moab::SequenceManager Class Reference
#include <SequenceManager.hpp>
+ Collaboration diagram for moab::SequenceManager:
Public Member Functions
 SequenceManager (double default_seq_multiplier=1.0)
 ~SequenceManager ()
void clear ()
ErrorCode find (EntityHandle handle, EntitySequence *&sequence_out)
ErrorCode find (EntityHandle handle, const EntitySequence *&sequence_out) const
void get_entities (EntityType type, Range &entities_out) const
void get_entities (Range &entities_out) const
void get_entities (EntityType type, std::vector< EntityHandle > &entities_out) const
void get_entities (std::vector< EntityHandle > &entities_out) const
EntityID get_number_entities (EntityType type) const
EntityID get_number_entities () const
const EntitySequenceget_last_accessed_sequence (EntityType type) const
ErrorCode replace_subsequence (EntitySequence *new_seq)
 Replace subset of existing sequence with new sequence (splits existing sequence)
ErrorCode check_valid_entities (Error *error_handler, const Range &entities) const
ErrorCode check_valid_entities (Error *error_handler, const EntityHandle entities[], size_t num_entities, bool root_set_okay=false) const
ErrorCode delete_entity (Error *error_handler, EntityHandle entity)
ErrorCode delete_entities (Error *error_handler, const Range &entities)
ErrorCode create_vertex (const double coords[3], EntityHandle &handle_out)
ErrorCode create_element (EntityType type, const EntityHandle *conn_array, unsigned num_vertices, EntityHandle &handle_out)
ErrorCode create_mesh_set (unsigned flags, EntityHandle &handle_out)
ErrorCode allocate_mesh_set (EntityHandle at_this_handle, unsigned flags)
ErrorCode create_entity_sequence (EntityType type, EntityID num_entities, int nodes_per_entity, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out, int sequence_size)
 Allocate a block of consecutive entity handles.
ErrorCode create_meshset_sequence (EntityID num_sets, EntityID start_id_hint, const unsigned *flags, EntityHandle &first_handle_out, EntitySequence *&sequence_out)
 Allocate a block of consecutive mesh sets.
ErrorCode create_meshset_sequence (EntityID num_sets, EntityID start_id_hint, unsigned flags, EntityHandle &first_handle_out, EntitySequence *&sequence_out)
ErrorCode create_scd_sequence (int imin, int jmin, int kmin, int imax, int jmax, int kmax, EntityType type, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out, int *is_periodic=NULL)
ErrorCode create_scd_sequence (const HomCoord &coord_min, const HomCoord &coord_max, EntityType type, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out, int *is_periodic=NULL)
ErrorCode create_sweep_sequence (int imin, int jmin, int kmin, int imax, int jmax, int kmax, int *Cq, EntityType type, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out)
ErrorCode create_sweep_sequence (const HomCoord &coord_min, const HomCoord &coord_max, int *Cq, EntityType type, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out)
ErrorCode add_vsequence (EntitySequence *vert_seq, EntitySequence *elem_seq, const HomCoord &p1, const HomCoord &q1, const HomCoord &p2, const HomCoord &q2, const HomCoord &p3, const HomCoord &q3, bool bb_input=false, const HomCoord *bb_min=NULL, const HomCoord *bb_max=NULL)
TypeSequenceManagerentity_map (EntityType type)
const TypeSequenceManagerentity_map (EntityType type) const
void get_memory_use (unsigned long long &total_entity_storage, unsigned long long &total_storage) const
void get_memory_use (EntityType type, unsigned long long &total_entity_storage, unsigned long long &total_storage) const
void get_memory_use (const Range &entities, unsigned long long &total_entity_storage, unsigned long long &total_amortized_storage) const
ErrorCode reserve_tag_array (Error *error_handler, int tag_size, int &array_id_out)
ErrorCode release_tag_array (Error *error_handler, int id, bool release_id)
EntityID new_sequence_size (EntityHandle start_handle, EntityID requested_size, int sequence_size) const
 Size to allocate for new SquenceData THIS FUNCTION SHOULD ONLY BE CALLED WHEN ALLOCATING FROM ReadUtil IN BULK (since it will allocate lesser of requested_size and default_size) If sequence_size != -1, will try to allocate that, unless there isn't available space.
double get_sequence_multiplier () const
 Interface to control memory allocation for sequences Provide a factor that controls the size of the sequence that gets allocated. This is typically useful in the parallel setting when a-priori, the number of ghost entities and the memory required for them within the same sequence as the owned entities are unknown. The default factor is 1.0 but this can be appropriately updated at runtime so that we do not have broken sequences.
void set_sequence_multiplier (double factor)
Static Public Member Functions
static EntityID default_poly_sequence_size (int entity_connectivity_length)
 Get default size of POLYGON and POLYHEDRON SequenceData.
Static Public Attributes
static const EntityID DEFAULT_VERTEX_SEQUENCE_SIZE = 16 * 1024
 Default allocation size for vertices.
static const EntityID DEFAULT_ELEMENT_SEQUENCE_SIZE = DEFAULT_VERTEX_SEQUENCE_SIZE
 Default allocation size for elements.
static const EntityID DEFAULT_POLY_SEQUENCE_SIZE = 16 * 1024
 Default allocation size for poly's.
static const EntityID DEFAULT_MESHSET_SEQUENCE_SIZE = DEFAULT_VERTEX_SEQUENCE_SIZE
 Default allocation size for meshsets.
