MeshKit  1.0
AssyMesher Class Reference
#include <AssyMesher.hpp>
Inheritance diagram for AssyMesher:
List of all members.
Public Member Functions
 AssyMesher (MKCore *mkcore, const MEntVector &me_vec)
virtual ~AssyMesher ()
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
virtual bool add_modelent (ModelEnt *model_ent)
 Re-implemented here so we can check topological dimension of model_ent.
virtual void setup_this ()
 Setup is a no-op, but must be provided since it's pure virtual.
virtual void execute_this ()
 The only setup/execute function we need, since meshing vertices is trivial.
void PrepareIO (int argc, char *argv[], std::string TestDir)
 Prepare input/output files for reading/writing command line args and testdir for default test case.
void ReadPinCellData (int i)
 Read pincell data input file.
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Types
enum  ErrorStates {
  PINCELLS, INVALIDINPUT, EMAT, EGEOMTYPE,
  EGEOMENGINE, ENEGATIVE, EALIAS, EPIN
Private Member Functions
void IOErrorHandler (ErrorStates) const
std::vector
< iGeom::EntityHandle > *
selectByMaterialsAndNameSuffix (std::vector< iGeom::EntityHandle > const &geoEntVec, std::set< std::string > const &matFilter, const char *suffix) const
void createMaterialNeumannSets (std::set< std::string > const &matFilter)
void createMaterialNeumannSets ()
Private Attributes
iGeomigeom
 iGeom Impl for calling geometry creation/manipulation operations
iMeshimesh
 iMesh Impl for calling mesh creation/manipulation operations
moab::Interface * mb
 MOAB Impl for calling mesh creation/manipulation operations.
std::vector< iBase_EntityHandle > assms
std::vector< iBase_EntityHandle > in_pins
int m_nSides
std::ifstream m_FileInput
std::ifstream m_FileCommon
mstream m_LogFile
std::string szInputString
std::string szComment
int MAXCHARS
bool have_common
std::string m_InputFile
std::string m_szCommonFile
std::string m_GeomFile
std::string m_MeshFile
std::string m_OutFile
std::string m_LogName
std::string m_MeshType
std::string m_Card
CMatrix< std::string > m_Assembly
CMatrix< double > m_dMTopSurfCoords
CMatrix< double > m_dMAssmPitch
CMatrix< double > m_dMAssmPitchX
CMatrix< double > m_dMAssmPitchY
CMatrix< double > m_dMXYAssm
CMatrix< double > m_dMZAssm
CVector< std::string > m_szAssmMat
CVector< std::string > m_szAssmMatAlias
CMatrix< std::string > m_szMMAlias
CVector< CPincellm_Pincell
std::string m_szEngine
std::string m_szGeomType
std::string m_szMeshType
std::string m_szSideset
int m_nAssemblyMat
int m_nDimensions
int m_nPincells
int m_nLineNumber
int m_nPlanar
int m_nNeumannSetId
int m_nMaterialSetId
int m_nDuct
int m_nDuctNum
int m_nJouFlag
double m_dPitch
double pi
double m_dRadialSize
double m_dAxialSize
double m_dTetMeshSize
double m_dMergeTol
std::set< std::string > allMtrlsSet
Detailed Description
Definition at line 36 of file AssyMesher.hpp.
Member Enumeration Documentation
enum ErrorStates [private]
Enumerator:
PINCELLS
INVALIDINPUT
EMAT
EGEOMTYPE
EGEOMENGINE
ENEGATIVE
EALIAS
EPIN
Definition at line 128 of file AssyMesher.hpp.
AssyMesher ( MKCore mkcore,
const MEntVector me_vec
Definition at line 27 of file AssyMesher.cpp.
~AssyMesher ( ) [virtual]
Definition at line 53 of file AssyMesher.cpp.
Member Function Documentation
bool add_modelent ( ModelEnt model_ent) [virtual]
Parameters:
model_entModelEnt being added
Reimplemented from MeshOp.
Definition at line 56 of file AssyMesher.cpp.
bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 181 of file AssyMesher.hpp.
bool can_mesh ( ModelEnt me) [inline, static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 188 of file AssyMesher.hpp.
void createMaterialNeumannSets ( std::set< std::string > const &  matFilter) [private]
Definition at line 1091 of file AssyMesher.cpp.
void createMaterialNeumannSets ( ) [private]
Definition at line 1123 of file AssyMesher.cpp.
void execute_this ( ) [virtual]
Implements GraphNode.
