DenseTag.cpp
00001 /** \file   DenseTag.cpp
00002  *  \author Jason Kraftcheck
00003  *  \date   2010-12-14
00004  */
00005
00006 #include "DenseTag.hpp"
00007 #include "moab/Range.hpp"
00008 #include "TagCompare.hpp"
00009 #include "SysUtil.hpp"
00010 #include "SequenceManager.hpp"
00011 #include "SequenceData.hpp"
00012 #include "moab/Error.hpp"
00013 #include "moab/ErrorHandler.hpp"
00014 #include "moab/CN.hpp"
00015 #include <utility>
00016
00017 namespace moab
00018 {
00019
00020 inline static ErrorCode not_found( const std::string& /*name*/, EntityHandle /*h*/ )
00021 {
00022     // MB_TAG_NOT_FOUND could be a non-error condition, do not call MB_SET_ERR on it
00023 #if 0
00024   if (h)
00025     fprintf(stderr, "[Warning]: No dense tag %s value for %s %ld\n",
00026         name.c_str(),
00027         CN::EntityTypeName(TYPE_FROM_HANDLE(h)),
00028         (unsigned long)ID_FROM_HANDLE(h));
00029   else
00030     fprintf(stderr, "[Warning]: No dense tag %s value for root set\n", name.c_str());
00031 #endif
00032
00033     return MB_TAG_NOT_FOUND;
00034 }
00035
00036 inline static ErrorCode ent_not_found( const std::string& /*name*/, EntityHandle /*h*/ )
00037 {
00038     // MB_ENTITY_NOT_FOUND could be a non-error condition, do not call MB_SET_ERR on it
00039 #if 0
00040   fprintf(
00041       stderr,
00042       "[Warning]: Invalid entity handle setting tag %s: %s %ld\n",
00043       name.c_str(),
00044       CN::EntityTypeName(TYPE_FROM_HANDLE(h)),
00045       (unsigned long)ID_FROM_HANDLE(h)
00046       );
00047 #endif
00048
00049     return MB_ENTITY_NOT_FOUND;
00050 }
00051
00052 DenseTag::DenseTag( int index, const char* name, int size, DataType type, const void* default_value )
00053     : TagInfo( name, size, type, default_value, size ), mySequenceArray( index ), meshValue( 0 )
00054 {
00055 }
00056
00057 TagType DenseTag::get_storage_type() const
00058 {
00059     return MB_TAG_DENSE;
00060 }
00061
00062 DenseTag* DenseTag::create_tag( SequenceManager* seqman,
00063                                 Error* /* error */,
00064                                 const char* name,
00065                                 int bytes,
00066                                 DataType type,
00067                                 const void* default_value )
00068 {
00069     if( bytes < 1 ) return 0;
00070
00071     int index;
00072     if( MB_SUCCESS != seqman->reserve_tag_array( NULL, bytes, index ) ) return 0;
00073
00074     return new DenseTag( index, name, bytes, type, default_value );
00075 }
00076
00077 DenseTag::~DenseTag()
00078 {
00079     assert( mySequenceArray < 0 );
00080     delete[] meshValue;
00081 }
00082
00083 ErrorCode DenseTag::release_all_data( SequenceManager* seqman, Error* /* error */, bool delete_pending )
00084 {
00085     ErrorCode result = seqman->release_tag_array( NULL, mySequenceArray, delete_pending );
00086     if( MB_SUCCESS == result && delete_pending ) mySequenceArray = -1;
00087     return result;
00088 }
00089
00090 ErrorCode DenseTag::get_array( const SequenceManager* seqman,
00091                                Error* /* error */,
00092                                EntityHandle h,
00093                                const unsigned char* const& ptr,
00094                                size_t& count ) const
00095 {
00096     //  cast away the const-ness; do we really want to do this?
