moab::NCHelperMPAS Member List
This is the complete list of members for moab::NCHelperMPAS, including all inherited members.
_fileIdmoab::NCHelper [protected]
_fileSetmoab::NCHelper [protected]
_optsmoab::NCHelper [protected]
_readNCmoab::NCHelper [protected]
can_read_file(ReadNC *readNC)moab::NCHelperMPAS [static]
cDimmoab::UcdNCHelper [protected]
cellHandleToGlobalIDmoab::NCHelperMPAS [private]
check_existing_mesh()moab::NCHelperMPAS [private, virtual]
create_attrib_string(const std::map< std::string, ReadNC::AttData > &attMap, std::string &attString, std::vector< int > &attLen)moab::NCHelper [protected]
create_conventional_tags(const std::vector< int > &tstep_nums)moab::NCHelper
create_dummy_variables()moab::NCHelper [protected]
create_gather_set_cells(EntityHandle gather_set, EntityHandle gather_set_start_vertex)moab::NCHelperMPAS [private]
create_gather_set_edges(EntityHandle gather_set, EntityHandle gather_set_start_vertex)moab::NCHelperMPAS [private]
create_gather_set_vertices(EntityHandle gather_set, EntityHandle &gather_set_start_vertex)moab::NCHelperMPAS [private]
create_local_cells(const std::vector< int > &vertices_on_local_cells, const std::vector< int > &num_edges_on_local_cells, EntityHandle start_vertex, Range &faces)moab::NCHelperMPAS [private]
create_local_edges(EntityHandle start_vertex, const std::vector< int > &num_edges_on_local_cells)moab::NCHelperMPAS [private]
create_local_vertices(const std::vector< int > &vertices_on_local_cells, EntityHandle &start_vertex)moab::NCHelperMPAS [private]
create_mesh(Range &faces)moab::NCHelperMPAS [private, virtual]
create_padded_gather_set_cells(EntityHandle gather_set, EntityHandle gather_set_start_vertex)moab::NCHelperMPAS [private]
create_padded_local_cells(const std::vector< int > &vertices_on_local_cells, EntityHandle start_vertex, Range &faces)moab::NCHelperMPAS [private]
createGatherSetmoab::NCHelperMPAS [private]
dummyVarNamesmoab::NCHelper [protected]
eDimmoab::UcdNCHelper [protected]
facesOwnedmoab::NCHelperMPAS [private]
get_mesh_type_name()moab::NCHelperMPAS [inline, private, virtual]
get_nc_helper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::NCHelper [static]
get_tag_to_nonset(ReadNC::VarData &var_data, int tstep_num, Tag &tagh, int num_lev)moab::NCHelper [protected]
get_tag_to_set(ReadNC::VarData &var_data, int tstep_num, Tag &tagh)moab::NCHelper [protected]
ignoredVarNamesmoab::NCHelper [protected]
init_mesh_vals()moab::NCHelperMPAS [private, virtual]
kji_to_jik_stride(size_t, size_t nj, size_t nk, void *dest, T *source, Range &localGid)moab::UcdNCHelper [inline, protected]
levDimmoab::NCHelper [protected]
levValsmoab::NCHelper [protected]
localGidCellsmoab::UcdNCHelper [protected]
localGidEdgesmoab::UcdNCHelper [protected]
localGidVertsmoab::UcdNCHelper [protected]
maxEdgesPerCellmoab::NCHelperMPAS [private]
nCellsmoab::UcdNCHelper [protected]
NCHelper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::NCHelper [inline]
NCHelperMPAS(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::NCHelperMPAS
nEdgesmoab::UcdNCHelper [protected]
nLevelsmoab::NCHelper [protected]
nLocalCellsmoab::UcdNCHelper [protected]
nLocalEdgesmoab::UcdNCHelper [protected]
nLocalVerticesmoab::UcdNCHelper [protected]
nTimeStepsmoab::NCHelper [protected]
numCellGroupsmoab::NCHelperMPAS [private]
nVerticesmoab::UcdNCHelper [protected]
read_coordinate(const char *var_name, int lmin, int lmax, std::vector< double > &cvals)moab::NCHelper [protected]
read_ucd_variables_to_nonset(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)moab::NCHelperMPAS [private, virtual]
read_ucd_variables_to_nonset_allocate(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)moab::NCHelperMPAS [private, virtual]
read_variables_setup(std::vector< std::string > &var_names, std::vector< int > &tstep_nums, std::vector< ReadNC::VarData > &vdatas, std::vector< ReadNC::VarData > &vsetdatas)moab::NCHelper [protected]
read_variables_to_set(std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)moab::NCHelper [protected]
tDimmoab::NCHelper [protected]
tValsmoab::NCHelper [protected]
UcdNCHelper(ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)moab::UcdNCHelper [inline]
update_time_tag_vals()moab::NCHelper
vDimmoab::UcdNCHelper [protected]
xVertValsmoab::UcdNCHelper [protected]
yVertValsmoab::UcdNCHelper [protected]
zVertValsmoab::UcdNCHelper [protected]
~NCHelper()moab::NCHelper [inline, virtual]
~UcdNCHelper()moab::UcdNCHelper [inline, virtual]
