WriteHDF5Parallel.cpp
00001 #undef DEBUG
00002 #undef TIME_DEBUG
00003
00004 #include <cstdarg>
00005 #include <ctime>
00006 #include <cstdlib>
00007
00008 #include <cstring>
00009 #include <cassert>
00010
00011 #include <vector>
00012 #include <set>
00013 #include <map>
00014 #include <utility>
00015 #include <iostream>
00016 #include <sstream>
00017 #include <string>
00018
00019 #include "moab/Interface.hpp"
00020 #include "Internals.hpp"
00021 #include "MBTagConventions.hpp"
00022 #include "MBParallelConventions.h"
00023 #include "moab/ParallelComm.hpp"
00024 #include "moab/CN.hpp"
00025 #include "moab/Range.hpp"
00026 #include "moab/CpuTimer.hpp"
00027
00028 #include "WriteHDF5Parallel.hpp"
00029
00030 #ifndef MOAB_HAVE_HDF5
00031 #error Attempt to compile WriteHDF5Parallel with HDF5 support disabled
00032 #endif
00033
00034 #include <H5Tpublic.h>
00035 #include <H5Ppublic.h>
00036 #include <H5FDmpi.h>
00037 #include <H5FDmpio.h>
00038
00039 #include "mhdf.h"
00040
00041 #include "IODebugTrack.hpp"
00042 #include "moab/FileOptions.hpp"
00043
00044 namespace
00045 {
00046 template < bool Condition >
00047 struct STATIC_ASSERTION;
00048 template <>
00049 struct STATIC_ASSERTION< true >
00050 {
00051 };
00052 }  // namespace
00053
00054 #define PP_CAT_( a, b ) a##b
00055 #define PP_CAT( a, b )  PP_CAT_( a, b )
00056 #define STATIC_ASSERT( Condition )                                                      \
00057     enum        \
00058     {        \
00059         PP_CAT( dummy, __LINE__ ) = sizeof( ::STATIC_ASSERTION< (bool)( Condition ) > ) \
00060     }
00061
00062 namespace moab
00063 {
00064
00065 #ifndef _WIN32  // problematic for windows
00066 // Need an MPI type that we can put handles in
00067 STATIC_ASSERT( sizeof( unsigned long ) >= sizeof( EntityHandle ) );
00068
00069 // Need an MPI type that we can put file IDs in
00070 STATIC_ASSERT( sizeof( unsigned long ) >= sizeof( WriteHDF5::wid_t ) );
00071 #endif
00072
00073 // This function doesn't do anything useful. It's just a nice
00074 // place to set a break point to determine why the reader fails.
00075 static inline ErrorCode error( ErrorCode rval )
00076 {
00077     return rval;
00078 }
00079
00080 const char* mpi_err_str( int errorcode )
00081 {
00082     static char buffer[2048];
00083     int len = sizeof( buffer );
00084     MPI_Error_string( errorcode, buffer, &len );
00085     buffer[std::min( (size_t)len, sizeof( buffer ) - 1 )] = '\0';
00086     return buffer;
00087 }
00088
00089 #define MPI_FAILURE_MSG( A ) \
00090     "MPI Failure at " __FILE__ ":%d : (Code %d) %s\n", __LINE__, (int)( A ), mpi_err_str( ( A ) )
00091
00092 #define CHECK_MPI( A )        \
00093     do        \
00094     {        \
00095         if( MPI_SUCCESS != ( A ) )        \
00096         {        \
00097             MB_SET_ERR_CONT( "MPI Failure : (Code " << (int)( A ) << ") " << mpi_err_str( ( A ) ) ); \
00098             dbgOut.printf( 1, MPI_FAILURE_MSG( ( A ) ) );                                            \
00099             return error( MB_FAILURE );                                                              \
00100         }        \
00101     } while( false )
00102
00103 #define MB_FAILURE_MSG( A ) "MOAB_Failure at " __FILE__ ":%d : %s (%d)\n", __LINE__, ErrorCodeStr[( A )], (int)( A )
00104
00105 #define CHECK_MB( A )                                                    \
00106     do        \
00107     {        \
00108         if( MB_SUCCESS != ( A ) )                                        \
00109         {        \
00110             MB_SET_ERR_CONT( "MOAB Failure : " << ErrorCodeStr[( A )] ); \
00111             dbgOut.printf( 1, MB_FAILURE_MSG( ( A ) ) );                 \
00112             return error( A );                                           \
00113         }        \
00114     } while( false )
00115
00116 #define HDF_FAILURE_MSG( A ) "MHDF Failure at " __FILE__ ":%d : %s\n", __LINE__, mhdf_message( &( A ) )
00117
00118 #define CHECK_HDF( A )                                                      \
00119     do        \
00120     {        \
00121         if( mhdf_isError( &( A ) ) )                                        \
00122         {        \
00123             MB_SET_ERR_CONT( "MHDF Failure : " << mhdf_message( &( A ) ) ); \
00124             dbgOut.printf( 1, HDF_FAILURE_MSG( ( A ) ) );                   \
00125             return error( MB_FAILURE );                                     \
00126         }        \
00127     } while( false )
00128
00129 #define CHECK_HDFN( A )                                                     \
00130     do        \
00131     {        \
00132         if( mhdf_isError( &( A ) ) )                                        \
00133         {        \
00134             MB_SET_ERR_CONT( "MHDF Failure : " << mhdf_message( &( A ) ) ); \
00135             return error( MB_FAILURE );                                     \
00136         }        \
00137     } while( false )
00138
00139 #ifdef VALGRIND
00140 #include <valgrind/memcheck.h>
00141
00142 template < typename T >
00143 inline void VALGRIND_MAKE_VEC_UNDEFINED( std::vector< T >& v )
00144 {
00145     if( v.size() )
00146     {
00147     }
00148     (void)VALGRIND_MAKE_MEM_UNDEFINED( &v[0], v.size() * sizeof( T ) );
00149 }
00150
00151 #else
00152 #ifndef VALGRIND_CHECK_MEM_IS_DEFINED
00153 #define VALGRIND_CHECK_MEM_IS_DEFINED( a, b ) ( (void)0 )
00154 #endif
00155 #ifndef VALGRIND_CHECK_MEM_IS_ADDRESSABLE
00156 #define VALGRIND_CHECK_MEM_IS_ADDRESSABLE( a, b ) ( (void)0 )
00157 #endif
00158 #ifndef VALGRIND_MAKE_MEM_UNDEFINED
00159 #define VALGRIND_MAKE_MEM_UNDEFINED( a, b ) ( (void)0 )
00160 #endif
00161
00162 template < typename T >
00163 inline void VALGRIND_MAKE_VEC_UNDEFINED( std::vector< T >& )
00164 {
00165     /* Nothing to do */
00166 }
00167
00168 #endif
00169
00170 #ifndef NDEBUG
00171 #define START_SERIAL                                                      \
00172     for( unsigned _x = 0; _x < myPcomm->proc_config().proc_size(); ++_x ) \
00173     {        \
00174         MPI_Barrier( myPcomm->proc_config().proc_comm() );                \
00175         if( _x != myPcomm->proc_config().proc_rank() ) continue
00176 #define END_SERIAL \
00177     }              \
00178     MPI_Barrier( myPcomm->proc_config().proc_comm() )
00179 #else
00180 #define START_SERIAL
00181 #define END_SERIAL
00182 #endif
00183
00184 static int my_Gatherv( void* sendbuf,
00185                        int sendcount,
00186                        MPI_Datatype sendtype,
00187                        std::vector< unsigned char >& recvbuf,
00188                        std::vector< int >& recvcounts,
00189                        int root,
00190                        MPI_Comm comm )
00191 {
00192     int nproc, rank, bytes, err;
00193     MPI_Comm_size( comm, &nproc );
00194     MPI_Comm_rank( comm, &rank );
00195     MPI_Type_size( sendtype, &bytes );
00196
00197     recvcounts.resize( rank == root ? nproc : 0 );
00198     err = MPI_Gather( &sendcount, 1, MPI_INT, &recvcounts[0], 1, MPI_INT, root, comm );
00199     if( MPI_SUCCESS != err ) return err;
00200
00201     std::vector< int > disp( recvcounts.size() );
00202     if( root == rank )
00203     {
00204         disp[0] = 0;
00205         for( int i = 1; i < nproc; ++i )
00206             disp[i] = disp[i - 1] + recvcounts[i - 1];
00207         recvbuf.resize( bytes * ( disp.back() + recvcounts.back() ) );
00208     }
00209
00210     return MPI_Gatherv( sendbuf, sendcount, sendtype, &recvbuf[0], &recvcounts[0], &disp[0], sendtype, root, comm );
00211 }
00212
00213 static void print_type_sets( Interface* iFace, DebugOutput* str, Range& sets )
00214 {
00215     const unsigned VB = 2;
00216     if( str->get_verbosity() < VB ) return;
00217
00218     Tag gid, did, bid, sid, nid;
00219     gid = iFace->globalId_tag();
00220     iFace->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, did );
00221     iFace->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, bid );
00222     iFace->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, nid );
00223     iFace->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, sid );
00224     Range typesets[10];
00225     const char* typenames[] = { "Block ",  "Sideset ", "NodeSet", "Vertex", "Curve",
00226                                 "Surface", "Volume",   "Body",    "Other" };
00227     for( Range::iterator riter = sets.begin(); riter != sets.end(); ++riter )
00228     {
00229         unsigned dim, id;  //, oldsize;
00230         if( MB_SUCCESS == iFace->tag_get_data( bid, &*riter, 1, &id ) )
00231             dim = 0;
00232         else if( MB_SUCCESS == iFace->tag_get_data( sid, &*riter, 1, &id ) )
00233             dim = 1;
00234         else if( MB_SUCCESS == iFace->tag_get_data( nid, &*riter, 1, &id ) )
00235             dim = 2;
00236         else if( MB_SUCCESS == iFace->tag_get_data( did, &*riter, 1, &dim ) )
00237         {
00238             id = 0;
00239             iFace->tag_get_data( gid, &*riter, 1, &id );
00240             dim += 3;
00241         }
00242         else
00243         {
00244             id  = *riter;
00245             dim = 9;
00246         }
00247
00248         // oldsize = typesets[dim].size();
00249         typesets[dim].insert( id );
00250         // assert(typesets[dim].size() - oldsize == 1);
00251     }
00252     for( int ii = 0; ii < 9; ++ii )
00253     {
00254         char tmp[64];
00255         sprintf( tmp, "%s (%lu) ", typenames[ii], (unsigned long)typesets[ii].size() );
00256         str->print( VB, tmp, typesets[ii] );
00257     }
00258     str->printf( VB, "Total: %lu\n", (unsigned long)sets.size() );
00259 }
00260
00261 #define debug_barrier() debug_barrier_line( __LINE__ )
00262
00263 void WriteHDF5Parallel::debug_barrier_line( int lineno )
00264 {
00265     const unsigned threshold   = 2;
00266     static unsigned long count = 0;
00267     if( dbgOut.get_verbosity() >= threshold && myPcomm )
00268     {
00269         dbgOut.printf( threshold, "*********** Debug Barrier %lu (@%d)***********\n", ++count, lineno );
00270         MPI_Barrier( myPcomm->proc_config().proc_comm() );
00271     }
00272 }
00273
00274 WriterIface* WriteHDF5Parallel::factory( Interface* iface )
00275 {
00276     return new WriteHDF5Parallel( iface );
00277 }
00278
00279 WriteHDF5Parallel::WriteHDF5Parallel( Interface* iface )
00280     : WriteHDF5( iface ), myPcomm( NULL ), pcommAllocated( false ), hslabOp( H5S_SELECT_OR )
00281 {
00282 }
00283
00284 WriteHDF5Parallel::~WriteHDF5Parallel()
00285 {
00286     if( pcommAllocated && myPcomm ) delete myPcomm;
00287 }
00288
00289 // The parent WriteHDF5 class has ExportSet structs that are
00290 // populated with the entities to be written, grouped by type
00291 // (and for elements, connectivity length).  This function:
00292 //  o determines which entities are to be written by a remote processor
00293 //  o removes those entities from the ExportSet structs in WriteMesh
00294 //  o passes them back in a Range
00295 ErrorCode WriteHDF5Parallel::gather_interface_meshes( Range& nonowned )
00296 {
00297     ErrorCode result;
00298
00299     // START_SERIAL;
00300     dbgOut.print( 3, "Pre-interface mesh:\n" );
00301     dbgOut.print( 3, nodeSet.range );
00302     for( std::list< ExportSet >::iterator eiter = exportList.begin(); eiter != exportList.end(); ++eiter )
00303         dbgOut.print( 3, eiter->range );
00304     dbgOut.print( 3, setSet.range );
00305
00306     // Move handles of non-owned entities from lists of entities
00307     // that this processor will write to the 'nonowned' list.
