MeshKit  1.0
EBMesher Class Reference
A meshing geometry as Cartesian structured mesh It makes constructs tree structure with triangles and makes hexes bounding geometry With ray-tracing, find intersections and determine element inside/outside/boundary. Intersection fraction is stored to boundary elements. Element inside/outside/boundary status are stored as tag. More...
#include <meshkit/EBMesher.hpp>
Inheritance diagram for EBMesher:
List of all members.
Public Member Functions
 EBMesher (MKCore *mkcore, const MEntVector &me_vec, double size=-1., bool use_geom=true, int add_layer=3)
 Bare constructor.
virtual ~EBMesher ()
 Destructor.
virtual const moab::EntityType * mesh_types_arr () const
 Return the mesh entity types operated on by this scheme.
virtual bool add_modelent (ModelEnt *model_ent)
 Add a ModelEnt to this operation's MEntSelection The MEntSelection is a map, and can only have a given entity once.
int set_division (double *min, double *max)
 set # of divisions (x/y/z directions) of Cartesian box to use SCDMesh output
virtual void setup_this ()
 Setup is a no-op, but must be provided since it's pure virtual.
virtual void execute_this ()
void get_grid_and_edges_techX (double *boxMin, double *boxMax, int *nDiv, std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &rmdCutCellSurfEdge, std::vector< int > &rvnInsideCell, bool isCornerExterior=true)
 query function for techX
bool get_grid_and_edges (double *boxMin, double *boxMax, int *nDiv, std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &rmdCutCellEdge, std::vector< int > &rvnInsideCell, bool isCornerExterior=true)
 query function to get multiple cut-cell edges
bool get_volume_fraction (int vol_frac_div)
 get volume fraction for each material
void export_mesh (const char *file_name, bool separate=false)
 export mesh to file
void set_num_interval (int *n_interval)
 set number of intervals
void increase_box (double box_increase)
void use_whole_geom (int use)
 set if mesh for whole geometry at once or individually
void use_mesh_geometry (bool use)
 set if mesh based geometry is used
void set_obb_tree_box_dimension ()
 construct obb tree with faceted geometry and set the box max/min coordinates
Static Public Member Functions
static const char * name ()
 Get class name.
static bool can_mesh (iBase_EntityType dim)
 Function returning whether this scheme can mesh entities of t the specified dimension.
static bool can_mesh (ModelEnt *me)
 Function returning whether this scheme can mesh the specified entity.
static const moab::EntityType * output_types ()
 Get list of mesh entity types that can be generated.
Private Member Functions
 EBMesher (const EBMesher &)
 No copy constructor, since there's only meant to be one of these.
MeshOpget_scd_mesher ()
EBMesheroperator= (const EBMesher &)
 No operator=, since there's only meant to be one of these.
EdgeStatus get_edge_status (const double dZ, int &iSkip)
 get hex edge status (inside/outside/boundary)
bool set_neighbor_hex_status (int dir, int i, int j, int k)
 set hex status for neighboring elements
bool set_hex_status (int index, EdgeStatus value, int dir)
bool set_edge_status (int dir)
 set edge status
void set_tag_info ()
 set all produced mesh information as tag \ hex status, edge-cut information.....
