Mesh Oriented datABase
(version 5.4.1)
Parallel communications in MOAB. More...
#include <ParallelComm.hpp>
Classes | |
class | Buffer |
struct | SharedEntityData |
Public Member Functions | |
ParallelComm (Interface *impl, MPI_Comm comm, int *pcomm_id_out=0) | |
constructor | |
ParallelComm (Interface *impl, std::vector< unsigned char > &tmp_buff, MPI_Comm comm, int *pcomm_id_out=0) | |
constructor taking packed buffer, for testing | |
int | get_id () const |
Get ID used to reference this PCOMM instance. | |
~ParallelComm () | |
destructor | |
ErrorCode | assign_global_ids (EntityHandle this_set, const int dimension, const int start_id=1, const bool largest_dim_only=true, const bool parallel=true, const bool owned_only=false) |
assign a global id space, for largest-dimension or all entities (and in either case for vertices too) | |
ErrorCode | assign_global_ids (Range entities[], const int dimension, const int start_id, const bool parallel, const bool owned_only) |
ErrorCode | check_global_ids (EntityHandle this_set, const int dimension, const int start_id=1, const bool largest_dim_only=true, const bool parallel=true, const bool owned_only=false) |
check for global ids; based only on tag handle being there or not; if it's not there, create them for the specified dimensions | |
ErrorCode | send_entities (const int to_proc, Range &orig_ents, const bool adjs, const bool tags, const bool store_remote_handles, const bool is_iface, Range &final_ents, int &incoming1, int &incoming2, TupleList &entprocs, std::vector< MPI_Request > &recv_remoteh_reqs, bool wait_all=true) |
send entities to another processor, optionally waiting until it's done | |
ErrorCode | send_entities (std::vector< unsigned int > &send_procs, std::vector< Range * > &send_ents, int &incoming1, int &incoming2, const bool store_remote_handles) |
ErrorCode | recv_entities (const int from_proc, const bool store_remote_handles, const bool is_iface, Range &final_ents, int &incomming1, int &incoming2, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< MPI_Request > &recv_remoteh_reqs, bool wait_all=true) |
Receive entities from another processor, optionally waiting until it's done. | |
ErrorCode | recv_entities (std::set< unsigned int > &recv_procs, int incoming1, int incoming2, const bool store_remote_handles, const bool migrate=false) |
ErrorCode | recv_messages (const int from_proc, const bool store_remote_handles, const bool is_iface, Range &final_ents, int &incoming1, int &incoming2, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< MPI_Request > &recv_remoteh_reqs) |
Receive messages from another processor in while loop. | |
ErrorCode | recv_remote_handle_messages (const int from_proc, int &incoming2, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< MPI_Request > &recv_remoteh_reqs) |
ErrorCode | exchange_ghost_cells (int ghost_dim, int bridge_dim, int num_layers, int addl_ents, bool store_remote_handles, bool wait_all=true, EntityHandle *file_set=NULL) |
Exchange ghost cells with neighboring procs Neighboring processors are those sharing an interface with this processor. All entities of dimension ghost_dim within num_layers of interface, measured going through bridge_dim, are exchanged. See MeshTopoUtil::get_bridge_adjacencies for description of bridge adjacencies. If wait_all is false and store_remote_handles is true, MPI_Request objects are available in the sendReqs[2*MAX_SHARING_PROCS] member array, with inactive requests marked as MPI_REQUEST_NULL. If store_remote_handles or wait_all is false, this function returns after all entities have been received and processed. | |
ErrorCode | post_irecv (std::vector< unsigned int > &exchange_procs) |
Post "MPI_Irecv" before meshing. | |
ErrorCode | post_irecv (std::vector< unsigned int > &shared_procs, std::set< unsigned int > &recv_procs) |
ErrorCode | exchange_owned_meshs (std::vector< unsigned int > &exchange_procs, std::vector< Range * > &exchange_ents, std::vector< MPI_Request > &recv_ent_reqs, std::vector< MPI_Request > &recv_remoteh_reqs, bool store_remote_handles, bool wait_all=true, bool migrate=false, int dim=0) |
Exchange owned mesh for input mesh entities and sets This function should be called collectively over the communicator for this ParallelComm. If this version is called, all shared exchanged entities should have a value for this tag (or the tag should have a default value). | |
ErrorCode | exchange_owned_mesh (std::vector< unsigned int > &exchange_procs, std::vector< Range * > &exchange_ents, std::vector< MPI_Request > &recv_ent_reqs, std::vector< MPI_Request > &recv_remoteh_reqs, const bool recv_posted, bool store_remote_handles, bool wait_all, bool migrate=false) |
Exchange owned mesh for input mesh entities and sets This function is called twice by exchange_owned_meshs to exchange entities before sets. | |
ErrorCode | exchange_tags (const std::vector< Tag > &src_tags, const std::vector< Tag > &dst_tags, const Range &entities) |
Exchange tags for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If this version is called, all ghosted/shared entities should have a value for this tag (or the tag should have a default value). If the entities vector is empty, all shared entities participate in the exchange. If a proc has no owned entities this function must still be called since it is collective. | |
ErrorCode | exchange_tags (const char *tag_name, const Range &entities) |
Exchange tags for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If the entities vector is empty, all shared entities participate in the exchange. If a proc has no owned entities this function must still be called since it is collective. | |
ErrorCode | exchange_tags (Tag tagh, const Range &entities) |
ErrorCode | reduce_tags (const std::vector< Tag > &src_tags, const std::vector< Tag > &dst_tags, const MPI_Op mpi_op, const Range &entities) |
Perform data reduction operation for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If this version is called, all ghosted/shared entities should have a value for this tag (or the tag should have a default value). Operation is any MPI_Op, with result stored in destination tag. | |
ErrorCode | reduce_tags (const char *tag_name, const MPI_Op mpi_op, const Range &entities) |
Perform data reduction operation for all shared and ghosted entities Same as std::vector variant except for one tag specified by name. | |
ErrorCode | reduce_tags (Tag tag_handle, const MPI_Op mpi_op, const Range &entities) |
Perform data reduction operation for all shared and ghosted entities Same as std::vector variant except for one tag specified by handle. | |
ErrorCode | broadcast_entities (const int from_proc, Range &entities, const bool adjacencies=false, const bool tags=true) |
Broadcast all entities resident on from_proc to other processors This function assumes remote handles are *not* being stored, since (usually) every processor will know about the whole mesh. | |
ErrorCode | scatter_entities (const int from_proc, std::vector< Range > &entities, const bool adjacencies=false, const bool tags=true) |
Scatter entities on from_proc to other processors This function assumes remote handles are *not* being stored, since (usually) every processor will know about the whole mesh. | |
ErrorCode | send_recv_entities (std::vector< int > &send_procs, std::vector< std::vector< int > > &msgsizes, std::vector< std::vector< EntityHandle > > &senddata, std::vector< std::vector< EntityHandle > > &recvdata) |
Send and receives data from a set of processors. | |
ErrorCode | update_remote_data (EntityHandle entity, std::vector< int > &procs, std::vector< EntityHandle > &handles) |
ErrorCode | get_remote_handles (EntityHandle *local_vec, EntityHandle *rem_vec, int num_ents, int to_proc) |
ErrorCode | resolve_shared_ents (EntityHandle this_set, Range &proc_ents, int resolve_dim=-1, int shared_dim=-1, Range *skin_ents=NULL, const Tag *id_tag=0) |
Resolve shared entities between processors. | |
ErrorCode | resolve_shared_ents (EntityHandle this_set, int resolve_dim=3, int shared_dim=-1, const Tag *id_tag=0) |
ErrorCode | resolve_shared_sets (EntityHandle this_set, const Tag *id_tag=0) |
ErrorCode | resolve_shared_sets (Range &candidate_sets, Tag id_tag) |
ErrorCode | augment_default_sets_with_ghosts (EntityHandle file_set) |
ErrorCode | get_pstatus (EntityHandle entity, unsigned char &pstatus_val) |
Get parallel status of an entity Returns the parallel status of an entity. | |
ErrorCode | get_pstatus_entities (int dim, unsigned char pstatus_val, Range &pstatus_ents) |
Get entities with the given pstatus bit(s) set Returns any entities whose pstatus tag value v satisfies (v & pstatus_val) | |
ErrorCode | get_owner (EntityHandle entity, int &owner) |
Return the rank of the entity owner. | |
ErrorCode | get_owner_handle (EntityHandle entity, int &owner, EntityHandle &handle) |
Return the owner processor and handle of a given entity. | |
ErrorCode | get_sharing_data (const EntityHandle entity, int *ps, EntityHandle *hs, unsigned char &pstat, unsigned int &num_ps) |
Get the shared processors/handles for an entity Get the shared processors/handles for an entity. Arrays must be large enough to receive data for all sharing procs. Does *not* include this proc if only shared with one other proc. | |
ErrorCode | get_sharing_data (const EntityHandle entity, int *ps, EntityHandle *hs, unsigned char &pstat, int &num_ps) |
Get the shared processors/handles for an entity Same as other version but with int num_ps. | |
ErrorCode | get_sharing_data (const EntityHandle *entities, int num_entities, std::set< int > &procs, int op=Interface::INTERSECT) |
Get the intersection or union of all sharing processors Get the intersection or union of all sharing processors. Processor set is cleared as part of this function. | |
ErrorCode | get_sharing_data (const Range &entities, std::set< int > &procs, int op=Interface::INTERSECT) |
Get the intersection or union of all sharing processors Same as previous variant but with range as input. | |
ErrorCode | get_shared_entities (int other_proc, Range &shared_ents, int dim=-1, const bool iface=false, const bool owned_filter=false) |
Get shared entities of specified dimension If other_proc is -1, any shared entities are returned. If dim is -1, entities of all dimensions on interface are returned. | |
ErrorCode | get_interface_procs (std::set< unsigned int > &iface_procs, const bool get_buffs=false) |
get processors with which this processor shares an interface | |
ErrorCode | get_comm_procs (std::set< unsigned int > &procs) |
get processors with which this processor communicates | |
ErrorCode | get_entityset_procs (EntityHandle entity_set, std::vector< unsigned > &ranks) const |
Get array of process IDs sharing a set. Returns zero and passes back NULL if set is not shared. | |
ErrorCode | get_entityset_owner (EntityHandle entity_set, unsigned &owner_rank, EntityHandle *remote_handle=0) const |
Get rank of the owner of a shared set. Returns this proc if set is not shared. Optionally returns handle on owning process for shared set. | |
ErrorCode | get_entityset_local_handle (unsigned owning_rank, EntityHandle remote_handle, EntityHandle &local_handle) const |
Given set owner and handle on owner, find local set handle. | |
ErrorCode | get_shared_sets (Range &result) const |
Get all shared sets. | |
ErrorCode | get_entityset_owners (std::vector< unsigned > &ranks) const |
Get ranks of all processes that own at least one set that is shared with this process. Will include the rank of this process if this process owns any shared set. | |
ErrorCode | get_owned_sets (unsigned owning_rank, Range &sets_out) const |
Get shared sets owned by process with specified rank. | |
const ProcConfig & | proc_config () const |
Get proc config for this communication object. | |
ProcConfig & | proc_config () |
unsigned | rank () const |
unsigned | size () const |
MPI_Comm | comm () const |
ErrorCode | get_shared_proc_tags (Tag &sharedp_tag, Tag &sharedps_tag, Tag &sharedh_tag, Tag &sharedhs_tag, Tag &pstatus_tag) |
return the tags used to indicate shared procs and handles | |
Range & | partition_sets () |
return partition, interface set ranges | |
const Range & | partition_sets () const |
Range & | interface_sets () |
const Range & | interface_sets () const |
Tag | sharedp_tag () |
return sharedp tag | |
Tag | sharedps_tag () |
return sharedps tag | |
Tag | sharedh_tag () |
return sharedh tag | |
Tag | sharedhs_tag () |
return sharedhs tag | |
Tag | pstatus_tag () |
return pstatus tag | |
Tag | partition_tag () |
return partitions set tag | |
Tag | part_tag () |
void | print_pstatus (unsigned char pstat, std::string &ostr) |
print contents of pstatus value in human-readable form | |
void | print_pstatus (unsigned char pstat) |
print contents of pstatus value in human-readable form to std::cut | |
ErrorCode | get_part_entities (Range &ents, int dim=-1) |
return all the entities in parts owned locally | |
EntityHandle | get_partitioning () const |
ErrorCode | set_partitioning (EntityHandle h) |
ErrorCode | get_global_part_count (int &count_out) const |
ErrorCode | get_part_owner (int part_id, int &owner_out) const |
ErrorCode | get_part_id (EntityHandle part, int &id_out) const |
ErrorCode | get_part_handle (int id, EntityHandle &handle_out) const |
ErrorCode | create_part (EntityHandle &part_out) |
ErrorCode | destroy_part (EntityHandle part) |
ErrorCode | collective_sync_partition () |
ErrorCode | get_part_neighbor_ids (EntityHandle part, int neighbors_out[MAX_SHARING_PROCS], int &num_neighbors_out) |
ErrorCode | get_interface_sets (EntityHandle part, Range &iface_sets_out, int *adj_part_id=0) |
ErrorCode | get_owning_part (EntityHandle entity, int &owning_part_id_out, EntityHandle *owning_handle=0) |
ErrorCode | get_sharing_parts (EntityHandle entity, int part_ids_out[MAX_SHARING_PROCS], int &num_part_ids_out, EntityHandle remote_handles[MAX_SHARING_PROCS]=0) |
ErrorCode | filter_pstatus (Range &ents, const unsigned char pstatus_val, const unsigned char op, int to_proc=-1, Range *returned_ents=NULL) |
ErrorCode | get_iface_entities (int other_proc, int dim, Range &iface_ents) |
Get entities on interfaces shared with another proc. | |
Interface * | get_moab () const |
ErrorCode | clean_shared_tags (std::vector< Range * > &exchange_ents) |
ErrorCode | pack_buffer (Range &orig_ents, const bool adjacencies, const bool tags, const bool store_remote_handles, const int to_proc, Buffer *buff, TupleList *entprocs=NULL, Range *allsent=NULL) |
public 'cuz we want to unit test these externally | |
ErrorCode | unpack_buffer (unsigned char *buff_ptr, const bool store_remote_handles, const int from_proc, const int ind, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< EntityHandle > &new_ents, const bool created_iface=false) |
ErrorCode | pack_entities (Range &entities, Buffer *buff, const bool store_remote_handles, const int to_proc, const bool is_iface, TupleList *entprocs=NULL, Range *allsent=NULL) |
ErrorCode | unpack_entities (unsigned char *&buff_ptr, const bool store_remote_handles, const int from_ind, const bool is_iface, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< EntityHandle > &new_ents, const bool created_iface=false) |
unpack entities in buff_ptr | |
ErrorCode | check_all_shared_handles (bool print_em=false) |
Call exchange_all_shared_handles, then compare the results with tag data on local shared entities. | |
ErrorCode | pack_shared_handles (std::vector< std::vector< SharedEntityData > > &send_data) |
ErrorCode | check_local_shared () |
ErrorCode | check_my_shared_handles (std::vector< std::vector< SharedEntityData > > &shents, const char *prefix=NULL) |
void | set_rank (unsigned int r) |
set rank for this pcomm; USED FOR TESTING ONLY! | |
void | set_size (unsigned int r) |
int | get_buffers (int to_proc, bool *is_new=NULL) |
get (and possibly allocate) buffers for messages to/from to_proc; returns index of to_proc in buffProcs vector; if is_new is non-NULL, sets to whether new buffer was allocated PUBLIC ONLY FOR TESTING! | |
const std::vector< unsigned int > & | buff_procs () const |
get buff processor vector | |
ErrorCode | unpack_remote_handles (unsigned int from_proc, unsigned char *&buff_ptr, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p) |
ErrorCode | pack_remote_handles (std::vector< EntityHandle > &L1hloc, std::vector< EntityHandle > &L1hrem, std::vector< int > &procs, unsigned int to_proc, Buffer *buff) |
ErrorCode | create_interface_sets (std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs) |
ErrorCode | create_interface_sets (EntityHandle this_set, int resolve_dim, int shared_dim) |
ErrorCode | tag_shared_verts (TupleList &shared_ents, std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs, Range &proc_verts, unsigned int i_extra=1) |
ErrorCode | list_entities (const EntityHandle *ents, int num_ents) |
ErrorCode | list_entities (const Range &ents) |
void | set_send_request (int n_request) |
void | set_recv_request (int n_request) |
void | reset_all_buffers () |
reset message buffers to their initial state | |
void | set_debug_verbosity (int verb) |
set the verbosity level of output from this pcomm | |
int | get_debug_verbosity () |
get the verbosity level of output from this pcomm | |
ErrorCode | gather_data (Range &gather_ents, Tag &tag_handle, Tag id_tag=0, EntityHandle gather_set=0, int root_proc_rank=0) |
ErrorCode | settle_intersection_points (Range &edges, Range &shared_edges_owned, std::vector< std::vector< EntityHandle > * > &extraNodesVec, double tolerance) |
ErrorCode | delete_entities (Range &to_delete) |
ErrorCode | correct_thin_ghost_layers () |
Static Public Member Functions | |
static ParallelComm * | get_pcomm (Interface *impl, const int index) |
get the indexed pcomm object from the interface | |
static ParallelComm * | get_pcomm (Interface *impl, EntityHandle partitioning, const MPI_Comm *comm=0) |
Get ParallelComm instance associated with partition handle Will create ParallelComm instance if a) one does not already exist and b) a valid value for MPI_Comm is passed. | |
static ErrorCode | get_all_pcomm (Interface *impl, std::vector< ParallelComm * > &list) |
static ErrorCode | exchange_ghost_cells (ParallelComm **pc, unsigned int num_procs, int ghost_dim, int bridge_dim, int num_layers, int addl_ents, bool store_remote_handles, EntityHandle *file_sets=NULL) |
Static version of exchange_ghost_cells, exchanging info through buffers rather than messages. | |
static ErrorCode | resolve_shared_ents (ParallelComm **pc, const unsigned int np, EntityHandle this_set, const int to_dim) |
static Tag | pcomm_tag (Interface *impl, bool create_if_missing=true) |
return pcomm tag; static because might not have a pcomm before going to look for one on the interface | |
static ErrorCode | check_all_shared_handles (ParallelComm **pcs, int num_pcs) |
Static Public Attributes | |
static unsigned char | PROC_SHARED |
static unsigned char | PROC_OWNER |
static const unsigned int | INITIAL_BUFF_SIZE = 1024 |
Private Member Functions | |
ErrorCode | reduce_void (int tag_data_type, const MPI_Op mpi_op, int num_ents, void *old_vals, void *new_vals) |
template<class T > | |
ErrorCode | reduce (const MPI_Op mpi_op, int num_ents, void *old_vals, void *new_vals) |
void | print_debug_isend (int from, int to, unsigned char *buff, int tag, int size) |
void | print_debug_irecv (int to, int from, unsigned char *buff, int size, int tag, int incoming) |
void | print_debug_recd (MPI_Status status) |
void | print_debug_waitany (std::vector< MPI_Request > &reqs, int tag, int proc) |
void | initialize () |
ErrorCode | set_sharing_data (EntityHandle ent, unsigned char pstatus, int old_nump, int new_nump, int *ps, EntityHandle *hs) |
ErrorCode | check_clean_iface (Range &allsent) |
void | define_mpe () |
ErrorCode | get_sent_ents (const bool is_iface, const int bridge_dim, const int ghost_dim, const int num_layers, const int addl_ents, Range *sent_ents, Range &allsent, TupleList &entprocs) |
ErrorCode | set_pstatus_entities (Range &pstatus_ents, unsigned char pstatus_val, bool lower_dim_ents=false, bool verts_too=true, int operation=Interface::UNION) |
Set pstatus values on entities. | |
ErrorCode | set_pstatus_entities (EntityHandle *pstatus_ents, int num_ents, unsigned char pstatus_val, bool lower_dim_ents=false, bool verts_too=true, int operation=Interface::UNION) |
Set pstatus values on entities (vector-based function) | |
int | estimate_ents_buffer_size (Range &entities, const bool store_remote_handles) |
estimate size required to pack entities | |
int | estimate_sets_buffer_size (Range &entities, const bool store_remote_handles) |
estimate size required to pack sets | |
ErrorCode | send_buffer (const unsigned int to_proc, Buffer *send_buff, const int msg_tag, MPI_Request &send_req, MPI_Request &ack_recv_req, int *ack_buff, int &this_incoming, int next_mesg_tag=-1, Buffer *next_recv_buff=NULL, MPI_Request *next_recv_req=NULL, int *next_incoming=NULL) |
send the indicated buffer, possibly sending size first | |
ErrorCode | recv_buffer (int mesg_tag_expected, const MPI_Status &mpi_status, Buffer *recv_buff, MPI_Request &recv_2nd_req, MPI_Request &ack_req, int &this_incoming, Buffer *send_buff, MPI_Request &send_req, MPI_Request &sent_ack_req, bool &done, Buffer *next_buff=NULL, int next_tag=-1, MPI_Request *next_req=NULL, int *next_incoming=NULL) |
process incoming message; if longer than the initial size, post recv for next part then send ack; if ack, send second part; else indicate that we're done and buffer is ready for processing | |
ErrorCode | pack_entity_seq (const int nodes_per_entity, const bool store_remote_handles, const int to_proc, Range &these_ents, std::vector< EntityHandle > &entities, Buffer *buff) |
pack a range of entities with equal # verts per entity, along with the range on the sending proc | |
ErrorCode | print_buffer (unsigned char *buff_ptr, int mesg_type, int from_proc, bool sent) |
ErrorCode | unpack_iface_entities (unsigned char *&buff_ptr, const int from_proc, const int ind, std::vector< EntityHandle > &recd_ents) |
for all the entities in the received buffer; for each, save entities in this instance which match connectivity, or zero if none found | |
ErrorCode | pack_sets (Range &entities, Buffer *buff, const bool store_handles, const int to_proc) |
ErrorCode | unpack_sets (unsigned char *&buff_ptr, std::vector< EntityHandle > &entities, const bool store_handles, const int to_proc) |
ErrorCode | pack_adjacencies (Range &entities, Range::const_iterator &start_rit, Range &whole_range, unsigned char *&buff_ptr, int &count, const bool just_count, const bool store_handles, const int to_proc) |
ErrorCode | unpack_adjacencies (unsigned char *&buff_ptr, Range &entities, const bool store_handles, const int from_proc) |
ErrorCode | unpack_remote_handles (unsigned int from_proc, const unsigned char *buff_ptr, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p) |
ErrorCode | find_existing_entity (const bool is_iface, const int owner_p, const EntityHandle owner_h, const int num_ents, const EntityHandle *connect, const int num_connect, const EntityType this_type, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, EntityHandle &new_h) |
given connectivity and type, find an existing entity, if there is one | |
ErrorCode | build_sharedhps_list (const EntityHandle entity, const unsigned char pstatus, const int sharedp, const std::set< unsigned int > &procs, unsigned int &num_ents, int *tmp_procs, EntityHandle *tmp_handles) |
ErrorCode | get_tag_send_list (const Range &all_entities, std::vector< Tag > &all_tags, std::vector< Range > &tag_ranges) |
Get list of tags for which to exchange data. | |
ErrorCode | pack_tags (Range &entities, const std::vector< Tag > &src_tags, const std::vector< Tag > &dst_tags, const std::vector< Range > &tag_ranges, Buffer *buff, const bool store_handles, const int to_proc) |
Serialize entity tag data. | |
ErrorCode | packed_tag_size (Tag source_tag, const Range &entities, int &count_out) |
Calculate buffer size required to pack tag data. | |
ErrorCode | pack_tag (Tag source_tag, Tag destination_tag, const Range &entities, const std::vector< EntityHandle > &whole_range, Buffer *buff, const bool store_remote_handles, const int to_proc) |
Serialize tag data. | |
ErrorCode | unpack_tags (unsigned char *&buff_ptr, std::vector< EntityHandle > &entities, const bool store_handles, const int to_proc, const MPI_Op *const mpi_op=NULL) |
ErrorCode | tag_shared_verts (TupleList &shared_verts, Range *skin_ents, std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs, Range &proc_verts) |
ErrorCode | get_proc_nvecs (int resolve_dim, int shared_dim, Range *skin_ents, std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs) |
ErrorCode | create_iface_pc_links () |
ErrorCode | pack_range_map (Range &this_range, EntityHandle actual_start, HandleMap &handle_map) |
pack a range map with keys in this_range and values a contiguous series of handles starting at actual_start | |
bool | is_iface_proc (EntityHandle this_set, int to_proc) |
returns true if the set is an interface shared with to_proc | |
ErrorCode | update_iface_sets (Range &sent_ents, std::vector< EntityHandle > &remote_handles, int from_proc) |
for any remote_handles set to zero, remove corresponding sent_ents from iface_sets corresponding to from_proc | |
ErrorCode | get_ghosted_entities (int bridge_dim, int ghost_dim, int to_proc, int num_layers, int addl_ents, Range &ghosted_ents) |
for specified bridge/ghost dimension, to_proc, and number of layers, get the entities to be ghosted, and info on additional procs needing to communicate with to_proc | |
ErrorCode | add_verts (Range &sent_ents) |
add vertices adjacent to entities in this list | |
ErrorCode | exchange_all_shared_handles (std::vector< std::vector< SharedEntityData > > &send_data, std::vector< std::vector< SharedEntityData > > &result) |
Every processor sends shared entity handle data to every other processor that it shares entities with. Passed back map is all received data, indexed by processor ID. This function is intended to be used for debugging. | |
ErrorCode | get_remote_handles (const bool store_remote_handles, EntityHandle *from_vec, EntityHandle *to_vec_tmp, int num_ents, int to_proc, const std::vector< EntityHandle > &new_ents) |
replace handles in from_vec with corresponding handles on to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag; if no remote handle and new_ents is non-null, substitute instead CREATE_HANDLE(MBMAXTYPE, index) where index is handle's position in new_ents | |
ErrorCode | get_remote_handles (const bool store_remote_handles, const Range &from_range, Range &to_range, int to_proc, const std::vector< EntityHandle > &new_ents) |
same as other version, except from_range and to_range should be different here | |
ErrorCode | get_remote_handles (const bool store_remote_handles, const Range &from_range, EntityHandle *to_vec, int to_proc, const std::vector< EntityHandle > &new_ents) |
same as other version, except packs range into vector | |
ErrorCode | get_local_handles (EntityHandle *from_vec, int num_ents, const Range &new_ents) |
goes through from_vec, and for any with type MBMAXTYPE, replaces with new_ents value at index corresponding to id of entity in from_vec | |
ErrorCode | get_local_handles (const Range &remote_handles, Range &local_handles, const std::vector< EntityHandle > &new_ents) |
same as above except puts results in range | |
ErrorCode | get_local_handles (EntityHandle *from_vec, int num_ents, const std::vector< EntityHandle > &new_ents) |
same as above except gets new_ents from vector | |
ErrorCode | update_remote_data (Range &local_range, Range &remote_range, int other_proc, const unsigned char add_pstat) |
ErrorCode | update_remote_data (const EntityHandle new_h, const int *ps, const EntityHandle *hs, const int num_ps, const unsigned char add_pstat) |
ErrorCode | update_remote_data_old (const EntityHandle new_h, const int *ps, const EntityHandle *hs, const int num_ps, const unsigned char add_pstat) |
ErrorCode | tag_iface_entities () |
Set pstatus tag interface bit on entities in sets passed in. | |
int | add_pcomm (ParallelComm *pc) |
add a pc to the iface instance tag PARALLEL_COMM | |
void | remove_pcomm (ParallelComm *pc) |
remove a pc from the iface instance tag PARALLEL_COMM | |
ErrorCode | check_sent_ents (Range &allsent) |
check entities to make sure there are no zero-valued remote handles where they shouldn't be | |
ErrorCode | assign_entities_part (std::vector< EntityHandle > &entities, const int proc) |
assign entities to the input processor part | |
ErrorCode | remove_entities_part (Range &entities, const int proc) |
remove entities to the input processor part | |
void | delete_all_buffers () |
Private Attributes | |
Interface * | mbImpl |
MB interface associated with this writer. | |
ProcConfig | procConfig |
Proc config object, keeps info on parallel stuff. | |
SequenceManager * | sequenceManager |
Sequence manager, to get more efficient access to entities. | |
Error * | errorHandler |
Error handler. | |
std::vector< Buffer * > | localOwnedBuffs |
more data buffers, proc-specific | |
std::vector< Buffer * > | remoteOwnedBuffs |
std::vector< MPI_Request > | sendReqs |
request objects, may be used if store_remote_handles is used | |
std::vector< MPI_Request > | recvReqs |
receive request objects | |
std::vector< MPI_Request > | recvRemotehReqs |
std::vector< unsigned int > | buffProcs |
processor rank for each buffer index | |
Range | partitionSets |
the partition, interface sets for this comm'n instance | |
Range | interfaceSets |
std::set< EntityHandle > | sharedEnts |
all local entities shared with others, whether ghost or ghosted | |
Tag | sharedpTag |
tags used to save sharing procs and handles | |
Tag | sharedpsTag |
Tag | sharedhTag |
Tag | sharedhsTag |
Tag | pstatusTag |
Tag | ifaceSetsTag |
Tag | partitionTag |
int | globalPartCount |
Cache of global part count. | |
EntityHandle | partitioningSet |
entity set containing all parts | |
std::ofstream | myFile |
int | pcommID |
int | ackbuff |
DebugOutput * | myDebug |
used to set verbosity level and to report output | |
SharedSetData * | sharedSetData |
Data about shared sets. | |
Friends | |
class | ParallelMergeMesh |
This class implements methods to communicate mesh between processors
Definition at line 54 of file ParallelComm.hpp.
moab::ParallelComm::ParallelComm | ( | Interface * | impl, |
MPI_Comm | comm, | ||
int * | pcomm_id_out = 0 |
constructor
Definition at line 313 of file ParallelComm.cpp.
References initialize(), pcommID, moab::ProcConfig::proc_rank(), procConfig, and sharedSetData.
Referenced by get_pcomm().
: mbImpl( impl ), procConfig( cm ), sharedpTag( 0 ), sharedpsTag( 0 ), sharedhTag( 0 ), sharedhsTag( 0 ), pstatusTag( 0 ), ifaceSetsTag( 0 ), partitionTag( 0 ), globalPartCount( -1 ), partitioningSet( 0 ), myDebug( NULL ) { initialize(); sharedSetData = new SharedSetData( *impl, pcommID, procConfig.proc_rank() ); if( id ) *id = pcommID; }
std::vector< unsigned char > & | tmp_buff, | ||
Definition at line 323 of file ParallelComm.cpp.
destructor
Definition at line 333 of file ParallelComm.cpp.
References delete_all_buffers(), myDebug, remove_pcomm(), and sharedSetData.
{ remove_pcomm( this ); delete_all_buffers(); delete myDebug; delete sharedSetData; }
int moab::ParallelComm::add_pcomm | ( | ParallelComm * | pc | ) | [private] |
Definition at line 374 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_NOT_FOUND, mbImpl, pcomm_tag(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by initialize().
{ // Add this pcomm to instance tag std::vector< ParallelComm* > pc_array( MAX_SHARING_PROCS, (ParallelComm*)NULL ); Tag pc_tag = pcomm_tag( mbImpl, true ); assert( 0 != pc_tag ); const EntityHandle root = 0; ErrorCode result = mbImpl->tag_get_data( pc_tag, &root, 1, (void*)&pc_array[0] ); if( MB_SUCCESS != result && MB_TAG_NOT_FOUND != result ) return -1; int index = 0; while( index < MAX_SHARING_PROCS && pc_array[index] ) index++; if( index == MAX_SHARING_PROCS ) { index = -1; assert( false ); } else { pc_array[index] = pc; mbImpl->tag_set_data( pc_tag, &root, 1, (void*)&pc_array[0] ); } return index; }
ErrorCode moab::ParallelComm::add_verts | ( | Range & | sent_ents | ) | [private] |
Definition at line 7502 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::equal_range(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), MB_CHK_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, MBPOLYHEDRON, MBVERTEX, moab::Range::subset_by_type(), and moab::Interface::UNION.
Referenced by broadcast_entities(), exchange_owned_mesh(), get_ghosted_entities(), scatter_entities(), and send_entities().
{ // Get the verts adj to these entities, since we'll have to send those too // First check sets std::pair< Range::const_iterator, Range::const_iterator > set_range = sent_ents.equal_range( MBENTITYSET ); ErrorCode result = MB_SUCCESS, tmp_result; for( Range::const_iterator rit = set_range.first; rit != set_range.second; ++rit ) { tmp_result = mbImpl->get_entities_by_type( *rit, MBVERTEX, sent_ents );MB_CHK_SET_ERR( tmp_result, "Failed to get contained verts" ); } // Now non-sets Range tmp_ents; std::copy( sent_ents.begin(), set_range.first, range_inserter( tmp_ents ) ); result = mbImpl->get_adjacencies( tmp_ents, 0, false, sent_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get vertices adj to ghosted ents" ); // if polyhedra, need to add all faces from there Range polyhedra = sent_ents.subset_by_type( MBPOLYHEDRON ); // get all faces adjacent to every polyhedra result = mbImpl->get_connectivity( polyhedra, sent_ents );MB_CHK_SET_ERR( result, "Failed to get polyhedra faces" ); return result; }
ErrorCode moab::ParallelComm::assign_entities_part | ( | std::vector< EntityHandle > & | entities, |
const int | proc | ||
) | [private] |
Definition at line 7297 of file ParallelComm.cpp.
References moab::Interface::add_entities(), ErrorCode, get_part_handle(), MB_CHK_SET_ERR, MB_SUCCESS, and mbImpl.
Referenced by exchange_owned_mesh(), and recv_entities().
{ EntityHandle part_set; ErrorCode result = get_part_handle( proc, part_set );MB_CHK_SET_ERR( result, "Failed to get part handle" ); if( part_set > 0 ) { result = mbImpl->add_entities( part_set, &entities[0], entities.size() );MB_CHK_SET_ERR( result, "Failed to add entities to part set" ); } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::assign_global_ids | ( | EntityHandle | this_set, |
const int | dimension, | ||
const int | start_id = 1 , |
const bool | largest_dim_only = true , |
const bool | parallel = true , |
const bool | owned_only = false |
Assign a global id space, for largest-dimension or all entities (and in either case for vertices too)
owned_only | If true, do not get global IDs for non-owned entities from remote processors. |
Definition at line 421 of file ParallelComm.cpp.
References dim, moab::Range::end(), entities, ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Range::insert(), MB_CHK_SET_ERR, mbImpl, PSTATUS_NOT_OWNED, pstatus_tag(), size(), moab::subtract(), and moab::Interface::tag_get_data().
Referenced by check_global_ids(), compute_dual_mesh(), create_fine_mesh(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), iMeshP_assignGlobalIds(), main(), and resolve_shared_ents().
{ Range entities[4]; ErrorCode result; std::vector< unsigned char > pstatus; for( int dim = 0; dim <= dimension; dim++ ) { if( dim == 0 || !largest_dim_only || dim == dimension ) { result = mbImpl->get_entities_by_dimension( this_set, dim, entities[dim] );MB_CHK_SET_ERR( result, "Failed to get vertices in assign_global_ids" ); } // Need to filter out non-locally-owned entities!!! pstatus.resize( entities[dim].size() ); result = mbImpl->tag_get_data( pstatus_tag(), entities[dim], &pstatus[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus in assign_global_ids" ); Range dum_range; Range::iterator rit; unsigned int i; for( rit = entities[dim].begin(), i = 0; rit != entities[dim].end(); ++rit, i++ ) if( pstatus[i] & PSTATUS_NOT_OWNED ) dum_range.insert( *rit ); entities[dim] = subtract( entities[dim], dum_range ); } return assign_global_ids( entities, dimension, start_id, parallel, owned_only ); }
ErrorCode moab::ParallelComm::assign_global_ids | ( | Range | entities[], |
const int | start_id, | ||
const bool | parallel, | ||
const bool | owned_only | ||
Definition at line 455 of file ParallelComm.cpp.
References dim, moab::Range::end(), ErrorCode, exchange_tags(), moab::Interface::globalId_tag(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), procConfig, moab::Range::size(), size(), and moab::Interface::tag_set_data().
{ int local_num_elements[4]; ErrorCode result; for( int dim = 0; dim <= dimension; dim++ ) { local_num_elements[dim] = entities[dim].size(); } // Communicate numbers std::vector< int > num_elements( procConfig.proc_size() * 4 ); #ifdef MOAB_HAVE_MPI if( procConfig.proc_size() > 1 && parallel ) { int retval = MPI_Allgather( local_num_elements, 4, MPI_INT, &num_elements[0], 4, MPI_INT, procConfig.proc_comm() ); if( 0 != retval ) return MB_FAILURE; } else #endif for( int dim = 0; dim < 4; dim++ ) num_elements[dim] = local_num_elements[dim]; // My entities start at one greater than total_elems[d] int total_elems[4] = { start_id, start_id, start_id, start_id }; for( unsigned int proc = 0; proc < procConfig.proc_rank(); proc++ ) { for( int dim = 0; dim < 4; dim++ ) total_elems[dim] += num_elements[4 * proc + dim]; } // Assign global ids now Tag gid_tag = mbImpl->globalId_tag(); for( int dim = 0; dim < 4; dim++ ) { if( entities[dim].empty() ) continue; num_elements.resize( entities[dim].size() ); int i = 0; for( Range::iterator rit = entities[dim].begin(); rit != entities[dim].end(); ++rit ) num_elements[i++] = total_elems[dim]++; result = mbImpl->tag_set_data( gid_tag, entities[dim], &num_elements[0] );MB_CHK_SET_ERR( result, "Failed to set global id tag in assign_global_ids" ); } if( owned_only ) return MB_SUCCESS; // Exchange tags for( int dim = 1; dim < 4; dim++ ) entities[0].merge( entities[dim] ); return exchange_tags( gid_tag, entities[0] ); }
extend shared sets with ghost entities After ghosting, ghost entities do not have yet information about the material set, partition set, Neumann or Dirichlet set they could belong to This method will assign ghosted entities to the those special entity sets In some case we might even have to create those sets, if they do not exist yet on the local processor
The special entity sets all have an unique identifier, in a form of an integer tag to the set. The shared sets data is not used, because we do not use the geometry sets, as they are not uniquely identified
file_set | : file set used per application |
Definition at line 4766 of file ParallelComm.cpp.
References moab::Interface::add_entities(), moab::Interface::contains_entities(), moab::Interface::create_meshset(), moab::ProcConfig::crystal_router(), DIRICHLET_SET_TAG_NAME, moab::TupleList::enableWriteAccess(), ErrorCode, get_debug_verbosity(), moab::Interface::get_entities_by_type_and_tag(), moab::TupleList::get_max(), moab::TupleList::get_n(), get_sharing_data(), moab::Interface::globalId_tag(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MATERIAL_SET_TAG_NAME, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_ANY, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, MESHSET_SET, NEUMANN_SET_TAG_NAME, PARALLEL_PARTITION_TAG_NAME, moab::TupleList::print(), moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_size(), procConfig, PSTATUS_NOT_OWNED, rank(), moab::TupleList::resize(), sharedEnts, moab::Range::size(), size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::Interface::UNION, moab::TupleList::vi_rd, moab::TupleList::vi_wr, moab::TupleList::vul_rd, and moab::TupleList::vul_wr.
Referenced by moab::ReadParallel::load_file().
{ // gather all default sets we are interested in, material, neumann, etc // we will skip geometry sets, because they are not uniquely identified with their tag value // maybe we will add another tag, like category if( procConfig.proc_size() < 2 ) return MB_SUCCESS; // no reason to stop by const char* const shared_set_tag_names[] = { MATERIAL_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME, PARALLEL_PARTITION_TAG_NAME }; int num_tags = sizeof( shared_set_tag_names ) / sizeof( shared_set_tag_names[0] ); Range* rangeSets = new Range[num_tags]; Tag* tags = new Tag[num_tags + 1]; // one extra for global id tag, which is an int, so far int my_rank = rank(); int** tagVals = new int*[num_tags]; for( int i = 0; i < num_tags; i++ ) tagVals[i] = NULL; ErrorCode rval; // for each tag, we keep a local map, from the value to the actual set with that value // we assume that the tag values are unique, for a given set, otherwise we // do not know to which set to add the entity typedef std::map< int, EntityHandle > MVal; typedef std::map< int, EntityHandle >::iterator itMVal; MVal* localMaps = new MVal[num_tags]; for( int i = 0; i < num_tags; i++ ) { rval = mbImpl->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, tags[i], MB_TAG_ANY ); if( MB_SUCCESS != rval ) continue; rval = mbImpl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &( tags[i] ), 0, 1, rangeSets[i], Interface::UNION );MB_CHK_SET_ERR( rval, "can't get sets with a tag" ); if( rangeSets[i].size() > 0 ) { tagVals[i] = new int[rangeSets[i].size()]; // fill up with the tag values rval = mbImpl->tag_get_data( tags[i], rangeSets[i], tagVals[i] );MB_CHK_SET_ERR( rval, "can't get set tag values" ); // now for inverse mapping: for( int j = 0; j < (int)rangeSets[i].size(); j++ ) { localMaps[i][tagVals[i][j]] = rangeSets[i][j]; } } } // get the global id tag too tags[num_tags] = mbImpl->globalId_tag(); TupleList remoteEnts; // processor to send to, type of tag (0-mat,) tag value, remote handle // 1-diri // 2-neum // 3-part // int initialSize = (int)sharedEnts.size(); // estimate that on average, each shared ent // will be sent to one processor, for one tag // we will actually send only entities that are owned locally, and from those // only those that do have a special tag (material, neumann, etc) // if we exceed the capacity, we resize the tuple remoteEnts.initialize( 3, 0, 1, 0, initialSize ); remoteEnts.enableWriteAccess(); // now, for each owned entity, get the remote handle(s) and Proc(s), and verify if it // belongs to one of the sets; if yes, create a tuple and append it std::set< EntityHandle > own_and_sha; int ir = 0, jr = 0; for( std::set< EntityHandle >::iterator vit = sharedEnts.begin(); vit != sharedEnts.end(); ++vit ) { // ghosted eh EntityHandle geh = *vit; if( own_and_sha.find( geh ) != own_and_sha.end() ) // already encountered continue; int procs[MAX_SHARING_PROCS]; EntityHandle handles[MAX_SHARING_PROCS]; int nprocs; unsigned char pstat; rval = get_sharing_data( geh, procs, handles, pstat, nprocs ); if( rval != MB_SUCCESS ) { for( int i = 0; i < num_tags; i++ ) delete[] tagVals[i]; delete[] tagVals; MB_CHK_SET_ERR( rval, "Failed to get sharing data" ); } if( pstat & PSTATUS_NOT_OWNED ) continue; // we will send info only for entities that we own own_and_sha.insert( geh ); for( int i = 0; i < num_tags; i++ ) { for( int j = 0; j < (int)rangeSets[i].size(); j++ ) { EntityHandle specialSet = rangeSets[i][j]; // this set has tag i, value tagVals[i][j]; if( mbImpl->contains_entities( specialSet, &geh, 1 ) ) { // this ghosted entity is in a special set, so form the tuple // to send to the processors that do not own this for( int k = 0; k < nprocs; k++ ) { if( procs[k] != my_rank ) { if( remoteEnts.get_n() >= remoteEnts.get_max() - 1 ) { // resize, so we do not overflow int oldSize = remoteEnts.get_max(); // increase with 50% the capacity remoteEnts.resize( oldSize + oldSize / 2 + 1 ); } remoteEnts.vi_wr[ir++] = procs[k]; // send to proc remoteEnts.vi_wr[ir++] = i; // for the tags [i] (0-3) remoteEnts.vi_wr[ir++] = tagVals[i][j]; // actual value of the tag remoteEnts.vul_wr[jr++] = handles[k]; remoteEnts.inc_n(); } } } } } // if the local entity has a global id, send it too, so we avoid // another "exchange_tags" for global id int gid; rval = mbImpl->tag_get_data( tags[num_tags], &geh, 1, &gid );MB_CHK_SET_ERR( rval, "Failed to get global id" ); if( gid != 0 ) { for( int k = 0; k < nprocs; k++ ) { if( procs[k] != my_rank ) { if( remoteEnts.get_n() >= remoteEnts.get_max() - 1 ) { // resize, so we do not overflow int oldSize = remoteEnts.get_max(); // increase with 50% the capacity remoteEnts.resize( oldSize + oldSize / 2 + 1 ); } remoteEnts.vi_wr[ir++] = procs[k]; // send to proc remoteEnts.vi_wr[ir++] = num_tags; // for the tags [j] (4) remoteEnts.vi_wr[ir++] = gid; // actual value of the tag remoteEnts.vul_wr[jr++] = handles[k]; remoteEnts.inc_n(); } } } } #ifndef NDEBUG if( my_rank == 1 && 1 == get_debug_verbosity() ) remoteEnts.print( " on rank 1, before augment routing" ); MPI_Barrier( procConfig.proc_comm() ); int sentEnts = remoteEnts.get_n(); assert( ( sentEnts == jr ) && ( 3 * sentEnts == ir ) ); #endif // exchange the info now, and send to gs_data::crystal_data* cd = this->procConfig.crystal_router(); // All communication happens here; no other mpi calls // Also, this is a collective call rval = cd->gs_transfer( 1, remoteEnts, 0 );MB_CHK_SET_ERR( rval, "Error in tuple transfer" ); #ifndef NDEBUG if( my_rank == 0 && 1 == get_debug_verbosity() ) remoteEnts.print( " on rank 0, after augment routing" ); MPI_Barrier( procConfig.proc_comm() ); #endif // now process the data received from other processors int received = remoteEnts.get_n(); for( int i = 0; i < received; i++ ) { // int from = ents_to_delete.vi_rd[i]; EntityHandle geh = (EntityHandle)remoteEnts.vul_rd[i]; int from_proc = remoteEnts.vi_rd[3 * i]; if( my_rank == from_proc ) std::cout << " unexpected receive from my rank " << my_rank << " during augmenting with ghosts\n "; int tag_type = remoteEnts.vi_rd[3 * i + 1]; assert( ( 0 <= tag_type ) && ( tag_type <= num_tags ) ); int value = remoteEnts.vi_rd[3 * i + 2]; if( tag_type == num_tags ) { // it is global id rval = mbImpl->tag_set_data( tags[num_tags], &geh, 1, &value );MB_CHK_SET_ERR( rval, "Error in setting gid tag" ); } else { // now, based on value and tag type, see if we have that value in the map MVal& lmap = localMaps[tag_type]; itMVal itm = lmap.find( value ); if( itm == lmap.end() ) { // the value was not found yet in the local map, so we have to create the set EntityHandle newSet; rval = mbImpl->create_meshset( MESHSET_SET, newSet );MB_CHK_SET_ERR( rval, "can't create new set" ); lmap[value] = newSet; // set the tag value rval = mbImpl->tag_set_data( tags[tag_type], &newSet, 1, &value );MB_CHK_SET_ERR( rval, "can't set tag for new set" ); // we also need to add the new created set to the file set, if not null if( file_set ) { rval = mbImpl->add_entities( file_set, &newSet, 1 );MB_CHK_SET_ERR( rval, "can't add new set to the file set" ); } } // add the entity to the set pointed to by the map rval = mbImpl->add_entities( lmap[value], &geh, 1 );MB_CHK_SET_ERR( rval, "can't add ghost ent to the set" ); } } for( int i = 0; i < num_tags; i++ ) delete[] tagVals[i]; delete[] tagVals; delete[] rangeSets; delete[] tags; delete[] localMaps; return MB_SUCCESS; }
ErrorCode moab::ParallelComm::broadcast_entities | ( | const int | from_proc, |
Range & | entities, | ||
const bool | adjacencies = false , |
const bool | tags = true |
from_proc | Processor having the mesh to be broadcast |
entities | On return, the entities sent or received in this call |
adjacencies | If true, adjacencies are sent for equiv entities (currently unsupported) |
tags | If true, all non-default-valued tags are sent for sent entities |
Definition at line 536 of file ParallelComm.cpp.
References add_verts(), moab::ParallelComm::Buffer::buff_ptr, ErrorCode, INITIAL_BUFF_SIZE, moab::MAX_BCAST_SIZE, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, pack_buffer(), moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, moab::ParallelComm::Buffer::reserve(), moab::ParallelComm::Buffer::reset_ptr(), moab::ParallelComm::Buffer::set_stored_size(), and unpack_buffer().
{ #ifndef MOAB_HAVE_MPI return MB_FAILURE; #else ErrorCode result = MB_SUCCESS; int success; int buff_size; Buffer buff( INITIAL_BUFF_SIZE ); buff.reset_ptr( sizeof( int ) ); if( (int)procConfig.proc_rank() == from_proc ) { result = add_verts( entities );MB_CHK_SET_ERR( result, "Failed to add adj vertices" ); buff.reset_ptr( sizeof( int ) ); result = pack_buffer( entities, adjacencies, tags, false, -1, &buff );MB_CHK_SET_ERR( result, "Failed to compute buffer size in broadcast_entities" ); buff.set_stored_size(); buff_size = buff.buff_ptr - buff.mem_ptr; } success = MPI_Bcast( &buff_size, 1, MPI_INT, from_proc, procConfig.proc_comm() ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "MPI_Bcast of buffer size failed" ); } if( !buff_size ) // No data return MB_SUCCESS; if( (int)procConfig.proc_rank() != from_proc ) buff.reserve( buff_size ); size_t offset = 0; while( buff_size ) { int sz = std::min( buff_size, MAX_BCAST_SIZE ); success = MPI_Bcast( buff.mem_ptr + offset, sz, MPI_UNSIGNED_CHAR, from_proc, procConfig.proc_comm() ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "MPI_Bcast of buffer failed" ); } offset += sz; buff_size -= sz; } if( (int)procConfig.proc_rank() != from_proc ) { std::vector< std::vector< EntityHandle > > dum1a, dum1b; std::vector< std::vector< int > > dum1p; std::vector< EntityHandle > dum2, dum4; std::vector< unsigned int > dum3; buff.reset_ptr( sizeof( int ) ); result = unpack_buffer( buff.buff_ptr, false, from_proc, -1, dum1a, dum1b, dum1p, dum2, dum2, dum3, dum4 );MB_CHK_SET_ERR( result, "Failed to unpack buffer in broadcast_entities" ); std::copy( dum4.begin(), dum4.end(), range_inserter( entities ) ); } return MB_SUCCESS; #endif }
const std::vector< unsigned int > & moab::ParallelComm::buff_procs | ( | ) | const [inline] |
Definition at line 1569 of file ParallelComm.hpp.
References buffProcs.
{ return buffProcs; }
ErrorCode moab::ParallelComm::build_sharedhps_list | ( | const EntityHandle | entity, |
const unsigned char | pstatus, | ||
const int | sharedp, | ||
const std::set< unsigned int > & | procs, | ||
unsigned int & | num_ents, | ||
int * | tmp_procs, | ||
EntityHandle * | tmp_handles | ||
) | [private] |
Definition at line 1748 of file ParallelComm.cpp.
References ErrorCode, get_sharing_data(), list_entities(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, moab::ProcConfig::proc_rank(), procConfig, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, and PSTATUS_SHARED.
Referenced by pack_entities().
{ num_ents = 0; unsigned char pstat; ErrorCode result = get_sharing_data( entity, tmp_procs, tmp_handles, pstat, num_ents );MB_CHK_SET_ERR( result, "Failed to get sharing data" ); assert( pstat == pstatus ); // Build shared proc/handle lists // Start with multi-shared, since if it is the owner will be first if( pstatus & PSTATUS_MULTISHARED ) { } else if( pstatus & PSTATUS_NOT_OWNED ) { // If not multishared and not owned, other sharing proc is owner, put that // one first assert( "If not owned, I should be shared too" && pstatus & PSTATUS_SHARED && 1 == num_ents ); tmp_procs[1] = procConfig.proc_rank(); tmp_handles[1] = entity; num_ents = 2; } else if( pstatus & PSTATUS_SHARED ) { // If not multishared and owned, I'm owner assert( "shared and owned, should be only 1 sharing proc" && 1 == num_ents ); tmp_procs[1] = tmp_procs[0]; tmp_procs[0] = procConfig.proc_rank(); tmp_handles[1] = tmp_handles[0]; tmp_handles[0] = entity; num_ents = 2; } else { // Not shared yet, just add owner (me) tmp_procs[0] = procConfig.proc_rank(); tmp_handles[0] = entity; num_ents = 1; } #ifndef NDEBUG int tmp_ps = num_ents; #endif // Now add others, with zero handle for now for( std::set< unsigned int >::iterator sit = procs.begin(); sit != procs.end(); ++sit ) { #ifndef NDEBUG if( tmp_ps && std::find( tmp_procs, tmp_procs + tmp_ps, *sit ) != tmp_procs + tmp_ps ) { std::cerr << "Trouble with something already in shared list on proc " << procConfig.proc_rank() << ". Entity:" << std::endl; list_entities( &entity, 1 ); std::cerr << "pstatus = " << (int)pstatus << ", sharedp = " << sharedp << std::endl; std::cerr << "tmp_ps = "; for( int i = 0; i < tmp_ps; i++ ) std::cerr << tmp_procs[i] << " "; std::cerr << std::endl; std::cerr << "procs = "; for( std::set< unsigned int >::iterator sit2 = procs.begin(); sit2 != procs.end(); ++sit2 ) std::cerr << *sit2 << " "; assert( false ); } #endif tmp_procs[num_ents] = *sit; tmp_handles[num_ents] = 0; num_ents++; } // Put -1 after procs and 0 after handles if( MAX_SHARING_PROCS > num_ents ) { tmp_procs[num_ents] = -1; tmp_handles[num_ents] = 0; } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::check_all_shared_handles | ( | bool | print_em = false | ) |
Definition at line 8541 of file ParallelComm.cpp.
References buffProcs, check_local_shared(), check_my_shared_handles(), ErrorCode, exchange_all_shared_handles(), MB_SUCCESS, mbImpl, pack_shared_handles(), moab::ProcConfig::proc_rank(), procConfig, and moab::Interface::write_mesh().
Referenced by exchange_ghost_cells(), main(), resolve_shared_ents(), moab::ScdInterface::tag_shared_vertices(), and test_intx_in_parallel_elem_based().
{ // Get all shared ent data from other procs std::vector< std::vector< SharedEntityData > > shents( buffProcs.size() ), send_data( buffProcs.size() ); ErrorCode result; bool done = false; while( !done ) { result = check_local_shared(); if( MB_SUCCESS != result ) { done = true; continue; } result = pack_shared_handles( send_data ); if( MB_SUCCESS != result ) { done = true; continue; } result = exchange_all_shared_handles( send_data, shents ); if( MB_SUCCESS != result ) { done = true; continue; } if( !shents.empty() ) result = check_my_shared_handles( shents ); done = true; } if( MB_SUCCESS != result && print_em ) { #ifdef MOAB_HAVE_HDF5 std::ostringstream ent_str; ent_str << "mesh." << procConfig.proc_rank() << ".h5m"; mbImpl->write_mesh( ent_str.str().c_str() ); #endif } return result; }
ErrorCode moab::ParallelComm::check_all_shared_handles | ( | ParallelComm ** | pcs, |
int | num_pcs | ||
) | [static] |
Definition at line 8715 of file ParallelComm.cpp.
References buffProcs, check_my_shared_handles(), ErrorCode, get_buffers(), MB_SUCCESS, and pack_shared_handles().