00308
00309     nonowned.clear();
00310     result = myPcomm->filter_pstatus( nodeSet.range, PSTATUS_NOT_OWNED, PSTATUS_AND, -1, &nonowned );
00311     if( MB_SUCCESS != result ) return error( result );
00312     nodeSet.range = subtract( nodeSet.range, nonowned );
00313
00314     for( std::list< ExportSet >::iterator eiter = exportList.begin(); eiter != exportList.end(); ++eiter )
00315     {
00316         Range tmpset;
00317         result = myPcomm->filter_pstatus( eiter->range, PSTATUS_NOT_OWNED, PSTATUS_AND, -1, &tmpset );
00318         if( MB_SUCCESS != result ) return error( result );
00319         eiter->range = subtract( eiter->range, tmpset );
00320         nonowned.merge( tmpset );
00321     }
00322
00323     dbgOut.print( 3, "Post-interface mesh:\n" );
00324     dbgOut.print( 3, nodeSet.range );
00325     for( std::list< ExportSet >::iterator eiter = exportList.begin(); eiter != exportList.end(); ++eiter )
00326         dbgOut.print( 3, eiter->range );
00327     dbgOut.print( 3, setSet.range );
00328
00329     // END_SERIAL;
00330
00331     return MB_SUCCESS;
00332 }
00333
00334 ErrorCode WriteHDF5Parallel::parallel_create_file( const char* filename,
00335                                                    bool overwrite,
00336                                                    const std::vector< std::string >& qa_records,
00337                                                    const FileOptions& opts,
00338                                                    const Tag* user_tag_list,
00339                                                    int user_tag_count,
00340                                                    int dimension,
00341                                                    double* times )
00342 {
00343     ErrorCode rval;
00344     mhdf_Status status;
00345
00346     int pcomm_no = 0;
00347     opts.get_int_option( "PARALLEL_COMM", pcomm_no );
00348
00349     myPcomm = ParallelComm::get_pcomm( iFace, pcomm_no );
00350     if( 0 == myPcomm )
00351     {
00352         myPcomm        = new ParallelComm( iFace, MPI_COMM_WORLD );
00353         pcommAllocated = true;
00354     }
00355
00356     MPI_Info info = MPI_INFO_NULL;
00357     std::string cb_size;
00358     rval = opts.get_str_option( "CB_BUFFER_SIZE", cb_size );
00359     if( MB_SUCCESS == rval )
00360     {
00361         MPI_Info_create( &info );
00362         MPI_Info_set( info, const_cast< char* >( "cb_buffer_size" ), const_cast< char* >( cb_size.c_str() ) );
00363     }
00364
00365     dbgOut.set_rank( myPcomm->proc_config().proc_rank() );
00366     dbgOut.limit_output_to_first_N_procs( 32 );
00367     Range nonlocal;
00368     debug_barrier();
00369     dbgOut.tprint( 1, "Gathering interface meshes\n" );
00370     rval = gather_interface_meshes( nonlocal );
00371     if( MB_SUCCESS != rval ) return error( rval );
00372
00373     /**************** Get tag names for sets likely to be shared ***********/
00374     // debug_barrier();
00375     // dbgOut.tprint(1, "Getting shared entity sets\n");
00376     // rval = get_sharedset_tags();
00377     // if (MB_SUCCESS != rval) return error(rval);
00378
00379     /**************** Create actual file and write meta info ***************/
00380
00381     debug_barrier();
00382     if( myPcomm->proc_config().proc_rank() == 0 )
00383     {
00384         dbgOut.tprintf( 1, "Creating file: %s\n", filename );
00385
00386         // Create the file
00387         const char* type_names[MBMAXTYPE];
00388         memset( type_names, 0, MBMAXTYPE * sizeof( char* ) );
00389         for( EntityType i = MBEDGE; i < MBENTITYSET; ++i )
00390             type_names[i] = CN::EntityTypeName( i );
00391
00392         dbgOut.tprint( 1, "call mhdf_createFile\n" );
00393         filePtr = mhdf_createFile( filename, overwrite, type_names, MBMAXTYPE, id_type, &status );
00394         if( !filePtr )
00395         {
00396             MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) );
00397         }
00398
00399         dbgOut.tprint( 1, "call write_qa\n" );
00400         rval = write_qa( qa_records );
00401         if( MB_SUCCESS != rval ) return error( rval );
00402     }
00403
00404     /**************** Create node coordinate table ***************/
00405     CpuTimer timer;
00406     debug_barrier();
00407     dbgOut.tprint( 1, "creating node table\n" );
00408     topState.start( "creating node table" );
00409     rval = create_node_table( dimension );
00410     topState.end( rval );
00411     if( MB_SUCCESS != rval ) return error( rval );
00412     if( times ) times[CREATE_NODE_TIME] = timer.time_elapsed();
00413
00414     /**************** Create element tables ***************/
00415
00416     debug_barrier();
00417     dbgOut.tprint( 1, "negotiating element types\n" );
00418     topState.start( "negotiating element types" );
00419     rval = negotiate_type_list();
00420     topState.end( rval );
00421     if( MB_SUCCESS != rval ) return error( rval );
00422     if( times ) times[NEGOTIATE_TYPES_TIME] = timer.time_elapsed();
00423     dbgOut.tprint( 1, "creating element table\n" );
00424     topState.start( "creating element tables" );
00425     rval = create_element_tables();
00426     topState.end( rval );
00427     if( MB_SUCCESS != rval ) return error( rval );
00428     if( times ) times[CREATE_ELEM_TIME] = timer.time_elapsed();
00429
00430     /*************** Exchange file IDs *****************/
00431
00432     debug_barrier();
00433     dbgOut.tprint( 1, "communicating file ids\n" );
00434     topState.start( "communicating file ids" );
00435     rval = exchange_file_ids( nonlocal );
00436     topState.end( rval );
00437     if( MB_SUCCESS != rval ) return error( rval );
00438     if( times ) times[FILEID_EXCHANGE_TIME] = timer.time_elapsed();
00439
00440     /**************** Create meshset tables *********************/
00441
00442     debug_barrier();
00443     dbgOut.tprint( 1, "creating meshset table\n" );
00444     topState.start( "creating meshset tables" );
00445     rval = create_meshset_tables( times );
00446     topState.end( rval );
00447     if( MB_SUCCESS != rval ) return error( rval );
00448     if( times ) times[CREATE_SET_TIME] = timer.time_elapsed();
00449
00450     /**************** Create adjacency tables *********************/
00451
00452     debug_barrier();
00453     dbgOut.tprint( 1, "creating adjacency table\n" );
00454     topState.start( "creating adjacency tables" );
00455     rval = create_adjacency_tables();
00456     topState.end( rval );
00457     if( MB_SUCCESS != rval ) return error( rval );
00458     if( times ) times[CREATE_ADJ_TIME] = timer.time_elapsed();
00459
00460     /**************** Create tag data *********************/
00461
00462     debug_barrier();
00463     dbgOut.tprint( 1, "creating tag tables\n" );
00464     topState.start( "creating tag tables" );
00465     rval = gather_tags( user_tag_list, user_tag_count );
00466     if( MB_SUCCESS != rval ) return error( rval );
00467     rval = create_tag_tables();
00468     topState.end( rval );
00469     if( MB_SUCCESS != rval ) return error( rval );
00470     if( times ) times[CREATE_TAG_TIME] = timer.time_elapsed();
00471
00472     /************** Close serial file and reopen parallel *****************/
00473
00474     if( 0 == myPcomm->proc_config().proc_rank() ) mhdf_closeFile( filePtr, &status );
00475
00476     MPI_Barrier( myPcomm->proc_config().proc_comm() );
00477     dbgOut.tprint( 1, "(re)opening file in parallel mode\n" );
00478     unsigned long junk;
00479     hid_t hdf_opt = H5Pcreate( H5P_FILE_ACCESS );
00480     H5Pset_fapl_mpio( hdf_opt, myPcomm->proc_config().proc_comm(), info );
00481     filePtr = mhdf_openFileWithOpt( filename, 1, &junk, id_type, hdf_opt, &status );
00482     H5Pclose( hdf_opt );
00483     if( !filePtr )
00484     {
00485         MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) );
00486     }
00487
00488     if( collectiveIO )
00489     {
00490         dbgOut.print( 1, "USING COLLECTIVE IO\n" );
00491         writeProp = H5Pcreate( H5P_DATASET_XFER );
00492         H5Pset_dxpl_mpio( writeProp, H5FD_MPIO_COLLECTIVE );
00493     }
00494
00495     /* Test if we can use H5S_APPEND when selecting hyperslabs */
00496     if( MB_SUCCESS != opts.get_null_option( "HYPERSLAB_OR" ) &&
00497         ( MB_SUCCESS == opts.get_null_option( "HYPERSLAB_APPEND" ) || HDF5_can_append_hyperslabs() ) )
00498     {
00499         dbgOut.print( 1, "HDF5 library supports H5Sselect_hyperlsab with H5S_SELECT_APPEND\n" );
00500         hslabOp = H5S_SELECT_APPEND;
00501     }
00502
00503     dbgOut.tprint( 1, "Exiting parallel_create_file\n" );
00504     return MB_SUCCESS;
00505 }
00506
00507 class TagNameCompare
00508 {
00509     Interface* iFace;
00510     std::string name1, name2;
00511
00512   public:
00513     TagNameCompare( Interface* iface ) : iFace( iface ) {}
00514     bool operator()( const WriteHDF5::TagDesc& t1, const WriteHDF5::TagDesc& t2 );
00515 };
00516
00517 bool TagNameCompare::operator()( const WriteHDF5::TagDesc& t1, const WriteHDF5::TagDesc& t2 )
00518 {
00519     iFace->tag_get_name( t1.tag_id, name1 );
00520     iFace->tag_get_name( t2.tag_id, name2 );
00521     return name1 < name2;
00522 }
00523
00524 struct serial_tag_data
00525 {
00526     TagType storage;
00527     DataType type;
00528     int size;
00529     int name_len;
00530     int def_val_len;
00531     char name[sizeof( unsigned long )];
00532
00533     static size_t pad( size_t len )
00534     {
00535         if( len % sizeof( unsigned long ) )
00536             return len + sizeof( unsigned long ) - len % sizeof( unsigned long );
00537         else
00538             return len;
00539     }
00540
00541     static size_t def_val_bytes( int def_val_len, DataType type )
00542     {
00543         switch( type )
00544         {
00545             case MB_TYPE_BIT:
00546                 return def_val_len ? 1 : 0;
00547             case MB_TYPE_OPAQUE:
00548                 return def_val_len;
00549             case MB_TYPE_INTEGER:
00550                 return def_val_len * sizeof( int );
00551             case MB_TYPE_DOUBLE:
00552                 return def_val_len * sizeof( double );
00553             case MB_TYPE_HANDLE:
00554                 return def_val_len * sizeof( EntityHandle );
00555         }
00556         return 0;
00557     }
00558
00559     static size_t len( int name_len, int def_val_len, DataType type )
00560     {
00561         return sizeof( serial_tag_data ) + pad( name_len + def_val_bytes( def_val_len, type ) ) -
00562                sizeof( unsigned long );
00563     }
00564     size_t len() const
00565     {
00566         return len( name_len, def_val_len, type );
00567     }
00568     void* default_value()
00569     {
00570         return def_val_len ? name + name_len : 0;
00571     }
00572     const void* default_value() const
00573     {
00574         return const_cast< serial_tag_data* >( this )->default_value();
00575     }
00576     void set_default_value( const void* val )
00577     {
00578         memcpy( default_value(), val, def_val_bytes( def_val_len, type ) );
00579     }
00580 };
00581
00582 ErrorCode WriteHDF5Parallel::append_serial_tag_data( std::vector< unsigned char >& buffer,
00583                                                      const WriteHDF5::TagDesc& tag )
00584 {
00585     ErrorCode rval;
00586
00587     std::string name;
00588     rval = iFace->tag_get_name( tag.tag_id, name );
00589     if( MB_SUCCESS != rval ) return error( rval );
00590
00591     // Get name length, including space for null char
00592     size_t name_len = name.size() + 1;
00593     if( name_len == 1 ) return MB_SUCCESS;  // Skip tags with no name
00594
00595     DataType data_type;
00596     rval = iFace->tag_get_data_type( tag.tag_id, data_type );
00597     if( MB_SUCCESS != rval ) return error( rval );
00598
00599     // Get default value
00600     int def_val_len;
00601     const void* def_val;
00602     if( MB_SUCCESS != iFace->tag_get_default_value( tag.tag_id, def_val, def_val_len ) )
00603     {
00604         def_val_len = 0;
00605         def_val     = 0;
00606     }
00607
00608     // Allocate struct within buffer
00609     size_t init_size = buffer.size();
00610     buffer.resize( init_size + serial_tag_data::len( name_len, def_val_len, data_type ) );
00611     serial_tag_data* ptr = reinterpret_cast< serial_tag_data* >( &buffer[init_size] );
00612
00613     // Populate struct
00614     rval = iFace->tag_get_type( tag.tag_id, ptr->storage );
00615     if( MB_SUCCESS != rval ) return error( rval );
00616     ptr->type = data_type;
00617     rval      = iFace->tag_get_length( tag.tag_id, ptr->size );
00618     if( MB_VARIABLE_DATA_LENGTH == rval )
00619         ptr->size = MB_VARIABLE_LENGTH;
00620     else if( MB_SUCCESS != rval )
00621         return error( rval );
00622     ptr->name_len = name_len;
00623     Range range;
00624     memset( ptr->name, 0, ptr->name_len );
00625     memcpy( ptr->name, name.data(), name.size() );
00626     ptr->def_val_len = def_val_len;
00627     ptr->set_default_value( def_val );
00628
00629     return MB_SUCCESS;
00630 }
00631
00632 ErrorCode WriteHDF5Parallel::check_serial_tag_data( const std::vector< unsigned char >& buffer,
00633                                                     std::vector< TagDesc* >* missing,
00634                                                     std::vector< TagDesc* >* newlist )
00635 {
00636     ErrorCode rval;
00637
00638     // Use 'write_sparse' field as a 'visited' mark
00639     std::list< TagDesc >::iterator tag_iter;
00640     if( missing )
00641         for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter )
00642             tag_iter->write_sparse = true;
00643
00644     // Use a set as a temporary for what will ultimately go in
00645     // newlist because we need to pass back newlist in the order
00646     // of the tagList member.