Private Member Functions
void trim_sequence_block (EntityHandle start_handle, EntityHandle &end_handle_in_out, unsigned maximum_sequence_size)
 Utility function for allocate_mesh_set (and similar)
EntityHandle sequence_start_handle (EntityType type, EntityID entity_count, int values_per_entity, EntityID start_id_hint, SequenceData *&data_out, EntityID &data_size)
 Get range of handles in which to create an entity sequence.
Private Attributes
TypeSequenceManager typeData [MBMAXTYPE]
std::vector< int > tagSizes
double sequence_multiplier
 The over-allocation factor for entities in a sequence (strictly >= 1.0)
Detailed Description
Definition at line 14 of file SequenceManager.hpp.
moab::SequenceManager::SequenceManager ( double  default_seq_multiplier = 1.0) [inline]
Definition at line 17 of file SequenceManager.hpp.
: sequence_multiplier( default_seq_multiplier ) {}
Definition at line 36 of file SequenceManager.cpp.
References MB_VARIABLE_LENGTH, release_tag_array(), and tagSizes.
    // Release variable-length tag data
    for( unsigned i = 0; i < tagSizes.size(); ++i )
        if( tagSizes[i] == MB_VARIABLE_LENGTH ) release_tag_array( 0, i, false );
Member Function Documentation
ErrorCode moab::SequenceManager::add_vsequence ( EntitySequence vert_seq,
EntitySequence elem_seq,
const HomCoord p1,
const HomCoord q1,
const HomCoord p2,
const HomCoord q2,
const HomCoord p3,
const HomCoord q3,
bool  bb_input = false,
const HomCoord bb_min = NULL,
const HomCoord bb_max = NULL
Add a structured vertex sequence to this structured element sequence; see comments in ScdElementData
Definition at line 736 of file SequenceManager.cpp.
References moab::ScdElementData::add_vsequence(), moab::EntitySequence::data(), and moab::HomCoord::unitv.
    // Check first that they're structured vtx/elem sequences
    ScdVertexData* scd_vd = dynamic_cast< ScdVertexData* >( vert_seq->data() );
    if( !scd_vd ) return MB_FAILURE;
    ScdElementData* scd_ed = dynamic_cast< ScdElementData* >( elem_seq->data() );
    if( !scd_ed ) return MB_FAILURE;
    if( bb_min && bb_max )
        return scd_ed->add_vsequence( scd_vd, p1, q1, p2, q2, p3, q3, bb_input, *bb_min, *bb_max );
    else
        return scd_ed->add_vsequence( scd_vd, p1, q1, p2, q2, p3, q3, bb_input, HomCoord::unitv[0],
                                      HomCoord::unitv[0] );
ErrorCode moab::SequenceManager::allocate_mesh_set ( EntityHandle  at_this_handle,
unsigned  flags
Allocate an entity set with the specified handle.
Returns:
MB_ALREADY_ALLOCATED if handle is in use, MB_SUCCESS otherwise.
Definition at line 340 of file SequenceManager.cpp.
References moab::EntitySequence::data(), DEFAULT_MESHSET_SEQUENCE_SIZE, moab::EntitySequence::end_handle(), ErrorCode, moab::TypeSequenceManager::insert_sequence(), moab::TypeSequenceManager::is_free_handle(), MB_SUCCESS, MBENTITYSET, moab::TypeSequenceManager::notify_appended(), moab::TypeSequenceManager::notify_prepended(), moab::MeshSetSequence::pop_back(), moab::MeshSetSequence::pop_front(), moab::MeshSetSequence::push_back(), moab::MeshSetSequence::push_front(), moab::EntitySequence::start_handle(), trim_sequence_block(), and typeData.
    SequenceData* data = 0;
    TypeSequenceManager::iterator seqptr;
    EntityHandle block_start = 1, block_end = 0;
    ErrorCode rval = typeData[MBENTITYSET].is_free_handle( handle, seqptr, data, block_start, block_end );
    if( MB_SUCCESS != rval ) return rval;
    MeshSetSequence* seq;
    if( seqptr != typeData[MBENTITYSET].end() )
        seq = static_cast< MeshSetSequence* >( *seqptr );
        if( seq->start_handle() - 1 == handle )
            rval = seq->push_front( 1, &flags );
            if( MB_SUCCESS == rval )
                rval = typeData[MBENTITYSET].notify_prepended( seqptr );
                if( MB_SUCCESS != rval ) seq->pop_front( 1 );
            return rval;
        else if( seq->end_handle() + 1 == handle )
            rval = seq->push_back( 1, &flags );
                rval = typeData[MBENTITYSET].notify_appended( seqptr );
                if( MB_SUCCESS != rval ) seq->pop_back( 1 );
            return rval;
        else
            return MB_FAILURE;  // Should be unreachable
    else
        if( data )
            seq = new MeshSetSequence( handle, 1, flags, data );
        else
            assert( handle >= block_start && handle <= block_end );
            trim_sequence_block( handle, block_end, DEFAULT_MESHSET_SEQUENCE_SIZE );
            seq = new MeshSetSequence( handle, 1, flags, block_end - handle + 1 );
        rval = typeData[MBENTITYSET].insert_sequence( seq );
            SequenceData* vdata = seq->data();
            delete seq;
            if( !data ) delete vdata;
            return rval;
        return MB_SUCCESS;
ErrorCode moab::SequenceManager::check_valid_entities ( Error error_handler,
const Range entities
) const
Check if passed entity handles are valid
Definition at line 78 of file SequenceManager.cpp.