{ std::vector< std::vector< std::vector< SharedEntityData > > > shents, send_data; ErrorCode result = MB_SUCCESS, tmp_result; // Get all shared ent data from each proc to all other procs send_data.resize( num_pcs ); for( int p = 0; p < num_pcs; p++ ) { tmp_result = pcs[p]->pack_shared_handles( send_data[p] ); if( MB_SUCCESS != tmp_result ) result = tmp_result; } if( MB_SUCCESS != result ) return result; // Move the data sorted by sending proc to data sorted by receiving proc shents.resize( num_pcs ); for( int p = 0; p < num_pcs; p++ ) shents[p].resize( pcs[p]->buffProcs.size() ); for( int p = 0; p < num_pcs; p++ ) { for( unsigned int idx_p = 0; idx_p < pcs[p]->buffProcs.size(); idx_p++ ) { // Move send_data[p][to_p] to shents[to_p][idx_p] int to_p = pcs[p]->buffProcs[idx_p]; int top_idx_p = pcs[to_p]->get_buffers( p ); assert( -1 != top_idx_p ); shents[to_p][top_idx_p] = send_data[p][idx_p]; } } for( int p = 0; p < num_pcs; p++ ) { std::ostringstream ostr; ostr << "Processor " << p << " bad entities:"; tmp_result = pcs[p]->check_my_shared_handles( shents[p], ostr.str().c_str() ); if( MB_SUCCESS != tmp_result ) result = tmp_result; } return result; }
ErrorCode moab::ParallelComm::check_clean_iface | ( | Range & | allsent | ) | [private] |
Definition at line 6256 of file ParallelComm.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), moab::Range::erase(), ErrorCode, moab::Interface::get_number_entities_by_handle(), get_sharing_data(), moab::Range::insert(), interface_sets(), interfaceSets, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, MESHSET_SET, proc_config(), moab::ProcConfig::proc_rank(), procConfig, moab::ProcList::procs, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, pstatus_tag(), moab::Range::rbegin(), moab::Interface::remove_entities(), moab::Range::rend(), set_sharing_data(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), moab::Interface::tag_clear_data(), and moab::Interface::tag_set_data().
Referenced by exchange_ghost_cells().
{ // allsent is all entities I think are on interface; go over them, looking // for zero-valued handles, and fix any I find // Keep lists of entities for which teh sharing data changed, grouped // by set of sharing procs. typedef std::map< ProcList, Range > procmap_t; procmap_t old_procs, new_procs; ErrorCode result = MB_SUCCESS; Range::iterator rit; Range::reverse_iterator rvit; unsigned char pstatus; int nump; ProcList sharedp; EntityHandle sharedh[MAX_SHARING_PROCS]; for( rvit = allsent.rbegin(); rvit != allsent.rend(); ++rvit ) { result = get_sharing_data( *rvit, sharedp.procs, sharedh, pstatus, nump );MB_CHK_SET_ERR( result, "Failed to get sharing data" ); assert( "Should be shared with at least one other proc" && ( nump > 1 || sharedp.procs[0] != (int)procConfig.proc_rank() ) ); assert( nump == MAX_SHARING_PROCS || sharedp.procs[nump] == -1 ); // Look for first null handle in list int idx = std::find( sharedh, sharedh + nump, (EntityHandle)0 ) - sharedh; if( idx == nump ) continue; // All handles are valid ProcList old_list( sharedp ); std::sort( old_list.procs, old_list.procs + nump ); old_procs[old_list].insert( *rvit ); // Remove null handles and corresponding proc ranks from lists int new_nump = idx; bool removed_owner = !idx; for( ++idx; idx < nump; ++idx ) { if( sharedh[idx] ) { sharedh[new_nump] = sharedh[idx]; sharedp.procs[new_nump] = sharedp.procs[idx]; ++new_nump; } } sharedp.procs[new_nump] = -1; if( removed_owner && new_nump > 1 ) { // The proc that we choose as the entity owner isn't sharing the // entity (doesn't have a copy of it). We need to pick a different // owner. Choose the proc with lowest rank. idx = std::min_element( sharedp.procs, sharedp.procs + new_nump ) - sharedp.procs; std::swap( sharedp.procs[0], sharedp.procs[idx] ); std::swap( sharedh[0], sharedh[idx] ); if( sharedp.procs[0] == (int)proc_config().proc_rank() ) pstatus &= ~PSTATUS_NOT_OWNED; } result = set_sharing_data( *rvit, pstatus, nump, new_nump, sharedp.procs, sharedh );MB_CHK_SET_ERR( result, "Failed to set sharing data in check_clean_iface" ); if( new_nump > 1 ) { if( new_nump == 2 ) { if( sharedp.procs[1] != (int)proc_config().proc_rank() ) { assert( sharedp.procs[0] == (int)proc_config().proc_rank() ); sharedp.procs[0] = sharedp.procs[1]; } sharedp.procs[1] = -1; } else { std::sort( sharedp.procs, sharedp.procs + new_nump ); } new_procs[sharedp].insert( *rvit ); } } if( old_procs.empty() ) { assert( new_procs.empty() ); return MB_SUCCESS; } // Update interface sets procmap_t::iterator pmit; // std::vector<unsigned char> pstatus_list; rit = interface_sets().begin(); while( rit != interface_sets().end() ) { result = get_sharing_data( *rit, sharedp.procs, sharedh, pstatus, nump );MB_CHK_SET_ERR( result, "Failed to get sharing data for interface set" ); assert( nump != 2 ); std::sort( sharedp.procs, sharedp.procs + nump ); assert( nump == MAX_SHARING_PROCS || sharedp.procs[nump] == -1 ); pmit = old_procs.find( sharedp ); if( pmit != old_procs.end() ) { result = mbImpl->remove_entities( *rit, pmit->second );MB_CHK_SET_ERR( result, "Failed to remove entities from interface set" ); } pmit = new_procs.find( sharedp ); if( pmit == new_procs.end() ) { int count; result = mbImpl->get_number_entities_by_handle( *rit, count );MB_CHK_SET_ERR( result, "Failed to get number of entities in interface set" ); if( !count ) { result = mbImpl->delete_entities( &*rit, 1 );MB_CHK_SET_ERR( result, "Failed to delete entities from interface set" ); rit = interface_sets().erase( rit ); } else { ++rit; } } else { result = mbImpl->add_entities( *rit, pmit->second );MB_CHK_SET_ERR( result, "Failed to add entities to interface set" ); // Remove those that we've processed so that we know which ones // are new. new_procs.erase( pmit ); ++rit; } } // Create interface sets for new proc id combinations std::fill( sharedh, sharedh + MAX_SHARING_PROCS, 0 ); for( pmit = new_procs.begin(); pmit != new_procs.end(); ++pmit ) { EntityHandle new_set; result = mbImpl->create_meshset( MESHSET_SET, new_set );MB_CHK_SET_ERR( result, "Failed to create interface set" ); interfaceSets.insert( new_set ); // Add entities result = mbImpl->add_entities( new_set, pmit->second );MB_CHK_SET_ERR( result, "Failed to add entities to interface set" ); // Tag set with the proc rank(s) assert( pmit->first.procs[0] >= 0 ); pstatus = PSTATUS_SHARED | PSTATUS_INTERFACE; if( pmit->first.procs[1] == -1 ) { int other = pmit->first.procs[0]; assert( other != (int)procConfig.proc_rank() ); result = mbImpl->tag_set_data( sharedp_tag(), &new_set, 1, pmit->first.procs );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" ); sharedh[0] = 0; result = mbImpl->tag_set_data( sharedh_tag(), &new_set, 1, sharedh );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" ); if( other < (int)proc_config().proc_rank() ) pstatus |= PSTATUS_NOT_OWNED; } else { result = mbImpl->tag_set_data( sharedps_tag(), &new_set, 1, pmit->first.procs );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" ); result = mbImpl->tag_set_data( sharedhs_tag(), &new_set, 1, sharedh );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" ); pstatus |= PSTATUS_MULTISHARED; if( pmit->first.procs[0] < (int)proc_config().proc_rank() ) pstatus |= PSTATUS_NOT_OWNED; } result = mbImpl->tag_set_data( pstatus_tag(), &new_set, 1, &pstatus );MB_CHK_SET_ERR( result, "Failed to tag interface set with pstatus" ); // Set pstatus on all interface entities in set result = mbImpl->tag_clear_data( pstatus_tag(), pmit->second, &pstatus );MB_CHK_SET_ERR( result, "Failed to tag interface entities with pstatus" ); } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::check_global_ids | ( | EntityHandle | this_set, |
check for global ids; based only on tag handle being there or not; if it's not there, create them for the specified dimensions
Definition at line 5532 of file ParallelComm.cpp.
References assign_global_ids(), moab::Range::empty(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, and MBVERTEX.
{ // Global id tag Tag gid_tag = mbImpl->globalId_tag(); int def_val = -1; Range dum_range; void* tag_ptr = &def_val; ErrorCode result = mbImpl->get_entities_by_type_and_tag( this_set, MBVERTEX, &gid_tag, &tag_ptr, 1, dum_range );MB_CHK_SET_ERR( result, "Failed to get entities by MBVERTEX type and gid tag" ); if( !dum_range.empty() ) { // Just created it, so we need global ids result = assign_global_ids( this_set, dimension, start_id, largest_dim_only, parallel, owned_only );MB_CHK_SET_ERR( result, "Failed assigning global ids" ); } return MB_SUCCESS; }
Definition at line 8588 of file ParallelComm.cpp.
References ErrorCode, moab::Interface::get_connectivity(), get_sharing_data(), list_entities(), MAX_SHARING_PROCS, MB_SUCCESS, MBENTITYSET, mbImpl, MBVERTEX, moab::ProcConfig::proc_rank(), procConfig, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, sharedEnts, and moab::Interface::type_from_handle().
Referenced by check_all_shared_handles().
{ // Do some checks on shared entities to make sure things look // consistent // Check that non-vertex shared entities are shared by same procs as all // their vertices // std::pair<Range::const_iterator,Range::const_iterator> vert_it = // sharedEnts.equal_range(MBVERTEX); std::vector< EntityHandle > dum_connect; const EntityHandle* connect; int num_connect; int tmp_procs[MAX_SHARING_PROCS]; EntityHandle tmp_hs[MAX_SHARING_PROCS]; std::set< int > tmp_set, vset; int num_ps; ErrorCode result; unsigned char pstat; std::vector< EntityHandle > bad_ents; std::vector< std::string > errors; std::set< EntityHandle >::iterator vit; for( vit = sharedEnts.begin(); vit != sharedEnts.end(); ++vit ) { // Get sharing procs for this ent result = get_sharing_data( *vit, tmp_procs, tmp_hs, pstat, num_ps ); if( MB_SUCCESS != result ) { bad_ents.push_back( *vit ); errors.push_back( std::string( "Failure getting sharing data." ) ); continue; } bool bad = false; // Entity must be shared if( !( pstat & PSTATUS_SHARED ) ) errors.push_back( std::string( "Entity should be shared but isn't." ) ), bad = true; // If entity is not owned this must not be first proc if( pstat & PSTATUS_NOT_OWNED && tmp_procs[0] == (int)procConfig.proc_rank() ) errors.push_back( std::string( "Entity not owned but is first proc." ) ), bad = true; // If entity is owned and multishared, this must be first proc if( !( pstat & PSTATUS_NOT_OWNED ) && pstat & PSTATUS_MULTISHARED && ( tmp_procs[0] != (int)procConfig.proc_rank() || tmp_hs[0] != *vit ) ) errors.push_back( std::string( "Entity owned and multishared but not first proc or not first handle." ) ), bad = true; if( bad ) { bad_ents.push_back( *vit ); continue; } EntityType type = mbImpl->type_from_handle( *vit ); if( type == MBVERTEX || type == MBENTITYSET ) continue; // Copy element's procs to vset and save size int orig_ps = num_ps; vset.clear(); std::copy( tmp_procs, tmp_procs + num_ps, std::inserter( vset, vset.begin() ) ); // Get vertices for this ent and intersection of sharing procs result = mbImpl->get_connectivity( *vit, connect, num_connect, false, &dum_connect ); if( MB_SUCCESS != result ) { bad_ents.push_back( *vit ); errors.push_back( std::string( "Failed to get connectivity." ) ); continue; } for( int i = 0; i < num_connect; i++ ) { result = get_sharing_data( connect[i], tmp_procs, NULL, pstat, num_ps ); if( MB_SUCCESS != result ) { bad_ents.push_back( *vit ); continue; } if( !num_ps ) { vset.clear(); break; } std::sort( tmp_procs, tmp_procs + num_ps ); tmp_set.clear(); std::set_intersection( tmp_procs, tmp_procs + num_ps, vset.begin(), vset.end(), std::inserter( tmp_set, tmp_set.end() ) ); vset.swap( tmp_set ); if( vset.empty() ) break; } // Intersect them; should be the same size as orig_ps tmp_set.clear(); std::set_intersection( tmp_procs, tmp_procs + num_ps, vset.begin(), vset.end(), std::inserter( tmp_set, tmp_set.end() ) ); if( orig_ps != (int)tmp_set.size() ) { errors.push_back( std::string( "Vertex proc set not same size as entity proc set." ) ); bad_ents.push_back( *vit ); for( int i = 0; i < num_connect; i++ ) { bad_ents.push_back( connect[i] ); errors.push_back( std::string( "vertex in connect" ) ); } } } if( !bad_ents.empty() ) { std::cout << "Found bad entities in check_local_shared, proc rank " << procConfig.proc_rank() << "," << std::endl; std::vector< std::string >::iterator sit; std::vector< EntityHandle >::iterator rit; for( rit = bad_ents.begin(), sit = errors.begin(); rit != bad_ents.end(); ++rit, ++sit ) { list_entities( &( *rit ), 1 ); std::cout << "Reason: " << *sit << std::endl; } return MB_FAILURE; } // To do: check interface sets return MB_SUCCESS; }
ErrorCode moab::ParallelComm::check_my_shared_handles | ( | std::vector< std::vector< SharedEntityData > > & | shents, |
const char * | prefix = NULL |
Definition at line 8757 of file ParallelComm.cpp.
References buffProcs, moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, get_pstatus(), get_remote_handles(), get_shared_entities(), moab::Range::insert(), list_entities(), MB_SUCCESS, MBPOLYHEDRON, moab::Range::merge(), PSTATUS_NOT_OWNED, rank(), sharedEnts, and moab::Range::upper_bound().
{ // Now check against what I think data should be // Get all shared entities ErrorCode result; Range all_shared; std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( all_shared ) ); std::vector< EntityHandle > dum_vec; all_shared.erase( all_shared.upper_bound( MBPOLYHEDRON ), all_shared.end() ); Range bad_ents, local_shared; std::vector< SharedEntityData >::iterator vit; unsigned char tmp_pstat; for( unsigned int i = 0; i < shents.size(); i++ ) { int other_proc = buffProcs[i]; result = get_shared_entities( other_proc, local_shared ); if( MB_SUCCESS != result ) return result; for( vit = shents[i].begin(); vit != shents[i].end(); ++vit ) { EntityHandle localh = vit->local, remoteh = vit->remote, dumh; local_shared.erase( localh ); result = get_remote_handles( true, &localh, &dumh, 1, other_proc, dum_vec ); if( MB_SUCCESS != result || dumh != remoteh ) bad_ents.insert( localh ); result = get_pstatus( localh, tmp_pstat ); if( MB_SUCCESS != result || ( !( tmp_pstat & PSTATUS_NOT_OWNED ) && (unsigned)vit->owner != rank() ) || ( tmp_pstat & PSTATUS_NOT_OWNED && (unsigned)vit->owner == rank() ) ) bad_ents.insert( localh ); } if( !local_shared.empty() ) bad_ents.merge( local_shared ); } if( !bad_ents.empty() ) { if( prefix ) std::cout << prefix << std::endl; list_entities( bad_ents ); return MB_FAILURE; } else return MB_SUCCESS; }
ErrorCode moab::ParallelComm::check_sent_ents | ( | Range & | allsent | ) | [private] |
Definition at line 7323 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Range::insert(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mbImpl, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by exchange_ghost_cells(), and exchange_owned_mesh().
{ // Check entities to make sure there are no zero-valued remote handles // where they shouldn't be std::vector< unsigned char > pstat( allsent.size() ); ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), allsent, &pstat[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" ); std::vector< EntityHandle > handles( allsent.size() ); result = mbImpl->tag_get_data( sharedh_tag(), allsent, &handles[0] );MB_CHK_SET_ERR( result, "Failed to get sharedh tag data" ); std::vector< int > procs( allsent.size() ); result = mbImpl->tag_get_data( sharedp_tag(), allsent, &procs[0] );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" ); Range bad_entities; Range::iterator rit; unsigned int i; EntityHandle dum_hs[MAX_SHARING_PROCS]; int dum_ps[MAX_SHARING_PROCS]; for( rit = allsent.begin(), i = 0; rit != allsent.end(); ++rit, i++ ) { if( -1 != procs[i] && 0 == handles[i] ) bad_entities.insert( *rit ); else { // Might be multi-shared... result = mbImpl->tag_get_data( sharedps_tag(), &( *rit ), 1, dum_ps ); if( MB_TAG_NOT_FOUND == result ) continue; else if( MB_SUCCESS != result ) MB_SET_ERR( result, "Failed to get sharedps tag data" ); result = mbImpl->tag_get_data( sharedhs_tag(), &( *rit ), 1, dum_hs );MB_CHK_SET_ERR( result, "Failed to get sharedhs tag data" ); // Find first non-set proc int* ns_proc = std::find( dum_ps, dum_ps + MAX_SHARING_PROCS, -1 ); int num_procs = ns_proc - dum_ps; assert( num_procs <= MAX_SHARING_PROCS ); // Now look for zero handles in active part of dum_hs EntityHandle* ns_handle = std::find( dum_hs, dum_hs + num_procs, 0 ); int num_handles = ns_handle - dum_hs; assert( num_handles <= num_procs ); if( num_handles != num_procs ) bad_entities.insert( *rit ); } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::clean_shared_tags | ( | std::vector< Range * > & | exchange_ents | ) |
Definition at line 8842 of file ParallelComm.cpp.
References moab::Range::begin(), ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mbImpl, pstatus_tag(), sharedh_tag(), sharedp_tag(), moab::Range::size(), moab::Interface::tag_delete_data(), and moab::Interface::tag_get_data().
{ for( unsigned int i = 0; i < exchange_ents.size(); i++ ) { Range* ents = exchange_ents[i]; int num_ents = ents->size(); Range::iterator it = ents->begin(); for( int n = 0; n < num_ents; n++ ) { int sharing_proc; ErrorCode result = mbImpl->tag_get_data( sharedp_tag(), &( *ents->begin() ), 1, &sharing_proc ); if( result != MB_TAG_NOT_FOUND && sharing_proc == -1 ) { result = mbImpl->tag_delete_data( sharedp_tag(), &( *it ), 1 );MB_CHK_SET_ERR( result, "Failed to delete sharedp tag data" ); result = mbImpl->tag_delete_data( sharedh_tag(), &( *it ), 1 );MB_CHK_SET_ERR( result, "Failed to delete sharedh tag data" ); result = mbImpl->tag_delete_data( pstatus_tag(), &( *it ), 1 );MB_CHK_SET_ERR( result, "Failed to delete pstatus tag data" ); } ++it; } } return MB_SUCCESS; }
Definition at line 8268 of file ParallelComm.cpp.
References globalPartCount, MB_SUCCESS, partition_sets(), proc_config(), and moab::Range::size().
Referenced by iMeshP_loadAll(), and iMeshP_syncPartitionAll().
{ int count = partition_sets().size(); globalPartCount = 0; int err = MPI_Allreduce( &count, &globalPartCount, 1, MPI_INT, MPI_SUM, proc_config().proc_comm() ); return err ? MB_FAILURE : MB_SUCCESS; }
MPI_Comm moab::ParallelComm::comm | ( | ) | const [inline] |
Definition at line 652 of file ParallelComm.hpp.
References moab::ProcConfig::proc_comm(), and proc_config().
Referenced by gather_data(), moab::ParallelMergeMesh::GetGlobalBox(), main(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::ParallelMergeMesh::PerformMerge(), moab::ParCommGraph::receive_comm_graph(), and moab::ParCommGraph::send_graph_partition().
{ return proc_config().proc_comm(); }
Definition at line 9346 of file ParallelComm.cpp.
References buffProcs, ErrorCode, exchange_all_shared_handles(), get_buffers(), get_sharing_data(), moab::ParallelComm::SharedEntityData::local, MAX_SHARING_PROCS, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::ParallelComm::SharedEntityData::owner, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, pstatus_tag(), rank(), moab::ParallelComm::SharedEntityData::remote, sharedEnts, sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), and moab::Interface::tag_set_data().
{ // Get all shared ent data from other procs std::vector< std::vector< SharedEntityData > > shents( buffProcs.size() ), send_data( buffProcs.size() ); // will work only on multi-shared tags sharedps_tag(), sharedhs_tag(); /* * domain0 | domain1 | domain2 | domain3 * vertices from domain 1 and 2 are visible from both 0 and 3, but * domain 0 might not have info about multi-sharing from domain 3 * so we will force that domain 0 vertices owned by 1 and 2 have information * about the domain 3 sharing * * SharedEntityData will have : * struct SharedEntityData { EntityHandle local; // this is same meaning, for the proc we sent to, it is local EntityHandle remote; // this will be the far away handle that will need to be added EntityID owner; // this will be the remote proc }; // so we need to add data like this: a multishared entity owned by proc x will have data like multishared procs: proc x, a, b, c multishared handles: h1, h2, h3, h4 we will need to send data from proc x like this: to proc a we will send (h2, h3, b), (h2, h4, c) to proc b we will send (h3, h2, a), (h3, h4, c) to proc c we will send (h4, h2, a), (h4, h3, b) * */ ErrorCode result = MB_SUCCESS; int ent_procs[MAX_SHARING_PROCS + 1]; EntityHandle handles[MAX_SHARING_PROCS + 1]; int num_sharing; SharedEntityData tmp; for( std::set< EntityHandle >::iterator i = sharedEnts.begin(); i != sharedEnts.end(); ++i ) { unsigned char pstat; result = get_sharing_data( *i, ent_procs, handles, pstat, num_sharing );MB_CHK_SET_ERR( result, "can't get sharing data" ); if( !( pstat & PSTATUS_MULTISHARED ) || num_sharing <= 2 ) // if not multishared, skip, it should have no problems continue; // we should skip the ones that are not owned locally // the owned ones will have the most multi-shared info, because the info comes from other // remote processors if( pstat & PSTATUS_NOT_OWNED ) continue; for( int j = 1; j < num_sharing; j++ ) { // we will send to proc int send_to_proc = ent_procs[j]; // tmp.local = handles[j]; int ind = get_buffers( send_to_proc ); assert( -1 != ind ); // THIS SHOULD NEVER HAPPEN for( int k = 1; k < num_sharing; k++ ) { // do not send to self proc if( j == k ) continue; tmp.remote = handles[k]; // this will be the handle of entity on proc tmp.owner = ent_procs[k]; send_data[ind].push_back( tmp ); } } } result = exchange_all_shared_handles( send_data, shents );MB_CHK_ERR( result ); // loop over all shents and add if vertex type, add if missing for( size_t i = 0; i < shents.size(); i++ ) { std::vector< SharedEntityData >& shEnts = shents[i]; for( size_t j = 0; j < shEnts.size(); j++ ) { tmp = shEnts[j]; // basically, check the shared data for tmp.local entity // it should have inside the tmp.owner and tmp.remote EntityHandle eh = tmp.local; unsigned char pstat; result = get_sharing_data( eh, ent_procs, handles, pstat, num_sharing );MB_CHK_SET_ERR( result, "can't get sharing data" ); // see if the proc tmp.owner is in the list of ent_procs; if not, we have to increase // handles, and ent_procs; and set int proc_remote = tmp.owner; // if( std::find( ent_procs, ent_procs + num_sharing, proc_remote ) == ent_procs + num_sharing ) { // so we did not find on proc #ifndef NDEBUG std::cout << "THIN GHOST: we did not find on proc " << rank() << " for shared ent " << eh << " the proc " << proc_remote << "\n"; #endif // increase num_sharing, and set the multi-shared tags if( num_sharing >= MAX_SHARING_PROCS ) return MB_FAILURE; handles[num_sharing] = tmp.remote; handles[num_sharing + 1] = 0; // end of list ent_procs[num_sharing] = tmp.owner; ent_procs[num_sharing + 1] = -1; // this should be already set result = mbImpl->tag_set_data( sharedps_tag(), &eh, 1, ent_procs );MB_CHK_SET_ERR( result, "Failed to set sharedps tag data" ); result = mbImpl->tag_set_data( sharedhs_tag(), &eh, 1, handles );MB_CHK_SET_ERR( result, "Failed to set sharedhs tag data" ); if( 2 == num_sharing ) // it means the sharedp and sharedh tags were set with a // value non default { // so entity eh was simple shared before, we need to set those dense tags back // to default // values EntityHandle zero = 0; int no_proc = -1; result = mbImpl->tag_set_data( sharedp_tag(), &eh, 1, &no_proc );MB_CHK_SET_ERR( result, "Failed to set sharedp tag data" ); result = mbImpl->tag_set_data( sharedh_tag(), &eh, 1, &zero );MB_CHK_SET_ERR( result, "Failed to set sharedh tag data" ); // also, add multishared pstatus tag // also add multishared status to pstatus pstat = pstat | PSTATUS_MULTISHARED; result = mbImpl->tag_set_data( pstatus_tag(), &eh, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to set pstatus tag data" ); } } } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::create_iface_pc_links | ( | ) | [private] |
Definition at line 5093 of file ParallelComm.cpp.
References moab::Interface::add_parent_child(), moab::Range::begin(), moab::Range::clear(), moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_handle(), interfaceSets, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, mbImpl, moab::Range::rbegin(), moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
{ // Now that we've resolved the entities in the iface sets, // set parent/child links between the iface sets // First tag all entities in the iface sets Tag tmp_iface_tag; EntityHandle tmp_iface_set = 0; ErrorCode result = mbImpl->tag_get_handle( "__tmp_iface", 1, MB_TYPE_HANDLE, tmp_iface_tag, MB_TAG_DENSE | MB_TAG_CREAT, &tmp_iface_set );MB_CHK_SET_ERR( result, "Failed to create temporary interface set tag" ); Range iface_ents; std::vector< EntityHandle > tag_vals; Range::iterator rit; for( rit = interfaceSets.begin(); rit != interfaceSets.end(); ++rit ) { // tag entities with interface set iface_ents.clear(); result = mbImpl->get_entities_by_handle( *rit, iface_ents );MB_CHK_SET_ERR( result, "Failed to get entities in interface set" ); if( iface_ents.empty() ) continue; tag_vals.resize( iface_ents.size() ); std::fill( tag_vals.begin(), tag_vals.end(), *rit ); result = mbImpl->tag_set_data( tmp_iface_tag, iface_ents, &tag_vals[0] );MB_CHK_SET_ERR( result, "Failed to tag iface entities with interface set" ); } // Now go back through interface sets and add parent/child links Range tmp_ents2; for( int d = 2; d >= 0; d-- ) { for( rit = interfaceSets.begin(); rit != interfaceSets.end(); ++rit ) { // Get entities on this interface iface_ents.clear(); result = mbImpl->get_entities_by_handle( *rit, iface_ents, true );MB_CHK_SET_ERR( result, "Failed to get entities by handle" ); if( iface_ents.empty() || mbImpl->dimension_from_handle( *iface_ents.rbegin() ) != d ) continue; // Get higher-dimensional entities and their interface sets result = mbImpl->get_adjacencies( &( *iface_ents.begin() ), 1, d + 1, false, tmp_ents2 );MB_CHK_SET_ERR( result, "Failed to get adjacencies for interface sets" ); tag_vals.resize( tmp_ents2.size() ); result = mbImpl->tag_get_data( tmp_iface_tag, tmp_ents2, &tag_vals[0] );MB_CHK_SET_ERR( result, "Failed to get tmp iface tag for interface sets" ); // Go through and for any on interface make it a parent EntityHandle last_set = 0; for( unsigned int i = 0; i < tag_vals.size(); i++ ) { if( tag_vals[i] && tag_vals[i] != last_set ) { result = mbImpl->add_parent_child( tag_vals[i], *rit );MB_CHK_SET_ERR( result, "Failed to add parent/child link for interface set" ); last_set = tag_vals[i]; } } } } // Delete the temporary tag result = mbImpl->tag_delete( tmp_iface_tag );MB_CHK_SET_ERR( result, "Failed to delete tmp iface tag" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::create_interface_sets | ( | std::map< std::vector< int >, std::vector< EntityHandle > > & | proc_nvecs | ) |
Definition at line 5017 of file ParallelComm.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), moab::CN::EntityTypeName(), ErrorCode, moab::GeomUtil::first(), get_shared_proc_tags(), moab::ID_FROM_HANDLE(), moab::Range::insert(), interfaceSets, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, MBVERTEX, MESHSET_SET, proc_config(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, moab::Interface::tag_set_data(), moab::TYPE_FROM_HANDLE(), and moab::Interface::type_from_handle().
Referenced by create_interface_sets(), exchange_owned_meshs(), resolve_shared_ents(), moab::ScdInterface::tag_shared_vertices(), and moab::ParallelMergeMesh::TagSharedElements().
{ if( proc_nvecs.empty() ) return MB_SUCCESS; int proc_ids[MAX_SHARING_PROCS]; EntityHandle proc_handles[MAX_SHARING_PROCS]; Tag shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag; ErrorCode result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags in create_interface_sets" ); Range::iterator rit; // Create interface sets, tag them, and tag their contents with iface set tag std::vector< unsigned char > pstatus; for( std::map< std::vector< int >, std::vector< EntityHandle > >::iterator vit = proc_nvecs.begin(); vit != proc_nvecs.end(); ++vit ) { // Create the set EntityHandle new_set; result = mbImpl->create_meshset( MESHSET_SET, new_set );MB_CHK_SET_ERR( result, "Failed to create interface set" ); interfaceSets.insert( new_set ); // Add entities assert( !vit->second.empty() ); result = mbImpl->add_entities( new_set, &( vit->second )[0], ( vit->second ).size() );MB_CHK_SET_ERR( result, "Failed to add entities to interface set" ); // Tag set with the proc rank(s) if( vit->first.size() == 1 ) { assert( ( vit->first )[0] != (int)procConfig.proc_rank() ); result = mbImpl->tag_set_data( shp_tag, &new_set, 1, &( vit->first )[0] );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" ); proc_handles[0] = 0; result = mbImpl->tag_set_data( shh_tag, &new_set, 1, proc_handles );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" ); } else { // Pad tag data out to MAX_SHARING_PROCS with -1 if( vit->first.size() > MAX_SHARING_PROCS ) { std::cerr << "Exceeded MAX_SHARING_PROCS for " << CN::EntityTypeName( TYPE_FROM_HANDLE( new_set ) ) << ' ' << ID_FROM_HANDLE( new_set ) << " on process " << proc_config().proc_rank() << std::endl; std::cerr.flush(); MPI_Abort( proc_config().proc_comm(), 66 ); } // assert(vit->first.size() <= MAX_SHARING_PROCS); std::copy( vit->first.begin(), vit->first.end(), proc_ids ); std::fill( proc_ids + vit->first.size(), proc_ids + MAX_SHARING_PROCS, -1 ); result = mbImpl->tag_set_data( shps_tag, &new_set, 1, proc_ids );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" ); unsigned int ind = std::find( proc_ids, proc_ids + vit->first.size(), procConfig.proc_rank() ) - proc_ids; assert( ind < vit->first.size() ); std::fill( proc_handles, proc_handles + MAX_SHARING_PROCS, 0 ); proc_handles[ind] = new_set; result = mbImpl->tag_set_data( shhs_tag, &new_set, 1, proc_handles );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" ); } // Get the owning proc, then set the pstatus tag on iface set int min_proc = ( vit->first )[0]; unsigned char pval = ( PSTATUS_SHARED | PSTATUS_INTERFACE ); if( min_proc < (int)procConfig.proc_rank() ) pval |= PSTATUS_NOT_OWNED; if( vit->first.size() > 1 ) pval |= PSTATUS_MULTISHARED; result = mbImpl->tag_set_data( pstat_tag, &new_set, 1, &pval );MB_CHK_SET_ERR( result, "Failed to tag interface set with pstatus" ); // Tag the vertices with the same thing pstatus.clear(); std::vector< EntityHandle > verts; for( std::vector< EntityHandle >::iterator v2it = ( vit->second ).begin(); v2it != ( vit->second ).end(); ++v2it ) if( mbImpl->type_from_handle( *v2it ) == MBVERTEX ) verts.push_back( *v2it ); pstatus.resize( verts.size(), pval ); if( !verts.empty() ) { result = mbImpl->tag_set_data( pstat_tag, &verts[0], verts.size(), &pstatus[0] );MB_CHK_SET_ERR( result, "Failed to tag interface set vertices with pstatus" ); } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::create_interface_sets | ( | EntityHandle | this_set, |
int | resolve_dim, | ||
int | shared_dim | ||
Definition at line 4981 of file ParallelComm.cpp.
References create_interface_sets(), moab::Interface::dimension_from_handle(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), get_proc_nvecs(), get_sharing_data(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, mbImpl, sharedEnts, and moab::Interface::UNION.
{ std::map< std::vector< int >, std::vector< EntityHandle > > proc_nvecs; // Build up the list of shared entities int procs[MAX_SHARING_PROCS]; EntityHandle handles[MAX_SHARING_PROCS]; ErrorCode result; int nprocs; unsigned char pstat; for( std::set< EntityHandle >::iterator vit = sharedEnts.begin(); vit != sharedEnts.end(); ++vit ) { if( shared_dim != -1 && mbImpl->dimension_from_handle( *vit ) > shared_dim ) continue; result = get_sharing_data( *vit, procs, handles, pstat, nprocs );MB_CHK_SET_ERR( result, "Failed to get sharing data" ); std::sort( procs, procs + nprocs ); std::vector< int > tmp_procs( procs, procs + nprocs ); assert( tmp_procs.size() != 2 ); proc_nvecs[tmp_procs].push_back( *vit ); } Skinner skinner( mbImpl ); Range skin_ents[4]; result = mbImpl->get_entities_by_dimension( this_set, resolve_dim, skin_ents[resolve_dim] );MB_CHK_SET_ERR( result, "Failed to get skin entities by dimension" ); result = skinner.find_skin( this_set, skin_ents[resolve_dim], false, skin_ents[resolve_dim - 1], 0, true, true, true );MB_CHK_SET_ERR( result, "Failed to find skin" ); if( shared_dim > 1 ) { result = mbImpl->get_adjacencies( skin_ents[resolve_dim - 1], resolve_dim - 2, true, skin_ents[resolve_dim - 2], Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get skin adjacencies" ); } result = get_proc_nvecs( resolve_dim, shared_dim, skin_ents, proc_nvecs ); return create_interface_sets( proc_nvecs ); }
ErrorCode moab::ParallelComm::create_part | ( | EntityHandle & | part_out | ) |
Definition at line 8210 of file ParallelComm.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), ErrorCode, get_partitioning(), globalPartCount, moab::Range::index(), moab::Range::insert(), MB_SUCCESS, mbImpl, MESHSET_SET, part_tag(), partition_sets(), proc_config(), moab::ProcConfig::proc_rank(), and moab::Interface::tag_set_data().
Referenced by iMeshP_createPart().
{ // Mark as invalid so we know that it needs to be updated globalPartCount = -1; // Create set representing part ErrorCode rval = mbImpl->create_meshset( MESHSET_SET, set_out ); if( MB_SUCCESS != rval ) return rval; // Set tag on set int val = proc_config().proc_rank(); rval = mbImpl->tag_set_data( part_tag(), &set_out, 1, &val ); if( MB_SUCCESS != rval ) { mbImpl->delete_entities( &set_out, 1 ); return rval; } if( get_partitioning() ) { rval = mbImpl->add_entities( get_partitioning(), &set_out, 1 ); if( MB_SUCCESS != rval ) { mbImpl->delete_entities( &set_out, 1 ); return rval; } } moab::Range& pSets = this->partition_sets(); if( pSets.index( set_out ) < 0 ) { pSets.insert( set_out ); } return MB_SUCCESS; }
void moab::ParallelComm::define_mpe | ( | ) | [private] |
Definition at line 4228 of file ParallelComm.cpp.
References moab::DebugOutput::get_verbosity(), MPE_Describe_state, MPE_LOG_OK, and myDebug.
Referenced by resolve_shared_ents().
{ #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { // Define mpe states used for logging int success; MPE_Log_get_state_eventIDs( &IFACE_START, &IFACE_END ); MPE_Log_get_state_eventIDs( &GHOST_START, &GHOST_END ); MPE_Log_get_state_eventIDs( &SHAREDV_START, &SHAREDV_END ); MPE_Log_get_state_eventIDs( &RESOLVE_START, &RESOLVE_END ); MPE_Log_get_state_eventIDs( &ENTITIES_START, &ENTITIES_END ); MPE_Log_get_state_eventIDs( &RHANDLES_START, &RHANDLES_END ); MPE_Log_get_state_eventIDs( &OWNED_START, &OWNED_END ); success = MPE_Describe_state( IFACE_START, IFACE_END, "Resolve interface ents", "green" ); assert( MPE_LOG_OK == success ); success = MPE_Describe_state( GHOST_START, GHOST_END, "Exchange ghost ents", "red" ); assert( MPE_LOG_OK == success ); success = MPE_Describe_state( SHAREDV_START, SHAREDV_END, "Resolve interface vertices", "blue" ); assert( MPE_LOG_OK == success ); success = MPE_Describe_state( RESOLVE_START, RESOLVE_END, "Resolve shared ents", "purple" ); assert( MPE_LOG_OK == success ); success = MPE_Describe_state( ENTITIES_START, ENTITIES_END, "Exchange shared ents", "yellow" ); assert( MPE_LOG_OK == success ); success = MPE_Describe_state( RHANDLES_START, RHANDLES_END, "Remote handles", "cyan" ); assert( MPE_LOG_OK == success ); success = MPE_Describe_state( OWNED_START, OWNED_END, "Exchange owned ents", "black" ); assert( MPE_LOG_OK == success ); } #endif }
void moab::ParallelComm::delete_all_buffers | ( | ) | [inline, private] |
reset message buffers to their initial state
delete all buffers, freeing up any memory held by them
Definition at line 1557 of file ParallelComm.hpp.
References localOwnedBuffs, and remoteOwnedBuffs.
Referenced by ~ParallelComm().
{ std::vector< Buffer* >::iterator vit; for( vit = localOwnedBuffs.begin(); vit != localOwnedBuffs.end(); ++vit ) delete( *vit ); localOwnedBuffs.clear(); for( vit = remoteOwnedBuffs.begin(); vit != remoteOwnedBuffs.end(); ++vit ) delete( *vit ); remoteOwnedBuffs.clear(); }
ErrorCode moab::ParallelComm::delete_entities | ( | Range & | to_delete | ) |
Definition at line 9258 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ProcConfig::crystal_router(), moab::Interface::delete_entities(), moab::TupleList::enableWriteAccess(), moab::Range::end(), ErrorCode, moab::TupleList::get_n(), get_sharing_data(), moab::TupleList::inc_n(), moab::Range::index(), moab::TupleList::initialize(), moab::Range::insert(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, procConfig, sharedEnts, moab::Range::size(), moab::TupleList::vi_wr, moab::TupleList::vul_rd, and moab::TupleList::vul_wr.
Referenced by moab::NCHelperScrip::create_mesh().
{ // Will not look at shared sets yet, but maybe we should // First, see if any of the entities to delete is shared; then inform the other processors // about their fate (to be deleted), using a crystal router transfer ErrorCode rval = MB_SUCCESS; unsigned char pstat; EntityHandle tmp_handles[MAX_SHARING_PROCS]; int tmp_procs[MAX_SHARING_PROCS]; unsigned int num_ps; TupleList ents_to_delete; ents_to_delete.initialize( 1, 0, 1, 0, to_delete.size() * ( MAX_SHARING_PROCS + 1 ) ); // A little bit of overkill ents_to_delete.enableWriteAccess(); unsigned int i = 0; for( Range::iterator it = to_delete.begin(); it != to_delete.end(); ++it ) { EntityHandle eh = *it; // Entity to be deleted rval = get_sharing_data( eh, tmp_procs, tmp_handles, pstat, num_ps ); if( rval != MB_SUCCESS || num_ps == 0 ) continue; // Add to the tuple list the information to be sent (to the remote procs) for( unsigned int p = 0; p < num_ps; p++ ) { ents_to_delete.vi_wr[i] = tmp_procs[p]; ents_to_delete.vul_wr[i] = (unsigned long)tmp_handles[p]; i++; ents_to_delete.inc_n(); } } gs_data::crystal_data* cd = this->procConfig.crystal_router(); // All communication happens here; no other mpi calls // Also, this is a collective call rval = cd->gs_transfer( 1, ents_to_delete, 0 );MB_CHK_SET_ERR( rval, "Error in tuple transfer" ); // Add to the range of ents to delete the new ones that were sent from other procs unsigned int received = ents_to_delete.get_n(); for( i = 0; i < received; i++ ) { // int from = ents_to_delete.vi_rd[i]; unsigned long valrec = ents_to_delete.vul_rd[i]; to_delete.insert( (EntityHandle)valrec ); } rval = mbImpl->delete_entities( to_delete );MB_CHK_SET_ERR( rval, "Error in deleting actual entities" ); std::set< EntityHandle > good_ents; for( std::set< EntityHandle >::iterator sst = sharedEnts.begin(); sst != sharedEnts.end(); sst++ ) { EntityHandle eh = *sst; int index = to_delete.index( eh ); if( -1 == index ) good_ents.insert( eh ); } sharedEnts = good_ents; // What about shared sets? Who is updating them? return MB_SUCCESS; }
Definition at line 8248 of file ParallelComm.cpp.
References moab::Interface::delete_entities(), moab::Range::erase(), ErrorCode, get_partitioning(), globalPartCount, moab::Range::index(), MB_SUCCESS, mbImpl, partition_sets(), and moab::Interface::remove_entities().
Referenced by iMeshP_destroyPart().
{ // Mark as invalid so we know that it needs to be updated globalPartCount = -1; ErrorCode rval; if( get_partitioning() ) { rval = mbImpl->remove_entities( get_partitioning(), &part_id, 1 ); if( MB_SUCCESS != rval ) return rval; } moab::Range& pSets = this->partition_sets(); if( pSets.index( part_id ) >= 0 ) { pSets.erase( part_id ); } return mbImpl->delete_entities( &part_id, 1 ); }
int moab::ParallelComm::estimate_ents_buffer_size | ( | Range & | entities, |
const bool | store_remote_handles | ||
) | [private] |
estimate size required to pack entities
Definition at line 1503 of file ParallelComm.cpp.
References ErrorCode, moab::Interface::get_connectivity(), moab::Range::lower_bound(), MB_CHK_SET_ERR_RET_VAL, MBEDGE, MBENTITYSET, mbImpl, MBVERTEX, moab::Range::num_of_type(), t, and moab::TYPE_FROM_HANDLE().
{ int buff_size = 0; std::vector< EntityHandle > dum_connect_vec; const EntityHandle* connect; int num_connect; int num_verts = entities.num_of_type( MBVERTEX ); // # verts + coords + handles buff_size += 2 * sizeof( int ) + 3 * sizeof( double ) * num_verts; if( store_remote_handles ) buff_size += sizeof( EntityHandle ) * num_verts; // Do a rough count by looking at first entity of each type for( EntityType t = MBEDGE; t < MBENTITYSET; t++ ) { const Range::iterator rit = entities.lower_bound( t ); if( TYPE_FROM_HANDLE( *rit ) != t ) continue; ErrorCode result = mbImpl->get_connectivity( *rit, connect, num_connect, false, &dum_connect_vec );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get connectivity to estimate buffer size", -1 ); // Number, type, nodes per entity buff_size += 3 * sizeof( int ); int num_ents = entities.num_of_type( t ); // Connectivity, handle for each ent buff_size += ( num_connect + 1 ) * sizeof( EntityHandle ) * num_ents; } // Extra entity type at end, passed as int buff_size += sizeof( int ); return buff_size; }
int moab::ParallelComm::estimate_sets_buffer_size | ( | Range & | entities, |
) | [private] |
estimate size required to pack sets
Definition at line 1536 of file ParallelComm.cpp.
References moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), moab::Interface::get_meshset_options(), moab::Interface::get_number_entities_by_handle(), moab::Range::lower_bound(), MB_CHK_SET_ERR_RET_VAL, MBENTITYSET, mbImpl, MESHSET_SET, moab::Interface::num_child_meshsets(), moab::Interface::num_parent_meshsets(), and moab::RANGE_SIZE().
Referenced by pack_sets().
{ // Number of sets int buff_size = sizeof( int ); // Do a rough count by looking at first entity of each type Range::iterator rit = entities.lower_bound( MBENTITYSET ); ErrorCode result; for( ; rit != entities.end(); ++rit ) { unsigned int options; result = mbImpl->get_meshset_options( *rit, options );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get meshset options", -1 ); buff_size += sizeof( int ); Range set_range; if( options & MESHSET_SET ) { // Range-based set; count the subranges result = mbImpl->get_entities_by_handle( *rit, set_range );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get set entities", -1 ); // Set range buff_size += RANGE_SIZE( set_range ); } else if( options & MESHSET_ORDERED ) { // Just get the number of entities in the set int num_ents; result = mbImpl->get_number_entities_by_handle( *rit, num_ents );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get number entities in ordered set", -1 ); // Set vec buff_size += sizeof( EntityHandle ) * num_ents + sizeof( int ); } // Get numbers of parents/children int num_par, num_ch; result = mbImpl->num_child_meshsets( *rit, &num_ch );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get num children", -1 ); result = mbImpl->num_parent_meshsets( *rit, &num_par );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get num parents", -1 ); buff_size += ( num_ch + num_par ) * sizeof( EntityHandle ) + 2 * sizeof( int ); } return buff_size; }
ErrorCode moab::ParallelComm::exchange_all_shared_handles | ( | std::vector< std::vector< SharedEntityData > > & | send_data, |
std::vector< std::vector< SharedEntityData > > & | result | ||
) | [private] |
Every processor sends shared entity handle data to every other processor that it shares entities with. Passed back map is all received data, indexed by processor ID. This function is intended to be used for debugging.
Definition at line 8474 of file ParallelComm.cpp.
References buffProcs, MB_FILE_WRITE_ERROR, MB_SUCCESS, moab::ProcConfig::proc_comm(), and procConfig.
Referenced by check_all_shared_handles(), and correct_thin_ghost_layers().
{ int ierr; const int tag = 0; const MPI_Comm cm = procConfig.proc_comm(); const int num_proc = buffProcs.size(); const std::vector< int > procs( buffProcs.begin(), buffProcs.end() ); std::vector< MPI_Request > recv_req( buffProcs.size(), MPI_REQUEST_NULL ); std::vector< MPI_Request > send_req( buffProcs.size(), MPI_REQUEST_NULL ); // Set up to receive sizes std::vector< int > sizes_send( num_proc ), sizes_recv( num_proc ); for( int i = 0; i < num_proc; i++ ) { ierr = MPI_Irecv( &sizes_recv[i], 1, MPI_INT, procs[i], tag, cm, &recv_req[i] ); if( ierr ) return MB_FILE_WRITE_ERROR; } // Send sizes assert( num_proc == (int)send_data.size() ); result.resize( num_proc ); for( int i = 0; i < num_proc; i++ ) { sizes_send[i] = send_data[i].size(); ierr = MPI_Isend( &sizes_send[i], 1, MPI_INT, buffProcs[i], tag, cm, &send_req[i] ); if( ierr ) return MB_FILE_WRITE_ERROR; } // Receive sizes std::vector< MPI_Status > stat( num_proc ); ierr = MPI_Waitall( num_proc, &recv_req[0], &stat[0] ); if( ierr ) return MB_FILE_WRITE_ERROR; // Wait until all sizes are sent (clean up pending req's) ierr = MPI_Waitall( num_proc, &send_req[0], &stat[0] ); if( ierr ) return MB_FILE_WRITE_ERROR; // Set up to receive data for( int i = 0; i < num_proc; i++ ) { result[i].resize( sizes_recv[i] ); ierr = MPI_Irecv( (void*)( &( result[i][0] ) ), sizeof( SharedEntityData ) * sizes_recv[i], MPI_UNSIGNED_CHAR, buffProcs[i], tag, cm, &recv_req[i] ); if( ierr ) return MB_FILE_WRITE_ERROR; } // Send data for( int i = 0; i < num_proc; i++ ) { ierr = MPI_Isend( (void*)( &( send_data[i][0] ) ), sizeof( SharedEntityData ) * sizes_send[i], MPI_UNSIGNED_CHAR, buffProcs[i], tag, cm, &send_req[i] ); if( ierr ) return MB_FILE_WRITE_ERROR; } // Receive data ierr = MPI_Waitall( num_proc, &recv_req[0], &stat[0] ); if( ierr ) return MB_FILE_WRITE_ERROR; // Wait until everything is sent to release send buffers ierr = MPI_Waitall( num_proc, &send_req[0], &stat[0] ); if( ierr ) return MB_FILE_WRITE_ERROR; return MB_SUCCESS; }
ErrorCode moab::ParallelComm::exchange_ghost_cells | ( | int | ghost_dim, |
int | bridge_dim, | ||
int | num_layers, | ||
int | addl_ents, | ||
bool | store_remote_handles, | ||
bool | wait_all = true , |
EntityHandle * | file_set = NULL |
Exchange ghost cells with neighboring procs Neighboring processors are those sharing an interface with this processor. All entities of dimension ghost_dim within num_layers of interface, measured going through bridge_dim, are exchanged. See MeshTopoUtil::get_bridge_adjacencies for description of bridge adjacencies. If wait_all is false and store_remote_handles is true, MPI_Request objects are available in the sendReqs[2*MAX_SHARING_PROCS] member array, with inactive requests marked as MPI_REQUEST_NULL. If store_remote_handles or wait_all is false, this function returns after all entities have been received and processed.
ghost_dim | Dimension of ghost entities to be exchanged |
bridge_dim | Dimension of entities used to measure layers from interface |
num_layers | Number of layers of ghosts requested |
addl_ents | Dimension of additional adjacent entities to exchange with ghosts, 0 if none |
store_remote_handles | If true, send message with new entity handles to source processor |
wait_all | If true, function does not return until all send buffers are cleared. |
Definition at line 5687 of file ParallelComm.cpp.
References moab::Interface::add_entities(), buffProcs, check_all_shared_handles(), check_clean_iface(), check_sent_ents(), moab::Range::compactness(), moab::Range::empty(), ErrorCode, get_sent_ents(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SET_ERR, MB_SUCCESS, mbImpl, MPE_Log_event, moab::msgs, myDebug, pack_entities(), pack_remote_handles(), print_buffer(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), remoteOwnedBuffs, moab::TupleList::reset(), reset_all_buffers(), send_buffer(), sendReqs, sharedEnts, moab::Range::size(), size(), tag_iface_entities(), moab::DebugOutput::tprintf(), unpack_entities(), and unpack_remote_handles().
