cgma
CubitCompat.cpp
00001 #include "CubitCompat.h"
00002 #include "CubitCompat.hpp"
00003 #include "GeometryQueryTool.hpp"
00004 #include <string.h>
00005
00006 #define CUBIT_COMPAT_FT_ELIF(TYPE) \
00007   else if (!strcmp(file_type,#TYPE)) \
00008     return TYPE ## _TYPE
00009
00010 static Model_File_Type
00011 CubitCompat_file_type( const char* file_type )
00012 {
00013   if (!file_type)
00014     return MFT_NOT_DEFINED;
00015   CUBIT_COMPAT_FT_ELIF(IGES);
00016   CUBIT_COMPAT_FT_ELIF(CATIA);
00017   CUBIT_COMPAT_FT_ELIF(STEP);
00018   CUBIT_COMPAT_FT_ELIF(PROE);
00019   CUBIT_COMPAT_FT_ELIF(GRANITE);
00020   CUBIT_COMPAT_FT_ELIF(GRANITE_G);
00021   CUBIT_COMPAT_FT_ELIF(GRANITE_SAT);
00022   CUBIT_COMPAT_FT_ELIF(GRANITE_PROE_PART);
00023   CUBIT_COMPAT_FT_ELIF(GRANITE_PROE_ASM);
00024   CUBIT_COMPAT_FT_ELIF(GRANITE_NEUTRAL);
00025   CUBIT_COMPAT_FT_ELIF(NCGM);
00026   CUBIT_COMPAT_FT_ELIF(CATIA_NCGM);
00027   CUBIT_COMPAT_FT_ELIF(CATPART);
00028   CUBIT_COMPAT_FT_ELIF(CATPRODUCT);
00029   CUBIT_COMPAT_FT_ELIF(FACET);
00030   CUBIT_COMPAT_FT_ELIF(SOLIDWORKS);
00031   CUBIT_COMPAT_FT_ELIF(OCC);
00032   else
00033     return MFT_NOT_DEFINED;
00034 }
00035
00036 CubitStatus
00037 CubitCompat_import_solid_model( const char* file_name,
00038                                 const char* file_type,
00039                                 const char* logfile_name,
00040                                 CubitBoolean heal_step,
00041                                 CubitBoolean import_bodies,
00042                                 CubitBoolean import_surfaces,
00043                                 CubitBoolean import_curves,
00044                                 CubitBoolean import_vertices,
00045                                 CubitBoolean free_surfaces,
00046                 DLIList<RefEntity*> *imported_entities)
00047 {
00048   const bool print_results = false;
00049   const bool merge_globally = false;
00050   const bool no_assembly_level_features = false;
00051   ModelImportOptions CubitCompat_opts = { heal_step,
00052                                         print_results,
00053                                         import_bodies,
00054                                         import_surfaces,
00055                                         import_curves,
00056                                         import_vertices,
00057                                         free_surfaces,
00058                                         merge_globally,
00059                                         no_assembly_level_features,
00060                                         logfile_name ? logfile_name : "" };
00061
00062   return GeometryQueryTool::instance()->import_solid_model(
00063            file_name,
00064            CubitCompat_file_type(file_type),
00065            CubitCompat_opts,
00066            imported_entities );
00067 }
00068
00069 CubitStatus
00070 CubitCompat_export_solid_model( DLIList<RefEntity*>& ref_entity_list,
00071                                 const char* filename,
00072                                 const char * filetype,
00073                                 int &num_ents_exported,
00074                                 const CubitString &cubit_version,
00075                                 const char* logfile_name )
00076 {
00077 //  const bool print_results = false;
00078 //  const bool merge_globally = false;
00079 //  const bool no_assembly_level_features = false;
00080   ModelExportOptions CubitCompat_opts = {1, logfile_name ? logfile_name : "" };
00081
00082   return GeometryQueryTool::instance()->export_solid_model(
00083            ref_entity_list,
00084            filename,
00085            CubitCompat_file_type(filetype),
00086            num_ents_exported,
00087            cubit_version,
00088            CubitCompat_opts );
00089 }