References moab::TypeSequenceManager::check_valid_handles(), moab::Range::const_pair_begin(), moab::Range::const_pair_end(), moab::CREATE_HANDLE(), ErrorCode, MB_SUCCESS, split, moab::TYPE_FROM_HANDLE(), and typeData.
Referenced by moab::BitTag::clear_data(), moab::VarLenSparseTag::clear_data(), moab::SparseTag::clear_data(), delete_entities(), moab::BitTag::set_data(), moab::SparseTag::set_data(), moab::VarLenSparseTag::set_data(), and moab::SparseTag::tag_iterate().
    ErrorCode rval;
    Range::const_pair_iterator i;
    for( i = entities.const_pair_begin(); i != entities.const_pair_end(); ++i )
        const EntityType type1 = TYPE_FROM_HANDLE( i->first );
        const EntityType type2 = TYPE_FROM_HANDLE( i->second );
        if( type1 == type2 )
            rval = typeData[type1].check_valid_handles( NULL, i->first, i->second );
        else
            int junk;
            EntityHandle split = CREATE_HANDLE( type2, 0, junk );
            rval               = typeData[type1].check_valid_handles( NULL, i->first, split - 1 );
            rval = typeData[type2].check_valid_handles( NULL, split, i->second );
    return MB_SUCCESS;
bool  root_set_okay = false
) const
Parameters:
root_set_okayIf true, do not returnan error if the passed array contains one or more zero-valued handles
Delete all contained data
Definition at line 43 of file SequenceManager.cpp.
References MBMAXTYPE, MBVERTEX, sequence_multiplier, t, and typeData.
    // reset sequence multiplier
    sequence_multiplier = 1.0;
    // Destroy all TypeSequenceManager instances
    for( EntityType t = MBVERTEX; t < MBMAXTYPE; ++t )
        typeData[t].~TypeSequenceManager();
    // Now re-create TypeSequenceManager instances
        new( typeData + t ) TypeSequenceManager();
ErrorCode moab::SequenceManager::create_element ( EntityType  type,
const EntityHandle conn_array,
EntityHandle handle_out
Allocate a element (possibly in an existing sequence) and assign it the passed connectivity.
Definition at line 219 of file SequenceManager.cpp.
References moab::CREATE_HANDLE(), moab::EntitySequence::data(), DEFAULT_ELEMENT_SEQUENCE_SIZE, default_poly_sequence_size(), moab::EntitySequence::end_handle(), ErrorCode, moab::TypeSequenceManager::find_free_handle(), moab::TypeSequenceManager::find_free_sequence(), moab::TypeSequenceManager::insert_sequence(), MB_END_ID, MB_START_ID, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, MBENTITYSET, MBPOLYGON, MBPOLYHEDRON, moab::TypeSequenceManager::notify_appended(), moab::TypeSequenceManager::notify_prepended(), moab::UnstructuredElemSeq::push_back(), moab::UnstructuredElemSeq::push_front(), moab::UnstructuredElemSeq::set_connectivity(), size, moab::EntitySequence::start_handle(), and typeData.
    if( type <= MBVERTEX || type >= MBENTITYSET ) return MB_TYPE_OUT_OF_RANGE;
    const EntityHandle start = CREATE_HANDLE( type, MB_START_ID );
    const EntityHandle end   = CREATE_HANDLE( type, MB_END_ID );
    bool append;
    TypeSequenceManager::iterator seq = typeData[type].find_free_handle( start, end, append, conn_len );
    UnstructuredElemSeq* eseq;
    if( seq == typeData[type].end() )
        SequenceData* seq_data = 0;
        unsigned size          = DEFAULT_ELEMENT_SEQUENCE_SIZE;
        if( type == MBPOLYGON || type == MBPOLYHEDRON )
            size = default_poly_sequence_size( conn_len );
        EntityID seq_data_size = 0;
        handle = typeData[type].find_free_sequence( size, start, end, seq_data, seq_data_size, conn_len );
        if( !handle ) return MB_FAILURE;
        if( MBPOLYGON == type || MBPOLYHEDRON == type )
            if( seq_data )
                eseq = new PolyElementSeq( handle, 1, conn_len, seq_data );
            else
                eseq = new PolyElementSeq( handle, 1, conn_len, size );
        else
            if( seq_data )
                eseq = new UnstructuredElemSeq( handle, 1, conn_len, seq_data );
            else
                eseq = new UnstructuredElemSeq( handle, 1, conn_len, size );
        ErrorCode rval = typeData[type].insert_sequence( eseq );
            SequenceData* vdata = eseq->data();
            delete eseq;
            if( !seq_data ) delete vdata;
            return rval;
    else
        eseq = reinterpret_cast< UnstructuredElemSeq* >( *seq );
        if( append )
            eseq->push_back( 1 );
            handle = eseq->end_handle();
            typeData[type].notify_appended( seq );
        else
            eseq->push_front( 1 );
            handle = eseq->start_handle();
            typeData[type].notify_prepended( seq );
    return eseq->set_connectivity( handle, conn, conn_len );
ErrorCode moab::SequenceManager::create_entity_sequence ( EntityType  type,
EntityHandle first_handle_out,
EntitySequence *&  sequence_out,
int  sequence_size
Allocate a block of consecutive entity handles. Handles may be appended or prepended to an existing entity sequence.