Referenced by moab::NestedRefine::exchange_ghosts(), iMesh_createStructuredMesh(), iMeshP_createGhostEntsAll(), moab::ReadParallel::load_file(), main(), resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
{ #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { if( !num_layers ) MPE_Log_event( IFACE_START, procConfig.proc_rank(), "Starting interface exchange." ); else MPE_Log_event( GHOST_START, procConfig.proc_rank(), "Starting ghost exchange." ); } #endif myDebug->tprintf( 1, "Entering exchange_ghost_cells with num_layers = %d\n", num_layers ); if( myDebug->get_verbosity() == 4 ) { msgs.clear(); msgs.reserve( MAX_SHARING_PROCS ); } // If we're only finding out about existing ents, we have to be storing // remote handles too assert( num_layers > 0 || store_remote_handles ); const bool is_iface = !num_layers; // Get the b-dimensional interface(s) with with_proc, where b = bridge_dim int success; ErrorCode result = MB_SUCCESS; int incoming1 = 0, incoming2 = 0; reset_all_buffers(); // When this function is called, buffProcs should already have any // communicating procs //=========================================== // Post ghost irecv's for ghost entities from all communicating procs //=========================================== #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( ENTITIES_START, procConfig.proc_rank(), "Starting entity exchange." ); } #endif // Index reqs the same as buffer/sharing procs indices std::vector< MPI_Request > recv_ent_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL ), recv_remoteh_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL ); std::vector< unsigned int >::iterator proc_it; int ind, p; sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); for( ind = 0, proc_it = buffProcs.begin(); proc_it != buffProcs.end(); ++proc_it, ind++ ) { incoming1++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[ind], remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_ENTS_SIZE, incoming1 ); success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, buffProcs[ind], MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recv_ent_reqs[3 * ind] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv in ghost exchange" ); } } //=========================================== // Get entities to be sent to neighbors //=========================================== Range sent_ents[MAX_SHARING_PROCS], allsent, tmp_range; TupleList entprocs; int dum_ack_buff; result = get_sent_ents( is_iface, bridge_dim, ghost_dim, num_layers, addl_ents, sent_ents, allsent, entprocs );MB_CHK_SET_ERR( result, "get_sent_ents failed" ); // augment file set with the entities to be sent // we might have created new entities if addl_ents>0, edges and/or faces if( addl_ents > 0 && file_set && !allsent.empty() ) { result = mbImpl->add_entities( *file_set, allsent );MB_CHK_SET_ERR( result, "Failed to add new sub-entities to set" ); } myDebug->tprintf( 1, "allsent ents compactness (size) = %f (%lu)\n", allsent.compactness(), (unsigned long)allsent.size() ); //=========================================== // Pack and send ents from this proc to others //=========================================== for( p = 0, proc_it = buffProcs.begin(); proc_it != buffProcs.end(); ++proc_it, p++ ) { myDebug->tprintf( 1, "Sent ents compactness (size) = %f (%lu)\n", sent_ents[p].compactness(), (unsigned long)sent_ents[p].size() ); // Reserve space on front for size and for initial buff size localOwnedBuffs[p]->reset_buffer( sizeof( int ) ); // Entities result = pack_entities( sent_ents[p], localOwnedBuffs[p], store_remote_handles, buffProcs[p], is_iface, &entprocs, &allsent );MB_CHK_SET_ERR( result, "Packing entities failed" ); if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *localOwnedBuffs[p] ); } // Send the buffer (size stored in front in send_buffer) result = send_buffer( *proc_it, localOwnedBuffs[p], MB_MESG_ENTS_SIZE, sendReqs[3 * p], recv_ent_reqs[3 * p + 2], &dum_ack_buff, incoming1, MB_MESG_REMOTEH_SIZE, ( !is_iface && store_remote_handles ? // this used for ghosting only localOwnedBuffs[p] : NULL ), &recv_remoteh_reqs[3 * p], &incoming2 );MB_CHK_SET_ERR( result, "Failed to Isend in ghost exchange" ); } entprocs.reset(); //=========================================== // Receive/unpack new entities //=========================================== // Number of incoming messages for ghosts is the number of procs we // communicate with; for iface, it's the number of those with lower rank MPI_Status status; std::vector< std::vector< EntityHandle > > recd_ents( buffProcs.size() ); std::vector< std::vector< EntityHandle > > L1hloc( buffProcs.size() ), L1hrem( buffProcs.size() ); std::vector< std::vector< int > > L1p( buffProcs.size() ); std::vector< EntityHandle > L2hloc, L2hrem; std::vector< unsigned int > L2p; std::vector< EntityHandle > new_ents; while( incoming1 ) { // Wait for all recvs of ghost ents before proceeding to sending remote handles, // b/c some procs may have sent to a 3rd proc ents owned by me; PRINT_DEBUG_WAITANY( recv_ent_reqs, MB_MESG_ENTS_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 3 * buffProcs.size(), &recv_ent_reqs[0], &ind, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in ghost exchange" ); } PRINT_DEBUG_RECD( status ); // OK, received something; decrement incoming counter incoming1--; bool done = false; // In case ind is for ack, we need index of one before it unsigned int base_ind = 3 * ( ind / 3 ); result = recv_buffer( MB_MESG_ENTS_SIZE, status, remoteOwnedBuffs[ind / 3], recv_ent_reqs[base_ind + 1], recv_ent_reqs[base_ind + 2], incoming1, localOwnedBuffs[ind / 3], sendReqs[base_ind + 1], sendReqs[base_ind + 2], done, ( !is_iface && store_remote_handles ? localOwnedBuffs[ind / 3] : NULL ), MB_MESG_REMOTEH_SIZE, // maybe base_ind+1? &recv_remoteh_reqs[base_ind + 1], &incoming2 );MB_CHK_SET_ERR( result, "Failed to receive buffer" ); if( done ) { if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *remoteOwnedBuffs[ind / 3] ); } // Message completely received - process buffer that was sent remoteOwnedBuffs[ind / 3]->reset_ptr( sizeof( int ) ); result = unpack_entities( remoteOwnedBuffs[ind / 3]->buff_ptr, store_remote_handles, ind / 3, is_iface, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents ); if( MB_SUCCESS != result ) { std::cout << "Failed to unpack entities. Buffer contents:" << std::endl; print_buffer( remoteOwnedBuffs[ind / 3]->mem_ptr, MB_MESG_ENTS_SIZE, buffProcs[ind / 3], false ); return result; } if( recv_ent_reqs.size() != 3 * buffProcs.size() ) { // Post irecv's for remote handles from new proc; shouldn't be iface, // since we know about all procs we share with assert( !is_iface ); recv_remoteh_reqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); for( unsigned int i = recv_ent_reqs.size(); i < 3 * buffProcs.size(); i += 3 ) { localOwnedBuffs[i / 3]->reset_buffer(); incoming2++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[i / 3], localOwnedBuffs[i / 3]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_REMOTEH_SIZE, incoming2 ); success = MPI_Irecv( localOwnedBuffs[i / 3]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, buffProcs[i / 3], MB_MESG_REMOTEH_SIZE, procConfig.proc_comm(), &recv_remoteh_reqs[i] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv for remote handles in ghost exchange" ); } } recv_ent_reqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); } } } // Add requests for any new addl procs if( recv_ent_reqs.size() != 3 * buffProcs.size() ) { // Shouldn't get here... MB_SET_ERR( MB_FAILURE, "Requests length doesn't match proc count in ghost exchange" ); } #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( ENTITIES_END, procConfig.proc_rank(), "Ending entity exchange." ); } #endif if( is_iface ) { // Need to check over entities I sent and make sure I received // handles for them from all expected procs; if not, need to clean // them up result = check_clean_iface( allsent ); if( MB_SUCCESS != result ) std::cout << "Failed check." << std::endl; // Now set the shared/interface tag on non-vertex entities on interface result = tag_iface_entities();MB_CHK_SET_ERR( result, "Failed to tag iface entities" ); #ifndef NDEBUG result = check_sent_ents( allsent ); if( MB_SUCCESS != result ) std::cout << "Failed check." << std::endl; result = check_all_shared_handles( true ); if( MB_SUCCESS != result ) std::cout << "Failed check." << std::endl; #endif #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( IFACE_END, procConfig.proc_rank(), "Ending interface exchange." ); } #endif //=========================================== // Wait if requested //=========================================== if( wait_all ) { if( myDebug->get_verbosity() == 5 ) { success = MPI_Barrier( procConfig.proc_comm() ); } else { MPI_Status mult_status[3 * MAX_SHARING_PROCS]; success = MPI_Waitall( 3 * buffProcs.size(), &recv_ent_reqs[0], mult_status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitall in ghost exchange" ); } success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], mult_status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitall in ghost exchange" ); } /*success = MPI_Waitall(3*buffProcs.size(), &recv_remoteh_reqs[0], mult_status); if (MPI_SUCCESS != success) { MB_SET_ERR(MB_FAILURE, "Failed in waitall in ghost exchange"); }*/ } } myDebug->tprintf( 1, "Total number of shared entities = %lu.\n", (unsigned long)sharedEnts.size() ); myDebug->tprintf( 1, "Exiting exchange_ghost_cells for is_iface==true \n" ); return MB_SUCCESS; } // we still need to wait on sendReqs, if they are not fulfilled yet if( wait_all ) { if( myDebug->get_verbosity() == 5 ) { success = MPI_Barrier( procConfig.proc_comm() ); } else { MPI_Status mult_status[3 * MAX_SHARING_PROCS]; success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], mult_status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitall in ghost exchange" ); } } } //=========================================== // Send local handles for new ghosts to owner, then add // those to ghost list for that owner //=========================================== for( p = 0, proc_it = buffProcs.begin(); proc_it != buffProcs.end(); ++proc_it, p++ ) { // Reserve space on front for size and for initial buff size remoteOwnedBuffs[p]->reset_buffer( sizeof( int ) ); result = pack_remote_handles( L1hloc[p], L1hrem[p], L1p[p], *proc_it, remoteOwnedBuffs[p] );MB_CHK_SET_ERR( result, "Failed to pack remote handles" ); remoteOwnedBuffs[p]->set_stored_size(); if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *remoteOwnedBuffs[p] ); } result = send_buffer( buffProcs[p], remoteOwnedBuffs[p], MB_MESG_REMOTEH_SIZE, sendReqs[3 * p], recv_remoteh_reqs[3 * p + 2], &dum_ack_buff, incoming2 );MB_CHK_SET_ERR( result, "Failed to send remote handles" ); } //=========================================== // Process remote handles of my ghosteds //=========================================== while( incoming2 ) { PRINT_DEBUG_WAITANY( recv_remoteh_reqs, MB_MESG_REMOTEH_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 3 * buffProcs.size(), &recv_remoteh_reqs[0], &ind, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in ghost exchange" ); } // OK, received something; decrement incoming counter incoming2--; PRINT_DEBUG_RECD( status ); bool done = false; unsigned int base_ind = 3 * ( ind / 3 ); result = recv_buffer( MB_MESG_REMOTEH_SIZE, status, localOwnedBuffs[ind / 3], recv_remoteh_reqs[base_ind + 1], recv_remoteh_reqs[base_ind + 2], incoming2, remoteOwnedBuffs[ind / 3], sendReqs[base_ind + 1], sendReqs[base_ind + 2], done );MB_CHK_SET_ERR( result, "Failed to receive remote handles" ); if( done ) { // Incoming remote handles if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *localOwnedBuffs[ind / 3] ); } localOwnedBuffs[ind / 3]->reset_ptr( sizeof( int ) ); result = unpack_remote_handles( buffProcs[ind / 3], localOwnedBuffs[ind / 3]->buff_ptr, L2hloc, L2hrem, L2p );MB_CHK_SET_ERR( result, "Failed to unpack remote handles" ); } } #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( RHANDLES_END, procConfig.proc_rank(), "Ending remote handles." ); MPE_Log_event( GHOST_END, procConfig.proc_rank(), "Ending ghost exchange (still doing checks)." ); } #endif //=========================================== // Wait if requested //=========================================== if( wait_all ) { if( myDebug->get_verbosity() == 5 ) { success = MPI_Barrier( procConfig.proc_comm() ); } else { MPI_Status mult_status[3 * MAX_SHARING_PROCS]; success = MPI_Waitall( 3 * buffProcs.size(), &recv_remoteh_reqs[0], mult_status ); if( MPI_SUCCESS == success ) success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], mult_status ); } if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitall in ghost exchange" ); } } #ifndef NDEBUG result = check_sent_ents( allsent );MB_CHK_SET_ERR( result, "Failed check on shared entities" ); result = check_all_shared_handles( true );MB_CHK_SET_ERR( result, "Failed check on all shared handles" ); #endif if( file_set && !new_ents.empty() ) { result = mbImpl->add_entities( *file_set, &new_ents[0], new_ents.size() );MB_CHK_SET_ERR( result, "Failed to add new entities to set" ); } myDebug->tprintf( 1, "Total number of shared entities = %lu.\n", (unsigned long)sharedEnts.size() ); myDebug->tprintf( 1, "Exiting exchange_ghost_cells for is_iface==false \n" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::exchange_ghost_cells | ( | ParallelComm ** | pc, |
unsigned int | num_procs, | ||
int | ghost_dim, | ||
EntityHandle * | file_sets = NULL |
) | [static] |
Static version of exchange_ghost_cells, exchanging info through buffers rather than messages.
Definition at line 6588 of file ParallelComm.cpp.
References moab::Interface::add_entities(), buffProcs, check_all_shared_handles(), check_clean_iface(), check_sent_ents(), ErrorCode, get_moab(), get_sent_ents(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, pack_entities(), pack_remote_handles(), moab::Interface::query_interface(), moab::TupleList::reset(), size(), unpack_entities(), and unpack_remote_handles().
{ // Static version of function, exchanging info through buffers rather // than through messages // If we're only finding out about existing ents, we have to be storing // remote handles too assert( num_layers > 0 || store_remote_handles ); const bool is_iface = !num_layers; unsigned int ind; ParallelComm* pc; ErrorCode result = MB_SUCCESS; std::vector< Error* > ehs( num_procs ); for( unsigned int i = 0; i < num_procs; i++ ) { result = pcs[i]->get_moab()->query_interface( ehs[i] ); assert( MB_SUCCESS == result ); } // When this function is called, buffProcs should already have any // communicating procs //=========================================== // Get entities to be sent to neighbors //=========================================== // Done in a separate loop over procs because sometimes later procs // need to add info to earlier procs' messages Range sent_ents[MAX_SHARING_PROCS][MAX_SHARING_PROCS], allsent[MAX_SHARING_PROCS]; //=========================================== // Get entities to be sent to neighbors //=========================================== TupleList entprocs[MAX_SHARING_PROCS]; for( unsigned int p = 0; p < num_procs; p++ ) { pc = pcs[p]; result = pc->get_sent_ents( is_iface, bridge_dim, ghost_dim, num_layers, addl_ents, sent_ents[p], allsent[p], entprocs[p] );MB_CHK_SET_ERR( result, "p = " << p << ", get_sent_ents failed" ); //=========================================== // Pack entities into buffers //=========================================== for( ind = 0; ind < pc->buffProcs.size(); ind++ ) { // Entities pc->localOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); result = pc->pack_entities( sent_ents[p][ind], pc->localOwnedBuffs[ind], store_remote_handles, pc->buffProcs[ind], is_iface, &entprocs[p], &allsent[p] );MB_CHK_SET_ERR( result, "p = " << p << ", packing entities failed" ); } entprocs[p].reset(); } //=========================================== // Receive/unpack new entities //=========================================== // Number of incoming messages for ghosts is the number of procs we // communicate with; for iface, it's the number of those with lower rank std::vector< std::vector< EntityHandle > > L1hloc[MAX_SHARING_PROCS], L1hrem[MAX_SHARING_PROCS]; std::vector< std::vector< int > > L1p[MAX_SHARING_PROCS]; std::vector< EntityHandle > L2hloc[MAX_SHARING_PROCS], L2hrem[MAX_SHARING_PROCS]; std::vector< unsigned int > L2p[MAX_SHARING_PROCS]; std::vector< EntityHandle > new_ents[MAX_SHARING_PROCS]; for( unsigned int p = 0; p < num_procs; p++ ) { L1hloc[p].resize( pcs[p]->buffProcs.size() ); L1hrem[p].resize( pcs[p]->buffProcs.size() ); L1p[p].resize( pcs[p]->buffProcs.size() ); } for( unsigned int p = 0; p < num_procs; p++ ) { pc = pcs[p]; for( ind = 0; ind < pc->buffProcs.size(); ind++ ) { // Incoming ghost entities; unpack; returns entities received // both from sending proc and from owning proc (which may be different) // Buffer could be empty, which means there isn't any message to // unpack (due to this comm proc getting added as a result of indirect // communication); just skip this unpack if( pc->localOwnedBuffs[ind]->get_stored_size() == 0 ) continue; unsigned int to_p = pc->buffProcs[ind]; pc->localOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); result = pcs[to_p]->unpack_entities( pc->localOwnedBuffs[ind]->buff_ptr, store_remote_handles, ind, is_iface, L1hloc[to_p], L1hrem[to_p], L1p[to_p], L2hloc[to_p], L2hrem[to_p], L2p[to_p], new_ents[to_p] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to unpack entities" ); } } if( is_iface ) { // Need to check over entities I sent and make sure I received // handles for them from all expected procs; if not, need to clean // them up for( unsigned int p = 0; p < num_procs; p++ ) { result = pcs[p]->check_clean_iface( allsent[p] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to check on shared entities" ); } #ifndef NDEBUG for( unsigned int p = 0; p < num_procs; p++ ) { result = pcs[p]->check_sent_ents( allsent[p] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to check on shared entities" ); } result = check_all_shared_handles( pcs, num_procs );MB_CHK_SET_ERR( result, "Failed to check on all shared handles" ); #endif return MB_SUCCESS; } //=========================================== // Send local handles for new ghosts to owner, then add // those to ghost list for that owner //=========================================== std::vector< unsigned int >::iterator proc_it; for( unsigned int p = 0; p < num_procs; p++ ) { pc = pcs[p]; for( ind = 0, proc_it = pc->buffProcs.begin(); proc_it != pc->buffProcs.end(); ++proc_it, ind++ ) { // Skip if iface layer and higher-rank proc pc->localOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); result = pc->pack_remote_handles( L1hloc[p][ind], L1hrem[p][ind], L1p[p][ind], *proc_it, pc->localOwnedBuffs[ind] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to pack remote handles" ); } } //=========================================== // Process remote handles of my ghosteds //=========================================== for( unsigned int p = 0; p < num_procs; p++ ) { pc = pcs[p]; for( ind = 0, proc_it = pc->buffProcs.begin(); proc_it != pc->buffProcs.end(); ++proc_it, ind++ ) { // Incoming remote handles unsigned int to_p = pc->buffProcs[ind]; pc->localOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); result = pcs[to_p]->unpack_remote_handles( p, pc->localOwnedBuffs[ind]->buff_ptr, L2hloc[to_p], L2hrem[to_p], L2p[to_p] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to unpack remote handles" ); } } #ifndef NDEBUG for( unsigned int p = 0; p < num_procs; p++ ) { result = pcs[p]->check_sent_ents( allsent[p] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to check on shared entities" ); } result = ParallelComm::check_all_shared_handles( pcs, num_procs );MB_CHK_SET_ERR( result, "Failed to check on all shared handles" ); #endif if( file_sets ) { for( unsigned int p = 0; p < num_procs; p++ ) { if( new_ents[p].empty() ) continue; result = pcs[p]->get_moab()->add_entities( file_sets[p], &new_ents[p][0], new_ents[p].size() );MB_CHK_SET_ERR( result, "p = " << p << ", failed to add new entities to set" ); } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::exchange_owned_mesh | ( | std::vector< unsigned int > & | exchange_procs, |
std::vector< Range * > & | exchange_ents, | ||
std::vector< MPI_Request > & | recv_ent_reqs, | ||
std::vector< MPI_Request > & | recv_remoteh_reqs, | ||
const bool | recv_posted, | ||
bool | wait_all, | ||
bool | migrate = false |
Exchange owned mesh for input mesh entities and sets This function is called twice by exchange_owned_meshs to exchange entities before sets.
migrate | if the owner if entities are changed or not |
Definition at line 6912 of file ParallelComm.cpp.
References add_verts(), assign_entities_part(), buffProcs, check_sent_ents(), moab::Range::compactness(), moab::Range::empty(), moab::TupleList::enableWriteAccess(), ErrorCode, filter_pstatus(), get_buffers(), moab::TupleList::get_n(), moab::DebugOutput::get_verbosity(), moab::TupleList::inc_n(), INITIAL_BUFF_SIZE, moab::TupleList::initialize(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SET_ERR, MB_SUCCESS, moab::Range::merge(), MPE_Log_event, moab::msgs, myDebug, pack_buffer(), pack_remote_handles(), print_buffer(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_SHARED, recv_buffer(), remoteOwnedBuffs, remove_entities_part(), moab::TupleList::buffer::reset(), moab::TupleList::reset(), reset_all_buffers(), send_buffer(), sendReqs, moab::Range::size(), size(), moab::TupleList::sort(), moab::subtract(), moab::DebugOutput::tprintf(), unpack_buffer(), unpack_remote_handles(), moab::TupleList::vi_wr, and moab::TupleList::vul_wr.
Referenced by exchange_owned_meshs().
{ #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( OWNED_START, procConfig.proc_rank(), "Starting owned ents exchange." ); } #endif myDebug->tprintf( 1, "Entering exchange_owned_mesh\n" ); if( myDebug->get_verbosity() == 4 ) { msgs.clear(); msgs.reserve( MAX_SHARING_PROCS ); } unsigned int i; int ind, success; ErrorCode result = MB_SUCCESS; int incoming1 = 0, incoming2 = 0; // Set buffProcs with communicating procs unsigned int n_proc = exchange_procs.size(); for( i = 0; i < n_proc; i++ ) { ind = get_buffers( exchange_procs[i] ); result = add_verts( *exchange_ents[i] );MB_CHK_SET_ERR( result, "Failed to add verts" ); // Filter out entities already shared with destination Range tmp_range; result = filter_pstatus( *exchange_ents[i], PSTATUS_SHARED, PSTATUS_AND, buffProcs[ind], &tmp_range );MB_CHK_SET_ERR( result, "Failed to filter on owner" ); if( !tmp_range.empty() ) { *exchange_ents[i] = subtract( *exchange_ents[i], tmp_range ); } } //=========================================== // Post ghost irecv's for entities from all communicating procs //=========================================== #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( ENTITIES_START, procConfig.proc_rank(), "Starting entity exchange." ); } #endif // Index reqs the same as buffer/sharing procs indices if( !recv_posted ) { reset_all_buffers(); recv_ent_reqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); recv_remoteh_reqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); for( i = 0; i < n_proc; i++ ) { ind = get_buffers( exchange_procs[i] ); incoming1++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[ind], remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_ENTS_SIZE, incoming1 ); success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, buffProcs[ind], MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recv_ent_reqs[3 * ind] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv in owned entity exchange" ); } } } else incoming1 += n_proc; //=========================================== // Get entities to be sent to neighbors // Need to get procs each entity is sent to //=========================================== Range allsent, tmp_range; int dum_ack_buff; int npairs = 0; TupleList entprocs; for( i = 0; i < n_proc; i++ ) { int n_ents = exchange_ents[i]->size(); if( n_ents > 0 ) { npairs += n_ents; // Get the total # of proc/handle pairs allsent.merge( *exchange_ents[i] ); } } // Allocate a TupleList of that size entprocs.initialize( 1, 0, 1, 0, npairs ); entprocs.enableWriteAccess(); // Put the proc/handle pairs in the list for( i = 0; i < n_proc; i++ ) { for( Range::iterator rit = exchange_ents[i]->begin(); rit != exchange_ents[i]->end(); ++rit ) { entprocs.vi_wr[entprocs.get_n()] = exchange_procs[i]; entprocs.vul_wr[entprocs.get_n()] = *rit; entprocs.inc_n(); } } // Sort by handle moab::TupleList::buffer sort_buffer; sort_buffer.buffer_init( npairs ); entprocs.sort( 1, &sort_buffer ); sort_buffer.reset(); myDebug->tprintf( 1, "allsent ents compactness (size) = %f (%lu)\n", allsent.compactness(), (unsigned long)allsent.size() ); //=========================================== // Pack and send ents from this proc to others //=========================================== for( i = 0; i < n_proc; i++ ) { ind = get_buffers( exchange_procs[i] ); myDebug->tprintf( 1, "Sent ents compactness (size) = %f (%lu)\n", exchange_ents[i]->compactness(), (unsigned long)exchange_ents[i]->size() ); // Reserve space on front for size and for initial buff size localOwnedBuffs[ind]->reset_buffer( sizeof( int ) ); result = pack_buffer( *exchange_ents[i], false, true, store_remote_handles, buffProcs[ind], localOwnedBuffs[ind], &entprocs, &allsent ); if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *localOwnedBuffs[ind] ); } // Send the buffer (size stored in front in send_buffer) result = send_buffer( exchange_procs[i], localOwnedBuffs[ind], MB_MESG_ENTS_SIZE, sendReqs[3 * ind], recv_ent_reqs[3 * ind + 2], &dum_ack_buff, incoming1, MB_MESG_REMOTEH_SIZE, ( store_remote_handles ? localOwnedBuffs[ind] : NULL ), &recv_remoteh_reqs[3 * ind], &incoming2 );MB_CHK_SET_ERR( result, "Failed to Isend in ghost exchange" ); } entprocs.reset(); //=========================================== // Receive/unpack new entities //=========================================== // Number of incoming messages is the number of procs we communicate with MPI_Status status; std::vector< std::vector< EntityHandle > > recd_ents( buffProcs.size() ); std::vector< std::vector< EntityHandle > > L1hloc( buffProcs.size() ), L1hrem( buffProcs.size() ); std::vector< std::vector< int > > L1p( buffProcs.size() ); std::vector< EntityHandle > L2hloc, L2hrem; std::vector< unsigned int > L2p; std::vector< EntityHandle > new_ents; while( incoming1 ) { // Wait for all recvs of ents before proceeding to sending remote handles, // b/c some procs may have sent to a 3rd proc ents owned by me; PRINT_DEBUG_WAITANY( recv_ent_reqs, MB_MESG_ENTS_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 3 * buffProcs.size(), &recv_ent_reqs[0], &ind, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in owned entity exchange" ); } PRINT_DEBUG_RECD( status ); // OK, received something; decrement incoming counter incoming1--; bool done = false; // In case ind is for ack, we need index of one before it unsigned int base_ind = 3 * ( ind / 3 ); result = recv_buffer( MB_MESG_ENTS_SIZE, status, remoteOwnedBuffs[ind / 3], recv_ent_reqs[base_ind + 1], recv_ent_reqs[base_ind + 2], incoming1, localOwnedBuffs[ind / 3], sendReqs[base_ind + 1], sendReqs[base_ind + 2], done, ( store_remote_handles ? localOwnedBuffs[ind / 3] : NULL ), MB_MESG_REMOTEH_SIZE, &recv_remoteh_reqs[base_ind + 1], &incoming2 );MB_CHK_SET_ERR( result, "Failed to receive buffer" ); if( done ) { if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *remoteOwnedBuffs[ind / 3] ); } // Message completely received - process buffer that was sent remoteOwnedBuffs[ind / 3]->reset_ptr( sizeof( int ) ); result = unpack_buffer( remoteOwnedBuffs[ind / 3]->buff_ptr, store_remote_handles, buffProcs[ind / 3], ind / 3, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents, true ); if( MB_SUCCESS != result ) { std::cout << "Failed to unpack entities. Buffer contents:" << std::endl; print_buffer( remoteOwnedBuffs[ind / 3]->mem_ptr, MB_MESG_ENTS_SIZE, buffProcs[ind / 3], false ); return result; } if( recv_ent_reqs.size() != 3 * buffProcs.size() ) { // Post irecv's for remote handles from new proc recv_remoteh_reqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); for( i = recv_ent_reqs.size(); i < 3 * buffProcs.size(); i += 3 ) { localOwnedBuffs[i / 3]->reset_buffer(); incoming2++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[i / 3], localOwnedBuffs[i / 3]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_REMOTEH_SIZE, incoming2 ); success = MPI_Irecv( localOwnedBuffs[i / 3]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, buffProcs[i / 3], MB_MESG_REMOTEH_SIZE, procConfig.proc_comm(), &recv_remoteh_reqs[i] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv for remote handles in ghost exchange" ); } } recv_ent_reqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); } } } // Assign and remove newly created elements from/to receive processor result = assign_entities_part( new_ents, procConfig.proc_rank() );MB_CHK_SET_ERR( result, "Failed to assign entities to part" ); if( migrate ) { result = remove_entities_part( allsent, procConfig.proc_rank() );MB_CHK_SET_ERR( result, "Failed to remove entities to part" ); } // Add requests for any new addl procs if( recv_ent_reqs.size() != 3 * buffProcs.size() ) { // Shouldn't get here... MB_SET_ERR( MB_FAILURE, "Requests length doesn't match proc count in entity exchange" ); } #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( ENTITIES_END, procConfig.proc_rank(), "Ending entity exchange." ); } #endif // we still need to wait on sendReqs, if they are not fulfilled yet if( wait_all ) { if( myDebug->get_verbosity() == 5 ) { success = MPI_Barrier( procConfig.proc_comm() ); } else { MPI_Status mult_status[3 * MAX_SHARING_PROCS]; success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], mult_status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitall in exchange owned mesh" ); } } } //=========================================== // Send local handles for new entity to owner //=========================================== for( i = 0; i < n_proc; i++ ) { ind = get_buffers( exchange_procs[i] ); // Reserve space on front for size and for initial buff size remoteOwnedBuffs[ind]->reset_buffer( sizeof( int ) ); result = pack_remote_handles( L1hloc[ind], L1hrem[ind], L1p[ind], buffProcs[ind], remoteOwnedBuffs[ind] );MB_CHK_SET_ERR( result, "Failed to pack remote handles" ); remoteOwnedBuffs[ind]->set_stored_size(); if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *remoteOwnedBuffs[ind] ); } result = send_buffer( buffProcs[ind], remoteOwnedBuffs[ind], MB_MESG_REMOTEH_SIZE, sendReqs[3 * ind], recv_remoteh_reqs[3 * ind + 2], &dum_ack_buff, incoming2 );MB_CHK_SET_ERR( result, "Failed to send remote handles" ); } //=========================================== // Process remote handles of my ghosteds //=========================================== while( incoming2 ) { PRINT_DEBUG_WAITANY( recv_remoteh_reqs, MB_MESG_REMOTEH_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 3 * buffProcs.size(), &recv_remoteh_reqs[0], &ind, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in owned entity exchange" ); } // OK, received something; decrement incoming counter incoming2--; PRINT_DEBUG_RECD( status ); bool done = false; unsigned int base_ind = 3 * ( ind / 3 ); result = recv_buffer( MB_MESG_REMOTEH_SIZE, status, localOwnedBuffs[ind / 3], recv_remoteh_reqs[base_ind + 1], recv_remoteh_reqs[base_ind + 2], incoming2, remoteOwnedBuffs[ind / 3], sendReqs[base_ind + 1], sendReqs[base_ind + 2], done );MB_CHK_SET_ERR( result, "Failed to receive remote handles" ); if( done ) { // Incoming remote handles if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *localOwnedBuffs[ind / 3] ); } localOwnedBuffs[ind / 3]->reset_ptr( sizeof( int ) ); result = unpack_remote_handles( buffProcs[ind / 3], localOwnedBuffs[ind / 3]->buff_ptr, L2hloc, L2hrem, L2p );MB_CHK_SET_ERR( result, "Failed to unpack remote handles" ); } } #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( RHANDLES_END, procConfig.proc_rank(), "Ending remote handles." ); MPE_Log_event( OWNED_END, procConfig.proc_rank(), "Ending ghost exchange (still doing checks)." ); } #endif //=========================================== // Wait if requested //=========================================== if( wait_all ) { if( myDebug->get_verbosity() == 5 ) { success = MPI_Barrier( procConfig.proc_comm() ); } else { MPI_Status mult_status[3 * MAX_SHARING_PROCS]; success = MPI_Waitall( 3 * buffProcs.size(), &recv_remoteh_reqs[0], mult_status ); if( MPI_SUCCESS == success ) success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], mult_status ); } if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitall in owned entity exchange" ); } } #ifndef NDEBUG result = check_sent_ents( allsent );MB_CHK_SET_ERR( result, "Failed check on shared entities" ); #endif myDebug->tprintf( 1, "Exiting exchange_owned_mesh\n" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::exchange_owned_meshs | ( | std::vector< unsigned int > & | exchange_procs, |
bool | migrate = false , |
int | dim = 0 |
Exchange owned mesh for input mesh entities and sets This function should be called collectively over the communicator for this ParallelComm. If this version is called, all shared exchanged entities should have a value for this tag (or the tag should have a default value).
exchange_procs | processor vector exchanged |
exchange_ents | exchanged entities for each processors |
Definition at line 6842 of file ParallelComm.cpp.
References create_interface_sets(), moab::Interface::dimension_from_handle(), ErrorCode, exchange_owned_mesh(), get_sharing_data(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, recvRemotehReqs, recvReqs, sharedEnts, and moab::subtract().
Referenced by iMeshP_exchEntArrToPartsAll().
{ // Filter out entities already shared with destination // Exchange twice for entities and sets ErrorCode result; std::vector< unsigned int > exchange_procs_sets; std::vector< Range* > exchange_sets; int n_proc = exchange_procs.size(); for( int i = 0; i < n_proc; i++ ) { Range set_range = exchange_ents[i]->subset_by_type( MBENTITYSET ); *exchange_ents[i] = subtract( *exchange_ents[i], set_range ); Range* tmp_range = new Range( set_range ); exchange_sets.push_back( tmp_range ); exchange_procs_sets.push_back( exchange_procs[i] ); } if( dim == 2 ) { // Exchange entities first result = exchange_owned_mesh( exchange_procs, exchange_ents, recvReqs, recvRemotehReqs, true, store_remote_handles, wait_all, migrate );MB_CHK_SET_ERR( result, "Failed to exchange owned mesh entities" ); // Exchange sets result = exchange_owned_mesh( exchange_procs_sets, exchange_sets, recvReqs, recvRemotehReqs, false, store_remote_handles, wait_all, migrate ); } else { // Exchange entities first result = exchange_owned_mesh( exchange_procs, exchange_ents, recv_ent_reqs, recv_remoteh_reqs, false, store_remote_handles, wait_all, migrate );MB_CHK_SET_ERR( result, "Failed to exchange owned mesh entities" ); // Exchange sets result = exchange_owned_mesh( exchange_procs_sets, exchange_sets, recv_ent_reqs, recv_remoteh_reqs, false, store_remote_handles, wait_all, migrate );MB_CHK_SET_ERR( result, "Failed to exchange owned mesh sets" ); } for( int i = 0; i < n_proc; i++ ) delete exchange_sets[i]; // Build up the list of shared entities std::map< std::vector< int >, std::vector< EntityHandle > > proc_nvecs; int procs[MAX_SHARING_PROCS]; EntityHandle handles[MAX_SHARING_PROCS]; int nprocs; unsigned char pstat; for( std::set< EntityHandle >::iterator vit = sharedEnts.begin(); vit != sharedEnts.end(); ++vit ) { if( mbImpl->dimension_from_handle( *vit ) > 2 ) continue; result = get_sharing_data( *vit, procs, handles, pstat, nprocs );MB_CHK_SET_ERR( result, "Failed to get sharing data in exchange_owned_meshs" ); std::sort( procs, procs + nprocs ); std::vector< int > tmp_procs( procs, procs + nprocs ); assert( tmp_procs.size() != 2 ); proc_nvecs[tmp_procs].push_back( *vit ); } // Create interface sets from shared entities result = create_interface_sets( proc_nvecs );MB_CHK_SET_ERR( result, "Failed to create interface sets" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::exchange_tags | ( | const std::vector< Tag > & | src_tags, |
const std::vector< Tag > & | dst_tags, | ||
const Range & | entities | ||
Exchange tags for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If this version is called, all ghosted/shared entities should have a value for this tag (or the tag should have a default value). If the entities vector is empty, all shared entities participate in the exchange. If a proc has no owned entities this function must still be called since it is collective.
src_tags | Vector of tag handles to be exchanged |
dst_tags | Tag handles to store the tags on the non-owning procs |
entities | Entities for which tags are exchanged |
Definition at line 7526 of file ParallelComm.cpp.
References buffProcs, moab::Range::empty(), entities, ErrorCode, filter_pstatus(), get_comm_procs(), moab::Interface::get_entities_by_type_and_tag(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, moab::Interface::INTERSECT, moab::intersect(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_TAGS_SIZE, MB_SET_ERR, MB_SUCCESS, mbImpl, MBMAXTYPE, myDebug, pack_tags(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_NOT, PSTATUS_NOT_OWNED, PSTATUS_SHARED, recv_buffer(), remoteOwnedBuffs, reset_all_buffers(), send_buffer(), sendReqs, sharedEnts, moab::Range::size(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_default_value(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), and unpack_tags().
Referenced by assign_global_ids(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::NestedRefine::exchange_ghosts(), exchange_tags(), iMeshP_pushTags(), iMeshP_pushTagsEnt(), iMOAB_SynchronizeTags(), main(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), and moab::LloydSmoother::perform_smooth().
{ ErrorCode result; int success; myDebug->tprintf( 1, "Entering exchange_tags\n" ); // Get all procs interfacing to this proc std::set< unsigned int > exch_procs; result = get_comm_procs( exch_procs ); // Post ghost irecv's for all interface procs // Index requests the same as buffer/sharing procs indices std::vector< MPI_Request > recv_tag_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL ); // sent_ack_reqs(buffProcs.size(), MPI_REQUEST_NULL); std::vector< unsigned int >::iterator sit; int ind; reset_all_buffers(); int incoming = 0; for( ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); ++sit, ind++ ) { incoming++; PRINT_DEBUG_IRECV( *sit, procConfig.proc_rank(), remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_TAGS_SIZE, incoming ); success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, *sit, MB_MESG_TAGS_SIZE, procConfig.proc_comm(), &recv_tag_reqs[3 * ind] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv in ghost exchange" ); } } // Pack and send tags from this proc to others // Make sendReqs vector to simplify initialization sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); // Take all shared entities if incoming list is empty Range entities; if( entities_in.empty() ) std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( entities ) ); else entities = entities_in; int dum_ack_buff; for( ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); ++sit, ind++ ) { Range tag_ents = entities; // Get ents shared by proc *sit result = filter_pstatus( tag_ents, PSTATUS_SHARED, PSTATUS_AND, *sit );MB_CHK_SET_ERR( result, "Failed pstatus AND check" ); // Remote nonowned entities if( !tag_ents.empty() ) { result = filter_pstatus( tag_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( result, "Failed pstatus NOT check" ); } // Pack-send; this also posts receives if store_remote_handles is true std::vector< Range > tag_ranges; for( std::vector< Tag >::const_iterator vit = src_tags.begin(); vit != src_tags.end(); ++vit ) { const void* ptr; int sz; if( mbImpl->tag_get_default_value( *vit, ptr, sz ) != MB_SUCCESS ) { Range tagged_ents; mbImpl->get_entities_by_type_and_tag( 0, MBMAXTYPE, &*vit, 0, 1, tagged_ents ); tag_ranges.push_back( intersect( tag_ents, tagged_ents ) ); } else { tag_ranges.push_back( tag_ents ); } } // Pack the data // Reserve space on front for size and for initial buff size localOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); result = pack_tags( tag_ents, src_tags, dst_tags, tag_ranges, localOwnedBuffs[ind], true, *sit );MB_CHK_SET_ERR( result, "Failed to count buffer in pack_send_tag" ); // Now send it result = send_buffer( *sit, localOwnedBuffs[ind], MB_MESG_TAGS_SIZE, sendReqs[3 * ind], recv_tag_reqs[3 * ind + 2], &dum_ack_buff, incoming );MB_CHK_SET_ERR( result, "Failed to send buffer" ); } // Receive/unpack tags while( incoming ) { MPI_Status status; int index_in_recv_requests; PRINT_DEBUG_WAITANY( recv_tag_reqs, MB_MESG_TAGS_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 3 * buffProcs.size(), &recv_tag_reqs[0], &index_in_recv_requests, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in tag exchange" ); } // Processor index in the list is divided by 3 ind = index_in_recv_requests / 3; PRINT_DEBUG_RECD( status ); // OK, received something; decrement incoming counter incoming--; bool done = false; std::vector< EntityHandle > dum_vec; result = recv_buffer( MB_MESG_TAGS_SIZE, status, remoteOwnedBuffs[ind], recv_tag_reqs[3 * ind + 1], // This is for receiving the second message recv_tag_reqs[3 * ind + 2], // This would be for ack, but it is not // used; consider removing it incoming, localOwnedBuffs[ind], sendReqs[3 * ind + 1], // Send request for sending the second message sendReqs[3 * ind + 2], // This is for sending the ack done );MB_CHK_SET_ERR( result, "Failed to resize recv buffer" ); if( done ) { remoteOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); result = unpack_tags( remoteOwnedBuffs[ind]->buff_ptr, dum_vec, true, buffProcs[ind] );MB_CHK_SET_ERR( result, "Failed to recv-unpack-tag message" ); } } // OK, now wait if( myDebug->get_verbosity() == 5 ) { success = MPI_Barrier( procConfig.proc_comm() ); } else { MPI_Status status[3 * MAX_SHARING_PROCS]; success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], status ); } if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failure in waitall in tag exchange" ); } // If source tag is not equal to destination tag, then // do local copy for owned entities (communicate w/ self) assert( src_tags.size() == dst_tags.size() ); if( src_tags != dst_tags ) { std::vector< unsigned char > data; Range owned_ents; if( entities_in.empty() ) std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( entities ) ); else owned_ents = entities_in; result = filter_pstatus( owned_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( result, "Failure to get subset of owned entities" ); if( !owned_ents.empty() ) { // Check this here, otherwise we get // Unexpected results from get_entities_by_type_and_tag w/ Interface::INTERSECT for( size_t i = 0; i < src_tags.size(); i++ ) { if( src_tags[i] == dst_tags[i] ) continue; Range tagged_ents( owned_ents ); result = mbImpl->get_entities_by_type_and_tag( 0, MBMAXTYPE, &src_tags[0], 0, 1, tagged_ents, Interface::INTERSECT );MB_CHK_SET_ERR( result, "get_entities_by_type_and_tag(type == MBMAXTYPE) failed" ); int sz, size2; result = mbImpl->tag_get_bytes( src_tags[i], sz );MB_CHK_SET_ERR( result, "tag_get_size failed" ); result = mbImpl->tag_get_bytes( dst_tags[i], size2 );MB_CHK_SET_ERR( result, "tag_get_size failed" ); if( sz != size2 ) { MB_SET_ERR( MB_FAILURE, "tag sizes don't match" ); } data.resize( sz * tagged_ents.size() ); result = mbImpl->tag_get_data( src_tags[i], tagged_ents, &data[0] );MB_CHK_SET_ERR( result, "tag_get_data failed" ); result = mbImpl->tag_set_data( dst_tags[i], tagged_ents, &data[0] );MB_CHK_SET_ERR( result, "tag_set_data failed" ); } } } myDebug->tprintf( 1, "Exiting exchange_tags" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::exchange_tags | ( | const char * | tag_name, |
) | [inline] |
Exchange tags for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If the entities vector is empty, all shared entities participate in the exchange. If a proc has no owned entities this function must still be called since it is collective.
tag_name | Name of tag to be exchanged |
Definition at line 1589 of file ParallelComm.hpp.
References ErrorCode, exchange_tags(), MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_OPAQUE, mbImpl, and moab::Interface::tag_get_handle().
{ // get the tag handle std::vector< Tag > tags( 1 ); ErrorCode result = mbImpl->tag_get_handle( tag_name, 0, MB_TYPE_OPAQUE, tags[0], MB_TAG_ANY ); if( MB_SUCCESS != result ) return result; else if( !tags[0] ) return MB_TAG_NOT_FOUND; return exchange_tags( tags, tags, entities ); }
ErrorCode moab::ParallelComm::exchange_tags | ( | Tag | tagh, |
) | [inline] |
tagh | Handle of tag to be exchanged |
Definition at line 1602 of file ParallelComm.hpp.
References exchange_tags().
{ // get the tag handle std::vector< Tag > tags; tags.push_back( tagh ); return exchange_tags( tags, tags, entities ); }
ErrorCode moab::ParallelComm::filter_pstatus | ( | Range & | ents, |
const unsigned char | pstatus_val, | ||
const unsigned char | op, | ||
int | to_proc = -1 , |
Range * | returned_ents = NULL |
Filter the entities by pstatus tag. op is one of PSTATUS_ AND, OR, NOT; an entity is output if: AND: all bits set in pstatus_val are also set on entity OR: any bits set in pstatus_val also set on entity NOT: any bits set in pstatus_val are not set on entity
Results returned in input list, unless result_ents is passed in non-null, in which case results are returned in result_ents.
If ents is passed in empty, filter is done on shared entities in this pcomm instance, i.e. contents of sharedEnts.
ents | Input entities to filter |
pstatus_val | pstatus value to which entities are compared |
op | Bitwise operation performed between pstatus values |
to_proc | If non-negative and PSTATUS_SHARED is set on pstatus_val, only entities shared with to_proc are returned |
result_ents | If non-null, results of filter are put in the pointed-to range |
Definition at line 5577 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Range::insert(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, PSTATUS_AND, PSTATUS_MULTISHARED, PSTATUS_NOT, PSTATUS_OR, PSTATUS_SHARED, pstatus_tag(), sharedp_tag(), sharedps_tag(), moab::Range::size(), moab::Range::swap(), and moab::Interface::tag_get_data().
Referenced by moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), create_fine_mesh(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::WriteHDF5Parallel::exchange_file_ids(), exchange_owned_mesh(), exchange_tags(), moab::WriteHDF5Parallel::gather_interface_meshes(), get_ghosted_entities(), get_max_volume(), get_sent_ents(), get_shared_entities(), hcFilter(), iMOAB_UpdateMeshInfo(), moab::HiReconstruction::initialize(), moab::HalfFacetRep::initialize(), moab::LloydSmoother::initialize(), laplacianFilter(), moab::ReadParallel::load_file(), main(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), reduce_tags(), resolve_shared_sets(), send_entities(), and settle_intersection_points().
{ Range tmp_ents; // assert(!ents.empty()); if( ents.empty() ) { if( returned_ents ) returned_ents->clear(); return MB_SUCCESS; } // Put into tmp_ents any entities which are not owned locally or // who are already shared with to_proc std::vector< unsigned char > shared_flags( ents.size() ), shared_flags2; ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), ents, &shared_flags[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus flag" ); Range::const_iterator rit, hint = tmp_ents.begin(); ; int i; if( op == PSTATUS_OR ) { for( rit = ents.begin(), i = 0; rit != ents.end(); ++rit, i++ ) { if( ( ( shared_flags[i] & ~pstat ) ^ shared_flags[i] ) & pstat ) { hint = tmp_ents.insert( hint, *rit ); if( -1 != to_proc ) shared_flags2.push_back( shared_flags[i] ); } } } else if( op == PSTATUS_AND ) { for( rit = ents.begin(), i = 0; rit != ents.end(); ++rit, i++ ) { if( ( shared_flags[i] & pstat ) == pstat ) { hint = tmp_ents.insert( hint, *rit ); if( -1 != to_proc ) shared_flags2.push_back( shared_flags[i] ); } } } else if( op == PSTATUS_NOT ) { for( rit = ents.begin(), i = 0; rit != ents.end(); ++rit, i++ ) { if( !( shared_flags[i] & pstat ) ) { hint = tmp_ents.insert( hint, *rit ); if( -1 != to_proc ) shared_flags2.push_back( shared_flags[i] ); } } } else { assert( false ); return MB_FAILURE; } if( -1 != to_proc ) { int sharing_procs[MAX_SHARING_PROCS]; std::fill( sharing_procs, sharing_procs + MAX_SHARING_PROCS, -1 ); Range tmp_ents2; hint = tmp_ents2.begin(); for( rit = tmp_ents.begin(), i = 0; rit != tmp_ents.end(); ++rit, i++ ) { // We need to check sharing procs if( shared_flags2[i] & PSTATUS_MULTISHARED ) { result = mbImpl->tag_get_data( sharedps_tag(), &( *rit ), 1, sharing_procs );MB_CHK_SET_ERR( result, "Failed to get sharedps tag" ); assert( -1 != sharing_procs[0] ); for( unsigned int j = 0; j < MAX_SHARING_PROCS; j++ ) { // If to_proc shares this entity, add it to list if( sharing_procs[j] == to_proc ) { hint = tmp_ents2.insert( hint, *rit ); } else if( -1 == sharing_procs[j] ) break; sharing_procs[j] = -1; } } else if( shared_flags2[i] & PSTATUS_SHARED ) { result = mbImpl->tag_get_data( sharedp_tag(), &( *rit ), 1, sharing_procs );MB_CHK_SET_ERR( result, "Failed to get sharedp tag" ); assert( -1 != sharing_procs[0] ); if( sharing_procs[0] == to_proc ) hint = tmp_ents2.insert( hint, *rit ); sharing_procs[0] = -1; } else assert( "should never get here" && false ); } tmp_ents.swap( tmp_ents2 ); } if( returned_ents ) returned_ents->swap( tmp_ents ); else ents.swap( tmp_ents ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::find_existing_entity | ( | const bool | is_iface, |
const int | owner_p, | ||
const EntityHandle | owner_h, | ||
const int | num_ents, | ||
const EntityHandle * | connect, | ||
const int | num_connect, | ||
const EntityType | this_type, | ||
std::vector< EntityHandle > & | L2hloc, | ||
std::vector< EntityHandle > & | L2hrem, | ||
std::vector< unsigned int > & | L2p, | ||
EntityHandle & | new_h | ||
) | [private] |
given connectivity and type, find an existing entity, if there is one
Definition at line 3047 of file ParallelComm.cpp.
References moab::Range::begin(), moab::CN::Dimension(), moab::Range::empty(), ErrorCode, moab::Interface::get_adjacencies(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, and MBVERTEX.
Referenced by unpack_entities(), and unpack_remote_handles().
{ new_h = 0; if( !is_iface && num_ps > 2 ) { for( unsigned int i = 0; i < L2hrem.size(); i++ ) { if( L2hrem[i] == owner_h && owner_p == (int)L2p[i] ) { new_h = L2hloc[i]; return MB_SUCCESS; } } } // If we got here and it's a vertex, we don't need to look further if( MBVERTEX == this_type || !connect || !num_connect ) return MB_SUCCESS; Range tmp_range; ErrorCode result = mbImpl->get_adjacencies( connect, num_connect, CN::Dimension( this_type ), false, tmp_range );MB_CHK_SET_ERR( result, "Failed to get existing entity" ); if( !tmp_range.empty() ) { // Found a corresponding entity - return target new_h = *tmp_range.begin(); } else { new_h = 0; } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::gather_data | ( | Range & | gather_ents, |
Tag & | tag_handle, | ||
Tag | id_tag = 0 , |
EntityHandle | gather_set = 0 , |
int | root_proc_rank = 0 |
Definition at line 8914 of file ParallelComm.cpp.
References moab::Range::begin(), comm(), dim, moab::Interface::dimension_from_handle(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_size(), moab::Range::psize(), rank(), moab::Range::size(), size(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), and moab::Interface::tag_iterate().
{ int dim = mbImpl->dimension_from_handle( *gather_ents.begin() ); int bytes_per_tag = 0; ErrorCode rval = mbImpl->tag_get_bytes( tag_handle, bytes_per_tag ); if( rval != MB_SUCCESS ) return rval; int sz_buffer = sizeof( int ) + gather_ents.size() * ( sizeof( int ) + bytes_per_tag ); void* senddata = malloc( sz_buffer ); ( (int*)senddata )[0] = (int)gather_ents.size(); int* ptr_int = (int*)senddata + 1; rval = mbImpl->tag_get_data( id_tag, gather_ents, (void*)ptr_int ); if( rval != MB_SUCCESS ) return rval; ptr_int = (int*)( senddata ) + 1 + gather_ents.size(); rval = mbImpl->tag_get_data( tag_handle, gather_ents, (void*)ptr_int ); if( rval != MB_SUCCESS ) return rval; std::vector< int > displs( proc_config().proc_size(), 0 ); MPI_Gather( &sz_buffer, 1, MPI_INT, &displs[0], 1, MPI_INT, root_proc_rank, comm() ); std::vector< int > recvcnts( proc_config().proc_size(), 0 ); std::copy( displs.begin(), displs.end(), recvcnts.begin() ); std::partial_sum( displs.begin(), displs.end(), displs.begin() ); std::vector< int >::iterator lastM1 = displs.end() - 1; std::copy_backward( displs.begin(), lastM1, displs.end() ); // std::copy_backward(displs.begin(), --displs.end(), displs.end()); displs[0] = 0; if( (int)rank() != root_proc_rank ) MPI_Gatherv( senddata, sz_buffer, MPI_BYTE, NULL, NULL, NULL, MPI_BYTE, root_proc_rank, comm() ); else { Range gents; mbImpl->get_entities_by_dimension( gather_set, dim, gents ); int recvbuffsz = gents.size() * ( bytes_per_tag + sizeof( int ) ) + proc_config().proc_size() * sizeof( int ); void* recvbuf = malloc( recvbuffsz ); MPI_Gatherv( senddata, sz_buffer, MPI_BYTE, recvbuf, &recvcnts[0], &displs[0], MPI_BYTE, root_proc_rank, comm() ); void* gvals = NULL; // Test whether gents has multiple sequences bool multiple_sequences = false; if( gents.psize() > 1 ) multiple_sequences = true; else { int count; rval = mbImpl->tag_iterate( tag_handle, gents.begin(), gents.end(), count, gvals ); assert( NULL != gvals ); assert( count > 0 ); if( (size_t)count != gents.size() ) { multiple_sequences = true; gvals = NULL; } } // If gents has multiple sequences, create a temp buffer for gathered values if( multiple_sequences ) { gvals = malloc( gents.size() * bytes_per_tag ); assert( NULL != gvals ); } for( int i = 0; i != (int)size(); i++ ) { int numents = *(int*)( ( (char*)recvbuf ) + displs[i] ); int* id_ptr = (int*)( ( (char*)recvbuf ) + displs[i] + sizeof( int ) ); char* val_ptr = (char*)( id_ptr + numents ); for( int j = 0; j != numents; j++ ) { int idx = id_ptr[j]; memcpy( (char*)gvals + ( idx - 1 ) * bytes_per_tag, val_ptr + j * bytes_per_tag, bytes_per_tag ); } } // Free the receive buffer free( recvbuf ); // If gents has multiple sequences, copy tag data (stored in the temp buffer) to each // sequence separately if( multiple_sequences ) { Range::iterator iter = gents.begin(); size_t start_idx = 0; while( iter != gents.end() ) { int count; void* ptr; rval = mbImpl->tag_iterate( tag_handle, iter, gents.end(), count, ptr ); assert( NULL != ptr ); assert( count > 0 ); memcpy( (char*)ptr, (char*)gvals + start_idx * bytes_per_tag, bytes_per_tag * count ); iter += count; start_idx += count; } assert( start_idx == gents.size() ); // Free the temp buffer free( gvals ); } } // Free the send data free( senddata ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_all_pcomm | ( | Interface * | impl, |
std::vector< ParallelComm * > & | list | ||
) | [static] |
Definition at line 8023 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_NOT_FOUND, pcomm_tag(), and moab::Interface::tag_get_data().
Referenced by moab::Core::deinitialize(), iMeshP_getNumPartitions(), and iMeshP_getPartitions().
{ Tag pc_tag = pcomm_tag( impl, false ); if( 0 == pc_tag ) return MB_TAG_NOT_FOUND; const EntityHandle root = 0; ParallelComm* pc_array[MAX_SHARING_PROCS]; ErrorCode rval = impl->tag_get_data( pc_tag, &root, 1, pc_array ); if( MB_SUCCESS != rval ) return rval; for( int i = 0; i < MAX_SHARING_PROCS; i++ ) { if( pc_array[i] ) list.push_back( pc_array[i] ); } return MB_SUCCESS; }
int moab::ParallelComm::get_buffers | ( | int | to_proc, |
bool * | is_new = NULL |
get (and possibly allocate) buffers for messages to/from to_proc; returns index of to_proc in buffProcs vector; if is_new is non-NULL, sets to whether new buffer was allocated PUBLIC ONLY FOR TESTING!
Definition at line 514 of file ParallelComm.cpp.
References buffProcs, INITIAL_BUFF_SIZE, localOwnedBuffs, MAX_SHARING_PROCS, moab::ProcConfig::proc_rank(), procConfig, and remoteOwnedBuffs.
Referenced by check_all_shared_handles(), correct_thin_ghost_layers(), exchange_owned_mesh(), get_interface_procs(), pack_shared_handles(), post_irecv(), recv_entities(), recv_messages(), recv_remote_handle_messages(), send_entities(), send_recv_entities(), moab::ScdInterface::tag_shared_vertices(), and unpack_entities().
{ int ind = -1; std::vector< unsigned int >::iterator vit = std::find( buffProcs.begin(), buffProcs.end(), to_proc ); if( vit == buffProcs.end() ) { assert( "shouldn't need buffer to myself" && to_proc != (int)procConfig.proc_rank() ); ind = buffProcs.size(); buffProcs.push_back( (unsigned int)to_proc ); localOwnedBuffs.push_back( new Buffer( INITIAL_BUFF_SIZE ) ); remoteOwnedBuffs.push_back( new Buffer( INITIAL_BUFF_SIZE ) ); if( is_new ) *is_new = true; } else { ind = vit - buffProcs.begin(); if( is_new ) *is_new = false; } assert( ind < MAX_SHARING_PROCS ); return ind; }
ErrorCode moab::ParallelComm::get_comm_procs | ( | std::set< unsigned int > & | procs | ) | [inline] |
get processors with which this processor communicates
Definition at line 1633 of file ParallelComm.hpp.
References buffProcs, ErrorCode, get_interface_procs(), and MB_SUCCESS.
Referenced by exchange_tags(), reduce_tags(), and settle_intersection_points().
{ ErrorCode result = get_interface_procs( procs ); if( MB_SUCCESS != result ) return result; std::copy( buffProcs.begin(), buffProcs.end(), std::inserter( procs, procs.begin() ) ); return MB_SUCCESS; }
get the verbosity level of output from this pcomm
Definition at line 8872 of file ParallelComm.cpp.
References moab::DebugOutput::get_verbosity(), and myDebug.
Referenced by augment_default_sets_with_ghosts(), moab::ScdInterface::construct_box(), and moab::ScdInterface::tag_shared_vertices().
{ return myDebug->get_verbosity(); }
ErrorCode moab::ParallelComm::get_entityset_local_handle | ( | unsigned | owning_rank, |
EntityHandle | remote_handle, | ||
EntityHandle & | local_handle | ||
) | const |
Given set owner and handle on owner, find local set handle.
Definition at line 8892 of file ParallelComm.cpp.
References moab::SharedSetData::get_local_handle(), and sharedSetData.
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_ids().
{ return sharedSetData->get_local_handle( owning_rank, remote_handle, local_handle ); }
ErrorCode moab::ParallelComm::get_entityset_owner | ( | EntityHandle | entity_set, |
unsigned & | owner_rank, | ||
EntityHandle * | remote_handle = 0 |
) | const |
Get rank of the owner of a shared set. Returns this proc if set is not shared. Optionally returns handle on owning process for shared set.
Definition at line 8882 of file ParallelComm.cpp.
References moab::SharedSetData::get_owner(), and sharedSetData.
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), and moab::WriteHDF5Parallel::print_set_sharing_data().
{ if( remote_handle ) return sharedSetData->get_owner( entity_set, owner_rank, *remote_handle ); else return sharedSetData->get_owner( entity_set, owner_rank ); }
ErrorCode moab::ParallelComm::get_entityset_owners | ( | std::vector< unsigned > & | ranks | ) | const |
Get ranks of all processes that own at least one set that is shared with this process. Will include the rank of this process if this process owns any shared set.