00097     // probably we are not calling this anywhere;
00098     // clang compiler found this
00099     return get_array_private( seqman, NULL, h, const_cast< const unsigned char*& >( ptr ), count );
00100 }
00101
00102 ErrorCode DenseTag::get_array_private( const SequenceManager* seqman,
00103                                        Error* /* error */,
00104                                        EntityHandle h,
00105                                        const unsigned char*& ptr,
00106                                        size_t& count ) const
00107 {
00108     const EntitySequence* seq = 0;
00109     ErrorCode rval            = seqman->find( h, seq );
00110     if( MB_SUCCESS != rval )
00111     {
00112         if( !h )
00113         {  // Root set
00114             ptr   = meshValue;
00115             count = 1;
00116             return MB_SUCCESS;
00117         }
00118         else
00119         {  // Not root set
00120             ptr   = 0;
00121             count = 0;
00122             return ent_not_found( get_name(), h );
00123         }
00124     }
00125
00126     const void* mem = seq->data()->get_tag_data( mySequenceArray );
00127     ptr             = reinterpret_cast< const unsigned char* >( mem );
00128     count           = seq->data()->end_handle() - h + 1;
00129     if( ptr ) ptr += get_size() * ( h - seq->data()->start_handle() );
00130
00131     return MB_SUCCESS;
00132 }
00133
00134 ErrorCode DenseTag::get_array( const EntitySequence* seq, const unsigned char* const& ptr ) const
00135 {
00136     // cast away the constness; otherwise it would be infinite recursion
00137     // probably we are not calling this anywhere
00138     return get_array_private( seq, const_cast< const unsigned char*& >( ptr ) );
00139 }
00140
00141 ErrorCode DenseTag::get_array_private( const EntitySequence* seq, const unsigned char*& ptr ) const
00142 {
00143     ptr = reinterpret_cast< const unsigned char* >( seq->data()->get_tag_data( mySequenceArray ) );
00144     if( ptr ) ptr += get_size() * ( seq->start_handle() - seq->data()->start_handle() );
00145
00146     return MB_SUCCESS;
00147 }
00148
00149 ErrorCode DenseTag::get_array_private( SequenceManager* seqman,
00150                                        Error* /* error */,
00151                                        EntityHandle h,
00152                                        unsigned char*& ptr,
00153                                        size_t& count,
00154                                        bool allocate )
00155 {
00156     EntitySequence* seq = 0;
00157     ErrorCode rval      = seqman->find( h, seq );
00158     if( MB_SUCCESS != rval )
00159     {
00160         if( !h )
00161         {  // Root set
00162             if( !meshValue && allocate ) meshValue = new unsigned char[get_size()];
00163             ptr   = meshValue;
00164             count = 1;
00165             return MB_SUCCESS;
00166         }
00167         else
00168         {  // Not root set
00169             ptr   = 0;
00170             count = 0;
00171             return ent_not_found( get_name(), h );
00172         }
00173     }
00174
00175     void* mem = seq->data()->get_tag_data( mySequenceArray );
00176     if( !mem && allocate )
00177     {
00178         mem = seq->data()->allocate_tag_array( mySequenceArray, get_size(), get_default_value() );
00179         if( !mem )
00180         {
00181             MB_SET_ERR( MB_MEMORY_ALLOCATION_FAILED, "Memory allocation for dense tag data failed" );
00182         }
00183
00184         if( !get_default_value() ) memset( mem, 0, get_size() * seq->data()->size() );
00185     }
00186
00187     ptr   = reinterpret_cast< unsigned char* >( mem );
00188     count = seq->data()->end_handle() - h + 1;
00189     if( ptr ) ptr += get_size() * ( h - seq->data()->start_handle() );
00190     return MB_SUCCESS;
00191 }
00192
00193 ErrorCode DenseTag::get_data( const SequenceManager* seqman,
00194                               Error* /* error */,
00195                               const EntityHandle* entities,
00196                               size_t num_entities,
00197                               void* adata ) const
00198 {
00199     size_t junk                   = 0;
00200     unsigned char* ptr            = reinterpret_cast< unsigned char* >( adata );
00201     const EntityHandle* const end = entities + num_entities;
00202     for( const EntityHandle* i = entities; i != end; ++i, ptr += get_size() )
00203     {
00204         const unsigned char* data = 0;
00205         ErrorCode rval            = get_array( seqman, NULL, *i, data, junk );MB_CHK_ERR( rval );
00206
00207         if( data )
00208             memcpy( ptr, data, get_size() );
00209         else if( get_default_value() )
00210             memcpy( ptr, get_default_value(), get_size() );
00211         else
00212             return not_found( get_name(), *i );
00213     }
00214
