moab::DataCoupler Member List
This is the complete list of members for moab::DataCoupler, including all inherited members.
CONSTANT enum valuemoab::DataCoupler
DataCoupler(Interface *impl, Range &source_ents, int coupler_id, ParallelComm *pc=NULL, bool init_locator=true, int dim=-1)moab::DataCoupler
get_dim() const moab::DataCoupler [inline]
IntegType enum namemoab::DataCoupler
interpolate(int method, Tag tag, double *interp_vals=NULL, std::vector< int > *point_indices=NULL, bool normalize=true)moab::DataCoupler [inline]
interpolate(int method, const std::string &tag_name, double *interp_vals=NULL, std::vector< int > *point_indices=NULL, bool normalize=true)moab::DataCoupler
interpolate(int *methods, const std::string *tag_names, int *points_per_method, int num_methods, double *interp_vals=NULL, std::vector< int > *point_indices=NULL, bool normalize=true)moab::DataCoupler
interpolate(int *methods, Tag *tag_names, int *points_per_method, int num_methods, double *interp_vals=NULL, std::vector< int > *point_indices=NULL, bool normalize=true)moab::DataCoupler
LINEAR_FE enum valuemoab::DataCoupler
locate_points(double *xyz, int num_points, const double rel_iter_tol=1.0e-10, const double abs_iter_tol=1.0e-10, const double inside_tol=1.0e-6)moab::DataCoupler
locate_points(Range &ents, const double rel_iter_tol=1.0e-10, const double abs_iter_tol=1.0e-10, const double inside_tol=1.0e-6)moab::DataCoupler
mbImplmoab::DataCoupler [private]
Method enum namemoab::DataCoupler
my_id() const moab::DataCoupler [inline]
myDimmoab::DataCoupler [private]
myIdmoab::DataCoupler [private]
myLocatormoab::DataCoupler [private]
myPcommmoab::DataCoupler [private]
QUADRATIC_FE enum valuemoab::DataCoupler
spatial_locator()moab::DataCoupler [inline]
SPECTRAL enum valuemoab::DataCoupler
target_ents() const moab::DataCoupler [inline]
target_ents()moab::DataCoupler [inline]
targetEntsmoab::DataCoupler [private]
VOLUME enum valuemoab::DataCoupler
~DataCoupler()moab::DataCoupler [virtual]
