Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include "ScdElementData.hpp" 00017 #include "ScdVertexData.hpp" 00018 #include "moab/Interface.hpp" 00019 #include "moab/ReadUtilIface.hpp" 00020 #include "moab/CN.hpp" 00021 #include "Internals.hpp" 00022 #include <cassert> 00023 00024 namespace moab 00025 { 00026 00027 EntityID ScdElementData::calc_num_entities( EntityHandle start_handle, 00028 int irange, 00029 int jrange, 00030 int krange, 00031 int* is_periodic ) 00032 { 00033 size_t result = 1; 00034 auto dim = CN::Dimension( TYPE_FROM_HANDLE( start_handle ) ); 00035 switch( dim ) 00036 { 00037 case 3: 00038 result *= krange; 00039 // fall through 00040 case 2: 00041 result *= ( is_periodic && is_periodic[1] ? ( jrange + 1 ) : jrange ); 00042 // fall through 00043 case 1: 00044 result *= ( is_periodic && is_periodic[0] ? ( irange + 1 ) : irange ); 00045 break; 00046 default: 00047 result = 0; 00048 assert( false ); 00049 break; 00050 } 00051 return result; 00052 } 00053 00054 ScdElementData::ScdElementData( EntityHandle shandle, 00055 const int imin, 00056 const int jmin, 00057 const int kmin, 00058 const int imax, 00059 const int jmax, 00060 const int kmax, 00061 int* is_p ) 00062 : SequenceData( 0, 00063 shandle, 00064 shandle + calc_num_entities( shandle, imax - imin, jmax - jmin, kmax - kmin, is_p ) - 1 ) 00065 { 00066 // need to have meaningful parameters 00067 assert( imax >= imin && jmax >= jmin && kmax >= kmin ); 00068 00069 isPeriodic[0] = ( is_p ? is_p[0] : 0 ); 00070 isPeriodic[1] = ( is_p ? is_p[1] : 0 ); 00071 00072 boxParams[0] = HomCoord( imin, jmin, kmin ); 00073 boxParams[1] = HomCoord( imax, jmax, kmax ); 00074 boxParams[2] = HomCoord( 1, 1, 1 ); 00075 00076 // assign and compute parameter stuff 00077 dIJK[0] = boxParams[1][0] - boxParams[0][0] + 1; 00078 dIJK[1] = boxParams[1][1] - boxParams[0][1] + 1; 00079 dIJK[2] = boxParams[1][2] - boxParams[0][2] + 1; 00080 dIJKm1[0] = dIJK[0] - ( isPeriodic[0] ? 0 : 1 ); 00081 dIJKm1[1] = dIJK[1] - ( isPeriodic[1] ? 0 : 1 ); 00082 dIJKm1[2] = dIJK[2] - 1; 00083 } 00084 00085 ScdElementData::~ScdElementData() {} 00086 00087 bool ScdElementData::boundary_complete() const 00088 { 00089 // test the bounding vertex sequences to see if they fully define the 00090 // vertex parameter space for this rectangular block of elements 00091 00092 int p; 00093 std::vector< VertexDataRef > minlist, maxlist; 00094 00095 // pseudo code: 00096 // for each vertex sequence v: 00097 for( std::vector< VertexDataRef >::const_iterator vseq = vertexSeqRefs.begin(); vseq != vertexSeqRefs.end(); 00098 ++vseq ) 00099 { 00100 // test min corner mincorner: 00101 bool mincorner = true; 00102 // for each p = (i-1,j,k), (i,j-1,k), (i,j,k-1): 00103 for( p = 0; p < 3; p++ ) 00104 { 00105 00106 // for each vsequence v' != v: 00107 for( std::vector< VertexDataRef >::const_iterator othervseq = vertexSeqRefs.begin(); 00108 othervseq != vertexSeqRefs.end(); ++othervseq ) 00109 { 00110 if( othervseq == vseq ) continue; 00111 // if v.min-p contained in v' 00112 if( ( *othervseq ).contains( ( *vseq ).minmax[0] - HomCoord::unitv[p] ) ) 00113 { 00114 // mincorner = false 00115 mincorner = false; 00116 break; 00117 } 00118 } 00119 if( !mincorner ) break; 00120 } 00121 00122 bool maxcorner = true; 00123 // for each p = (i-1,j,k), (i,j-1,k), (i,j,k-1): 00124 for( p = 0; p < 3; p++ ) 00125 { 00126 00127 // for each vsequence v' != v: 00128 for( std::vector< VertexDataRef >::const_iterator othervseq = vertexSeqRefs.begin(); 00129 othervseq != vertexSeqRefs.end(); ++othervseq ) 00130 { 00131 if( othervseq == vseq ) continue; 00132 // if v.max+p contained in v' 00133 if( ( *othervseq ).contains( ( *vseq ).minmax[1] + HomCoord::unitv[p] ) ) 00134 { 00135 // maxcorner = false 00136 maxcorner = false; 00137 break; 00138 } 00139 } 00140 if( !maxcorner ) break; 00141 } 00142 00143 // if mincorner add to min corner list minlist 00144 if( mincorner ) minlist.push_back( *vseq ); 00145 // if maxcorner add to max corner list maxlist 00146 if( maxcorner ) maxlist.push_back( *vseq ); 00147 } 00148 00149 // 00150 // if minlist.size = 1 & maxlist.size = 1 & minlist[0] = esequence.min & 00151 // maxlist[0] = esequence.max+(1,1,1) 00152 if( minlist.size() == 1 && maxlist.size() == 1 && minlist[0].minmax[0] == boxParams[0] && 00153 maxlist[0].minmax[1] == boxParams[1] ) 00154 // complete 00155 return true; 00156 // else 00157 00158 return false; 00159 } 00160 00161 SequenceData* ScdElementData::subset( EntityHandle /*start*/, 00162 EntityHandle /*end*/, 00163 const int* /*sequence_data_sizes*/, 00164 const int* /*tag_data_sizes*/ ) const 00165 { 00166 return 0; 00167 } 00168 00169 unsigned long ScdElementData::get_memory_use() const 00170 { 00171 return sizeof( *this ) + vertexSeqRefs.capacity() * sizeof( VertexDataRef ); 00172 } 00173 00174 } // namespace moab
