moab::ParallelComm Member List
This is the complete list of members for moab::ParallelComm, including all inherited members.
ackbuffmoab::ParallelComm [private]
add_pcomm(ParallelComm *pc)moab::ParallelComm [private]
add_verts(Range &sent_ents)moab::ParallelComm [private]
assign_entities_part(std::vector< EntityHandle > &entities, const int proc)moab::ParallelComm [private]
assign_global_ids(EntityHandle this_set, const int dimension, const int start_id=1, const bool largest_dim_only=true, const bool parallel=true, const bool owned_only=false)moab::ParallelComm
assign_global_ids(Range entities[], const int dimension, const int start_id, const bool parallel, const bool owned_only)moab::ParallelComm
augment_default_sets_with_ghosts(EntityHandle file_set)moab::ParallelComm
broadcast_entities(const int from_proc, Range &entities, const bool adjacencies=false, const bool tags=true)moab::ParallelComm
buff_procs() const moab::ParallelComm [inline]
buffProcsmoab::ParallelComm [private]
build_sharedhps_list(const EntityHandle entity, const unsigned char pstatus, const int sharedp, const std::set< unsigned int > &procs, unsigned int &num_ents, int *tmp_procs, EntityHandle *tmp_handles)moab::ParallelComm [private]
check_all_shared_handles(bool print_em=false)moab::ParallelComm
check_all_shared_handles(ParallelComm **pcs, int num_pcs)moab::ParallelComm [static]
check_clean_iface(Range &allsent)moab::ParallelComm [private]
check_global_ids(EntityHandle this_set, const int dimension, const int start_id=1, const bool largest_dim_only=true, const bool parallel=true, const bool owned_only=false)moab::ParallelComm
check_local_shared()moab::ParallelComm
check_my_shared_handles(std::vector< std::vector< SharedEntityData > > &shents, const char *prefix=NULL)moab::ParallelComm
check_sent_ents(Range &allsent)moab::ParallelComm [private]
clean_shared_tags(std::vector< Range * > &exchange_ents)moab::ParallelComm
collective_sync_partition()moab::ParallelComm
comm() const moab::ParallelComm [inline]
correct_thin_ghost_layers()moab::ParallelComm
create_iface_pc_links()moab::ParallelComm [private]
create_interface_sets(std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs)moab::ParallelComm
create_interface_sets(EntityHandle this_set, int resolve_dim, int shared_dim)moab::ParallelComm
create_part(EntityHandle &part_out)moab::ParallelComm
define_mpe()moab::ParallelComm [private]
delete_all_buffers()moab::ParallelComm [inline, private]
delete_entities(Range &to_delete)moab::ParallelComm
destroy_part(EntityHandle part)moab::ParallelComm
errorHandlermoab::ParallelComm [private]
estimate_ents_buffer_size(Range &entities, const bool store_remote_handles)moab::ParallelComm [private]
estimate_sets_buffer_size(Range &entities, const bool store_remote_handles)moab::ParallelComm [private]
exchange_all_shared_handles(std::vector< std::vector< SharedEntityData > > &send_data, std::vector< std::vector< SharedEntityData > > &result)moab::ParallelComm [private]
exchange_ghost_cells(int ghost_dim, int bridge_dim, int num_layers, int addl_ents, bool store_remote_handles, bool wait_all=true, EntityHandle *file_set=NULL)moab::ParallelComm
exchange_ghost_cells(ParallelComm **pc, unsigned int num_procs, int ghost_dim, int bridge_dim, int num_layers, int addl_ents, bool store_remote_handles, EntityHandle *file_sets=NULL)moab::ParallelComm [static]
exchange_owned_mesh(std::vector< unsigned int > &exchange_procs, std::vector< Range * > &exchange_ents, std::vector< MPI_Request > &recv_ent_reqs, std::vector< MPI_Request > &recv_remoteh_reqs, const bool recv_posted, bool store_remote_handles, bool wait_all, bool migrate=false)moab::ParallelComm
