cgma
BoundingBoxTool Member List
This is the complete list of members for BoundingBoxTool, including all inherited members.
append_body_points(DLIList< Body * > &body_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol)BoundingBoxTool [private, static]
append_curve_points(DLIList< RefEdge * > &ref_edge_list, DLIList< CubitVector * > &vec_list)BoundingBoxTool [private, static]
append_ref_entity_points(DLIList< RefEntity * > &ref_entity_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol)BoundingBoxTool [private, static]
append_surface_points(DLIList< RefFace * > &ref_face_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol)BoundingBoxTool [private, static]
append_vertex_points(DLIList< RefVertex * > &ref_vertex_list, DLIList< CubitVector * > &vec_list)BoundingBoxTool [private, static]
append_volume_points(DLIList< RefVolume * > &vol_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol)BoundingBoxTool [private, static]
BoundingBoxTool()BoundingBoxTool [protected]
expand_groups_in_list(DLIList< RefEntity * > &ref_entity_list)BoundingBoxTool [private, static]
get_axis_bounding_box(DLIList< RefEntity * > &ref_entity_list, CubitVector &center, CubitVector axes[3], CubitVector &extension)BoundingBoxTool [static]
get_corner_points(CubitVector &center, CubitVector axes[3], CubitVector &extension, CubitVector &p1, CubitVector &p2, CubitVector &p3, CubitVector &p4, CubitVector &p5, CubitVector &p6, CubitVector &p7, CubitVector &p8)BoundingBoxTool [static]
get_tight_bounding_box(DLIList< RefEntity * > &ref_entity_list, CubitVector &center, CubitVector axes[3], CubitVector &extension, double ang_facet_tol, double abs_facet_tol)BoundingBoxTool [static]
get_use_curves()BoundingBoxTool [static]
get_use_curves_setting()BoundingBoxTool [static]
get_use_triangles()BoundingBoxTool [static]
get_use_triangles_setting()BoundingBoxTool [static]
get_use_vertices()BoundingBoxTool [static]
get_use_vertices_setting()BoundingBoxTool [static]
initialize_settings()BoundingBoxTool [static]
set_use_curves(CubitBoolean val)BoundingBoxTool [static]
set_use_curves_setting(int val)BoundingBoxTool [static]
set_use_triangles(CubitBoolean val)BoundingBoxTool [static]
set_use_triangles_setting(int val)BoundingBoxTool [static]
set_use_vertices(CubitBoolean val)BoundingBoxTool [static]
set_use_vertices_setting(int val)BoundingBoxTool [static]
useCurvesBoundingBoxTool [private, static]
useTrianglesBoundingBoxTool [private, static]
useVerticesBoundingBoxTool [private, static]
~BoundingBoxTool()BoundingBoxTool [protected]