Parameters:
typeThe type of of entity for which to allocate handles
num_entitiesNumber of entities to allocate
nodes_per_entityNumber of nodes in connectivity for elements, ignored MBVERTEX, MBPOLYGON, MBPOLYHEDRON, and MBENTITYSET types.
start_id_hintPreferred ID portion for first handle. May be ignored if not available.
first_handle_outFirst allocated handle. Allocated handles are [first_handle_out, first_handle_out+num_entities-1].
sequence_outThe sequence in which the entities were allocated. NOTE: first_handle_out may not be first handle in sequence.
sequence_sizeIf specified, allocate this sequence size instead of DEFAULT_***_SEQUENCE_SIZE
Definition at line 451 of file SequenceManager.cpp.
References moab::EntitySequence::data(), default_poly_sequence_size(), ErrorCode, moab::TypeSequenceManager::insert_sequence(), MB_INDEX_OUT_OF_RANGE, MB_MEMORY_ALLOCATION_FAILED, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, MBENTITYSET, MBMAXTYPE, MBPOLYGON, MBPOLYHEDRON, MBVERTEX, new_sequence_size(), sequence_start_handle(), and typeData.
Referenced by moab::ReadUtil::get_element_connect(), and moab::ReadUtil::get_node_coords().
    SequenceData* data = NULL;
    EntityID data_size = 0;
    handle             = sequence_start_handle( type, count, size, start, data, data_size );
    if( !handle ) return MB_MEMORY_ALLOCATION_FAILED;
    switch( type )
        case MBENTITYSET:
        case MBMAXTYPE:
        case MBVERTEX:
            if( size != 0 ) return MB_INDEX_OUT_OF_RANGE;
            if( data )
                sequence = new VertexSequence( handle, count, data );
            else
                if( !data_size ) data_size = new_sequence_size( handle, count, sequence_size );
                sequence = new VertexSequence( handle, count, data_size );
            break;
        case MBPOLYGON:
        case MBPOLYHEDRON:
            if( size == 0 ) return MB_INDEX_OUT_OF_RANGE;
            if( data )
                sequence = new PolyElementSeq( handle, count, size, data );
            else
                if( !data_size )
                        handle, count, ( -1 == sequence_size ? default_poly_sequence_size( size ) : sequence_size ) );
                sequence = new PolyElementSeq( handle, count, size, data_size );
            break;
        default:
            if( data )
                sequence = new UnstructuredElemSeq( handle, count, size, data );
            else
                sequence = new UnstructuredElemSeq( handle, count, size, data_size );
            // tjt calling new_sequence_size 'cuz don't have a sequence data;
            // start 41467, count 246
            break;
    ErrorCode result = typeData[type].insert_sequence( sequence );
    if( MB_SUCCESS != result )
        // Change to NULL if had an existing data or if no existing data,
        // change to the new data created
        data = data ? 0 : sequence->data();
        delete sequence;
        delete data;
        return result;
    return MB_SUCCESS;
ErrorCode moab::SequenceManager::create_mesh_set ( unsigned  flags,
Allocate an entity set (possibly in an existing sequence)
Definition at line 289 of file SequenceManager.cpp.
References moab::CREATE_HANDLE(), moab::EntitySequence::data(), DEFAULT_MESHSET_SEQUENCE_SIZE, moab::EntitySequence::end_handle(), ErrorCode, moab::TypeSequenceManager::find_free_handle(), moab::TypeSequenceManager::find_free_sequence(), moab::TypeSequenceManager::insert_sequence(), MB_END_ID, MB_START_ID, MB_SUCCESS, MBENTITYSET, moab::TypeSequenceManager::notify_appended(), moab::TypeSequenceManager::notify_prepended(), moab::MeshSetSequence::push_back(), moab::MeshSetSequence::push_front(), moab::EntitySequence::start_handle(), and typeData.
    const EntityHandle start = CREATE_HANDLE( MBENTITYSET, MB_START_ID );
    const EntityHandle end   = CREATE_HANDLE( MBENTITYSET, MB_END_ID );
    bool append;
    TypeSequenceManager::iterator seq = typeData[MBENTITYSET].find_free_handle( start, end, append );
    MeshSetSequence* msseq;
    if( seq == typeData[MBENTITYSET].end() )
        handle = typeData[MBENTITYSET].find_free_sequence( DEFAULT_MESHSET_SEQUENCE_SIZE, start, end, seq_data,
                                                           seq_data_size );
        if( seq_data )
            msseq = new MeshSetSequence( handle, 1, flags, seq_data );
        else
            msseq = new MeshSetSequence( handle, 1, flags, DEFAULT_MESHSET_SEQUENCE_SIZE );
        ErrorCode rval = typeData[MBENTITYSET].insert_sequence( msseq );
            SequenceData* vdata = msseq->data();
            delete msseq;
            return rval;
    else
        msseq = reinterpret_cast< MeshSetSequence* >( *seq );
        if( append )
            msseq->push_back( 1, &flags );
            handle = msseq->end_handle();
            typeData[MBENTITYSET].notify_appended( seq );
        else
            msseq->push_front( 1, &flags );
            handle = msseq->start_handle();
            typeData[MBENTITYSET].notify_prepended( seq );
    return MB_SUCCESS;
ErrorCode moab::SequenceManager::create_meshset_sequence ( EntityID  num_sets,
const unsigned *  flags,
Parameters:
num_setsNumber of entities to allocate
processor_idProcessor ID to embed in handles
flagsArray of length 'num_sets' containing entity set creating flags.