exchange_owned_meshs(std::vector< unsigned int > &exchange_procs, std::vector< Range * > &exchange_ents, std::vector< MPI_Request > &recv_ent_reqs, std::vector< MPI_Request > &recv_remoteh_reqs, bool store_remote_handles, bool wait_all=true, bool migrate=false, int dim=0)moab::ParallelComm
exchange_tags(const std::vector< Tag > &src_tags, const std::vector< Tag > &dst_tags, const Range &entities)moab::ParallelComm
exchange_tags(const char *tag_name, const Range &entities)moab::ParallelComm [inline]
exchange_tags(Tag tagh, const Range &entities)moab::ParallelComm [inline]
filter_pstatus(Range &ents, const unsigned char pstatus_val, const unsigned char op, int to_proc=-1, Range *returned_ents=NULL)moab::ParallelComm
find_existing_entity(const bool is_iface, const int owner_p, const EntityHandle owner_h, const int num_ents, const EntityHandle *connect, const int num_connect, const EntityType this_type, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, EntityHandle &new_h)moab::ParallelComm [private]
gather_data(Range &gather_ents, Tag &tag_handle, Tag id_tag=0, EntityHandle gather_set=0, int root_proc_rank=0)moab::ParallelComm
get_all_pcomm(Interface *impl, std::vector< ParallelComm * > &list)moab::ParallelComm [static]
get_buffers(int to_proc, bool *is_new=NULL)moab::ParallelComm
get_comm_procs(std::set< unsigned int > &procs)moab::ParallelComm [inline]
get_debug_verbosity()moab::ParallelComm
get_entityset_local_handle(unsigned owning_rank, EntityHandle remote_handle, EntityHandle &local_handle) const moab::ParallelComm
get_entityset_owner(EntityHandle entity_set, unsigned &owner_rank, EntityHandle *remote_handle=0) const moab::ParallelComm
get_entityset_owners(std::vector< unsigned > &ranks) const moab::ParallelComm
get_entityset_procs(EntityHandle entity_set, std::vector< unsigned > &ranks) const moab::ParallelComm
get_ghosted_entities(int bridge_dim, int ghost_dim, int to_proc, int num_layers, int addl_ents, Range &ghosted_ents)moab::ParallelComm [private]
get_global_part_count(int &count_out) const moab::ParallelComm
get_id() const moab::ParallelComm [inline]
get_iface_entities(int other_proc, int dim, Range &iface_ents)moab::ParallelComm
get_interface_procs(std::set< unsigned int > &iface_procs, const bool get_buffs=false)moab::ParallelComm
get_interface_sets(EntityHandle part, Range &iface_sets_out, int *adj_part_id=0)moab::ParallelComm
get_local_handles(EntityHandle *from_vec, int num_ents, const Range &new_ents)moab::ParallelComm [private]
get_local_handles(const Range &remote_handles, Range &local_handles, const std::vector< EntityHandle > &new_ents)moab::ParallelComm [private]
get_local_handles(EntityHandle *from_vec, int num_ents, const std::vector< EntityHandle > &new_ents)moab::ParallelComm [private]
get_moab() const moab::ParallelComm [inline]
get_owned_sets(unsigned owning_rank, Range &sets_out) const moab::ParallelComm
get_owner(EntityHandle entity, int &owner)moab::ParallelComm [inline]
get_owner_handle(EntityHandle entity, int &owner, EntityHandle &handle)moab::ParallelComm
get_owning_part(EntityHandle entity, int &owning_part_id_out, EntityHandle *owning_handle=0)moab::ParallelComm
get_part_entities(Range &ents, int dim=-1)moab::ParallelComm
get_part_handle(int id, EntityHandle &handle_out) const moab::ParallelComm
get_part_id(EntityHandle part, int &id_out) const moab::ParallelComm
get_part_neighbor_ids(EntityHandle part, int neighbors_out[MAX_SHARING_PROCS], int &num_neighbors_out)moab::ParallelComm
get_part_owner(int part_id, int &owner_out) const moab::ParallelComm
get_partitioning() const moab::ParallelComm [inline]
get_pcomm(Interface *impl, const int index)moab::ParallelComm [static]
