moab::CN Member List
This is the complete list of members for moab::CN, including all inherited members.
AdjacentSubEntities(const EntityType this_type, const int *source_indices, const int num_source_indices, const int source_dim, const int target_dim, std::vector< int > &index_list, const int operation_type=CN::INTERSECT)moab::CN [static]
CN()moab::CN [private]
ConnectivityMatch(const int *conn1, const int *conn2, const int num_vertices, int &direct, int &offset)moab::CN [static]
ConnectivityMatch(const unsigned int *conn1, const unsigned int *conn2, const int num_vertices, int &direct, int &offset)moab::CN [static]
ConnectivityMatch(const long *conn1, const long *conn2, const int num_vertices, int &direct, int &offset)moab::CN [static]
ConnectivityMatch(const unsigned long *conn1, const unsigned long *conn2, const int num_vertices, int &direct, int &offset)moab::CN [static]
ConnectivityMatch(const unsigned long long *conn1, const unsigned long long *conn2, const int num_vertices, int &direct, int &offset)moab::CN [static]
ConnectivityMatch(void *const *conn1, void *const *conn2, const int num_vertices, int &direct, int &offset)moab::CN [static]
Dimension(const EntityType t)moab::CN [static]
EntityTypeFromName(const char *name)moab::CN [static]
EntityTypeName(const EntityType this_type)moab::CN [static]
entityTypeNamesmoab::CN [private, static]
GetBasis()moab::CN [inline, static]
getDimPair(int entity_type)moab::CN [static]
HasMidEdgeNodes(const EntityType this_type, const int num_verts)moab::CN [inline, static]
HasMidFaceNodes(const EntityType this_type, const int num_verts)moab::CN [inline, static]
HasMidNodes(const EntityType this_type, const int num_verts, int mid_nodes[4])moab::CN [inline, static]
HasMidNodes(const EntityType this_type, const int num_verts)moab::CN [inline, static]
HasMidRegionNodes(const EntityType this_type, const int num_verts)moab::CN [inline, static]
HONodeIndex(const EntityType this_type, const int num_verts, const int subfacet_dim, const int subfacet_index)moab::CN [static]
HONodeParent(EntityType elem_type, int num_nodes, int ho_node_index, int &parent_dim, int &parent_index)moab::CN [static]
increasingIntsmoab::CN [private, static]
INTERSECT enum valuemoab::CN
MAX_NODES_PER_ELEMENT enum valuemoab::CN
mConnectivityMapmoab::CN [static]
MID_EDGE_BIT enum valuemoab::CN
MID_FACE_BIT enum valuemoab::CN
MID_REGION_BIT enum valuemoab::CN
midNodesPerTypemoab::CN [static]
mUpConnMapmoab::CN [static]
numberBasismoab::CN [private, static]
NumSubEntities(const EntityType t, const int d)moab::CN [static]
OppositeSide(const EntityType parent_type, const int child_index, const int child_dim, int &opposite_index, int &opposite_dim)moab::CN [static]
permuteThis(const EntityType t, const int dim, int *pvec, const int indices_per_ent, const int num_entries)moab::CN [inline, static]
permuteThis(const EntityType t, const int dim, unsigned int *pvec, const int indices_per_ent, const int num_entries)moab::CN [inline, static]
permuteThis(const EntityType t, const int dim, long *pvec, const int indices_per_ent, const int num_entries)moab::CN [inline, static]
permuteThis(const EntityType t, const int dim, void **pvec, const int indices_per_ent, const int num_entries)moab::CN [inline, static]
permuteVecmoab::CN [static]
resetPermutation(const EntityType t, const int dim)moab::CN [inline, static]
revPermuteThis(const EntityType t, const int dim, int *pvec, const int indices_per_ent, const int num_entries)moab::CN [inline, static]
revPermuteThis(const EntityType t, const int dim, unsigned int *pvec, const int indices_per_ent, const int num_entries)moab::CN [inline, static]
revPermuteThis(const EntityType t, const int dim, long *pvec, const int indices_per_ent, const int num_entries)moab::CN [inline, static]
revPermuteThis(const EntityType t, const int dim, void **pvec, const int indices_per_ent, const int num_entries)moab::CN [inline, static]
revPermuteVecmoab::CN [static]
SetBasis(const int in_basis)moab::CN [static]
setPermutation(const EntityType t, const int dim, short int *pvec, const int num_entries, const bool is_reverse=false)moab::CN [inline, static]
SideNumber(const EntityType parent_type, const int *parent_conn, const int *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)moab::CN [static]
SideNumber(const EntityType parent_type, const unsigned int *parent_conn, const unsigned int *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)moab::CN [static]
SideNumber(const EntityType parent_type, const long *parent_conn, const long *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)moab::CN [static]
SideNumber(const EntityType parent_type, const unsigned long *parent_conn, const unsigned long *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)moab::CN [static]
SideNumber(const EntityType parent_type, const unsigned long long *parent_conn, const unsigned long long *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)moab::CN [static]
SideNumber(const EntityType parent_type, void *const *parent_conn, void *const *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)moab::CN [static]
SideNumber(const EntityType parent_type, const int *child_conn_indices, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)moab::CN [static]
SubEntityConn(const void *parent_conn, const EntityType parent_type, const int sub_dimension, const int sub_index, void *sub_entity_conn, int &num_sub_vertices)moab::CN [static]
SubEntityNodeIndices(const EntityType this_topo, const int num_nodes, const int sub_dimension, const int sub_index, EntityType &sub_entity_topo, int &num_sub_entity_nodes, int sub_entity_conn[])moab::CN [static]
SubEntityType(const EntityType this_type, const int sub_dimension, const int index)moab::CN [static]
SubEntityVertexIndices(const EntityType this_type, const int sub_dimension, const int sub_index, int sub_entity_conn[])moab::CN [inline, static]
SubEntityVertexIndices(const EntityType this_type, const int sub_dimension, const int sub_index, EntityType &sub_type, int &num_sub_ent_vertices)moab::CN [static]
SwitchBasis(const int old_basis, const int new_basis)moab::CN [private, static]
TypeDimensionMapmoab::CN [static]
UNION enum valuemoab::CN
VerticesPerEntity(const EntityType t)moab::CN [static]