Definition at line 527 of file SequenceManager.cpp.
References moab::EntitySequence::data(), ErrorCode, moab::TypeSequenceManager::insert_sequence(), MB_MEMORY_ALLOCATION_FAILED, MB_SUCCESS, MBENTITYSET, sequence_start_handle(), and typeData.
Referenced by moab::ReadUtil::create_entity_sets().
    handle             = sequence_start_handle( MBENTITYSET, count, 0, start, data, data_size );
    if( data )
        sequence = new MeshSetSequence( handle, count, flags, data );
    else
        sequence = new MeshSetSequence( handle, count, flags, count );
    ErrorCode result = typeData[MBENTITYSET].insert_sequence( sequence );
        delete sequence;
        delete data;
        return result;
    return MB_SUCCESS;
unsigned  flags,
Alternate form that creates all mesh sets with same flags.
Definition at line 558 of file SequenceManager.cpp.
    if( data )
    else
        delete sequence;
        delete data;
        return result;
    return MB_SUCCESS;
ErrorCode moab::SequenceManager::create_scd_sequence ( int  imin,
int  jmin,
int  kmin,
int  imax,
int  jmax,
int  kmax,
EntityType  type,
int *  is_periodic = NULL
Create structured mesh
Definition at line 588 of file SequenceManager.cpp.
References moab::EntitySequence::data(), moab::CN::Dimension(), ErrorCode, moab::TypeSequenceManager::insert_sequence(), MB_MEMORY_ALLOCATION_FAILED, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, MBEDGE, MBHEX, MBQUAD, MBVERTEX, sequence_start_handle(), moab::SequenceData::size(), and typeData.
Referenced by moab::ScdInterface::construct_box(), create_scd_sequence(), and moab::ScdInterface::create_scd_sequence().
    int this_dim = CN::Dimension( type );
    // Use > instead of != in the following assert to also catch cases where imin > imax, etc.
    assert( ( this_dim < 3 || kmax > kmin ) && ( this_dim < 2 || jmax > jmin ) && ( this_dim < 1 || imax > imin ) );
    // Compute # entities; not as easy as it would appear...
    EntityID num_ent;
    if( MBVERTEX == type )
        num_ent = (EntityID)( imax - imin + 1 ) * (EntityID)( jmax - jmin + 1 ) * (EntityID)( kmax - kmin + 1 );
    else
        num_ent = ( imax - imin + ( is_periodic && is_periodic[0] ? 1 : 0 ) ) *
                  ( this_dim >= 2 ? ( jmax - jmin + ( is_periodic && is_periodic[1] ? 1 : 0 ) ) : 1 ) *
                  ( this_dim >= 3 ? ( kmax - kmin ) : 1 );
    if( MBVERTEX == type && ( is_periodic && ( is_periodic[0] || is_periodic[1] ) ) ) return MB_FAILURE;
    // Get a start handle
    handle             = sequence_start_handle( type, num_ent, -1, start_id_hint, data, data_size );
    assert( !data );
    switch( type )
        case MBVERTEX:
            data     = new ScdVertexData( handle, imin, jmin, kmin, imax, jmax, kmax );
            sequence = new VertexSequence( handle, data->size(), data );
            break;
        case MBEDGE:
        case MBQUAD:
        case MBHEX:
            sequence = new StructuredElementSeq( handle, imin, jmin, kmin, imax, jmax, kmax, is_periodic );
            break;
        default:
        data = sequence->data();
        delete sequence;
        delete data;
        return result;
    return MB_SUCCESS;
ErrorCode moab::SequenceManager::create_scd_sequence ( const HomCoord coord_min,
const HomCoord coord_max,
EntityType  type,
Definition at line 653 of file SequenceManager.cpp.
References create_scd_sequence(), moab::HomCoord::i(), moab::HomCoord::j(), and moab::HomCoord::k().
    return create_scd_sequence( coord_min.i(), coord_min.j(), coord_min.k(), coord_max.i(), coord_max.j(),
                                coord_max.k(), type, start_id_hint, first_handle_out, sequence_out, is_periodic );
ErrorCode moab::SequenceManager::create_sweep_sequence ( int  imin,
int  jmin,
int  kmin,
int  imax,
int  jmax,
int  kmax,
int *  Cq,
EntityType  type,
Create swept mesh
Definition at line 665 of file SequenceManager.cpp.
Referenced by create_sweep_sequence().
    EntityID num_ent;
    else
        num_ent = ( imax - imin ) * ( this_dim >= 2 ? ( jmax - jmin ) : 1 ) * ( this_dim >= 3 ? ( kmax - kmin ) : 1 );
    assert( !data );
    switch( type )
        case MBVERTEX:
            break;
        case MBEDGE:
        case MBQUAD:
        case MBHEX:
            sequence = new SweptElementSeq( handle, imin, jmin, kmin, imax, jmax, kmax, Cq );
            break;
        default:
        delete sequence;
        delete data;
        return result;
    return MB_SUCCESS;
ErrorCode moab::SequenceManager::create_sweep_sequence ( const HomCoord coord_min,
int *  Cq,
EntityType  type,
Create swept mesh
Definition at line 724 of file SequenceManager.cpp.