00215     return MB_SUCCESS;
00216 }
00217
00218 ErrorCode DenseTag::get_data( const SequenceManager* seqman,
00219                               Error* /* error */,
00220                               const Range& entities,
00221                               void* values ) const
00222 {
00223     ErrorCode rval;
00224     size_t avail               = 0;
00225     const unsigned char* array = NULL;  // Initialize to get rid of warning
00226     unsigned char* data        = reinterpret_cast< unsigned char* >( values );
00227
00228     for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p )
00229     {
00230         EntityHandle start = p->first;
00231         while( start <= p->second )
00232         {
00233             rval = get_array( seqman, NULL, start, array, avail );MB_CHK_ERR( rval );
00234
00235             const size_t count = std::min< size_t >( p->second - start + 1, avail );
00236             if( array )
00237                 memcpy( data, array, get_size() * count );
00238             else if( get_default_value() )
00239                 SysUtil::setmem( data, get_default_value(), get_size(), count );
00240             else
00241                 return not_found( get_name(), start );
00242
00243             data += get_size() * count;
00244             start += count;
00245         }
00246     }
00247
00248     return MB_SUCCESS;
00249 }
00250
00251 ErrorCode DenseTag::get_data( const SequenceManager* seqman,
00252                               Error* /* error */,
00253                               const EntityHandle* entities,
00254                               size_t num_entities,
00255                               const void** pointers,
00256                               int* data_lengths ) const
00257 {
00258     ErrorCode result;
00259     const EntityHandle* const end = entities + num_entities;
00260     size_t junk                   = 0;
00261     const unsigned char* ptr      = NULL;  // Initialize to get rid of warning
00262
00263     if( data_lengths )
00264     {
00265         const int len = get_size();
00266         SysUtil::setmem( data_lengths, &len, sizeof( int ), num_entities );
00267     }
00268
00269     for( const EntityHandle* i = entities; i != end; ++i, ++pointers )
00270     {
00271         result = get_array( seqman, NULL, *i, ptr, junk );MB_CHK_ERR( result );
00272
00273         if( ptr )
00274             *pointers = ptr;
00275         else if( get_default_value() )
00276             *pointers = get_default_value();
00277         else
00278             return not_found( get_name(), *i );
00279     }
00280
00281     return MB_SUCCESS;
00282 }
00283
00284 ErrorCode DenseTag::get_data( const SequenceManager* seqman,
00285                               Error* /* error */,
00286                               const Range& entities,
00287                               const void** pointers,
00288                               int* data_lengths ) const
00289 {
00290     ErrorCode rval;
00291     size_t avail               = 0;
00292     const unsigned char* array = NULL;
00293
00294     if( data_lengths )
00295     {
00296         int len = get_size();
00297         SysUtil::setmem( data_lengths, &len, sizeof( int ), entities.size() );
00298     }
00299
00300     for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p )
00301     {
00302         EntityHandle start = p->first;
00303         while( start <= p->second )
00304         {
00305             rval = get_array( seqman, NULL, start, array, avail );MB_CHK_ERR( rval );
00306
00307             const size_t count = std::min< size_t >( p->second - start + 1, avail );
00308             if( array )
00309             {
00310                 for( EntityHandle end = start + count; start != end; ++start )
00311                 {
00312                     *pointers = array;
00313                     array += get_size();
00314                     ++pointers;
00315                 }
00316             }
00317             else if( const void* val = get_default_value() )
00318             {
00319                 SysUtil::setmem( pointers, &val, sizeof( void* ), count );
00320                 pointers += count;
00321                 start += count;
00322             }
00323             else
00324             {
00325                 return not_found( get_name(), start );
00326             }
00327         }
00328     }
00329
00330     return MB_SUCCESS;
00331 }
00332
00333 ErrorCode DenseTag::set_data( SequenceManager* seqman,
00334                               Error* /* error */,
00335                               const EntityHandle* entities,
00336                               size_t num_entities,
00337                               const void* data )
00338 {
00339     ErrorCode rval;
00340     const unsigned char* ptr      = reinterpret_cast< const unsigned char* >( data );
00341     const EntityHandle* const end = entities + num_entities;