get_pcomm(Interface *impl, EntityHandle partitioning, const MPI_Comm *comm=0)moab::ParallelComm [static]
get_proc_nvecs(int resolve_dim, int shared_dim, Range *skin_ents, std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs)moab::ParallelComm [private]
get_pstatus(EntityHandle entity, unsigned char &pstatus_val)moab::ParallelComm
get_pstatus_entities(int dim, unsigned char pstatus_val, Range &pstatus_ents)moab::ParallelComm
get_remote_handles(EntityHandle *local_vec, EntityHandle *rem_vec, int num_ents, int to_proc)moab::ParallelComm
get_remote_handles(const bool store_remote_handles, EntityHandle *from_vec, EntityHandle *to_vec_tmp, int num_ents, int to_proc, const std::vector< EntityHandle > &new_ents)moab::ParallelComm [private]
get_remote_handles(const bool store_remote_handles, const Range &from_range, Range &to_range, int to_proc, const std::vector< EntityHandle > &new_ents)moab::ParallelComm [private]
get_remote_handles(const bool store_remote_handles, const Range &from_range, EntityHandle *to_vec, int to_proc, const std::vector< EntityHandle > &new_ents)moab::ParallelComm [private]
get_sent_ents(const bool is_iface, const int bridge_dim, const int ghost_dim, const int num_layers, const int addl_ents, Range *sent_ents, Range &allsent, TupleList &entprocs)moab::ParallelComm [private]
get_shared_entities(int other_proc, Range &shared_ents, int dim=-1, const bool iface=false, const bool owned_filter=false)moab::ParallelComm
get_shared_proc_tags(Tag &sharedp_tag, Tag &sharedps_tag, Tag &sharedh_tag, Tag &sharedhs_tag, Tag &pstatus_tag)moab::ParallelComm [inline]
get_shared_sets(Range &result) const moab::ParallelComm
get_sharing_data(const EntityHandle entity, int *ps, EntityHandle *hs, unsigned char &pstat, unsigned int &num_ps)moab::ParallelComm
get_sharing_data(const EntityHandle entity, int *ps, EntityHandle *hs, unsigned char &pstat, int &num_ps)moab::ParallelComm [inline]
get_sharing_data(const EntityHandle *entities, int num_entities, std::set< int > &procs, int op=Interface::INTERSECT)moab::ParallelComm [inline]
get_sharing_data(const Range &entities, std::set< int > &procs, int op=Interface::INTERSECT)moab::ParallelComm
get_sharing_parts(EntityHandle entity, int part_ids_out[MAX_SHARING_PROCS], int &num_part_ids_out, EntityHandle remote_handles[MAX_SHARING_PROCS]=0)moab::ParallelComm
get_tag_send_list(const Range &all_entities, std::vector< Tag > &all_tags, std::vector< Range > &tag_ranges)moab::ParallelComm [private]
globalPartCountmoab::ParallelComm [private]
ifaceSetsTagmoab::ParallelComm [private]
INITIAL_BUFF_SIZEmoab::ParallelComm [static]
initialize()moab::ParallelComm [private]
interface_sets()moab::ParallelComm [inline]
interface_sets() const moab::ParallelComm [inline]
interfaceSetsmoab::ParallelComm [private]
is_iface_proc(EntityHandle this_set, int to_proc)moab::ParallelComm [private]
list_entities(const EntityHandle *ents, int num_ents)moab::ParallelComm
list_entities(const Range &ents)moab::ParallelComm
localOwnedBuffsmoab::ParallelComm [private]
mbImplmoab::ParallelComm [private]
myDebugmoab::ParallelComm [private]
myFilemoab::ParallelComm [private]
pack_adjacencies(Range &entities, Range::const_iterator &start_rit, Range &whole_range, unsigned char *&buff_ptr, int &count, const bool just_count, const bool store_handles, const int to_proc)moab::ParallelComm [private]
pack_buffer(Range &orig_ents, const bool adjacencies, const bool tags, const bool store_remote_handles, const int to_proc, Buffer *buff, TupleList *entprocs=NULL, Range *allsent=NULL)moab::ParallelComm