References create_sweep_sequence(), moab::HomCoord::i(), moab::HomCoord::j(), and moab::HomCoord::k().
    return create_sweep_sequence( coord_min.i(), coord_min.j(), coord_min.k(), coord_max.i(), coord_max.j(),
                                  coord_max.k(), Cq, type, start_id_hint, first_handle_out, sequence_out );
ErrorCode moab::SequenceManager::create_vertex ( const double  coords[3],
Allocate a vertex (possibly in an existing sequence) and assign it the passed coordinate values.
Definition at line 168 of file SequenceManager.cpp.
References moab::CREATE_HANDLE(), moab::EntitySequence::data(), DEFAULT_VERTEX_SEQUENCE_SIZE, moab::EntitySequence::end_handle(), ErrorCode, moab::TypeSequenceManager::find_free_handle(), moab::TypeSequenceManager::find_free_sequence(), moab::TypeSequenceManager::insert_sequence(), MB_END_ID, MB_START_ID, MB_SUCCESS, MBVERTEX, moab::TypeSequenceManager::notify_appended(), moab::TypeSequenceManager::notify_prepended(), moab::VertexSequence::push_back(), moab::VertexSequence::push_front(), moab::VertexSequence::set_coordinates(), moab::EntitySequence::start_handle(), and typeData.
    const EntityHandle start = CREATE_HANDLE( MBVERTEX, MB_START_ID );
    const EntityHandle end   = CREATE_HANDLE( MBVERTEX, MB_END_ID );
    bool append;
    TypeSequenceManager::iterator seq = typeData[MBVERTEX].find_free_handle( start, end, append );
    VertexSequence* vseq;
    if( seq == typeData[MBVERTEX].end() )
        handle =
            typeData[MBVERTEX].find_free_sequence( DEFAULT_VERTEX_SEQUENCE_SIZE, start, end, seq_data, seq_data_size );
        if( seq_data )
            vseq = new VertexSequence( handle, 1, seq_data );
        else
            vseq = new VertexSequence( handle, 1, DEFAULT_VERTEX_SEQUENCE_SIZE );
        ErrorCode rval = typeData[MBVERTEX].insert_sequence( vseq );
            SequenceData* vdata = vseq->data();
            delete vseq;
            return rval;
    else
        vseq = reinterpret_cast< VertexSequence* >( *seq );
        if( append )
            vseq->push_back( 1 );
            handle = vseq->end_handle();
            typeData[MBVERTEX].notify_appended( seq );
        else
            vseq->push_front( 1 );
            handle = vseq->start_handle();
            typeData[MBVERTEX].notify_prepended( seq );
    return vseq->set_coordinates( handle, coords );
EntityID moab::SequenceManager::default_poly_sequence_size ( int  entity_connectivity_length) [static]
Definition at line 31 of file SequenceManager.cpp.
References DEFAULT_POLY_SEQUENCE_SIZE.
Referenced by create_element(), and create_entity_sequence().
    return std::max( DEFAULT_POLY_SEQUENCE_SIZE / conn_len, (EntityID)1 );
ErrorCode moab::SequenceManager::delete_entities ( Error error_handler,
Delete entities
Definition at line 138 of file SequenceManager.cpp.
References check_valid_entities(), moab::Range::const_pair_begin(), moab::Range::const_pair_end(), moab::CREATE_HANDLE(), moab::TypeSequenceManager::erase(), ErrorCode, MB_SUCCESS, split, moab::TYPE_FROM_HANDLE(), and typeData.
    ErrorCode rval = check_valid_entities( NULL, entities );
    ErrorCode result = MB_SUCCESS;
            rval = typeData[type1].erase( NULL, i->first, i->second );
            if( MB_SUCCESS != rval ) return result = rval;
        else
            int junk;
            rval               = typeData[type1].erase( NULL, i->first, split - 1 );
            rval = typeData[type2].erase( NULL, split, i->second );
    return result;
Delete an entity. Deletes sequence if only contained entity.
Definition at line 133 of file SequenceManager.cpp.
References moab::TypeSequenceManager::erase(), moab::TYPE_FROM_HANDLE(), and typeData.
    return typeData[TYPE_FROM_HANDLE( entity )].erase( NULL, entity );
const TypeSequenceManager& moab::SequenceManager::entity_map ( EntityType  type) const [inline]
Get data for a specific EntityType
Definition at line 252 of file SequenceManager.hpp.
References typeData.
        return typeData[type];
ErrorCode moab::SequenceManager::find ( EntityHandle  handle,
const EntitySequence *&  sequence_out
) const [inline]
Find entity sequence containing specified handle.
Returns:
MB_SUCCESS or MB_ENTITY_NOT_FOUND
Definition at line 35 of file SequenceManager.hpp.
References moab::TypeSequenceManager::find(), moab::TYPE_FROM_HANDLE(), and typeData.
        return typeData[TYPE_FROM_HANDLE( handle )].find( handle, sequence_out );
void moab::SequenceManager::get_entities ( EntityType  type,
Range entities_out
) const [inline]
Get all entities of a given EntityType, return all entities if type == MBMAXTYPE
Definition at line 42 of file SequenceManager.hpp.
References moab::TypeSequenceManager::get_entities(), MBMAXTYPE, and typeData.
Referenced by get_entities(), and moab::VarLenDenseTag::release_all_data().
        if( type == MBMAXTYPE )
            get_entities( entities_out );
        else
            typeData[type].get_entities( entities_out );
void moab::SequenceManager::get_entities ( Range entities_out) const
Definition at line 57 of file SequenceManager.cpp.
