MetisPartitioner.hpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 // Contributed by Lorenzo Alessio Botti (SpaFEDTe)
00017 // This implementation is mostly borrowed from the mbzoltan MOAB partitioning tool
00018
00019 #ifndef __metispartitioner_hpp__
00020 #define __metispartitioner_hpp__
00021
00022 #include <cstdlib>
00023 #include "moab/PartitionerBase.hpp"
00024 #include "metis.h"
00025
00026 namespace moab
00027 {
00028
00029 class Interface;
00030 class Range;
00031 }  // namespace moab
00032
00033 using namespace moab;
00034
00035 class MetisPartitioner : public PartitionerBase< idx_t >
00036 {
00037
00038   public:
00039     MetisPartitioner( Interface* impl = NULL, const bool use_coords = false );
00040
00041     virtual ~MetisPartitioner();
00042
00043     virtual ErrorCode partition_mesh_and_geometry( const double part_geom_mesh_size,
00044                                                    const idx_t nparts,
00045                                                    const char* zmethod,
00046                                                    const char* other_method,
00047                                                    double imbal_tol,
00048                                                    const int part_dim           = 3,
00049                                                    const bool write_as_sets     = true,
00050                                                    const bool write_as_tags     = false,
00051                                                    const int obj_weight         = 0,
00052                                                    const int edge_weight        = 0,
00053                                                    const bool part_surf         = false,
00054                                                    const bool ghost             = false,
00055                                                    const int projection_type    = 0,
00056                                                    const bool recompute_rcb_box = false,
00057                                                    const bool print_time        = false );
00058
00059     virtual ErrorCode partition_mesh( const idx_t nparts,
00060                                       const char* method,
00061                                       const int part_dim               = 3,
00062                                       const bool write_as_sets         = true,
00063                                       const bool write_as_tags         = false,
00064                                       const bool partition_tagged_sets = false,
00065                                       const bool partition_tagged_ents = false,
00066                                       const char* aggregating_tag      = NULL,
00067                                       const bool print_time            = false );
00068
00069     virtual ErrorCode write_partition( const idx_t nparts,
00070                                        Range& elems,
00071                                        const idx_t* assignment,
00072                                        const bool write_as_sets,
00073                                        const bool write_as_tags );
00074
00075     ErrorCode write_aggregationtag_partition( const idx_t nparts,
00076                                               Range& elems,
00077                                               const idx_t* assignment,
00078                                               const bool write_as_sets,
00079                                               const bool write_as_tags );
00080
00081     // put closure of entities in the part sets too
00082     virtual ErrorCode include_closure();
00083
00084     // virtual ErrorCode write_file(const char *filename, const char *out_file);
00085
00086   private:
00087     ErrorCode assemble_graph( const int dimension,
00088                               std::vector< double >& coords,
00089                               std::vector< idx_t >& moab_ids,
00090                               std::vector< idx_t >& adjacencies,
00091                               std::vector< idx_t >& length,
00092                               Range& elems );
00093
00094     ErrorCode assemble_taggedsets_graph( const int dimension,
00095                                          std::vector< double >& coords,
00096                                          std::vector< idx_t >& moab_ids,
00097                                          std::vector< idx_t >& adjacencies,
00098                                          std::vector< idx_t >& length,
00099                                          Range& elems,
00100                                          const char* aggregating_tag );
00101
00102     ErrorCode assemble_taggedents_graph( const int dimension,
00103                                          std::vector< double >& coords,
00104                                          std::vector< idx_t >& moab_ids,
00105                                          std::vector< idx_t >& adjacencies,
00106                                          std::vector< idx_t >& length,
00107                                          Range& elems,
00108                                          const char* aggregating_tag );
00109 };
00110
00111 // Inline functions
00112
00113 inline ErrorCode MetisPartitioner::partition_mesh_and_geometry( const double,
00114        const idx_t nparts,
00115        const char* zmethod,
00116        const char*,
00117        double,
00118        const int part_dim,
00119        const bool write_as_sets,
00120        const bool write_as_tags,
00121        const int,
00122        const int,
00123        const bool,
00124        const bool,
00125        const int,
00126        const bool,
00127        const bool print_time )
00128 {
00129     // Only partition the mesh - no geometric partition available
00130     return partition_mesh( nparts, zmethod, part_dim, write_as_sets, write_as_tags, false, false, NULL, print_time );
00131 }
00132
00133 inline ErrorCode MetisPartitioner::include_closure()
00134 {
00135     return MB_NOT_IMPLEMENTED;
00136 }
00137
00138 #endif