00342     unsigned char* array          = NULL;
00343     size_t junk                   = 0;
00344
00345     for( const EntityHandle* i = entities; i != end; ++i, ptr += get_size() )
00346     {
00347         rval = get_array_private( seqman, NULL, *i, array, junk, true );MB_CHK_ERR( rval );
00348
00349         memcpy( array, ptr, get_size() );
00350     }
00351
00352     return MB_SUCCESS;
00353 }
00354
00355 ErrorCode DenseTag::set_data( SequenceManager* seqman, Error* /* error */, const Range& entities, const void* values )
00356 {
00357     ErrorCode rval;
00358     const char* data     = reinterpret_cast< const char* >( values );
00359     unsigned char* array = NULL;
00360     size_t avail         = 0;
00361
00362     for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p )
00363     {
00364         EntityHandle start = p->first;
00365         while( start <= p->second )
00366         {
00367             rval = get_array_private( seqman, NULL, start, array, avail, true );MB_CHK_ERR( rval );
00368
00369             const size_t count = std::min< size_t >( p->second - start + 1, avail );
00370             memcpy( array, data, get_size() * count );
00371             data += get_size() * count;
00372             start += count;
00373         }
00374     }
00375
00376     return MB_SUCCESS;
00377 }
00378
00379 ErrorCode DenseTag::set_data( SequenceManager* seqman,
00380                               Error* /* error */,
00381                               const EntityHandle* entities,
00382                               size_t num_entities,
00383                               void const* const* pointers,
00384                               const int* data_lengths )
00385 {
00386     ErrorCode rval = validate_lengths( NULL, data_lengths, num_entities );MB_CHK_ERR( rval );
00387
00388     const EntityHandle* const end = entities + num_entities;
00389     unsigned char* array          = NULL;
00390     size_t junk                   = 0;
00391
00392     for( const EntityHandle* i = entities; i != end; ++i, ++pointers )
00393     {
00394         rval = get_array_private( seqman, NULL, *i, array, junk, true );MB_CHK_ERR( rval );
00395
00396         memcpy( array, *pointers, get_size() );
00397     }
00398
00399     return MB_SUCCESS;
00400 }
00401
00402 ErrorCode DenseTag::set_data( SequenceManager* seqman,
00403                               Error* /* error */,
00404                               const Range& entities,
00405                               void const* const* pointers,
00406                               const int* /* data_lengths */ )
00407 {
00408     ErrorCode rval;
00409     unsigned char* array = NULL;
00410     size_t avail         = 0;
00411
00412     for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p )
00413     {
00414         EntityHandle start = p->first;
00415         while( start <= p->second )
00416         {
00417             rval = get_array_private( seqman, NULL, start, array, avail, true );MB_CHK_ERR( rval );
00418
00419             const EntityHandle end = std::min< EntityHandle >( p->second + 1, start + avail );
00420             while( start != end )
00421             {
00422                 memcpy( array, *pointers, get_size() );
00423                 ++start;
00424                 ++pointers;
00425                 array += get_size();
00426             }
00427         }
00428     }
00429
00430     return MB_SUCCESS;
00431 }
00432
00433 ErrorCode DenseTag::clear_data( bool allocate,
00434                                 SequenceManager* seqman,
00435                                 Error* /* error */,
00436                                 const EntityHandle* entities,
00437                                 size_t num_entities,
00438                                 const void* value_ptr )
00439 {
00440     ErrorCode rval;
00441     const EntityHandle* const end = entities + num_entities;
00442     unsigned char* array          = NULL;
00443     size_t junk                   = 0;
00444
00445     for( const EntityHandle* i = entities; i != end; ++i )
00446     {
00447         rval = get_array_private( seqman, NULL, *i, array, junk, allocate );MB_CHK_ERR( rval );
00448
00449         if( array )  // Array should never be null if allocate == true
00450             memcpy( array, value_ptr, get_size() );
00451     }
00452
00453     return MB_SUCCESS;
00454 }
00455
00456 ErrorCode DenseTag::clear_data( bool allocate,
00457                                 SequenceManager* seqman,
00458                                 Error* /* error */,
00459                                 const Range& entities,
00460                                 const void* value_ptr )
00461 {
00462     ErrorCode rval;
00463     unsigned char* array = NULL;
00464     size_t avail         = 0;
00465
00466     for( Range::const_pair_iterator p = entities.const_pair_begin(); p != entities.const_pair_end(); ++p )