Definition at line 8904 of file ParallelComm.cpp.
References moab::SharedSetData::get_owning_procs(), and sharedSetData.
{ return sharedSetData->get_owning_procs( ranks ); }
ErrorCode moab::ParallelComm::get_entityset_procs | ( | EntityHandle | entity_set, |
std::vector< unsigned > & | ranks | ||
) | const |
Get array of process IDs sharing a set. Returns zero and passes back NULL if set is not shared.
Definition at line 8877 of file ParallelComm.cpp.
References moab::SharedSetData::get_sharing_procs(), and sharedSetData.
{ return sharedSetData->get_sharing_procs( set, ranks ); }
ErrorCode moab::ParallelComm::get_ghosted_entities | ( | int | bridge_dim, |
int | to_proc, | ||
int | num_layers, | ||
int | addl_ents, | ||
Range & | ghosted_ents | ||
) | [private] |
for specified bridge/ghost dimension, to_proc, and number of layers, get the entities to be ghosted, and info on additional procs needing to communicate with to_proc
Definition at line 7437 of file ParallelComm.cpp.
References add_verts(), moab::Range::begin(), moab::Range::empty(), moab::Range::end(), ErrorCode, filter_pstatus(), moab::Interface::get_adjacencies(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), interfaceSets, is_iface_proc(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::Range::merge(), PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Range::subset_by_dimension(), and moab::Interface::UNION.
Referenced by get_sent_ents().
{ // Get bridge ents on interface(s) Range from_ents; ErrorCode result = MB_SUCCESS; assert( 0 < num_layers ); for( Range::iterator rit = interfaceSets.begin(); rit != interfaceSets.end(); ++rit ) { if( !is_iface_proc( *rit, to_proc ) ) continue; // Get starting "from" entities if( bridge_dim == -1 ) { result = mbImpl->get_entities_by_handle( *rit, from_ents );MB_CHK_SET_ERR( result, "Failed to get bridge ents in the set" ); } else { result = mbImpl->get_entities_by_dimension( *rit, bridge_dim, from_ents );MB_CHK_SET_ERR( result, "Failed to get bridge ents in the set" ); } // Need to get layers of bridge-adj entities if( from_ents.empty() ) continue; result = MeshTopoUtil( mbImpl ).get_bridge_adjacencies( from_ents, bridge_dim, ghost_dim, ghosted_ents, num_layers );MB_CHK_SET_ERR( result, "Failed to get bridge adjacencies" ); } result = add_verts( ghosted_ents );MB_CHK_SET_ERR( result, "Failed to add verts" ); if( addl_ents ) { // First get the ents of ghost_dim Range tmp_ents, tmp_owned, tmp_notowned; tmp_owned = ghosted_ents.subset_by_dimension( ghost_dim ); if( tmp_owned.empty() ) return result; tmp_notowned = tmp_owned; // Next, filter by pstatus; can only create adj entities for entities I own result = filter_pstatus( tmp_owned, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &tmp_owned );MB_CHK_SET_ERR( result, "Failed to filter owned entities" ); tmp_notowned -= tmp_owned; // Get edges first if( 1 == addl_ents || 3 == addl_ents ) { result = mbImpl->get_adjacencies( tmp_owned, 1, true, tmp_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get edge adjacencies for owned ghost entities" ); result = mbImpl->get_adjacencies( tmp_notowned, 1, false, tmp_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get edge adjacencies for notowned ghost entities" ); } if( 2 == addl_ents || 3 == addl_ents ) { result = mbImpl->get_adjacencies( tmp_owned, 2, true, tmp_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get face adjacencies for owned ghost entities" ); result = mbImpl->get_adjacencies( tmp_notowned, 2, false, tmp_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get face adjacencies for notowned ghost entities" ); } ghosted_ents.merge( tmp_ents ); } return result; }
ErrorCode moab::ParallelComm::get_global_part_count | ( | int & | count_out | ) | const |
Definition at line 8182 of file ParallelComm.cpp.
References globalPartCount, and MB_SUCCESS.
Referenced by iMeshP_getNumGlobalParts().
{ count_out = globalPartCount; return count_out < 0 ? MB_FAILURE : MB_SUCCESS; }
int moab::ParallelComm::get_id | ( | ) | const [inline] |
Get ID used to reference this PCOMM instance.
Definition at line 70 of file ParallelComm.hpp.
References pcommID.
Referenced by iMeshP_createPartitionAll(), iMeshP_loadAll(), iMOAB_RegisterApplication(), and DeformMeshRemap::read_file().
{ return pcommID; }
ErrorCode moab::ParallelComm::get_iface_entities | ( | int | other_proc, |
int | dim, | ||
Range & | iface_ents | ||
Get entities on interfaces shared with another proc.
other_proc | Other proc sharing the interface |
dim | Dimension of entities to return, -1 if all dims |
iface_ents | Returned entities |
Definition at line 7275 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), interfaceSets, is_iface_proc(), MB_CHK_SET_ERR, MB_SUCCESS, and mbImpl.
{ Range iface_sets; ErrorCode result = MB_SUCCESS; for( Range::iterator rit = interfaceSets.begin(); rit != interfaceSets.end(); ++rit ) { if( -1 != other_proc && !is_iface_proc( *rit, other_proc ) ) continue; if( -1 == dim ) { result = mbImpl->get_entities_by_handle( *rit, iface_ents );MB_CHK_SET_ERR( result, "Failed to get entities in iface set" ); } else { result = mbImpl->get_entities_by_dimension( *rit, dim, iface_ents );MB_CHK_SET_ERR( result, "Failed to get entities in iface set" ); } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_interface_procs | ( | std::set< unsigned int > & | iface_procs, |
const bool | get_buffs = false |
get processors with which this processor shares an interface
Get processors with which this processor communicates; sets are sorted by processor.
Definition at line 5440 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, get_buffers(), interfaceSets, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::ProcConfig::proc_rank(), procConfig, sharedp_tag(), sharedps_tag(), moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by get_comm_procs(), resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
{ // Make sure the sharing procs vector is empty procs_set.clear(); // Pre-load vector of single-proc tag values unsigned int i, j; std::vector< int > iface_proc( interfaceSets.size() ); ErrorCode result = mbImpl->tag_get_data( sharedp_tag(), interfaceSets, &iface_proc[0] );MB_CHK_SET_ERR( result, "Failed to get iface_proc for iface sets" ); // Get sharing procs either from single-proc vector or by getting // multi-proc tag value int tmp_iface_procs[MAX_SHARING_PROCS]; std::fill( tmp_iface_procs, tmp_iface_procs + MAX_SHARING_PROCS, -1 ); Range::iterator rit; for( rit = interfaceSets.begin(), i = 0; rit != interfaceSets.end(); ++rit, i++ ) { if( -1 != iface_proc[i] ) { assert( iface_proc[i] != (int)procConfig.proc_rank() ); procs_set.insert( (unsigned int)iface_proc[i] ); } else { // Get the sharing_procs tag result = mbImpl->tag_get_data( sharedps_tag(), &( *rit ), 1, tmp_iface_procs );MB_CHK_SET_ERR( result, "Failed to get iface_procs for iface set" ); for( j = 0; j < MAX_SHARING_PROCS; j++ ) { if( -1 != tmp_iface_procs[j] && tmp_iface_procs[j] != (int)procConfig.proc_rank() ) procs_set.insert( (unsigned int)tmp_iface_procs[j] ); else if( -1 == tmp_iface_procs[j] ) { std::fill( tmp_iface_procs, tmp_iface_procs + j, -1 ); break; } } } } if( get_buffs ) { for( std::set< unsigned int >::iterator sit = procs_set.begin(); sit != procs_set.end(); ++sit ) get_buffers( *sit ); } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_interface_sets | ( | EntityHandle | part, |
Range & | iface_sets_out, | ||
int * | adj_part_id = 0 |
Definition at line 8310 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), moab::Range::erase(), ErrorCode, get_sharing_data(), interface_sets(), MAX_SHARING_PROCS, and MB_SUCCESS.
Referenced by get_boundary_entities(), and get_part_neighbor_ids().
{ // FIXME : assumes one part per processor. // Need to store part iface sets as children to implement // this correctly. iface_sets_out = interface_sets(); if( adj_part_id ) { int part_ids[MAX_SHARING_PROCS], num_parts; Range::iterator i = iface_sets_out.begin(); while( i != iface_sets_out.end() ) { unsigned char pstat; ErrorCode rval = get_sharing_data( *i, part_ids, NULL, pstat, num_parts ); if( MB_SUCCESS != rval ) return rval; if( std::find( part_ids, part_ids + num_parts, *adj_part_id ) - part_ids != num_parts ) ++i; else i = iface_sets_out.erase( i ); } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_local_handles | ( | EntityHandle * | from_vec, |
const Range & | new_ents | ||
) | [private] |
goes through from_vec, and for any with type MBMAXTYPE, replaces with new_ents value at index corresponding to id of entity in from_vec
Definition at line 3102 of file ParallelComm.cpp.
References moab::Range::begin(), and moab::Range::end().
Referenced by get_local_handles(), unpack_entities(), unpack_sets(), and unpack_tags().
{ std::vector< EntityHandle > tmp_ents; std::copy( new_ents.begin(), new_ents.end(), std::back_inserter( tmp_ents ) ); return get_local_handles( from_vec, num_ents, tmp_ents ); }
ErrorCode moab::ParallelComm::get_local_handles | ( | const Range & | remote_handles, |
Range & | local_handles, | ||
const std::vector< EntityHandle > & | new_ents | ||
) | [private] |
same as above except puts results in range
Definition at line 3090 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, get_local_handles(), and moab::Range::size().
{ std::vector< EntityHandle > rh_vec; rh_vec.reserve( remote_handles.size() ); std::copy( remote_handles.begin(), remote_handles.end(), std::back_inserter( rh_vec ) ); ErrorCode result = get_local_handles( &rh_vec[0], remote_handles.size(), new_ents ); std::copy( rh_vec.begin(), rh_vec.end(), range_inserter( local_handles ) ); return result; }
) | [private] |
same as above except gets new_ents from vector
Definition at line 3109 of file ParallelComm.cpp.
References moab::ID_FROM_HANDLE(), MB_SUCCESS, MBMAXTYPE, and moab::TYPE_FROM_HANDLE().
{ for( int i = 0; i < num_ents; i++ ) { if( TYPE_FROM_HANDLE( from_vec[i] ) == MBMAXTYPE ) { assert( ID_FROM_HANDLE( from_vec[i] ) < (int)new_ents.size() ); from_vec[i] = new_ents[ID_FROM_HANDLE( from_vec[i] )]; } } return MB_SUCCESS; }
Interface* moab::ParallelComm::get_moab | ( | ) | const [inline] |
Definition at line 779 of file ParallelComm.hpp.
References mbImpl.
Referenced by moab::ParCommGraph::compute_partition(), count_owned(), exchange_ghost_cells(), get_boundary_entities(), moab::ParallelMergeMesh::ParallelMergeMesh(), moab::ParCommGraph::receive_mesh(), moab::ParCommGraph::receive_tag_values(), resolve_shared_ents(), moab::ParCommGraph::send_mesh_parts(), and moab::ParCommGraph::send_tag_values().
{ return mbImpl; }
ErrorCode moab::ParallelComm::get_owned_sets | ( | unsigned | owning_rank, |
Range & | sets_out | ||
) | const |
Get shared sets owned by process with specified rank.
Definition at line 8909 of file ParallelComm.cpp.
References moab::SharedSetData::get_shared_sets(), and sharedSetData.
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_ids(), and moab::WriteHDF5Parallel::create_meshset_tables().
{ return sharedSetData->get_shared_sets( owning_rank, sets_out ); }
ErrorCode moab::ParallelComm::get_owner | ( | EntityHandle | entity, |
int & | owner | ||
) | [inline] |
Return the rank of the entity owner.
Definition at line 1643 of file ParallelComm.hpp.
References get_owner_handle().
Referenced by moab::WriteHDF5Parallel::exchange_file_ids(), iMeshP_isEntOwnerArr(), iMOAB_GetElementOwnership(), iMOAB_GetVertexOwnership(), iMOAB_GetVisibleElementsInfo(), and pack_shared_handles().
{ EntityHandle tmp_handle; return get_owner_handle( entity, owner, tmp_handle ); }
ErrorCode moab::ParallelComm::get_owner_handle | ( | EntityHandle | entity, |
int & | owner, | ||
EntityHandle & | handle | ||
Return the owner processor and handle of a given entity.
Definition at line 8147 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), and moab::Interface::tag_get_data().
Referenced by get_owner().
{ unsigned char pstat; int sharing_procs[MAX_SHARING_PROCS]; EntityHandle sharing_handles[MAX_SHARING_PROCS]; ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), &entity, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" ); if( !( pstat & PSTATUS_NOT_OWNED ) ) { owner = proc_config().proc_rank(); handle = entity; } else if( pstat & PSTATUS_MULTISHARED ) { result = mbImpl->tag_get_data( sharedps_tag(), &entity, 1, sharing_procs );MB_CHK_SET_ERR( result, "Failed to get sharedps tag data" ); owner = sharing_procs[0]; result = mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, sharing_handles );MB_CHK_SET_ERR( result, "Failed to get sharedhs tag data" ); handle = sharing_handles[0]; } else if( pstat & PSTATUS_SHARED ) { result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, sharing_procs );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" ); owner = sharing_procs[0]; result = mbImpl->tag_get_data( sharedh_tag(), &entity, 1, sharing_handles );MB_CHK_SET_ERR( result, "Failed to get sharedh tag data" ); handle = sharing_handles[0]; } else { owner = -1; handle = 0; } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_owning_part | ( | EntityHandle | entity, |
int & | owning_part_id_out, | ||
EntityHandle * | owning_handle = 0 |
Definition at line 8337 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), PSTATUS_NOT_OWNED, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), moab::Interface::tag_get_by_ptr(), and moab::Interface::tag_get_data().
Referenced by iMeshP_getEntOwnerPartArr(), and iMeshP_getOwnerCopy().
{ // FIXME : assumes one part per proc, and therefore part_id == rank // If entity is not shared, then we're the owner. unsigned char pstat; ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), &handle, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" ); if( !( pstat & PSTATUS_NOT_OWNED ) ) { owning_part_id = proc_config().proc_rank(); if( remote_handle ) *remote_handle = handle; return MB_SUCCESS; } // If entity is shared with one other proc, then // sharedp_tag will contain a positive value. result = mbImpl->tag_get_data( sharedp_tag(), &handle, 1, &owning_part_id );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" ); if( owning_part_id != -1 ) { // Done? if( !remote_handle ) return MB_SUCCESS; // Get handles on remote processors (and this one) return mbImpl->tag_get_data( sharedh_tag(), &handle, 1, remote_handle ); } // If here, then the entity is shared with at least two other processors. // Get the list from the sharedps_tag const void* part_id_list = 0; result = mbImpl->tag_get_by_ptr( sharedps_tag(), &handle, 1, &part_id_list ); if( MB_SUCCESS != result ) return result; owning_part_id = ( (const int*)part_id_list )[0]; // Done? if( !remote_handle ) return MB_SUCCESS; // Get remote handles const void* handle_list = 0; result = mbImpl->tag_get_by_ptr( sharedhs_tag(), &handle, 1, &handle_list ); if( MB_SUCCESS != result ) return result; *remote_handle = ( (const EntityHandle*)handle_list )[0]; return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_part_entities | ( | Range & | ents, |
int | dim = -1 |
return all the entities in parts owned locally
Definition at line 8126 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), MB_SUCCESS, mbImpl, moab::Range::merge(), and partitionSets.
Referenced by moab::Coupler::initialize_tree(), and main().
{ ErrorCode result; for( Range::iterator rit = partitionSets.begin(); rit != partitionSets.end(); ++rit ) { Range tmp_ents; if( -1 == dim ) result = mbImpl->get_entities_by_handle( *rit, tmp_ents, true ); else result = mbImpl->get_entities_by_dimension( *rit, dim, tmp_ents, true ); if( MB_SUCCESS != result ) return result; ents.merge( tmp_ents ); } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_part_handle | ( | int | id, |
EntityHandle & | handle_out | ||
) | const |
Definition at line 8202 of file ParallelComm.cpp.
References moab::Range::front(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, partition_sets(), and proc_config().
Referenced by assign_entities_part(), iMeshP_getPartHandlesFromPartsIdsArr(), and remove_entities_part().
{ // FIXME: assumes only 1 local part if( (unsigned)id != proc_config().proc_rank() ) return MB_ENTITY_NOT_FOUND; handle_out = partition_sets().front(); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_part_id | ( | EntityHandle | part, |
int & | id_out | ||
) | const |
Definition at line 8195 of file ParallelComm.cpp.
References MB_SUCCESS, proc_config(), and moab::ProcConfig::proc_rank().
Referenced by get_part_neighbor_ids(), iMeshP_getPartIdsFromPartHandlesArr(), and iMeshP_isEntOwnerArr().
{ // FIXME: assumes only 1 local part id_out = proc_config().proc_rank(); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_part_neighbor_ids | ( | EntityHandle | part, |
int | neighbors_out[MAX_SHARING_PROCS], | ||
int & | num_neighbors_out | ||
Definition at line 8276 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, get_interface_sets(), get_part_id(), get_sharing_data(), iface, MAX_SHARING_PROCS, and MB_SUCCESS.
Referenced by iMeshP_getNumPartNborsArr(), and iMeshP_getPartNborsArr().
{ ErrorCode rval; Range iface; rval = get_interface_sets( part, iface ); if( MB_SUCCESS != rval ) return rval; num_neighbors_out = 0; int n, j = 0; int tmp[MAX_SHARING_PROCS] = { 0 }, curr[MAX_SHARING_PROCS] = { 0 }; int* parts[2] = { neighbors_out, tmp }; for( Range::iterator i = iface.begin(); i != iface.end(); ++i ) { unsigned char pstat; rval = get_sharing_data( *i, curr, NULL, pstat, n ); if( MB_SUCCESS != rval ) return rval; std::sort( curr, curr + n ); assert( num_neighbors_out < MAX_SHARING_PROCS ); int* k = std::set_union( parts[j], parts[j] + num_neighbors_out, curr, curr + n, parts[1 - j] ); j = 1 - j; num_neighbors_out = k - parts[j]; } if( parts[j] != neighbors_out ) std::copy( parts[j], parts[j] + num_neighbors_out, neighbors_out ); // Remove input part from list int id; rval = get_part_id( part, id ); if( MB_SUCCESS == rval ) num_neighbors_out = std::remove( neighbors_out, neighbors_out + num_neighbors_out, id ) - neighbors_out; return rval; }
ErrorCode moab::ParallelComm::get_part_owner | ( | int | part_id, |
int & | owner_out | ||
) | const |
Definition at line 8188 of file ParallelComm.cpp.
References MB_SUCCESS.
Referenced by iMeshP_exchEntArrToPartsAll(), and iMeshP_getRankOfPartArr().
{ // FIXME: assumes only 1 local part owner = part_id; return MB_SUCCESS; }
EntityHandle moab::ParallelComm::get_partitioning | ( | ) | const [inline] |
Definition at line 725 of file ParallelComm.hpp.
References partitioningSet.
Referenced by create_part(), and destroy_part().
{ return partitioningSet; }
ParallelComm * moab::ParallelComm::get_pcomm | ( | Interface * | impl, |
const int | index | ||
) | [static] |
get the indexed pcomm object from the interface
Definition at line 8010 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, pcomm_tag(), and moab::Interface::tag_get_data().
Referenced by moab::ScdInterface::construct_box(), get_max_volume(), get_pcomm(), moab::HiReconstruction::HiReconstruction(), iMeshP_assignGlobalIds(), iMeshP_createPartitionAll(), iMeshP_getPartsArrOnRank(), iMeshP_getPartsOnRank(), iMeshP_loadAll(), intersection_at_level(), moab::Core::load_file(), main(), moab::MeshGeneration::MeshGeneration(), moab::MeshRefiner::MeshRefiner(), moab::NestedRefine::NestedRefine(), moab::WriteHDF5Parallel::parallel_create_file(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::ReadParallel::ReadParallel(), moab::RefinerTagManager::RefinerTagManager(), moab::ReadHDF5::set_up_read(), and test_intx_in_parallel_elem_based().
{ Tag pc_tag = pcomm_tag( impl, false ); if( 0 == pc_tag ) return NULL; const EntityHandle root = 0; ParallelComm* pc_array[MAX_SHARING_PROCS]; ErrorCode result = impl->tag_get_data( pc_tag, &root, 1, (void*)pc_array ); if( MB_SUCCESS != result ) return NULL; return pc_array[index]; }
EntityHandle | partitioning, | ||
const MPI_Comm * | comm = 0 |
) | [static] |
Get ParallelComm instance associated with partition handle Will create ParallelComm instance if a) one does not already exist and b) a valid value for MPI_Comm is passed.
Definition at line 8042 of file ParallelComm.cpp.
References ErrorCode, get_pcomm(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TYPE_INTEGER, ParallelComm(), moab::PARTITIONING_PCOMM_TAG_NAME, set_partitioning(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
{ ErrorCode rval; ParallelComm* result = 0; Tag prtn_tag; rval = impl->tag_get_handle( PARTITIONING_PCOMM_TAG_NAME, 1, MB_TYPE_INTEGER, prtn_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); if( MB_SUCCESS != rval ) return 0; int pcomm_id; rval = impl->tag_get_data( prtn_tag, &prtn, 1, &pcomm_id ); if( MB_SUCCESS == rval ) { result = get_pcomm( impl, pcomm_id ); } else if( MB_TAG_NOT_FOUND == rval && comm ) { result = new ParallelComm( impl, *comm, &pcomm_id ); if( !result ) return 0; result->set_partitioning( prtn ); rval = impl->tag_set_data( prtn_tag, &prtn, 1, &pcomm_id ); if( MB_SUCCESS != rval ) { delete result; result = 0; } } return result; }
ErrorCode moab::ParallelComm::get_proc_nvecs | ( | int | resolve_dim, |
int | shared_dim, | ||
Range * | skin_ents, | ||
std::map< std::vector< int >, std::vector< EntityHandle > > & | proc_nvecs | ||
) | [private] |
Definition at line 5156 of file ParallelComm.cpp.
References moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), get_sharing_data(), smoab::INTERSECT, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), procConfig, and moab::Interface::UNION.
Referenced by create_interface_sets(), resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
{ // Set sharing procs tags on other skin ents ErrorCode result; const EntityHandle* connect; int num_connect; std::set< int > sharing_procs; std::vector< EntityHandle > dum_connect; std::vector< int > sp_vec; for( int d = 3; d > 0; d-- ) { if( resolve_dim == d ) continue; for( Range::iterator rit = skin_ents[d].begin(); rit != skin_ents[d].end(); ++rit ) { // Get connectivity result = mbImpl->get_connectivity( *rit, connect, num_connect, false, &dum_connect );MB_CHK_SET_ERR( result, "Failed to get connectivity on non-vertex skin entities" ); int op = ( resolve_dim < shared_dim ? Interface::UNION : Interface::INTERSECT ); result = get_sharing_data( connect, num_connect, sharing_procs, op );MB_CHK_SET_ERR( result, "Failed to get sharing data in get_proc_nvecs" ); if( sharing_procs.empty() || ( sharing_procs.size() == 1 && *sharing_procs.begin() == (int)procConfig.proc_rank() ) ) continue; // Need to specify sharing data correctly for entities or they will // end up in a different interface set than corresponding vertices if( sharing_procs.size() == 2 ) { std::set< int >::iterator it = sharing_procs.find( proc_config().proc_rank() ); assert( it != sharing_procs.end() ); sharing_procs.erase( it ); } // Intersection is the owning proc(s) for this skin ent sp_vec.clear(); std::copy( sharing_procs.begin(), sharing_procs.end(), std::back_inserter( sp_vec ) ); assert( sp_vec.size() != 2 ); proc_nvecs[sp_vec].push_back( *rit ); } } #ifndef NDEBUG // Shouldn't be any repeated entities in any of the vectors in proc_nvecs for( std::map< std::vector< int >, std::vector< EntityHandle > >::iterator mit = proc_nvecs.begin(); mit != proc_nvecs.end(); ++mit ) { std::vector< EntityHandle > tmp_vec = ( mit->second ); std::sort( tmp_vec.begin(), tmp_vec.end() ); std::vector< EntityHandle >::iterator vit = std::unique( tmp_vec.begin(), tmp_vec.end() ); assert( vit == tmp_vec.end() ); } #endif return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_pstatus | ( | EntityHandle | entity, |
unsigned char & | pstatus_val | ||
Get parallel status of an entity Returns the parallel status of an entity.
entity | The entity being queried |
pstatus_val | Parallel status of the entity |
Definition at line 5488 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, mbImpl, pstatus_tag(), and moab::Interface::tag_get_data().
Referenced by check_my_shared_handles().
{ ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), &entity, 1, &pstatus_val );MB_CHK_SET_ERR( result, "Failed to get pastatus tag data" ); return result; }
ErrorCode moab::ParallelComm::get_pstatus_entities | ( | int | dim, |
Range & | pstatus_ents | ||
Get entities with the given pstatus bit(s) set Returns any entities whose pstatus tag value v satisfies (v & pstatus_val)
dim | Dimension of entities to be returned, or -1 if any |
pstatus_val | pstatus value of desired entities |
pstatus_ents | Entities returned from function |
Definition at line 5494 of file ParallelComm.cpp.
References moab::Range::begin(), dim, moab::Interface::dimension_from_handle(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, pstatus_tag(), moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by main().
{ Range ents; ErrorCode result; if( -1 == dim ) { result = mbImpl->get_entities_by_handle( 0, ents );MB_CHK_SET_ERR( result, "Failed to get all entities" ); } else { result = mbImpl->get_entities_by_dimension( 0, dim, ents );MB_CHK_SET_ERR( result, "Failed to get entities of dimension " << dim ); } std::vector< unsigned char > pstatus( ents.size() ); result = mbImpl->tag_get_data( pstatus_tag(), ents, &pstatus[0] );MB_CHK_SET_ERR( result, "Failed to get pastatus tag data" ); Range::iterator rit = ents.begin(); int i = 0; if( pstatus_val ) { for( ; rit != ents.end(); i++, ++rit ) { if( pstatus[i] & pstatus_val && ( -1 == dim || mbImpl->dimension_from_handle( *rit ) == dim ) ) pstatus_ents.insert( *rit ); } } else { for( ; rit != ents.end(); i++, ++rit ) { if( !pstatus[i] && ( -1 == dim || mbImpl->dimension_from_handle( *rit ) == dim ) ) pstatus_ents.insert( *rit ); } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_remote_handles | ( | EntityHandle * | local_vec, |
EntityHandle * | rem_vec, | ||
int | to_proc | ||
Definition at line 1064 of file ParallelComm.cpp.
References moab::error(), ErrorCode, MB_CHK_ERR, and MB_SUCCESS.
Referenced by check_my_shared_handles(), get_remote_handles(), pack_entity_seq(), pack_sets(), pack_tag(), and settle_intersection_points().
{ ErrorCode error; std::vector< EntityHandle > newents; error = get_remote_handles( true, local_vec, rem_vec, num_ents, to_proc, newents );MB_CHK_ERR( error ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_remote_handles | ( | const bool | store_remote_handles, |
EntityHandle * | from_vec, | ||
EntityHandle * | to_vec_tmp, | ||
int | to_proc, | ||
) | [private] |
replace handles in from_vec with corresponding handles on to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag; if no remote handle and new_ents is non-null, substitute instead CREATE_HANDLE(MBMAXTYPE, index) where index is handle's position in new_ents
Definition at line 1875 of file ParallelComm.cpp.
References moab::CREATE_HANDLE(), ErrorCode, get_shared_proc_tags(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, MBMAXTYPE, moab::ProcConfig::proc_rank(), procConfig, and moab::Interface::tag_get_data().
{ // NOTE: THIS IMPLEMENTATION IS JUST LIKE THE RANGE-BASED VERSION, NO REUSE // AT THIS TIME, SO IF YOU FIX A BUG IN THIS VERSION, IT MAY BE IN THE // OTHER VERSION TOO!!! if( 0 == num_ents ) return MB_SUCCESS; // Use a local destination ptr in case we're doing an in-place copy std::vector< EntityHandle > tmp_vector; EntityHandle* to_vec = to_vec_tmp; if( to_vec == from_vec ) { tmp_vector.resize( num_ents ); to_vec = &tmp_vector[0]; } if( !store_remote_handles ) { int err; // In this case, substitute position in new_ents list for( int i = 0; i < num_ents; i++ ) { int ind = std::lower_bound( new_ents.begin(), new_ents.end(), from_vec[i] ) - new_ents.begin(); assert( new_ents[ind] == from_vec[i] ); to_vec[i] = CREATE_HANDLE( MBMAXTYPE, ind, err ); assert( to_vec[i] != 0 && !err && -1 != ind ); } } else { Tag shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag; ErrorCode result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags" ); // Get single-proc destination handles and shared procs std::vector< int > sharing_procs( num_ents ); result = mbImpl->tag_get_data( shh_tag, from_vec, num_ents, to_vec );MB_CHK_SET_ERR( result, "Failed to get shared handle tag for remote_handles" ); result = mbImpl->tag_get_data( shp_tag, from_vec, num_ents, &sharing_procs[0] );MB_CHK_SET_ERR( result, "Failed to get sharing proc tag in remote_handles" ); for( int j = 0; j < num_ents; j++ ) { if( to_vec[j] && sharing_procs[j] != to_proc ) to_vec[j] = 0; } EntityHandle tmp_handles[MAX_SHARING_PROCS]; int tmp_procs[MAX_SHARING_PROCS]; int i; // Go through results, and for 0-valued ones, look for multiple shared proc for( i = 0; i < num_ents; i++ ) { if( !to_vec[i] ) { result = mbImpl->tag_get_data( shps_tag, from_vec + i, 1, tmp_procs ); if( MB_SUCCESS == result ) { for( int j = 0; j < MAX_SHARING_PROCS; j++ ) { if( -1 == tmp_procs[j] ) break; else if( tmp_procs[j] == to_proc ) { result = mbImpl->tag_get_data( shhs_tag, from_vec + i, 1, tmp_handles );MB_CHK_SET_ERR( result, "Failed to get sharedhs tag data" ); to_vec[i] = tmp_handles[j]; assert( to_vec[i] ); break; } } } if( !to_vec[i] ) { int j = std::lower_bound( new_ents.begin(), new_ents.end(), from_vec[i] ) - new_ents.begin(); if( (int)new_ents.size() == j ) { std::cout << "Failed to find new entity in send list, proc " << procConfig.proc_rank() << std::endl; for( int k = 0; k <= num_ents; k++ ) std::cout << k << ": " << from_vec[k] << " " << to_vec[k] << std::endl; MB_SET_ERR( MB_FAILURE, "Failed to find new entity in send list" ); } int err; to_vec[i] = CREATE_HANDLE( MBMAXTYPE, j, err ); if( err ) { MB_SET_ERR( MB_FAILURE, "Failed to create handle in remote_handles" ); } } } } } // memcpy over results if from_vec and to_vec are the same if( to_vec_tmp == from_vec ) memcpy( from_vec, to_vec, num_ents * sizeof( EntityHandle ) ); return MB_SUCCESS; }
const Range & | from_range, | ||
Range & | to_range, | ||
int | to_proc, | ||
) | [private] |
same as other version, except from_range and to_range should be different here
Definition at line 2055 of file ParallelComm.cpp.
References ErrorCode, get_remote_handles(), MB_CHK_SET_ERR, and moab::Range::size().
{ std::vector< EntityHandle > to_vector( from_range.size() ); ErrorCode result = get_remote_handles( store_remote_handles, from_range, &to_vector[0], to_proc, new_ents );MB_CHK_SET_ERR( result, "Failed to get remote handles" ); std::copy( to_vector.begin(), to_vector.end(), range_inserter( to_range ) ); return result; }
EntityHandle * | to_vec, | ||
int | to_proc, | ||
) | [private] |
same as other version, except packs range into vector
Definition at line 1974 of file ParallelComm.cpp.
References moab::Range::begin(), moab::CREATE_HANDLE(), moab::Range::empty(), moab::Range::end(), ErrorCode, get_shared_proc_tags(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, MBMAXTYPE, moab::Range::size(), and moab::Interface::tag_get_data().
{ // NOTE: THIS IMPLEMENTATION IS JUST LIKE THE VECTOR-BASED VERSION, NO REUSE // AT THIS TIME, SO IF YOU FIX A BUG IN THIS VERSION, IT MAY BE IN THE // OTHER VERSION TOO!!! if( from_range.empty() ) return MB_SUCCESS; if( !store_remote_handles ) { int err; // In this case, substitute position in new_ents list Range::iterator rit; unsigned int i; for( rit = from_range.begin(), i = 0; rit != from_range.end(); ++rit, i++ ) { int ind = std::lower_bound( new_ents.begin(), new_ents.end(), *rit ) - new_ents.begin(); assert( new_ents[ind] == *rit ); to_vec[i] = CREATE_HANDLE( MBMAXTYPE, ind, err ); assert( to_vec[i] != 0 && !err && -1 != ind ); } } else { Tag shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag; ErrorCode result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags" ); // Get single-proc destination handles and shared procs std::vector< int > sharing_procs( from_range.size() ); result = mbImpl->tag_get_data( shh_tag, from_range, to_vec );MB_CHK_SET_ERR( result, "Failed to get shared handle tag for remote_handles" ); result = mbImpl->tag_get_data( shp_tag, from_range, &sharing_procs[0] );MB_CHK_SET_ERR( result, "Failed to get sharing proc tag in remote_handles" ); for( unsigned int j = 0; j < from_range.size(); j++ ) { if( to_vec[j] && sharing_procs[j] != to_proc ) to_vec[j] = 0; } EntityHandle tmp_handles[MAX_SHARING_PROCS]; int tmp_procs[MAX_SHARING_PROCS]; // Go through results, and for 0-valued ones, look for multiple shared proc Range::iterator rit; unsigned int i; for( rit = from_range.begin(), i = 0; rit != from_range.end(); ++rit, i++ ) { if( !to_vec[i] ) { result = mbImpl->tag_get_data( shhs_tag, &( *rit ), 1, tmp_handles ); if( MB_SUCCESS == result ) { result = mbImpl->tag_get_data( shps_tag, &( *rit ), 1, tmp_procs );MB_CHK_SET_ERR( result, "Failed to get sharedps tag data" ); for( int j = 0; j < MAX_SHARING_PROCS; j++ ) if( tmp_procs[j] == to_proc ) { to_vec[i] = tmp_handles[j]; break; } } if( !to_vec[i] ) { int j = std::lower_bound( new_ents.begin(), new_ents.end(), *rit ) - new_ents.begin(); if( (int)new_ents.size() == j ) { MB_SET_ERR( MB_FAILURE, "Failed to find new entity in send list" ); } int err; to_vec[i] = CREATE_HANDLE( MBMAXTYPE, j, err ); if( err ) { MB_SET_ERR( MB_FAILURE, "Failed to create handle in remote_handles" ); } } } } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_sent_ents | ( | const bool | is_iface, |
const int | bridge_dim, | ||
const int | ghost_dim, | ||
const int | num_layers, | ||
const int | addl_ents, | ||
Range * | sent_ents, | ||
Range & | allsent, | ||
TupleList & | entprocs | ||
) | [private] |
Definition at line 6518 of file ParallelComm.cpp.
References buffProcs, moab::Range::clear(), moab::TupleList::disableWriteAccess(), moab::Range::empty(), moab::TupleList::enableWriteAccess(), moab::Range::end(), ErrorCode, filter_pstatus(), get_ghosted_entities(), get_iface_entities(), moab::TupleList::get_n(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::merge(), PSTATUS_AND, PSTATUS_SHARED, moab::TupleList::buffer::reset(), size(), moab::TupleList::sort(), moab::subtract(), moab::TupleList::vi_wr, and moab::TupleList::vul_wr.
Referenced by exchange_ghost_cells().
{ ErrorCode result; unsigned int ind; std::vector< unsigned int >::iterator proc_it; Range tmp_range; // Done in a separate loop over procs because sometimes later procs // need to add info to earlier procs' messages for( ind = 0, proc_it = buffProcs.begin(); proc_it != buffProcs.end(); ++proc_it, ind++ ) { if( !is_iface ) { result = get_ghosted_entities( bridge_dim, ghost_dim, buffProcs[ind], num_layers, addl_ents, sent_ents[ind] );MB_CHK_SET_ERR( result, "Failed to get ghost layers" ); } else { result = get_iface_entities( buffProcs[ind], -1, sent_ents[ind] );MB_CHK_SET_ERR( result, "Failed to get interface layers" ); } // Filter out entities already shared with destination tmp_range.clear(); result = filter_pstatus( sent_ents[ind], PSTATUS_SHARED, PSTATUS_AND, buffProcs[ind], &tmp_range );MB_CHK_SET_ERR( result, "Failed to filter on owner" ); if( !tmp_range.empty() ) sent_ents[ind] = subtract( sent_ents[ind], tmp_range ); allsent.merge( sent_ents[ind] ); } //=========================================== // Need to get procs each entity is sent to //=========================================== // Get the total # of proc/handle pairs int npairs = 0; for( ind = 0; ind < buffProcs.size(); ind++ ) npairs += sent_ents[ind].size(); // Allocate a TupleList of that size entprocs.initialize( 1, 0, 1, 0, npairs ); entprocs.enableWriteAccess(); // Put the proc/handle pairs in the list for( ind = 0, proc_it = buffProcs.begin(); proc_it != buffProcs.end(); ++proc_it, ind++ ) { for( Range::iterator rit = sent_ents[ind].begin(); rit != sent_ents[ind].end(); ++rit ) { entprocs.vi_wr[entprocs.get_n()] = *proc_it; entprocs.vul_wr[entprocs.get_n()] = *rit; entprocs.inc_n(); } } // Sort by handle moab::TupleList::buffer sort_buffer; sort_buffer.buffer_init( npairs ); entprocs.sort( 1, &sort_buffer ); entprocs.disableWriteAccess(); sort_buffer.reset(); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_shared_entities | ( | int | other_proc, |
Range & | shared_ents, | ||
int | dim = -1 , |
const bool | iface = false , |
const bool | owned_filter = false |
Get shared entities of specified dimension If other_proc is -1, any shared entities are returned. If dim is -1, entities of all dimensions on interface are returned.
other_proc | Rank of processor for which interface entities are requested |
shared_ents | Entities returned from function |
dim | Dimension of interface entities requested |
iface | If true, return only entities on the interface |
owned_filter | If true, return only owned shared entities |
Definition at line 8801 of file ParallelComm.cpp.
References moab::Range::clear(), dim, ErrorCode, filter_pstatus(), moab::Range::lower_bound(), MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::merge(), PSTATUS_AND, PSTATUS_INTERFACE, PSTATUS_NOT, PSTATUS_NOT_OWNED, PSTATUS_SHARED, sharedEnts, moab::CN::TypeDimensionMap, and moab::Range::upper_bound().
Referenced by check_my_shared_handles(), moab::ParCommGraph::compute_partition(), main(), perform_laplacian_smoothing(), and perform_lloyd_relaxation().
{ shared_ents.clear(); ErrorCode result = MB_SUCCESS; // Dimension if( -1 != dim ) { DimensionPair dp = CN::TypeDimensionMap[dim]; Range dum_range; std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( dum_range ) ); shared_ents.merge( dum_range.lower_bound( dp.first ), dum_range.upper_bound( dp.second ) ); } else std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( shared_ents ) ); // Filter by iface if( iface ) { result = filter_pstatus( shared_ents, PSTATUS_INTERFACE, PSTATUS_AND );MB_CHK_SET_ERR( result, "Failed to filter by iface" ); } // Filter by owned if( owned_filter ) { result = filter_pstatus( shared_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( result, "Failed to filter by owned" ); } // Filter by proc if( -1 != other_proc ) { result = filter_pstatus( shared_ents, PSTATUS_SHARED, PSTATUS_AND, other_proc );MB_CHK_SET_ERR( result, "Failed to filter by proc" ); } return result; }
ErrorCode moab::ParallelComm::get_shared_proc_tags | ( | Tag & | sharedp_tag, |
Tag & | sharedps_tag, | ||
Tag & | sharedh_tag, | ||
Tag & | sharedhs_tag, | ||
Tag & | pstatus_tag | ||
) | [inline] |
return the tags used to indicate shared procs and handles
Definition at line 1574 of file ParallelComm.hpp.
References MB_SUCCESS, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), and sharedps_tag().
Referenced by create_interface_sets(), get_remote_handles(), moab::RefinerTagManager::RefinerTagManager(), resolve_shared_ents(), and tag_shared_verts().
{ sharedp = sharedp_tag(); sharedps = sharedps_tag(); sharedh = sharedh_tag(); sharedhs = sharedhs_tag(); pstatus = pstatus_tag(); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_shared_sets | ( | Range & | result | ) | const |
Get all shared sets.
Definition at line 8899 of file ParallelComm.cpp.
Referenced by moab::WriteHDF5Parallel::create_meshset_tables().
{ return sharedSetData->get_shared_sets( result ); }
ErrorCode moab::ParallelComm::get_sharing_data | ( | const EntityHandle | entity, |
int * | ps, | ||
EntityHandle * | hs, | ||
unsigned char & | pstat, | ||
unsigned int & | num_ps | ||
Get the shared processors/handles for an entity Get the shared processors/handles for an entity. Arrays must be large enough to receive data for all sharing procs. Does *not* include this proc if only shared with one other proc.
entity | Entity being queried |
ps | Pointer to sharing proc data |
hs | Pointer to shared proc handle data |
pstat | Reference to pstatus data returned from this function |
Definition at line 3007 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, PSTATUS_MULTISHARED, PSTATUS_SHARED, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), and moab::Interface::tag_get_data().
Referenced by augment_default_sets_with_ghosts(), build_sharedhps_list(), check_clean_iface(), check_local_shared(), moab::ParCommGraph::compute_partition(), correct_thin_ghost_layers(), create_interface_sets(), delete_entities(), exchange_owned_meshs(), get_interface_sets(), get_part_neighbor_ids(), get_proc_nvecs(), get_sharing_data(), list_entities(), pack_shared_handles(), update_remote_data(), and update_remote_data_old().
{ ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), &entity, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" ); if( pstat & PSTATUS_MULTISHARED ) { result = mbImpl->tag_get_data( sharedps_tag(), &entity, 1, ps );MB_CHK_SET_ERR( result, "Failed to get sharedps tag data" ); if( hs ) { result = mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, hs );MB_CHK_SET_ERR( result, "Failed to get sharedhs tag data" ); } num_ps = std::find( ps, ps + MAX_SHARING_PROCS, -1 ) - ps; } else if( pstat & PSTATUS_SHARED ) { result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, ps );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" ); if( hs ) { result = mbImpl->tag_get_data( sharedh_tag(), &entity, 1, hs );MB_CHK_SET_ERR( result, "Failed to get sharedh tag data" ); hs[1] = 0; } // Initialize past end of data ps[1] = -1; num_ps = 1; } else { ps[0] = -1; if( hs ) hs[0] = 0; num_ps = 0; } assert( MAX_SHARING_PROCS >= num_ps ); return MB_SUCCESS; }
int * | ps, | ||
int & | num_ps | ||
) | [inline] |
Get the shared processors/handles for an entity Same as other version but with int num_ps.
Definition at line 1685 of file ParallelComm.hpp.
References ErrorCode, get_sharing_data(), and MB_SUCCESS.
{ unsigned int dum_ps; ErrorCode result = get_sharing_data( entity, ps, hs, pstat, dum_ps ); if( MB_SUCCESS == result ) num_ps = dum_ps; return result; }
ErrorCode moab::ParallelComm::get_sharing_data | ( | const EntityHandle * | entities, |
int | num_entities, | ||
std::set< int > & | procs, | ||
int | op = Interface::INTERSECT |
) | [inline] |
Get the intersection or union of all sharing processors Get the intersection or union of all sharing processors. Processor set is cleared as part of this function.
entities | Entity list ptr |
num_entities | Number of entities |
procs | Processors returned |
op | Either Interface::UNION or Interface::INTERSECT |
Definition at line 1673 of file ParallelComm.hpp.
References entities, and get_sharing_data().
{ Range dum_range; // cast away constness 'cuz the range is passed as const EntityHandle* ents_cast = const_cast< EntityHandle* >( entities ); std::copy( ents_cast, ents_cast + num_entities, range_inserter( dum_range ) ); return get_sharing_data( dum_range, procs, op ); }
ErrorCode moab::ParallelComm::get_sharing_data | ( | const Range & | entities, |
Get the intersection or union of all sharing processors Same as previous variant but with range as input.
Definition at line 2960 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, get_sharing_data(), moab::Interface::INTERSECT, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, PSTATUS_SHARED, and moab::Interface::UNION.
{ // Get the union or intersection of sharing data for multiple entities ErrorCode result; int sp2[MAX_SHARING_PROCS]; int num_ps; unsigned char pstat; std::set< int > tmp_procs; procs.clear(); for( Range::const_iterator rit = entities.begin(); rit != entities.end(); ++rit ) { // Get sharing procs result = get_sharing_data( *rit, sp2, NULL, pstat, num_ps );MB_CHK_SET_ERR( result, "Failed to get sharing data in get_sharing_data" ); if( !( pstat & PSTATUS_SHARED ) && Interface::INTERSECT == operation ) { procs.clear(); return MB_SUCCESS; } if( rit == entities.begin() ) { std::copy( sp2, sp2 + num_ps, std::inserter( procs, procs.begin() ) ); } else { std::sort( sp2, sp2 + num_ps ); tmp_procs.clear(); if( Interface::UNION == operation ) std::set_union( procs.begin(), procs.end(), sp2, sp2 + num_ps, std::inserter( tmp_procs, tmp_procs.end() ) ); else if( Interface::INTERSECT == operation ) std::set_intersection( procs.begin(), procs.end(), sp2, sp2 + num_ps, std::inserter( tmp_procs, tmp_procs.end() ) ); else { assert( "Unknown operation." && false ); return MB_FAILURE; } procs.swap( tmp_procs ); } if( Interface::INTERSECT == operation && procs.empty() ) return MB_SUCCESS; } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::get_sharing_parts | ( | EntityHandle | entity, |
int | part_ids_out[MAX_SHARING_PROCS], | ||
int & | num_part_ids_out, | ||
EntityHandle | remote_handles[MAX_SHARING_PROCS] = 0 |
Definition at line 8382 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), PSTATUS_SHARED, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), and moab::Interface::tag_get_data().
Referenced by iMeshP_getCopies(), iMeshP_getCopyOnPart(), iMeshP_getCopyParts(), and iMeshP_getNumCopies().
{ // FIXME : assumes one part per proc, and therefore part_id == rank // If entity is not shared, then we're the owner. unsigned char pstat; ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), &entity, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" ); if( !( pstat & PSTATUS_SHARED ) ) { part_ids_out[0] = proc_config().proc_rank(); if( remote_handles ) remote_handles[0] = entity; num_part_ids_out = 1; return MB_SUCCESS; } // If entity is shared with one other proc, then // sharedp_tag will contain a positive value. result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, part_ids_out );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" ); if( part_ids_out[0] != -1 ) { num_part_ids_out = 2; part_ids_out[1] = proc_config().proc_rank(); // Done? if( !remote_handles ) return MB_SUCCESS; // Get handles on remote processors (and this one) remote_handles[1] = entity; return mbImpl->tag_get_data( sharedh_tag(), &entity, 1, remote_handles ); } // If here, then the entity is shared with at least two other processors. // Get the list from the sharedps_tag result = mbImpl->tag_get_data( sharedps_tag(), &entity, 1, part_ids_out ); if( MB_SUCCESS != result ) return result; // Count number of valid (positive) entries in sharedps_tag for( num_part_ids_out = 0; num_part_ids_out < MAX_SHARING_PROCS && part_ids_out[num_part_ids_out] >= 0; num_part_ids_out++ ) ; // part_ids_out[num_part_ids_out++] = proc_config().proc_rank(); #ifndef NDEBUG int my_idx = std::find( part_ids_out, part_ids_out + num_part_ids_out, proc_config().proc_rank() ) - part_ids_out; assert( my_idx < num_part_ids_out ); #endif // Done? if( !remote_handles ) return MB_SUCCESS; // Get remote handles result = mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, remote_handles ); // remote_handles[num_part_ids_out - 1] = entity; assert( remote_handles[my_idx] == entity ); return result; }
ErrorCode moab::ParallelComm::get_tag_send_list | ( | const Range & | all_entities, |
std::vector< Tag > & | all_tags, | ||
std::vector< Range > & | tag_ranges | ||
) | [private] |
Get list of tags for which to exchange data.
Get tags and entities for which to exchange tag data. This function was originally part of 'pack_tags' requested with the 'all_possible_tags' parameter.
all_entities | Input. The set of entities for which data is to be communicated. |
all_tags | Output. Populated with the handles of tags to be sent. |
tag_ranges | Output. For each corresponding tag in all_tags, the subset of 'all_entities' for which a tag value has been set. |
Definition at line 3650 of file ParallelComm.cpp.
References moab::Range::empty(), ErrorCode, moab::intersect(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, sequenceManager, moab::Interface::tag_get_name(), and moab::Interface::tag_get_tags().
Referenced by pack_buffer().
{ std::vector< Tag > tmp_tags; ErrorCode result = mbImpl->tag_get_tags( tmp_tags );MB_CHK_SET_ERR( result, "Failed to get tags in pack_tags" ); std::vector< Tag >::iterator tag_it; for( tag_it = tmp_tags.begin(); tag_it != tmp_tags.end(); ++tag_it ) { std::string tag_name; result = mbImpl->tag_get_name( *tag_it, tag_name ); if( tag_name.c_str()[0] == '_' && tag_name.c_str()[1] == '_' ) continue; Range tmp_range; result = ( *tag_it )->get_tagged_entities( sequenceManager, tmp_range );MB_CHK_SET_ERR( result, "Failed to get entities for tag in pack_tags" ); tmp_range = intersect( tmp_range, whole_range ); if( tmp_range.empty() ) continue; // OK, we'll be sending this tag all_tags.push_back( *tag_it ); tag_ranges.push_back( Range() ); tag_ranges.back().swap( tmp_range ); } return MB_SUCCESS; }
void moab::ParallelComm::initialize | ( | ) | [private] |
Definition at line 341 of file ParallelComm.cpp.
References add_pcomm(), buffProcs, errorHandler, localOwnedBuffs, MAX_SHARING_PROCS, mbImpl, myDebug, pcommID, moab::ProcConfig::proc_rank(), procConfig, moab::Interface::query_interface(), remoteOwnedBuffs, moab::Core::sequence_manager(), sequenceManager, and moab::DebugOutput::set_rank().
Referenced by ParallelComm().
{ Core* core = dynamic_cast< Core* >( mbImpl ); sequenceManager = core->sequence_manager(); mbImpl->query_interface( errorHandler ); // Initialize MPI, if necessary int flag = 1; int retval = MPI_Initialized( &flag ); if( MPI_SUCCESS != retval || !flag ) { int argc = 0; char** argv = NULL; // mpi not initialized yet - initialize here retval = MPI_Init( &argc, &argv ); assert( MPI_SUCCESS == retval ); } // Reserve space for vectors buffProcs.reserve( MAX_SHARING_PROCS ); localOwnedBuffs.reserve( MAX_SHARING_PROCS ); remoteOwnedBuffs.reserve( MAX_SHARING_PROCS ); pcommID = add_pcomm( this ); if( !myDebug ) { myDebug = new DebugOutput( "ParallelComm", std::cerr ); myDebug->set_rank( procConfig.proc_rank() ); } }
Range& moab::ParallelComm::interface_sets | ( | ) | [inline] |
Definition at line 673 of file ParallelComm.hpp.
References interfaceSets.
Referenced by check_clean_iface(), moab::NCHelperScrip::create_mesh(), and get_interface_sets().
{ return interfaceSets; }
const Range& moab::ParallelComm::interface_sets | ( | ) | const [inline] |
Definition at line 677 of file ParallelComm.hpp.
bool moab::ParallelComm::is_iface_proc | ( | EntityHandle | this_set, |
int | to_proc | ||
) | [private] |
returns true if the set is an interface shared with to_proc
Definition at line 5556 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, mbImpl, sharedp_tag(), sharedps_tag(), and moab::Interface::tag_get_data().
Referenced by get_ghosted_entities(), and get_iface_entities().
{ int sharing_procs[MAX_SHARING_PROCS]; std::fill( sharing_procs, sharing_procs + MAX_SHARING_PROCS, -1 ); ErrorCode result = mbImpl->tag_get_data( sharedp_tag(), &this_set, 1, sharing_procs ); if( MB_SUCCESS == result && to_proc == sharing_procs[0] ) return true; result = mbImpl->tag_get_data( sharedps_tag(), &this_set, 1, sharing_procs ); if( MB_SUCCESS != result ) return false; for( int i = 0; i < MAX_SHARING_PROCS; i++ ) { if( to_proc == sharing_procs[i] ) return true; else if( -1 == sharing_procs[i] ) return false; } return false; }
ErrorCode moab::ParallelComm::list_entities | ( | const EntityHandle * | ents, |
int | num_ents | ||
Definition at line 2573 of file ParallelComm.cpp.
References ErrorCode, moab::Interface::get_coords(), get_sharing_data(), moab::Interface::id_from_handle(), moab::Interface::list_entities(), MAX_SHARING_PROCS, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::Range::print(), PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, and sharedEnts.
Referenced by build_sharedhps_list(), check_local_shared(), check_my_shared_handles(), list_entities(), moab::ReadParallel::load_file(), and moab::ScdInterface::tag_shared_vertices().
{ if( NULL == ents ) { Range shared_ents; std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( shared_ents ) ); shared_ents.print( "Shared entities:\n" ); return MB_SUCCESS; } unsigned char pstat; EntityHandle tmp_handles[MAX_SHARING_PROCS]; int tmp_procs[MAX_SHARING_PROCS]; unsigned int num_ps; ErrorCode result; for( int i = 0; i < num_ents; i++ ) { result = mbImpl->list_entities( ents + i, 1 );MB_CHK_ERR( result ); double coords[3]; result = mbImpl->get_coords( ents + i, 1, coords ); std::cout << " coords: " << coords[0] << " " << coords[1] << " " << coords[2] << "\n"; result = get_sharing_data( ents[i], tmp_procs, tmp_handles, pstat, num_ps );MB_CHK_SET_ERR( result, "Failed to get sharing data" ); std::cout << "Pstatus: "; if( !num_ps ) std::cout << "local " << std::endl; else { if( pstat & PSTATUS_NOT_OWNED ) std::cout << "NOT_OWNED; "; if( pstat & PSTATUS_SHARED ) std::cout << "SHARED; "; if( pstat & PSTATUS_MULTISHARED ) std::cout << "MULTISHARED; "; if( pstat & PSTATUS_INTERFACE ) std::cout << "INTERFACE; "; if( pstat & PSTATUS_GHOST ) std::cout << "GHOST; "; std::cout << std::endl; for( unsigned int j = 0; j < num_ps; j++ ) { std::cout << " proc " << tmp_procs[j] << " id (handle) " << mbImpl->id_from_handle( tmp_handles[j] ) << "(" << tmp_handles[j] << ")" << std::endl; } } std::cout << std::endl; } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::list_entities | ( | const Range & | ents | ) |
Definition at line 2621 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), list_entities(), and MB_SUCCESS.