void write_mesh (const char *file_name, int type, iBase_EntityHandle *handles, int &n_elem)
 wirte mesh
double get_edge_fraction (int idHex, int dir)
 get edge fraction information
double get_uncut_edge_fraction (int i, int j, int k, int dir)
 get if the edge is fully inside(returns 1) or outside(returns 0)
bool is_shared_overlapped_surf (int index)
 check if the intersected surface geometry is shared or overlapped
bool move_intersections (int n_dir, int n_inter, double start_pnt[3])
 move intersection pairs to check element status
bool get_inside_hex (std::vector< int > &rvnInsideCell)
 get inside status elements
bool is_ray_move_and_set_overlap_surf (bool &bMoveOnce)
 check if ray is passing shared vertices or edges \ And, check if the passing surface is overlapped one
void remove_intersection_duplicates ()
bool export_fraction_edges (std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &rmdCutCellSurfEdge)
bool export_fraction_points (std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &mdCutCellEdge)
bool make_edge (double ePnt[6], std::vector< iBase_EntityHandle > &edge_handles)
moab::Interface * moab_instance ()
 get MOAB instance
iBase_TagHandle get_tag (const char *name, int size, unsigned flags, moab::DataType type, const void *def_value=NULL, bool create_if_missing=true)
 get MOAB's Tag
iBase_TagHandle get_various_length_tag (const char *name, unsigned store, moab::DataType type)
 get MOAB's various length Tag
int make_scd_hexes ()
 construct hexes in MOAB structured mesh format
int make_uscd_hexes ()
 construct hexes in MOAB unstructured mesh format
int construct_obb_tree ()
 construct OBB tree geometry is faceted which are constructed to OBB tree
void set_tree_root (ModelEnt *me)
 construct and set OBB tree Model entity pointer for tree construction
void set_division ()
 set # of divisions the best ones from the size of faceted triangles
void find_intersections ()
 find intersections by firing rays
void fire_rays (int dir)
 fires rays to 3 directions
bool fire_ray (int &nIntersect, double startPnt[3], double endPnt[3], double tol, int dir, double rayLength)
 fires ray
bool move_ray (int &nIntersect, double *startPnt, double *endPnt, double tol, int dir, bool bMoveOnce)
 moves ray which passes any singluar point
bool is_same_direct_to_ray (int i, int dir)
 if the facet has the same direction to the ray
Private Attributes
iBase_TagHandle m_elemStatusTag
iBase_TagHandle m_edgeCutFracLengthTag
iBase_TagHandle m_edgeCutFracTag
iBase_TagHandle m_volFracLengthTag
iBase_TagHandle m_volFracHandleTag
iBase_TagHandle m_volFracTag
iBase_TagHandle m_bbTag
iMesh_Instance m_mesh
iBase_EntitySetHandle m_hRootSet
std::vector< IntersectDistm_vIntersection
int m_nTri
int m_nHex
int m_iInter
int m_nFraction
int m_iStartHex
int m_nMove
int m_nAddLayer
int m_nIteration
int m_iOverlap
int m_iElem
int m_nNode [3]
int m_nDiv [3]
int m_iFirstP
int m_iSecondP
double m_dFirstP
double m_dSecondP
double m_curPnt
double m_prevPnt
double m_boxIncrease
double m_dIntervalSize [3]
double m_origin_coords [3]
double m_dInputSize
double m_min [3]
double m_max [3]
EdgeStatus m_nStatus
bool m_bMovedOnce
bool m_bUseGeom
bool m_bUseWholeGeom
bool m_bUseMeshGeom
std::vector< iBase_EntityHandle > m_vhVertex
std::vector< int > m_vnHexStatus
std::map< int, CutFractionm_mdCutFraction
std::vector< EdgeStatusm_vnEdgeStatus [3]
moab::GeomTopoTool * m_GeomTopoTool
moab::EntityHandle m_hTreeRoot
moab::OrientedBoxTreeTool * m_hObbTree
std::vector< moab::EntityHandle > m_vhInterSurf
std::vector< moab::EntityHandle > m_vhInterFacet
std::map< moab::EntityHandle, int > m_mhOverlappedSurf
m_mRootSets
double m_minCoord [3]
double m_maxCoord [3]
Static Private Attributes
static int init
 Static variable, used in registration.
Detailed Description
Examples:
example_ebmesh.cpp.
Definition at line 119 of file EBMesher.hpp.
EBMesher ( MKCore mkcore,
const MEntVector me_vec,
double  size = -1.,
bool  use_geom = true,
int  add_layer = 3
Bare constructor.
Definition at line 46 of file EBMesher.cpp.
~EBMesher ( ) [virtual]
Destructor.
Definition at line 95 of file EBMesher.cpp.
EBMesher ( const EBMesher ) [private]
Member Function Documentation
bool add_modelent ( ModelEnt model_ent) [virtual]
Parameters:
model_entModelEnt being added
Returns:
Returns true if model_ent was actually added, false otherwise
Reimplemented from MeshOp.
Definition at line 106 of file EBMesher.cpp.
static bool can_mesh ( iBase_EntityType  dim) [inline, static]
Parameters:
dimentity dimension
Definition at line 139 of file EBMesher.hpp.
bool can_mesh ( ModelEnt me) [static]
Used by MeshOpFactory to find scheme for an entity.