pack_entities(Range &entities, Buffer *buff, const bool store_remote_handles, const int to_proc, const bool is_iface, TupleList *entprocs=NULL, Range *allsent=NULL)moab::ParallelComm
pack_entity_seq(const int nodes_per_entity, const bool store_remote_handles, const int to_proc, Range &these_ents, std::vector< EntityHandle > &entities, Buffer *buff)moab::ParallelComm [private]
pack_range_map(Range &this_range, EntityHandle actual_start, HandleMap &handle_map)moab::ParallelComm [private]
pack_remote_handles(std::vector< EntityHandle > &L1hloc, std::vector< EntityHandle > &L1hrem, std::vector< int > &procs, unsigned int to_proc, Buffer *buff)moab::ParallelComm
pack_sets(Range &entities, Buffer *buff, const bool store_handles, const int to_proc)moab::ParallelComm [private]
pack_shared_handles(std::vector< std::vector< SharedEntityData > > &send_data)moab::ParallelComm
pack_tag(Tag source_tag, Tag destination_tag, const Range &entities, const std::vector< EntityHandle > &whole_range, Buffer *buff, const bool store_remote_handles, const int to_proc)moab::ParallelComm [private]
pack_tags(Range &entities, const std::vector< Tag > &src_tags, const std::vector< Tag > &dst_tags, const std::vector< Range > &tag_ranges, Buffer *buff, const bool store_handles, const int to_proc)moab::ParallelComm [private]
packed_tag_size(Tag source_tag, const Range &entities, int &count_out)moab::ParallelComm [private]
ParallelComm(Interface *impl, MPI_Comm comm, int *pcomm_id_out=0)moab::ParallelComm
ParallelComm(Interface *impl, std::vector< unsigned char > &tmp_buff, MPI_Comm comm, int *pcomm_id_out=0)moab::ParallelComm
ParallelMergeMesh classmoab::ParallelComm [friend]
part_tag()moab::ParallelComm [inline]
partition_sets()moab::ParallelComm [inline]
partition_sets() const moab::ParallelComm [inline]
partition_tag()moab::ParallelComm
partitioningSetmoab::ParallelComm [private]
partitionSetsmoab::ParallelComm [private]
partitionTagmoab::ParallelComm [private]
pcomm_tag(Interface *impl, bool create_if_missing=true)moab::ParallelComm [static]
pcommIDmoab::ParallelComm [private]
post_irecv(std::vector< unsigned int > &exchange_procs)moab::ParallelComm
post_irecv(std::vector< unsigned int > &shared_procs, std::set< unsigned int > &recv_procs)moab::ParallelComm
print_buffer(unsigned char *buff_ptr, int mesg_type, int from_proc, bool sent)moab::ParallelComm [private]
print_debug_irecv(int to, int from, unsigned char *buff, int size, int tag, int incoming)moab::ParallelComm [private]
print_debug_isend(int from, int to, unsigned char *buff, int tag, int size)moab::ParallelComm [private]
print_debug_recd(MPI_Status status)moab::ParallelComm [private]
print_debug_waitany(std::vector< MPI_Request > &reqs, int tag, int proc)moab::ParallelComm [private]
print_pstatus(unsigned char pstat, std::string &ostr)moab::ParallelComm
print_pstatus(unsigned char pstat)moab::ParallelComm
proc_config() const moab::ParallelComm [inline]
proc_config()moab::ParallelComm [inline]
PROC_OWNERmoab::ParallelComm [static]
PROC_SHAREDmoab::ParallelComm [static]
procConfigmoab::ParallelComm [private]
pstatus_tag()moab::ParallelComm
pstatusTagmoab::ParallelComm [private]
rank() const moab::ParallelComm [inline]
recv_buffer(int mesg_tag_expected, const MPI_Status &mpi_status, Buffer *recv_buff, MPI_Request &recv_2nd_req, MPI_Request &ack_req, int &this_incoming, Buffer *send_buff, MPI_Request &send_req, MPI_Request &sent_ack_req, bool &done, Buffer *next_buff=NULL, int next_tag=-1, MPI_Request *next_req=NULL, int *next_incoming=NULL)moab::ParallelComm [private]
recv_entities(const int from_proc, const bool store_remote_handles, const bool is_iface, Range &final_ents, int &incomming1, int &incoming2, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< MPI_Request > &recv_remoteh_reqs, bool wait_all=true)moab::ParallelComm