00647     std::set< TagDesc* > newset;
00648
00649     // Iterate over data from, updating the local list of tags.
00650     // Be careful to keep tagList sorted such that in the end all
00651     // procs have the same list in the same order.
00652     std::vector< unsigned char >::const_iterator diter = buffer.begin();
00653     tag_iter                                           = tagList.begin();
00654     while( diter < buffer.end() )
00655     {
00656         // Get struct from buffer
00657         const serial_tag_data* ptr = reinterpret_cast< const serial_tag_data* >( &*diter );
00658
00659         // Find local struct for tag
00660         std::string name( ptr->name );
00661         std::string n;
00662         iFace->tag_get_name( tag_iter->tag_id, n );  // Second time we've called, so shouldn't fail
00663         if( n > name )
00664         {
00665             tag_iter = tagList.begin();  // New proc, start search from beginning
00666         }
00667         iFace->tag_get_name( tag_iter->tag_id, n );
00668         while( n < name )
00669         {
00670             ++tag_iter;
00671             if( tag_iter == tagList.end() ) break;
00672             iFace->tag_get_name( tag_iter->tag_id, n );
00673         }
00674         if( tag_iter == tagList.end() || n != name )
00675         {  // New tag
00676             TagDesc newtag;
00677
00678             if( ptr->size == MB_VARIABLE_LENGTH )
00679                 rval = iFace->tag_get_handle( name.c_str(), ptr->def_val_len, ptr->type, newtag.tag_id,
00680                                               MB_TAG_VARLEN | MB_TAG_CREAT | ptr->storage, ptr->default_value() );
00681             else
00682                 rval = iFace->tag_get_handle( name.c_str(), ptr->size, ptr->type, newtag.tag_id,
00683                                               MB_TAG_CREAT | ptr->storage, ptr->default_value() );
00684             if( MB_SUCCESS != rval ) return error( rval );
00685
00686             newtag.sparse_offset   = 0;
00687             newtag.var_data_offset = 0;
00688             newtag.write_sparse    = false;
00689             newtag.max_num_ents    = 0;
00690             newtag.max_num_vals    = 0;
00691
00692             tag_iter = tagList.insert( tag_iter, newtag );
00693             if( newlist ) newset.insert( &*tag_iter );
00694         }
00695         else
00696         {  // Check that tag is as expected
00697             DataType type;
00698             iFace->tag_get_data_type( tag_iter->tag_id, type );
00699             if( type != ptr->type )
00700             {
00701                 MB_SET_ERR( MB_FAILURE, "Processes have inconsistent data type for tag \"" << name << "\"" );
00702             }
00703             int size;
00704             iFace->tag_get_length( tag_iter->tag_id, size );
00705             if( size != ptr->size )
00706             {
00707                 MB_SET_ERR( MB_FAILURE, "Processes have inconsistent size for tag \"" << name << "\"" );
00708             }
00709             tag_iter->write_sparse = false;
00710         }
00711
00712         // Step to next variable-length struct.
00713         diter += ptr->len();
00714     }
00715
00716     // Now pass back any local tags that weren't in the buffer
00717     if( missing )
00718     {
00719         for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter )
00720         {
00721             if( tag_iter->write_sparse )
00722             {
00723                 tag_iter->write_sparse = false;
00724                 missing->push_back( &*tag_iter );
00725             }
00726         }
00727     }
00728
00729     // Be careful to populate newlist in the same, sorted, order as tagList
00730     if( newlist )
00731     {
00732         for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter )
00733             if( newset.find( &*tag_iter ) != newset.end() ) newlist->push_back( &*tag_iter );
00734     }
00735
00736     return MB_SUCCESS;
00737 }
00738
00739 static void set_bit( int position, unsigned char* bytes )
00740 {
00741     int byte = position / 8;
00742     int bit  = position % 8;
00743     bytes[byte] |= ( ( (unsigned char)1 ) << bit );
00744 }
00745
00746 static bool get_bit( int position, const unsigned char* bytes )
00747 {
00748     int byte = position / 8;
00749     int bit  = position % 8;
00750     return 0 != ( bytes[byte] & ( ( (unsigned char)1 ) << bit ) );
00751 }
00752
00753 ErrorCode WriteHDF5Parallel::create_tag_tables()
00754 {
00755     std::list< TagDesc >::iterator tag_iter;
00756     ErrorCode rval;
00757     int err;
00758     const int rank      = myPcomm->proc_config().proc_rank();
00759     const MPI_Comm comm = myPcomm->proc_config().proc_comm();
00760
00761     subState.start( "negotiating tag list" );
00762
00763     dbgOut.tprint( 1, "communicating tag metadata\n" );
00764
00765     dbgOut.printf( 2, "Exchanging tag data for %d tags.\n", (int)tagList.size() );
00766
00767     // Sort tagList contents in alphabetical order by tag name
00768     tagList.sort( TagNameCompare( iFace ) );
00769
00770     // Negotiate total list of tags to write
00771
00772     // Build concatenated list of all tag data
00773     std::vector< unsigned char > tag_buffer;
00774     for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter )
00775     {
00776         rval = append_serial_tag_data( tag_buffer, *tag_iter );
00777         CHECK_MB( rval );
00778     }
00779
00780     // Broadcast list from root to all other procs
00781     unsigned long size = tag_buffer.size();
00782     err                = MPI_Bcast( &size, 1, MPI_UNSIGNED_LONG, 0, comm );
00783     CHECK_MPI( err );
00784     tag_buffer.resize( size );
00785     err = MPI_Bcast( &tag_buffer[0], size, MPI_UNSIGNED_CHAR, 0, comm );
00786     CHECK_MPI( err );
00787
00788     // Update local tag list
00789     std::vector< TagDesc* > missing;
00790     rval = check_serial_tag_data( tag_buffer, &missing, 0 );
00791     CHECK_MB( rval );
00792
00793     // Check if we're done (0->done, 1->more, 2+->error)
00794     int code, lcode = ( MB_SUCCESS != rval ) ? rval + 2 : missing.empty() ? 0 : 1;
00795     err = MPI_Allreduce( &lcode, &code, 1, MPI_INT, MPI_MAX, comm );
00796     CHECK_MPI( err );
00797     if( code > 1 )
00798     {
00799         MB_SET_ERR_CONT( "Inconsistent tag definitions between procs" );
00800         return error( (ErrorCode)( code - 2 ) );
00801     }
00802
00803     // If not done...
00804     if( code )
00805     {
00806         dbgOut.print( 1, "Not all procs had same tag definitions, negotiating...\n" );
00807
00808         // Get tags defined on this proc but not on root proc
00809         tag_buffer.clear();
00810         for( size_t i = 0; i < missing.size(); ++i )
00811         {
00812             rval = append_serial_tag_data( tag_buffer, *missing[i] );
00813             CHECK_MB( rval );
00814         }
00815
00816         // Gather extra tag definitions on root processor
00817         std::vector< int > junk;               // don't care how many from each proc
00818         assert( rank || tag_buffer.empty() );  // must be empty on root
00819         err = my_Gatherv( &tag_buffer[0], tag_buffer.size(), MPI_UNSIGNED_CHAR, tag_buffer, junk, 0, comm );
00820         CHECK_MPI( err );
00821
00822         // Process serialized tag descriptions on root, and
00823         rval = MB_SUCCESS;
00824         if( 0 == rank )
00825         {
00826             // Process serialized tag descriptions on root, and
00827             std::vector< TagDesc* > newlist;
00828             rval = check_serial_tag_data( tag_buffer, 0, &newlist );
00829             tag_buffer.clear();
00830             // re-serialize a unique list of new tag definitions
00831             for( size_t i = 0; MB_SUCCESS == rval && i != newlist.size(); ++i )
00832             {
00833                 rval = append_serial_tag_data( tag_buffer, *newlist[i] );
00834                 CHECK_MB( rval );
00835             }
00836         }
00837
00838         // Broadcast any new tag definitions from root to other procs
00839         long this_size = tag_buffer.size();
00840         if( MB_SUCCESS != rval ) this_size = -rval;
00841         err = MPI_Bcast( &this_size, 1, MPI_LONG, 0, comm );
00842         CHECK_MPI( err );
00843         if( this_size < 0 )
00844         {
00845             MB_SET_ERR_CONT( "Inconsistent tag definitions between procs" );
00846             return error( (ErrorCode)-this_size );
00847         }
00848         tag_buffer.resize( this_size );
00849         err = MPI_Bcast( &tag_buffer[0], this_size, MPI_UNSIGNED_CHAR, 0, comm );
00850         CHECK_MPI( err );
00851
00852         // Process new tag definitions
00853         rval = check_serial_tag_data( tag_buffer, 0, 0 );
00854         CHECK_MB( rval );
00855     }
00856
00857     subState.end();
00858     subState.start( "negotiate which element/tag combinations are dense" );
00859
00860     // Figure out for which tag/element combinations we can
00861     // write dense tag data.
00862
00863     // Construct a table of bits,
00864     // where each row of the table corresponds to a tag
00865     // and each column to an element group.
00866
00867     // Two extra, because first is nodes and last is sets.
00868     // (n+7)/8 is ceil(n/8)
00869     const int bytes_per_tag = ( exportList.size() + 9 ) / 8;
00870     std::vector< unsigned char > data( bytes_per_tag * tagList.size(), 0 );
00871     std::vector< unsigned char > recv( data.size(), 0 );
00872     unsigned char* iter = &data[0];
00873     if( writeTagDense && !data.empty() )
00874     {
00875         for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter, iter += bytes_per_tag )
00876         {
00877
00878             Range tagged;
00879             rval = get_sparse_tagged_entities( *tag_iter, tagged );
00880             CHECK_MB( rval );
00881
00882             int s;
00883             if( MB_VARIABLE_DATA_LENGTH == iFace->tag_get_length( tag_iter->tag_id, s ) ) continue;
00884
00885             std::string n;
00886             iFace->tag_get_name( tag_iter->tag_id,
00887                                  n );  // Second time we've called, so shouldn't fail
00888
00889             // Check if we want to write this tag in dense format even if not
00890             // all of the entities have a tag value.  The criterion of this
00891             // is that the tag be dense, have a default value, and have at
00892             // least 2/3 of the entities tagged.
00893             bool prefer_dense = false;
00894             TagType type;
00895             rval = iFace->tag_get_type( tag_iter->tag_id, type );
00896             CHECK_MB( rval );
00897             if( MB_TAG_DENSE == type )
00898             {
00899                 const void* defval = 0;
00900                 rval               = iFace->tag_get_default_value( tag_iter->tag_id, defval, s );
00901                 if( MB_SUCCESS == rval ) prefer_dense = true;
00902             }
00903
00904             int i = 0;
00905             if( check_dense_format_tag( nodeSet, tagged, prefer_dense ) )
00906             {
00907                 set_bit( i, iter );
00908                 dbgOut.printf( 2, "Can write dense data for \"%s\"/Nodes\n", n.c_str() );
00909             }
00910             std::list< ExportSet >::const_iterator ex_iter = exportList.begin();
00911             for( ++i; ex_iter != exportList.end(); ++i, ++ex_iter )
00912             {
00913                 // when writing in parallel, on some partitions, some of these element ranges might
00914                 // be empty so do not turn this tag as sparse, just because of that, leave it dense,
00915                 // if we prefer dense
00916                 if( ( prefer_dense && ex_iter->range.empty() ) ||
00917                     check_dense_format_tag( *ex_iter, tagged, prefer_dense ) )
00918                 {
00919                     set_bit( i, iter );
00920                     dbgOut.printf( 2, "Can write dense data for \"%s\"/%s\n", n.c_str(), ex_iter->name() );
00921                 }
00922             }
00923             if( check_dense_format_tag( setSet, tagged, prefer_dense ) )
00924             {
00925                 set_bit( i, iter );
00926                 dbgOut.printf( 2, "Can write dense data for \"%s\"/Sets\n", n.c_str() );
00927             }
00928         }
00929
00930         // Do bit-wise AND of list over all processors (only write dense format
00931         // if all proccesses want dense format for this group of entities).
00932         err = MPI_Allreduce( &data[0], &recv[0], data.size(), MPI_UNSIGNED_CHAR, MPI_BAND,
00933                              myPcomm->proc_config().proc_comm() );
00934         CHECK_MPI( err );
00935     }  // if (writeTagDense)
00936
00937     // Store initial counts for sparse-formatted tag data.
