moab::EdgeSizeSimpleImplicit Class Reference
#include <EdgeSizeSimpleImplicit.hpp>
+ Inheritance diagram for moab::EdgeSizeSimpleImplicit:
+ Collaboration diagram for moab::EdgeSizeSimpleImplicit:
Public Member Functions
 EdgeSizeSimpleImplicit ()
 Construct an evaluator.
virtual ~EdgeSizeSimpleImplicit ()
 Destruction is virtual so subclasses may clean up after refinement.
virtual bool evaluate_edge (const double *p0, const void *t0, double *p1, void *t1, const double *p2, const void *t2)
 Given an edge of length L, true when edge midpoint is within $^2$ of $({2f(x,y,z)}{L})^2$.
virtual void set_implicit_function (double *coeffs)
 Set the 10 coefficients of the implicit function. The vector contains the entries of A, followed by B, followed by C.
void get_implicit_function (double *&coeffs)
 Get the 10 coefficients of the implicit function. The vector contains the entries of A, followed by B, followed by C.
virtual void set_ratio (double r)
 Set the threshold ratio of function value to half-edge length that triggers subdivision.
double get_ratio ()
 Get the threshold ratio of function value to half-edge length that triggers subdivision.
Protected Attributes
double coeffA [6]
double coeffB [3]
double coeffC
double ratio
Detailed Description
This is an simple example edge evaluator tha subdivides edges based on their midpoint's distance to a simple, fixed-form implicit surface written as \( x^T A x + B x + C \) where \(x\) is a column vector of holding the edge midpoint coordinates, \(A\) is a symmetric 3x3 matrix, \(B\) is a 1x3 row vector, and \(C\) is a scalar. Whenever the implicit function divided by half of the edge length is smaller than some minimum ratio (which defaults to 1), the edge is marked for subdivision.
Author:
David Thompson
Date:
19 November 2007
Definition at line 38 of file EdgeSizeSimpleImplicit.hpp.
Definition at line 6 of file EdgeSizeSimpleImplicit.cpp.
References coeffA, coeffB, coeffC, and ratio.
    int i;
    // Default to the plane: x = 0.
    this->coeffC = 0.;
    for( i = 0; i < 3; ++i )
        this->coeffB[i] = this->coeffA[i] = this->coeffA[i + 3] = 0.;
    this->coeffB[0] = 1.;
    // Default to a scaling ratio of 1.
    this->ratio = 1.;
Definition at line 20 of file EdgeSizeSimpleImplicit.cpp.
Member Function Documentation
bool moab::EdgeSizeSimpleImplicit::evaluate_edge ( const double *  p0,
const void *  t0,
double *  p1,
void *  t1,
const double *  p2,
const void *  t2
) [virtual]
Implements moab::EdgeSizeEvaluator.
Definition at line 22 of file EdgeSizeSimpleImplicit.cpp.
    (void)t0;
    (void)t1;
    (void)t2;
    double L2 = 0.;
    double delta;
    int i;
        delta = p2[i + 3] - p0[i + 3];
        L2 += delta * delta;
    // parametric coords in p1[{0,1,2}]
    double x  = p1[3];
    double y  = p1[4];
    double z  = p1[5];
    double F2 = this->coeffA[0] * x * x + 2. * this->coeffA[1] * x * y + 2. * this->coeffA[2] * x * z +
                this->coeffA[3] * y * y + 2. * this->coeffA[4] * y * z + this->coeffA[5] * z * z + this->coeffB[0] * x +
                this->coeffB[1] * y + this->coeffB[2] * z + this->coeffC;
    F2        = F2 * F2;  // square it
    double r2 = this->ratio * this->ratio;
    if( 4. * F2 / L2 < r2 ) return true;  // Midpoint is close to surface => split edge
    return false;  // Don't split edge
Definition at line 67 of file EdgeSizeSimpleImplicit.cpp.
References coeffA, coeffB, and coeffC.
    int i;
        coeffs[i]     = this->coeffA[i];
        coeffs[i + 3] = this->coeffA[i + 3];
        coeffs[i + 6] = this->coeffB[i];
    coeffs[9] = this->coeffC;
Definition at line 69 of file EdgeSizeSimpleImplicit.hpp.
References ratio.
        return this->ratio;
void moab::EdgeSizeSimpleImplicit::set_implicit_function ( double *  coeffs) [virtual]
Definition at line 54 of file EdgeSizeSimpleImplicit.cpp.
    int i;
        this->coeffA[i]     = coeffs[i];
        this->coeffA[i + 3] = coeffs[i + 3];
        this->coeffB[i]     = coeffs[i + 6];
    this->coeffC = coeffs[9];
virtual void moab::EdgeSizeSimpleImplicit::set_ratio ( double  r) [inline, virtual]
Definition at line 64 of file EdgeSizeSimpleImplicit.hpp.
References ratio.
Referenced by TestMeshRefiner().
        this->ratio = r;
Member Data Documentation
List of all members.