recv_entities(std::set< unsigned int > &recv_procs, int incoming1, int incoming2, const bool store_remote_handles, const bool migrate=false)moab::ParallelComm
recv_messages(const int from_proc, const bool store_remote_handles, const bool is_iface, Range &final_ents, int &incoming1, int &incoming2, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< MPI_Request > &recv_remoteh_reqs)moab::ParallelComm
recv_remote_handle_messages(const int from_proc, int &incoming2, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< MPI_Request > &recv_remoteh_reqs)moab::ParallelComm
recvRemotehReqsmoab::ParallelComm [private]
recvReqsmoab::ParallelComm [private]
reduce(const MPI_Op mpi_op, int num_ents, void *old_vals, void *new_vals)moab::ParallelComm [private]
reduce_tags(const std::vector< Tag > &src_tags, const std::vector< Tag > &dst_tags, const MPI_Op mpi_op, const Range &entities)moab::ParallelComm
reduce_tags(const char *tag_name, const MPI_Op mpi_op, const Range &entities)moab::ParallelComm [inline]
reduce_tags(Tag tag_handle, const MPI_Op mpi_op, const Range &entities)moab::ParallelComm [inline]
reduce_void(int tag_data_type, const MPI_Op mpi_op, int num_ents, void *old_vals, void *new_vals)moab::ParallelComm [private]
remoteOwnedBuffsmoab::ParallelComm [private]
remove_entities_part(Range &entities, const int proc)moab::ParallelComm [private]
remove_pcomm(ParallelComm *pc)moab::ParallelComm [private]
reset_all_buffers()moab::ParallelComm [inline]
resolve_shared_ents(EntityHandle this_set, Range &proc_ents, int resolve_dim=-1, int shared_dim=-1, Range *skin_ents=NULL, const Tag *id_tag=0)moab::ParallelComm
resolve_shared_ents(EntityHandle this_set, int resolve_dim=3, int shared_dim=-1, const Tag *id_tag=0)moab::ParallelComm
resolve_shared_ents(ParallelComm **pc, const unsigned int np, EntityHandle this_set, const int to_dim)moab::ParallelComm [static]
resolve_shared_sets(EntityHandle this_set, const Tag *id_tag=0)moab::ParallelComm
resolve_shared_sets(Range &candidate_sets, Tag id_tag)moab::ParallelComm
scatter_entities(const int from_proc, std::vector< Range > &entities, const bool adjacencies=false, const bool tags=true)moab::ParallelComm
send_buffer(const unsigned int to_proc, Buffer *send_buff, const int msg_tag, MPI_Request &send_req, MPI_Request &ack_recv_req, int *ack_buff, int &this_incoming, int next_mesg_tag=-1, Buffer *next_recv_buff=NULL, MPI_Request *next_recv_req=NULL, int *next_incoming=NULL)moab::ParallelComm [private]
send_entities(const int to_proc, Range &orig_ents, const bool adjs, const bool tags, const bool store_remote_handles, const bool is_iface, Range &final_ents, int &incoming1, int &incoming2, TupleList &entprocs, std::vector< MPI_Request > &recv_remoteh_reqs, bool wait_all=true)moab::ParallelComm
send_entities(std::vector< unsigned int > &send_procs, std::vector< Range * > &send_ents, int &incoming1, int &incoming2, const bool store_remote_handles)moab::ParallelComm
send_recv_entities(std::vector< int > &send_procs, std::vector< std::vector< int > > &msgsizes, std::vector< std::vector< EntityHandle > > &senddata, std::vector< std::vector< EntityHandle > > &recvdata)moab::ParallelComm
sendReqsmoab::ParallelComm [private]
sequenceManagermoab::ParallelComm [private]
set_debug_verbosity(int verb)moab::ParallelComm
set_partitioning(EntityHandle h)moab::ParallelComm
set_pstatus_entities(Range &pstatus_ents, unsigned char pstatus_val, bool lower_dim_ents=false, bool verts_too=true, int operation=Interface::UNION)moab::ParallelComm [private]