00938     // The total number of values to send and receive will be the number of
00939     // tags plus the number of var-len tags because we need to negotiate
00940     // offsets into two different tables for the var-len tags.
00941     std::vector< long > counts;
00942
00943     // Record dense tag/element combinations
00944     iter                       = &recv[0];
00945     const unsigned char* iter2 = &data[0];
00946     for( tag_iter = tagList.begin(); tag_iter != tagList.end();
00947          ++tag_iter, iter += bytes_per_tag, iter2 += bytes_per_tag )
00948     {
00949
00950         Range tagged;
00951         rval = get_sparse_tagged_entities( *tag_iter, tagged );
00952         CHECK_MB( rval );
00953
00954         std::string n;
00955         iFace->tag_get_name( tag_iter->tag_id, n );  // Second time we've called, so shouldn't fail
00956
00957         int i = 0;
00958         if( get_bit( i, iter ) )
00959         {
00960             assert( get_bit( i, iter2 ) );
00961             tag_iter->dense_list.push_back( nodeSet );
00962             tagged -= nodeSet.range;
00963             dbgOut.printf( 2, "Will write dense data for \"%s\"/Nodes\n", n.c_str() );
00964         }
00965         std::list< ExportSet >::const_iterator ex_iter = exportList.begin();
00966         for( ++i; ex_iter != exportList.end(); ++i, ++ex_iter )
00967         {
00968             if( get_bit( i, iter ) )
00969             {
00970                 assert( get_bit( i, iter2 ) );
00971                 tag_iter->dense_list.push_back( *ex_iter );
00972                 dbgOut.printf( 2, "WIll write dense data for \"%s\"/%s\n", n.c_str(), ex_iter->name() );
00973                 tagged -= ex_iter->range;
00974             }
00975         }
00976         if( get_bit( i, iter ) )
00977         {
00978             assert( get_bit( i, iter2 ) );
00979             tag_iter->dense_list.push_back( setSet );
00980             dbgOut.printf( 2, "Will write dense data for \"%s\"/Sets\n", n.c_str() );
00981             tagged -= setSet.range;
00982         }
00983
00984         counts.push_back( tagged.size() );
00985
00986         int s;
00987         if( MB_VARIABLE_DATA_LENGTH == iFace->tag_get_length( tag_iter->tag_id, s ) )
00988         {
00989             unsigned long data_len;
00990             rval = get_tag_data_length( *tag_iter, tagged, data_len );
00991             CHECK_MB( rval );
00992             counts.push_back( data_len );
00993         }
00994     }
00995
00996     subState.end();
00997     subState.start( "Negotiate offsets for sparse tag info" );
00998
00999     std::vector< long > offsets( counts.size() ), maxima( counts.size() ), totals( counts.size() );
01000     rval = create_dataset( counts.size(), &counts[0], &offsets[0], &maxima[0], &totals[0] );
01001     CHECK_MB( rval );
01002
01003     // Copy values into local structs and if root then create tables
01004     size_t idx = 0;
01005     for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter, ++idx )
01006     {
01007         assert( idx < counts.size() );
01008         tag_iter->sparse_offset = offsets[idx];
01009         tag_iter->max_num_ents  = maxima[idx];
01010         tag_iter->write_sparse  = ( 0 != totals[idx] );
01011         int s;
01012         if( MB_VARIABLE_DATA_LENGTH == iFace->tag_get_length( tag_iter->tag_id, s ) )
01013         {
01014             ++idx;
01015             assert( idx < counts.size() );
01016             tag_iter->var_data_offset = offsets[idx];
01017             tag_iter->max_num_vals    = maxima[idx];
01018         }
01019         else
01020         {
01021             tag_iter->var_data_offset = 0;
01022             tag_iter->max_num_vals    = 0;
01023         }
01024     }
01025
01026     subState.end();
01027
01028     // Create tag tables on root process
01029     if( 0 == myPcomm->proc_config().proc_rank() )
01030     {
01031         size_t iidx = 0;
01032         for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter, ++iidx )
01033         {
01034             assert( iidx < totals.size() );
01035             unsigned long num_ents = totals[iidx];
01036             unsigned long num_val  = 0;
01037             int s;
01038             if( MB_VARIABLE_DATA_LENGTH == iFace->tag_get_length( tag_iter->tag_id, s ) )
01039             {
01040                 ++iidx;
01041                 assert( iidx < totals.size() );
01042                 num_val = totals[iidx];
01043             }
01044             dbgOut.printf( 2, "Writing tag description for tag 0x%lx with %lu values\n",
01045                            (unsigned long)tag_iter->tag_id, num_val ? num_val : num_ents );
01046
01047             rval = create_tag( *tag_iter, num_ents, num_val );
01048             if( MB_SUCCESS != rval ) return error( rval );
01049         }
01050     }
01051
01052     if( dbgOut.get_verbosity() > 1 )
01053     {
01054         dbgOut.printf( 2, "Tags: %12s %8s %8s %8s %8s %8s\n", "Name", "Count", "Offset", "Var Off", "Max Ent",
01055                        "Handle" );
01056
01057         for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter )
01058         {
01059             std::string name;
01060             iFace->tag_get_name( tag_iter->tag_id, name );
01061             size_t this_size;
01062             get_num_sparse_tagged_entities( *tag_iter, this_size );
01063             dbgOut.printf( 2, "%18s %8lu %8lu %8lu %8lu 0x%7lx\n", name.c_str(), (unsigned long)this_size,
01064                            (unsigned long)tag_iter->sparse_offset, (unsigned long)tag_iter->var_data_offset,
01065                            (unsigned long)tag_iter->max_num_ents, (unsigned long)tag_iter->tag_id );
01066         }
01067     }
01068
01069     return MB_SUCCESS;
01070 }
01071
01072 struct DatasetVals
01073 {
01074     long start_id;
01075     long max_count;
01076     long total;
01077 };
01078 STATIC_ASSERT( ( sizeof( DatasetVals ) == 3 * sizeof( long ) ) );
01079
01080 ErrorCode WriteHDF5Parallel::create_dataset( int num_datasets,
01081                                              const long* num_owned,
01082                                              long* offsets_out,
01083                                              long* max_proc_entities,
01084                                              long* total_entities,
01085                                              const DataSetCreator& creator,
01086                                              ExportSet* groups[],
01087                                              wid_t* first_ids_out )
01088 {
01089     int result;
01090     ErrorCode rval;
01091     const unsigned rank  = myPcomm->proc_config().proc_rank();
01092     const unsigned nproc = myPcomm->proc_config().proc_size();
01093     const MPI_Comm comm  = myPcomm->proc_config().proc_comm();
01094
01095     // Gather entity counts for each processor on root
01096     std::vector< long > counts( rank ? 0 : nproc * num_datasets );
01097     (void)VALGRIND_CHECK_MEM_IS_DEFINED( &num_owned, sizeof( long ) );
01098     result = MPI_Gather( const_cast< long* >( num_owned ), num_datasets, MPI_LONG, &counts[0], num_datasets, MPI_LONG,
01099                          0, comm );
01100     CHECK_MPI( result );
01101
01102     // Create node data in file
01103     DatasetVals zero_val = { 0, 0, 0 };
01104     std::vector< DatasetVals > cumulative( num_datasets, zero_val );
01105     if( rank == 0 )
01106     {
01107         for( unsigned i = 0; i < nproc; i++ )
01108         {
01109             const long* proc_data = &counts[i * num_datasets];
01110             for( int index = 0; index < num_datasets; ++index )
01111             {
01112                 cumulative[index].total += proc_data[index];
01113                 if( proc_data[index] > cumulative[index].max_count ) cumulative[index].max_count = proc_data[index];
01114             }
01115         }
01116
01117         for( int index = 0; index < num_datasets; ++index )
01118         {
01119             if( cumulative[index].total )
01120             {
01121                 rval = creator( this, cumulative[index].total, groups ? groups[index] : 0, cumulative[index].start_id );
01122                 CHECK_MB( rval );
01123             }
01124             else
01125             {
01126                 cumulative[index].start_id = -1;
01127             }
01128         }
01129     }
01130
01131     // Send id offset to every proc
01132     result = MPI_Bcast( (void*)&cumulative[0], 3 * num_datasets, MPI_LONG, 0, comm );
01133     CHECK_MPI( result );
01134     for( int index = 0; index < num_datasets; ++index )
01135     {
01136         if( first_ids_out ) first_ids_out[index] = (wid_t)cumulative[index].start_id;
01137         max_proc_entities[index] = cumulative[index].max_count;
01138         total_entities[index]    = cumulative[index].total;
01139     }
01140
01141     // Convert array of per-process counts to per-process offsets
01142     if( rank == 0 )
01143     {
01144         // Initialize prev_size with data sizes for root process
01145         std::vector< long > prev_size( counts.begin(), counts.begin() + num_datasets );
01146         // Root process gets offset zero
01147         std::fill( counts.begin(), counts.begin() + num_datasets, 0L );
01148         // For each proc other than this one (root)
01149         for( unsigned i = 1; i < nproc; ++i )
01150         {
01151             // Get pointer to offsets for previous process in list
01152             long* prev_data = &counts[( i - 1 ) * num_datasets];
01153             // Get pointer to offsets for this process in list
01154             long* proc_data = &counts[i * num_datasets];
01155             // For each data set
01156             for( int j = 0; j < num_datasets; ++j )
01157             {
01158                 // Get size of data in dataset from process i
01159                 long mysize = proc_data[j];
01160                 // Offset for process i is offset of previous process plus
01161                 // number of values previous process will write
01162                 proc_data[j] = prev_data[j] + prev_size[j];
01163                 // Store my size, as it is no longer available in 'counts'
01164                 prev_size[j] = mysize;
01165             }
01166         }
01167     }
01168
01169     // Send each proc it's offset in the table
01170     if( rank == 0 )
01171     {
01172         (void)VALGRIND_CHECK_MEM_IS_DEFINED( &counts[0], num_datasets * nproc * sizeof( long ) );
01173     }
01174     result = MPI_Scatter( &counts[0], num_datasets, MPI_LONG, offsets_out, num_datasets, MPI_LONG, 0, comm );
01175     CHECK_MPI( result );
01176
01177     return MB_SUCCESS;
01178 }
01179
01180 ErrorCode WriteHDF5Parallel::create_node_table( int dimension )
01181 {
01182     nodeSet.num_nodes = dimension;  // Put it here so NodeSetCreator can access it
01183     struct NodeSetCreator : public DataSetCreator
01184     {
01185         ErrorCode operator()( WriteHDF5* file, long count, const ExportSet* group, long& start_id ) const
01186         {
01187             mhdf_Status status;
01188             hid_t handle = mhdf_createNodeCoords( file->file_ptr(), group->num_nodes, count, &start_id, &status );
01189             CHECK_HDFN( status );
01190             mhdf_closeData( file->file_ptr(), handle, &status );
01191             CHECK_HDFN( status );
01192             return MB_SUCCESS;
01193         }
01194     };
01195
01196     const long count   = nodeSet.range.size();
01197     ExportSet* array[] = { &nodeSet };
01198     ErrorCode rval     = create_dataset( 1, &count, &nodeSet.offset, &nodeSet.max_num_ents, &nodeSet.total_num_ents,
01199                                          NodeSetCreator(), array, &nodeSet.first_id );
01200     CHECK_MB( rval );
01201     return assign_ids( nodeSet.range, nodeSet.first_id + nodeSet.offset );
01202 }
01203
01204 struct elemtype
01205 {
01206     int mbtype;
01207     int numnode;
01208
01209     elemtype( int vals[2] ) : mbtype( vals[0] ), numnode( vals[1] ) {}
01210     elemtype( int t, int n ) : mbtype( t ), numnode( n ) {}
01211
01212     bool operator==( const elemtype& other ) const
01213     {
01214         return mbtype == other.mbtype && ( mbtype == MBENTITYSET || numnode == other.numnode );
01215     }
01216     bool operator<( const elemtype& other ) const
01217     {
01218         if( mbtype > other.mbtype ) return false;
01219
01220         return mbtype < other.mbtype || ( mbtype != MBENTITYSET && numnode < other.numnode );
01221     }
01222     bool operator!=( const elemtype& other ) const
01223     {
01224         return !this->operator==( other );
01225     }
01226 };
01227
01228 ErrorCode WriteHDF5Parallel::negotiate_type_list()
01229 {
01230     int result;
01231     const MPI_Comm comm = myPcomm->proc_config().proc_comm();
01232
01233     exportList.sort();
01234     int num_types = exportList.size();
01235
01236     // Get list of types on this processor
01237     typedef std::vector< std::pair< int, int > > typelist;
01238     typelist my_types( num_types );
01239     (void)VALGRIND_MAKE_VEC_UNDEFINED( my_types );
01240     typelist::iterator viter = my_types.begin();
01241     for( std::list< ExportSet >::iterator eiter = exportList.begin(); eiter != exportList.end(); ++eiter )
01242     {
01243         viter->first  = eiter->type;
01244         viter->second = eiter->num_nodes;
01245         ++viter;
01246     }
01247
01248     dbgOut.print( 2, "Local Element Types:\n" );
01249     for( viter = my_types.begin(); viter != my_types.end(); ++viter )
01250     {
01251         int type  = viter->first;
01252         int count = viter->second;
01253         dbgOut.printf( 2, "  %s : %d\n", CN::EntityTypeName( (EntityType)type ), count );
01254     }
01255
01256     // Broadcast number of types from root to all nodes
01257     int num_types0 = num_types;
01258     result         = MPI_Bcast( &num_types0, 1, MPI_INT, 0, comm );
01259     CHECK_MPI( result );
01260     // Broadcast type list from root to all nodes
01261     typelist root_types( num_types0 );
01262     if( 0 == myPcomm->proc_config().proc_rank() ) root_types = my_types;
01263     result = MPI_Bcast( (void*)&root_types[0], 2 * num_types0, MPI_INT, 0, comm );
01264     CHECK_MPI( result );
01265
01266     // Build local list of any types that root did not know about
01267     typelist non_root_types;
01268     viter = root_types.begin();
01269     for( typelist::iterator iter = my_types.begin(); iter != my_types.end(); ++iter )
01270     {
01271         if( viter == root_types.end() || *viter != *iter )
01272             non_root_types.push_back( *iter );
01273         else
01274             ++viter;
01275     }
01276
01277     // Determine if any process had types not defined on the root
01278     int non_root_count = non_root_types.size();
01279     int not_done;
01280     result = MPI_Allreduce( &non_root_count, &not_done, 1, MPI_INT, MPI_LOR, comm );
01281     CHECK_MPI( result );
01282     if( not_done )
01283     {
01284         // Get number of types each processor has that root does not
01285         std::vector< int > counts( myPcomm->proc_config().proc_size() );
01286         int two_count = 2 * non_root_count;
01287         result        = MPI_Gather( &two_count, 1, MPI_INT, &counts[0], 1, MPI_INT, 0, comm );
01288         CHECK_MPI( result );
01289
01290         // Get list of types from each processor
01291         std::vector< int > displs( myPcomm->proc_config().proc_size() + 1 );
01292         (void)VALGRIND_MAKE_VEC_UNDEFINED( displs );
01293         displs[0] = 0;
01294         for( unsigned long i = 1; i <= myPcomm->proc_config().proc_size(); ++i )
01295             displs[i] = displs[i - 1] + counts[i - 1];
01296         int total = displs[myPcomm->proc_config().proc_size()];
01297         typelist alltypes( total / 2 );
01298         (void)VALGRIND_MAKE_VEC_UNDEFINED( alltypes );
01299         (void)VALGRIND_CHECK_MEM_IS_DEFINED( &non_root_types[0], non_root_types.size() * sizeof( int ) );
01300         result = MPI_Gatherv( (void*)&non_root_types[0], 2 * non_root_count, MPI_INT, (int*)&alltypes[0], &counts[0],
01301                               &displs[0], MPI_INT, 0, comm );
01302         CHECK_MPI( result );
01303
01304         // Merge type lists.