References get_entities(), MBENTITYSET, MBVERTEX, t, and typeData.
    for( EntityType t = MBENTITYSET; t >= MBVERTEX; --t )
        typeData[t].get_entities( entities_out );
std::vector< EntityHandle > &  entities_out
) const [inline]
Definition at line 54 of file SequenceManager.hpp.
References get_entities(), moab::TypeSequenceManager::get_entities(), MBMAXTYPE, and typeData.
        else
void moab::SequenceManager::get_entities ( std::vector< EntityHandle > &  entities_out) const
Definition at line 63 of file SequenceManager.cpp.
References get_entities(), MBMAXTYPE, MBVERTEX, t, and typeData.
    for( EntityType t = MBVERTEX; t != MBMAXTYPE; ++t )
const EntitySequence* moab::SequenceManager::get_last_accessed_sequence ( EntityType  type) const [inline]
Get most recently accessed sequence for a given type
Definition at line 74 of file SequenceManager.hpp.
References moab::TypeSequenceManager::get_last_accessed(), and typeData.
        return typeData[type].get_last_accessed();
void moab::SequenceManager::get_memory_use ( unsigned long long &  total_entity_storage,
unsigned long long &  total_storage
) const
Definition at line 768 of file SequenceManager.cpp.
References MBMAXTYPE, and MBVERTEX.
    total_entity_storage = 0;
    total_storage        = 0;
    unsigned long long temp_entity, temp_total;
    for( EntityType i = MBVERTEX; i < MBMAXTYPE; ++i )
        temp_entity = temp_total = 0;
        get_memory_use( i, temp_entity, temp_total );
        total_entity_storage += temp_entity;
        total_storage += temp_total;
void moab::SequenceManager::get_memory_use ( EntityType  type,
) const
Definition at line 784 of file SequenceManager.cpp.
References moab::TypeSequenceManager::get_memory_use(), and typeData.
    typeData[type].get_memory_use( total_entity_storage, total_storage );
void moab::SequenceManager::get_memory_use ( const Range entities,
unsigned long long &  total_amortized_storage
) const
Definition at line 791 of file SequenceManager.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), moab::CREATE_HANDLE(), moab::TypeSequenceManager::get_memory_use(), MB_END_ID, MB_START_ID, moab::TYPE_FROM_HANDLE(), and typeData.
    total_amortized_storage = 0;
        const EntityType t1 = TYPE_FROM_HANDLE( i->first );
        const EntityType t2 = TYPE_FROM_HANDLE( i->second );
        if( t1 == t2 )
            typeData[t1].get_memory_use( i->first, i->second, temp_entity, temp_total );
            total_amortized_storage += temp_total;
        else
            int junk;
            typeData[t1].get_memory_use( i->first, CREATE_HANDLE( t1, MB_END_ID, junk ), temp_entity, temp_total );
            typeData[t2].get_memory_use( CREATE_HANDLE( t2, MB_START_ID, junk ), i->second, temp_entity, temp_total );
EntityID moab::SequenceManager::get_number_entities ( EntityType  type) const [inline]
Count entities of a given EntityType
Definition at line 65 of file SequenceManager.hpp.
References get_number_entities(), moab::TypeSequenceManager::get_number_entities(), MBMAXTYPE, and typeData.
        return type == MBMAXTYPE ? get_number_entities() : typeData[type].get_number_entities();
Definition at line 69 of file SequenceManager.cpp.
References MBMAXTYPE, MBVERTEX, moab::sum(), t, and typeData.
Referenced by get_number_entities().
    EntityID sum = 0;
        sum += typeData[t].get_number_entities();
    return sum;
Definition at line 296 of file SequenceManager.hpp.
References sequence_multiplier.
        return sequence_multiplier;
EntityID moab::SequenceManager::new_sequence_size ( EntityHandle  start_handle,
int  sequence_size
) const
Definition at line 430 of file SequenceManager.cpp.
References moab::TypeSequenceManager::last_free_handle(), sequence_multiplier, moab::TYPE_FROM_HANDLE(), and typeData.
Referenced by create_entity_sequence().
    requested_size = (EntityID)( this->sequence_multiplier * requested_size );
    if( sequence_size < (int)requested_size ) return requested_size;
    EntityHandle last = typeData[TYPE_FROM_HANDLE( start )].last_free_handle( start );
    if( !last )
        assert( false );
        return 0;
    EntityID available_size = last - start + 1;
    if( sequence_size < available_size )
        return sequence_size;
    else
        return available_size;
ErrorCode moab::SequenceManager::release_tag_array ( Error error_handler,
int  id,
bool  release_id
Release any storage assocociated with a tag ID, and optionally, release the reserved tag ID.
Definition at line 849 of file SequenceManager.cpp.
References moab::TypeSequenceManager::begin(), moab::TypeSequenceManager::end(), entity_map(), MB_SUCCESS, MB_TAG_NOT_FOUND, MBENTITYSET, MBVERTEX, t, tagSizes, and moab::UNUSED_SIZE.