set_pstatus_entities(EntityHandle *pstatus_ents, int num_ents, unsigned char pstatus_val, bool lower_dim_ents=false, bool verts_too=true, int operation=Interface::UNION)moab::ParallelComm [private]
set_rank(unsigned int r)moab::ParallelComm [inline]
set_recv_request(int n_request)moab::ParallelComm [inline]
set_send_request(int n_request)moab::ParallelComm [inline]
set_sharing_data(EntityHandle ent, unsigned char pstatus, int old_nump, int new_nump, int *ps, EntityHandle *hs)moab::ParallelComm [private]
set_size(unsigned int r)moab::ParallelComm [inline]
settle_intersection_points(Range &edges, Range &shared_edges_owned, std::vector< std::vector< EntityHandle > * > &extraNodesVec, double tolerance)moab::ParallelComm
sharedEntsmoab::ParallelComm [private]
sharedh_tag()moab::ParallelComm
sharedhs_tag()moab::ParallelComm
sharedhsTagmoab::ParallelComm [private]
sharedhTagmoab::ParallelComm [private]
sharedp_tag()moab::ParallelComm
sharedps_tag()moab::ParallelComm
sharedpsTagmoab::ParallelComm [private]
sharedpTagmoab::ParallelComm [private]
sharedSetDatamoab::ParallelComm [private]
size() const moab::ParallelComm [inline]
tag_iface_entities()moab::ParallelComm [private]
tag_shared_verts(TupleList &shared_ents, std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs, Range &proc_verts, unsigned int i_extra=1)moab::ParallelComm
tag_shared_verts(TupleList &shared_verts, Range *skin_ents, std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs, Range &proc_verts)moab::ParallelComm [private]
unpack_adjacencies(unsigned char *&buff_ptr, Range &entities, const bool store_handles, const int from_proc)moab::ParallelComm [private]
unpack_buffer(unsigned char *buff_ptr, const bool store_remote_handles, const int from_proc, const int ind, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< EntityHandle > &new_ents, const bool created_iface=false)moab::ParallelComm
unpack_entities(unsigned char *&buff_ptr, const bool store_remote_handles, const int from_ind, const bool is_iface, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< EntityHandle > &new_ents, const bool created_iface=false)moab::ParallelComm
unpack_iface_entities(unsigned char *&buff_ptr, const int from_proc, const int ind, std::vector< EntityHandle > &recd_ents)moab::ParallelComm [private]
unpack_remote_handles(unsigned int from_proc, unsigned char *&buff_ptr, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p)moab::ParallelComm
unpack_remote_handles(unsigned int from_proc, const unsigned char *buff_ptr, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p)moab::ParallelComm [inline, private]
unpack_sets(unsigned char *&buff_ptr, std::vector< EntityHandle > &entities, const bool store_handles, const int to_proc)moab::ParallelComm [private]
unpack_tags(unsigned char *&buff_ptr, std::vector< EntityHandle > &entities, const bool store_handles, const int to_proc, const MPI_Op *const mpi_op=NULL)moab::ParallelComm [private]
update_iface_sets(Range &sent_ents, std::vector< EntityHandle > &remote_handles, int from_proc)moab::ParallelComm [private]
update_remote_data(EntityHandle entity, std::vector< int > &procs, std::vector< EntityHandle > &handles)moab::ParallelComm
update_remote_data(Range &local_range, Range &remote_range, int other_proc, const unsigned char add_pstat)moab::ParallelComm [private]
update_remote_data(const EntityHandle new_h, const int *ps, const EntityHandle *hs, const int num_ps, const unsigned char add_pstat)moab::ParallelComm [private]
update_remote_data_old(const EntityHandle new_h, const int *ps, const EntityHandle *hs, const int num_ps, const unsigned char add_pstat)moab::ParallelComm [private]
~ParallelComm()moab::ParallelComm
