moab::DataCoupler Class Reference
This class couples data between meshes. More...
#include <DataCoupler.hpp>
+ Collaboration diagram for moab::DataCoupler:
Public Types
enum  Method { CONSTANT, LINEAR_FE, QUADRATIC_FE, SPECTRAL }
enum  IntegType { VOLUME }
Public Member Functions
 DataCoupler (Interface *impl, Range &source_ents, int coupler_id, ParallelComm *pc=NULL, bool init_locator=true, int dim=-1)
virtual ~DataCoupler ()
ErrorCode locate_points (double *xyz, int num_points, const double rel_iter_tol=1.0e-10, const double abs_iter_tol=1.0e-10, const double inside_tol=1.0e-6)
ErrorCode locate_points (Range &ents, const double rel_iter_tol=1.0e-10, const double abs_iter_tol=1.0e-10, const double inside_tol=1.0e-6)
ErrorCode interpolate (int method, Tag tag, double *interp_vals=NULL, std::vector< int > *point_indices=NULL, bool normalize=true)
ErrorCode interpolate (int method, const std::string &tag_name, double *interp_vals=NULL, std::vector< int > *point_indices=NULL, bool normalize=true)
ErrorCode interpolate (int *methods, const std::string *tag_names, int *points_per_method, int num_methods, double *interp_vals=NULL, std::vector< int > *point_indices=NULL, bool normalize=true)
ErrorCode interpolate (int *methods, Tag *tag_names, int *points_per_method, int num_methods, double *interp_vals=NULL, std::vector< int > *point_indices=NULL, bool normalize=true)
SpatialLocatorspatial_locator ()
int my_id () const
const Rangetarget_ents () const
Rangetarget_ents ()
int get_dim () const
Private Attributes
InterfacembImpl
ParallelCommmyPcomm
SpatialLocatormyLocator
int myId
Range targetEnts
int myDim
Detailed Description
The coupler interpolates solution data at a set of points. Data being interpolated resides on a "source" mesh, in a tag or in vertex coords. Applications calling this coupler send in entities, and receive back data interpolated at those points. Entities in the source mesh containing those points do not have to reside on the same processor.
To use, an application should:
  • instantiate this DataCoupler by calling the constructor collectively on all processors in the communicator
  • call locate_points, which locates the points to be interpolated and (optionally) caches the results in this class and SpatialLocator
  • call interpolate, which does the interpolation
Multiple interpolations (of multiple tags, or element-average vs. true interpolation) can be done after locating the points.
SpatialLocator is used for the spatial location portion of this work.
This class is a next-generation implementation of Coupler.
Examples:
DeformMeshRemap.cpp.
Definition at line 39 of file DataCoupler.hpp.
Member Enumeration Documentation
Enumerator:
VOLUME
Definition at line 50 of file DataCoupler.hpp.
        VOLUME
Enumerator:
CONSTANT
LINEAR_FE
QUADRATIC_FE
SPECTRAL
Definition at line 42 of file DataCoupler.hpp.
moab::DataCoupler::DataCoupler ( Interface impl,
Range source_ents,
int  coupler_id,
ParallelComm pc = NULL,
bool  init_locator = true,
int  dim = -1
Definition at line 22 of file DataCoupler.cpp.
References moab::Interface::dimension_from_handle(), moab::SpatialLocator::elem_eval(), moab::Range::empty(), ErrorCode, MB_SUCCESS, mbImpl, MBMAXTYPE, myDim, myLocator, myPcomm, moab::Range::pair_begin(), moab::Range::pair_end(), moab::Range::rbegin(), moab::ElemEvaluator::set_eval_set(), and moab::Interface::type_from_handle().