00467     {
00468         EntityHandle start = p->first;
00469         while( start <= p->second )
00470         {
00471             rval = get_array_private( seqman, NULL, start, array, avail, allocate );MB_CHK_ERR( rval );
00472
00473             const size_t count = std::min< size_t >( p->second - start + 1, avail );
00474             if( array )  // Array should never be null if allocate == true
00475                 SysUtil::setmem( array, value_ptr, get_size(), count );
00476             start += count;
00477         }
00478     }
00479
00480     return MB_SUCCESS;
00481 }
00482
00483 ErrorCode DenseTag::clear_data( SequenceManager* seqman,
00484                                 Error* /* error */,
00485                                 const EntityHandle* entities,
00486                                 size_t num_entities,
00487                                 const void* value_ptr,
00488                                 int value_len )
00489 {
00490     if( value_len && value_len != get_size() ) return MB_INVALID_SIZE;
00491
00492     return clear_data( true, seqman, NULL, entities, num_entities, value_ptr );
00493 }
00494
00495 ErrorCode DenseTag::clear_data( SequenceManager* seqman,
00496                                 Error* /* error */,
00497                                 const Range& entities,
00498                                 const void* value_ptr,
00499                                 int value_len )
00500 {
00501     if( value_len && value_len != get_size() ) return MB_INVALID_SIZE;
00502
00503     return clear_data( true, seqman, NULL, entities, value_ptr );
00504 }
00505
00506 ErrorCode DenseTag::remove_data( SequenceManager* seqman,
00507                                  Error* /* error */,
00508                                  const EntityHandle* entities,
00509                                  size_t num_entities )
00510 {
00511     std::vector< unsigned char > zeros;
00512     const void* value = get_default_value();
00513     if( !value )
00514     {
00515         zeros.resize( get_size(), 0 );
00516         value = &zeros[0];
00517     }
00518
00519     return clear_data( false, seqman, NULL, entities, num_entities, value );
00520 }
00521
00522 ErrorCode DenseTag::remove_data( SequenceManager* seqman, Error* /* error */, const Range& entities )
00523 {
00524     std::vector< unsigned char > zeros;
00525     const void* value = get_default_value();
00526     if( !value )
00527     {
00528         zeros.resize( get_size(), 0 );
00529         value = &zeros[0];
00530     }
00531
00532     return clear_data( false, seqman, NULL, entities, value );
00533 }
00534
00535 ErrorCode DenseTag::tag_iterate( SequenceManager* seqman,
00536                                  Error* /* error */,
00537                                  Range::iterator& iter,
00538                                  const Range::iterator& end,
00539                                  void*& data_ptr,
00540                                  bool allocate )
00541 {
00542     // If asked for nothing, successfully return nothing.
00543     if( iter == end ) return MB_SUCCESS;
00544
00545     unsigned char* array = NULL;
00546     size_t avail         = 0;
00547     ErrorCode rval       = get_array_private( seqman, NULL, *iter, array, avail, allocate );MB_CHK_ERR( rval );
00548     data_ptr = array;
00549
00550     size_t count = std::min< size_t >( avail, *( iter.end_of_block() ) - *iter + 1 );
00551     if( 0 != *end && *end <= *( iter.end_of_block() ) )
00552         iter = end;
00553     else
00554         iter += count;
00555
00556     return MB_SUCCESS;
00557 }
00558
00559 ErrorCode DenseTag::get_tagged_entities( const SequenceManager* seqman,
00560                                          Range& entities_in,
00561                                          EntityType type,
00562                                          const Range* intersect_list ) const
00563 {
00564     Range tmp;
00565     Range* entities                           = intersect_list ? &tmp : &entities_in;
00566     Range::iterator hint                      = entities->begin();
00567     std::pair< EntityType, EntityType > range = type_range( type );
00568     TypeSequenceManager::const_iterator i;
00569     for( EntityType t = range.first; t != range.second; ++t )
00570     {
00571         const TypeSequenceManager& map = seqman->entity_map( t );
00572         for( i = map.begin(); i != map.end(); ++i )
00573             if( ( *i )->data()->get_tag_data( mySequenceArray ) )
00574                 hint = entities->insert( hint, ( *i )->start_handle(), ( *i )->end_handle() );
00575     }
00576
00577     if( intersect_list ) entities_in = intersect( *entities, *intersect_list );
00578
00579     return MB_SUCCESS;
00580 }
00581
00582 ErrorCode DenseTag::num_tagged_entities( const SequenceManager* seqman,