{ for( Range::iterator rit = ents.begin(); rit != ents.end(); ++rit ) list_entities( &( *rit ), 1 ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::pack_adjacencies | ( | Range & | entities, |
Range::const_iterator & | start_rit, | ||
Range & | whole_range, | ||
unsigned char *& | buff_ptr, | ||
int & | count, | ||
const bool | just_count, | ||
const bool | store_handles, | ||
const int | to_proc | ||
) | [private] |
Definition at line 3450 of file ParallelComm.cpp.
return MB_FAILURE;
ErrorCode moab::ParallelComm::pack_buffer | ( | Range & | orig_ents, |
const bool | adjacencies, | ||
const bool | tags, | ||
const bool | store_remote_handles, | ||
const int | to_proc, | ||
Buffer * | buff, | ||
TupleList * | entprocs = NULL , |
Range * | allsent = NULL |
public 'cuz we want to unit test these externally
Definition at line 1418 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), ErrorCode, get_tag_send_list(), MB_CHK_SET_ERR, pack_entities(), moab::PACK_INT(), pack_sets(), pack_tags(), and moab::ParallelComm::Buffer::set_stored_size().
Referenced by broadcast_entities(), exchange_owned_mesh(), scatter_entities(), send_entities(), and moab::ParCommGraph::send_mesh_parts().
{ // Pack the buffer with the entity ranges, adjacencies, and tags sections // // Note: new entities used in subsequent connectivity lists, sets, or tags, // are referred to as (MBMAXTYPE + index), where index is into vector // of new entities, 0-based ErrorCode result; Range set_range; std::vector< Tag > all_tags; std::vector< Range > tag_ranges; Range::const_iterator rit; // Entities result = pack_entities( orig_ents, buff, store_remote_handles, to_proc, false, entprocs, allsent );MB_CHK_SET_ERR( result, "Packing entities failed" ); // Sets result = pack_sets( orig_ents, buff, store_remote_handles, to_proc );MB_CHK_SET_ERR( result, "Packing sets (count) failed" ); // Tags Range final_ents; if( tags ) { result = get_tag_send_list( orig_ents, all_tags, tag_ranges );MB_CHK_SET_ERR( result, "Failed to get tagged entities" ); result = pack_tags( orig_ents, all_tags, all_tags, tag_ranges, buff, store_remote_handles, to_proc );MB_CHK_SET_ERR( result, "Packing tags (count) failed" ); } else { // Set tag size to 0 buff->check_space( sizeof( int ) ); PACK_INT( buff->buff_ptr, 0 ); buff->set_stored_size(); } return result; }
ErrorCode moab::ParallelComm::pack_entities | ( | Range & | entities, |
const bool | is_iface, | ||
Definition at line 1582 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, build_sharedhps_list(), moab::ParallelComm::Buffer::check_space(), moab::Range::clear(), moab::Range::empty(), moab::Range::end(), moab::EntitySequence::end_handle(), moab::CN::EntityTypeName(), ErrorCode, estimate_ents_buffer_size(), moab::SequenceManager::find(), moab::Range::find(), moab::Interface::get_coords(), moab::TupleList::get_n(), moab::Range::lower_bound(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, MBMAXTYPE, MBVERTEX, myDebug, moab::ElementSequence::nodes_per_element(), moab::PACK_DBLS(), moab::PACK_EH(), pack_entity_seq(), moab::PACK_INT(), moab::PACK_INTS(), pstatus_tag(), moab::Range::rbegin(), sequenceManager, moab::ParallelComm::Buffer::set_stored_size(), sharedp_tag(), moab::Range::size(), moab::Range::subset_by_type(), moab::Interface::tag_get_data(), moab::DebugOutput::tprintf(), moab::EntitySequence::type(), moab::TYPE_FROM_HANDLE(), moab::TupleList::vi_rd, and moab::TupleList::vul_rd.
Referenced by exchange_ghost_cells(), and pack_buffer().
{ // Packed information: // 1. # entities = E // 2. for e in E // a. # procs sharing e, incl. sender and receiver = P // b. for p in P (procs sharing e) // c. for p in P (handle for e on p) (Note1) // 3. vertex/entity info // Get an estimate of the buffer size & pre-allocate buffer size int buff_size = estimate_ents_buffer_size( entities, store_remote_handles ); if( buff_size < 0 ) MB_SET_ERR( MB_FAILURE, "Failed to estimate ents buffer size" ); buff->check_space( buff_size ); myDebug->tprintf( 3, "estimate buffer size for %d entities: %d \n", (int)entities.size(), buff_size ); unsigned int num_ents; ErrorCode result; std::vector< EntityHandle > entities_vec( entities.size() ); std::copy( entities.begin(), entities.end(), entities_vec.begin() ); // First pack procs/handles sharing this ent, not including this dest but including // others (with zero handles) if( store_remote_handles ) { // Buff space is at least proc + handle for each entity; use avg of 4 other procs // to estimate buff size, but check later buff->check_space( sizeof( int ) + ( 5 * sizeof( int ) + sizeof( EntityHandle ) ) * entities.size() ); // 1. # entities = E PACK_INT( buff->buff_ptr, entities.size() ); Range::iterator rit; // Pre-fetch sharedp and pstatus std::vector< int > sharedp_vals( entities.size() ); result = mbImpl->tag_get_data( sharedp_tag(), entities, &sharedp_vals[0] );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" ); std::vector< char > pstatus_vals( entities.size() ); result = mbImpl->tag_get_data( pstatus_tag(), entities, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" ); unsigned int i; int tmp_procs[MAX_SHARING_PROCS]; EntityHandle tmp_handles[MAX_SHARING_PROCS]; std::set< unsigned int > dumprocs; // 2. for e in E for( rit = entities.begin(), i = 0; rit != entities.end(); ++rit, i++ ) { unsigned int ind = std::lower_bound( entprocs->vul_rd, entprocs->vul_rd + entprocs->get_n(), *rit ) - entprocs->vul_rd; assert( ind < entprocs->get_n() ); while( ind < entprocs->get_n() && entprocs->vul_rd[ind] == *rit ) dumprocs.insert( entprocs->vi_rd[ind++] ); result = build_sharedhps_list( *rit, pstatus_vals[i], sharedp_vals[i], dumprocs, num_ents, tmp_procs, tmp_handles );MB_CHK_SET_ERR( result, "Failed to build sharedhps" ); dumprocs.clear(); // Now pack them buff->check_space( ( num_ents + 1 ) * sizeof( int ) + num_ents * sizeof( EntityHandle ) ); PACK_INT( buff->buff_ptr, num_ents ); PACK_INTS( buff->buff_ptr, tmp_procs, num_ents ); PACK_EH( buff->buff_ptr, tmp_handles, num_ents ); #ifndef NDEBUG // Check for duplicates in proc list unsigned int dp = 0; for( ; dp < MAX_SHARING_PROCS && -1 != tmp_procs[dp]; dp++ ) dumprocs.insert( tmp_procs[dp] ); assert( dumprocs.size() == dp ); dumprocs.clear(); #endif } } // Pack vertices Range these_ents = entities.subset_by_type( MBVERTEX ); num_ents = these_ents.size(); if( num_ents ) { buff_size = 2 * sizeof( int ) + 3 * num_ents * sizeof( double ); buff->check_space( buff_size ); // Type, # ents PACK_INT( buff->buff_ptr, ( (int)MBVERTEX ) ); PACK_INT( buff->buff_ptr, ( (int)num_ents ) ); std::vector< double > tmp_coords( 3 * num_ents ); result = mbImpl->get_coords( these_ents, &tmp_coords[0] );MB_CHK_SET_ERR( result, "Failed to get vertex coordinates" ); PACK_DBLS( buff->buff_ptr, &tmp_coords[0], 3 * num_ents ); myDebug->tprintf( 4, "Packed %lu ents of type %s\n", (unsigned long)these_ents.size(), CN::EntityTypeName( TYPE_FROM_HANDLE( *these_ents.begin() ) ) ); } // Now entities; go through range, packing by type and equal # verts per element Range::iterator start_rit = entities.find( *these_ents.rbegin() ); ++start_rit; int last_nodes = -1; EntityType last_type = MBMAXTYPE; these_ents.clear(); Range::iterator end_rit = start_rit; EntitySequence* seq; ElementSequence* eseq; while( start_rit != entities.end() || !these_ents.empty() ) { // Cases: // A: !end, last_type == MBMAXTYPE, seq: save contig sequence in these_ents // B: !end, last type & nodes same, seq: save contig sequence in these_ents // C: !end, last type & nodes different: pack these_ents, then save contig sequence in // these_ents D: end: pack these_ents // Find the sequence holding current start entity, if we're not at end eseq = NULL; if( start_rit != entities.end() ) { result = sequenceManager->find( *start_rit, seq );MB_CHK_SET_ERR( result, "Failed to find entity sequence" ); if( NULL == seq ) return MB_FAILURE; eseq = dynamic_cast< ElementSequence* >( seq ); } // Pack the last batch if at end or next one is different if( !these_ents.empty() && ( !eseq || eseq->type() != last_type || last_nodes != (int)eseq->nodes_per_element() ) ) { result = pack_entity_seq( last_nodes, store_remote_handles, to_proc, these_ents, entities_vec, buff );MB_CHK_SET_ERR( result, "Failed to pack entities from a sequence" ); these_ents.clear(); } if( eseq ) { // Continuation of current range, just save these entities // Get position in entities list one past end of this sequence end_rit = entities.lower_bound( start_rit, entities.end(), eseq->end_handle() + 1 ); // Put these entities in the range std::copy( start_rit, end_rit, range_inserter( these_ents ) ); last_type = eseq->type(); last_nodes = eseq->nodes_per_element(); } else if( start_rit != entities.end() && TYPE_FROM_HANDLE( *start_rit ) == MBENTITYSET ) break; start_rit = end_rit; } // Pack MBMAXTYPE to indicate end of ranges buff->check_space( sizeof( int ) ); PACK_INT( buff->buff_ptr, ( (int)MBMAXTYPE ) ); buff->set_stored_size(); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::pack_entity_seq | ( | const int | nodes_per_entity, |
Range & | these_ents, | ||
std::vector< EntityHandle > & | entities, | ||
Buffer * | buff | ||
) | [private] |
pack a range of entities with equal # verts per entity, along with the range on the sending proc
Definition at line 1836 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), moab::Range::end(), moab::CN::EntityTypeName(), ErrorCode, moab::Interface::get_connectivity(), moab::ParallelComm::Buffer::get_current_size(), get_remote_handles(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, myDebug, moab::PACK_EH(), moab::PACK_INT(), moab::Range::size(), moab::DebugOutput::tprintf(), and moab::TYPE_FROM_HANDLE().
Referenced by pack_entities().
{ int tmp_space = 3 * sizeof( int ) + nodes_per_entity * these_ents.size() * sizeof( EntityHandle ); buff->check_space( tmp_space ); // Pack the entity type PACK_INT( buff->buff_ptr, ( (int)TYPE_FROM_HANDLE( *these_ents.begin() ) ) ); // Pack # ents PACK_INT( buff->buff_ptr, these_ents.size() ); // Pack the nodes per entity PACK_INT( buff->buff_ptr, nodes_per_entity ); myDebug->tprintf( 3, "after some pack int %d \n", buff->get_current_size() ); // Pack the connectivity std::vector< EntityHandle > connect; ErrorCode result = MB_SUCCESS; for( Range::const_iterator rit = these_ents.begin(); rit != these_ents.end(); ++rit ) { connect.clear(); result = mbImpl->get_connectivity( &( *rit ), 1, connect, false );MB_CHK_SET_ERR( result, "Failed to get connectivity" ); assert( (int)connect.size() == nodes_per_entity ); result = get_remote_handles( store_remote_handles, &connect[0], &connect[0], connect.size(), to_proc, entities_vec );MB_CHK_SET_ERR( result, "Failed in get_remote_handles" ); PACK_EH( buff->buff_ptr, &connect[0], connect.size() ); } myDebug->tprintf( 3, "Packed %lu ents of type %s\n", (unsigned long)these_ents.size(), CN::EntityTypeName( TYPE_FROM_HANDLE( *these_ents.begin() ) ) ); return result; }
ErrorCode moab::ParallelComm::pack_range_map | ( | Range & | this_range, |
EntityHandle | actual_start, | ||
HandleMap & | handle_map | ||
) | [private] |
pack a range map with keys in this_range and values a contiguous series of handles starting at actual_start
Definition at line 3136 of file ParallelComm.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), moab::RangeMap< KeyType, ValType, NullVal >::insert(), and MB_SUCCESS.
{ for( Range::const_pair_iterator key_it = key_range.const_pair_begin(); key_it != key_range.const_pair_end(); ++key_it ) { int tmp_num = ( *key_it ).second - ( *key_it ).first + 1; handle_map.insert( ( *key_it ).first, val_start, tmp_num ); val_start += tmp_num; } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::pack_remote_handles | ( | std::vector< EntityHandle > & | L1hloc, |
std::vector< EntityHandle > & | L1hrem, | ||
std::vector< int > & | procs, | ||
unsigned int | to_proc, | ||
Definition at line 7370 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), MB_SUCCESS, moab::PACK_EH(), moab::PACK_INT(), moab::PACK_INTS(), and moab::ParallelComm::Buffer::set_stored_size().
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), recv_entities(), and recv_messages().
{ assert( std::find( L1hloc.begin(), L1hloc.end(), (EntityHandle)0 ) == L1hloc.end() ); // 2 vectors of handles plus ints buff->check_space( ( ( L1p.size() + 1 ) * sizeof( int ) + ( L1hloc.size() + 1 ) * sizeof( EntityHandle ) + ( L1hrem.size() + 1 ) * sizeof( EntityHandle ) ) ); // Should be in pairs of handles PACK_INT( buff->buff_ptr, L1hloc.size() ); PACK_INTS( buff->buff_ptr, &L1p[0], L1p.size() ); // Pack handles in reverse order, (remote, local), so on destination they // are ordered (local, remote) PACK_EH( buff->buff_ptr, &L1hrem[0], L1hrem.size() ); PACK_EH( buff->buff_ptr, &L1hloc[0], L1hloc.size() ); buff->set_stored_size(); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::pack_sets | ( | Range & | entities, |
) | [private] |
Definition at line 3149 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), moab::Range::empty(), moab::Range::end(), ErrorCode, estimate_sets_buffer_size(), moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::Interface::get_meshset_options(), moab::Interface::get_parent_meshsets(), get_remote_handles(), moab::ID_FROM_HANDLE(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, MBMAXTYPE, myDebug, moab::Interface::num_child_meshsets(), moab::Interface::num_parent_meshsets(), moab::PACK_EH(), moab::PACK_INT(), moab::PACK_INTS(), moab::PACK_RANGE(), moab::PACK_VOID(), moab::RANGE_SIZE(), moab::ParallelComm::Buffer::set_stored_size(), moab::Range::size(), moab::Range::subset_by_type(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::DebugOutput::tprintf(), and moab::TYPE_FROM_HANDLE().
{ // SETS: // . #sets // . for each set: // - options[#sets] (unsigned int) // - if (unordered) set range // - else if ordered // . #ents in set // . handles[#ents] // - #parents // - if (#parents) handles[#parents] // - #children // - if (#children) handles[#children] // Now the sets; assume any sets the application wants to pass are in the entities list ErrorCode result; Range all_sets = entities.subset_by_type( MBENTITYSET ); int buff_size = estimate_sets_buffer_size( all_sets, store_remote_handles ); if( buff_size < 0 ) MB_SET_ERR( MB_FAILURE, "Failed to estimate sets buffer size" ); buff->check_space( buff_size ); // Number of sets PACK_INT( buff->buff_ptr, all_sets.size() ); // Options for all sets std::vector< unsigned int > options( all_sets.size() ); Range::iterator rit; std::vector< EntityHandle > members; int i; for( rit = all_sets.begin(), i = 0; rit != all_sets.end(); ++rit, i++ ) { result = mbImpl->get_meshset_options( *rit, options[i] );MB_CHK_SET_ERR( result, "Failed to get meshset options" ); } buff->check_space( all_sets.size() * sizeof( unsigned int ) ); PACK_VOID( buff->buff_ptr, &options[0], all_sets.size() * sizeof( unsigned int ) ); // Pack parallel geometry unique id if( !all_sets.empty() ) { Tag uid_tag; int n_sets = all_sets.size(); bool b_pack = false; std::vector< int > id_data( n_sets ); result = mbImpl->tag_get_handle( "PARALLEL_UNIQUE_ID", 1, MB_TYPE_INTEGER, uid_tag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( result, "Failed to create parallel geometry unique id tag" ); result = mbImpl->tag_get_data( uid_tag, all_sets, &id_data[0] ); if( MB_TAG_NOT_FOUND != result ) { if( MB_SUCCESS != result ) MB_SET_ERR( result, "Failed to get parallel geometry unique ids" ); for( i = 0; i < n_sets; i++ ) { if( id_data[i] != 0 ) { b_pack = true; break; } } } if( b_pack ) { // If you find buff->check_space( ( n_sets + 1 ) * sizeof( int ) ); PACK_INT( buff->buff_ptr, n_sets ); PACK_INTS( buff->buff_ptr, &id_data[0], n_sets ); } else { buff->check_space( sizeof( int ) ); PACK_INT( buff->buff_ptr, 0 ); } } // Vectors/ranges std::vector< EntityHandle > entities_vec( entities.size() ); std::copy( entities.begin(), entities.end(), entities_vec.begin() ); for( rit = all_sets.begin(), i = 0; rit != all_sets.end(); ++rit, i++ ) { members.clear(); result = mbImpl->get_entities_by_handle( *rit, members );MB_CHK_SET_ERR( result, "Failed to get entities in ordered set" ); result = get_remote_handles( store_remote_handles, &members[0], &members[0], members.size(), to_proc, entities_vec );MB_CHK_SET_ERR( result, "Failed in get_remote_handles" ); buff->check_space( members.size() * sizeof( EntityHandle ) + sizeof( int ) ); PACK_INT( buff->buff_ptr, members.size() ); PACK_EH( buff->buff_ptr, &members[0], members.size() ); } // Pack parent/child sets if( !store_remote_handles ) { // Only works not store remote handles // Pack numbers of parents/children unsigned int tot_pch = 0; int num_pch; buff->check_space( 2 * all_sets.size() * sizeof( int ) ); for( rit = all_sets.begin(), i = 0; rit != all_sets.end(); ++rit, i++ ) { // Pack parents result = mbImpl->num_parent_meshsets( *rit, &num_pch );MB_CHK_SET_ERR( result, "Failed to get num parents" ); PACK_INT( buff->buff_ptr, num_pch ); tot_pch += num_pch; result = mbImpl->num_child_meshsets( *rit, &num_pch );MB_CHK_SET_ERR( result, "Failed to get num children" ); PACK_INT( buff->buff_ptr, num_pch ); tot_pch += num_pch; } // Now pack actual parents/children members.clear(); members.reserve( tot_pch ); std::vector< EntityHandle > tmp_pch; for( rit = all_sets.begin(), i = 0; rit != all_sets.end(); ++rit, i++ ) { result = mbImpl->get_parent_meshsets( *rit, tmp_pch );MB_CHK_SET_ERR( result, "Failed to get parents" ); std::copy( tmp_pch.begin(), tmp_pch.end(), std::back_inserter( members ) ); tmp_pch.clear(); result = mbImpl->get_child_meshsets( *rit, tmp_pch );MB_CHK_SET_ERR( result, "Failed to get children" ); std::copy( tmp_pch.begin(), tmp_pch.end(), std::back_inserter( members ) ); tmp_pch.clear(); } assert( members.size() == tot_pch ); if( !members.empty() ) { result = get_remote_handles( store_remote_handles, &members[0], &members[0], members.size(), to_proc, entities_vec );MB_CHK_SET_ERR( result, "Failed to get remote handles for set parent/child sets" ); #ifndef NDEBUG // Check that all handles are either sets or maxtype for( unsigned int __j = 0; __j < members.size(); __j++ ) assert( ( TYPE_FROM_HANDLE( members[__j] ) == MBMAXTYPE && ID_FROM_HANDLE( members[__j] ) < (int)entities.size() ) || TYPE_FROM_HANDLE( members[__j] ) == MBENTITYSET ); #endif buff->check_space( members.size() * sizeof( EntityHandle ) ); PACK_EH( buff->buff_ptr, &members[0], members.size() ); } } else { buff->check_space( 2 * all_sets.size() * sizeof( int ) ); for( rit = all_sets.begin(); rit != all_sets.end(); ++rit ) { PACK_INT( buff->buff_ptr, 0 ); PACK_INT( buff->buff_ptr, 0 ); } } // Pack the handles if( store_remote_handles && !all_sets.empty() ) { buff_size = RANGE_SIZE( all_sets ); buff->check_space( buff_size ); PACK_RANGE( buff->buff_ptr, all_sets ); } myDebug->tprintf( 4, "Done packing sets.\n" ); buff->set_stored_size(); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::pack_shared_handles | ( | std::vector< std::vector< SharedEntityData > > & | send_data | ) |
Definition at line 8441 of file ParallelComm.cpp.
References buffProcs, ErrorCode, get_buffers(), get_owner(), get_sharing_data(), moab::ParallelComm::SharedEntityData::local, MAX_SHARING_PROCS, MB_SUCCESS, moab::ParallelComm::SharedEntityData::owner, proc_config(), moab::ParallelComm::SharedEntityData::remote, and sharedEnts.
Referenced by check_all_shared_handles().
{ // Build up send buffers ErrorCode rval = MB_SUCCESS; int ent_procs[MAX_SHARING_PROCS]; EntityHandle handles[MAX_SHARING_PROCS]; int num_sharing, tmp_int; SharedEntityData tmp; send_data.resize( buffProcs.size() ); for( std::set< EntityHandle >::iterator i = sharedEnts.begin(); i != sharedEnts.end(); ++i ) { tmp.remote = *i; // Swap local/remote so they're correct on the remote proc. rval = get_owner( *i, tmp_int ); tmp.owner = tmp_int; if( MB_SUCCESS != rval ) return rval; unsigned char pstat; rval = get_sharing_data( *i, ent_procs, handles, pstat, num_sharing ); if( MB_SUCCESS != rval ) return rval; for( int j = 0; j < num_sharing; j++ ) { if( ent_procs[j] == (int)proc_config().proc_rank() ) continue; tmp.local = handles[j]; int ind = get_buffers( ent_procs[j] ); assert( -1 != ind ); if( (int)send_data.size() < ind + 1 ) send_data.resize( ind + 1 ); send_data[ind].push_back( tmp ); } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::pack_tag | ( | Tag | source_tag, |
Tag | destination_tag, | ||
const Range & | entities, | ||
const std::vector< EntityHandle > & | whole_range, | ||
) | [private] |
Serialize tag data.
source_tag | The tag for which data will be serialized |
destination_tag | Tag in which to store unpacked tag data. Typically the same as source_tag. |
entities | The entities for which tag values will be serialized |
whole_range | Calculate entity indices as location in this range |
buff_ptr | Input/Output: As input, pointer to the start of the buffer in which to serialize data. As output, the position just passed the serialized data. |
count_out | Output: The required buffer size, in bytes. |
store_handles | The data for each tag is preceded by a list of EntityHandles designating the entity each of the subsequent tag values corresponds to. This value may be one of: 1) If store_handles == false: An invalid handle composed of {MBMAXTYPE,idx}, where idx is the position of the entity in "whole_range". 2) If store_hanldes == true and a valid remote handle exists, the remote handle. 3) If store_hanldes == true and no valid remote handle is defined for the entity, the same as 1). |
to_proc | If 'store_handles' is true, the processor rank for which to store the corresponding remote entity handles. |
Definition at line 3556 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), ErrorCode, moab::TagInfo::get_data_type(), moab::TagInfo::get_default_value(), moab::TagInfo::get_default_value_size(), moab::TagInfo::get_name(), get_remote_handles(), moab::TagInfo::get_size(), moab::DebugOutput::get_verbosity(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TYPE_OPAQUE, MB_TYPE_OUT_OF_RANGE, MB_VARIABLE_LENGTH, mbImpl, myDebug, moab::PACK_BYTES(), moab::PACK_EH(), moab::PACK_INT(), moab::PACK_INTS(), moab::PACK_VOID(), PC, moab::Range::print(), moab::Range::size(), moab::TagInfo::size_from_data_type(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data(), moab::Interface::tag_get_type(), TagType, and moab::DebugOutput::tprintf().
Referenced by pack_tags().
{ ErrorCode result; std::vector< int > var_len_sizes; std::vector< const void* > var_len_values; if( src_tag != dst_tag ) { if( dst_tag->get_size() != src_tag->get_size() ) return MB_TYPE_OUT_OF_RANGE; if( dst_tag->get_data_type() != src_tag->get_data_type() && dst_tag->get_data_type() != MB_TYPE_OPAQUE && src_tag->get_data_type() != MB_TYPE_OPAQUE ) return MB_TYPE_OUT_OF_RANGE; } // Size, type, data type buff->check_space( 3 * sizeof( int ) ); PACK_INT( buff->buff_ptr, src_tag->get_size() ); TagType this_type; result = mbImpl->tag_get_type( dst_tag, this_type ); PACK_INT( buff->buff_ptr, (int)this_type ); DataType data_type = src_tag->get_data_type(); PACK_INT( buff->buff_ptr, (int)data_type ); int type_size = TagInfo::size_from_data_type( data_type ); // Default value if( NULL == src_tag->get_default_value() ) { buff->check_space( sizeof( int ) ); PACK_INT( buff->buff_ptr, 0 ); } else { buff->check_space( src_tag->get_default_value_size() ); PACK_BYTES( buff->buff_ptr, src_tag->get_default_value(), src_tag->get_default_value_size() ); } // Name buff->check_space( src_tag->get_name().size() ); PACK_BYTES( buff->buff_ptr, dst_tag->get_name().c_str(), dst_tag->get_name().size() ); myDebug->tprintf( 4, "Packing tag \"%s\"", src_tag->get_name().c_str() ); if( src_tag != dst_tag ) myDebug->tprintf( 4, " (as tag \"%s\")", dst_tag->get_name().c_str() ); myDebug->tprintf( 4, "\n" ); // Pack entities buff->check_space( tagged_entities.size() * sizeof( EntityHandle ) + sizeof( int ) ); PACK_INT( buff->buff_ptr, tagged_entities.size() ); std::vector< EntityHandle > dum_tagged_entities( tagged_entities.size() ); result = get_remote_handles( store_remote_handles, tagged_entities, &dum_tagged_entities[0], to_proc, whole_vec ); if( MB_SUCCESS != result ) { if( myDebug->get_verbosity() == 3 ) { std::cerr << "Failed to get remote handles for tagged entities:" << std::endl; tagged_entities.print( " " ); } MB_SET_ERR( result, "Failed to get remote handles for tagged entities" ); } PACK_EH( buff->buff_ptr, &dum_tagged_entities[0], dum_tagged_entities.size() ); const size_t num_ent = tagged_entities.size(); if( src_tag->get_size() == MB_VARIABLE_LENGTH ) { var_len_sizes.resize( num_ent, 0 ); var_len_values.resize( num_ent, 0 ); result = mbImpl->tag_get_by_ptr( src_tag, tagged_entities, &var_len_values[0], &var_len_sizes[0] );MB_CHK_SET_ERR( result, "Failed to get variable-length tag data in pack_tags" ); buff->check_space( num_ent * sizeof( int ) ); PACK_INTS( buff->buff_ptr, &var_len_sizes[0], num_ent ); for( unsigned int i = 0; i < num_ent; i++ ) { buff->check_space( var_len_sizes[i] ); PACK_VOID( buff->buff_ptr, var_len_values[i], type_size * var_len_sizes[i] ); } } else { buff->check_space( num_ent * src_tag->get_size() ); // Should be OK to read directly into buffer, since tags are untyped and // handled by memcpy result = mbImpl->tag_get_data( src_tag, tagged_entities, buff->buff_ptr );MB_CHK_SET_ERR( result, "Failed to get tag data in pack_tags" ); buff->buff_ptr += num_ent * src_tag->get_size(); PC( num_ent * src_tag->get_size(), " void" ); } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::pack_tags | ( | Range & | entities, |
const std::vector< Tag > & | src_tags, | ||
const std::vector< Tag > & | dst_tags, | ||
const std::vector< Range > & | tag_ranges, | ||
) | [private] |
Serialize entity tag data.
This function operates in two passes. The first phase, specified by 'just_count == true' calculates the necessary buffer size for the serialized data. The second phase writes the actual binary serialized representation of the data to the passed buffer.
First two arguments are not used. (Legacy interface?)
entities | NOT USED |
start_rit | NOT USED |
whole_range | Should be the union of the sets of entities for which tag values are to be serialized. Also specifies ordering for indexes for tag values and serves as the superset from which to compose entity lists from individual tags if just_count and all_possible_tags are both true. |
buff_ptr | Buffer into which to write binary serialized data |
count | Output: The size of the serialized data is added to this parameter. NOTE: Should probably initialize to zero before calling. |
just_count | If true, just calculate the buffer size required to hold the serialized data. Will also append to 'all_tags' and 'tag_ranges' if all_possible_tags == true. |
all_tags | List of tags to write |
tag_ranges | List of entities to serialize tag data, one for each corresponding tag handle in 'all_tags. |
Definition at line 3470 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), moab::Range::end(), ErrorCode, MB_SUCCESS, myDebug, moab::PACK_INT(), pack_tag(), packed_tag_size(), moab::ParallelComm::Buffer::set_stored_size(), moab::Range::size(), and moab::DebugOutput::tprintf().
Referenced by exchange_tags(), pack_buffer(), and reduce_tags().
{ ErrorCode result; std::vector< Tag >::const_iterator tag_it, dst_it; std::vector< Range >::const_iterator rit; int count = 0; for( tag_it = src_tags.begin(), rit = tag_ranges.begin(); tag_it != src_tags.end(); ++tag_it, ++rit ) { result = packed_tag_size( *tag_it, *rit, count ); if( MB_SUCCESS != result ) return result; } // Number of tags count += sizeof( int ); buff->check_space( count ); PACK_INT( buff->buff_ptr, src_tags.size() ); std::vector< EntityHandle > entities_vec( entities.size() ); std::copy( entities.begin(), entities.end(), entities_vec.begin() ); for( tag_it = src_tags.begin(), dst_it = dst_tags.begin(), rit = tag_ranges.begin(); tag_it != src_tags.end(); ++tag_it, ++dst_it, ++rit ) { result = pack_tag( *tag_it, *dst_it, *rit, entities_vec, buff, store_remote_handles, to_proc ); if( MB_SUCCESS != result ) return result; } myDebug->tprintf( 4, "Done packing tags." ); buff->set_stored_size(); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::packed_tag_size | ( | Tag | source_tag, |
int & | count_out | ||
) | [private] |
Calculate buffer size required to pack tag data.
Definition at line 3513 of file ParallelComm.cpp.
References ErrorCode, errorHandler, moab::TagInfo::get_data(), moab::TagInfo::get_default_value(), moab::TagInfo::get_default_value_size(), moab::TagInfo::get_name(), moab::TagInfo::get_size(), MB_CHK_SET_ERR, MB_SUCCESS, MB_VARIABLE_LENGTH, sequenceManager, and moab::Range::size().
{ // For dense tags, compute size assuming all entities have that tag // For sparse tags, get number of entities w/ that tag to compute size std::vector< int > var_len_sizes; std::vector< const void* > var_len_values; // Default value count += sizeof( int ); if( NULL != tag->get_default_value() ) count += tag->get_default_value_size(); // Size, type, data type count += 3 * sizeof( int ); // Name count += sizeof( int ); count += tag->get_name().size(); // Range of tag count += sizeof( int ) + tagged_entities.size() * sizeof( EntityHandle ); if( tag->get_size() == MB_VARIABLE_LENGTH ) { const int num_ent = tagged_entities.size(); // Send a tag size for each entity count += num_ent * sizeof( int ); // Send tag data for each entity var_len_sizes.resize( num_ent ); var_len_values.resize( num_ent ); ErrorCode result = tag->get_data( sequenceManager, errorHandler, tagged_entities, &var_len_values[0], &var_len_sizes[0] );MB_CHK_SET_ERR( result, "Failed to get lenghts of variable-length tag values" ); count += std::accumulate( var_len_sizes.begin(), var_len_sizes.end(), 0 ); } else { // Tag data values for range or vector count += tagged_entities.size() * tag->get_size(); } return MB_SUCCESS; }
Tag moab::ParallelComm::part_tag | ( | ) | [inline] |
Definition at line 703 of file ParallelComm.hpp.
References partition_tag().
Referenced by create_part().
{ return partition_tag(); }
Range& moab::ParallelComm::partition_sets | ( | ) | [inline] |
return partition, interface set ranges
Definition at line 665 of file ParallelComm.hpp.
References partitionSets.
Referenced by collective_sync_partition(), create_part(), moab::ReadParallel::create_partition_sets(), moab::ReadParallel::delete_nonlocal_entities(), destroy_part(), get_part_handle(), iMeshP_getLocalParts(), iMeshP_getNumLocalParts(), moab::ReadParallel::load_file(), set_partitioning(), and moab::ScdInterface::tag_shared_vertices().
{ return partitionSets; }
const Range& moab::ParallelComm::partition_sets | ( | ) | const [inline] |
Definition at line 669 of file ParallelComm.hpp.
return partitions set tag
return partition set tag
Definition at line 7975 of file ParallelComm.cpp.
References ErrorCode, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, mbImpl, PARALLEL_PARTITION_TAG_NAME, partitionTag, and moab::Interface::tag_get_handle().
Referenced by part_tag().
{ if( !partitionTag ) { int dum_id = -1; ErrorCode result = mbImpl->tag_get_handle( PARALLEL_PARTITION_TAG_NAME, 1, MB_TYPE_INTEGER, partitionTag, MB_TAG_SPARSE | MB_TAG_CREAT, &dum_id ); if( MB_SUCCESS != result ) return 0; } return partitionTag; }
Tag moab::ParallelComm::pcomm_tag | ( | Interface * | impl, |
bool | create_if_missing = true |
) | [static] |
return pcomm tag; static because might not have a pcomm before going to look for one on the interface
return pcomm tag; passes in impl 'cuz this is a static function
Definition at line 7989 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_OPAQUE, PARALLEL_COMM_TAG_NAME, and moab::Interface::tag_get_handle().
Referenced by add_pcomm(), get_all_pcomm(), get_pcomm(), remove_pcomm(), and set_partitioning().
{ Tag this_tag = 0; ErrorCode result; if( create_if_missing ) { result = impl->tag_get_handle( PARALLEL_COMM_TAG_NAME, MAX_SHARING_PROCS * sizeof( ParallelComm* ), MB_TYPE_OPAQUE, this_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); } else { result = impl->tag_get_handle( PARALLEL_COMM_TAG_NAME, MAX_SHARING_PROCS * sizeof( ParallelComm* ), MB_TYPE_OPAQUE, this_tag, MB_TAG_SPARSE ); } if( MB_SUCCESS != result ) return 0; return this_tag; }
ErrorCode moab::ParallelComm::post_irecv | ( | std::vector< unsigned int > & | exchange_procs | ) |
Post "MPI_Irecv" before meshing.
exchange_procs | processor vector exchanged |
Definition at line 6768 of file ParallelComm.cpp.
References buffProcs, get_buffers(), INITIAL_BUFF_SIZE, moab::MB_MESG_ENTS_SIZE, MB_SET_ERR, MB_SUCCESS, PRINT_DEBUG_IRECV, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recvRemotehReqs, recvReqs, remoteOwnedBuffs, reset_all_buffers(), and sendReqs.
{ // Set buffers int n_proc = exchange_procs.size(); for( int i = 0; i < n_proc; i++ ) get_buffers( exchange_procs[i] ); reset_all_buffers(); // Post ghost irecv's for entities from all communicating procs // Index requests the same as buffer/sharing procs indices int success; recvReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL ); recvRemotehReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL ); sendReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL ); int incoming = 0; for( int i = 0; i < n_proc; i++ ) { int ind = get_buffers( exchange_procs[i] ); incoming++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[ind], remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_ENTS_SIZE, incoming ); success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, buffProcs[ind], MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recvReqs[2 * ind] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv in owned entity exchange" ); } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::post_irecv | ( | std::vector< unsigned int > & | shared_procs, |
std::set< unsigned int > & | recv_procs | ||
Definition at line 6801 of file ParallelComm.cpp.
References buffProcs, get_buffers(), INITIAL_BUFF_SIZE, localOwnedBuffs, moab::MB_MESG_ENTS_SIZE, MB_SET_ERR, MB_SUCCESS, PRINT_DEBUG_IRECV, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recvRemotehReqs, recvReqs, remoteOwnedBuffs, reset_all_buffers(), and sendReqs.
{ // Set buffers int num = shared_procs.size(); for( int i = 0; i < num; i++ ) get_buffers( shared_procs[i] ); reset_all_buffers(); num = remoteOwnedBuffs.size(); for( int i = 0; i < num; i++ ) remoteOwnedBuffs[i]->set_stored_size(); num = localOwnedBuffs.size(); for( int i = 0; i < num; i++ ) localOwnedBuffs[i]->set_stored_size(); // Post ghost irecv's for entities from all communicating procs // Index requests the same as buffer/sharing procs indices int success; recvReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL ); recvRemotehReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL ); sendReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL ); int incoming = 0; std::set< unsigned int >::iterator it = recv_procs.begin(); std::set< unsigned int >::iterator eit = recv_procs.end(); for( ; it != eit; ++it ) { int ind = get_buffers( *it ); incoming++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[ind], remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_ENTS_SIZE, incoming ); success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, buffProcs[ind], MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recvReqs[2 * ind] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv in owned entity exchange" ); } } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::print_buffer | ( | unsigned char * | buff_ptr, |
int | mesg_type, | ||
int | from_proc, | ||
bool | sent | ||
) | [private] |
Definition at line 2357 of file ParallelComm.cpp.
References moab::CN::EntityTypeName(), moab::ID_FROM_HANDLE(), moab::CN::MAX_NODES_PER_ELEMENT, moab::MB_MESG_ENTS_LARGE, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_LARGE, moab::MB_MESG_REMOTEH_SIZE, moab::MB_MESG_TAGS_LARGE, moab::MB_MESG_TAGS_SIZE, MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MB_VARIABLE_LENGTH, MBENTITYSET, MBMAXTYPE, MBVERTEX, moab::ProcConfig::proc_rank(), procConfig, moab::TYPE_FROM_HANDLE(), moab::UNPACK_DBL(), moab::UNPACK_DBLS(), moab::UNPACK_EH(), moab::UNPACK_INT(), moab::UNPACK_INTS(), and moab::UNPACK_TYPE().
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), and recv_entities().
{ std::cerr << procConfig.proc_rank(); if( sent ) std::cerr << " sent"; else std::cerr << " received"; std::cerr << " message type " << mesg_tag << " to/from proc " << from_proc << "; contents:" << std::endl; int msg_length, num_ents; unsigned char* orig_ptr = buff_ptr; UNPACK_INT( buff_ptr, msg_length ); std::cerr << msg_length << " bytes..." << std::endl; if( MB_MESG_ENTS_SIZE == mesg_tag || MB_MESG_ENTS_LARGE == mesg_tag ) { // 1. # entities = E int i, j, k; std::vector< int > ps; std::vector< EntityHandle > hs; UNPACK_INT( buff_ptr, num_ents ); std::cerr << num_ents << " entities..." << std::endl; // Save place where remote handle info starts, then scan forward to ents for( i = 0; i < num_ents; i++ ) { UNPACK_INT( buff_ptr, j ); if( 0 > j ) return MB_FAILURE; ps.resize( j ); hs.resize( j ); std::cerr << "Entity " << i << ", # procs = " << j << std::endl; UNPACK_INTS( buff_ptr, &ps[0], j ); UNPACK_EH( buff_ptr, &hs[0], j ); std::cerr << " Procs: "; for( k = 0; k < j; k++ ) std::cerr << ps[k] << " "; std::cerr << std::endl; std::cerr << " Handles: "; for( k = 0; k < j; k++ ) std::cerr << hs[k] << " "; std::cerr << std::endl; if( buff_ptr - orig_ptr > msg_length ) { std::cerr << "End of buffer..." << std::endl; std::cerr.flush(); return MB_FAILURE; } } while( true ) { EntityType this_type = MBMAXTYPE; UNPACK_TYPE( buff_ptr, this_type ); assert( this_type != MBENTITYSET ); // MBMAXTYPE signifies end of entities data if( MBMAXTYPE == this_type ) break; // Get the number of ents int num_ents2, verts_per_entity = 0; UNPACK_INT( buff_ptr, num_ents2 ); // Unpack the nodes per entity if( MBVERTEX != this_type && num_ents2 ) { UNPACK_INT( buff_ptr, verts_per_entity ); } std::cerr << "Type: " << CN::EntityTypeName( this_type ) << "; num_ents = " << num_ents2; if( MBVERTEX != this_type ) std::cerr << "; verts_per_ent = " << verts_per_entity; std::cerr << std::endl; if( num_ents2 < 0 || num_ents2 > msg_length ) { std::cerr << "Wrong number of entities, returning." << std::endl; return MB_FAILURE; } for( int e = 0; e < num_ents2; e++ ) { // Check for existing entity, otherwise make new one if( MBVERTEX == this_type ) { double coords[3]; UNPACK_DBLS( buff_ptr, coords, 3 ); std::cerr << "xyz = " << coords[0] << ", " << coords[1] << ", " << coords[2] << std::endl; } else { EntityHandle connect[CN::MAX_NODES_PER_ELEMENT]; assert( verts_per_entity <= CN::MAX_NODES_PER_ELEMENT ); UNPACK_EH( buff_ptr, connect, verts_per_entity ); // Update connectivity to local handles std::cerr << "Connectivity: "; for( k = 0; k < verts_per_entity; k++ ) std::cerr << connect[k] << " "; std::cerr << std::endl; } if( buff_ptr - orig_ptr > msg_length ) { std::cerr << "End of buffer..." << std::endl; std::cerr.flush(); return MB_FAILURE; } } } } else if( MB_MESG_REMOTEH_SIZE == mesg_tag || MB_MESG_REMOTEH_LARGE == mesg_tag ) { UNPACK_INT( buff_ptr, num_ents ); std::cerr << num_ents << " entities..." << std::endl; if( 0 > num_ents || num_ents > msg_length ) { std::cerr << "Wrong number of entities, returning." << std::endl; return MB_FAILURE; } std::vector< EntityHandle > L1hloc( num_ents ), L1hrem( num_ents ); std::vector< int > L1p( num_ents ); UNPACK_INTS( buff_ptr, &L1p[0], num_ents ); UNPACK_EH( buff_ptr, &L1hrem[0], num_ents ); UNPACK_EH( buff_ptr, &L1hloc[0], num_ents ); std::cerr << num_ents << " Entity pairs; hremote/hlocal/proc: " << std::endl; for( int i = 0; i < num_ents; i++ ) { EntityType etype = TYPE_FROM_HANDLE( L1hloc[i] ); std::cerr << CN::EntityTypeName( etype ) << ID_FROM_HANDLE( L1hrem[i] ) << ", " << CN::EntityTypeName( etype ) << ID_FROM_HANDLE( L1hloc[i] ) << ", " << L1p[i] << std::endl; } if( buff_ptr - orig_ptr > msg_length ) { std::cerr << "End of buffer..." << std::endl; std::cerr.flush(); return MB_FAILURE; } } else if( mesg_tag == MB_MESG_TAGS_SIZE || mesg_tag == MB_MESG_TAGS_LARGE ) { int num_tags, dum1, data_type, tag_size; UNPACK_INT( buff_ptr, num_tags ); std::cerr << "Number of tags = " << num_tags << std::endl; for( int i = 0; i < num_tags; i++ ) { std::cerr << "Tag " << i << ":" << std::endl; UNPACK_INT( buff_ptr, tag_size ); UNPACK_INT( buff_ptr, dum1 ); UNPACK_INT( buff_ptr, data_type ); std::cerr << "Tag size, type, data type = " << tag_size << ", " << dum1 << ", " << data_type << std::endl; UNPACK_INT( buff_ptr, dum1 ); std::cerr << "Default value size = " << dum1 << std::endl; buff_ptr += dum1; UNPACK_INT( buff_ptr, dum1 ); std::string name( (char*)buff_ptr, dum1 ); std::cerr << "Tag name = " << name.c_str() << std::endl; buff_ptr += dum1; UNPACK_INT( buff_ptr, num_ents ); std::cerr << "Number of ents = " << num_ents << std::endl; std::vector< EntityHandle > tmp_buff( num_ents ); UNPACK_EH( buff_ptr, &tmp_buff[0], num_ents ); int tot_length = 0; for( int j = 0; j < num_ents; j++ ) { EntityType etype = TYPE_FROM_HANDLE( tmp_buff[j] ); std::cerr << CN::EntityTypeName( etype ) << " " << ID_FROM_HANDLE( tmp_buff[j] ) << ", tag = "; if( tag_size == MB_VARIABLE_LENGTH ) { UNPACK_INT( buff_ptr, dum1 ); tot_length += dum1; std::cerr << "(variable, length = " << dum1 << ")" << std::endl; } else if( data_type == MB_TYPE_DOUBLE ) { double dum_dbl; UNPACK_DBL( buff_ptr, dum_dbl ); std::cerr << dum_dbl << std::endl; } else if( data_type == MB_TYPE_INTEGER ) { int dum_int; UNPACK_INT( buff_ptr, dum_int ); std::cerr << dum_int << std::endl; } else if( data_type == MB_TYPE_OPAQUE ) { std::cerr << "(opaque)" << std::endl; buff_ptr += tag_size; } else if( data_type == MB_TYPE_HANDLE ) { EntityHandle dum_eh; UNPACK_EH( buff_ptr, &dum_eh, 1 ); std::cerr << dum_eh << std::endl; } else if( data_type == MB_TYPE_BIT ) { std::cerr << "(bit)" << std::endl; buff_ptr += tag_size; } } if( tag_size == MB_VARIABLE_LENGTH ) buff_ptr += tot_length; } } else { assert( false ); return MB_FAILURE; } std::cerr.flush(); return MB_SUCCESS; }
void moab::ParallelComm::print_debug_irecv | ( | int | to, |
int | from, | ||
unsigned char * | buff, | ||
int | size, | ||
int | tag, | ||
int | incoming | ||
) | [private] |
Definition at line 255 of file ParallelComm.cpp.
References moab::MB_MESG_REMOTEH_ACK, moab::MB_MESG_TAGS_ACK, myDebug, moab::DebugOutput::printf(), and moab::DebugOutput::tprintf().
{ myDebug->tprintf( 3, "Irecv, %d<-%d, buffer ptr = %p, tag=%d, size=%d", to, from, (void*)buff, tag, sz ); if( tag < MB_MESG_REMOTEH_ACK ) myDebug->printf( 3, ", incoming1=%d\n", incoming ); else if( tag < MB_MESG_TAGS_ACK ) myDebug->printf( 3, ", incoming2=%d\n", incoming ); else myDebug->printf( 3, ", incoming=%d\n", incoming ); }
void moab::ParallelComm::print_debug_isend | ( | int | from, |
int | to, | ||
int | tag, | ||
int | size | ||
) | [private] |
Definition at line 250 of file ParallelComm.cpp.
References myDebug, and moab::DebugOutput::tprintf().
void moab::ParallelComm::print_debug_recd | ( | MPI_Status | status | ) | [private] |
Definition at line 266 of file ParallelComm.cpp.
References moab::DebugOutput::get_verbosity(), myDebug, and moab::DebugOutput::tprintf().
{ if( myDebug->get_verbosity() == 3 ) { int this_count; int success = MPI_Get_count( &status, MPI_UNSIGNED_CHAR, &this_count ); if( MPI_SUCCESS != success ) this_count = -1; myDebug->tprintf( 3, "Received from %d, count = %d, tag = %d\n", status.MPI_SOURCE, this_count, status.MPI_TAG ); } }
void moab::ParallelComm::print_debug_waitany | ( | std::vector< MPI_Request > & | reqs, |
int | tag, | ||
int | proc | ||
) | [private] |
Definition at line 278 of file ParallelComm.cpp.
References moab::DebugOutput::get_verbosity(), moab::MB_MESG_REMOTEH_ACK, moab::MB_MESG_TAGS_ACK, myDebug, moab::DebugOutput::print(), moab::DebugOutput::printf(), and moab::DebugOutput::tprintf().
{ if( myDebug->get_verbosity() == 3 ) { myDebug->tprintf( 3, "Waitany, p=%d, ", proc ); if( tag < MB_MESG_REMOTEH_ACK ) myDebug->print( 3, ", recv_ent_reqs=" ); else if( tag < MB_MESG_TAGS_ACK ) myDebug->print( 3, ", recv_remoteh_reqs=" ); else myDebug->print( 3, ", recv_tag_reqs=" ); for( unsigned int i = 0; i < reqs.size(); i++ ) myDebug->printf( 3, " %p", (void*)(intptr_t)reqs[i] ); myDebug->print( 3, "\n" ); } }
void moab::ParallelComm::print_pstatus | ( | unsigned char | pstat, |
std::string & | ostr | ||
print contents of pstatus value in human-readable form
Definition at line 9316 of file ParallelComm.cpp.
References ppstat, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, and PSTATUS_SHARED.
Referenced by print_pstatus().
{ std::ostringstream str; int num = 0; #define ppstat( a, b ) \ { \ if( pstat & ( a ) ) \ { \ if( num ) str << ", "; \ str << ( b ); \ num++; \ } \ } ppstat( PSTATUS_NOT_OWNED, "NOT_OWNED" ); ppstat( PSTATUS_SHARED, "SHARED" ); ppstat( PSTATUS_MULTISHARED, "MULTISHARED" ); ppstat( PSTATUS_INTERFACE, "INTERFACE" ); ppstat( PSTATUS_GHOST, "GHOST" ); ostr = str.str(); }
void moab::ParallelComm::print_pstatus | ( | unsigned char | pstat | ) |
print contents of pstatus value in human-readable form to std::cut
Definition at line 9339 of file ParallelComm.cpp.
References print_pstatus().
{ std::string str; print_pstatus( pstat, str ); std::cout << str.c_str() << std::endl; }
const ProcConfig& moab::ParallelComm::proc_config | ( | ) | const [inline] |
Get proc config for this communication object.
Definition at line 633 of file ParallelComm.hpp.
References procConfig.
Referenced by moab::MeshOutputFunctor::assign_global_ids(), check_clean_iface(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), collective_sync_partition(), comm(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), moab::ParCommGraph::compute_partition(), create_coarse_mesh(), moab::WriteHDF5Parallel::create_dataset(), create_fine_mesh(), create_interface_sets(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperGCRM::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::WriteHDF5Parallel::create_meshset_tables(), create_part(), moab::ReadParallel::create_partition_sets(), moab::WriteHDF5Parallel::create_tag_tables(), moab::WriteHDF5Parallel::debug_barrier_line(), moab::ReadParallel::delete_nonlocal_entities(), moab::Coupler::do_normalization(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ReadHDF5::find_sets_containing(), gather_data(), moab::ParallelData::get_interface_sets(), moab::Coupler::get_matching_entities(), get_owner_handle(), get_owning_part(), get_part_handle(), get_part_id(), get_proc_nvecs(), moab::ScdInterface::get_shared_vertices(), get_sharing_parts(), iMeshP_getNumOfTopoAll(), iMeshP_getNumOfTypeAll(), iMeshP_getPartitionComm(), iMOAB_SetDoubleTagStorageWithGid(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::Coupler::initialize_tree(), moab::DataCoupler::interpolate(), moab::Coupler::interpolate(), intersection_at_level(), moab::ReadParallel::load_file(), moab::ReadDamsel::load_file(), moab::Coupler::locate_points(), main(), moab::WriteHDF5Parallel::negotiate_type_list(), pack_shared_handles(), moab::WriteHDF5Parallel::parallel_create_file(), moab::WriteHDF5Parallel::print_times(), moab::ReadHDF5::print_times(), rank(), moab::ReadHDF5::read_all_set_meta(), moab::ReadParallel::ReadParallel(), moab::RefinerTagManager::RefinerTagManager(), resolve_shared_ents(), resolve_shared_sets(), moab::ReadHDF5::set_up_read(), size(), moab::ScdInterface::tag_shared_vertices(), tag_shared_verts(), test_intx_in_parallel_elem_based(), update_remote_data_old(), and moab::NCWriteHelper::write_set_variables().
{ return procConfig; }
ProcConfig& moab::ParallelComm::proc_config | ( | ) | [inline] |
Definition at line 639 of file ParallelComm.hpp.
return pstatus tag
Definition at line 7961 of file ParallelComm.cpp.
References ErrorCode, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_OPAQUE, mbImpl, PARALLEL_STATUS_TAG_NAME, pstatusTag, and moab::Interface::tag_get_handle().
Referenced by assign_global_ids(), check_clean_iface(), check_sent_ents(), clean_shared_tags(), correct_thin_ghost_layers(), count_owned(), filter_pstatus(), get_owner_handle(), get_owning_part(), get_pstatus(), get_pstatus_entities(), get_shared_proc_tags(), get_sharing_data(), get_sharing_parts(), iMeshP_getEntStatusArr(), pack_entities(), set_pstatus_entities(), set_sharing_data(), tag_iface_entities(), and update_remote_data_old().
{ if( !pstatusTag ) { unsigned char tmp_pstatus = 0; ErrorCode result = mbImpl->tag_get_handle( PARALLEL_STATUS_TAG_NAME, 1, MB_TYPE_OPAQUE, pstatusTag, MB_TAG_DENSE | MB_TAG_CREAT, &tmp_pstatus ); if( MB_SUCCESS != result ) return 0; } return pstatusTag; }
unsigned moab::ParallelComm::rank | ( | ) | const [inline] |
Definition at line 644 of file ParallelComm.hpp.
References proc_config(), and moab::ProcConfig::proc_rank().
Referenced by augment_default_sets_with_ghosts(), check_my_shared_handles(), moab::ParCommGraph::compute_partition(), moab::ScdInterface::construct_box(), correct_thin_ghost_layers(), gather_data(), iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_DuplicateAppMesh(), moab::ReadParallel::load_file(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), resolve_shared_ents(), set_sharing_data(), unpack_entities(), and update_remote_data().
{ return proc_config().proc_rank(); }
ErrorCode moab::ParallelComm::recv_buffer | ( | int | mesg_tag_expected, |
const MPI_Status & | mpi_status, | ||
Buffer * | recv_buff, | ||
MPI_Request & | recv_2nd_req, | ||
MPI_Request & | ack_req, | ||
int & | this_incoming, | ||
Buffer * | send_buff, | ||
MPI_Request & | send_req, | ||
MPI_Request & | sent_ack_req, | ||
bool & | done, | ||
Buffer * | next_buff = NULL , |
int | next_tag = -1 , |
MPI_Request * | next_req = NULL , |
int * | next_incoming = NULL |
) | [private] |
process incoming message; if longer than the initial size, post recv for next part then send ack; if ack, send second part; else indicate that we're done and buffer is ready for processing
Definition at line 6139 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::alloc_size, moab::ParallelComm::Buffer::get_stored_size(), INITIAL_BUFF_SIZE, MB_SET_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, PRINT_DEBUG_IRECV, PRINT_DEBUG_ISEND, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, moab::ParallelComm::Buffer::reserve(), and moab::ParallelComm::Buffer::reset_ptr().
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), recv_entities(), recv_messages(), recv_remote_handle_messages(), reduce_tags(), send_recv_entities(), and settle_intersection_points().