    : mbImpl( impl ), myPcomm( pc ), myId( coupler_id ), myDim( dim )
    assert( NULL != mbImpl && ( myPcomm || !source_ents.empty() ) );
    // Now initialize the tree
    if( init_locator )
        myLocator = new SpatialLocator( mbImpl, source_ents );
        myLocator->elem_eval( new ElemEvaluator( mbImpl ) );
        // Initialize element evaluator with the default for the entity types in source_ents;
        // can be replaced later by application if desired
        if( !source_ents.empty() )
            Range::pair_iterator pit = source_ents.pair_begin();
            EntityType last_type     = MBMAXTYPE;
            for( ; pit != source_ents.pair_end(); ++pit )
                EntityType this_type = mbImpl->type_from_handle( pit->first );
                if( last_type == this_type ) continue;
                ErrorCode rval = myLocator->elem_eval()->set_eval_set( pit->first );
                if( MB_SUCCESS != rval ) throw( rval );
                last_type = this_type;
    if( -1 == dim && !source_ents.empty() ) myDim = mbImpl->dimension_from_handle( *source_ents.rbegin() );
Definition at line 60 of file DataCoupler.cpp.
References moab::SpatialLocator::elem_eval(), and myLocator.
    delete myLocator->elem_eval();
    delete myLocator;
Member Function Documentation
int moab::DataCoupler::get_dim ( ) const [inline]
Definition at line 236 of file DataCoupler.hpp.
References myDim.
        return myDim;
ErrorCode moab::DataCoupler::interpolate ( int  method,
Tag  tag,
double *  interp_vals = NULL,
std::vector< int > *  point_indices = NULL,
bool  normalize = true
) [inline]
Definition at line 266 of file DataCoupler.hpp.
References moab::Range::size(), and targetEnts.
Referenced by DeformMeshRemap::execute(), and interpolate().
    // No point indices input,
    int num_pts = ( point_indices ? point_indices->size() : targetEnts.size() );
    return interpolate( &method, &tag, &num_pts, 1, interp_vals, point_indices, normalize );
const std::string &  tag_name,
Definition at line 95 of file DataCoupler.cpp.
References ErrorCode, interpolate(), MB_CHK_SET_ERR, mbImpl, and moab::Interface::tag_get_handle().
    // Tag name input, translate to tag handle and pass down the chain
    Tag tag;
    ErrorCode result = mbImpl->tag_get_handle( interp_tag.c_str(), tag );MB_CHK_SET_ERR( result, "Failed to get handle for interpolation tag \"" << interp_tag << "\"" );
    return interpolate( method, tag, interp_vals, point_indices, normalize );
ErrorCode moab::DataCoupler::interpolate ( int *  methods,
const std::string *  tag_names,
int *  points_per_method,
int  num_methods,
Tag tag_names,
int  num_methods,
*Method*/ int method = methods[TLob.vi_rd[4*i + 3]];
Definition at line 109 of file DataCoupler.cpp.
References moab::ProcConfig::crystal_router(), moab::SpatialLocator::elem_eval(), moab::TupleList::enableWriteAccess(), ErrorCode, moab::ElemEvaluator::eval(), moab::TupleList::get_n(), moab::TupleList::inc_n(), moab::TupleList::initialize(), moab::SpatialLocator::loc_table(), MB_SUCCESS, mbImpl, myLocator, myPcomm, moab::SpatialLocator::par_loc_table(), moab::ParallelComm::proc_config(), moab::ElemEvaluator::set_ent_handle(), moab::TupleList::set_n(), moab::ElemEvaluator::set_tag_handle(), moab::Range::size(), moab::ParallelComm::size(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_length(), moab::Interface::tag_set_data(), targetEnts, moab::TupleList::vi_rd, moab::TupleList::vi_wr, moab::TupleList::vr_rd, and moab::TupleList::vul_rd.