01305         // Prefer O(n) insertions with O(ln n) search time because
01306         // we expect data from a potentially large number of processes,
01307         // but with a small total number of element types.
01308         if( 0 == myPcomm->proc_config().proc_rank() )
01309         {
01310             for( viter = alltypes.begin(); viter != alltypes.end(); ++viter )
01311             {
01312                 typelist::iterator titer = std::lower_bound( my_types.begin(), my_types.end(), *viter );
01313                 if( titer == my_types.end() || *titer != *viter ) my_types.insert( titer, *viter );
01314             }
01315
01316             dbgOut.print( 2, "Global Element Types:\n" );
01317             for( viter = my_types.begin(); viter != my_types.end(); ++viter )
01318                 dbgOut.printf( 2, "  %s : %d\n", CN::EntityTypeName( (EntityType)viter->first ), viter->second );
01319         }
01320
01321         // Send total number of types to each processor
01322         total  = my_types.size();
01323         result = MPI_Bcast( &total, 1, MPI_INT, 0, comm );
01324         CHECK_MPI( result );
01325
01326         // Send list of types to each processor
01327         my_types.resize( total );
01328         result = MPI_Bcast( (void*)&my_types[0], 2 * total, MPI_INT, 0, comm );
01329         CHECK_MPI( result );
01330     }
01331     else
01332     {
01333         // Special case: if root had types but some subset of procs did not
01334         // have those types, but there are no types that the root doesn't
01335         // know about then we still need to update processes that are missing
01336         // types.
01337         my_types.swap( root_types );
01338     }
01339
01340     // Insert missing types into exportList, with an empty
01341     // range of entities to export.
01342     std::list< ExportSet >::iterator ex_iter = exportList.begin();
01343     for( viter = my_types.begin(); viter != my_types.end(); ++viter )
01344     {
01345         while( ex_iter != exportList.end() && *ex_iter < *viter )
01346             ++ex_iter;
01347
01348         if( ex_iter == exportList.end() || !( *ex_iter == *viter ) )
01349         {
01350             ExportSet insert;
01351             insert.type       = (EntityType)viter->first;
01352             insert.num_nodes  = viter->second;
01353             insert.first_id   = 0;
01354             insert.offset     = 0;
01355             insert.adj_offset = 0;
01356             ex_iter           = exportList.insert( ex_iter, insert );
01357         }
01358     }
01359
01360     return MB_SUCCESS;
01361 }
01362
01363 ErrorCode WriteHDF5Parallel::create_element_tables()
01364 {
01365     struct ElemSetCreator : public DataSetCreator
01366     {
01367         ErrorCode operator()( WriteHDF5* file, long size, const ExportSet* ex, long& start_id ) const
01368         {
01369             return file->create_elem_table( *ex, size, start_id );
01370         }
01371     };
01372
01373     const int numtypes = exportList.size();
01374     std::vector< ExportSet* > groups( numtypes );
01375     std::vector< long > counts( numtypes ), offsets( numtypes ), max_ents( numtypes ), total_ents( numtypes );
01376     std::vector< wid_t > start_ids( numtypes );
01377
01378     size_t idx = 0;
01379     std::list< ExportSet >::iterator ex_iter;
01380     for( ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter, ++idx )
01381     {
01382         groups[idx] = &*ex_iter;
01383         counts[idx] = ex_iter->range.size();
01384     }
01385     ErrorCode rval = create_dataset( numtypes, &counts[0], &offsets[0], &max_ents[0], &total_ents[0], ElemSetCreator(),
01386                                      &groups[0], &start_ids[0] );
01387     CHECK_MB( rval );
01388
01389     for( idx = 0, ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter, ++idx )
01390     {
01391         ex_iter->first_id       = start_ids[idx];
01392         ex_iter->offset         = offsets[idx];
01393         ex_iter->max_num_ents   = max_ents[idx];
01394         ex_iter->total_num_ents = total_ents[idx];
01395         rval                    = assign_ids( ex_iter->range, ex_iter->first_id + ex_iter->offset );
01396         CHECK_MB( rval );
01397     }
01398
01399     return MB_SUCCESS;
01400 }
01401
01402 ErrorCode WriteHDF5Parallel::create_adjacency_tables()
01403 {
01404     struct AdjSetCreator : public DataSetCreator
01405     {
01406         ErrorCode operator()( WriteHDF5* file, long size, const ExportSet* ex, long& start_id ) const
01407         {
01408             mhdf_Status status;
01409             hid_t handle = mhdf_createAdjacency( file->file_ptr(), ex->name(), size, &status );
01410             CHECK_HDFN( status );
01411             mhdf_closeData( file->file_ptr(), handle, &status );
01412             CHECK_HDFN( status );
01413             start_id = -1;
01414             return MB_SUCCESS;
01415         }
01416     };
01417
01418     std::vector< ExportSet* > groups;
01419 #ifdef WRITE_NODE_ADJACENCIES
01420     groups.push_back( &nodeSet );
01421 #endif
01422     for( std::list< ExportSet >::iterator ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter )
01423         groups.push_back( &*ex_iter );
01424
01425     ErrorCode rval;
01426     const int numtypes = groups.size();
01427     std::vector< long > counts( numtypes );
01428     std::vector< long > offsets( numtypes );
01429     std::vector< long > max_ents( numtypes );
01430     std::vector< long > totals( numtypes );
01431     for( int i = 0; i < numtypes; ++i )
01432     {
01433         wid_t count;
01434         rval = count_adjacencies( groups[i]->range, count );
01435         CHECK_MB( rval );
01436         counts[i] = count;
01437     }
01438
01439     rval = create_dataset( numtypes, &counts[0], &offsets[0], &max_ents[0], &totals[0], AdjSetCreator(), &groups[0] );
01440     CHECK_MB( rval );
01441
01442     // Cppcheck warning (false positive): variable groups is assigned a value that is never used
01443     for( int i = 0; i < numtypes; ++i )
01444     {
01445         groups[i]->max_num_adjs = max_ents[i];
01446         groups[i]->adj_offset   = offsets[i];
01447     }
01448     return MB_SUCCESS;
01449 }
01450
01451 const unsigned SSVB = 3;
01452
01453 void WriteHDF5Parallel::print_set_sharing_data( const Range& range, const char* label, Tag idt )
01454 {
01455     dbgOut.printf( SSVB, "set\tid\towner\t%-*s\tfid\tshared\n", (int)( sizeof( EntityHandle ) * 2 ), "handle" );
01456     for( Range::iterator it = range.begin(); it != range.end(); ++it )
01457     {
01458         int id;
01459         iFace->tag_get_data( idt, &*it, 1, &id );
01460         EntityHandle handle = 0;
01461         unsigned owner      = 0;
01462         wid_t file_id       = 0;
01463         myPcomm->get_entityset_owner( *it, owner, &handle );
01464         if( !idMap.find( *it, file_id ) ) file_id = 0;
01465         dbgOut.printf( SSVB, "%s\t%d\t%u\t%lx\t%lu\t", label, id, owner, (unsigned long)handle,
01466                        (unsigned long)file_id );
01467         std::vector< unsigned > procs;
01468         myPcomm->get_entityset_procs( *it, procs );
01469         if( procs.empty() )
01470             dbgOut.print( SSVB, "<none>\n" );
01471         else
01472         {
01473             for( unsigned i = 0; i < procs.size() - 1; ++i )
01474                 dbgOut.printf( SSVB, "%u,", procs[i] );
01475             dbgOut.printf( SSVB, "%u\n", procs.back() );
01476         }
01477     }
01478 }
01479
01480 void WriteHDF5Parallel::print_shared_sets()
01481 {
01482     const char* tag_names[][2] = { { MATERIAL_SET_TAG_NAME, "block" },
01483                                    { DIRICHLET_SET_TAG_NAME, "nodeset" },
01484                                    { NEUMANN_SET_TAG_NAME, "sideset" },
01485                                    { 0, 0 } };
01486
01487     for( int i = 0; tag_names[i][0]; ++i )
01488     {
01489         Tag tag;
01490         if( MB_SUCCESS != iFace->tag_get_handle( tag_names[i][0], 1, MB_TYPE_INTEGER, tag ) ) continue;
01491
01492         Range tagged;
01493         iFace->get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, tagged );
01494         print_set_sharing_data( tagged, tag_names[i][1], tag );
01495     }
01496
01497     Tag geom, id;
01498     if( MB_SUCCESS != iFace->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom ) ) return;
01499     id = iFace->globalId_tag();
01500
01501     const char* geom_names[] = { "vertex", "curve", "surface", "volume" };
01502     for( int d = 0; d <= 3; ++d )
01503     {
01504         Range tagged;
01505         const void* vals[] = { &d };
01506         iFace->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom, vals, 1, tagged );
01507         print_set_sharing_data( tagged, geom_names[d], id );
01508     }
01509 }
01510
01511 ErrorCode WriteHDF5Parallel::communicate_shared_set_ids( const Range& owned, const Range& remote )
01512 {
01513     ErrorCode rval;
01514     int mperr;
01515     const int TAG = 0xD0E;
01516     // const unsigned rank = myPcomm->proc_config().proc_rank();
01517     const MPI_Comm comm = myPcomm->proc_config().proc_comm();
01518
01519     dbgOut.tprint( 1, "COMMUNICATING SHARED SET IDS\n" );
01520     dbgOut.print( 6, "Owned, shared sets: ", owned );
01521
01522     // Post receive buffers for all procs for which we share sets
01523
01524     std::vector< unsigned > procs;
01525     rval = myPcomm->get_entityset_owners( procs );
01526     CHECK_MB( rval );
01527     std::vector< unsigned >::iterator it = std::find( procs.begin(), procs.end(), myPcomm->proc_config().proc_rank() );
01528     if( it != procs.end() ) procs.erase( it );
01529
01530     std::vector< MPI_Request > recv_req( procs.size(), MPI_REQUEST_NULL );
01531     std::vector< std::vector< unsigned long > > recv_buf( procs.size() );
01532
01533     size_t recv_count = 0;
01534     for( size_t i = 0; i < procs.size(); ++i )
01535     {
01536         Range tmp;
01537         rval = myPcomm->get_owned_sets( procs[i], tmp );
01538         CHECK_MB( rval );
01539         size_t count =
01540             intersect( tmp, remote ).size();  // Necessary because we might not be writing all of the database
01541         if( count )
01542         {
01543             dbgOut.printf( 6, "Sets owned by proc %u (remote handles): ", procs[i] );
01544             if( dbgOut.get_verbosity() >= 6 )
01545             {
01546                 Range remote_handles;
01547                 tmp = intersect( tmp, remote );
01548                 for( Range::iterator j = tmp.begin(); j != tmp.end(); ++j )
01549                 {
01550                     unsigned r;
01551                     EntityHandle h;
01552                     myPcomm->get_entityset_owner( *j, r, &h );
01553                     assert( r == procs[i] );
01554                     remote_handles.insert( h );
01555                 }
01556                 dbgOut.print( 6, remote_handles );
01557             }
01558             recv_count++;
01559             recv_buf[i].resize( 2 * count + 1 );
01560             dbgOut.printf( 5, "Posting receive buffer of size %lu for proc %u (%lu of %lu owned sets)\n",
01561                            (unsigned long)recv_buf[i].size(), procs[i], count, tmp.size() );
01562             mperr =
01563                 MPI_Irecv( &recv_buf[i][0], recv_buf[i].size(), MPI_UNSIGNED_LONG, procs[i], TAG, comm, &recv_req[i] );
01564             CHECK_MPI( mperr );
01565         }
01566     }
01567
01568     // Send set ids to all procs with which we share them
01569
01570     // First build per-process lists of sets for which we need to send data
01571     std::map< unsigned, Range > send_sets;
01572     std::vector< unsigned > set_procs;
01573     for( Range::reverse_iterator i = owned.rbegin(); i != owned.rend(); ++i )
01574     {
01575         set_procs.clear();
01576         rval = myPcomm->get_entityset_procs( *i, set_procs );
01577         CHECK_MB( rval );
01578         for( size_t j = 0; j < set_procs.size(); ++j )
01579             if( set_procs[j] != myPcomm->proc_config().proc_rank() ) send_sets[set_procs[j]].insert( *i );
01580     }
01581     assert( send_sets.find( myPcomm->proc_config().proc_rank() ) == send_sets.end() );
01582
01583     // Now send the data
01584     std::vector< std::vector< unsigned long > > send_buf( send_sets.size() );
01585     std::vector< MPI_Request > send_req( send_sets.size() );
01586     std::map< unsigned, Range >::iterator si = send_sets.begin();
01587     for( size_t i = 0; si != send_sets.end(); ++si, ++i )
01588     {
01589         dbgOut.printf( 6, "Sending data for shared sets to proc %u: ", si->first );