{ // Process a received message; if there will be more coming, // post a receive for 2nd part then send an ack message int from_proc = mpi_status.MPI_SOURCE; int success; // Set the buff_ptr on the recv_buffer; needs to point beyond any // valid data already in the buffer recv_buff->reset_ptr( std::min( recv_buff->get_stored_size(), (int)recv_buff->alloc_size ) ); if( mpi_status.MPI_TAG == mesg_tag_expected && recv_buff->get_stored_size() > (int)INITIAL_BUFF_SIZE ) { // 1st message & large - allocate buffer, post irecv for 2nd message, // then send ack recv_buff->reserve( recv_buff->get_stored_size() ); assert( recv_buff->alloc_size > INITIAL_BUFF_SIZE ); // Will expect a 2nd message this_incoming++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), from_proc, recv_buff->mem_ptr + INITIAL_BUFF_SIZE, recv_buff->get_stored_size() - INITIAL_BUFF_SIZE, mesg_tag_expected + 1, this_incoming ); success = MPI_Irecv( recv_buff->mem_ptr + INITIAL_BUFF_SIZE, recv_buff->get_stored_size() - INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, from_proc, mesg_tag_expected + 1, procConfig.proc_comm(), &recv_req ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post 2nd iRecv in ghost exchange" ); } // Send ack, doesn't matter what data actually is PRINT_DEBUG_ISEND( procConfig.proc_rank(), from_proc, recv_buff->mem_ptr, mesg_tag_expected - 1, sizeof( int ) ); success = MPI_Isend( recv_buff->mem_ptr, sizeof( int ), MPI_UNSIGNED_CHAR, from_proc, mesg_tag_expected - 1, procConfig.proc_comm(), &sent_ack_req ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to send ack in ghost exchange" ); } } else if( mpi_status.MPI_TAG == mesg_tag_expected - 1 ) { // Got an ack back, send the 2nd half of message // Should be a large message if we got this assert( *( (size_t*)send_buff->mem_ptr ) > INITIAL_BUFF_SIZE ); // Post irecv for next message, then send 2nd message if( next_buff ) { // We'll expect a return message ( *next_incoming )++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), from_proc, next_buff->mem_ptr, INITIAL_BUFF_SIZE, next_tag, *next_incoming ); success = MPI_Irecv( next_buff->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, from_proc, next_tag, procConfig.proc_comm(), next_req ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post next irecv in ghost exchange" ); } } // Send 2nd message PRINT_DEBUG_ISEND( procConfig.proc_rank(), from_proc, send_buff->mem_ptr + INITIAL_BUFF_SIZE, mesg_tag_expected + 1, send_buff->get_stored_size() - INITIAL_BUFF_SIZE ); assert( send_buff->get_stored_size() - INITIAL_BUFF_SIZE < send_buff->alloc_size && 0 <= send_buff->get_stored_size() ); success = MPI_Isend( send_buff->mem_ptr + INITIAL_BUFF_SIZE, send_buff->get_stored_size() - INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, from_proc, mesg_tag_expected + 1, procConfig.proc_comm(), &send_req ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to send 2nd message in ghost exchange" ); } } else if( ( mpi_status.MPI_TAG == mesg_tag_expected && recv_buff->get_stored_size() <= (int)INITIAL_BUFF_SIZE ) || mpi_status.MPI_TAG == mesg_tag_expected + 1 ) { // Message completely received - signal that we're done done = true; } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::recv_entities | ( | const int | from_proc, |
Range & | final_ents, | ||
int & | incomming1, | ||
int & | incoming2, | ||
std::vector< std::vector< EntityHandle > > & | L1hloc, | ||
std::vector< std::vector< EntityHandle > > & | L1hrem, | ||
std::vector< std::vector< int > > & | L1p, | ||
std::vector< EntityHandle > & | L2hloc, | ||
std::vector< EntityHandle > & | L2hrem, | ||
std::vector< unsigned int > & | L2p, | ||
std::vector< MPI_Request > & | recv_remoteh_reqs, | ||
bool | wait_all = true |
Receive entities from another processor, optionally waiting until it's done.
Receive entities from another processor, with adjs, sets, and tags. If store_remote_handles is true, this call sends back handles assigned to the entities received.
from_proc | Source processor |
store_remote_handles | If true, send message with new entity handles to source processor (currently unsupported) |
final_ents | Range containing all entities received |
incoming | keep track if any messages are coming to this processor (newly added) |
wait_all | If true, wait until all messages received/sent complete |
Definition at line 1075 of file ParallelComm.cpp.
References get_buffers(), INITIAL_BUFF_SIZE, moab::MB_MESG_ENTS_SIZE, MB_SET_ERR, PRINT_DEBUG_IRECV, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recv_messages(), recvReqs, and remoteOwnedBuffs.
{ #ifndef MOAB_HAVE_MPI return MB_FAILURE; #else // Non-blocking receive for the first message (having size info) int ind1 = get_buffers( from_proc ); incoming1++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), from_proc, remoteOwnedBuffs[ind1]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_ENTS_SIZE, incoming1 ); int success = MPI_Irecv( remoteOwnedBuffs[ind1]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, from_proc, MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recvReqs[2 * ind1] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv in ghost exchange" ); } // Receive messages in while loop return recv_messages( from_proc, store_remote_handles, is_iface, final_ents, incoming1, incoming2, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, recv_remoteh_reqs ); #endif }
ErrorCode moab::ParallelComm::recv_entities | ( | std::set< unsigned int > & | recv_procs, |
int | incoming1, | ||
int | incoming2, | ||
const bool | migrate = false |
Definition at line 1111 of file ParallelComm.cpp.
References ackbuff, assign_entities_part(), buffProcs, ErrorCode, get_buffers(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, localOwnedBuffs, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SET_ERR, MB_SUCCESS, MPE_Log_event, moab::msgs, myDebug, pack_remote_handles(), print_buffer(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), recvRemotehReqs, recvReqs, remoteOwnedBuffs, send_buffer(), sendReqs, moab::DebugOutput::tprintf(), unpack_buffer(), and unpack_remote_handles().
{ //=========================================== // Receive/unpack new entities //=========================================== // Number of incoming messages is the number of procs we communicate with int success, ind, i; ErrorCode result; MPI_Status status; std::vector< std::vector< EntityHandle > > recd_ents( buffProcs.size() ); std::vector< std::vector< EntityHandle > > L1hloc( buffProcs.size() ), L1hrem( buffProcs.size() ); std::vector< std::vector< int > > L1p( buffProcs.size() ); std::vector< EntityHandle > L2hloc, L2hrem; std::vector< unsigned int > L2p; std::vector< EntityHandle > new_ents; while( incoming1 ) { // Wait for all recvs of ents before proceeding to sending remote handles, // b/c some procs may have sent to a 3rd proc ents owned by me; PRINT_DEBUG_WAITANY( recvReqs, MB_MESG_ENTS_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 2 * buffProcs.size(), &recvReqs[0], &ind, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in owned entity exchange" ); } PRINT_DEBUG_RECD( status ); // OK, received something; decrement incoming counter incoming1--; bool done = false; // In case ind is for ack, we need index of one before it unsigned int base_ind = 2 * ( ind / 2 ); result = recv_buffer( MB_MESG_ENTS_SIZE, status, remoteOwnedBuffs[ind / 2], recvReqs[ind], recvReqs[ind + 1], incoming1, localOwnedBuffs[ind / 2], sendReqs[base_ind], sendReqs[base_ind + 1], done, ( store_remote_handles ? localOwnedBuffs[ind / 2] : NULL ), MB_MESG_REMOTEH_SIZE, &recvRemotehReqs[base_ind], &incoming2 );MB_CHK_SET_ERR( result, "Failed to receive buffer" ); if( done ) { if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *remoteOwnedBuffs[ind / 2] ); } // Message completely received - process buffer that was sent remoteOwnedBuffs[ind / 2]->reset_ptr( sizeof( int ) ); result = unpack_buffer( remoteOwnedBuffs[ind / 2]->buff_ptr, store_remote_handles, buffProcs[ind / 2], ind / 2, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents, true ); if( MB_SUCCESS != result ) { std::cout << "Failed to unpack entities. Buffer contents:" << std::endl; print_buffer( remoteOwnedBuffs[ind / 2]->mem_ptr, MB_MESG_ENTS_SIZE, buffProcs[ind / 2], false ); return result; } if( recvReqs.size() != 2 * buffProcs.size() ) { // Post irecv's for remote handles from new proc recvRemotehReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL ); for( i = recvReqs.size(); i < (int)( 2 * buffProcs.size() ); i += 2 ) { localOwnedBuffs[i / 2]->reset_buffer(); incoming2++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[i / 2], localOwnedBuffs[i / 2]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_REMOTEH_SIZE, incoming2 ); success = MPI_Irecv( localOwnedBuffs[i / 2]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, buffProcs[i / 2], MB_MESG_REMOTEH_SIZE, procConfig.proc_comm(), &recvRemotehReqs[i] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv for remote handles in ghost exchange" ); } } recvReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL ); sendReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL ); } } } // Assign and remove newly created elements from/to receive processor result = assign_entities_part( new_ents, procConfig.proc_rank() );MB_CHK_SET_ERR( result, "Failed to assign entities to part" ); if( migrate ) { // result = remove_entities_part(allsent, procConfig.proc_rank());MB_CHK_SET_ERR(ressult, // "Failed to remove entities to part"); } // Add requests for any new addl procs if( recvReqs.size() != 2 * buffProcs.size() ) { // Shouldn't get here... MB_SET_ERR( MB_FAILURE, "Requests length doesn't match proc count in entity exchange" ); } #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( ENTITIES_END, procConfig.proc_rank(), "Ending recv entities." ); } #endif //=========================================== // Send local handles for new entity to owner //=========================================== std::set< unsigned int >::iterator it = recv_procs.begin(); std::set< unsigned int >::iterator eit = recv_procs.end(); for( ; it != eit; ++it ) { ind = get_buffers( *it ); // Reserve space on front for size and for initial buff size remoteOwnedBuffs[ind]->reset_buffer( sizeof( int ) ); result = pack_remote_handles( L1hloc[ind], L1hrem[ind], L1p[ind], buffProcs[ind], remoteOwnedBuffs[ind] );MB_CHK_SET_ERR( result, "Failed to pack remote handles" ); remoteOwnedBuffs[ind]->set_stored_size(); if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *remoteOwnedBuffs[ind] ); } result = send_buffer( buffProcs[ind], remoteOwnedBuffs[ind], MB_MESG_REMOTEH_SIZE, sendReqs[2 * ind], recvRemotehReqs[2 * ind + 1], &ackbuff, incoming2 );MB_CHK_SET_ERR( result, "Failed to send remote handles" ); } //=========================================== // Process remote handles of my ghosteds //=========================================== while( incoming2 ) { PRINT_DEBUG_WAITANY( recvRemotehReqs, MB_MESG_REMOTEH_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 2 * buffProcs.size(), &recvRemotehReqs[0], &ind, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in owned entity exchange" ); } // OK, received something; decrement incoming counter incoming2--; PRINT_DEBUG_RECD( status ); bool done = false; unsigned int base_ind = 2 * ( ind / 2 ); result = recv_buffer( MB_MESG_REMOTEH_SIZE, status, localOwnedBuffs[ind / 2], recvRemotehReqs[ind], recvRemotehReqs[ind + 1], incoming2, remoteOwnedBuffs[ind / 2], sendReqs[base_ind], sendReqs[base_ind + 1], done );MB_CHK_SET_ERR( result, "Failed to receive remote handles" ); if( done ) { // Incoming remote handles if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *localOwnedBuffs[ind] ); } localOwnedBuffs[ind / 2]->reset_ptr( sizeof( int ) ); result = unpack_remote_handles( buffProcs[ind / 2], localOwnedBuffs[ind / 2]->buff_ptr, L2hloc, L2hrem, L2p );MB_CHK_SET_ERR( result, "Failed to unpack remote handles" ); } } #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( RHANDLES_END, procConfig.proc_rank(), "Ending remote handles." ); MPE_Log_event( OWNED_END, procConfig.proc_rank(), "Ending recv entities (still doing checks)." ); } #endif myDebug->tprintf( 1, "Exiting recv_entities.\n" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::recv_messages | ( | const int | from_proc, |
const bool | store_remote_handles, | ||
const bool | is_iface, | ||
int & | incoming1, | ||
std::vector< MPI_Request > & | recv_remoteh_reqs | ||
Receive messages from another processor in while loop.
Receive messages from another processor.
Definition at line 1292 of file ParallelComm.cpp.
References buffProcs, ErrorCode, get_buffers(), localOwnedBuffs, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, moab::MB_MESG_TAGS_SIZE, MB_SET_ERR, MB_SUCCESS, pack_remote_handles(), PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), recvReqs, remoteOwnedBuffs, send_buffer(), sendReqs, and unpack_buffer().
Referenced by recv_entities().
{ #ifndef MOAB_HAVE_MPI return MB_FAILURE; #else MPI_Status status; ErrorCode result; int ind1 = get_buffers( from_proc ); int success, ind2; std::vector< EntityHandle > new_ents; // Wait and receive messages while( incoming1 ) { PRINT_DEBUG_WAITANY( recvReqs, MB_MESG_TAGS_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 2, &recvReqs[2 * ind1], &ind2, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in recv_messages" ); } PRINT_DEBUG_RECD( status ); // OK, received something; decrement incoming counter incoming1--; bool done = false; // In case ind is for ack, we need index of one before it ind2 += 2 * ind1; unsigned int base_ind = 2 * ( ind2 / 2 ); result = recv_buffer( MB_MESG_ENTS_SIZE, status, remoteOwnedBuffs[ind2 / 2], // recvbuff, recvReqs[ind2], recvReqs[ind2 + 1], incoming1, localOwnedBuffs[ind2 / 2], sendReqs[base_ind], sendReqs[base_ind + 1], done, ( !is_iface && store_remote_handles ? localOwnedBuffs[ind2 / 2] : NULL ), MB_MESG_REMOTEH_SIZE, &recv_remoteh_reqs[base_ind], &incoming2 );MB_CHK_SET_ERR( result, "Failed to receive buffer" ); if( done ) { // If it is done, unpack buffer remoteOwnedBuffs[ind2 / 2]->reset_ptr( sizeof( int ) ); result = unpack_buffer( remoteOwnedBuffs[ind2 / 2]->buff_ptr, store_remote_handles, from_proc, ind2 / 2, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents );MB_CHK_SET_ERR( result, "Failed to unpack buffer in recev_messages" ); std::copy( new_ents.begin(), new_ents.end(), range_inserter( final_ents ) ); // Send local handles for new elements to owner // Reserve space on front for size and for initial buff size remoteOwnedBuffs[ind2 / 2]->reset_buffer( sizeof( int ) ); result = pack_remote_handles( L1hloc[ind2 / 2], L1hrem[ind2 / 2], L1p[ind2 / 2], from_proc, remoteOwnedBuffs[ind2 / 2] );MB_CHK_SET_ERR( result, "Failed to pack remote handles" ); remoteOwnedBuffs[ind2 / 2]->set_stored_size(); result = send_buffer( buffProcs[ind2 / 2], remoteOwnedBuffs[ind2 / 2], MB_MESG_REMOTEH_SIZE, sendReqs[ind2], recv_remoteh_reqs[ind2 + 1], (int*)( localOwnedBuffs[ind2 / 2]->mem_ptr ), //&ackbuff, incoming2 );MB_CHK_SET_ERR( result, "Failed to send remote handles" ); } } return MB_SUCCESS; #endif }
ErrorCode moab::ParallelComm::recv_remote_handle_messages | ( | const int | from_proc, |
Definition at line 1370 of file ParallelComm.cpp.
References buffProcs, ErrorCode, get_buffers(), localOwnedBuffs, MB_CHK_SET_ERR, moab::MB_MESG_REMOTEH_SIZE, MB_SET_ERR, MB_SUCCESS, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), remoteOwnedBuffs, sendReqs, and unpack_remote_handles().
{ #ifndef MOAB_HAVE_MPI return MB_FAILURE; #else MPI_Status status; ErrorCode result; int ind1 = get_buffers( from_proc ); int success, ind2; while( incoming2 ) { PRINT_DEBUG_WAITANY( recv_remoteh_reqs, MB_MESG_REMOTEH_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 2, &recv_remoteh_reqs[2 * ind1], &ind2, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in recv_remote_handle_messages" ); } // OK, received something; decrement incoming counter incoming2--; PRINT_DEBUG_RECD( status ); bool done = false; ind2 += 2 * ind1; unsigned int base_ind = 2 * ( ind2 / 2 ); result = recv_buffer( MB_MESG_REMOTEH_SIZE, status, localOwnedBuffs[ind2 / 2], recv_remoteh_reqs[ind2], recv_remoteh_reqs[ind2 + 1], incoming2, remoteOwnedBuffs[ind2 / 2], sendReqs[base_ind], sendReqs[base_ind + 1], done );MB_CHK_SET_ERR( result, "Failed to receive remote handles" ); if( done ) { // Incoming remote handles localOwnedBuffs[ind2 / 2]->reset_ptr( sizeof( int ) ); result = unpack_remote_handles( buffProcs[ind2 / 2], localOwnedBuffs[ind2 / 2]->buff_ptr, L2hloc, L2hrem, L2p );MB_CHK_SET_ERR( result, "Failed to unpack remote handles" ); } } return MB_SUCCESS; #endif }
ErrorCode moab::ParallelComm::reduce | ( | const MPI_Op | mpi_op, |
int | num_ents, | ||
void * | old_vals, | ||
void * | new_vals | ||
) | [private] |
Definition at line 3843 of file ParallelComm.cpp.
References MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, and T.
{ T* old_tmp = reinterpret_cast< T* >( old_vals ); // T *new_tmp = reinterpret_cast<T*>(new_vals); // new vals pointer needs to be aligned , some compilers will optimize and will shift std::vector< T > new_values; new_values.resize( num_ents ); memcpy( &new_values[0], new_vals, num_ents * sizeof( T ) ); T* new_tmp = &new_values[0]; if( mpi_op == MPI_SUM ) std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, ADD< T > ); else if( mpi_op == MPI_PROD ) std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, MULT< T > ); else if( mpi_op == MPI_MAX ) std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, MAX< T > ); else if( mpi_op == MPI_MIN ) std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, MIN< T > ); else if( mpi_op == MPI_LAND ) std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, LAND< T > ); else if( mpi_op == MPI_LOR ) std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, LOR< T > ); else if( mpi_op == MPI_LXOR ) std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, LXOR< T > ); else if( mpi_op == MPI_BAND || mpi_op == MPI_BOR || mpi_op == MPI_BXOR ) { std::cerr << "Bitwise operations not allowed in tag reductions." << std::endl; return MB_FAILURE; } else if( mpi_op != MPI_OP_NULL ) { std::cerr << "Unknown MPI operation type." << std::endl; return MB_TYPE_OUT_OF_RANGE; } // copy now the result back where it should be memcpy( new_vals, new_tmp, num_ents * sizeof( T ) ); std::vector< T >().swap( new_values ); // way to release allocated vector return MB_SUCCESS; }
ErrorCode moab::ParallelComm::reduce_tags | ( | const std::vector< Tag > & | src_tags, |
const MPI_Op | mpi_op, | ||
const Range & | entities | ||
Perform data reduction operation for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If this version is called, all ghosted/shared entities should have a value for this tag (or the tag should have a default value). Operation is any MPI_Op, with result stored in destination tag.
src_tags | Vector of tag handles to be reduced |
dst_tags | Vector of tag handles in which the answer will be stored |
mpi_op | Operation type |
entities | Entities on which reduction will be made; if empty, operates on all shared entities |
Definition at line 7713 of file ParallelComm.cpp.
References buffProcs, moab::Range::empty(), entities, ErrorCode, filter_pstatus(), get_comm_procs(), moab::Interface::get_entities_by_type_and_tag(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, moab::intersect(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_TAGS_SIZE, MB_SET_ERR, MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, mbImpl, MBMAXTYPE, myDebug, pack_tags(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_SHARED, recv_buffer(), remoteOwnedBuffs, reset_all_buffers(), send_buffer(), sendReqs, sharedEnts, moab::Range::size(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), and unpack_tags().
Referenced by iMOAB_ReduceTagsMax(), main(), and reduce_tags().
{ ErrorCode result; int success; myDebug->tprintf( 1, "Entering reduce_tags\n" ); // Check that restrictions are met: number of source/dst tags... if( src_tags.size() != dst_tags.size() ) { MB_SET_ERR( MB_FAILURE, "Source and destination tag handles must be specified for reduce_tags" ); } // ... tag data types std::vector< Tag >::const_iterator vits, vitd; int tags_size, tagd_size; DataType tags_type, tagd_type; std::vector< unsigned char > vals; std::vector< int > tags_sizes; for( vits = src_tags.begin(), vitd = dst_tags.begin(); vits != src_tags.end(); ++vits, ++vitd ) { // Checks on tag characteristics result = mbImpl->tag_get_data_type( *vits, tags_type );MB_CHK_SET_ERR( result, "Failed to get src tag data type" ); if( tags_type != MB_TYPE_INTEGER && tags_type != MB_TYPE_DOUBLE && tags_type != MB_TYPE_BIT ) { MB_SET_ERR( MB_FAILURE, "Src/dst tags must have integer, double, or bit data type" ); } result = mbImpl->tag_get_bytes( *vits, tags_size );MB_CHK_SET_ERR( result, "Failed to get src tag bytes" ); vals.resize( tags_size ); result = mbImpl->tag_get_default_value( *vits, &vals[0] );MB_CHK_SET_ERR( result, "Src tag must have default value" ); tags_sizes.push_back( tags_size ); // OK, those passed; now check whether dest tags, if specified, agree with src tags if( *vits == *vitd ) continue; result = mbImpl->tag_get_bytes( *vitd, tagd_size );MB_CHK_SET_ERR( result, "Coudln't get dst tag bytes" ); if( tags_size != tagd_size ) { MB_SET_ERR( MB_FAILURE, "Sizes between src and dst tags don't match" ); } result = mbImpl->tag_get_data_type( *vitd, tagd_type );MB_CHK_SET_ERR( result, "Coudln't get dst tag data type" ); if( tags_type != tagd_type ) { MB_SET_ERR( MB_FAILURE, "Src and dst tags must be of same data type" ); } } // Get all procs interfacing to this proc std::set< unsigned int > exch_procs; result = get_comm_procs( exch_procs ); // Post ghost irecv's for all interface procs // Index requests the same as buffer/sharing procs indices std::vector< MPI_Request > recv_tag_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL ); std::vector< unsigned int >::iterator sit; int ind; reset_all_buffers(); int incoming = 0; for( ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); ++sit, ind++ ) { incoming++; PRINT_DEBUG_IRECV( *sit, procConfig.proc_rank(), remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_TAGS_SIZE, incoming ); success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, *sit, MB_MESG_TAGS_SIZE, procConfig.proc_comm(), &recv_tag_reqs[3 * ind] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv in ghost exchange" ); } } // Pack and send tags from this proc to others // Make sendReqs vector to simplify initialization sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); // Take all shared entities if incoming list is empty Range entities; if( entities_in.empty() ) std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( entities ) ); else entities = entities_in; // If the tags are different, copy the source to the dest tag locally std::vector< Tag >::const_iterator vit = src_tags.begin(), vit2 = dst_tags.begin(); std::vector< int >::const_iterator vsizes = tags_sizes.begin(); for( ; vit != src_tags.end(); ++vit, ++vit2, ++vsizes ) { if( *vit == *vit2 ) continue; vals.resize( entities.size() * ( *vsizes ) ); result = mbImpl->tag_get_data( *vit, entities, &vals[0] );MB_CHK_SET_ERR( result, "Didn't get data properly" ); result = mbImpl->tag_set_data( *vit2, entities, &vals[0] );MB_CHK_SET_ERR( result, "Didn't set data properly" ); } int dum_ack_buff; for( ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); ++sit, ind++ ) { Range tag_ents = entities; // Get ents shared by proc *sit result = filter_pstatus( tag_ents, PSTATUS_SHARED, PSTATUS_AND, *sit );MB_CHK_SET_ERR( result, "Failed pstatus AND check" ); // Pack-send std::vector< Range > tag_ranges; for( vit = src_tags.begin(); vit != src_tags.end(); ++vit ) { const void* ptr; int sz; if( mbImpl->tag_get_default_value( *vit, ptr, sz ) != MB_SUCCESS ) { Range tagged_ents; mbImpl->get_entities_by_type_and_tag( 0, MBMAXTYPE, &*vit, 0, 1, tagged_ents ); tag_ranges.push_back( intersect( tag_ents, tagged_ents ) ); } else tag_ranges.push_back( tag_ents ); } // Pack the data // Reserve space on front for size and for initial buff size localOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); result = pack_tags( tag_ents, src_tags, dst_tags, tag_ranges, localOwnedBuffs[ind], true, *sit );MB_CHK_SET_ERR( result, "Failed to count buffer in pack_send_tag" ); // Now send it result = send_buffer( *sit, localOwnedBuffs[ind], MB_MESG_TAGS_SIZE, sendReqs[3 * ind], recv_tag_reqs[3 * ind + 2], &dum_ack_buff, incoming );MB_CHK_SET_ERR( result, "Failed to send buffer" ); } // Receive/unpack tags while( incoming ) { MPI_Status status; int index_in_recv_requests; PRINT_DEBUG_WAITANY( recv_tag_reqs, MB_MESG_TAGS_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 3 * buffProcs.size(), &recv_tag_reqs[0], &index_in_recv_requests, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in ghost exchange" ); } ind = index_in_recv_requests / 3; PRINT_DEBUG_RECD( status ); // OK, received something; decrement incoming counter incoming--; bool done = false; std::vector< EntityHandle > dum_vec; result = recv_buffer( MB_MESG_TAGS_SIZE, status, remoteOwnedBuffs[ind], recv_tag_reqs[3 * ind + 1], // This is for receiving the second message recv_tag_reqs[3 * ind + 2], // This would be for ack, but it is not // used; consider removing it incoming, localOwnedBuffs[ind], sendReqs[3 * ind + 1], // Send request for sending the second message sendReqs[3 * ind + 2], // This is for sending the ack done );MB_CHK_SET_ERR( result, "Failed to resize recv buffer" ); if( done ) { remoteOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); result = unpack_tags( remoteOwnedBuffs[ind]->buff_ptr, dum_vec, true, buffProcs[ind], &mpi_op );MB_CHK_SET_ERR( result, "Failed to recv-unpack-tag message" ); } } // OK, now wait if( myDebug->get_verbosity() == 5 ) { success = MPI_Barrier( procConfig.proc_comm() ); } else { MPI_Status status[3 * MAX_SHARING_PROCS]; success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], status ); } if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failure in waitall in tag exchange" ); } myDebug->tprintf( 1, "Exiting reduce_tags" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::reduce_tags | ( | const char * | tag_name, |
) | [inline] |
Perform data reduction operation for all shared and ghosted entities Same as std::vector variant except for one tag specified by name.
tag_name | Name of tag to be reduced |
Definition at line 1611 of file ParallelComm.hpp.
References ErrorCode, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_OPAQUE, mbImpl, reduce_tags(), and moab::Interface::tag_get_handle().
{ // get the tag handle std::vector< Tag > tags( 1 ); ErrorCode result = mbImpl->tag_get_handle( tag_name, 0, MB_TYPE_OPAQUE, tags[0], MB_TAG_ANY ); if( MB_SUCCESS != result ) return result; else if( !tags[0] ) return MB_TAG_NOT_FOUND; return reduce_tags( tags, tags, mpi_op, entities ); }
ErrorCode moab::ParallelComm::reduce_tags | ( | Tag | tag_handle, |
) | [inline] |
Perform data reduction operation for all shared and ghosted entities Same as std::vector variant except for one tag specified by handle.
Definition at line 1624 of file ParallelComm.hpp.
References reduce_tags().
{ // get the tag handle std::vector< Tag > tags; tags.push_back( tagh ); return reduce_tags( tags, tags, mpi_op, entities ); }
ErrorCode moab::ParallelComm::reduce_void | ( | int | tag_data_type, |
) | [private] |
Definition at line 3886 of file ParallelComm.cpp.
References ErrorCode, MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_DOUBLE, and MB_TYPE_INTEGER.
Referenced by unpack_tags().
{ ErrorCode result; switch( tag_data_type ) { case MB_TYPE_INTEGER: result = reduce< int >( mpi_op, num_ents, old_vals, new_vals ); break; case MB_TYPE_DOUBLE: result = reduce< double >( mpi_op, num_ents, old_vals, new_vals ); break; case MB_TYPE_BIT: result = reduce< unsigned char >( mpi_op, num_ents, old_vals, new_vals ); break; default: result = MB_SUCCESS; break; } return result; }
ErrorCode moab::ParallelComm::remove_entities_part | ( | Range & | entities, |
const int | proc | ||
) | [private] |
remove entities to the input processor part
Definition at line 7310 of file ParallelComm.cpp.
References ErrorCode, get_part_handle(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, and moab::Interface::remove_entities().
Referenced by exchange_owned_mesh().
{ EntityHandle part_set; ErrorCode result = get_part_handle( proc, part_set );MB_CHK_SET_ERR( result, "Failed to get part handle" ); if( part_set > 0 ) { result = mbImpl->remove_entities( part_set, entities );MB_CHK_SET_ERR( result, "Failed to remove entities from part set" ); } return MB_SUCCESS; }
void moab::ParallelComm::remove_pcomm | ( | ParallelComm * | pc | ) | [private] |
remove a pc from the iface instance tag PARALLEL_COMM
Definition at line 400 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, mbImpl, pcomm_tag(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by ~ParallelComm().
{ // Remove this pcomm from instance tag std::vector< ParallelComm* > pc_array( MAX_SHARING_PROCS ); Tag pc_tag = pcomm_tag( mbImpl, true ); const EntityHandle root = 0; ErrorCode result = mbImpl->tag_get_data( pc_tag, &root, 1, (void*)&pc_array[0] ); std::vector< ParallelComm* >::iterator pc_it = std::find( pc_array.begin(), pc_array.end(), pc ); assert( MB_SUCCESS == result && pc_it != pc_array.end() ); // Empty if test to get around compiler warning about unused var if( MB_SUCCESS == result ) { } *pc_it = NULL; mbImpl->tag_set_data( pc_tag, &root, 1, (void*)&pc_array[0] ); }
void moab::ParallelComm::reset_all_buffers | ( | ) | [inline] |
reset message buffers to their initial state
Definition at line 1548 of file ParallelComm.hpp.
References localOwnedBuffs, and remoteOwnedBuffs.
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), post_irecv(), reduce_tags(), send_recv_entities(), and settle_intersection_points().
{ std::vector< Buffer* >::iterator vit; for( vit = localOwnedBuffs.begin(); vit != localOwnedBuffs.end(); ++vit ) ( *vit )->reset_buffer(); for( vit = remoteOwnedBuffs.begin(); vit != remoteOwnedBuffs.end(); ++vit ) ( *vit )->reset_buffer(); }
ErrorCode moab::ParallelComm::resolve_shared_ents | ( | EntityHandle | this_set, |
Range & | proc_ents, | ||
int | resolve_dim = -1 , |
int | shared_dim = -1 , |
Range * | skin_ents = NULL , |
const Tag * | id_tag = 0 |
Resolve shared entities between processors.
Resolve shared entities between processors for entities in proc_ents, by comparing global id tag values on vertices on skin of elements in proc_ents. Shared entities are assigned a tag that's either PARALLEL_SHARED_PROC_TAG_NAME, which is 1 integer in length, or PARALLEL_SHARED_PROCS_TAG_NAME, whose length depends on the maximum number of sharing processors. Values in these tags denote the ranks of sharing processors, and the list ends with the value -1.
If shared_dim is input as -1 or not input, a value one less than the maximum dimension of entities in proc_ents is used.
proc_ents | Entities for which to resolve shared entities |
shared_dim | Maximum dimension of shared entities to look for |
Definition at line 3967 of file ParallelComm.cpp.
References moab::Interface::add_entities(), assign_global_ids(), moab::Range::begin(), check_all_shared_handles(), create_iface_pc_links(), create_interface_sets(), moab::ProcConfig::crystal_router(), define_mpe(), moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::TupleList::enableWriteAccess(), ErrorCode, exchange_ghost_cells(), moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), get_interface_procs(), moab::TupleList::get_n(), get_proc_nvecs(), get_shared_proc_tags(), moab::DebugOutput::get_verbosity(), GLOBAL_ID_TAG_NAME, moab::TupleList::inc_n(), moab::TupleList::initialize(), moab::gs_data::initialize(), MAX_SHARING_PROCS, MB_ALREADY_ALLOCATED, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mbImpl, MPE_Log_event, myDebug, moab::DebugOutput::print(), moab::DebugOutput::printf(), proc_config(), moab::ProcConfig::proc_rank(), procConfig, moab::TupleList::buffer::reset(), moab::TupleList::reset(), moab::gs_data::reset(), moab::Range::size(), size(), moab::TupleList::sort(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), tag_shared_verts(), moab::DebugOutput::tprintf(), moab::Interface::UNION, moab::TupleList::vi_wr, and moab::TupleList::vul_wr.
Referenced by create_coarse_mesh(), iMesh_createStructuredMesh(), iMeshP_syncMeshAll(), moab::ReadParallel::load_file(), and resolve_shared_ents().
{ #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { define_mpe(); MPE_Log_event( RESOLVE_START, procConfig.proc_rank(), "Entering resolve_shared_ents." ); } #endif ErrorCode result; myDebug->tprintf( 1, "Resolving shared entities.\n" ); if( resolve_dim < shared_dim ) { MB_SET_ERR( MB_FAILURE, "MOAB does not support vertex-based partitions, only element-based ones" ); } if( -1 == shared_dim ) { if( !proc_ents.empty() ) shared_dim = mbImpl->dimension_from_handle( *proc_ents.begin() ) - 1; else if( resolve_dim == 3 ) shared_dim = 2; } int max_global_resolve_dim = -1; int err = MPI_Allreduce( &resolve_dim, &max_global_resolve_dim, 1, MPI_INT, MPI_MAX, proc_config().proc_comm() ); if( MPI_SUCCESS != err ) { MB_SET_ERR( MB_FAILURE, "Unable to guess global resolve_dim" ); } if( shared_dim < 0 || resolve_dim < 0 ) { // MB_SET_ERR(MB_FAILURE, "Unable to guess shared_dim or resolve_dim"); resolve_dim = max_global_resolve_dim; shared_dim = resolve_dim - 1; } if( resolve_dim < 0 || shared_dim < 0 ) return MB_SUCCESS; // no task has any mesh, get out // Get the skin entities by dimension Range tmp_skin_ents[4]; // Get the entities to be skinned // Find the skin int skin_dim = resolve_dim - 1; if( !skin_ents ) { skin_ents = tmp_skin_ents; skin_ents[resolve_dim] = proc_ents; Skinner skinner( mbImpl ); result = skinner.find_skin( this_set, skin_ents[skin_dim + 1], false, skin_ents[skin_dim], NULL, true, true, true );MB_CHK_SET_ERR( result, "Failed to find skin" ); myDebug->tprintf( 1, "Found skin: skin_dim: %d resolve_dim: %d , now resolving.\n", skin_dim, resolve_dim ); myDebug->tprintf( 3, "skin_ents[0].size(): %d skin_ents[1].size(): %d \n", (int)skin_ents[0].size(), (int)skin_ents[1].size() ); // Get entities adjacent to skin ents from shared_dim down to zero for( int this_dim = skin_dim - 1; this_dim >= 0; this_dim-- ) { result = mbImpl->get_adjacencies( skin_ents[skin_dim], this_dim, true, skin_ents[this_dim], Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get skin adjacencies" ); if( this_set && skin_dim == 2 && this_dim == 1 ) { result = mbImpl->add_entities( this_set, skin_ents[this_dim] );MB_CHK_ERR( result ); } } } else if( skin_ents[resolve_dim].empty() ) skin_ents[resolve_dim] = proc_ents; // Global id tag Tag gid_tag; if( id_tag ) gid_tag = *id_tag; else { bool tag_created = false; int def_val = -1; result = mbImpl->tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_DENSE | MB_TAG_CREAT, &def_val, &tag_created ); if( MB_ALREADY_ALLOCATED != result && MB_SUCCESS != result ) { MB_SET_ERR( result, "Failed to create/get gid tag handle" ); } else if( tag_created ) { // Just created it, so we need global ids result = assign_global_ids( this_set, skin_dim + 1, true, true, true );MB_CHK_SET_ERR( result, "Failed to assign global ids" ); } } DataType tag_type; result = mbImpl->tag_get_data_type( gid_tag, tag_type );MB_CHK_SET_ERR( result, "Failed to get tag data type" ); int bytes_per_tag; result = mbImpl->tag_get_bytes( gid_tag, bytes_per_tag );MB_CHK_SET_ERR( result, "Failed to get number of bytes per tag" ); // On 64 bits, long and int are different // On 32 bits, they are not; if size of long is 8, it is a 64 bit machine (really?) // Get gids for skin ents in a vector, to pass to gs std::vector< long > lgid_data( skin_ents[0].size() ); // Size is either long or int // On 64 bit is 8 or 4 if( sizeof( long ) == bytes_per_tag && ( ( MB_TYPE_HANDLE == tag_type ) || ( MB_TYPE_OPAQUE == tag_type ) ) ) { // It is a special id tag result = mbImpl->tag_get_data( gid_tag, skin_ents[0], &lgid_data[0] );MB_CHK_SET_ERR( result, "Couldn't get gid tag for skin vertices" ); } else if( 4 == bytes_per_tag ) { // Must be GLOBAL_ID tag or 32 bits ... std::vector< int > gid_data( lgid_data.size() ); result = mbImpl->tag_get_data( gid_tag, skin_ents[0], &gid_data[0] );MB_CHK_SET_ERR( result, "Failed to get gid tag for skin vertices" ); std::copy( gid_data.begin(), gid_data.end(), lgid_data.begin() ); } else { // Not supported flag MB_SET_ERR( MB_FAILURE, "Unsupported id tag" ); } // Put handles in vector for passing to gs setup std::vector< Ulong > handle_vec; // Assumes that we can do conversion from Ulong to EntityHandle std::copy( skin_ents[0].begin(), skin_ents[0].end(), std::back_inserter( handle_vec ) ); #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( SHAREDV_START, procConfig.proc_rank(), "Creating crystal router." ); } #endif // Get a crystal router gs_data::crystal_data* cd = procConfig.crystal_router(); /* // Get total number of entities; will overshoot highest global id, but // that's OK int num_total[2] = {0, 0}, num_local[2] = {0, 0}; result = mbImpl->get_number_entities_by_dimension(this_set, 0, num_local); if (MB_SUCCESS != result)return result; int failure = MPI_Allreduce(num_local, num_total, 1, MPI_INT, MPI_SUM, procConfig.proc_comm()); if (failure) { MB_SET_ERR(MB_FAILURE, "Allreduce for total number of shared ents failed"); } */ // Call gather-scatter to get shared ids & procs gs_data* gsd = new gs_data(); // assert(sizeof(ulong_) == sizeof(EntityHandle)); result = gsd->initialize( skin_ents[0].size(), &lgid_data[0], &handle_vec[0], 2, 1, 1, cd );MB_CHK_SET_ERR( result, "Failed to create gs data" ); // Get shared proc tags Tag shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag; result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags" ); // Load shared verts into a tuple, then sort by index TupleList shared_verts; shared_verts.initialize( 2, 0, 1, 0, skin_ents[0].size() * ( MAX_SHARING_PROCS + 1 ) ); shared_verts.enableWriteAccess(); unsigned int i = 0, j = 0; for( unsigned int p = 0; p < gsd->nlinfo->_np; p++ ) for( unsigned int np = 0; np < gsd->nlinfo->_nshared[p]; np++ ) { shared_verts.vi_wr[i++] = gsd->nlinfo->_sh_ind[j]; shared_verts.vi_wr[i++] = gsd->nlinfo->_target[p]; shared_verts.vul_wr[j] = gsd->nlinfo->_ulabels[j]; j++; shared_verts.inc_n(); } myDebug->tprintf( 3, " shared verts size %d \n", (int)shared_verts.get_n() ); int max_size = skin_ents[0].size() * ( MAX_SHARING_PROCS + 1 ); moab::TupleList::buffer sort_buffer; sort_buffer.buffer_init( max_size ); shared_verts.sort( 0, &sort_buffer ); sort_buffer.reset(); // Set sharing procs and handles tags on skin ents int maxp = -1; std::vector< int > sharing_procs( MAX_SHARING_PROCS ); std::fill( sharing_procs.begin(), sharing_procs.end(), maxp ); j = 0; i = 0; // Get ents shared by 1 or n procs std::map< std::vector< int >, std::vector< EntityHandle > > proc_nvecs; Range proc_verts; result = mbImpl->get_adjacencies( proc_ents, 0, false, proc_verts, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get proc_verts" ); myDebug->print( 3, " resolve shared ents: proc verts ", proc_verts ); result = tag_shared_verts( shared_verts, skin_ents, proc_nvecs, proc_verts );MB_CHK_SET_ERR( result, "Failed to tag shared verts" ); #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( SHAREDV_END, procConfig.proc_rank(), "Finished tag_shared_verts." ); } #endif // Get entities shared by 1 or n procs result = get_proc_nvecs( resolve_dim, shared_dim, skin_ents, proc_nvecs );MB_CHK_SET_ERR( result, "Failed to tag shared entities" ); shared_verts.reset(); if( myDebug->get_verbosity() > 0 ) { for( std::map< std::vector< int >, std::vector< EntityHandle > >::const_iterator mit = proc_nvecs.begin(); mit != proc_nvecs.end(); ++mit ) { myDebug->tprintf( 1, "Iface: " ); for( std::vector< int >::const_iterator vit = ( mit->first ).begin(); vit != ( mit->first ).end(); ++vit ) myDebug->printf( 1, " %d", *vit ); myDebug->print( 1, "\n" ); } } // Create the sets for each interface; store them as tags on // the interface instance Range iface_sets; result = create_interface_sets( proc_nvecs );MB_CHK_SET_ERR( result, "Failed to create interface sets" ); // Establish comm procs and buffers for them std::set< unsigned int > procs; result = get_interface_procs( procs, true );MB_CHK_SET_ERR( result, "Failed to get interface procs" ); #ifndef NDEBUG result = check_all_shared_handles( true );MB_CHK_SET_ERR( result, "Shared handle check failed after interface vertex exchange" ); #endif // Resolve shared entity remote handles; implemented in ghost cell exchange // code because it's so similar result = exchange_ghost_cells( -1, -1, 0, 0, true, true );MB_CHK_SET_ERR( result, "Failed to resolve shared entity remote handles" ); // Now build parent/child links for interface sets result = create_iface_pc_links();MB_CHK_SET_ERR( result, "Failed to create interface parent/child links" ); gsd->reset(); delete gsd; #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( RESOLVE_END, procConfig.proc_rank(), "Exiting resolve_shared_ents." ); } #endif // std::ostringstream ent_str; // ent_str << "mesh." << procConfig.proc_rank() << ".h5m"; // mbImpl->write_mesh(ent_str.str().c_str()); // Done return result; }
int | resolve_dim = 3 , |
Same as resolve_shared_ents(Range&), except works for all entities in instance of dimension dim.
If shared_dim is input as -1 or not input, a value one less than the maximum dimension of entities is used.
dim | Dimension of entities in the partition |
Definition at line 3912 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::GeomUtil::first(), moab::Interface::get_entities_by_handle(), moab::Range::lower_bound(), MB_SUCCESS, mbImpl, moab::Range::merge(), myDebug, partitionSets, moab::Interface::query_interface(), moab::Range::rbegin(), resolve_shared_ents(), sharedEnts, moab::ScdInterface::tag_shared_vertices(), moab::DebugOutput::tprintf(), moab::CN::TypeDimensionMap, and moab::Range::upper_bound().
{ ErrorCode result; Range proc_ents; // Check for structured mesh, and do it differently if it is ScdInterface* scdi; result = mbImpl->query_interface( scdi ); if( scdi ) { result = scdi->tag_shared_vertices( this, this_set ); if( MB_SUCCESS == result ) { myDebug->tprintf( 1, "Total number of shared entities = %lu.\n", (unsigned long)sharedEnts.size() ); return result; } } if( 0 == this_set ) { // Get the entities in the partition sets for( Range::iterator rit = partitionSets.begin(); rit != partitionSets.end(); ++rit ) { Range tmp_ents; result = mbImpl->get_entities_by_handle( *rit, tmp_ents, true ); if( MB_SUCCESS != result ) return result; proc_ents.merge( tmp_ents ); } } else { result = mbImpl->get_entities_by_handle( this_set, proc_ents, true ); if( MB_SUCCESS != result ) return result; } // Resolve dim is maximal dim of entities in proc_ents if( -1 == resolve_dim ) { if( !proc_ents.empty() ) resolve_dim = mbImpl->dimension_from_handle( *proc_ents.rbegin() ); } // proc_ents should all be of same dimension if( resolve_dim > shared_dim && mbImpl->dimension_from_handle( *proc_ents.rbegin() ) != mbImpl->dimension_from_handle( *proc_ents.begin() ) ) { Range::iterator lower = proc_ents.lower_bound( CN::TypeDimensionMap[0].first ), upper = proc_ents.upper_bound( CN::TypeDimensionMap[resolve_dim - 1].second ); proc_ents.erase( lower, upper ); } // Must call even if we don't have any entities, to make sure // collective comm'n works return resolve_shared_ents( this_set, proc_ents, resolve_dim, shared_dim, NULL, id_tag ); }
ErrorCode moab::ParallelComm::resolve_shared_ents | ( | ParallelComm ** | pc, |
const unsigned int | np, | ||
EntityHandle | this_set, | ||
const int | to_dim | ||
) | [static] |
Definition at line 4260 of file ParallelComm.cpp.
References create_interface_sets(), moab::TupleList::enableWriteAccess(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), get_interface_procs(), get_moab(), moab::TupleList::get_n(), moab::Interface::globalId_tag(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MB_SUCCESS, PSTATUS_INTERFACE, PSTATUS_NOT_OWNED, rank(), moab::TupleList::buffer::reset(), moab::TupleList::reset(), size(), moab::TupleList::sort(), moab::Interface::tag_get_data(), moab::Interface::UNION, update_remote_data(), moab::TupleList::vi_rd, moab::TupleList::vi_wr, moab::TupleList::vul_rd, and moab::TupleList::vul_wr.
{ std::vector< Range > verts( np ); int tot_verts = 0; unsigned int p, i, j, v; ErrorCode rval; for( p = 0; p < np; p++ ) { Skinner skinner( pc[p]->get_moab() ); Range part_ents, skin_ents; rval = pc[p]->get_moab()->get_entities_by_dimension( this_set, part_dim, part_ents ); if( MB_SUCCESS != rval ) return rval; rval = skinner.find_skin( this_set, part_ents, false, skin_ents, 0, true, true, true ); if( MB_SUCCESS != rval ) return rval; rval = pc[p]->get_moab()->get_adjacencies( skin_ents, 0, true, verts[p], Interface::UNION ); if( MB_SUCCESS != rval ) return rval; tot_verts += verts[p].size(); } TupleList shared_ents; shared_ents.initialize( 2, 0, 1, 0, tot_verts ); shared_ents.enableWriteAccess(); i = 0; j = 0; std::vector< int > gids; Range::iterator rit; Tag gid_tag; for( p = 0; p < np; p++ ) { gid_tag = pc[p]->get_moab()->globalId_tag(); gids.resize( verts[p].size() ); rval = pc[p]->get_moab()->tag_get_data( gid_tag, verts[p], &gids[0] ); if( MB_SUCCESS != rval ) return rval; for( v = 0, rit = verts[p].begin(); v < gids.size(); v++, ++rit ) { shared_ents.vi_wr[i++] = gids[v]; shared_ents.vi_wr[i++] = p; shared_ents.vul_wr[j] = *rit; j++; shared_ents.inc_n(); } } moab::TupleList::buffer sort_buffer; sort_buffer.buffer_init( tot_verts ); shared_ents.sort( 0, &sort_buffer ); sort_buffer.reset(); j = 0; i = 0; std::vector< EntityHandle > handles; std::vector< int > procs; while( i < shared_ents.get_n() ) { handles.clear(); procs.clear(); // Count & accumulate sharing procs int this_gid = shared_ents.vi_rd[j]; while( i < shared_ents.get_n() && shared_ents.vi_rd[j] == this_gid ) { j++; procs.push_back( shared_ents.vi_rd[j++] ); handles.push_back( shared_ents.vul_rd[i++] ); } if( 1 == procs.size() ) continue; for( v = 0; v < procs.size(); v++ ) { rval = pc[procs[v]]->update_remote_data( handles[v], &procs[0], &handles[0], procs.size(), ( procs[0] == (int)pc[procs[v]]->rank() ? PSTATUS_INTERFACE : ( PSTATUS_NOT_OWNED | PSTATUS_INTERFACE ) ) ); if( MB_SUCCESS != rval ) return rval; } } std::set< unsigned int > psets; for( p = 0; p < np; p++ ) { rval = pc[p]->create_interface_sets( this_set, part_dim, part_dim - 1 ); if( MB_SUCCESS != rval ) return rval; // Establish comm procs and buffers for them psets.clear(); rval = pc[p]->get_interface_procs( psets, true ); if( MB_SUCCESS != rval ) return rval; } shared_ents.reset(); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::resolve_shared_sets | ( | EntityHandle | this_set, |
Remove shared sets.
Generates list of candidate sets using from those (directly) contained in passed set and passes them to the other version of resolve_shared_sets
this_set | Set directly containing candidate sets (e.g. file set) |
id_tag | Tag containing global IDs for entity sets. |
Definition at line 4500 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::clear(), DIRICHLET_SET_TAG_NAME, moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, filter_pstatus(), GEOM_DIMENSION_TAG_NAME, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), moab::Range::insert(), moab::intersect(), moab::Range::lower_bound(), MATERIAL_SET_TAG_NAME, MB_SUCCESS, MB_TAG_ANY, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, moab::Range::merge(), NEUMANN_SET_TAG_NAME, PARALLEL_PARTITION_TAG_NAME, PSTATUS_OR, PSTATUS_SHARED, moab::subtract(), moab::Range::swap(), moab::Interface::tag_get_handle(), and moab::Interface::UNION.
Referenced by moab::ReadParallel::load_file().
{ // Find all sets with any of the following tags: const char* const shared_set_tag_names[] = { GEOM_DIMENSION_TAG_NAME, MATERIAL_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME, PARALLEL_PARTITION_TAG_NAME }; int num_tags = sizeof( shared_set_tag_names ) / sizeof( shared_set_tag_names[0] ); Range candidate_sets; ErrorCode result = MB_FAILURE; // If we're not given an ID tag to use to globally identify sets, // then fall back to using known tag values if( !idtag ) { Tag gid, tag; gid = mbImpl->globalId_tag(); if( NULL != gid ) result = mbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tag ); if( MB_SUCCESS == result ) { for( int d = 0; d < 4; d++ ) { candidate_sets.clear(); const void* vals[] = { &d }; result = mbImpl->get_entities_by_type_and_tag( file, MBENTITYSET, &tag, vals, 1, candidate_sets ); if( MB_SUCCESS == result ) resolve_shared_sets( candidate_sets, gid ); } } for( int i = 1; i < num_tags; i++ ) { result = mbImpl->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, tag ); if( MB_SUCCESS == result ) { candidate_sets.clear(); result = mbImpl->get_entities_by_type_and_tag( file, MBENTITYSET, &tag, 0, 1, candidate_sets ); if( MB_SUCCESS == result ) resolve_shared_sets( candidate_sets, tag ); } } return MB_SUCCESS; } for( int i = 0; i < num_tags; i++ ) { Tag tag; result = mbImpl->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, tag, MB_TAG_ANY ); if( MB_SUCCESS != result ) continue; mbImpl->get_entities_by_type_and_tag( file, MBENTITYSET, &tag, 0, 1, candidate_sets, Interface::UNION ); } // Find any additional sets that contain shared entities Range::iterator hint = candidate_sets.begin(); Range all_sets; mbImpl->get_entities_by_type( file, MBENTITYSET, all_sets ); all_sets = subtract( all_sets, candidate_sets ); Range::iterator it = all_sets.begin(); while( it != all_sets.end() ) { Range contents; mbImpl->get_entities_by_handle( *it, contents ); contents.erase( contents.lower_bound( MBENTITYSET ), contents.end() ); filter_pstatus( contents, PSTATUS_SHARED, PSTATUS_OR ); if( contents.empty() ) { ++it; } else { hint = candidate_sets.insert( hint, *it ); it = all_sets.erase( it ); } } // Find any additionl sets that contain or are parents of potential shared sets Range prev_list = candidate_sets; while( !prev_list.empty() ) { it = all_sets.begin(); Range new_list; hint = new_list.begin(); while( it != all_sets.end() ) { Range contents; mbImpl->get_entities_by_type( *it, MBENTITYSET, contents ); if( !intersect( prev_list, contents ).empty() ) { hint = new_list.insert( hint, *it ); it = all_sets.erase( it ); } else { new_list.clear(); mbImpl->get_child_meshsets( *it, contents ); if( !intersect( prev_list, contents ).empty() ) { hint = new_list.insert( hint, *it ); it = all_sets.erase( it ); } else { ++it; } } } candidate_sets.merge( new_list ); prev_list.swap( new_list ); } return resolve_shared_sets( candidate_sets, *idtag ); }
ErrorCode moab::ParallelComm::resolve_shared_sets | ( | Range & | candidate_sets, |
Tag | id_tag | ||
Remove shared sets.
Use values of id_tag to match sets across processes and populate sharing data for sets.
candidate_sets | Sets to consider as potentially shared. |
Definition at line 4621 of file ParallelComm.cpp.
References moab::Range::begin(), moab::choose_owner_idx(), moab::ProcConfig::crystal_router(), moab::dum, moab::Range::end(), ErrorCode, moab::set_tuple::handle, moab::set_tuple::idx, moab::gs_data::initialize(), moab::Range::insert(), moab::is_sorted_unique(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TYPE_HANDLE, MB_TYPE_OPAQUE, mbImpl, moab::set_tuple::proc, moab::ProcConfig::proc_comm(), proc_config(), moab::ProcConfig::proc_rank(), procConfig, moab::gs_data::reset(), moab::SharedSetData::set_owner(), moab::SharedSetData::set_sharing_procs(), sharedSetData, t, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_data_type().