    // Lowest-level interpolate function, does actual interpolation using calls to ElemEvaluator
    ErrorCode result = MB_SUCCESS;
    unsigned int pts_total = 0;
    for( int i = 0; i < num_methods; i++ )
        pts_total += ( points_per_method ? points_per_method[i] : targetEnts.size() );
    unsigned int num_indices = ( point_indices ? point_indices->size() : targetEnts.size() );
    // # points and indices should be identical
    if( pts_total != num_indices ) return MB_FAILURE;
    // Since each tuple contains one interpolated tag, if we're interpolating multiple tags, every
    // tuple needs to be able to store up to max tag size
    int max_tsize = -1;
        int tmp_tsize;
        result = mbImpl->tag_get_length( tags[i], tmp_tsize );
        if( MB_SUCCESS != result ) return MB_FAILURE;
        max_tsize = std::max( max_tsize, tmp_tsize );
    if( myPcomm && myPcomm->size() > 1 )
        // Build up the tuple list to distribute from my target points; assume that
        // all procs use same method/tag input
        TupleList TLob;  // TLob structure: (pto_i, ridx_i, lidx_i, meth_tagidx_i)
        TLob.initialize( 4, 0, 0, 0, num_indices );
        int tn = 0;  // The tuple number we're currently on
        TLob.enableWriteAccess();
        for( int m = 0; m < num_methods; m++ )
            int num_points = ( points_per_method ? points_per_method[m] : targetEnts.size() );
            for( int j = 0; j < num_points; j++ )
                int idx = ( point_indices ? ( *point_indices )[j]
                                          : j );  // The index in my targetEnts for this interpolation point
                // Remote proc/idx from myLocator->parLocTable
                TLob.vi_wr[4 * tn]     = myLocator->par_loc_table().vi_rd[2 * idx];      // proc
                TLob.vi_wr[4 * tn + 1] = myLocator->par_loc_table().vi_rd[2 * idx + 1];  // Remote idx
                // Local entity index, tag/method index from my data
                TLob.vi_wr[4 * tn + 2] = idx;
                TLob.vi_wr[4 * tn + 3] = m;
                TLob.inc_n();
                tn++;
        // Scatter/gather interpolation points
        myPcomm->proc_config().crystal_router()->gs_transfer( 1, TLob, 0 );
        // Perform interpolation on local source mesh; put results into TLinterp
        TupleList TLinterp;  // TLinterp structure: (pto_i, ridx_i, vals[max_tsize]_d)
        TLinterp.initialize( 2, 0, 0, max_tsize, TLob.get_n() );
        TLinterp.set_n( TLob.get_n() );  // Set the size right away
        TLinterp.enableWriteAccess();
        for( unsigned int i = 0; i < TLob.get_n(); i++ )
            int lidx = TLob.vi_rd[4 * i + 1];  // Index into myLocator's local table
            // Method and tag indexed with same index
            ///*Method*/ int method = methods[TLob.vi_rd[4*i + 3]];
            Tag tag = tags[TLob.vi_rd[4 * i + 3]];
            // Copy proc/remote index from TLob
            TLinterp.vi_wr[2 * i]     = TLob.vi_rd[4 * i];
            TLinterp.vi_wr[2 * i + 1] = TLob.vi_rd[4 * i + 2];
            // Set up the evaluator for the tag and entity, then interpolate, putting result in
            // TLinterp
            myLocator->elem_eval()->set_tag_handle( tag );
            myLocator->elem_eval()->set_ent_handle( myLocator->loc_table().vul_rd[lidx] );
            result =
                myLocator->elem_eval()->eval( myLocator->loc_table().vr_rd + 3 * lidx, TLinterp.vr_rd + i * max_tsize );
            if( MB_SUCCESS != result ) return result;
        // Scatter/gather interpolation data
        myPcomm->proc_config().crystal_router()->gs_transfer( 1, TLinterp, 0 );
        // Copy the interpolated field as a unit
        std::copy( TLinterp.vr_rd, TLinterp.vr_rd + TLinterp.get_n() * max_tsize, interp_vals );
    else
        // If called serially, interpolate directly from local locations/entities,
        // into either interp_vals or by setting data directly on tags on those entities