Definition at line 259 of file AssyMesher.cpp.
void IOErrorHandler ( ErrorStates  ECode) const [private]
Function: Displays error messages related to input data
Input: Error code
Output: none
Definition at line 1001 of file AssyMesher.cpp.
const moab::EntityType * mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 193 of file AssyMesher.hpp.
const char * name ( ) [inline, static]
Get class name.
Definition at line 176 of file AssyMesher.hpp.
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 24 of file AssyMesher.cpp.
void PrepareIO ( int  argc,
char *  argv[],
std::string  TestDir
Definition at line 279 of file AssyMesher.cpp.
void ReadPinCellData ( int  i)
Definition at line 744 of file AssyMesher.cpp.
std::vector< iGeom::EntityHandle > * selectByMaterialsAndNameSuffix ( std::vector< iGeom::EntityHandle > const &  geoEntVec,
std::set< std::string > const &  matFilter,
const char *  suffix
) const [private]
Definition at line 1034 of file AssyMesher.cpp.
void setup_this ( ) [virtual]
Definition at line 61 of file AssyMesher.cpp.
Member Data Documentation
std::set<std::string> allMtrlsSet [private]
Definition at line 163 of file AssyMesher.hpp.
std::vector<iBase_EntityHandle> assms [private]
Definition at line 110 of file AssyMesher.hpp.
bool have_common [private]
Definition at line 121 of file AssyMesher.hpp.
iGeom* igeom [private]
Definition at line 101 of file AssyMesher.hpp.
iMesh* imesh [private]
Definition at line 104 of file AssyMesher.hpp.
std::vector<iBase_EntityHandle> in_pins [private]
CMatrix<std::string> m_Assembly [private]
Definition at line 134 of file AssyMesher.hpp.
std::string m_Card [private]
Definition at line 125 of file AssyMesher.hpp.
double m_dAxialSize [private]
Definition at line 160 of file AssyMesher.hpp.
CMatrix<double> m_dMAssmPitch [private]
Definition at line 140 of file AssyMesher.hpp.
CMatrix<double> m_dMAssmPitchX [private]
CMatrix<double> m_dMAssmPitchY [private]
double m_dMergeTol [private]
CMatrix<double> m_dMTopSurfCoords [private]
Definition at line 137 of file AssyMesher.hpp.
CMatrix<double> m_dMXYAssm [private]
CMatrix<double> m_dMZAssm [private]
double m_dPitch [private]
double m_dRadialSize [private]
double m_dTetMeshSize [private]
std::ifstream m_FileCommon [private]
Definition at line 116 of file AssyMesher.hpp.
std::ifstream m_FileInput [private]
std::string m_GeomFile [private]
Definition at line 124 of file AssyMesher.hpp.
std::string m_InputFile [private]
mstream m_LogFile [private]
Definition at line 117 of file AssyMesher.hpp.
std::string m_LogName [private]
std::string m_MeshFile [private]
std::string m_MeshType [private]
int m_nAssemblyMat [private]
Definition at line 156 of file AssyMesher.hpp.
int m_nDimensions [private]
int m_nDuct [private]
int m_nDuctNum [private]
int m_nJouFlag [private]
int m_nLineNumber [private]
int m_nMaterialSetId [private]
int m_nNeumannSetId [private]
int m_nPincells [private]
int m_nPlanar [private]
int m_nSides [private]
Definition at line 113 of file AssyMesher.hpp.
std::string m_OutFile [private]
Definition at line 147 of file AssyMesher.hpp.
CVector<std::string> m_szAssmMat [private]
Definition at line 143 of file AssyMesher.hpp.
CVector<std::string> m_szAssmMatAlias [private]
std::string m_szCommonFile [private]
std::string m_szEngine [private]
Definition at line 150 of file AssyMesher.hpp.
std::string m_szGeomType [private]
Definition at line 151 of file AssyMesher.hpp.
std::string m_szMeshType [private]
Definition at line 152 of file AssyMesher.hpp.
CMatrix<std::string> m_szMMAlias [private]
Definition at line 144 of file AssyMesher.hpp.
std::string m_szSideset [private]
Definition at line 153 of file AssyMesher.hpp.
int MAXCHARS [private]
Definition at line 120 of file AssyMesher.hpp.
moab::Interface* mb [private]
Definition at line 107 of file AssyMesher.hpp.
double pi [private]
std::string szComment [private]
Definition at line 119 of file AssyMesher.hpp.
std::string szInputString [private]
Definition at line 118 of file AssyMesher.hpp.