Parameters:
meModelEnt being queried
Returns:
If true, this scheme can mesh the specified ModelEnt
Definition at line 100 of file EBMesher.cpp.
int construct_obb_tree ( ) [private]
Returns:
int if is working correctly
void execute_this ( ) [virtual]
\ The only setup/execute function we need, since meshing vertices is trivial
Implements GraphNode.
Definition at line 187 of file EBMesher.cpp.
bool export_fraction_edges ( std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &  rmdCutCellSurfEdge) [private]
Definition at line 1350 of file EBMesher.cpp.
bool export_fraction_points ( std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &  mdCutCellEdge) [private]
Definition at line 1496 of file EBMesher.cpp.
void export_mesh ( const char *  file_name,
bool  separate = false
export mesh to file
Parameters:
file_nameexport file name
separateexport file separately(inside/outside/boundary)
Examples:
example_ebmesh.cpp.
Definition at line 315 of file EBMesher.cpp.
void find_intersections ( ) [private]
Definition at line 299 of file EBMesher.cpp.
bool fire_ray ( int &  nIntersect,
double  startPnt[3],
double  endPnt[3],
double  tol,
int  dir,
double  rayLength
) [private]
fires ray
Parameters:
nIntersect# of intersections returned
startPntray starting point
endPntray ending point
toltolerance to find intersection
dirray direction
rayLengthray length
Returns:
bool if is working correctly
Definition at line 991 of file EBMesher.cpp.
void fire_rays ( int  dir) [private]
Parameters:
dirgive the ray direction calls fire_ray
Definition at line 852 of file EBMesher.cpp.
double get_edge_fraction ( int  idHex,
int  dir
) [private]
Parameters:
idHexindex in m_mdCutFraction
dirray direction
Returns:
double edge fraction
Definition at line 1567 of file EBMesher.cpp.
EdgeStatus get_edge_status ( const double  dZ,
int &  iSkip
) [private]
Parameters:
dZedge end coordinate
iSkiphow many index skipped for next intersection checking
Returns:
EdgeStatus edge status
Definition at line 457 of file EBMesher.cpp.
bool get_grid_and_edges ( double *  boxMin,
double *  boxMax,
int *  nDiv,
std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &  rmdCutCellEdge,
std::vector< int > &  rvnInsideCell,
bool  isCornerExterior = true
Parameters:
boxMinCartesian box min coordinates returned
boxMaxCartesian box max coordinates returned
nDivnDiv(x/yz directions) returned
rmdCutCellEdgemap of cut-cell surface index and edge cut information returned
rvnInsideCellInside elements returned
isCornerExteriorif box corner is exterior returned
Returns:
if this function is working correctly
Examples:
example_ebmesh.cpp.
Definition at line 1260 of file EBMesher.cpp.
void get_grid_and_edges_techX ( double *  boxMin,
double *  boxMax,
int *  nDiv,
std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &  rmdCutCellSurfEdge,
Parameters:
rmdCutCellSurfEdgemap of cut-cell surface index and edge cut information returned
Examples:
example_ebmesh.cpp.
Definition at line 1106 of file EBMesher.cpp.
bool get_inside_hex ( std::vector< int > &  rvnInsideCell) [private]
Parameters:
rvnInsideCellcell indices (i,j,k triple)
Returns:
Definition at line 1296 of file EBMesher.cpp.
MeshOp * get_scd_mesher ( ) [private]
Definition at line 115 of file EBMesher.cpp.
iBase_TagHandle get_tag ( const char *  name,
int  size,
unsigned  flags,
const void *  def_value = NULL,
bool  create_if_missing = true
) [private]
get MOAB's Tag
Parameters:
nameTag name
sizeTag size
storeTag type
typedata type stored
def_valuedefault value
create_if_missingcreate Tag if it is missed (flag)
Returns:
Tag handle
Definition at line 750 of file EBMesher.cpp.
double get_uncut_edge_fraction ( int  i,
int  j,
int  k,
int  dir
) [private]
Parameters:
iindex for i direction
jindex for j direction
kindex for k direction
dirray direction
Returns:
Definition at line 1579 of file EBMesher.cpp.
iBase_TagHandle get_various_length_tag ( const char *  name,
unsigned  store,
moab::DataType  type
) [private]
Parameters:
nameTag name
storeTag type
Returns:
Tag handle
Definition at line 771 of file EBMesher.cpp.
bool get_volume_fraction ( int  vol_frac_div)
Parameters:
vol_frac_divresolution to get volume fraction
Returns:
Examples:
example_ebmesh.cpp.