        std::vector< double > tmp_vals;
        std::vector< EntityHandle > tmp_ents;
        double* tmp_dbl = interp_vals;
            int num_points = ( points_per_method ? points_per_method[i] : targetEnts.size() );
            // Interpolated data is tsize long, which is either max size (if data passed back to
            // caller in interp_vals) or tag size (if data will be set on entities, in which case it
            // shouldn't have padding) set sizes here, inside loop over methods, to reduce memory
            // usage
            int tsize = max_tsize, tsize_bytes = 0;
            if( !interp_vals )
                tmp_vals.resize( num_points * max_tsize );
                tmp_dbl = &tmp_vals[0];
                tmp_ents.resize( num_points );
                result = mbImpl->tag_get_length( tags[i], tsize );
                result = mbImpl->tag_get_bytes( tags[i], tsize_bytes );
                int lidx;
                if( point_indices )
                    lidx = ( *point_indices )[j];
                else
                    lidx = j;
                myLocator->elem_eval()->set_tag_handle( tags[i] );
                if( !interp_vals ) tmp_ents[j] = targetEnts[lidx];  // Could be performance-sensitive, thus the if test
                result = myLocator->elem_eval()->eval( myLocator->loc_table().vr_rd + 3 * lidx, tmp_dbl );
                tmp_dbl += tsize;
            }  // for j over points
            if( !interp_vals )
                // Set tags on tmp_ents; data is already w/o padding, due to tsize setting above
                result = mbImpl->tag_set_data( tags[i], &tmp_ents[0], tmp_ents.size(), &tmp_vals[0] );
        }  // for i over methods
    }      // if myPcomm
    // Done
    return MB_SUCCESS;
ErrorCode moab::DataCoupler::locate_points ( double *  xyz,
int  num_points,
const double  rel_iter_tol = 1.0e-10,
const double  abs_iter_tol = 1.0e-10,
const double  inside_tol = 1.0e-6
Definition at line 81 of file DataCoupler.cpp.
References moab::SpatialLocator::locate_points(), myLocator, myPcomm, and moab::ParallelComm::size().
Referenced by DeformMeshRemap::execute().
#ifdef MOAB_HAVE_MPI
        return myLocator->par_locate_points( myPcomm, xyz, num_points, rel_iter_tol, abs_iter_tol, inside_tol );
#endif
    return myLocator->locate_points( xyz, num_points, rel_iter_tol, abs_iter_tol, inside_tol );
ErrorCode moab::DataCoupler::locate_points ( Range ents,
Definition at line 66 of file DataCoupler.cpp.
References moab::SpatialLocator::locate_points(), myLocator, myPcomm, moab::ParallelComm::size(), and targetEnts.
    targetEnts = targ_ents;
        return myLocator->par_locate_points( myPcomm, targ_ents, rel_iter_tol, abs_iter_tol, inside_tol );
#endif
    return myLocator->locate_points( targ_ents, rel_iter_tol, abs_iter_tol, inside_tol );
int moab::DataCoupler::my_id ( ) const [inline]
Definition at line 224 of file DataCoupler.hpp.
References myId.
        return myId;
Definition at line 220 of file DataCoupler.hpp.
References myLocator.
        return myLocator;
const Range& moab::DataCoupler::target_ents ( ) const [inline]
Definition at line 228 of file DataCoupler.hpp.
References targetEnts.
        return targetEnts;
Definition at line 232 of file DataCoupler.hpp.
        return targetEnts;
Member Data Documentation
Definition at line 244 of file DataCoupler.hpp.
Referenced by DataCoupler(), and interpolate().
int moab::DataCoupler::myDim [private]
Definition at line 263 of file DataCoupler.hpp.
Referenced by DataCoupler(), and get_dim().
int moab::DataCoupler::myId [private]
Definition at line 256 of file DataCoupler.hpp.
Referenced by my_id().
Definition at line 248 of file DataCoupler.hpp.
Referenced by DataCoupler(), interpolate(), and locate_points().
Definition at line 260 of file DataCoupler.hpp.
Referenced by interpolate(), locate_points(), and target_ents().
List of all members.
