Adjacency data.
+ Collaboration diagram for Adjacency data.:
Functions
hid_t mhdf_createAdjacency (mhdf_FileHandle file_handle, const char *elem_handle, long adj_list_size, mhdf_Status *status)
 Create adjacency data table for nodes, elements, polys, etc.
int mhdf_haveAdjacency (mhdf_FileHandle file, const char *elem_handle, mhdf_Status *status)
 Check if adjacency data is present in the file for the specified element group.
hid_t mhdf_openAdjacency (mhdf_FileHandle file_handle, const char *elem_handle, long *adj_list_size, mhdf_Status *status)
 Open adjacency data table for nodes, elements, polys, etc.
void mhdf_writeAdjacency (hid_t data_handle, long offset, long count, hid_t hdf_integer_type, const void *adj_list_data, mhdf_Status *status)
 Write node/element adjacency data.
void mhdf_writeAdjacencyWithOpt (hid_t data_handle, long offset, long count, hid_t hdf_integer_type, const void *adj_list_data, hid_t write_prop, mhdf_Status *status)
void mhdf_readAdjacency (hid_t data_handle, long offset, long count, hid_t hdf_integer_type, void *adj_list_data_out, mhdf_Status *status)
 Read node/element adjacency data.
void mhdf_readAdjacencyWithOpt (hid_t data_handle, long offset, long count, hid_t hdf_integer_type, void *adj_list_data_out, hid_t read_prop, mhdf_Status *status)
Detailed Description
Adjacency data is formated as a sequence of integer groups where the first entry in each group is the ID of the element for which adjacencies are being specified, the second value is the count of adjacent entities, and the remainder of the group is the list of IDs of the adjacent entities.
Function Documentation
hid_t mhdf_createAdjacency ( mhdf_FileHandle  file_handle,
const char *  elem_handle,
long  adj_list_size,
mhdf_Status status
Create file object for adjacency data for a nodes or a specified element group.
Parameters:
file_handleThe file.
elem_handleThe element group (or the result of mhdf_node_type_handle for nodes) for which the adjacency data is to be specified.
adj_list_sizeThe total number of integer values contained in the adjacency data for the specified element group.
statusPassed back status of API call.
Returns:
The HDF5 handle to the connectivity data.
Definition at line 61 of file adjacency.c.
References ADJACENCY_NAME, API_BEGIN, API_END_H, dim, struct_FileHandle::hdf_handle, struct_FileHandle::id_type, mhdf_check_valid_file(), mhdf_create_table(), mhdf_elem_group_from_handle(), mhdf_node_type_handle(), mhdf_setFail(), and NODE_ADJCY_PATH.
Referenced by moab::WriteHDF5Parallel::create_adjacency_tables(), and moab::WriteHDF5::serial_create_file().
    FileHandle* file_ptr;
    hid_t elem_id, table_id;
    hsize_t dim = (hsize_t)adj_list_size;
    API_BEGIN;
    file_ptr = (FileHandle*)( file );
    if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
    if( adj_list_size < 1 )
        mhdf_setFail( status, "Invalid argument.\n" );
        return -1;
    if( elem_handle == mhdf_node_type_handle() )
        table_id = mhdf_create_table( file_ptr->hdf_handle, NODE_ADJCY_PATH, file_ptr->id_type, 1, &dim, status );
    else
        elem_id = mhdf_elem_group_from_handle( file_ptr, elem_handle, status );
        if( elem_id < 0 ) return -1;
        table_id = mhdf_create_table( elem_id, ADJACENCY_NAME, file_ptr->id_type, 1, &dim, status );
        H5Gclose( elem_id );
    API_END_H( 1 );
    return table_id;
int mhdf_haveAdjacency ( mhdf_FileHandle  file,
const char *  elem_group,
mhdf_Status status
Parameters:
fileThe file.
elem_handleA handle to an element group.
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 25 of file adjacency.c.
References ADJACENCY_NAME, API_BEGIN, API_END, struct_FileHandle::hdf_handle, mhdf_check_valid_file(), mhdf_elem_group_from_handle(), mhdf_is_in_group(), mhdf_node_type_handle(), mhdf_setFail(), mhdf_setOkay(), and NODE_GROUP.
