ZoltanPartitioner Member List
This is the complete list of members for ZoltanPartitioner, including all inherited members.
argcArgZoltanPartitioner [private]
argvArgZoltanPartitioner [private]
assemble_graph(const int dimension, std::vector< double > &coords, std::vector< int > &moab_ids, std::vector< int > &adjacencies, std::vector< int > &length, Range &elems, bool part_geom=false, const int projection_type=0)ZoltanPartitioner [private]
assign_global_idsPartitionerBase< int > [protected]
balance_mesh(const char *zmethod, const char *other_method, const bool write_as_sets=true, const bool write_as_tags=false)ZoltanPartitioner
get_global_id_option()PartitionerBase< int > [inline]
include_closure()ZoltanPartitioner [virtual]
mbFinalizePoints(int npts, int numExport, ZOLTAN_ID_PTR exportLocalIDs, int *exportProcs, int **assignment)ZoltanPartitioner [private]
mbGlobalSuccess(int rc)ZoltanPartitioner [private]
mbImplPartitionerBase< int > [protected]
mbInitializePoints(int npts, double *pts, int *ids, int *adjs, int *length, double *obj_weights=NULL, double *edge_weights=NULL, int *parts=NULL, bool part_geom=false)ZoltanPartitioner [private]
mbPrintGlobalResult(const char *s, int begin, int import, int exp, int change)ZoltanPartitioner [private]
mbShowError(int val, const char *s)ZoltanPartitioner [private]
myNumPtsZoltanPartitioner [private]
myZZZoltanPartitioner [private]
newCommPartitionerBase< int > [protected]
part_sets()PartitionerBase< int > [inline]
part_sets() constPartitionerBase< int > [inline]
partition_inferred_mesh(EntityHandle sfileset, size_t num_parts, int part_dim=3, const bool write_as_sets=true, int projection_type=0)ZoltanPartitioner
partition_mesh(const int nparts, const char *method, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const bool partition_tagged_sets=false, const bool partition_tagged_ents=false, const char *aggregating_tag=NULL, const bool print_time=false)ZoltanPartitioner [inline, virtual]
partition_mesh_and_geometry(const double part_geom_mesh_size, const int nparts, const char *zmethod, const char *other_method, double imbal_tol, const int part_dim=3, const bool write_as_sets=true, const bool write_as_tags=false, const int obj_weight=0, const int edge_weight=0, const bool part_surf=false, const bool ghost=false, const int projection_type=0, const bool recompute_rcb_box=false, const bool print_time=false)ZoltanPartitioner [virtual]
partition_owned_cells(Range &owned, std::multimap< int, int > &extraGraphEdges, std::map< int, int > procs, int &numNewPartitions, std::map< int, Range > &distribution, int met, std::vector< char > &ZoltanBuffer)ZoltanPartitioner
PartitionerBase(Interface *impl=NULL, const bool use_coords=false)PartitionerBase< int >
partSetsZoltanPartitioner [private]
repartition(std::vector< double > &x, std::vector< double > &y, std::vector< double > &z, int StartID, const char *zmethod, Range &localGIDs)ZoltanPartitioner
set_global_id_option(bool id_opt)PartitionerBase< int > [inline]
SetHSFC_Parameters()ZoltanPartitioner
SetHypergraph_Parameters(const char *phg_method)ZoltanPartitioner
SetOCTPART_Parameters(const char *oct_method)ZoltanPartitioner
SetPARMETIS_Parameters(const char *parmetis_method)ZoltanPartitioner
SetRCB_Parameters(const bool recompute_rcb_box=false)ZoltanPartitioner
SetRIB_Parameters()ZoltanPartitioner
useCoordsPartitionerBase< int > [protected]
write_partition(const int nparts, Range &elems, const int *assignment, const bool write_as_sets, const bool write_as_tags)ZoltanPartitioner [virtual]
PartitionerBase< int >::write_partition(const intnparts, Range &elems, const int *assignment, const bool write_as_sets, const bool write_as_tags)=0PartitionerBase< int > [pure virtual]
ZoltanPartitioner(Interface *impl=NULL, const bool use_coords=false, int argc=0, char **argv=NULL)ZoltanPartitioner
~PartitionerBase()PartitionerBase< int > [virtual]
~ZoltanPartitioner()ZoltanPartitioner [virtual]