01590         dbgOut.print( 6, si->second );
01591
01592         send_buf[i].reserve( 2 * si->second.size() + 1 );
01593         send_buf[i].push_back( si->second.size() );
01594         for( Range::iterator j = si->second.begin(); j != si->second.end(); ++j )
01595         {
01596             send_buf[i].push_back( *j );
01597             send_buf[i].push_back( idMap.find( *j ) );
01598         }
01599         dbgOut.printf( 5, "Sending buffer of size %lu to proc %u (%lu of %lu owned sets)\n",
01600                        (unsigned long)send_buf[i].size(), si->first, si->second.size(), owned.size() );
01601         mperr = MPI_Isend( &send_buf[i][0], send_buf[i].size(), MPI_UNSIGNED_LONG, si->first, TAG, comm, &send_req[i] );
01602     }
01603
01604     // Process received data
01605     MPI_Status status;
01606     int idx;
01607     while( recv_count-- )
01608     {
01609         mperr = MPI_Waitany( recv_req.size(), &recv_req[0], &idx, &status );
01610         CHECK_MPI( mperr );
01611
01612         assert( (unsigned)status.MPI_SOURCE == procs[idx] );
01613         assert( 2 * recv_buf[idx].front() + 1 == recv_buf[idx].size() );
01614         const size_t n = std::min< size_t >( recv_buf[idx].front(), ( recv_buf[idx].size() - 1 ) / 2 );
01615         dbgOut.printf( 5, "Received buffer of size %lu from proc %d\n", (unsigned long)( 2 * n + 1 ),
01616                        (int)status.MPI_SOURCE );
01617
01618         for( size_t i = 0; i < n; ++i )
01619         {
01620             EntityHandle handle = 0;
01621             rval                = myPcomm->get_entityset_local_handle( procs[idx], recv_buf[idx][2 * i + 1], handle );
01622             CHECK_MB( rval );
01623             assert( handle != 0 );
01624             if( !idMap.insert( handle, recv_buf[idx][2 * i + 2], 1 ).second )
01625                 error( MB_FAILURE );  // Conflicting IDs??????
01626         }
01627
01628         recv_req[idx] = MPI_REQUEST_NULL;
01629     }
01630     assert( MPI_SUCCESS == MPI_Waitany( recv_req.size(), &recv_req[0], &idx, &status ) &&
01631             MPI_UNDEFINED == idx );  // Check that we got them all
01632
01633     // Wait for all sends to complete before we release send
01634     // buffers (implicitly releases when we return from this function)
01635
01636     std::vector< MPI_Status > stats( send_req.size() );
01637     mperr = MPI_Waitall( send_req.size(), &send_req[0], &stats[0] );
01638     CHECK_MPI( mperr );
01639
01640     if( dbgOut.get_verbosity() >= SSVB ) print_shared_sets();
01641
01642     return MB_SUCCESS;
01643 }
01644
01645 // void get_global_ids(Interface* iFace, const unsigned long* ptr,
01646 //                    size_t len, unsigned flags,
01647 //                    std::vector<int>& ids)
01648 //{
01649 //  Tag idtag;
01650 //  iFace->tag_get_handle(GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, idtag);
01651 //  for (size_t i = 0; i < len; ++i) {
01652 //    if (flags & MESHSET_ORDERED) {
01653 //      int tmp;
01654 //      iFace->tag_get_data(idtag, ptr + i, 1, &tmp);
01655 //      ids.push_back(tmp);
01656 //      continue;
01657 //    }
01658 //
01659 //    EntityHandle s = ptr[i];
01660 //    EntityHandle e = ptr[++i];
01661 //    for (; s <= e; ++s) {
01662 //      int tmp;
01663 //      iFace->tag_get_data(idtag, &s, 1, &tmp);
01664 //      ids.push_back(tmp);
01665 //    }
01666 //  }
01667 //}
01668
01669 ErrorCode WriteHDF5Parallel::pack_set( Range::const_iterator it, unsigned long* buffer, size_t buffer_size )
01670 {
01671     ErrorCode rval;
01672     const EntityHandle* ptr;
01673     int len;
01674     unsigned char flags;
01675     std::vector< wid_t > tmp;
01676     size_t newlen;
01677
01678     // Buffer must always contain at least flags and desired sizes
01679     assert( buffer_size >= 4 );
01680     buffer_size -= 4;
01681
01682     Range::const_iterator nd = it;
01683     ++nd;
01684     rval = writeUtil->get_entity_list_pointers( it, nd, &ptr, WriteUtilIface::CONTENTS, &len, &flags );
01685     CHECK_MB( rval );
01686
01687     // Tag mattag;
01688     // iFace->tag_get_handle(MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mattag);
01689     // int block;
01690     // if (MB_SUCCESS != iFace->tag_get_data(mattag, &*it, 1, &block))
01691     //  block = 0;
01692     //
01693     // if (block) {
01694     //  std::vector<int> ids;
01695     //  get_global_ids(iFace, ptr, len, flags, ids);
01696     //}
01697
01698     if( len && !( flags & MESHSET_ORDERED ) )
01699     {
01700         tmp.clear();
01701         bool blocked = false;
01702         assert( ( 0 == len % 2 ) );
01703         rval = range_to_blocked_list( ptr, len / 2, tmp, blocked );
01704         CHECK_MB( rval );
01705         if( blocked ) flags |= mhdf_SET_RANGE_BIT;
01706     }
01707     else
01708     {
01709         tmp.resize( len );
01710         rval = vector_to_id_list( ptr, len, &tmp[0], newlen, true );
01711         CHECK_MB( rval );
01712         tmp.resize( newlen );
01713     }
01714
01715     buffer[0] = flags;
01716     buffer[1] = tmp.size();
01717     if( tmp.size() <= buffer_size ) std::copy( tmp.begin(), tmp.end(), buffer + 4 );
01718
01719     rval = writeUtil->get_entity_list_pointers( it, nd, &ptr, WriteUtilIface::CHILDREN, &len );
01720     CHECK_MB( rval );
01721     tmp.resize( len );
01722     rval = vector_to_id_list( ptr, len, &tmp[0], newlen, true );
01723     tmp.resize( newlen );
01724     buffer[2] = tmp.size();
01725     if( tmp.size() <= buffer_size - buffer[1] ) std::copy( tmp.begin(), tmp.end(), buffer + 4 + buffer[1] );
01726
01727     rval = writeUtil->get_entity_list_pointers( it, nd, &ptr, WriteUtilIface::PARENTS, &len );
01728     CHECK_MB( rval );
01729     tmp.resize( len );
01730     rval = vector_to_id_list( ptr, len, &tmp[0], newlen, true );
01731     tmp.resize( newlen );
01732     buffer[3] = tmp.size();
01733     if( tmp.size() <= buffer_size - buffer[1] - buffer[2] )
01734         std::copy( tmp.begin(), tmp.end(), buffer + 4 + buffer[1] + buffer[2] );
01735
01736     return MB_SUCCESS;
01737 }
01738
01739 template < typename TYPE >
01740 static void convert_to_ranged_ids( const TYPE* buffer, size_t len, std::vector< WriteHDF5::wid_t >& result )
01741 {
01742     if( !len )
01743     {
01744         result.clear();
01745         return;
01746     }
01747
01748     result.resize( len * 2 );
01749     Range tmp;
01750     for( size_t i = 0; i < len; i++ )
01751         tmp.insert( (EntityHandle)buffer[i] );
01752     result.resize( tmp.psize() * 2 );
01753     int j = 0;
01754     for( Range::const_pair_iterator pit = tmp.const_pair_begin(); pit != tmp.const_pair_end(); ++pit, j++ )
01755     {
01756         result[2 * j]     = pit->first;
01757         result[2 * j + 1] = pit->second - pit->first + 1;
01758     }
01759 }
01760
01761 static void merge_ranged_ids( const unsigned long* range_list, size_t len, std::vector< WriteHDF5::wid_t >& result )
01762 {
01763     typedef WriteHDF5::wid_t wid_t;
01764     assert( 0 == len % 2 );
01765     assert( 0 == result.size() % 2 );
01766     STATIC_ASSERT( sizeof( std::pair< wid_t, wid_t > ) == 2 * sizeof( wid_t ) );
01767
01768     result.insert( result.end(), range_list, range_list + len );
01769     size_t plen = result.size() / 2;
01770     Range tmp;
01771     for( size_t i = 0; i < plen; i++ )
01772     {
01773         EntityHandle starth = (EntityHandle)result[2 * i];
01774         EntityHandle endh   = (EntityHandle)result[2 * i] + (wid_t)result[2 * i + 1] - 1;  // id + count - 1
01775         tmp.insert( starth, endh );
01776     }
01777     // Now convert back to std::vector<WriteHDF5::wid_t>, compressed range format
01778     result.resize( tmp.psize() * 2 );
01779     int j = 0;
01780     for( Range::const_pair_iterator pit = tmp.const_pair_begin(); pit != tmp.const_pair_end(); ++pit, j++ )
01781     {
01782         result[2 * j]     = pit->first;
01783         result[2 * j + 1] = pit->second - pit->first + 1;
01784     }
01785 }
01786
01787 static void merge_vector_ids( const unsigned long* list, size_t len, std::vector< WriteHDF5::wid_t >& result )
01788 {
01789     result.insert( result.end(), list, list + len );
01790 }
01791
01792 ErrorCode WriteHDF5Parallel::unpack_set( EntityHandle set, const unsigned long* buffer, size_t buffer_size )
01793 {
01794     // Use local variables for readability
01795     assert( buffer_size >= 4 );
01796     assert( buffer[1] + buffer[2] + buffer[3] <= buffer_size );
01797     const unsigned long flags      = buffer[0];
01798     unsigned long num_content      = buffer[1];
01799     const unsigned long num_child  = buffer[2];
01800     const unsigned long num_parent = buffer[3];
01801     const unsigned long* contents  = buffer + 4;
01802     const unsigned long* children  = contents + num_content;
01803     const unsigned long* parents   = children + num_child;
01804
01805     SpecialSetData* data = find_set_data( set );
01806     assert( NULL != data );
01807     if( NULL == data ) return MB_FAILURE;
01808
01809     // Tag mattag;
01810     // iFace->tag_get_handle(MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mattag);
01811     // int block;
01812     // if (MB_SUCCESS != iFace->tag_get_data(mattag, &set, 1, &block))
01813     //  block = 0;
01814
01815     // If either the current data or the new data is in ranged format,
01816     // then change the other to ranged format if it isn't already
01817     // in both cases when they differ, the data will end up "compressed range"
01818     std::vector< wid_t > tmp;
01819     if( ( flags & mhdf_SET_RANGE_BIT ) != ( data->setFlags & mhdf_SET_RANGE_BIT ) )
01820     {
01821         if( flags & mhdf_SET_RANGE_BIT )
01822         {
01823             tmp = data->contentIds;
01824             convert_to_ranged_ids( &tmp[0], tmp.size(), data->contentIds );
01825             data->setFlags |= mhdf_SET_RANGE_BIT;
01826         }
01827         else
01828         {
01829             tmp.clear();
01830             convert_to_ranged_ids( contents, num_content, tmp );
01831             num_content = tmp.size();
01832             if( sizeof( wid_t ) < sizeof( long ) )
01833             {
01834                 size_t old_size = tmp.size();
01835                 tmp.resize( sizeof( long ) * old_size / sizeof( wid_t ) );
01836                 unsigned long* array = reinterpret_cast< unsigned long* >( &tmp[0] );
01837                 for( long i = ( (long)old_size ) - 1; i >= 0; --i )
01838                     array[i] = tmp[i];
01839                 contents = array;
01840             }
01841             else if( sizeof( wid_t ) > sizeof( long ) )
01842             {
01843                 unsigned long* array = reinterpret_cast< unsigned long* >( &tmp[0] );
01844                 std::copy( tmp.begin(), tmp.end(), array );
01845             }
01846             contents = reinterpret_cast< unsigned long* >( &tmp[0] );
01847         }
01848     }
01849
01850     if( data->setFlags & mhdf_SET_RANGE_BIT )
01851         merge_ranged_ids( contents, num_content, data->contentIds );
01852     else
01853         merge_vector_ids( contents, num_content, data->contentIds );
01854
01855     merge_vector_ids( children, num_child, data->childIds );
01856     merge_vector_ids( parents, num_parent, data->parentIds );
01857     return MB_SUCCESS;
01858 }
01859
01860 ErrorCode WriteHDF5Parallel::communicate_shared_set_data( const Range& owned, const Range& remote )
01861 {
01862     ErrorCode rval;
01863     int mperr;
01864     const unsigned rank = myPcomm->proc_config().proc_rank();
01865     const MPI_Comm comm = myPcomm->proc_config().proc_comm();
01866
01867     dbgOut.tprintf( 1, "COMMUNICATING SHARED SET DATA (%lu owned & %lu remote)\n", (unsigned long)owned.size(),
01868                     (unsigned long)remote.size() );
01869
01870     // Calculate the total number of messages to be in transit (send and receive)
01871     size_t nummess = 0;
01872     std::vector< unsigned > procs;
01873     ;
01874     Range shared( owned );
01875     shared.merge( remote );
01876     for( Range::iterator i = shared.begin(); i != shared.end(); ++i )
01877     {
01878         procs.clear();
01879         rval = myPcomm->get_entityset_procs( *i, procs );
01880         CHECK_MB( rval );
01881         nummess += procs.size();
01882     }
01883
01884     // Choose a receive buffer size. We need 4*sizeof(long) minimum,
01885     // but that is almost useless so use 16*sizeof(long) as the minimum
01886     // instead. Choose an upper limit such that we don't exceed 32 MB
01887     // of allocated memory (unless we absolutely must to meet the minimum.)