Referenced by moab::DenseTag::release_all_data(), moab::VarLenDenseTag::release_all_data(), and ~SequenceManager().
    if( (unsigned)index >= tagSizes.size() || UNUSED_SIZE == tagSizes[index] )
        // MB_TAG_NOT_FOUND could be a non-error condition, do not call MB_SET_ERR on it
#if 0
    fprintf(stderr, "[Warning]: Invalid dense tag index: %d\n", index);
#endif
        return MB_TAG_NOT_FOUND;
    for( EntityType t = MBVERTEX; t <= MBENTITYSET; ++t )
        TypeSequenceManager& seqs = entity_map( t );
        for( TypeSequenceManager::iterator i = seqs.begin(); i != seqs.end(); ++i )
            ( *i )->data()->release_tag_data( index, tagSizes[index] );
    if( release_id ) tagSizes[index] = UNUSED_SIZE;
    return MB_SUCCESS;
Used for converting number of nodes for fixed-connectivity-length elements. Input sequence must be a non-strict subset of an existing sequence. Existing sequence will be removed, modified, or split into two prevent it from overlapping the new sequence.
Definition at line 762 of file SequenceManager.cpp.
References moab::TypeSequenceManager::replace_subsequence(), moab::EntitySequence::start_handle(), tagSizes, moab::TYPE_FROM_HANDLE(), and typeData.
Referenced by moab::HigherOrderFactory::convert_sequence().
    const EntityType type = TYPE_FROM_HANDLE( new_seq->start_handle() );
    return typeData[type].replace_subsequence( new_seq, &tagSizes[0], tagSizes.size() );
ErrorCode moab::SequenceManager::reserve_tag_array ( Error error_handler,
int  tag_size,
int &  array_id_out
Allocate a tag ID
Parameters:
tag_sizeThe size of the tag value for each entity
Definition at line 827 of file SequenceManager.cpp.
References find(), MB_INVALID_SIZE, MB_SET_ERR, MB_SUCCESS, MB_VARIABLE_LENGTH, size, tagSizes, and moab::UNUSED_SIZE.
Referenced by moab::DenseTag::create_tag(), and moab::VarLenDenseTag::create_tag().
    if( size < 1 && size != MB_VARIABLE_LENGTH )
        MB_SET_ERR( MB_INVALID_SIZE, "Invalid tag size: " << size );
    std::vector< int >::iterator i = std::find( tagSizes.begin(), tagSizes.end(), UNUSED_SIZE );
    if( i == tagSizes.end() )
        index = tagSizes.size();
        tagSizes.push_back( size );
    else
        index = i - tagSizes.begin();
        *i    = size;
    return MB_SUCCESS;
EntityHandle moab::SequenceManager::sequence_start_handle ( EntityType  type,
SequenceData *&  data_out,
EntityID data_size
) [private]
Get range of handles in whcih to place a new entity sequence.
Parameters:
typeThe EntityType for the contents of the sequence
entity_countThe number of entities in the range
values_per_entityVertices per element, zero for other types
start_id_hintPreferred id of first handle
processor_rankMPI processor ID
data_outOutput: Either NULL or an existing SequenceData with a sufficiently large block to accomodate the handle range.
Returns:
zero if no available handle range, start handle otherwise.
Definition at line 410 of file SequenceManager.cpp.
References moab::CREATE_HANDLE(), moab::TypeSequenceManager::find_free_sequence(), moab::TypeSequenceManager::is_free_sequence(), MB_END_ID, MB_START_ID, and typeData.
Referenced by create_entity_sequence(), create_meshset_sequence(), create_scd_sequence(), and create_sweep_sequence().
    TypeSequenceManager& tsm = typeData[type];
    data                     = 0;
    EntityHandle handle      = CREATE_HANDLE( type, start );
    if( start < MB_START_ID || !tsm.is_free_sequence( handle, count, data, size ) )
        EntityHandle pstart = CREATE_HANDLE( type, MB_START_ID );
        EntityHandle pend   = CREATE_HANDLE( type, MB_END_ID );
        handle              = tsm.find_free_sequence( count, pstart, pend, data, data_size, size );
    return handle;
void moab::SequenceManager::set_sequence_multiplier ( double  factor) [inline]
Parameters:
meshsetUser specified multiplier (should be greater than 1.0)
Definition at line 310 of file SequenceManager.hpp.
        sequence_multiplier = factor;
void moab::SequenceManager::trim_sequence_block ( EntityHandle  start_handle,
EntityHandle end_handle_in_out,
) [private]
Given a block of available handles, determine the non-strict subset at which to create a new EntitySequence.
Definition at line 401 of file SequenceManager.cpp.
Referenced by allocate_mesh_set().
    assert( end_handle >= start_handle );
    assert( (int)max_size > 0 );  // Cast to int also prohibits some ridiculously large values
    // If input range is larger than preferred size, trim it
    if( end_handle - start_handle >= max_size ) end_handle = start_handle + max_size - 1;
Member Data Documentation
Definition at line 319 of file SequenceManager.hpp.
Referenced by create_element(), and moab::Tqdcfr::read_elements().
Definition at line 325 of file SequenceManager.hpp.
Referenced by allocate_mesh_set(), and create_mesh_set().
Definition at line 322 of file SequenceManager.hpp.
Referenced by default_poly_sequence_size().
Definition at line 316 of file SequenceManager.hpp.
Referenced by create_vertex(), and moab::Tqdcfr::read_nodes().
Definition at line 362 of file SequenceManager.hpp.
Referenced by clear(), get_sequence_multiplier(), new_sequence_size(), and set_sequence_multiplier().
std::vector< int > moab::SequenceManager::tagSizes [private]
List of all members.
