00198 00199 moab::ErrorCode GenerateTestMatrixAndVectors( int nx, 00200 int ny, 00201 int nz, 00202 moab::HypreParMatrix& A, 00203 moab::HypreParVector& sol, 00204 moab::HypreParVector& rhs, 00205 moab::HypreParVector& exactsol ) 00206 { 00207 #ifdef DEBUG 00208 int debug = 1; 00209 #else 00210 int debug = 0; 00211 #endif 00212 #ifdef MOAB_HAVE_MPI 00213 int size, rank; // Number of MPI processes, My process ID 00214 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00215 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00216 #else 00217 int size = 1; // Serial case (not using MPI) 00218 int rank = 0; 00219 #endif 00220 // Set this bool to true if you want a 7-pt stencil instead of a 27 pt stencil 00221 bool use_7pt_stencil = false; 00222 const int NNZPERROW = 27; 00223 00224 int local_nrow = nx * ny * nz; // This is the size of our subblock 00225 assert( local_nrow > 0 ); // Must have something to work with 00226 int local_nnz = NNZPERROW * local_nrow; // Approximately 27 nonzeros per row (except for boundary nodes) 00227 int total_nrow = 0; 00228 MPI_Allreduce( &local_nrow, &total_nrow, 1, MPI_DOUBLE, MPI_SUM, MPI_COMM_WORLD ); 00229 00230 // int total_nrow = local_nrow * size; // Total number of grid points in mesh 00231 long long total_nnz = 00232 NNZPERROW * (long long)total_nrow; // Approximately 27 nonzeros per row (except for boundary nodes) 00233 int start_row = local_nrow * rank; // Each processor gets a section of a chimney stack domain 00234 int stop_row = start_row + local_nrow - 1; 00235 00236 // Allocate arrays that are of length local_nrow 00237 // Eigen::SparseMatrix<double, Eigen::RowMajor> diagMatrix(local_nrow, local_nrow); 00238 // diagMatrix.reserve(local_nnz); 00239 HYPRE_Int col[2] = { start_row, stop_row }; 00240 A.resize( total_nrow, col ); 00241 00242 sol.resize( total_nrow, start_row, stop_row ); 00243 rhs.resize( total_nrow, start_row, stop_row ); 00244 exactsol.resize( total_nrow, start_row, stop_row ); 00245 long long nnzglobal = 0; 00246 00247 for( int iz = 0; iz < nz; iz++ ) 00248 { 00249 for( int iy = 0; iy < ny; iy++ ) 00250 { 00251 for( int ix = 0; ix < nx; ix++ ) 00252 { 00253 const int curlocalrow = iz * nx * ny + iy * nx + ix; 00254 const int currow = start_row + curlocalrow; 00255 int nnzrow = 0; 00256 std::vector< double > colvals; 00257 std::vector< int > indices; 00258 00259 for( int sz = -1; sz <= 1; sz++ ) 00260 { 00261 for( int sy = -1; sy <= 1; sy++ ) 00262 { 00263 for( int sx = -1; sx <= 1; sx++ ) 00264 { 00265 const int curlocalcol = sz * nx * ny + sy * nx + sx; 00266 const int curcol = currow + curlocalcol; 00267 00268 // Since we have a stack of nx by ny by nz domains , stacking in the z 00269 // direction, we check to see if sx and sy are reaching outside of the 00270 // domain, while the check for the curcol being valid is sufficient to 00271 // check the z values 00272 if( ( ix + sx >= 0 ) && ( ix + sx < nx ) && ( iy + sy >= 0 ) && ( iy + sy < ny ) && 00273 ( curcol >= 0 && curcol < total_nrow ) ) 00274 { 00275 if( !use_7pt_stencil || ( sz * sz + sy * sy + sx * sx <= 1 ) ) 00276 { // This logic will skip over point that are not part of a 7-pt 00277 // stencil 00278 if( curcol == currow ) 00279 { 00280 colvals.push_back( 27.0 ); 00281 } 00282 else 00283 { 00284 colvals.push_back( -1.0 ); 00285 } 00286 00287 indices.push_back( curcol ); 00288 nnzrow++; 00289 } 00290 } 00291 } // end sx loop 00292 } // end sy loop 00293 } // end sz loop 00294 00295 int ncols = indices.size(); 00296 A.SetValues( 1, &ncols, &currow, indices.data(), colvals.data() ); 00297 // diagMatrix.set_row_values ( curlocalrow, indices.size(), indices.data(), 00298 // colvals.data() ); 00299 nnzglobal += nnzrow; 00300 sol.SetValue( currow, 0.0 ); 00301 rhs.SetValue( currow, 27.0 - ( (double)( nnzrow - 1 ) ) ); 00302 exactsol.SetValue( currow, 1.0 ); 00303 } // end ix loop 00304 } // end iy loop 00305 } // end iz loop 00306 00307 if( debug ) 00308 cout << "Global size of the matrix: " << total_nrow << " and NNZ (estimate) = " << total_nnz 00309 << " NNZ (actual) = " << nnzglobal << endl; 00310 00311 if( debug ) cout << "Process " << rank << " of " << size << " has " << local_nrow << endl; 00312 00313 if( debug ) cout << " rows. Global rows " << start_row << " through " << stop_row << endl; 00314 00315 if( debug ) cout << "Process " << rank << " of " << size << " has " << local_nnz << " nonzeros." << endl; 00316 00317 A.FinalizeAssembly(); 00318 sol.FinalizeAssembly(); 00319 rhs.FinalizeAssembly(); 00320 exactsol.FinalizeAssembly(); 00321 // A.Print("matrix.out"); 00322 return moab::MB_SUCCESS; 00323 }