01888     // Also, don't initially choose buffers larger than 128*sizeof(long).
01889     const size_t MAX_BUFFER_MEM = 32 * 1024 * 1024 / sizeof( long );
01890     // const size_t INIT_BUFFER_SIZE = 128;
01891     const size_t INIT_BUFFER_SIZE = 1024;
01892     const size_t MIN_BUFFER_SIZE  = 16;
01893     size_t init_buff_size         = INIT_BUFFER_SIZE;
01894     if( init_buff_size * nummess > MAX_BUFFER_MEM ) init_buff_size = MAX_BUFFER_MEM / nummess;
01895     if( init_buff_size < MIN_BUFFER_SIZE ) init_buff_size = MIN_BUFFER_SIZE;
01896
01897     dbgOut.printf( 2, "Using buffer size of %lu for an expected message count of %lu\n", (unsigned long)init_buff_size,
01898                    (unsigned long)nummess );
01899
01900     // Count number of recvs
01901     size_t numrecv = 0;
01902     for( Range::iterator i = owned.begin(); i != owned.end(); ++i )
01903     {
01904         procs.clear();
01905         rval = myPcomm->get_entityset_procs( *i, procs );
01906         CHECK_MB( rval );
01907         numrecv += procs.size();
01908         if( std::find( procs.begin(), procs.end(), rank ) != procs.end() ) --numrecv;
01909     }
01910
01911     // Post receive buffers for all owned sets for all sharing procs
01912     std::vector< MPI_Request > recv_req( numrecv, MPI_REQUEST_NULL );
01913     std::vector< MPI_Request > lrecv_req( numrecv, MPI_REQUEST_NULL );
01914
01915     std::vector< std::vector< unsigned long > > recv_buf( numrecv, std::vector< unsigned long >( init_buff_size ) );
01916     int idx = 0;
01917     for( Range::iterator i = owned.begin(); i != owned.end(); ++i )
01918     {
01919         procs.clear();
01920         rval = myPcomm->get_entityset_procs( *i, procs );
01921         CHECK_MB( rval );
01922         for( size_t j = 0; j < procs.size(); ++j )
01923         {
01924             if( procs[j] == rank ) continue;
01925             int tag = ID_FROM_HANDLE( *i );
01926             if( *i != CREATE_HANDLE( MBENTITYSET, tag ) )
01927             {
01928 #ifndef NDEBUG
01929                 abort();
01930 #endif
01931                 CHECK_MB( MB_FAILURE );
01932             }
01933             dbgOut.printf( 5, "Posting buffer to receive set %d from proc %u\n", tag, procs[j] );
01934             mperr =
01935                 MPI_Irecv( &recv_buf[idx][0], init_buff_size, MPI_UNSIGNED_LONG, procs[j], tag, comm, &recv_req[idx] );
01936             CHECK_MPI( mperr );
01937             ++idx;
01938         }
01939     }
01940     assert( (size_t)idx == numrecv );
01941
01942     // Now send set data for all remote sets that I know about
01943     std::vector< MPI_Request > send_req( remote.size() );
01944     std::vector< std::vector< unsigned long > > send_buf( remote.size() );
01945     idx = 0;
01946     for( Range::iterator i = remote.begin(); i != remote.end(); ++i, ++idx )
01947     {
01948         send_buf[idx].resize( init_buff_size );
01949         rval = pack_set( i, &send_buf[idx][0], init_buff_size );
01950         CHECK_MB( rval );
01951         EntityHandle remote_handle;
01952         unsigned owner;
01953         rval = myPcomm->get_entityset_owner( *i, owner, &remote_handle );
01954         CHECK_MB( rval );
01955
01956         int tag = ID_FROM_HANDLE( remote_handle );
01957         assert( remote_handle == CREATE_HANDLE( MBENTITYSET, tag ) );
01958         dbgOut.printf( 5, "Sending %lu values for set %d to proc %u\n",
01959                        send_buf[idx][1] + send_buf[idx][2] + send_buf[idx][3] + 4, tag, owner );
01960         mperr = MPI_Isend( &send_buf[idx][0], init_buff_size, MPI_UNSIGNED_LONG, owner, tag, comm, &send_req[idx] );
01961         CHECK_MPI( mperr );
01962     }
01963
01964     // Tag mattag;
01965     // iFace->tag_get_handle(MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mattag);
01966
01967     // Now initialize local data for managing contents of owned, shared sets
01968     assert( specialSets.empty() );
01969     specialSets.clear();
01970     specialSets.reserve( owned.size() );
01971     for( Range::iterator i = owned.begin(); i != owned.end(); ++i )
01972     {
01973         // int block;
01974         // if (MB_SUCCESS != iFace->tag_get_data(mattag, &*i, 1, &block))
01975         //  block = 0;
01976         // std::vector<int> ids;
01977
01978         SpecialSetData data;
01979         data.setHandle = *i;
01980         rval           = iFace->get_meshset_options( *i, data.setFlags );
01981         CHECK_MB( rval );
01982         specialSets.push_back( data );
01983         std::vector< EntityHandle > list;
01984         if( data.setFlags & MESHSET_ORDERED )
01985         {
01986             list.clear();
01987             rval = iFace->get_entities_by_handle( *i, list );
01988             CHECK_MB( rval );
01989             rval = vector_to_id_list( list, specialSets.back().contentIds, true );
01990             CHECK_MB( rval );
01991             // if (block)
01992             //  get_global_ids(iFace, &list[0], list.size(), MESHSET_ORDERED, ids);
01993         }
01994         else
01995         {
01996             Range range;
01997             rval = iFace->get_entities_by_handle( *i, range );
01998             CHECK_MB( rval );
01999             bool ranged;
02000             rval = range_to_blocked_list( range, specialSets.back().contentIds, ranged );
02001             if( ranged ) specialSets.back().setFlags |= mhdf_SET_RANGE_BIT;
02002             // if (block) {
02003             //  std::vector<EntityHandle> tmp;
02004             //  for (Range::const_pair_iterator pi = range.const_pair_begin(); pi !=
02005             //  range.const_pair_end(); ++pi) {
02006             //    tmp.push_back(pi->first);
02007             //    tmp.push_back(pi->second);
02008             //  }
02009             //  get_global_ids(iFace, &tmp[0], tmp.size(), ranged ? 0 : MESHSET_ORDERED, ids);
02010             //}
02011         }
02012
02013         list.clear();
02014         rval = iFace->get_parent_meshsets( *i, list );
02015         CHECK_MB( rval );
02016         rval = vector_to_id_list( list, specialSets.back().parentIds, true );
02017         CHECK_MB( rval );
02018         rval = iFace->get_child_meshsets( *i, list );
02019         CHECK_MB( rval );
02020         rval = vector_to_id_list( list, specialSets.back().childIds, true );
02021         CHECK_MB( rval );
02022     }
02023
02024     // Process received buffers, repost larger buffers where necessary
02025     size_t remaining = numrecv;
02026     numrecv          = 0;
02027     while( remaining-- )
02028     {
02029         std::vector< unsigned long > dead;
02030         MPI_Status status;
02031         mperr = MPI_Waitany( recv_req.size(), &recv_req[0], &idx, &status );
02032         CHECK_MPI( mperr );
02033         EntityHandle handle                = CREATE_HANDLE( MBENTITYSET, status.MPI_TAG );
02034         std::vector< unsigned long >& buff = recv_buf[idx];
02035         size_t size                        = buff[1] + buff[2] + buff[3] + 4;
02036         dbgOut.printf( 5, "Received %lu values for set %d from proc %d\n", (unsigned long)size, status.MPI_TAG,
02037                        status.MPI_SOURCE );
02038         if( size <= init_buff_size )
02039         {
02040             rval = unpack_set( handle, &buff[0], init_buff_size );
02041             CHECK_MB( rval );
02042             dead.swap( buff );  // Release memory
02043         }
02044         else
02045         {
02046             // Data was too big for init_buff_size
02047             // repost with larger buffer
02048             buff.resize( size );
02049             dbgOut.printf( 5, "Re-Posting buffer to receive set %d from proc %d with size %lu\n", status.MPI_TAG,
02050                            status.MPI_SOURCE, (unsigned long)size );
02051             mperr = MPI_Irecv( &buff[0], size, MPI_UNSIGNED_LONG, status.MPI_SOURCE, status.MPI_TAG, comm,
02052                                &lrecv_req[idx] );
02053             CHECK_MPI( mperr );
02054             ++numrecv;
02055         }
02056         recv_req[idx] = MPI_REQUEST_NULL;
02057     }
02058
02059     // Wait for sends to complete
02060     MPI_Waitall( send_req.size(), &send_req[0], MPI_STATUSES_IGNORE );
02061
02062     // Re-send sets that didn't fit initial buffer size
02063     idx = 0;
02064     for( Range::iterator i = remote.begin(); i != remote.end(); ++i, ++idx )
02065     {
02066         std::vector< unsigned long >& buff = send_buf[idx];
02067         size_t size                        = buff[1] + buff[2] + buff[3] + 4;
02068         if( size <= init_buff_size ) continue;
02069
02070         buff.resize( size );
02071         rval = pack_set( i, &buff[0], size );
02072         CHECK_MB( rval );
02073         EntityHandle remote_handle;
02074         unsigned owner;
02075         rval = myPcomm->get_entityset_owner( *i, owner, &remote_handle );
02076         CHECK_MB( rval );
02077
02078         int tag = ID_FROM_HANDLE( remote_handle );
02079         assert( remote_handle == CREATE_HANDLE( MBENTITYSET, tag ) );
02080         dbgOut.printf( 5, "Sending %lu values for set %d to proc %u\n", (unsigned long)size, tag, owner );
02081         mperr = MPI_Isend( &buff[0], size, MPI_UNSIGNED_LONG, owner, tag, comm, &send_req[idx] );
02082         CHECK_MPI( mperr );
02083     }
02084
02085     // Process received buffers
02086     remaining = numrecv;
02087     while( remaining-- )
02088     {
02089         std::vector< unsigned long > dead;
02090         MPI_Status status;
02091         mperr = MPI_Waitany( lrecv_req.size(), &lrecv_req[0], &idx, &status );
02092         CHECK_MPI( mperr );
02093         EntityHandle handle                = CREATE_HANDLE( MBENTITYSET, status.MPI_TAG );
02094         std::vector< unsigned long >& buff = recv_buf[idx];
02095         dbgOut.printf( 5, "Received %lu values for set %d from proc %d\n", 4 + buff[1] + buff[2] + buff[3],
02096                        status.MPI_TAG, status.MPI_SOURCE );
02097         rval = unpack_set( handle, &buff[0], buff.size() );
02098         CHECK_MB( rval );
02099         dead.swap( buff );  // Release memory
02100
02101         lrecv_req[idx] = MPI_REQUEST_NULL;
02102     }
02103
02104     // Wait for sends to complete
02105     MPI_Waitall( send_req.size(), &send_req[0], MPI_STATUSES_IGNORE );
02106
02107     return MB_SUCCESS;
02108 }
02109
02110 ErrorCode WriteHDF5Parallel::create_meshset_tables( double* times )
02111 {
02112     Range::const_iterator riter;
02113     const unsigned rank = myPcomm->proc_config().proc_rank();
02114
02115     START_SERIAL;
02116     print_type_sets( iFace, &dbgOut, setSet.range );
02117     END_SERIAL;
02118     CpuTimer timer;
02119
02120     // Remove remote sets from setSets
02121     Range shared, owned, remote;
02122     ErrorCode rval = myPcomm->get_shared_sets( shared );
02123     CHECK_MB( rval );
02124     shared = intersect( shared, setSet.range );
02125     rval   = myPcomm->get_owned_sets( rank, owned );
02126     CHECK_MB( rval );
02127     owned        = intersect( owned, setSet.range );
02128     remote       = subtract( shared, owned );
02129     setSet.range = subtract( setSet.range, remote );
02130
02131     // Create set meta table
02132     struct SetDescCreator : public DataSetCreator
02133     {
02134         ErrorCode operator()( WriteHDF5* writer, long size, const ExportSet*, long& start_id ) const
02135         {
02136             return writer->create_set_meta( size, start_id );
02137         }
02138     };
02139     long count = setSet.range.size();
02140     rval = create_dataset( 1, &count, &setSet.offset, &setSet.max_num_ents, &setSet.total_num_ents, SetDescCreator(),
02141                            NULL, &setSet.first_id );
02142     CHECK_MB( rval );
02143     writeSets = setSet.max_num_ents > 0;
02144
02145     rval = assign_ids( setSet.range, setSet.first_id + setSet.offset );
02146     CHECK_MB( rval );
02147     if( times ) times[SET_OFFSET_TIME] = timer.time_elapsed();
02148
02149     // Exchange file IDS for sets between all procs
02150     rval = communicate_shared_set_ids( owned, remote );
02151     CHECK_MB( rval );
02152     if( times ) times[SHARED_SET_IDS] = timer.time_elapsed();
02153
02154     // Communicate remote set contents, children, etc.
