MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 //------------------------------------------------------------------------- 00002 // Filename : netcdfcpp_par.hpp 00003 // 00004 // Purpose : Parallel C++ Climate NC file read/write 00005 // 00006 // Creator : Vijay Mahadevan 00007 //------------------------------------------------------------------------- 00008 00009 #if defined( MOAB_HAVE_NETCDFPAR ) && defined( MOAB_HAVE_TEMPESTREMAP ) 00010 #include "netcdf_par.h" 00011 #include "netcdfcpp.h" 00012 00013 class ParNcFile : public NcFile 00014 { 00015 public: 00016 ParNcFile( MPI_Comm comm, 00017 MPI_Info comm_info, 00018 const char* path, 00019 FileMode fmode = ReadOnly, 00020 FileFormat fformat = Classic ) 00021 : NcFile(), m_comm( comm ) 00022 { 00023 NcError err( NcError::silent_nonfatal ); // constructor must not fail 00024 00025 int mode = NC_NOWRITE; 00026 the_fill_mode = Fill; 00027 int status; 00028 00029 // If the user wants a 64-bit offset format, set that flag. 00030 if( fformat == Offset64Bits ) mode |= NC_64BIT_OFFSET; 00031 #ifndef NETCDF3_ONLY 00032 else if( fformat == Netcdf4 ) 00033 mode |= NC_NETCDF4; 00034 else if( fformat == Netcdf4Classic ) 00035 mode |= NC_NETCDF4 | NC_CLASSIC_MODEL; 00036 #endif 00037 mode |= NC_MPIIO; 00038 00039 switch( fmode ) 00040 { 00041 case Write: 00042 mode |= NC_WRITE; 00043 /*FALLTHRU*/ 00044 case ReadOnly: 00045 // use netcdf-3 interface to permit specifying tuning parameter 00046 status = NcError::set_err( nc_open_par( path, mode, comm, comm_info, &the_id ) ); 00047 if( status != NC_NOERR ) 00048 { 00049 NcError::set_err( status ); 00050 the_id = -1; 00051 } 00052 in_define_mode = 0; 00053 break; 00054 case New: 00055 mode |= NC_NOCLOBBER; 00056 /*FALLTHRU*/ 00057 case Replace: 00058 // use netcdf-3 interface to permit specifying tuning parameters 00059 status = NcError::set_err( nc_create_par( path, mode, comm, comm_info, &the_id ) ); 00060 if( status != NC_NOERR ) 00061 { 00062 NcError::set_err( status ); 00063 the_id = -1; 00064 } 00065 in_define_mode = 1; 00066 break; 00067 default: 00068 the_id = ncBad; 00069 in_define_mode = 0; 00070 break; 00071 } 00072 if( is_valid() ) 00073 { 00074 dimensions = new NcDim*[NC_MAX_DIMS]; 00075 variables = new NcVar*[NC_MAX_VARS]; 00076 int i; 00077 for( i = 0; i < num_dims(); i++ ) 00078 dimensions[i] = new NcDim( this, i ); 00079 for( i = 0; i < num_vars(); i++ ) 00080 variables[i] = new NcVar( this, i ); 00081 globalv = new NcVar( this, ncGlobal ); 00082 } 00083 else 00084 { 00085 dimensions = 0; 00086 variables = 0; 00087 globalv = 0; 00088 } 00089 } 00090 00091 virtual ~ParNcFile( void ){}; 00092 00093 NcBool enable_var_par_access( NcVar* var, bool is_independent = true ) // synchronize to disk 00094 { 00095 int status; 00096 status = NcError::set_err( 00097 nc_var_par_access( the_id, var->id(), ( is_independent ? NC_INDEPENDENT : NC_COLLECTIVE ) ) ); 00098 if( status != NC_NOERR ) 00099 { 00100 NcError::set_err( status ); 00101 return 0; 00102 } 00103 return 1; 00104 } 00105 00106 protected: 00107 MPI_Comm m_comm; 00108 static const int ncGlobal = NC_GLOBAL; // psuedo-variable for global attributes 00109 static const int ncBad = -1; // failure return for netCDF C interface 00110 }; 00111 00112 #endif // #if defined(MOAB_HAVE_NETCDFPAR) && defined(MOAB_HAVE_TEMPESTREMAP)