{ ErrorCode result; const unsigned rk = proc_config().proc_rank(); MPI_Comm cm = proc_config().proc_comm(); // Build sharing list for all sets // Get ids for sets in a vector, to pass to gs std::vector< long > larray; // Allocate sufficient space for longs std::vector< Ulong > handles; Range tmp_sets; // The id tag can be size 4 or size 8 // Based on that, convert to int or to long, similarly to what we do // for resolving shared vertices; // This code must work on 32 bit too, where long is 4 bytes, also // so test first size 4, then we should be fine DataType tag_type; result = mbImpl->tag_get_data_type( idtag, tag_type );MB_CHK_SET_ERR( result, "Failed getting tag data type" ); int bytes_per_tag; result = mbImpl->tag_get_bytes( idtag, bytes_per_tag );MB_CHK_SET_ERR( result, "Failed getting number of bytes per tag" ); // On 64 bits, long and int are different // On 32 bits, they are not; if size of long is 8, it is a 64 bit machine (really?) for( Range::iterator rit = sets.begin(); rit != sets.end(); ++rit ) { if( sizeof( long ) == bytes_per_tag && ( ( MB_TYPE_HANDLE == tag_type ) || ( MB_TYPE_OPAQUE == tag_type ) ) ) { // It is a special id tag long dum; result = mbImpl->tag_get_data( idtag, &( *rit ), 1, &dum ); if( MB_SUCCESS == result ) { larray.push_back( dum ); handles.push_back( *rit ); tmp_sets.insert( tmp_sets.end(), *rit ); } } else if( 4 == bytes_per_tag ) { // Must be GLOBAL_ID tag or MATERIAL_ID, etc int dum; result = mbImpl->tag_get_data( idtag, &( *rit ), 1, &dum ); if( MB_SUCCESS == result ) { larray.push_back( dum ); handles.push_back( *rit ); tmp_sets.insert( tmp_sets.end(), *rit ); } } } const size_t nsets = handles.size(); // Get handle array for sets // This is not true on windows machine, 64 bits: entity handle is 64 bit, long is 32 // assert(sizeof(EntityHandle) <= sizeof(unsigned long)); // Do communication of data gs_data::crystal_data* cd = procConfig.crystal_router(); gs_data* gsd = new gs_data(); result = gsd->initialize( nsets, &larray[0], &handles[0], 2, 1, 1, cd );MB_CHK_SET_ERR( result, "Failed to create gs data" ); // Convert from global IDs grouped by process rank to list // of <idx, rank> pairs so that we can sort primarily // by idx and secondarily by rank (we want lists of procs for each // idx, not lists if indices for each proc). size_t ntuple = 0; for( unsigned p = 0; p < gsd->nlinfo->_np; p++ ) ntuple += gsd->nlinfo->_nshared[p]; std::vector< set_tuple > tuples; tuples.reserve( ntuple ); size_t j = 0; for( unsigned p = 0; p < gsd->nlinfo->_np; p++ ) { for( unsigned np = 0; np < gsd->nlinfo->_nshared[p]; np++ ) { set_tuple t; t.idx = gsd->nlinfo->_sh_ind[j]; t.proc = gsd->nlinfo->_target[p]; t.handle = gsd->nlinfo->_ulabels[j]; tuples.push_back( t ); j++; } } std::sort( tuples.begin(), tuples.end() ); // Release crystal router stuff gsd->reset(); delete gsd; // Storing sharing data for each set size_t ti = 0; unsigned idx = 0; std::vector< unsigned > procs; Range::iterator si = tmp_sets.begin(); while( si != tmp_sets.end() && ti < tuples.size() ) { assert( idx <= tuples[ti].idx ); if( idx < tuples[ti].idx ) si += ( tuples[ti].idx - idx ); idx = tuples[ti].idx; procs.clear(); size_t ti_init = ti; while( ti < tuples.size() && tuples[ti].idx == idx ) { procs.push_back( tuples[ti].proc ); ++ti; } assert( is_sorted_unique( procs ) ); result = sharedSetData->set_sharing_procs( *si, procs ); if( MB_SUCCESS != result ) { std::cerr << "Failure at " __FILE__ ":" << __LINE__ << std::endl; std::cerr.flush(); MPI_Abort( cm, 1 ); } // Add this proc to list of sharing procs in correct position // so that all procs select owner based on same list std::vector< unsigned >::iterator it = std::lower_bound( procs.begin(), procs.end(), rk ); assert( it == procs.end() || *it > rk ); procs.insert( it, rk ); size_t owner_idx = choose_owner_idx( procs ); EntityHandle owner_handle; if( procs[owner_idx] == rk ) owner_handle = *si; else if( procs[owner_idx] > rk ) owner_handle = tuples[ti_init + owner_idx - 1].handle; else owner_handle = tuples[ti_init + owner_idx].handle; result = sharedSetData->set_owner( *si, procs[owner_idx], owner_handle ); if( MB_SUCCESS != result ) { std::cerr << "Failure at " __FILE__ ":" << __LINE__ << std::endl; std::cerr.flush(); MPI_Abort( cm, 1 ); } ++si; ++idx; } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::scatter_entities | ( | const int | from_proc, |
std::vector< Range > & | entities, | ||
const bool | adjacencies = false , |
const bool | tags = true |
Scatter entities on from_proc to other processors This function assumes remote handles are *not* being stored, since (usually) every processor will know about the whole mesh.
from_proc | Processor having the mesh to be broadcast |
entities | On return, the entities sent or received in this call |
adjacencies | If true, adjacencies are sent for equiv entities (currently unsupported) |
tags | If true, all non-default-valued tags are sent for sent entities |
Definition at line 601 of file ParallelComm.cpp.
References add_verts(), moab::ParallelComm::Buffer::buff_ptr, ErrorCode, INITIAL_BUFF_SIZE, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, pack_buffer(), moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), procConfig, moab::ParallelComm::Buffer::reserve(), moab::ParallelComm::Buffer::reset_ptr(), moab::ParallelComm::Buffer::set_stored_size(), and unpack_buffer().
{ #ifndef MOAB_HAVE_MPI return MB_FAILURE; #else ErrorCode result = MB_SUCCESS; int i, success, buff_size, prev_size; int nProcs = (int)procConfig.proc_size(); int* sendCounts = new int[nProcs]; int* displacements = new int[nProcs]; sendCounts[0] = sizeof( int ); displacements[0] = 0; Buffer buff( INITIAL_BUFF_SIZE ); buff.reset_ptr( sizeof( int ) ); buff.set_stored_size(); unsigned int my_proc = procConfig.proc_rank(); // Get buffer size array for each remote processor if( my_proc == (unsigned int)from_proc ) { for( i = 1; i < nProcs; i++ ) { prev_size = buff.buff_ptr - buff.mem_ptr; buff.reset_ptr( prev_size + sizeof( int ) ); result = add_verts( entities[i] );MB_CHK_SET_ERR( result, "Failed to add verts" ); result = pack_buffer( entities[i], adjacencies, tags, false, -1, &buff ); if( MB_SUCCESS != result ) { delete[] sendCounts; delete[] displacements; MB_SET_ERR( result, "Failed to pack buffer in scatter_entities" ); } buff_size = buff.buff_ptr - buff.mem_ptr - prev_size; *( (int*)( buff.mem_ptr + prev_size ) ) = buff_size; sendCounts[i] = buff_size; } } // Broadcast buffer size array success = MPI_Bcast( sendCounts, nProcs, MPI_INT, from_proc, procConfig.proc_comm() ); if( MPI_SUCCESS != success ) { delete[] sendCounts; delete[] displacements; MB_SET_ERR( MB_FAILURE, "MPI_Bcast of buffer size failed" ); } for( i = 1; i < nProcs; i++ ) { displacements[i] = displacements[i - 1] + sendCounts[i - 1]; } Buffer rec_buff; rec_buff.reserve( sendCounts[my_proc] ); // Scatter actual geometry success = MPI_Scatterv( buff.mem_ptr, sendCounts, displacements, MPI_UNSIGNED_CHAR, rec_buff.mem_ptr, sendCounts[my_proc], MPI_UNSIGNED_CHAR, from_proc, procConfig.proc_comm() ); if( MPI_SUCCESS != success ) { delete[] sendCounts; delete[] displacements; MB_SET_ERR( MB_FAILURE, "MPI_Scatterv of buffer failed" ); } // Unpack in remote processors if( my_proc != (unsigned int)from_proc ) { std::vector< std::vector< EntityHandle > > dum1a, dum1b; std::vector< std::vector< int > > dum1p; std::vector< EntityHandle > dum2, dum4; std::vector< unsigned int > dum3; rec_buff.reset_ptr( sizeof( int ) ); result = unpack_buffer( rec_buff.buff_ptr, false, from_proc, -1, dum1a, dum1b, dum1p, dum2, dum2, dum3, dum4 ); if( MB_SUCCESS != result ) { delete[] sendCounts; delete[] displacements; MB_SET_ERR( result, "Failed to unpack buffer in scatter_entities" ); } std::copy( dum4.begin(), dum4.end(), range_inserter( entities[my_proc] ) ); } delete[] sendCounts; delete[] displacements; return MB_SUCCESS; #endif }
ErrorCode moab::ParallelComm::send_buffer | ( | const unsigned int | to_proc, |
Buffer * | send_buff, | ||
const int | msg_tag, | ||
MPI_Request & | send_req, | ||
MPI_Request & | ack_recv_req, | ||
int * | ack_buff, | ||
int & | this_incoming, | ||
int | next_mesg_tag = -1 , |
Buffer * | next_recv_buff = NULL , |
MPI_Request * | next_recv_req = NULL , |
int * | next_incoming = NULL |
) | [private] |
send the indicated buffer, possibly sending size first
Definition at line 6086 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::alloc_size, ErrorCode, moab::ParallelComm::Buffer::get_stored_size(), INITIAL_BUFF_SIZE, MB_SET_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, PRINT_DEBUG_IRECV, PRINT_DEBUG_ISEND, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), and procConfig.
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), recv_entities(), recv_messages(), reduce_tags(), send_entities(), send_recv_entities(), and settle_intersection_points().
{ ErrorCode result = MB_SUCCESS; int success; // If small message, post recv for remote handle message if( send_buff->get_stored_size() <= (int)INITIAL_BUFF_SIZE && next_recv_buff ) { ( *next_incoming )++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), to_proc, next_recv_buff->mem_ptr, INITIAL_BUFF_SIZE, next_mesg_tag, *next_incoming ); success = MPI_Irecv( next_recv_buff->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, to_proc, next_mesg_tag, procConfig.proc_comm(), next_recv_req ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv for next message in ghost exchange" ); } } // If large, we'll need an ack before sending the rest else if( send_buff->get_stored_size() > (int)INITIAL_BUFF_SIZE ) { this_incoming++; PRINT_DEBUG_IRECV( procConfig.proc_rank(), to_proc, (unsigned char*)ack_buff, sizeof( int ), mesg_tag - 1, this_incoming ); success = MPI_Irecv( (void*)ack_buff, sizeof( int ), MPI_UNSIGNED_CHAR, to_proc, mesg_tag - 1, procConfig.proc_comm(), &ack_req ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv for entity ack in ghost exchange" ); } } // Send the buffer PRINT_DEBUG_ISEND( procConfig.proc_rank(), to_proc, send_buff->mem_ptr, mesg_tag, std::min( send_buff->get_stored_size(), (int)INITIAL_BUFF_SIZE ) ); assert( 0 <= send_buff->get_stored_size() && send_buff->get_stored_size() <= (int)send_buff->alloc_size ); success = MPI_Isend( send_buff->mem_ptr, std::min( send_buff->get_stored_size(), (int)INITIAL_BUFF_SIZE ), MPI_UNSIGNED_CHAR, to_proc, mesg_tag, procConfig.proc_comm(), &send_req ); if( success != MPI_SUCCESS ) return MB_FAILURE; return result; }
ErrorCode moab::ParallelComm::send_entities | ( | const int | to_proc, |
Range & | orig_ents, | ||
const bool | adjs, | ||
const bool | tags, | ||
Range & | final_ents, | ||
int & | incoming2, | ||
TupleList & | entprocs, | ||
std::vector< MPI_Request > & | recv_remoteh_reqs, | ||
bool | wait_all = true |
send entities to another processor, optionally waiting until it's done
Send entities to another processor, with adjs, sets, and tags. If store_remote_handles is true, this call receives back handles assigned to entities sent to destination processor and stores them in sharedh_tag or sharedhs_tag.
to_proc | Destination processor |
orig_ents | Entities requested to send |
adjs | If true, send adjacencies for equiv entities (currently unsupported) |
tags | If true, send tag values for all tags assigned to entities |
store_remote_handles | If true, also recv message with handles on destination processor (currently unsupported) |
final_ents | Range containing all entities sent |
incoming | keep track if any messages are coming to this processor (newly added) |
wait_all | If true, wait until all messages received/sent complete |
Definition at line 698 of file ParallelComm.cpp.
References add_verts(), moab::Range::empty(), ErrorCode, filter_pstatus(), get_buffers(), localOwnedBuffs, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SUCCESS, pack_buffer(), PSTATUS_AND, PSTATUS_SHARED, recvReqs, remoteOwnedBuffs, send_buffer(), sendReqs, and moab::subtract().
{ #ifndef MOAB_HAVE_MPI return MB_FAILURE; #else // Pack entities to local buffer int ind = get_buffers( to_proc ); localOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); // Add vertices ErrorCode result = add_verts( orig_ents );MB_CHK_SET_ERR( result, "Failed to add verts in send_entities" ); // Filter out entities already shared with destination Range tmp_range; result = filter_pstatus( orig_ents, PSTATUS_SHARED, PSTATUS_AND, to_proc, &tmp_range );MB_CHK_SET_ERR( result, "Failed to filter on owner" ); if( !tmp_range.empty() ) { orig_ents = subtract( orig_ents, tmp_range ); } result = pack_buffer( orig_ents, adjs, tags, store_remote_handles, to_proc, localOwnedBuffs[ind], &entprocs );MB_CHK_SET_ERR( result, "Failed to pack buffer in send_entities" ); // Send buffer result = send_buffer( to_proc, localOwnedBuffs[ind], MB_MESG_ENTS_SIZE, sendReqs[2 * ind], recvReqs[2 * ind + 1], (int*)( remoteOwnedBuffs[ind]->mem_ptr ), //&ackbuff, incoming1, MB_MESG_REMOTEH_SIZE, ( !is_iface && store_remote_handles ? localOwnedBuffs[ind] : NULL ), &recv_remoteh_reqs[2 * ind], &incoming2 );MB_CHK_SET_ERR( result, "Failed to send buffer" ); return MB_SUCCESS; #endif }
ErrorCode moab::ParallelComm::send_entities | ( | std::vector< unsigned int > & | send_procs, |
std::vector< Range * > & | send_ents, | ||
const bool | store_remote_handles | ||
Definition at line 743 of file ParallelComm.cpp.
References ackbuff, add_verts(), buffProcs, moab::Range::compactness(), moab::TupleList::disableWriteAccess(), moab::Range::empty(), moab::TupleList::enableWriteAccess(), ErrorCode, filter_pstatus(), get_buffers(), moab::TupleList::get_n(), moab::DebugOutput::get_verbosity(), moab::TupleList::inc_n(), moab::TupleList::initialize(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SUCCESS, moab::Range::merge(), MPE_Log_event, moab::msgs, myDebug, pack_buffer(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_SHARED, recvRemotehReqs, recvReqs, moab::TupleList::buffer::reset(), moab::TupleList::reset(), send_buffer(), sendReqs, moab::Range::size(), size(), moab::TupleList::sort(), moab::subtract(), moab::DebugOutput::tprintf(), moab::TupleList::vi_wr, and moab::TupleList::vul_wr.
{ #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( OWNED_START, procConfig.proc_rank(), "Starting send_entities." ); } #endif myDebug->tprintf( 1, "Entering send_entities\n" ); if( myDebug->get_verbosity() == 4 ) { msgs.clear(); msgs.reserve( MAX_SHARING_PROCS ); } unsigned int i; int ind; ErrorCode result = MB_SUCCESS; // Set buffProcs with communicating procs unsigned int n_proc = send_procs.size(); for( i = 0; i < n_proc; i++ ) { ind = get_buffers( send_procs[i] ); result = add_verts( *send_ents[i] );MB_CHK_SET_ERR( result, "Failed to add verts" ); // Filter out entities already shared with destination Range tmp_range; result = filter_pstatus( *send_ents[i], PSTATUS_SHARED, PSTATUS_AND, buffProcs[ind], &tmp_range );MB_CHK_SET_ERR( result, "Failed to filter on owner" ); if( !tmp_range.empty() ) { *send_ents[i] = subtract( *send_ents[i], tmp_range ); } } //=========================================== // Get entities to be sent to neighbors // Need to get procs each entity is sent to //=========================================== Range allsent, tmp_range; int npairs = 0; TupleList entprocs; for( i = 0; i < n_proc; i++ ) { int n_ents = send_ents[i]->size(); if( n_ents > 0 ) { npairs += n_ents; // Get the total # of proc/handle pairs allsent.merge( *send_ents[i] ); } } // Allocate a TupleList of that size entprocs.initialize( 1, 0, 1, 0, npairs ); entprocs.enableWriteAccess(); // Put the proc/handle pairs in the list for( i = 0; i < n_proc; i++ ) { for( Range::iterator rit = send_ents[i]->begin(); rit != send_ents[i]->end(); ++rit ) { entprocs.vi_wr[entprocs.get_n()] = send_procs[i]; entprocs.vul_wr[entprocs.get_n()] = *rit; entprocs.inc_n(); } } // Sort by handle moab::TupleList::buffer sort_buffer; sort_buffer.buffer_init( npairs ); entprocs.sort( 1, &sort_buffer ); entprocs.disableWriteAccess(); sort_buffer.reset(); myDebug->tprintf( 1, "allsent ents compactness (size) = %f (%lu)\n", allsent.compactness(), (unsigned long)allsent.size() ); //=========================================== // Pack and send ents from this proc to others //=========================================== for( i = 0; i < n_proc; i++ ) { if( send_ents[i]->size() > 0 ) { ind = get_buffers( send_procs[i] ); myDebug->tprintf( 1, "Sent ents compactness (size) = %f (%lu)\n", send_ents[i]->compactness(), (unsigned long)send_ents[i]->size() ); // Reserve space on front for size and for initial buff size localOwnedBuffs[ind]->reset_buffer( sizeof( int ) ); result = pack_buffer( *send_ents[i], false, true, store_remote_handles, buffProcs[ind], localOwnedBuffs[ind], &entprocs, &allsent ); if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *localOwnedBuffs[ind] ); } // Send the buffer (size stored in front in send_buffer) result = send_buffer( send_procs[i], localOwnedBuffs[ind], MB_MESG_ENTS_SIZE, sendReqs[2 * ind], recvReqs[2 * ind + 1], &ackbuff, incoming1, MB_MESG_REMOTEH_SIZE, ( store_remote_handles ? localOwnedBuffs[ind] : NULL ), &recvRemotehReqs[2 * ind], &incoming2 );MB_CHK_SET_ERR( result, "Failed to Isend in ghost send" ); } } entprocs.reset(); #ifdef MOAB_HAVE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( ENTITIES_END, procConfig.proc_rank(), "Ending send_entities." ); } #endif return MB_SUCCESS; }
ErrorCode moab::ParallelComm::send_recv_entities | ( | std::vector< int > & | send_procs, |
std::vector< std::vector< int > > & | msgsizes, | ||
std::vector< std::vector< EntityHandle > > & | senddata, | ||
std::vector< std::vector< EntityHandle > > & | recvdata | ||
Send and receives data from a set of processors.
Definition at line 873 of file ParallelComm.cpp.
References buffProcs, entities, moab::error(), ErrorCode, get_buffers(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, MB_SET_ERR, MB_SUCCESS, MPE_Log_event, moab::msgs, myDebug, moab::PACK_EH(), moab::PACK_INTS(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), remoteOwnedBuffs, reset_all_buffers(), send_buffer(), sendReqs, size(), moab::DebugOutput::tprintf(), moab::UNPACK_EH(), and moab::UNPACK_INTS().
{ #ifdef USE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( OWNED_START, procConfig.proc_rank(), "Starting send_recv_entities." ); } #endif myDebug->tprintf( 1, "Entering send_recv_entities\n" ); if( myDebug->get_verbosity() == 4 ) { msgs.clear(); msgs.reserve( MAX_SHARING_PROCS ); } // unsigned int i; int i, ind, success; ErrorCode error = MB_SUCCESS; //=========================================== // Pack and send ents from this proc to others //=========================================== // std::cout<<"resetting all buffers"<<std::endl; reset_all_buffers(); sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); std::vector< MPI_Request > recv_ent_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL ); int ack_buff; int incoming = 0; std::vector< unsigned int >::iterator sit; for( ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); ++sit, ind++ ) { incoming++; PRINT_DEBUG_IRECV( *sit, procConfig.proc_rank(), remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_ENTS_SIZE, incoming ); success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, *sit, MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recv_ent_reqs[3 * ind] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv in send_recv_entities" ); } } // std::set<unsigned int>::iterator it; for( i = 0; i < (int)send_procs.size(); i++ ) { // Get index of the shared processor in the local buffer ind = get_buffers( send_procs[i] ); localOwnedBuffs[ind]->reset_buffer( sizeof( int ) ); int buff_size = msgsizes[i].size() * sizeof( int ) + senddata[i].size() * sizeof( EntityHandle ); localOwnedBuffs[ind]->check_space( buff_size ); // Pack entities std::vector< int > msg; msg.insert( msg.end(), msgsizes[i].begin(), msgsizes[i].end() ); PACK_INTS( localOwnedBuffs[ind]->buff_ptr, &msg[0], msg.size() ); std::vector< EntityHandle > entities; entities.insert( entities.end(), senddata[i].begin(), senddata[i].end() ); PACK_EH( localOwnedBuffs[ind]->buff_ptr, &entities[0], entities.size() ); localOwnedBuffs[ind]->set_stored_size(); if( myDebug->get_verbosity() == 4 ) { msgs.resize( msgs.size() + 1 ); msgs.back() = new Buffer( *localOwnedBuffs[ind] ); } // Send the buffer (size stored in front in send_buffer) error = send_buffer( send_procs[i], localOwnedBuffs[ind], MB_MESG_ENTS_SIZE, sendReqs[3 * ind], recv_ent_reqs[3 * ind + 2], &ack_buff, incoming );MB_CHK_SET_ERR( error, "Failed to Isend in send_recv_entities" ); } //=========================================== // Receive and unpack ents from received data //=========================================== while( incoming ) { MPI_Status status; int index_in_recv_requests; PRINT_DEBUG_WAITANY( recv_ent_reqs, MB_MESG_ENTS_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 3 * buffProcs.size(), &recv_ent_reqs[0], &index_in_recv_requests, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in send_recv_entities" ); } // Processor index in the list is divided by 3 ind = index_in_recv_requests / 3; PRINT_DEBUG_RECD( status ); // OK, received something; decrement incoming counter incoming--; bool done = false; error = recv_buffer( MB_MESG_ENTS_SIZE, status, remoteOwnedBuffs[ind], recv_ent_reqs[3 * ind + 1], // This is for receiving the second message recv_ent_reqs[3 * ind + 2], // This would be for ack, but it is not // used; consider removing it incoming, localOwnedBuffs[ind], sendReqs[3 * ind + 1], // Send request for sending the second message sendReqs[3 * ind + 2], // This is for sending the ack done );MB_CHK_SET_ERR( error, "Failed to resize recv buffer" ); if( done ) { remoteOwnedBuffs[ind]->reset_ptr( sizeof( int ) ); int from_proc = status.MPI_SOURCE; int idx = std::find( send_procs.begin(), send_procs.end(), from_proc ) - send_procs.begin(); int msg = msgsizes[idx].size(); std::vector< int > recvmsg( msg ); int ndata = senddata[idx].size(); std::vector< EntityHandle > dum_vec( ndata ); UNPACK_INTS( remoteOwnedBuffs[ind]->buff_ptr, &recvmsg[0], msg ); UNPACK_EH( remoteOwnedBuffs[ind]->buff_ptr, &dum_vec[0], ndata ); recvdata[idx].insert( recvdata[idx].end(), dum_vec.begin(), dum_vec.end() ); } } #ifdef USE_MPE if( myDebug->get_verbosity() == 2 ) { MPE_Log_event( ENTITIES_END, procConfig.proc_rank(), "Ending send_recv_entities." ); } #endif return MB_SUCCESS; }
void moab::ParallelComm::set_debug_verbosity | ( | int | verb | ) |
set the verbosity level of output from this pcomm
Definition at line 8867 of file ParallelComm.cpp.
References myDebug, and moab::DebugOutput::set_verbosity().
{ myDebug->set_verbosity( verb ); }
Definition at line 8075 of file ParallelComm.cpp.
References moab::Interface::add_entities(), ErrorCode, moab::Interface::get_entities_by_handle(), MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, mbImpl, partition_sets(), moab::PARTITIONING_PCOMM_TAG_NAME, partitioningSet, pcomm_tag(), moab::Interface::tag_delete_data(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by get_pcomm().
{ ErrorCode rval; Tag prtn_tag; rval = mbImpl->tag_get_handle( PARTITIONING_PCOMM_TAG_NAME, 1, MB_TYPE_INTEGER, prtn_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); if( MB_SUCCESS != rval ) return rval; // Get my id ParallelComm* pcomm_arr[MAX_SHARING_PROCS]; Tag pc_tag = pcomm_tag( mbImpl, false ); if( 0 == pc_tag ) return MB_FAILURE; const EntityHandle root = 0; ErrorCode result = mbImpl->tag_get_data( pc_tag, &root, 1, pcomm_arr ); if( MB_SUCCESS != result ) return MB_FAILURE; int id = std::find( pcomm_arr, pcomm_arr + MAX_SHARING_PROCS, this ) - pcomm_arr; if( id == MAX_SHARING_PROCS ) return MB_FAILURE; EntityHandle old = partitioningSet; if( old ) { rval = mbImpl->tag_delete_data( prtn_tag, &old, 1 ); if( MB_SUCCESS != rval ) return rval; partitioningSet = 0; } if( !set ) return MB_SUCCESS; Range contents; if( old ) { rval = mbImpl->get_entities_by_handle( old, contents ); if( MB_SUCCESS != rval ) return rval; } else { contents = partition_sets(); } rval = mbImpl->add_entities( set, contents ); if( MB_SUCCESS != rval ) return rval; // Store pcomm id on new partition set rval = mbImpl->tag_set_data( prtn_tag, &set, 1, &id ); if( MB_SUCCESS != rval ) return rval; partitioningSet = set; return MB_SUCCESS; }
ErrorCode moab::ParallelComm::set_pstatus_entities | ( | Range & | pstatus_ents, |
unsigned char | pstatus_val, | ||
bool | lower_dim_ents = false , |
bool | verts_too = true , |
int | operation = Interface::UNION |
) | [private] |
Set pstatus values on entities.
pstatus_ents | Entities to be set |
pstatus_val | Pstatus value to be set |
lower_dim_ents | If true, lower-dimensional ents (incl. vertices) set too (and created if they don't exist) |
verts_too | If true, vertices also set |
operation | If UNION, pstatus_val is OR-d with existing value, otherwise existing value is over-written |
Definition at line 4410 of file ParallelComm.cpp.
References moab::Interface::dimension_from_handle(), ErrorCode, moab::Interface::get_adjacencies(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, pstatus_tag(), moab::Range::rbegin(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and moab::Interface::UNION.
Referenced by set_pstatus_entities().
{ std::vector< unsigned char > pstatus_vals( pstatus_ents.size() ); Range all_ents, *range_ptr = &pstatus_ents; ErrorCode result; if( lower_dim_ents || verts_too ) { all_ents = pstatus_ents; range_ptr = &all_ents; int start_dim = ( lower_dim_ents ? mbImpl->dimension_from_handle( *pstatus_ents.rbegin() ) - 1 : 0 ); for( ; start_dim >= 0; start_dim-- ) { result = mbImpl->get_adjacencies( all_ents, start_dim, true, all_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get adjacencies for pstatus entities" ); } } if( Interface::UNION == operation ) { result = mbImpl->tag_get_data( pstatus_tag(), *range_ptr, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" ); for( unsigned int i = 0; i < pstatus_vals.size(); i++ ) pstatus_vals[i] |= pstatus_val; } else { for( unsigned int i = 0; i < pstatus_vals.size(); i++ ) pstatus_vals[i] = pstatus_val; } result = mbImpl->tag_set_data( pstatus_tag(), *range_ptr, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to set pstatus tag data" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::set_pstatus_entities | ( | EntityHandle * | pstatus_ents, |
int | num_ents, | ||
) | [private] |
Set pstatus values on entities (vector-based function)
Definition at line 4445 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, pstatus_tag(), set_pstatus_entities(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and moab::Interface::UNION.
{ std::vector< unsigned char > pstatus_vals( num_ents ); ErrorCode result; if( lower_dim_ents || verts_too ) { // In this case, call the range-based version Range tmp_range; std::copy( pstatus_ents, pstatus_ents + num_ents, range_inserter( tmp_range ) ); return set_pstatus_entities( tmp_range, pstatus_val, lower_dim_ents, verts_too, operation ); } if( Interface::UNION == operation ) { result = mbImpl->tag_get_data( pstatus_tag(), pstatus_ents, num_ents, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" ); for( unsigned int i = 0; i < (unsigned int)num_ents; i++ ) pstatus_vals[i] |= pstatus_val; } else { for( unsigned int i = 0; i < (unsigned int)num_ents; i++ ) pstatus_vals[i] = pstatus_val; } result = mbImpl->tag_set_data( pstatus_tag(), pstatus_ents, num_ents, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to set pstatus tag data" ); return MB_SUCCESS; }
void moab::ParallelComm::set_rank | ( | unsigned int | r | ) | [inline] |
set rank for this pcomm; USED FOR TESTING ONLY!
Definition at line 1662 of file ParallelComm.hpp.
References moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), and procConfig.
{ procConfig.proc_rank( r ); if( procConfig.proc_size() < r ) procConfig.proc_size( r + 1 ); }
void moab::ParallelComm::set_recv_request | ( | int | n_request | ) | [inline] |
Definition at line 1702 of file ParallelComm.hpp.
References recvReqs.
{ recvReqs.resize( n_request, MPI_REQUEST_NULL ); }
void moab::ParallelComm::set_send_request | ( | int | n_request | ) | [inline] |
Definition at line 1697 of file ParallelComm.hpp.
References sendReqs.
{ sendReqs.resize( n_request, MPI_REQUEST_NULL ); }
ErrorCode moab::ParallelComm::set_sharing_data | ( | EntityHandle | ent, |
unsigned char | pstatus, | ||
int | old_nump, | ||
int | new_nump, | ||
int * | ps, | ||
EntityHandle * | hs | ||
) | [private] |
Definition at line 6422 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, mbImpl, moab::ProcConfig::proc_rank(), procConfig, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, pstatus_tag(), rank(), sharedEnts, sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), moab::Interface::tag_delete_data(), and moab::Interface::tag_set_data().
Referenced by check_clean_iface(), and update_remote_data().
{ // If new nump is less than 3, the entity is no longer mutishared if( old_nump > 2 && ( pstatus & PSTATUS_MULTISHARED ) && new_nump < 3 ) { // Unset multishared flag pstatus ^= PSTATUS_MULTISHARED; } // Check for consistency in input data // DBG /* bool con1 = ((new_nump == 2 && pstatus&PSTATUS_SHARED && !(pstatus&PSTATUS_MULTISHARED)) || (new_nump > 2 && pstatus&PSTATUS_SHARED && pstatus&PSTATUS_MULTISHARED)); bool con2 = (!(pstatus&PSTATUS_GHOST) || pstatus&PSTATUS_SHARED); bool con3 = (new_nump < 3 || (pstatus&PSTATUS_NOT_OWNED && ps[0] != (int)rank()) || (!(pstatus&PSTATUS_NOT_OWNED) && ps[0] == (int)rank())); std::cout<<"current rank = "<<rank()<<std::endl; std::cout<<"condition 1::"<<con1<<std::endl; std::cout<<"condition 2::"<<con2<<std::endl; std::cout<<"condition 3::"<<con3<<std::endl;*/ // DBG assert( new_nump > 1 && ( ( new_nump == 2 && pstatus & PSTATUS_SHARED && !( pstatus & PSTATUS_MULTISHARED ) ) || // If <= 2 must not be multishared ( new_nump > 2 && pstatus & PSTATUS_SHARED && pstatus & PSTATUS_MULTISHARED ) ) && // If > 2 procs, must be multishared ( !( pstatus & PSTATUS_GHOST ) || pstatus & PSTATUS_SHARED ) && // If ghost, it must also be shared ( new_nump < 3 || ( pstatus & PSTATUS_NOT_OWNED && ps[0] != (int)rank() ) || // I'm not owner and first proc not me ( !( pstatus & PSTATUS_NOT_OWNED ) && ps[0] == (int)rank() ) ) // I'm owner and first proc is me ); #ifndef NDEBUG { // Check for duplicates in proc list std::set< unsigned int > dumprocs; int dp = 0; for( ; dp < old_nump && -1 != ps[dp]; dp++ ) dumprocs.insert( ps[dp] ); assert( dp == (int)dumprocs.size() ); } #endif ErrorCode result; // Reset any old data that needs to be if( old_nump > 2 && new_nump < 3 ) { // Need to remove multishared tags result = mbImpl->tag_delete_data( sharedps_tag(), &ent, 1 );MB_CHK_SET_ERR( result, "set_sharing_data:1" ); result = mbImpl->tag_delete_data( sharedhs_tag(), &ent, 1 );MB_CHK_SET_ERR( result, "set_sharing_data:2" ); // if (new_nump < 2) // pstatus = 0x0; // else if (ps[0] != (int)proc_config().proc_rank()) // pstatus |= PSTATUS_NOT_OWNED; } else if( ( old_nump < 3 && new_nump > 2 ) || ( old_nump > 1 && new_nump == 1 ) ) { // Reset sharedp and sharedh tags int tmp_p = -1; EntityHandle tmp_h = 0; result = mbImpl->tag_set_data( sharedp_tag(), &ent, 1, &tmp_p );MB_CHK_SET_ERR( result, "set_sharing_data:3" ); result = mbImpl->tag_set_data( sharedh_tag(), &ent, 1, &tmp_h );MB_CHK_SET_ERR( result, "set_sharing_data:4" ); } assert( "check for multishared/owner I'm first proc" && ( !( pstatus & PSTATUS_MULTISHARED ) || ( pstatus & ( PSTATUS_NOT_OWNED | PSTATUS_GHOST ) ) || ( ps[0] == (int)rank() ) ) && "interface entities should have > 1 proc" && ( !( pstatus & PSTATUS_INTERFACE ) || new_nump > 1 ) && "ghost entities should have > 1 proc" && ( !( pstatus & PSTATUS_GHOST ) || new_nump > 1 ) ); // Now set new data if( new_nump > 2 ) { result = mbImpl->tag_set_data( sharedps_tag(), &ent, 1, ps );MB_CHK_SET_ERR( result, "set_sharing_data:5" ); result = mbImpl->tag_set_data( sharedhs_tag(), &ent, 1, hs );MB_CHK_SET_ERR( result, "set_sharing_data:6" ); } else { unsigned int j = ( ps[0] == (int)procConfig.proc_rank() ? 1 : 0 ); assert( -1 != ps[j] ); result = mbImpl->tag_set_data( sharedp_tag(), &ent, 1, ps + j );MB_CHK_SET_ERR( result, "set_sharing_data:7" ); result = mbImpl->tag_set_data( sharedh_tag(), &ent, 1, hs + j );MB_CHK_SET_ERR( result, "set_sharing_data:8" ); } result = mbImpl->tag_set_data( pstatus_tag(), &ent, 1, &pstatus );MB_CHK_SET_ERR( result, "set_sharing_data:9" ); if( old_nump > 1 && new_nump < 2 ) sharedEnts.erase( ent ); return result; }
void moab::ParallelComm::set_size | ( | unsigned int | r | ) | [inline] |
Definition at line 1668 of file ParallelComm.hpp.
References moab::ProcConfig::proc_size(), and procConfig.
{ procConfig.proc_size( s ); }
ErrorCode moab::ParallelComm::settle_intersection_points | ( | Range & | edges, |
Range & | shared_edges_owned, | ||
std::vector< std::vector< EntityHandle > * > & | extraNodesVec, | ||
double | tolerance | ||
Definition at line 9036 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, buffProcs, moab::ParallelComm::Buffer::check_space(), moab::Range::end(), entities, ErrorCode, filter_pstatus(), moab::Range::find(), get_comm_procs(), moab::Interface::get_coords(), get_remote_handles(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_TAGS_SIZE, MB_SET_ERR, MB_SUCCESS, mbImpl, myDebug, moab::PACK_EH(), moab::PACK_INT(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_SHARED, recv_buffer(), remoteOwnedBuffs, reset_all_buffers(), moab::ParallelComm::Buffer::reset_ptr(), send_buffer(), sendReqs, moab::Interface::set_coords(), moab::ParallelComm::Buffer::set_stored_size(), moab::Range::size(), moab::DebugOutput::tprintf(), moab::UNPACK_DBLS(), moab::UNPACK_EH(), and moab::UNPACK_INT().
{ // The index of an edge in the edges Range will give the index for extraNodesVec // the strategy of this follows exchange tags strategy: ErrorCode result; int success; myDebug->tprintf( 1, "Entering settle_intersection_points\n" ); // Get all procs interfacing to this proc std::set< unsigned int > exch_procs; result = get_comm_procs( exch_procs ); // Post ghost irecv's for all interface procs // Index requests the same as buffer/sharing procs indices std::vector< MPI_Request > recv_intx_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL ); std::vector< unsigned int >::iterator sit; int ind; reset_all_buffers(); int incoming = 0; for( ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); ++sit, ind++ ) { incoming++; PRINT_DEBUG_IRECV( *sit, procConfig.proc_rank(), remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MB_MESG_TAGS_SIZE, incoming ); success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, *sit, MB_MESG_TAGS_SIZE, procConfig.proc_comm(), &recv_intx_reqs[3 * ind] ); if( success != MPI_SUCCESS ) { MB_SET_ERR( MB_FAILURE, "Failed to post irecv in settle intersection point" ); } } // Pack and send intersection points from this proc to others // Make sendReqs vector to simplify initialization sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL ); // Take all shared entities if incoming list is empty Range& entities = shared_edges_owned; int dum_ack_buff; for( ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); ++sit, ind++ ) { Range edges_to_send = entities; // Get ents shared by proc *sit result = filter_pstatus( edges_to_send, PSTATUS_SHARED, PSTATUS_AND, *sit );MB_CHK_SET_ERR( result, "Failed pstatus AND check" ); // Remote nonowned entities; not needed, edges are already owned by this proc // Pack the data // Reserve space on front for size and for initial buff size Buffer* buff = localOwnedBuffs[ind]; buff->reset_ptr( sizeof( int ) ); /*result = pack_intx_points(edges_to_send, edges, extraNodesVec, localOwnedBuffs[ind], *sit);*/ // Count first data, and see if it is enough room? // Send the remote handles std::vector< EntityHandle > dum_remote_edges( edges_to_send.size() ); /* * get_remote_handles(const bool store_remote_handles, EntityHandle *from_vec, EntityHandle *to_vec_tmp, int num_ents, int to_proc, const std::vector<EntityHandle> &new_ents); */ // We are sending count, num edges, remote edges handles, and then, for each edge: // -- nb intx points, 3*nbintPointsforEdge "doubles" std::vector< EntityHandle > dum_vec; result = get_remote_handles( true, edges_to_send, &dum_remote_edges[0], *sit, dum_vec );MB_CHK_SET_ERR( result, "Failed to get remote handles" ); int count = 4; // Size of data count += sizeof( int ) * (int)edges_to_send.size(); count += sizeof( EntityHandle ) * (int)edges_to_send.size(); // We will send the remote handles for( Range::iterator eit = edges_to_send.begin(); eit != edges_to_send.end(); ++eit ) { EntityHandle edge = *eit; unsigned int indx = edges.find( edge ) - edges.begin(); std::vector< EntityHandle >& intx_nodes = *( extraNodesVec[indx] ); count += (int)intx_nodes.size() * 3 * sizeof( double ); // 3 integer for each entity handle } // buff->check_space( count ); PACK_INT( buff->buff_ptr, edges_to_send.size() ); PACK_EH( buff->buff_ptr, &dum_remote_edges[0], dum_remote_edges.size() ); for( Range::iterator eit = edges_to_send.begin(); eit != edges_to_send.end(); ++eit ) { EntityHandle edge = *eit; // Pack the remote edge unsigned int indx = edges.find( edge ) - edges.begin(); std::vector< EntityHandle >& intx_nodes = *( extraNodesVec[indx] ); PACK_INT( buff->buff_ptr, intx_nodes.size() ); result = mbImpl->get_coords( &intx_nodes[0], intx_nodes.size(), (double*)buff->buff_ptr );MB_CHK_SET_ERR( result, "Failed to get coords" ); buff->buff_ptr += 3 * sizeof( double ) * intx_nodes.size(); } // Done packing the intx points and remote edges buff->set_stored_size(); // Now send it result = send_buffer( *sit, localOwnedBuffs[ind], MB_MESG_TAGS_SIZE, sendReqs[3 * ind], recv_intx_reqs[3 * ind + 2], &dum_ack_buff, incoming );MB_CHK_SET_ERR( result, "Failed to send buffer" ); } // Receive/unpack intx points while( incoming ) { MPI_Status status; int index_in_recv_requests; PRINT_DEBUG_WAITANY( recv_intx_reqs, MB_MESG_TAGS_SIZE, procConfig.proc_rank() ); success = MPI_Waitany( 3 * buffProcs.size(), &recv_intx_reqs[0], &index_in_recv_requests, &status ); if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failed in waitany in ghost exchange" ); } // Processor index in the list is divided by 3 ind = index_in_recv_requests / 3; PRINT_DEBUG_RECD( status ); // OK, received something; decrement incoming counter incoming--; bool done = false; result = recv_buffer( MB_MESG_TAGS_SIZE, status, remoteOwnedBuffs[ind], recv_intx_reqs[3 * ind + 1], // This is for receiving the second message recv_intx_reqs[3 * ind + 2], // This would be for ack, but it is not // used; consider removing it incoming, localOwnedBuffs[ind], sendReqs[3 * ind + 1], // Send request for sending the second message sendReqs[3 * ind + 2], // This is for sending the ack done );MB_CHK_SET_ERR( result, "Failed to resize recv buffer" ); if( done ) { Buffer* buff = remoteOwnedBuffs[ind]; buff->reset_ptr( sizeof( int ) ); /*result = unpack_tags(remoteOwnedBuffs[ind/2]->buff_ptr, dum_vec, true, buffProcs[ind/2]);*/ // Unpack now the edges and vertex info; compare with the existing vertex positions int num_edges; UNPACK_INT( buff->buff_ptr, num_edges ); std::vector< EntityHandle > rec_edges; rec_edges.resize( num_edges ); UNPACK_EH( buff->buff_ptr, &rec_edges[0], num_edges ); for( int i = 0; i < num_edges; i++ ) { EntityHandle edge = rec_edges[i]; unsigned int indx = edges.find( edge ) - edges.begin(); std::vector< EntityHandle >& intx_nodes = *( extraNodesVec[indx] ); // Now get the number of nodes on this (now local) edge int nverts; UNPACK_INT( buff->buff_ptr, nverts ); std::vector< double > pos_from_owner; pos_from_owner.resize( 3 * nverts ); UNPACK_DBLS( buff->buff_ptr, &pos_from_owner[0], 3 * nverts ); std::vector< double > current_positions( 3 * intx_nodes.size() ); result = mbImpl->get_coords( &intx_nodes[0], intx_nodes.size(), ¤t_positions[0] );MB_CHK_SET_ERR( result, "Failed to get current positions" ); // Now, look at what we have in current pos, compare to pos from owner, and reset for( int k = 0; k < (int)intx_nodes.size(); k++ ) { double* pk = ¤t_positions[3 * k]; // Take the current pos k, and settle among the ones from owner: bool found = false; for( int j = 0; j < nverts && !found; j++ ) { double* pj = &pos_from_owner[3 * j]; double dist2 = ( pk[0] - pj[0] ) * ( pk[0] - pj[0] ) + ( pk[1] - pj[1] ) * ( pk[1] - pj[1] ) + ( pk[2] - pj[2] ) * ( pk[2] - pj[2] ); if( dist2 < tolerance ) { pk[0] = pj[0]; pk[1] = pj[1]; pk[2] = pj[2]; // Correct it! found = true; break; } } if( !found ) { #ifndef NDEBUG std::cout << " pk:" << pk[0] << " " << pk[1] << " " << pk[2] << " not found \n"; #endif result = MB_FAILURE; } } // After we are done resetting, we can set the new positions of nodes: result = mbImpl->set_coords( &intx_nodes[0], (int)intx_nodes.size(), ¤t_positions[0] );MB_CHK_SET_ERR( result, "Failed to set new current positions" ); } } } // OK, now wait if( myDebug->get_verbosity() == 5 ) { success = MPI_Barrier( procConfig.proc_comm() ); } else { MPI_Status status[3 * MAX_SHARING_PROCS]; success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], status ); } if( MPI_SUCCESS != success ) { MB_SET_ERR( MB_FAILURE, "Failure in waitall in tag exchange" ); } myDebug->tprintf( 1, "Exiting settle_intersection_points" ); return MB_SUCCESS; }
return sharedh tag
Definition at line 7934 of file ParallelComm.cpp.
References ErrorCode, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, mbImpl, PARALLEL_SHARED_HANDLE_TAG_NAME, sharedhTag, and moab::Interface::tag_get_handle().
Referenced by check_clean_iface(), check_sent_ents(), clean_shared_tags(), correct_thin_ghost_layers(), get_owner_handle(), get_owning_part(), get_shared_proc_tags(), get_sharing_data(), get_sharing_parts(), set_sharing_data(), and update_remote_data_old().
{ if( !sharedhTag ) { EntityHandle def_val = 0; ErrorCode result = mbImpl->tag_get_handle( PARALLEL_SHARED_HANDLE_TAG_NAME, 1, MB_TYPE_HANDLE, sharedhTag, MB_TAG_DENSE | MB_TAG_CREAT, &def_val ); if( MB_SUCCESS != result ) return 0; } return sharedhTag; }
return sharedhs tag
Definition at line 7948 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_HANDLE, mbImpl, PARALLEL_SHARED_HANDLES_TAG_NAME, sharedhsTag, and moab::Interface::tag_get_handle().
Referenced by check_clean_iface(), check_sent_ents(), correct_thin_ghost_layers(), get_owner_handle(), get_owning_part(), get_shared_proc_tags(), get_sharing_data(), get_sharing_parts(), set_sharing_data(), and update_remote_data_old().
{ if( !sharedhsTag ) { ErrorCode result = mbImpl->tag_get_handle( PARALLEL_SHARED_HANDLES_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_HANDLE, sharedhsTag, MB_TAG_SPARSE | MB_TAG_CREAT ); if( MB_SUCCESS != result ) return 0; } return sharedhsTag; }
return sharedp tag
Definition at line 7907 of file ParallelComm.cpp.
References ErrorCode, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, mbImpl, PARALLEL_SHARED_PROC_TAG_NAME, sharedpTag, and moab::Interface::tag_get_handle().
Referenced by check_clean_iface(), check_sent_ents(), clean_shared_tags(), correct_thin_ghost_layers(), filter_pstatus(), get_interface_procs(), get_owner_handle(), get_owning_part(), get_shared_proc_tags(), get_sharing_data(), get_sharing_parts(), is_iface_proc(), pack_entities(), set_sharing_data(), and update_remote_data_old().
{ if( !sharedpTag ) { int def_val = -1; ErrorCode result = mbImpl->tag_get_handle( PARALLEL_SHARED_PROC_TAG_NAME, 1, MB_TYPE_INTEGER, sharedpTag, MB_TAG_DENSE | MB_TAG_CREAT, &def_val ); if( MB_SUCCESS != result ) return 0; } return sharedpTag; }
return sharedps tag
Definition at line 7921 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, mbImpl, PARALLEL_SHARED_PROCS_TAG_NAME, sharedpsTag, and moab::Interface::tag_get_handle().
Referenced by check_clean_iface(), check_sent_ents(), correct_thin_ghost_layers(), filter_pstatus(), get_interface_procs(), get_owner_handle(), get_owning_part(), get_shared_proc_tags(), get_sharing_data(), get_sharing_parts(), is_iface_proc(), set_sharing_data(), and update_remote_data_old().
{ if( !sharedpsTag ) { ErrorCode result = mbImpl->tag_get_handle( PARALLEL_SHARED_PROCS_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_INTEGER, sharedpsTag, MB_TAG_SPARSE | MB_TAG_CREAT ); if( MB_SUCCESS != result ) return 0; } return sharedpsTag; }
unsigned moab::ParallelComm::size | ( | ) | const [inline] |
Definition at line 648 of file ParallelComm.hpp.
References proc_config(), and moab::ProcConfig::proc_size().
Referenced by assign_global_ids(), augment_default_sets_with_ghosts(), moab::ScdInterface::construct_box(), exchange_ghost_cells(), exchange_owned_mesh(), gather_data(), moab::NestedRefine::generate_hm(), get_sent_ents(), hcFilter(), iMOAB_SetDoubleTagStorageWithGid(), moab::DataCoupler::interpolate(), laplacianFilter(), moab::ReadParallel::load_file(), moab::DataCoupler::locate_points(), main(), moab::ParallelMergeMesh::PartitionGlobalBox(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::ParallelMergeMesh::PerformMerge(), moab::ParallelMergeMesh::PopulateMySkinEnts(), DeformMeshRemap::read_file(), resolve_shared_ents(), send_entities(), send_recv_entities(), and tag_shared_verts().
{ return proc_config().proc_size(); }
ErrorCode moab::ParallelComm::tag_iface_entities | ( | ) | [private] |
Set pstatus tag interface bit on entities in sets passed in.
Definition at line 4360 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), moab::Range::insert(), interfaceSets, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, PSTATUS_INTERFACE, PSTATUS_NOT_OWNED, pstatus_tag(), moab::Interface::remove_entities(), moab::Range::size(), moab::subtract(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by exchange_ghost_cells().
{ ErrorCode result = MB_SUCCESS; Range iface_ents, tmp_ents, rmv_ents; std::vector< unsigned char > pstat; unsigned char set_pstat; Range::iterator rit2; unsigned int i; for( Range::iterator rit = interfaceSets.begin(); rit != interfaceSets.end(); ++rit ) { iface_ents.clear(); result = mbImpl->get_entities_by_handle( *rit, iface_ents );MB_CHK_SET_ERR( result, "Failed to get interface set contents" ); pstat.resize( iface_ents.size() ); result = mbImpl->tag_get_data( pstatus_tag(), iface_ents, &pstat[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus values for interface set entities" ); result = mbImpl->tag_get_data( pstatus_tag(), &( *rit ), 1, &set_pstat );MB_CHK_SET_ERR( result, "Failed to get pstatus values for interface set" ); rmv_ents.clear(); for( rit2 = iface_ents.begin(), i = 0; rit2 != iface_ents.end(); ++rit2, i++ ) { if( !( pstat[i] & PSTATUS_INTERFACE ) ) { rmv_ents.insert( *rit2 ); pstat[i] = 0x0; } } result = mbImpl->remove_entities( *rit, rmv_ents );MB_CHK_SET_ERR( result, "Failed to remove entities from interface set" ); if( !( set_pstat & PSTATUS_NOT_OWNED ) ) continue; // If we're here, we need to set the notowned status on (remaining) set contents // Remove rmv_ents from the contents list iface_ents = subtract( iface_ents, rmv_ents ); // Compress the pstat vector (removing 0x0's) std::remove_if( pstat.begin(), pstat.end(), std::bind( std::equal_to< unsigned char >(), std::placeholders::_1, 0x0 ) ); // std::bind2nd(std::equal_to<unsigned char>(), 0x0)); // https://stackoverflow.com/questions/32739018/a-replacement-for-stdbind2nd // Fold the not_owned bit into remaining values unsigned int sz = iface_ents.size(); for( i = 0; i < sz; i++ ) pstat[i] |= PSTATUS_NOT_OWNED; // Set the tag on the entities result = mbImpl->tag_set_data( pstatus_tag(), iface_ents, &pstat[0] );MB_CHK_SET_ERR( result, "Failed to set pstatus values for interface set entities" ); } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::tag_shared_verts | ( | TupleList & | shared_ents, |
std::map< std::vector< int >, std::vector< EntityHandle > > & | proc_nvecs, | ||
Range & | proc_verts, | ||
unsigned int | i_extra = 1 |
Definition at line 5219 of file ParallelComm.cpp.
References ErrorCode, moab::TupleList::get_n(), get_shared_proc_tags(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_MULTISHARED, PSTATUS_SHARED, sharedEnts, moab::Interface::tag_set_data(), moab::TupleList::vi_rd, and moab::TupleList::vul_rd.
Referenced by resolve_shared_ents(), moab::ScdInterface::tag_shared_vertices(), and moab::ParallelMergeMesh::TagSharedElements().
{ Tag shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag; ErrorCode result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags in tag_shared_verts" ); unsigned int j = 0, i = 0; std::vector< int > sharing_procs, sharing_procs2, tag_procs; std::vector< EntityHandle > sharing_handles, sharing_handles2, tag_lhandles, tag_rhandles; std::vector< unsigned char > pstatus; // Were on tuple j/2 if( i_extra ) i += i_extra; while( j < 2 * shared_ents.get_n() ) { // Count & accumulate sharing procs EntityHandle this_ent = shared_ents.vul_rd[j], other_ent = 0; int other_proc = -1; while( j < 2 * shared_ents.get_n() && shared_ents.vul_rd[j] == this_ent ) { j++; // Shouldn't have same proc assert( shared_ents.vi_rd[i] != (int)procConfig.proc_rank() ); // Grab the remote data if its not a dublicate if( shared_ents.vul_rd[j] != other_ent || shared_ents.vi_rd[i] != other_proc ) { assert( 0 != shared_ents.vul_rd[j] ); sharing_procs.push_back( shared_ents.vi_rd[i] ); sharing_handles.push_back( shared_ents.vul_rd[j] ); } other_proc = shared_ents.vi_rd[i]; other_ent = shared_ents.vul_rd[j]; j++; i += 1 + i_extra; } if( sharing_procs.size() > 1 ) { // Add current proc/handle to list sharing_procs.push_back( procConfig.proc_rank() ); sharing_handles.push_back( this_ent ); // Sort sharing_procs and sharing_handles such that // sharing_procs is in ascending order. Use temporary // lists and binary search to re-order sharing_handles. sharing_procs2 = sharing_procs; std::sort( sharing_procs2.begin(), sharing_procs2.end() ); sharing_handles2.resize( sharing_handles.size() ); for( size_t k = 0; k < sharing_handles.size(); k++ ) { size_t idx = std::lower_bound( sharing_procs2.begin(), sharing_procs2.end(), sharing_procs[k] ) - sharing_procs2.begin(); sharing_handles2[idx] = sharing_handles[k]; } sharing_procs.swap( sharing_procs2 ); sharing_handles.swap( sharing_handles2 ); } assert( sharing_procs.size() != 2 ); proc_nvecs[sharing_procs].push_back( this_ent ); unsigned char share_flag = PSTATUS_SHARED, ms_flag = ( PSTATUS_SHARED | PSTATUS_MULTISHARED ); if( sharing_procs.size() == 1 ) { tag_procs.push_back( sharing_procs[0] ); tag_lhandles.push_back( this_ent ); tag_rhandles.push_back( sharing_handles[0] ); pstatus.push_back( share_flag ); } else { // Pad lists // assert(sharing_procs.size() <= MAX_SHARING_PROCS); if( sharing_procs.size() > MAX_SHARING_PROCS ) { std::cerr << "MAX_SHARING_PROCS exceeded for vertex " << this_ent << " on process " << proc_config().proc_rank() << std::endl; std::cerr.flush(); MPI_Abort( proc_config().proc_comm(), 66 ); } sharing_procs.resize( MAX_SHARING_PROCS, -1 ); sharing_handles.resize( MAX_SHARING_PROCS, 0 ); result = mbImpl->tag_set_data( shps_tag, &this_ent, 1, &sharing_procs[0] );MB_CHK_SET_ERR( result, "Failed to set sharedps tag on shared vertex" ); result = mbImpl->tag_set_data( shhs_tag, &this_ent, 1, &sharing_handles[0] );MB_CHK_SET_ERR( result, "Failed to set sharedhs tag on shared vertex" ); result = mbImpl->tag_set_data( pstat_tag, &this_ent, 1, &ms_flag );MB_CHK_SET_ERR( result, "Failed to set pstatus tag on shared vertex" ); sharedEnts.insert( this_ent ); } // Reset sharing proc(s) tags sharing_procs.clear(); sharing_handles.clear(); } if( !tag_procs.empty() ) { result = mbImpl->tag_set_data( shp_tag, &tag_lhandles[0], tag_procs.size(), &tag_procs[0] );MB_CHK_SET_ERR( result, "Failed to set sharedp tag on shared vertex" ); result = mbImpl->tag_set_data( shh_tag, &tag_lhandles[0], tag_procs.size(), &tag_rhandles[0] );MB_CHK_SET_ERR( result, "Failed to set sharedh tag on shared vertex" ); result = mbImpl->tag_set_data( pstat_tag, &tag_lhandles[0], tag_procs.size(), &pstatus[0] );MB_CHK_SET_ERR( result, "Failed to set pstatus tag on shared vertex" ); for( std::vector< EntityHandle >::iterator vvt = tag_lhandles.begin(); vvt != tag_lhandles.end(); vvt++ ) sharedEnts.insert( *vvt ); } #ifndef NDEBUG // Shouldn't be any repeated entities in any of the vectors in proc_nvecs for( std::map< std::vector< int >, std::vector< EntityHandle > >::iterator mit = proc_nvecs.begin(); mit != proc_nvecs.end(); ++mit ) { std::vector< EntityHandle > tmp_vec = ( mit->second ); std::sort( tmp_vec.begin(), tmp_vec.end() ); std::vector< EntityHandle >::iterator vit = std::unique( tmp_vec.begin(), tmp_vec.end() ); assert( vit == tmp_vec.end() ); } #endif return MB_SUCCESS; }
ErrorCode moab::ParallelComm::tag_shared_verts | ( | TupleList & | shared_verts, |
Range * | skin_ents, | ||
Range & | proc_verts | ||
) | [private] |
Definition at line 5338 of file ParallelComm.cpp.