Referenced by get_elem_desc().
    hid_t elem_id;
    int result;
    API_BEGIN;
    if( elem_group == mhdf_node_type_handle() )
#if defined( H5Gopen_vers ) && H5Gopen_vers > 1
        elem_id = H5Gopen( file_ptr->hdf_handle, NODE_GROUP, H5P_DEFAULT );
#else
        elem_id = H5Gopen( file_ptr->hdf_handle, NODE_GROUP );
#endif
        if( elem_id < 0 )
            mhdf_setFail( status, "H5Gopen( \"%s\" ) failed.\n", NODE_GROUP );
            return -1;
    else
        elem_id = mhdf_elem_group_from_handle( file_ptr, elem_group, status );
    result = mhdf_is_in_group( elem_id, ADJACENCY_NAME, status );
    mhdf_setOkay( status );
    API_END;
    return result;
hid_t mhdf_openAdjacency ( mhdf_FileHandle  file_handle,
long *  adj_list_size,
mhdf_Status status
Open the file object containing adjacency data for a nodes or a specified element group.
Parameters:
Returns:
Definition at line 94 of file adjacency.c.
References ADJACENCY_NAME, API_BEGIN, API_END_H, dim, struct_FileHandle::hdf_handle, mhdf_check_valid_file(), mhdf_elem_group_from_handle(), mhdf_node_type_handle(), mhdf_open_table(), mhdf_setFail(), and NODE_ADJCY_PATH.
Referenced by check_valid_adjacencies(), moab::ReadHDF5::load_file_impl(), moab::ReadHDF5::load_file_partial(), and moab::WriteHDF5::write_adjacencies().
    hsize_t dim;
    API_BEGIN;
    if( !adj_list_size_out )
        return -1;
        table_id = mhdf_open_table( file_ptr->hdf_handle, NODE_ADJCY_PATH, 1, &dim, status );
    else
        table_id = mhdf_open_table( elem_id, ADJACENCY_NAME, 1, &dim, status );
    *adj_list_size_out = (long)dim;
    API_END_H( 1 );
    return table_id;
void mhdf_readAdjacency ( hid_t  data_handle,
long  offset,
long  count,
void *  adj_list_data_out,
mhdf_Status status
Read adjacency data.
Parameters:
data_handleHandle returned from mhdf_createAdjacency or mhdf_openAdjacency.
offsetList position at which to start reading. Offset is from the count if integer values written, NOT a count of the number of elements for which adjacency data is written.
countNumber of integer values to reading.
hdf_integer_typeThe type of the integer data in adj_list_data_out. Typically H5T_NATIVE_INT or N5T_NATIVE_LONG as defined in H5Tpublic.h. The HDF class of this type object must be H5T_INTEGER
adj_list_data_outPointer to memory at which to write adjacency data.
Definition at line 148 of file adjacency.c.
References API_BEGIN, API_END, and mhdf_read_data().
Referenced by check_valid_adjacencies().
    API_BEGIN;
    mhdf_read_data( table_id, offset, count, type, data, H5P_DEFAULT, status );
    API_END;
void mhdf_readAdjacencyWithOpt ( hid_t  data_handle,
long  offset,
long  count,
hid_t  read_prop,
mhdf_Status status
Definition at line 154 of file adjacency.c.
Referenced by moab::ReadHDF5::read_adjacencies().
    API_BEGIN;
    mhdf_read_data( table_id, offset, count, type, data, prop, status );
    API_END;
void mhdf_writeAdjacency ( hid_t  data_handle,
long  offset,
long  count,
const void *  adj_list_data,
mhdf_Status status
Write adjacency data.
Parameters:
offsetList position at which to start writing. Offset is from the count if integer values written, NOT a count of the number of elements for which adjacency data is written.
countNumber of integer values to write.
hdf_integer_typeThe type of the integer data in adj_list_data. Typically H5T_NATIVE_INT or N5T_NATIVE_LONG as defined in H5Tpublic.h. The HDF class of this type object must be H5T_INTEGER
adj_list_dataAdjacency data to write.
Definition at line 128 of file adjacency.c.
References API_BEGIN, API_END, and mhdf_write_data().
    API_BEGIN;
    mhdf_write_data( table_id, offset, count, type, data, H5P_DEFAULT, status );
    API_END;
void mhdf_writeAdjacencyWithOpt ( hid_t  data_handle,
long  offset,
long  count,
hid_t  write_prop,
mhdf_Status status
Definition at line 135 of file adjacency.c.
Referenced by moab::WriteHDF5::write_adjacencies().
    API_BEGIN;
    mhdf_write_data( table_id, offset, count, type, data, prop, status );
    API_END;