Definition at line 1755 of file EBMesher.cpp.
void increase_box ( double  box_increase) [inline]
Parameters:
box_increasenumber of interval array for x/y/z directions
Examples:
example_ebmesh.cpp.
Definition at line 489 of file EBMesher.hpp.
bool is_ray_move_and_set_overlap_surf ( bool &  bMoveOnce) [private]
Parameters:
bMoveOnceif ray is already moved before
Returns:
Definition at line 1678 of file EBMesher.cpp.
bool is_same_direct_to_ray ( int  i,
int  dir
) [private]
Parameters:
iindex in m_vIntersection (intersection vector)
dirray direction
Returns:
Definition at line 2086 of file EBMesher.cpp.
bool is_shared_overlapped_surf ( int  index) [private]
Parameters:
indexintersection index in m_vIntersection vector
Returns:
Definition at line 1088 of file EBMesher.cpp.
bool make_edge ( double  ePnt[6],
std::vector< iBase_EntityHandle > &  edge_handles
) [private]
Definition at line 1548 of file EBMesher.cpp.
int make_scd_hexes ( ) [private]
Returns:
Definition at line 700 of file EBMesher.cpp.
int make_uscd_hexes ( ) [private]
Returns:
virtual const moab::EntityType* mesh_types_arr ( ) const [inline, virtual]
Returns:
array terminated with moab::MBMAXTYPE
Implements MeshOp.
Definition at line 158 of file EBMesher.hpp.
moab::Interface* moab_instance ( ) [inline, private]
get MOAB instance
Returns:
MOAB instance
Definition at line 375 of file EBMesher.hpp.
bool move_intersections ( int  n_dir,
int  n_inter,
double  start_pnt[3]
) [private]
Parameters:
n_dirray direction
n_interindex of intersection points
start_pntray starting point
Returns:
Definition at line 1052 of file EBMesher.cpp.
bool move_ray ( int &  nIntersect,
double *  startPnt,
double *  endPnt,
double  tol,
int  dir,
bool  bMoveOnce
) [private]
Parameters:
dirray direction
Returns:
Definition at line 1603 of file EBMesher.cpp.
static const char* name ( ) [inline, static]
Get class name.
Definition at line 132 of file EBMesher.hpp.
EBMesher& operator= ( const EBMesher ) [private]
const moab::EntityType * output_types ( ) [static]
Returns:
Definition at line 43 of file EBMesher.cpp.
void remove_intersection_duplicates ( ) [private]
Definition at line 1725 of file EBMesher.cpp.
int set_division ( double *  min,
double *  max
Parameters:
minCartesian box min coordinates
maxCartesian box max coordinates
Returns:
Definition at line 680 of file EBMesher.cpp.
void set_division ( ) [private]
Definition at line 616 of file EBMesher.cpp.
bool set_edge_status ( int  dir) [private]
set edge status
Parameters:
dirray direction
Returns:
Definition at line 589 of file EBMesher.cpp.
bool set_hex_status ( int  index,
EdgeStatus  value,
int  dir
) [private]
\ brief set hex status by edge status
Parameters:
indexhex index in m_vnHexStatus vector
valueedge status
dirray direction
Returns:
Definition at line 568 of file EBMesher.cpp.
bool set_neighbor_hex_status ( int  dir,
int  i,
int  j,
int  k
) [private]
Parameters:
dircurrent fired ray direction
Returns:
Definition at line 530 of file EBMesher.cpp.
void set_num_interval ( int *  n_interval)
Parameters:
n_intervalnumber of interval array for x/y/z directions
Examples:
example_ebmesh.cpp.
Definition at line 258 of file EBMesher.cpp.
Examples:
example_ebmesh.cpp.
Definition at line 2109 of file EBMesher.cpp.
void set_tag_info ( ) [private]
Definition at line 785 of file EBMesher.cpp.
void set_tree_root ( ModelEnt me) [private]
Definition at line 265 of file EBMesher.cpp.
void setup_this ( ) [virtual]
Definition at line 123 of file EBMesher.cpp.
void use_mesh_geometry ( bool  use) [inline]
Parameters:
useif mesh based geometry is used
Examples:
example_ebmesh.cpp.
