MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2007 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2007) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file main.cpp 00028 * \brief Test syncronous boundary case 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "ConditionNumberQualityMetric.hpp" 00034 #include "IdealWeightInverseMeanRatio.hpp" 00035 #include "LPtoPTemplate.hpp" 00036 #include "InstructionQueue.hpp" 00037 #include "ConjugateGradient.hpp" 00038 #include "FeasibleNewton.hpp" 00039 #include "MeshImpl.hpp" 00040 #include "QualityAssessor.hpp" 00041 #include "XYRectangle.hpp" 00042 00043 #include <iostream> 00044 #include <fstream> 00045 #include <cstdlib> 00046 00047 using namespace MBMesquite; 00048 00049 // constants 00050 const double min_x = 0.0, max_x = 2.0; 00051 const double min_y = 0.0, mid_y = 1.0, max_y = 2.0; 00052 const double z = 0.0; 00053 00054 const char default_out_file[] = "synchronous.vtk"; 00055 double default_x = 0.25; 00056 00057 void create_input_mesh( double mid_x, MBMesquite::MeshImpl& mesh, MBMesquite::MsqError& ); 00058 00059 void usage( const char* argv0, bool brief = true ) 00060 { 00061 std::ostream& str = brief ? std::cerr : std::cout; 00062 00063 str << "Usage: " << argv0 << " [-x <coord>]" 00064 << " [-j|-n|-d]" 00065 << " [-r|-c]" 00066 << " [<output_file>]" << std::endl; 00067 if( brief ) 00068 { 00069 str << " " << argv0 << " -h" << std::endl; 00070 std::exit( 1 ); 00071 } 00072 00073 str << " -x Specify X coordinate value for mesh (default is " << default_x << ")" << std::endl 00074 << " -j Use ConjugateGradient solver (default)" << std::endl 00075 << " -n Use FeasibleNewton solver" << std::endl 00076 << " -r Use IdealWeightInverseMeanRation metric" << std::endl 00077 << " -c Use ConditionNumber metric (default)" << std::endl 00078 << "Default output file is \"" << default_out_file << '"' << std::endl; 00079 00080 std::exit( 0 ); 00081 } 00082 00083 char mSolver = '\0', mMetric = '\0'; 00084 const char* outputFile = default_out_file; 00085 double input_x = default_x; 00086 00087 void parse_options( char* argv[], int argc ) 00088 { 00089 bool next_arg_is_x = false; 00090 for( int i = 1; i < argc; ++i ) 00091 { 00092 if( next_arg_is_x ) 00093 { 00094 next_arg_is_x = false; 00095 char* endptr = 0; 00096 input_x = std::strtod( argv[i], &endptr ); 00097 if( endptr && *endptr ) usage( argv[0] ); 00098 continue; 00099 } 00100 00101 if( argv[i][0] != '-' ) 00102 { 00103 if( outputFile != default_out_file ) usage( argv[0] ); 00104 outputFile = argv[i]; 00105 continue; 00106 } 00107 00108 for( const char* p = argv[i] + 1; *p; ++p ) 00109 { 00110 switch( *p ) 00111 { 00112 case 'x': 00113 next_arg_is_x = true; 00114 break; 00115 00116 case 'j': 00117 case 'n': 00118 if( mSolver ) usage( argv[0] ); 00119 mSolver = *p; 00120 break; 00121 00122 case 'r': 00123 case 'c': 00124 if( mMetric ) usage( argv[0] ); 00125 mMetric = *p; 00126 break; 00127 00128 default: 00129 usage( argv[0], *p != 'h' ); 00130 break; 00131 } 00132 } 00133 } 00134 00135 if( next_arg_is_x ) usage( argv[0] ); 00136 00137 // default values 00138 if( !mMetric ) mMetric = 'c'; 00139 if( !mSolver ) mSolver = 'j'; 00140 } 00141 00142 int main( int argc, char* argv[] ) 00143 { 00144 parse_options( argv, argc ); 00145 00146 MeshImpl mesh; 00147 XYRectangle domain( max_x - min_x, max_y - min_y, min_x, min_y ); 00148 MsqError err; 00149 00150 create_input_mesh( input_x, mesh, err ); 00151 if( MSQ_CHKERR( err ) ) 00152 { 00153 std::cerr << err << std::endl; 00154 return 2; 00155 } 00156 00157 domain.setup( &mesh, err ); 00158 if( MSQ_CHKERR( err ) ) 00159 { 00160 std::cerr << err << std::endl; 00161 return 2; 00162 } 00163 00164 QualityMetric* metric = 0; 00165 if( mMetric == 'c' ) 00166 metric = new ConditionNumberQualityMetric; 00167 else 00168 metric = new IdealWeightInverseMeanRatio; 00169 00170 LPtoPTemplate function( 1, metric ); 00171 00172 VertexMover* solver = 0; 00173 if( mSolver == 'j' ) 00174 solver = new ConjugateGradient( &function ); 00175 else 00176 solver = new FeasibleNewton( &function ); 00177 00178 if( PatchSetUser* psu = dynamic_cast< PatchSetUser* >( solver ) ) psu->use_global_patch(); 00179 00180 TerminationCriterion inner; 00181 inner.add_absolute_vertex_movement( 1e-4 ); 00182 inner.write_mesh_steps( "synchronous", TerminationCriterion::GNUPLOT ); 00183 solver->set_inner_termination_criterion( &inner ); 00184 00185 InstructionQueue q; 00186 QualityAssessor qa( metric, 10 ); 00187 q.add_quality_assessor( &qa, err ); 00188 q.set_master_quality_improver( solver, err ); 00189 q.add_quality_assessor( &qa, err ); 00190 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &domain ); 00191 q.run_instructions( &mesh_and_domain, err ); 00192 delete solver; 00193 delete metric; 00194 00195 if( MSQ_CHKERR( err ) ) 00196 { 00197 std::cerr << err << std::endl; 00198 return 3; 00199 } 00200 00201 mesh.write_vtk( outputFile, err ); 00202 if( MSQ_CHKERR( err ) ) 00203 { 00204 std::cerr << err << std::endl; 00205 return 2; 00206 } 00207 00208 return 0; 00209 } 00210 00211 const char* temp_file = "syncrononous_input.vtk"; 00212 void create_input_mesh( double mid_x, MeshImpl& mesh, MsqError& err ) 00213 { 00214 std::ofstream vtkfile( temp_file ); 00215 vtkfile << "# vtk DataFile Version 3.0" << std::endl 00216 << "Mesquite Syncronous Boundary test" << std::endl 00217 << "ASCII" << std::endl 00218 << "DATASET UNSTRUCTURED_GRID" << std::endl 00219 << "POINTS 9 float" << std::endl 00220 << min_x << ' ' << max_y << ' ' << z << std::endl 00221 << mid_x << ' ' << max_y << ' ' << z << std::endl 00222 << max_x << ' ' << max_y << ' ' << z << std::endl 00223 << min_x << ' ' << mid_y << ' ' << z << std::endl 00224 << mid_x << ' ' << mid_y << ' ' << z << std::endl 00225 << max_x << ' ' << mid_y << ' ' << z << std::endl 00226 << min_x << ' ' << min_y << ' ' << z << std::endl 00227 << mid_x << ' ' << min_y << ' ' << z << std::endl 00228 << max_x << ' ' << min_y << ' ' << z << std::endl 00229 << "CELLS 4 20" << std::endl 00230 << "4 1 0 3 4" << std::endl 00231 << "4 2 1 4 5" << std::endl 00232 << "4 4 3 6 7" << std::endl 00233 << "4 5 4 7 8" << std::endl 00234 << "CELL_TYPES 4" << std::endl 00235 << "9 9 9 9" << std::endl 00236 << "POINT_DATA 9" << std::endl 00237 << "SCALARS fixed int" << std::endl 00238 << "LOOKUP_TABLE default" << std::endl 00239 << "1 0 1" << std::endl 00240 << "1 0 1" << std::endl 00241 << "1 0 1" << std::endl; 00242 vtkfile.close(); 00243 00244 mesh.read_vtk( temp_file, err ); 00245 remove( temp_file ); 00246 }