00583                                          size_t& output_count,
00584                                          EntityType type,
00585                                          const Range* intersect ) const
00586 {
00587     Range tmp;
00588     ErrorCode rval = get_tagged_entities( seqman, tmp, type, intersect );
00589     output_count += tmp.size();
00590
00591     return rval;
00592 }
00593
00594 ErrorCode DenseTag::find_entities_with_value( const SequenceManager* seqman,
00595                                               Error* /* error */,
00596                                               Range& output_entities,
00597                                               const void* value,
00598                                               int value_bytes,
00599                                               EntityType type,
00600                                               const Range* intersect_entities ) const
00601 {
00602     if( value_bytes && value_bytes != get_size() )
00603     {
00604         MB_SET_ERR( MB_INVALID_SIZE,
00605                     "Cannot compare data of size " << value_bytes << " with tag of size " << get_size() );
00606     }
00607
00608     if( !intersect_entities )
00609     {
00610         std::pair< EntityType, EntityType > range = type_range( type );
00611         TypeSequenceManager::const_iterator i;
00612         for( EntityType t = range.first; t != range.second; ++t )
00613         {
00614             const TypeSequenceManager& map = seqman->entity_map( t );
00615             for( i = map.begin(); i != map.end(); ++i )
00616             {
00617                 const void* data = ( *i )->data()->get_tag_data( mySequenceArray );
00618                 if( data )
00619                 {
00620                     ByteArrayIterator start( ( *i )->data()->start_handle(), data, *this );
00621                     ByteArrayIterator end( ( *i )->end_handle() + 1, 0, 0 );
00622                     start += ( *i )->start_handle() - ( *i )->data()->start_handle();
00623                     find_tag_values_equal( *this, value, get_size(), start, end, output_entities );
00624                 }
00625             }
00626         }
00627     }
00628     else
00629     {
00630         const unsigned char* array = NULL;  // Initialize to get rid of warning
00631         size_t count;
00632         ErrorCode rval;
00633
00634         Range::const_pair_iterator p = intersect_entities->begin();
00635         if( type != MBMAXTYPE )
00636         {
00637             p = intersect_entities->lower_bound( type );
00638             assert( TYPE_FROM_HANDLE( p->first ) == type );
00639         }
00640         for( ;
00641              p != intersect_entities->const_pair_end() && ( MBMAXTYPE == type || TYPE_FROM_HANDLE( p->first ) == type );
00642              ++p )
00643         {
00644             EntityHandle start = p->first;
00645             while( start <= p->second )
00646             {
00647                 rval = get_array( seqman, NULL, start, array, count );MB_CHK_ERR( rval );
00648
00649                 if( p->second - start < count - 1 ) count = p->second - start + 1;
00650
00651                 if( array )
00652                 {
00653                     ByteArrayIterator istart( start, array, *this );
00654                     ByteArrayIterator iend( start + count, 0, 0 );
00655                     find_tag_values_equal( *this, value, get_size(), istart, iend, output_entities );
00656                 }
00657                 start += count;
00658             }
00659         }
00660     }
00661
00662     return MB_SUCCESS;
00663 }
00664
00665 bool DenseTag::is_tagged( const SequenceManager* seqman, EntityHandle h ) const
00666 {
00667     const unsigned char* ptr = NULL;  // Initialize to get rid of warning
00668     size_t count;
00669     return ( MB_SUCCESS == get_array( seqman, 0, h, ptr, count ) ) && ( NULL != ptr );
00670 }
00671
00672 ErrorCode DenseTag::get_memory_use( const SequenceManager* seqman,
00673                                     unsigned long& total,
00674                                     unsigned long& per_entity ) const
00675 {
00676     per_entity = get_size();
00677     total      = TagInfo::get_memory_use() + sizeof( *this );
00678     for( EntityType t = MBVERTEX; t <= MBENTITYSET; ++t )
00679     {
00680         const TypeSequenceManager& map = seqman->entity_map( t );
00681         const SequenceData* prev_data  = 0;
00682         for( TypeSequenceManager::const_iterator i = map.begin(); i != map.end(); ++i )
00683         {
00684             if( ( *i )->data() != prev_data && ( *i )->data()->get_tag_data( mySequenceArray ) )
00685             {
00686                 prev_data = ( *i )->data();
00687                 total += get_size() * ( *i )->data()->size();
00688             }
00689         }
00690     }
00691
00692     return MB_SUCCESS;
00693 }
00694
00695 }  // namespace moab