Definition at line 499 of file EBMesher.hpp.
void use_whole_geom ( int  use) [inline]
Parameters:
useif mesh for whole geometry at once
Examples:
example_ebmesh.cpp.
Definition at line 494 of file EBMesher.hpp.
void write_mesh ( const char *  file_name,
int  type,
iBase_EntityHandle *  handles,
int &  n_elem
) [private]
wirte mesh
Parameters:
file_name
typeelement type (inside:0, outside:1, boundary:2)
handleselement handles
n_elem# of elements
Returns:
Definition at line 416 of file EBMesher.cpp.
Member Data Documentation
int init [static, private]
Definition at line 370 of file EBMesher.hpp.
iBase_TagHandle m_bbTag [private]
Definition at line 252 of file EBMesher.hpp.
bool m_bMovedOnce [private]
Definition at line 264 of file EBMesher.hpp.
double m_boxIncrease [private]
Definition at line 260 of file EBMesher.hpp.
bool m_bUseGeom [private]
bool m_bUseMeshGeom [private]
bool m_bUseWholeGeom [private]
double m_curPnt [private]
double m_dFirstP [private]
double m_dInputSize [private]
double m_dIntervalSize[3] [private]
double m_dSecondP [private]
iBase_TagHandle m_edgeCutFracLengthTag [private]
iBase_TagHandle m_edgeCutFracTag [private]
iBase_TagHandle m_elemStatusTag [private]
moab::GeomTopoTool* m_GeomTopoTool [private]
Definition at line 467 of file EBMesher.hpp.
moab::OrientedBoxTreeTool* m_hObbTree [private]
Definition at line 473 of file EBMesher.hpp.
iBase_EntitySetHandle m_hRootSet [private]
Definition at line 255 of file EBMesher.hpp.
moab::EntityHandle m_hTreeRoot [private]
Definition at line 470 of file EBMesher.hpp.
int m_iElem [private]
Definition at line 257 of file EBMesher.hpp.
int m_iFirstP [private]
int m_iInter [private]
int m_iOverlap [private]
int m_iSecondP [private]
int m_iStartHex [private]
double m_max[3] [private]
double m_maxCoord[3] [private]
Definition at line 486 of file EBMesher.hpp.
std::map<int, CutFraction> m_mdCutFraction [private]
Definition at line 267 of file EBMesher.hpp.
iMesh_Instance m_mesh [private]
Definition at line 254 of file EBMesher.hpp.
std::map<moab::EntityHandle, int> m_mhOverlappedSurf [private]
Definition at line 482 of file EBMesher.hpp.
double m_min[3] [private]
double m_minCoord[3] [private]
std::map<moab::EntityHandle, moab::EntityHandle> m_mRootSets [private]
Definition at line 484 of file EBMesher.hpp.
int m_nAddLayer [private]
int m_nDiv[3] [private]
int m_nFraction [private]
int m_nHex [private]
int m_nIteration [private]
int m_nMove [private]
int m_nNode[3] [private]
EdgeStatus m_nStatus [private]
Definition at line 263 of file EBMesher.hpp.
int m_nTri [private]
double m_origin_coords[3] [private]
double m_prevPnt [private]
std::vector<moab::EntityHandle> m_vhInterFacet [private]
Definition at line 479 of file EBMesher.hpp.
std::vector<moab::EntityHandle> m_vhInterSurf [private]
Definition at line 476 of file EBMesher.hpp.
std::vector<iBase_EntityHandle> m_vhVertex [private]
Definition at line 265 of file EBMesher.hpp.
std::vector<IntersectDist> m_vIntersection [private]
Definition at line 256 of file EBMesher.hpp.
std::vector<EdgeStatus> m_vnEdgeStatus[3] [private]
Definition at line 268 of file EBMesher.hpp.
std::vector<int> m_vnHexStatus [private]
Definition at line 266 of file EBMesher.hpp.
iBase_TagHandle m_volFracHandleTag [private]
iBase_TagHandle m_volFracLengthTag [private]
iBase_TagHandle m_volFracTag [private]