02155     rval = communicate_shared_set_data( owned, remote );
02156     CHECK_MB( rval );
02157     if( times ) times[SHARED_SET_CONTENTS] = timer.time_elapsed();
02158
02159     // Communicate counts for owned sets
02160     long data_counts[3];  // { #contents, #children, #parents }
02161     rval = count_set_size( setSet.range, data_counts[0], data_counts[1], data_counts[2] );
02162     CHECK_MB( rval );
02163     if( times ) times[SET_OFFSET_TIME] += timer.time_elapsed();
02164
02165     long offsets[3], max_counts[3], totals[3];
02166     rval = create_dataset( 3, data_counts, offsets, max_counts, totals );
02167     CHECK_MB( rval );
02168
02169     // Create the datasets
02170     if( 0 == myPcomm->proc_config().proc_rank() )
02171     {
02172         rval = create_set_tables( totals[0], totals[1], totals[2] );
02173         CHECK_MB( rval );
02174     }
02175
02176     // Store communicated global data
02177     setContentsOffset = offsets[0];
02178     setChildrenOffset = offsets[1];
02179     setParentsOffset  = offsets[2];
02180     maxNumSetContents = max_counts[0];
02181     maxNumSetChildren = max_counts[1];
02182     maxNumSetParents  = max_counts[2];
02183     writeSetContents  = totals[0] > 0;
02184     writeSetChildren  = totals[1] > 0;
02185     writeSetParents   = totals[2] > 0;
02186
02187     dbgOut.printf( 2, "set contents: %ld local, %ld global, offset = %ld\n", data_counts[0], totals[0], offsets[0] );
02188     dbgOut.printf( 2, "set children: %ld local, %ld global, offset = %ld\n", data_counts[1], totals[1], offsets[1] );
02189     dbgOut.printf( 2, "set parents: %ld local, %ld global, offset = %ld\n", data_counts[2], totals[2], offsets[2] );
02190
02191     return MB_SUCCESS;
02192 }
02193
02194 void WriteHDF5Parallel::remove_remote_entities( EntityHandle relative, Range& range )
02195 {
02196     Range result;
02197     result.merge( intersect( range, nodeSet.range ) );
02198     result.merge( intersect( range, setSet.range ) );
02199     for( std::list< ExportSet >::iterator eiter = exportList.begin(); eiter != exportList.end(); ++eiter )
02200         result.merge( intersect( range, eiter->range ) );
02201
02202     // result.merge(intersect(range, myParallelSets));
02203     Range sets;
02204     int junk;
02205     sets.merge( Range::lower_bound( range.begin(), range.end(), CREATE_HANDLE( MBENTITYSET, 0, junk ) ), range.end() );
02206     remove_remote_sets( relative, sets );
02207     result.merge( sets );
02208     range.swap( result );
02209 }
02210
02211 void WriteHDF5Parallel::remove_remote_sets( EntityHandle /* relative */, Range& range )
02212 {
02213     Range result( intersect( range, setSet.range ) );
02214     // Store the non-intersecting entities separately if needed
02215     // Range remaining(subtract(range, result));
02216     range.swap( result );
02217 }
02218
02219 void WriteHDF5Parallel::remove_remote_entities( EntityHandle relative, std::vector< EntityHandle >& vect )
02220 {
02221     Range intrsct;
02222     for( std::vector< EntityHandle >::const_iterator iter = vect.begin(); iter != vect.end(); ++iter )
02223         intrsct.insert( *iter );
02224     remove_remote_entities( relative, intrsct );
02225
02226     unsigned int read, write;
02227     for( read = write = 0; read < vect.size(); ++read )
02228     {
02229         if( intrsct.find( vect[read] ) != intrsct.end() )
02230         {
02231             if( read != write ) vect[write] = vect[read];
02232             ++write;
02233         }
02234     }
02235     if( write != vect.size() ) vect.resize( write );
02236 }
02237
02238 void WriteHDF5Parallel::remove_remote_sets( EntityHandle relative, std::vector< EntityHandle >& vect )
02239 {
02240     Range intrsct;
02241     for( std::vector< EntityHandle >::const_iterator iter = vect.begin(); iter != vect.end(); ++iter )
02242         intrsct.insert( *iter );
02243     remove_remote_sets( relative, intrsct );
02244
02245     unsigned int read, write;
02246     for( read = write = 0; read < vect.size(); ++read )
02247     {
02248         if( intrsct.find( vect[read] ) != intrsct.end() )
02249         {
02250             if( read != write ) vect[write] = vect[read];
02251             ++write;
02252         }
02253     }
02254     if( write != vect.size() ) vect.resize( write );
02255 }
02256
02257 ErrorCode WriteHDF5Parallel::exchange_file_ids( const Range& nonlocal )
02258 {
02259     ErrorCode rval;
02260
02261     // For each entity owned on the interface, write its file id to
02262     // a tag. The sets of entities to be written should already contain
02263     // only owned entities so by intersecting with them we not only
02264     // filter by entities to be written, but also restrict to entities
02265     // owned by the proc
02266
02267     // Get list of interface entities
02268     Range imesh, tmp;
02269     for( std::list< ExportSet >::reverse_iterator i = exportList.rbegin(); i != exportList.rend(); ++i )
02270     {
02271         tmp.clear();
02272         rval = myPcomm->filter_pstatus( i->range, PSTATUS_SHARED, PSTATUS_AND, -1, &tmp );
02273         if( MB_SUCCESS != rval ) return error( rval );
02274         imesh.merge( tmp );
02275     }
02276     tmp.clear();
02277     rval = myPcomm->filter_pstatus( nodeSet.range, PSTATUS_SHARED, PSTATUS_AND, -1, &tmp );
02278     if( MB_SUCCESS != rval ) return error( rval );
02279     imesh.merge( tmp );
02280
02281     // Create tag to store file IDs
02282     EntityHandle default_val = 0;
02283     Tag file_id_tag          = 0;
02284     rval = iFace->tag_get_handle( "__hdf5_ll_fileid", 1, MB_TYPE_HANDLE, file_id_tag, MB_TAG_DENSE | MB_TAG_CREAT,
02285                                   &default_val );
02286     if( MB_SUCCESS != rval ) return error( rval );
02287
02288     // Copy file IDs into tag
02289     std::vector< EntityHandle > file_id_vect( imesh.size() );
02290     Range::const_iterator i;
02291     std::vector< EntityHandle >::iterator j = file_id_vect.begin();
02292     for( i = imesh.begin(); i != imesh.end(); ++i, ++j )
02293     {
02294         *j = idMap.find( *i );
02295         if( !*j )
02296         {
02297             iFace->tag_delete( file_id_tag );
02298             return error( MB_FAILURE );
02299         }
02300     }
02301     rval = iFace->tag_set_data( file_id_tag, imesh, &file_id_vect[0] );
02302     if( MB_SUCCESS != rval )
02303     {
02304         iFace->tag_delete( file_id_tag );
02305         return error( rval );
02306     }
02307
02308     // Do communication
02309     rval = myPcomm->exchange_tags( file_id_tag, imesh );
02310     if( MB_SUCCESS != rval )
02311     {
02312         iFace->tag_delete( file_id_tag );
02313         return error( rval );
02314     }
02315
02316     // Copy file IDs from tag into idMap for remote entities
02317     file_id_vect.resize( nonlocal.size() );
02318     rval = iFace->tag_get_data( file_id_tag, nonlocal, &file_id_vect[0] );
02319     if( MB_SUCCESS != rval )
02320     {
02321         iFace->tag_delete( file_id_tag );
02322         return error( rval );
02323     }
02324
02325     j = file_id_vect.begin();
02326     for( i = nonlocal.begin(); i != nonlocal.end(); ++i, ++j )
02327     {
02328         if( *j == 0 )
02329         {
02330             int owner = -1;
02331             myPcomm->get_owner( *i, owner );
02332             const char* name = CN::EntityTypeName( TYPE_FROM_HANDLE( *i ) );
02333             int id           = ID_FROM_HANDLE( *i );
02334             MB_SET_ERR_CONT( "Process " << myPcomm->proc_config().proc_rank()
02335                                         << " did not receive valid id handle for shared " << name << " " << id
02336                                         << " owned by process " << owner );
02337             dbgOut.printf( 1,
02338                            "Did not receive valid remote id for "
02339                            "shared %s %d owned by process %d",
02340                            name, id, owner );
02341             iFace->tag_delete( file_id_tag );
02342             return error( MB_FAILURE );
02343         }
02344         else
02345         {
02346             if( !idMap.insert( *i, *j, 1 ).second )
02347             {
02348                 iFace->tag_delete( file_id_tag );
02349                 return error( MB_FAILURE );
02350             }
02351         }
02352     }
02353
02354 #ifndef NDEBUG
02355     // Check that writer is correct with regards to which entities
02356     // that it owns by verifying that the file ids that we thought
02357     // we were sending where not received instead
02358     file_id_vect.resize( imesh.size() );
02359     rval = iFace->tag_get_data( file_id_tag, imesh, &file_id_vect[0] );
02360     if( MB_SUCCESS != rval )
02361     {
02362         iFace->tag_delete( file_id_tag );
02363         return error( rval );
02364     }
02365     int invalid_count = 0;
02366     j                 = file_id_vect.begin();
02367     for( i = imesh.begin(); i != imesh.end(); ++i, ++j )
02368     {
02369         EntityHandle h = idMap.find( *i );
02370         if( *j != h )
02371         {
02372             ++invalid_count;
02373             dbgOut.printf( 1, "Conflicting ownership for %s %ld\n", CN::EntityTypeName( TYPE_FROM_HANDLE( *i ) ),
02374                            (long)ID_FROM_HANDLE( *i ) );
02375         }
02376     }
02377     if( invalid_count )
02378     {
02379         iFace->tag_delete( file_id_tag );
02380         MB_SET_ERR( MB_FAILURE, invalid_count << " entities with conflicting ownership found by process "
02381                                               << myPcomm->proc_config().proc_rank()
02382                                               << ". This will result in duplicate entities written to file" );
02383     }
02384 #endif
02385
02386     return iFace->tag_delete( file_id_tag );
02387 }
02388
02389 void WriteHDF5Parallel::print_times( const double* times ) const
02390 {
02391     if( !myPcomm )
02392     {
02393         WriteHDF5::print_times( times );
02394     }
02395     else
02396     {
02397         double recv[NUM_TIMES];
02398         MPI_Reduce( (void*)times, recv, NUM_TIMES, MPI_DOUBLE, MPI_MAX, 0, myPcomm->proc_config().proc_comm() );
02399         if( 0 == myPcomm->proc_config().proc_rank() ) WriteHDF5::print_times( recv );
02400     }
02401 }
02402
02403 }  // namespace moab