References moab::Range::end(), ErrorCode, moab::TupleList::get_n(), get_shared_proc_tags(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_MULTISHARED, PSTATUS_SHARED, sharedEnts, size(), moab::Interface::tag_set_data(), moab::TupleList::vi_rd, and moab::TupleList::vul_rd.
{ Tag shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag; ErrorCode result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags in tag_shared_verts" ); unsigned int j = 0, i = 0; std::vector< int > sharing_procs, sharing_procs2; std::vector< EntityHandle > sharing_handles, sharing_handles2, skin_verts( skin_ents[0].size() ); for( Range::iterator rit = skin_ents[0].begin(); rit != skin_ents[0].end(); ++rit, i++ ) skin_verts[i] = *rit; i = 0; while( j < 2 * shared_ents.get_n() ) { // Count & accumulate sharing procs int this_idx = shared_ents.vi_rd[j]; EntityHandle this_ent = skin_verts[this_idx]; while( j < 2 * shared_ents.get_n() && shared_ents.vi_rd[j] == this_idx ) { j++; // Shouldn't have same proc assert( shared_ents.vi_rd[j] != (int)procConfig.proc_rank() ); sharing_procs.push_back( shared_ents.vi_rd[j++] ); sharing_handles.push_back( shared_ents.vul_rd[i++] ); } if( sharing_procs.size() > 1 ) { // Add current proc/handle to list sharing_procs.push_back( procConfig.proc_rank() ); sharing_handles.push_back( this_ent ); } // Sort sharing_procs and sharing_handles such that // sharing_procs is in ascending order. Use temporary // lists and binary search to re-order sharing_handles. sharing_procs2 = sharing_procs; std::sort( sharing_procs2.begin(), sharing_procs2.end() ); sharing_handles2.resize( sharing_handles.size() ); for( size_t k = 0; k < sharing_handles.size(); k++ ) { size_t idx = std::lower_bound( sharing_procs2.begin(), sharing_procs2.end(), sharing_procs[k] ) - sharing_procs2.begin(); sharing_handles2[idx] = sharing_handles[k]; } sharing_procs.swap( sharing_procs2 ); sharing_handles.swap( sharing_handles2 ); assert( sharing_procs.size() != 2 ); proc_nvecs[sharing_procs].push_back( this_ent ); unsigned char share_flag = PSTATUS_SHARED, ms_flag = ( PSTATUS_SHARED | PSTATUS_MULTISHARED ); if( sharing_procs.size() == 1 ) { result = mbImpl->tag_set_data( shp_tag, &this_ent, 1, &sharing_procs[0] );MB_CHK_SET_ERR( result, "Failed to set sharedp tag on shared vertex" ); result = mbImpl->tag_set_data( shh_tag, &this_ent, 1, &sharing_handles[0] );MB_CHK_SET_ERR( result, "Failed to set sharedh tag on shared vertex" ); result = mbImpl->tag_set_data( pstat_tag, &this_ent, 1, &share_flag );MB_CHK_SET_ERR( result, "Failed to set pstatus tag on shared vertex" ); sharedEnts.insert( this_ent ); } else { // Pad lists // assert(sharing_procs.size() <= MAX_SHARING_PROCS); if( sharing_procs.size() > MAX_SHARING_PROCS ) { std::cerr << "MAX_SHARING_PROCS exceeded for vertex " << this_ent << " on process " << proc_config().proc_rank() << std::endl; std::cerr.flush(); MPI_Abort( proc_config().proc_comm(), 66 ); } sharing_procs.resize( MAX_SHARING_PROCS, -1 ); sharing_handles.resize( MAX_SHARING_PROCS, 0 ); result = mbImpl->tag_set_data( shps_tag, &this_ent, 1, &sharing_procs[0] );MB_CHK_SET_ERR( result, "Failed to set sharedps tag on shared vertex" ); result = mbImpl->tag_set_data( shhs_tag, &this_ent, 1, &sharing_handles[0] );MB_CHK_SET_ERR( result, "Failed to set sharedhs tag on shared vertex" ); result = mbImpl->tag_set_data( pstat_tag, &this_ent, 1, &ms_flag );MB_CHK_SET_ERR( result, "Failed to set pstatus tag on shared vertex" ); sharedEnts.insert( this_ent ); } // Reset sharing proc(s) tags sharing_procs.clear(); sharing_handles.clear(); } #ifndef NDEBUG // Shouldn't be any repeated entities in any of the vectors in proc_nvecs for( std::map< std::vector< int >, std::vector< EntityHandle > >::iterator mit = proc_nvecs.begin(); mit != proc_nvecs.end(); ++mit ) { std::vector< EntityHandle > tmp_vec = ( mit->second ); std::sort( tmp_vec.begin(), tmp_vec.end() ); std::vector< EntityHandle >::iterator vit = std::unique( tmp_vec.begin(), tmp_vec.end() ); assert( vit == tmp_vec.end() ); } #endif return MB_SUCCESS; }
ErrorCode moab::ParallelComm::unpack_adjacencies | ( | unsigned char *& | buff_ptr, |
Range & | entities, | ||
const bool | store_handles, | ||
const int | from_proc | ||
) | [private] |
Definition at line 3462 of file ParallelComm.cpp.
return MB_FAILURE;
ErrorCode moab::ParallelComm::unpack_buffer | ( | unsigned char * | buff_ptr, |
const bool | store_remote_handles, | ||
const int | from_proc, | ||
const int | ind, | ||
std::vector< std::vector< EntityHandle > > & | L1hloc, | ||
std::vector< std::vector< EntityHandle > > & | L1hrem, | ||
std::vector< std::vector< int > > & | L1p, | ||
std::vector< EntityHandle > & | L2hloc, | ||
std::vector< EntityHandle > & | L2hrem, | ||
std::vector< unsigned int > & | L2p, | ||
std::vector< EntityHandle > & | new_ents, | ||
const bool | created_iface = false |
Definition at line 1463 of file ParallelComm.cpp.
References ErrorCode, moab::DebugOutput::get_verbosity(), MB_CHK_SET_ERR, MB_SUCCESS, myDebug, moab::DebugOutput::print(), moab::DebugOutput::tprintf(), unpack_entities(), unpack_sets(), and unpack_tags().
Referenced by broadcast_entities(), exchange_owned_mesh(), moab::ParCommGraph::receive_mesh(), recv_entities(), recv_messages(), and scatter_entities().
{ unsigned char* tmp_buff = buff_ptr; ErrorCode result; result = unpack_entities( buff_ptr, store_remote_handles, ind, false, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents, created_iface );MB_CHK_SET_ERR( result, "Unpacking entities failed" ); if( myDebug->get_verbosity() == 3 ) { myDebug->tprintf( 4, "unpack_entities buffer space: %ld bytes.\n", (long int)( buff_ptr - tmp_buff ) ); tmp_buff = buff_ptr; } result = unpack_sets( buff_ptr, new_ents, store_remote_handles, from_proc );MB_CHK_SET_ERR( result, "Unpacking sets failed" ); if( myDebug->get_verbosity() == 3 ) { myDebug->tprintf( 4, "unpack_sets buffer space: %ld bytes.\n", (long int)( buff_ptr - tmp_buff ) ); tmp_buff = buff_ptr; } result = unpack_tags( buff_ptr, new_ents, store_remote_handles, from_proc );MB_CHK_SET_ERR( result, "Unpacking tags failed" ); if( myDebug->get_verbosity() == 3 ) { myDebug->tprintf( 4, "unpack_tags buffer space: %ld bytes.\n", (long int)( buff_ptr - tmp_buff ) ); // tmp_buff = buff_ptr; } if( myDebug->get_verbosity() == 3 ) myDebug->print( 4, "\n" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::unpack_entities | ( | unsigned char *& | buff_ptr, |
const int | from_ind, | ||
const bool | is_iface, | ||
unpack entities in buff_ptr
Definition at line 2068 of file ParallelComm.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), moab::CN::EntityTypeName(), ErrorCode, find_existing_entity(), get_buffers(), get_local_handles(), moab::CN::MAX_NODES_PER_ELEMENT, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, MBMAXTYPE, MBVERTEX, myDebug, moab::ProcConfig::proc_rank(), procConfig, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_NOT_OWNED, moab::Interface::query_interface(), rank(), moab::DebugOutput::tprintf(), moab::UNPACK_DBLS(), moab::UNPACK_EH(), moab::UNPACK_INT(), moab::UNPACK_INTS(), moab::UNPACK_TYPE(), moab::ReadUtilIface::update_adjacencies(), and update_remote_data().
Referenced by exchange_ghost_cells(), and unpack_buffer().
{ // General algorithm: // - unpack # entities // - save start of remote handle info, then scan forward to entity definition data // - for all vertices or entities w/ same # verts: // . get entity type, num ents, and (if !vert) # verts // . for each ent: // o get # procs/handles in remote handle info // o if # procs/handles > 2, check for already-created entity: // x get index of owner proc (1st in proc list), resize L1 list if nec // x look for already-arrived entity in L2 by owner handle // o if no existing entity: // x if iface, look for existing entity with same connect & type // x if none found, create vertex or element // x if !iface & multi-shared, save on L2 // x if !iface, put new entity on new_ents list // o update proc/handle, pstatus tags, adjusting to put owner first if iface // o if !iface, save new handle on L1 for all sharing procs // Lists of handles/procs to return to sending/other procs // L1hloc[p], L1hrem[p]: handle pairs [h, h'], where h is the local proc handle // and h' is either the remote proc handle (if that is known) or // the owner proc handle (otherwise); // L1p[p]: indicates whether h is remote handle (= -1) or owner (rank of owner) // L2hloc, L2hrem: local/remote handles for entities shared by > 2 procs; // remote handles are on owning proc // L2p: owning procs for handles in L2hrem ErrorCode result; bool done = false; ReadUtilIface* ru = NULL; result = mbImpl->query_interface( ru );MB_CHK_SET_ERR( result, "Failed to get ReadUtilIface" ); // 1. # entities = E int num_ents = 0; unsigned char* buff_save = buff_ptr; int i, j; if( store_remote_handles ) { UNPACK_INT( buff_ptr, num_ents ); buff_save = buff_ptr; // Save place where remote handle info starts, then scan forward to ents for( i = 0; i < num_ents; i++ ) { UNPACK_INT( buff_ptr, j ); if( j < 0 ) { std::cout << "Should be non-negative # proc/handles."; return MB_FAILURE; } buff_ptr += j * ( sizeof( int ) + sizeof( EntityHandle ) ); } } std::vector< EntityHandle > msg_ents; while( !done ) { EntityType this_type = MBMAXTYPE; UNPACK_TYPE( buff_ptr, this_type ); assert( this_type != MBENTITYSET ); // MBMAXTYPE signifies end of entities data if( MBMAXTYPE == this_type ) break; // Get the number of ents int num_ents2, verts_per_entity = 0; UNPACK_INT( buff_ptr, num_ents2 ); // Unpack the nodes per entity if( MBVERTEX != this_type && num_ents2 ) { UNPACK_INT( buff_ptr, verts_per_entity ); } std::vector< int > ps( MAX_SHARING_PROCS, -1 ); std::vector< EntityHandle > hs( MAX_SHARING_PROCS, 0 ); for( int e = 0; e < num_ents2; e++ ) { // Check for existing entity, otherwise make new one EntityHandle new_h = 0; EntityHandle connect[CN::MAX_NODES_PER_ELEMENT]; double coords[3]; int num_ps = -1; //======================================= // Unpack all the data at once, to make sure the buffer pointers // are tracked correctly //======================================= if( store_remote_handles ) { // Pointers to other procs/handles UNPACK_INT( buff_save, num_ps ); if( 0 >= num_ps ) { std::cout << "Shouldn't ever be fewer than 1 procs here." << std::endl; return MB_FAILURE; } UNPACK_INTS( buff_save, &ps[0], num_ps ); UNPACK_EH( buff_save, &hs[0], num_ps ); } if( MBVERTEX == this_type ) { UNPACK_DBLS( buff_ptr, coords, 3 ); } else { assert( verts_per_entity <= CN::MAX_NODES_PER_ELEMENT ); UNPACK_EH( buff_ptr, connect, verts_per_entity ); // Update connectivity to local handles result = get_local_handles( connect, verts_per_entity, msg_ents );MB_CHK_SET_ERR( result, "Failed to get local handles" ); } //======================================= // Now, process that data; begin by finding an identical // entity, if there is one //======================================= if( store_remote_handles ) { result = find_existing_entity( is_iface, ps[0], hs[0], num_ps, connect, verts_per_entity, this_type, L2hloc, L2hrem, L2p, new_h );MB_CHK_SET_ERR( result, "Failed to get existing entity" ); } //======================================= // If we didn't find one, we'll have to create one //======================================= bool created_here = false; if( !new_h && !is_iface ) { if( MBVERTEX == this_type ) { // Create a vertex result = mbImpl->create_vertex( coords, new_h );MB_CHK_SET_ERR( result, "Failed to make new vertex" ); } else { // Create the element result = mbImpl->create_element( this_type, connect, verts_per_entity, new_h );MB_CHK_SET_ERR( result, "Failed to make new element" ); // Update adjacencies result = ru->update_adjacencies( new_h, 1, verts_per_entity, connect );MB_CHK_SET_ERR( result, "Failed to update adjacencies" ); } // Should have a new handle now assert( new_h ); created_here = true; } //======================================= // Take care of sharing data //======================================= // Need to save entities found in order, for interpretation of // later parts of this message if( !is_iface ) { assert( new_h ); msg_ents.push_back( new_h ); } if( created_here ) new_ents.push_back( new_h ); if( new_h && store_remote_handles ) { unsigned char new_pstat = 0x0; if( is_iface ) { new_pstat = PSTATUS_INTERFACE; // Here, lowest rank proc should be first int idx = std::min_element( &ps[0], &ps[0] + num_ps ) - &ps[0]; if( idx ) { std::swap( ps[0], ps[idx] ); std::swap( hs[0], hs[idx] ); } // Set ownership based on lowest rank; can't be in update_remote_data, because // there we don't know whether it resulted from ghosting or not if( ( num_ps > 1 && ps[0] != (int)rank() ) ) new_pstat |= PSTATUS_NOT_OWNED; } else if( created_here ) { if( created_iface ) new_pstat = PSTATUS_NOT_OWNED; else new_pstat = PSTATUS_GHOST | PSTATUS_NOT_OWNED; } // Update sharing data and pstatus, adjusting order if iface result = update_remote_data( new_h, &ps[0], &hs[0], num_ps, new_pstat );MB_CHK_SET_ERR( result, "unpack_entities" ); // If a new multi-shared entity, save owner for subsequent lookup in L2 lists if( store_remote_handles && !is_iface && num_ps > 2 ) { L2hrem.push_back( hs[0] ); L2hloc.push_back( new_h ); L2p.push_back( ps[0] ); } // Need to send this new handle to all sharing procs if( !is_iface ) { for( j = 0; j < num_ps; j++ ) { if( ps[j] == (int)procConfig.proc_rank() ) continue; int idx = get_buffers( ps[j] ); if( idx == (int)L1hloc.size() ) { L1hloc.resize( idx + 1 ); L1hrem.resize( idx + 1 ); L1p.resize( idx + 1 ); } // Don't bother adding if it's already in the list std::vector< EntityHandle >::iterator vit = std::find( L1hloc[idx].begin(), L1hloc[idx].end(), new_h ); if( vit != L1hloc[idx].end() ) { // If it's in the list but remote handle isn't known but we know // it, replace in the list if( L1p[idx][vit - L1hloc[idx].begin()] != -1 && hs[j] ) { L1hrem[idx][vit - L1hloc[idx].begin()] = hs[j]; L1p[idx][vit - L1hloc[idx].begin()] = -1; } else continue; } else { if( !hs[j] ) { assert( -1 != ps[0] && num_ps > 2 ); L1p[idx].push_back( ps[0] ); L1hrem[idx].push_back( hs[0] ); } else { assert( "either this remote handle isn't in the remote list, or " "it's for another proc" && ( std::find( L1hrem[idx].begin(), L1hrem[idx].end(), hs[j] ) == L1hrem[idx].end() || L1p[idx][std::find( L1hrem[idx].begin(), L1hrem[idx].end(), hs[j] ) - L1hrem[idx].begin()] != -1 ) ); L1p[idx].push_back( -1 ); L1hrem[idx].push_back( hs[j] ); } L1hloc[idx].push_back( new_h ); } } } assert( "Shouldn't be here for non-shared entities" && -1 != num_ps ); std::fill( &ps[0], &ps[num_ps], -1 ); std::fill( &hs[0], &hs[num_ps], 0 ); } } myDebug->tprintf( 4, "Unpacked %d ents of type %s", num_ents2, CN::EntityTypeName( this_type ) ); } myDebug->tprintf( 4, "Done unpacking entities.\n" ); // Need to sort here, to enable searching std::sort( new_ents.begin(), new_ents.end() ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::unpack_iface_entities | ( | unsigned char *& | buff_ptr, |
std::vector< EntityHandle > & | recd_ents | ||
) | [private] |
for all the entities in the received buffer; for each, save entities in this instance which match connectivity, or zero if none found
ErrorCode moab::ParallelComm::unpack_remote_handles | ( | unsigned int | from_proc, |
unsigned char *& | buff_ptr, | ||
std::vector< unsigned int > & | L2p | ||
Definition at line 7395 of file ParallelComm.cpp.
References ErrorCode, find_existing_entity(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::Interface::type_from_handle(), moab::UNPACK_EH(), moab::UNPACK_INT(), and update_remote_data().
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), recv_entities(), recv_remote_handle_messages(), and unpack_remote_handles().
{ // Incoming remote handles; use to set remote handles int num_eh; UNPACK_INT( buff_ptr, num_eh ); unsigned char* buff_proc = buff_ptr; buff_ptr += num_eh * sizeof( int ); unsigned char* buff_rem = buff_ptr + num_eh * sizeof( EntityHandle ); ErrorCode result; EntityHandle hpair[2], new_h; int proc; for( int i = 0; i < num_eh; i++ ) { UNPACK_INT( buff_proc, proc ); // Handles packed (local, remote), though here local is either on this // proc or owner proc, depending on value of proc (-1 = here, otherwise owner); // this is decoded in find_existing_entity UNPACK_EH( buff_ptr, hpair, 1 ); UNPACK_EH( buff_rem, hpair + 1, 1 ); if( -1 != proc ) { result = find_existing_entity( false, proc, hpair[0], 3, NULL, 0, mbImpl->type_from_handle( hpair[1] ), L2hloc, L2hrem, L2p, new_h );MB_CHK_SET_ERR( result, "Didn't get existing entity" ); if( new_h ) hpair[0] = new_h; else hpair[0] = 0; } if( !( hpair[0] && hpair[1] ) ) return MB_FAILURE; int this_proc = from_proc; result = update_remote_data( hpair[0], &this_proc, hpair + 1, 1, 0 );MB_CHK_SET_ERR( result, "Failed to set remote data range on sent entities in ghost exchange" ); } return MB_SUCCESS; }
const unsigned char * | buff_ptr, | ||
) | [inline, private] |
Definition at line 1651 of file ParallelComm.hpp.
References unpack_remote_handles().
{ // cast away const-ness, we won't be passing back a modified ptr unsigned char* tmp_buff = const_cast< unsigned char* >( buff_ptr ); return unpack_remote_handles( from_proc, tmp_buff, L2hloc, L2hrem, L2p ); }
ErrorCode moab::ParallelComm::unpack_sets | ( | unsigned char *& | buff_ptr, |
std::vector< EntityHandle > & | entities, | ||
const int | to_proc | ||
) | [private] |
Definition at line 3310 of file ParallelComm.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_entities(), moab::Interface::add_parent_meshset(), moab::Range::begin(), moab::Interface::create_meshset(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), get_local_handles(), moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, myDebug, moab::Range::rbegin(), moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), moab::Interface::type_from_handle(), moab::UNPACK_EH(), moab::UNPACK_INT(), moab::UNPACK_INTS(), moab::UNPACK_RANGE(), moab::UNPACK_VOID(), and update_remote_data().
Referenced by unpack_buffer().
{ // Now the sets; assume any sets the application wants to pass are in the entities list ErrorCode result; bool no_sets = ( entities.empty() || ( mbImpl->type_from_handle( *entities.rbegin() ) == MBENTITYSET ) ); Range new_sets; int num_sets; UNPACK_INT( buff_ptr, num_sets ); if( !num_sets ) return MB_SUCCESS; int i; Range::const_iterator rit; std::vector< EntityHandle > members; int num_ents; std::vector< unsigned int > options_vec( num_sets ); // Option value if( num_sets ) UNPACK_VOID( buff_ptr, &options_vec[0], num_sets * sizeof( unsigned int ) ); // Unpack parallel geometry unique id int n_uid; UNPACK_INT( buff_ptr, n_uid ); if( n_uid > 0 && n_uid != num_sets ) { std::cerr << "The number of Parallel geometry unique ids should be same." << std::endl; } if( n_uid > 0 ) { // If parallel geometry unique id is packed std::vector< int > uids( n_uid ); UNPACK_INTS( buff_ptr, &uids[0], n_uid ); Tag uid_tag; result = mbImpl->tag_get_handle( "PARALLEL_UNIQUE_ID", 1, MB_TYPE_INTEGER, uid_tag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( result, "Failed to create parallel geometry unique id tag" ); // Find existing sets for( i = 0; i < n_uid; i++ ) { EntityHandle set_handle; Range temp_sets; void* tag_vals[] = { &uids[i] }; if( uids[i] > 0 ) { result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &uid_tag, tag_vals, 1, temp_sets ); } if( !temp_sets.empty() ) { // Existing set set_handle = *temp_sets.begin(); } else { // Create a new set result = mbImpl->create_meshset( options_vec[i], set_handle );MB_CHK_SET_ERR( result, "Failed to create set in unpack" ); result = mbImpl->tag_set_data( uid_tag, &set_handle, 1, &uids[i] );MB_CHK_SET_ERR( result, "Failed to set parallel geometry unique ids" ); } new_sets.insert( set_handle ); } } else { // Create sets for( i = 0; i < num_sets; i++ ) { EntityHandle set_handle; result = mbImpl->create_meshset( options_vec[i], set_handle );MB_CHK_SET_ERR( result, "Failed to create set in unpack" ); // Make sure new sets handles are monotonically increasing assert( set_handle > *new_sets.rbegin() ); new_sets.insert( set_handle ); } } std::copy( new_sets.begin(), new_sets.end(), std::back_inserter( entities ) ); // Only need to sort if we came in with no sets on the end if( !no_sets ) std::sort( entities.begin(), entities.end() ); for( rit = new_sets.begin(), i = 0; rit != new_sets.end(); ++rit, i++ ) { // Unpack entities as vector, with length UNPACK_INT( buff_ptr, num_ents ); members.resize( num_ents ); if( num_ents ) UNPACK_EH( buff_ptr, &members[0], num_ents ); result = get_local_handles( &members[0], num_ents, entities );MB_CHK_SET_ERR( result, "Failed to get local handles for ordered set contents" ); result = mbImpl->add_entities( *rit, &members[0], num_ents );MB_CHK_SET_ERR( result, "Failed to add ents to ordered set in unpack" ); } std::vector< int > num_pch( 2 * new_sets.size() ); std::vector< int >::iterator vit; int tot_pch = 0; for( vit = num_pch.begin(); vit != num_pch.end(); ++vit ) { UNPACK_INT( buff_ptr, *vit ); tot_pch += *vit; } members.resize( tot_pch ); UNPACK_EH( buff_ptr, &members[0], tot_pch ); result = get_local_handles( &members[0], tot_pch, entities );MB_CHK_SET_ERR( result, "Failed to get local handle for parent/child sets" ); int num = 0; EntityHandle* mem_ptr = &members[0]; for( rit = new_sets.begin(); rit != new_sets.end(); ++rit ) { // Unpack parents/children int num_par = num_pch[num++], num_child = num_pch[num++]; if( num_par + num_child ) { for( i = 0; i < num_par; i++ ) { assert( 0 != mem_ptr[i] ); result = mbImpl->add_parent_meshset( *rit, mem_ptr[i] );MB_CHK_SET_ERR( result, "Failed to add parent to set in unpack" ); } mem_ptr += num_par; for( i = 0; i < num_child; i++ ) { assert( 0 != mem_ptr[i] ); result = mbImpl->add_child_meshset( *rit, mem_ptr[i] );MB_CHK_SET_ERR( result, "Failed to add child to set in unpack" ); } mem_ptr += num_child; } } // Unpack source handles Range dum_range; if( store_remote_handles && !new_sets.empty() ) { UNPACK_RANGE( buff_ptr, dum_range ); result = update_remote_data( new_sets, dum_range, from_proc, 0 );MB_CHK_SET_ERR( result, "Failed to set sharing data for sets" ); } myDebug->tprintf( 4, "Done unpacking sets." ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::unpack_tags | ( | unsigned char *& | buff_ptr, |
const int | to_proc, | ||
const MPI_Op *const | mpi_op = NULL |
) | [private] |
Definition at line 3679 of file ParallelComm.cpp.
References ErrorCode, get_local_handles(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_BYTES, MB_TAG_CREAT, MB_TAG_VARLEN, MB_TYPE_HANDLE, MB_VARIABLE_LENGTH, mbImpl, myDebug, reduce_void(), moab::TagInfo::size_from_data_type(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_set_by_ptr(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), moab::UNPACK_EH(), moab::UNPACK_INT(), moab::UNPACK_INTS(), and UPC.
Referenced by exchange_tags(), reduce_tags(), and unpack_buffer().
{ // Tags // Get all the tags // For dense tags, compute size assuming all entities have that tag // For sparse tags, get number of entities w/ that tag to compute size ErrorCode result; int num_tags; UNPACK_INT( buff_ptr, num_tags ); std::vector< const void* > var_len_vals; std::vector< unsigned char > dum_vals; std::vector< EntityHandle > dum_ehvals; for( int i = 0; i < num_tags; i++ ) { // Tag handle Tag tag_handle; // Size, data type int tag_size, tag_data_type, tag_type; UNPACK_INT( buff_ptr, tag_size ); UNPACK_INT( buff_ptr, tag_type ); UNPACK_INT( buff_ptr, tag_data_type ); // Default value int def_val_size; UNPACK_INT( buff_ptr, def_val_size ); void* def_val_ptr = NULL; if( def_val_size ) { def_val_ptr = buff_ptr; buff_ptr += def_val_size; UPC( tag_size, " void" ); } // Name int name_len; UNPACK_INT( buff_ptr, name_len ); std::string tag_name( reinterpret_cast< char* >( buff_ptr ), name_len ); buff_ptr += name_len; UPC( 64, " chars" ); myDebug->tprintf( 4, "Unpacking tag %s\n", tag_name.c_str() ); // Create the tag if( tag_size == MB_VARIABLE_LENGTH ) result = mbImpl->tag_get_handle( tag_name.c_str(), def_val_size, (DataType)tag_data_type, tag_handle, MB_TAG_VARLEN | MB_TAG_CREAT | MB_TAG_BYTES | tag_type, def_val_ptr ); else result = mbImpl->tag_get_handle( tag_name.c_str(), tag_size, (DataType)tag_data_type, tag_handle, MB_TAG_CREAT | MB_TAG_BYTES | tag_type, def_val_ptr ); if( MB_SUCCESS != result ) return result; // Get handles and convert to local handles int num_ents; UNPACK_INT( buff_ptr, num_ents ); std::vector< EntityHandle > dum_ents( num_ents ); UNPACK_EH( buff_ptr, &dum_ents[0], num_ents ); // In this case handles are indices into new entity range; need to convert // to local handles result = get_local_handles( &dum_ents[0], num_ents, entities );MB_CHK_SET_ERR( result, "Unable to convert to local handles" ); // If it's a handle type, also convert tag vals in-place in buffer if( MB_TYPE_HANDLE == tag_type ) { dum_ehvals.resize( num_ents ); UNPACK_EH( buff_ptr, &dum_ehvals[0], num_ents ); result = get_local_handles( &dum_ehvals[0], num_ents, entities );MB_CHK_SET_ERR( result, "Failed to get local handles for tag vals" ); } DataType data_type; mbImpl->tag_get_data_type( tag_handle, data_type ); int type_size = TagInfo::size_from_data_type( data_type ); if( !dum_ents.empty() ) { if( tag_size == MB_VARIABLE_LENGTH ) { // Be careful of alignment here. If the integers are aligned // in the buffer, we can use them directly. Otherwise we must // copy them. std::vector< int > var_lengths( num_ents ); UNPACK_INTS( buff_ptr, &var_lengths[0], num_ents ); UPC( sizeof( int ) * num_ents, " void" ); // Get pointers into buffer for each tag value var_len_vals.resize( num_ents ); for( std::vector< EntityHandle >::size_type j = 0; j < (std::vector< EntityHandle >::size_type)num_ents; j++ ) { var_len_vals[j] = buff_ptr; buff_ptr += var_lengths[j] * type_size; UPC( var_lengths[j], " void" ); } result = mbImpl->tag_set_by_ptr( tag_handle, &dum_ents[0], num_ents, &var_len_vals[0], &var_lengths[0] );MB_CHK_SET_ERR( result, "Failed to set tag data when unpacking variable-length tag" ); } else { // Get existing values of dst tag dum_vals.resize( tag_size * num_ents ); if( mpi_op ) { int tag_length; result = mbImpl->tag_get_length( tag_handle, tag_length );MB_CHK_SET_ERR( result, "Failed to get tag length" ); result = mbImpl->tag_get_data( tag_handle, &dum_ents[0], num_ents, &dum_vals[0] );MB_CHK_SET_ERR( result, "Failed to get existing value of dst tag on entities" ); result = reduce_void( tag_data_type, *mpi_op, tag_length * num_ents, &dum_vals[0], buff_ptr );MB_CHK_SET_ERR( result, "Failed to perform mpi op on dst tags" ); } result = mbImpl->tag_set_data( tag_handle, &dum_ents[0], num_ents, buff_ptr );MB_CHK_SET_ERR( result, "Failed to set range-based tag data when unpacking tag" ); buff_ptr += num_ents * tag_size; UPC( num_ents * tag_size, " void" ); } } } myDebug->tprintf( 4, "Done unpacking tags.\n" ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::update_iface_sets | ( | Range & | sent_ents, |
std::vector< EntityHandle > & | remote_handles, | ||
) | [private] |
for any remote_handles set to zero, remove corresponding sent_ents from iface_sets corresponding to from_proc
ErrorCode moab::ParallelComm::update_remote_data | ( | EntityHandle | entity, |
std::vector< int > & | procs, | ||
std::vector< EntityHandle > & | handles | ||
Definition at line 1019 of file ParallelComm.cpp.
References moab::error(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, PSTATUS_INTERFACE, PSTATUS_NOT_OWNED, and rank().
Referenced by resolve_shared_ents(), unpack_entities(), unpack_remote_handles(), unpack_sets(), and update_remote_data().
{ ErrorCode error; unsigned char pstatus = PSTATUS_INTERFACE; int procmin = *std::min_element( procs.begin(), procs.end() ); if( (int)rank() > procmin ) pstatus |= PSTATUS_NOT_OWNED; else procmin = rank(); // DBG // std::cout<<"entity = "<<entity<<std::endl; // for (int j=0; j<procs.size(); j++) // std::cout<<"procs["<<j<<"] = "<<procs[j]<<", handles["<<j<<"] = "<<handles[j]<<std::endl; // DBG if( (int)procs.size() > 1 ) { procs.push_back( rank() ); handles.push_back( entity ); int idx = std::find( procs.begin(), procs.end(), procmin ) - procs.begin(); std::iter_swap( procs.begin(), procs.begin() + idx ); std::iter_swap( handles.begin(), handles.begin() + idx ); // DBG // std::cout<<"entity = "<<entity<<std::endl; // for (int j=0; j<procs.size(); j++) // std::cout<<"procs["<<j<<"] = "<<procs[j]<<", handles["<<j<<"] = "<<handles[j]<<std::endl; // DBG } // if ((entity == 10388) && (rank()==1)) // std::cout<<"Here"<<std::endl; error = update_remote_data( entity, &procs[0], &handles[0], procs.size(), pstatus );MB_CHK_ERR( error ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::update_remote_data | ( | Range & | local_range, |
Range & | remote_range, | ||
int | other_proc, | ||
const unsigned char | add_pstat | ||
) | [private] |
Definition at line 2629 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, and update_remote_data().
{ Range::iterator rit, rit2; ErrorCode result = MB_SUCCESS; // For each pair of local/remote handles: for( rit = local_range.begin(), rit2 = remote_range.begin(); rit != local_range.end(); ++rit, ++rit2 ) { result = update_remote_data( *rit, &other_proc, &( *rit2 ), 1, add_pstat );MB_CHK_ERR( result ); } return MB_SUCCESS; }
ErrorCode moab::ParallelComm::update_remote_data | ( | const EntityHandle | new_h, |
const int * | ps, | ||
const EntityHandle * | hs, | ||
const int | num_ps, | ||
) | [private] |
Definition at line 2646 of file ParallelComm.cpp.
References moab::CN::EntityTypeName(), ErrorCode, get_sharing_data(), moab::ID_FROM_HANDLE(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, rank(), set_sharing_data(), sharedEnts, and moab::TYPE_FROM_HANDLE().
{ // Get initial sharing data; tag_ps and tag_hs get terminated with -1 and 0 // in this function, so no need to initialize; sharing data does not include // this proc if shared with only one other // Following variables declared here to avoid compiler errors int new_numps; unsigned char new_pstat; std::vector< int > new_ps( MAX_SHARING_PROCS, -1 ); std::vector< EntityHandle > new_hs( MAX_SHARING_PROCS, 0 ); new_numps = 0; ErrorCode result = get_sharing_data( new_h, &new_ps[0], &new_hs[0], new_pstat, new_numps );MB_CHK_SET_ERR( result, "Failed to get sharing data in update_remote_data" ); int num_exist = new_numps; // Add new pstat info to the flag new_pstat |= add_pstat; /* #define plist(str, lst, siz) \ std::cout << str << "("; \ for (int i = 0; i < (int)siz; i++) std::cout << lst[i] << " "; \ std::cout << ") "; \ std::cout << "update_remote_data: rank = " << rank() << ", new_h = " << new_h << std::endl; std::string ostr; plist("ps", ps, num_ps); plist("hs", hs, num_ps); print_pstatus(add_pstat, ostr); std::cout << ", add_pstat = " << ostr.c_str() << std::endl; plist("tag_ps", new_ps, new_numps); plist("tag_hs", new_hs, new_numps); assert(new_numps <= size()); print_pstatus(new_pstat, ostr); std::cout << ", tag_pstat=" << ostr.c_str() << std::endl; */ #ifndef NDEBUG { // Check for duplicates in proc list std::set< unsigned int > dumprocs; unsigned int dp = 0; for( ; (int)dp < num_ps && -1 != ps[dp]; dp++ ) dumprocs.insert( ps[dp] ); assert( dp == dumprocs.size() ); } #endif // If only one sharer and I'm the owner, insert myself in the list; // otherwise, my data is checked at the end if( 1 == new_numps && !( new_pstat & PSTATUS_NOT_OWNED ) ) { new_hs[1] = new_hs[0]; new_ps[1] = new_ps[0]; new_hs[0] = new_h; new_ps[0] = rank(); new_numps = 2; } // Now put passed-in data onto lists int idx; for( int i = 0; i < num_ps; i++ ) { idx = std::find( &new_ps[0], &new_ps[0] + new_numps, ps[i] ) - &new_ps[0]; if( idx < new_numps ) { if( !new_hs[idx] && hs[i] ) // h on list is 0 and passed-in h is non-zero, replace it new_hs[idx] = hs[i]; else assert( !hs[i] || new_hs[idx] == hs[i] ); } else { if( new_numps + 1 == MAX_SHARING_PROCS ) { MB_SET_ERR( MB_FAILURE, "Exceeded MAX_SHARING_PROCS for " << CN::EntityTypeName( TYPE_FROM_HANDLE( new_h ) ) << ' ' << ID_FROM_HANDLE( new_h ) << " in process " << rank() ); } new_ps[new_numps] = ps[i]; new_hs[new_numps] = hs[i]; new_numps++; } } // Add myself, if it isn't there already idx = std::find( &new_ps[0], &new_ps[0] + new_numps, rank() ) - &new_ps[0]; if( idx == new_numps ) { new_ps[new_numps] = rank(); new_hs[new_numps] = new_h; new_numps++; } else if( !new_hs[idx] && new_numps > 2 ) new_hs[idx] = new_h; // Proc list is complete; update for shared, multishared if( new_numps > 1 ) { if( new_numps > 2 ) new_pstat |= PSTATUS_MULTISHARED; new_pstat |= PSTATUS_SHARED; } /* plist("new_ps", new_ps, new_numps); plist("new_hs", new_hs, new_numps); print_pstatus(new_pstat, ostr); std::cout << ", new_pstat=" << ostr.c_str() << std::endl; std::cout << std::endl; */ result = set_sharing_data( new_h, new_pstat, num_exist, new_numps, &new_ps[0], &new_hs[0] );MB_CHK_SET_ERR( result, "Failed to set sharing data in update_remote_data" ); if( new_pstat & PSTATUS_SHARED ) sharedEnts.insert( new_h ); return MB_SUCCESS; }
ErrorCode moab::ParallelComm::update_remote_data_old | ( | const EntityHandle | new_h, |
) | [private] |
Definition at line 2777 of file ParallelComm.cpp.
References moab::CN::EntityTypeName(), ErrorCode, get_sharing_data(), moab::ID_FROM_HANDLE(), MAX_SHARING_PROCS, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, pstatus_tag(), sharedEnts, sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), moab::Interface::tag_set_data(), and moab::TYPE_FROM_HANDLE().
{ EntityHandle tag_hs[MAX_SHARING_PROCS]; int tag_ps[MAX_SHARING_PROCS]; unsigned char pstat; // Get initial sharing data; tag_ps and tag_hs get terminated with -1 and 0 // in this function, so no need to initialize unsigned int num_exist; ErrorCode result = get_sharing_data( new_h, tag_ps, tag_hs, pstat, num_exist );MB_CHK_ERR( result ); #ifndef NDEBUG { // Check for duplicates in proc list std::set< unsigned int > dumprocs; unsigned int dp = 0; for( ; (int)dp < num_ps && -1 != ps[dp]; dp++ ) dumprocs.insert( ps[dp] ); assert( dp == dumprocs.size() ); } #endif // Add any new sharing data bool changed = false; int idx; if( !num_exist ) { // Just take what caller passed memcpy( tag_ps, ps, num_ps * sizeof( int ) ); memcpy( tag_hs, hs, num_ps * sizeof( EntityHandle ) ); num_exist = num_ps; // If it's only one, hopefully I'm not there yet... assert( "I shouldn't be the only proc there." && ( 1 != num_exist || ps[0] != (int)procConfig.proc_rank() ) ); changed = true; } else { for( int i = 0; i < num_ps; i++ ) { idx = std::find( tag_ps, tag_ps + num_exist, ps[i] ) - tag_ps; if( idx == (int)num_exist ) { if( num_exist == MAX_SHARING_PROCS ) { std::cerr << "Exceeded MAX_SHARING_PROCS for " << CN::EntityTypeName( TYPE_FROM_HANDLE( new_h ) ) << ' ' << ID_FROM_HANDLE( new_h ) << " in process " << proc_config().proc_rank() << std::endl; std::cerr.flush(); MPI_Abort( proc_config().proc_comm(), 66 ); } // If there's only 1 sharing proc, and it's not me, then // we'll end up with 3; add me to the front if( !i && num_ps == 1 && num_exist == 1 && ps[0] != (int)procConfig.proc_rank() ) { int j = 1; // If I own this entity, put me at front, otherwise after first if( !( pstat & PSTATUS_NOT_OWNED ) ) { tag_ps[1] = tag_ps[0]; tag_hs[1] = tag_hs[0]; j = 0; } tag_ps[j] = procConfig.proc_rank(); tag_hs[j] = new_h; num_exist++; } tag_ps[num_exist] = ps[i]; tag_hs[num_exist] = hs[i]; num_exist++; changed = true; } else if( 0 == tag_hs[idx] ) { tag_hs[idx] = hs[i]; changed = true; } else if( 0 != hs[i] ) { assert( hs[i] == tag_hs[idx] ); } } } // Adjust for interface layer if necessary if( add_pstat & PSTATUS_INTERFACE ) { idx = std::min_element( tag_ps, tag_ps + num_exist ) - tag_ps; if( idx ) { int tag_proc = tag_ps[idx]; tag_ps[idx] = tag_ps[0]; tag_ps[0] = tag_proc; EntityHandle tag_h = tag_hs[idx]; tag_hs[idx] = tag_hs[0]; tag_hs[0] = tag_h; changed = true; if( tag_ps[0] != (int)procConfig.proc_rank() ) pstat |= PSTATUS_NOT_OWNED; } } if( !changed ) return MB_SUCCESS; assert( "interface entities should have > 1 proc" && ( !( add_pstat & PSTATUS_INTERFACE ) || num_exist > 1 ) ); assert( "ghost entities should have > 1 proc" && ( !( add_pstat & PSTATUS_GHOST ) || num_exist > 1 ) ); // If it's multi-shared and we created the entity in this unpack, // local handle probably isn't in handle list yet if( num_exist > 2 ) { idx = std::find( tag_ps, tag_ps + num_exist, procConfig.proc_rank() ) - tag_ps; assert( idx < (int)num_exist ); if( !tag_hs[idx] ) tag_hs[idx] = new_h; } int tag_p; EntityHandle tag_h; // Update pstat pstat |= add_pstat; if( num_exist > 2 ) pstat |= ( PSTATUS_MULTISHARED | PSTATUS_SHARED ); else if( num_exist > 0 ) pstat |= PSTATUS_SHARED; // compare_remote_data(new_h, num_ps, hs, ps, add_pstat, // num_exist, tag_hs, tag_ps, pstat); // Reset single shared proc/handle if was shared and moving to multi-shared if( num_exist > 2 && !( pstat & PSTATUS_MULTISHARED ) && ( pstat & PSTATUS_SHARED ) ) { // Must remove sharedp/h first, which really means set to default value tag_p = -1; result = mbImpl->tag_set_data( sharedp_tag(), &new_h, 1, &tag_p );MB_CHK_SET_ERR( result, "Failed to set sharedp tag data" ); tag_h = 0; result = mbImpl->tag_set_data( sharedh_tag(), &new_h, 1, &tag_h );MB_CHK_SET_ERR( result, "Failed to set sharedh tag data" ); } // Set sharing tags if( num_exist > 2 ) { std::fill( tag_ps + num_exist, tag_ps + MAX_SHARING_PROCS, -1 ); std::fill( tag_hs + num_exist, tag_hs + MAX_SHARING_PROCS, 0 ); result = mbImpl->tag_set_data( sharedps_tag(), &new_h, 1, tag_ps );MB_CHK_SET_ERR( result, "Failed to set sharedps tag data" ); result = mbImpl->tag_set_data( sharedhs_tag(), &new_h, 1, tag_hs );MB_CHK_SET_ERR( result, "Failed to set sharedhs tag data" ); #ifndef NDEBUG { // Check for duplicates in proc list std::set< unsigned int > dumprocs; unsigned int dp = 0; for( ; dp < num_exist && -1 != tag_ps[dp]; dp++ ) dumprocs.insert( tag_ps[dp] ); assert( dp == dumprocs.size() ); } #endif } else if( num_exist == 2 || num_exist == 1 ) { if( tag_ps[0] == (int)procConfig.proc_rank() ) { assert( 2 == num_exist && tag_ps[1] != (int)procConfig.proc_rank() ); tag_ps[0] = tag_ps[1]; tag_hs[0] = tag_hs[1]; } assert( tag_ps[0] != -1 && tag_hs[0] != 0 ); result = mbImpl->tag_set_data( sharedp_tag(), &new_h, 1, tag_ps );MB_CHK_SET_ERR( result, "Failed to set sharedp tag data" ); result = mbImpl->tag_set_data( sharedh_tag(), &new_h, 1, tag_hs );MB_CHK_SET_ERR( result, "Failed to set sharedh tag data" ); } // Now set new pstatus result = mbImpl->tag_set_data( pstatus_tag(), &new_h, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to set pstatus tag data" ); if( pstat & PSTATUS_SHARED ) sharedEnts.insert( new_h ); return MB_SUCCESS; }
friend class ParallelMergeMesh [friend] |
Definition at line 57 of file ParallelComm.hpp.
int moab::ParallelComm::ackbuff [private] |
Definition at line 1475 of file ParallelComm.hpp.
Referenced by recv_entities(), and send_entities().
std::vector< unsigned int > moab::ParallelComm::buffProcs [private] |
processor rank for each buffer index
Definition at line 1456 of file ParallelComm.hpp.
Referenced by buff_procs(), check_all_shared_handles(), check_my_shared_handles(), correct_thin_ghost_layers(), exchange_all_shared_handles(), exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), get_buffers(), get_comm_procs(), get_sent_ents(), initialize(), pack_shared_handles(), post_irecv(), recv_entities(), recv_messages(), recv_remote_handle_messages(), reduce_tags(), send_entities(), send_recv_entities(), and settle_intersection_points().
Error* moab::ParallelComm::errorHandler [private] |
Error handler.
Definition at line 1438 of file ParallelComm.hpp.
Referenced by initialize(), and packed_tag_size().
int moab::ParallelComm::globalPartCount [private] |
Cache of global part count.
Definition at line 1467 of file ParallelComm.hpp.
Referenced by collective_sync_partition(), create_part(), destroy_part(), and get_global_part_count().
Tag moab::ParallelComm::ifaceSetsTag [private] |
Definition at line 1465 of file ParallelComm.hpp.
const unsigned int moab::ParallelComm::INITIAL_BUFF_SIZE = 1024 [static] |
Definition at line 951 of file ParallelComm.hpp.
Referenced by broadcast_entities(), exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), get_buffers(), post_irecv(), recv_buffer(), recv_entities(), reduce_tags(), moab::ParallelComm::Buffer::reset_buffer(), scatter_entities(), send_buffer(), moab::ParCommGraph::send_mesh_parts(), send_recv_entities(), and settle_intersection_points().
Range moab::ParallelComm::interfaceSets [private] |
Definition at line 1459 of file ParallelComm.hpp.
Referenced by check_clean_iface(), create_iface_pc_links(), create_interface_sets(), get_ghosted_entities(), get_iface_entities(), get_interface_procs(), interface_sets(), and tag_iface_entities().
std::vector< Buffer* > moab::ParallelComm::localOwnedBuffs [private] |
more data buffers, proc-specific
Definition at line 1441 of file ParallelComm.hpp.
Referenced by delete_all_buffers(), exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), get_buffers(), initialize(), post_irecv(), recv_entities(), recv_messages(), recv_remote_handle_messages(), reduce_tags(), reset_all_buffers(), send_entities(), send_recv_entities(), and settle_intersection_points().
Interface* moab::ParallelComm::mbImpl [private] |
MB interface associated with this writer.
Definition at line 1429 of file ParallelComm.hpp.
Referenced by add_pcomm(), add_verts(), assign_entities_part(), assign_global_ids(), augment_default_sets_with_ghosts(), check_all_shared_handles(), check_clean_iface(), check_global_ids(), check_local_shared(), check_sent_ents(), clean_shared_tags(), correct_thin_ghost_layers(), create_iface_pc_links(), create_interface_sets(), create_part(), delete_entities(), destroy_part(), estimate_ents_buffer_size(), estimate_sets_buffer_size(), exchange_ghost_cells(), exchange_owned_meshs(), exchange_tags(), filter_pstatus(), find_existing_entity(), gather_data(), get_ghosted_entities(), get_iface_entities(), get_interface_procs(), get_moab(), get_owner_handle(), get_owning_part(), get_part_entities(), get_proc_nvecs(), get_pstatus(), get_pstatus_entities(), get_remote_handles(), get_sharing_data(), get_sharing_parts(), get_tag_send_list(), initialize(), is_iface_proc(), list_entities(), pack_entities(), pack_entity_seq(), pack_sets(), pack_tag(), partition_tag(), pstatus_tag(), reduce_tags(), remove_entities_part(), remove_pcomm(), resolve_shared_ents(), resolve_shared_sets(), set_partitioning(), set_pstatus_entities(), set_sharing_data(), settle_intersection_points(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), tag_iface_entities(), tag_shared_verts(), unpack_entities(), unpack_remote_handles(), unpack_sets(), unpack_tags(), and update_remote_data_old().
DebugOutput* moab::ParallelComm::myDebug [private] |
used to set verbosity level and to report output
Definition at line 1478 of file ParallelComm.hpp.
Referenced by define_mpe(), exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), get_debug_verbosity(), initialize(), pack_entities(), pack_entity_seq(), pack_sets(), pack_tag(), pack_tags(), print_debug_irecv(), print_debug_isend(), print_debug_recd(), print_debug_waitany(), recv_entities(), reduce_tags(), resolve_shared_ents(), send_entities(), send_recv_entities(), set_debug_verbosity(), settle_intersection_points(), unpack_buffer(), unpack_entities(), unpack_sets(), unpack_tags(), and ~ParallelComm().
std::ofstream moab::ParallelComm::myFile [private] |
Definition at line 1471 of file ParallelComm.hpp.
entity set containing all parts
Definition at line 1469 of file ParallelComm.hpp.
Referenced by get_partitioning(), and set_partitioning().
Range moab::ParallelComm::partitionSets [private] |
the partition, interface sets for this comm'n instance
Referenced by get_part_entities(), partition_sets(), resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
Tag moab::ParallelComm::partitionTag [private] |
Referenced by partition_tag().
int moab::ParallelComm::pcommID [private] |
Definition at line 1473 of file ParallelComm.hpp.
Referenced by get_id(), initialize(), and ParallelComm().
unsigned char moab::ParallelComm::PROC_OWNER [static] |
Definition at line 88 of file ParallelComm.hpp.
unsigned char moab::ParallelComm::PROC_SHARED [static] |
ProcConfig moab::ParallelComm::procConfig [private] |
Proc config object, keeps info on parallel stuff.
Definition at line 1432 of file ParallelComm.hpp.
Referenced by assign_global_ids(), augment_default_sets_with_ghosts(), broadcast_entities(), build_sharedhps_list(), check_all_shared_handles(), check_clean_iface(), check_local_shared(), create_interface_sets(), delete_entities(), exchange_all_shared_handles(), exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), get_buffers(), get_interface_procs(), get_proc_nvecs(), get_remote_handles(), initialize(), ParallelComm(), post_irecv(), print_buffer(), proc_config(), recv_buffer(), recv_entities(), recv_messages(), recv_remote_handle_messages(), reduce_tags(), resolve_shared_ents(), resolve_shared_sets(), scatter_entities(), send_buffer(), send_entities(), send_recv_entities(), set_rank(), set_sharing_data(), set_size(), settle_intersection_points(), tag_shared_verts(), unpack_entities(), and update_remote_data_old().
Tag moab::ParallelComm::pstatusTag [private] |
Referenced by pstatus_tag().
std::vector< MPI_Request > moab::ParallelComm::recvRemotehReqs [private] |
Definition at line 1453 of file ParallelComm.hpp.
Referenced by exchange_owned_meshs(), post_irecv(), recv_entities(), and send_entities().
std::vector< MPI_Request > moab::ParallelComm::recvReqs [private] |
receive request objects
Referenced by exchange_owned_meshs(), post_irecv(), recv_entities(), recv_messages(), send_entities(), and set_recv_request().
std::vector< Buffer* > moab::ParallelComm::remoteOwnedBuffs [private] |
std::vector< MPI_Request > moab::ParallelComm::sendReqs [private] |
request objects, may be used if store_remote_handles is used
Definition at line 1450 of file ParallelComm.hpp.
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), post_irecv(), recv_entities(), recv_messages(), recv_remote_handle_messages(), reduce_tags(), send_entities(), send_recv_entities(), set_send_request(), and settle_intersection_points().
Sequence manager, to get more efficient access to entities.
Definition at line 1435 of file ParallelComm.hpp.
Referenced by get_tag_send_list(), initialize(), pack_entities(), and packed_tag_size().
std::set< EntityHandle > moab::ParallelComm::sharedEnts [private] |
all local entities shared with others, whether ghost or ghosted
Definition at line 1462 of file ParallelComm.hpp.
Referenced by augment_default_sets_with_ghosts(), check_local_shared(), check_my_shared_handles(), correct_thin_ghost_layers(), create_interface_sets(), delete_entities(), exchange_ghost_cells(), exchange_owned_meshs(), exchange_tags(), get_shared_entities(), list_entities(), pack_shared_handles(), reduce_tags(), resolve_shared_ents(), set_sharing_data(), tag_shared_verts(), update_remote_data(), and update_remote_data_old().
Tag moab::ParallelComm::sharedhsTag [private] |
Referenced by sharedhs_tag().
Tag moab::ParallelComm::sharedhTag [private] |
Referenced by sharedh_tag().
Tag moab::ParallelComm::sharedpsTag [private] |
Referenced by sharedps_tag().
Tag moab::ParallelComm::sharedpTag [private] |
tags used to save sharing procs and handles
Referenced by sharedp_tag().
SharedSetData* moab::ParallelComm::sharedSetData [private] |
Data about shared sets.
Definition at line 1481 of file ParallelComm.hpp.
Referenced by get_entityset_local_handle(), get_entityset_owner(), get_entityset_owners(), get_entityset_procs(), get_owned_sets(), get_shared_sets(), ParallelComm(), resolve_shared_sets(), and ~ParallelComm().
