moab::NCHelperMPAS Class Reference
Child helper class for MPAS grid. More...
#include <NCHelperMPAS.hpp>
+ Inheritance diagram for moab::NCHelperMPAS:
+ Collaboration diagram for moab::NCHelperMPAS:
Public Member Functions
 NCHelperMPAS (ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet)
Static Public Member Functions
static bool can_read_file (ReadNC *readNC)
Private Member Functions
virtual ErrorCode init_mesh_vals ()
 Implementation of NCHelper::init_mesh_vals()
virtual ErrorCode check_existing_mesh ()
 Implementation of NCHelper::check_existing_mesh()
virtual ErrorCode create_mesh (Range &faces)
 Implementation of NCHelper::create_mesh()
virtual std::string get_mesh_type_name ()
 Implementation of NCHelper::get_mesh_type_name()
virtual ErrorCode read_ucd_variables_to_nonset_allocate (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)
 Implementation of UcdNCHelper::read_ucd_variables_to_nonset_allocate()
virtual ErrorCode read_ucd_variables_to_nonset (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums)
 Implementation of UcdNCHelper::read_ucd_variables_to_nonset()
ErrorCode create_local_vertices (const std::vector< int > &vertices_on_local_cells, EntityHandle &start_vertex)
 Create local vertices.
ErrorCode create_local_edges (EntityHandle start_vertex, const std::vector< int > &num_edges_on_local_cells)
 Create local edges (optional)
ErrorCode create_local_cells (const std::vector< int > &vertices_on_local_cells, const std::vector< int > &num_edges_on_local_cells, EntityHandle start_vertex, Range &faces)
 Create local cells without padding (cells are divided into groups based on the number of edges)
ErrorCode create_padded_local_cells (const std::vector< int > &vertices_on_local_cells, EntityHandle start_vertex, Range &faces)
 Create local cells with padding (padded cells will have the same number of edges)
ErrorCode create_gather_set_vertices (EntityHandle gather_set, EntityHandle &gather_set_start_vertex)
 Create gather set vertices.
ErrorCode create_gather_set_edges (EntityHandle gather_set, EntityHandle gather_set_start_vertex)
 Create gather set edges (optional)
ErrorCode create_gather_set_cells (EntityHandle gather_set, EntityHandle gather_set_start_vertex)
 Create gather set cells without padding (cells are divided into groups based on the number of edges)
ErrorCode create_padded_gather_set_cells (EntityHandle gather_set, EntityHandle gather_set_start_vertex)
 Create gather set cells with padding (padded cells will have the same number of edges)
Private Attributes
int maxEdgesPerCell
int numCellGroups
bool createGatherSet
std::map< EntityHandle, int > cellHandleToGlobalID
Range facesOwned
Detailed Description
Definition at line 20 of file NCHelperMPAS.hpp.
moab::NCHelperMPAS::NCHelperMPAS ( ReadNC readNC,
int  fileId,
const FileOptions opts,
Definition at line 18 of file NCHelperMPAS.cpp.
References moab::NCHelper::ignoredVarNames.
    : UcdNCHelper( readNC, fileId, opts, fileSet ), maxEdgesPerCell( DEFAULT_MAX_EDGES_PER_CELL ), numCellGroups( 0 ),
      createGatherSet( false )
    // Ignore variables containing topological information
    ignoredVarNames.insert( "nEdgesOnEdge" );
    ignoredVarNames.insert( "nEdgesOnCell" );
    ignoredVarNames.insert( "edgesOnVertex" );
    ignoredVarNames.insert( "cellsOnVertex" );
    ignoredVarNames.insert( "verticesOnEdge" );
    ignoredVarNames.insert( "edgesOnEdge" );
    ignoredVarNames.insert( "cellsOnEdge" );
    ignoredVarNames.insert( "verticesOnCell" );
    ignoredVarNames.insert( "edgesOnCell" );
    ignoredVarNames.insert( "cellsOnCell" );
    // ignore variables containing mesh related info, that are currently saved as variable tags on
    // file set ; if needed, these should be saved as dense tags, and read accordingly, in parallel
    ignoredVarNames.insert( "weightsOnEdge" );
    ignoredVarNames.insert( "angleEdge" );
    ignoredVarNames.insert( "areaCell" );
    ignoredVarNames.insert( "areaTriangle" );
    ignoredVarNames.insert( "dcEdge" );
    ignoredVarNames.insert( "dv1Edge" );
    ignoredVarNames.insert( "dv2Edge" );
    ignoredVarNames.insert( "fEdge" );
    ignoredVarNames.insert( "fVertex" );
    ignoredVarNames.insert( "h_s" );
    ignoredVarNames.insert( "kiteAreasOnVertex" );
    ignoredVarNames.insert( "latCell" );
    ignoredVarNames.insert( "latEdge" );
    ignoredVarNames.insert( "latVertex" );
    ignoredVarNames.insert( "lonCell" );
    ignoredVarNames.insert( "lonEdge" );
    ignoredVarNames.insert( "lonVertex" );
    ignoredVarNames.insert( "meshDensity" );
    ignoredVarNames.insert( "xCell" );
    ignoredVarNames.insert( "xEdge" );
    ignoredVarNames.insert( "xVertex" );
    ignoredVarNames.insert( "yCell" );
    ignoredVarNames.insert( "yEdge" );
    ignoredVarNames.insert( "yVertex" );
    ignoredVarNames.insert( "zCell" );
    ignoredVarNames.insert( "zEdge" );
    ignoredVarNames.insert( "zVertex" );
    // Ignore variables for index conversion
    ignoredVarNames.insert( "indexToVertexID" );
    ignoredVarNames.insert( "indexToEdgeID" );
    ignoredVarNames.insert( "indexToCellID" );
Member Function Documentation
bool moab::NCHelperMPAS::can_read_file ( ReadNC readNC) [static]
Definition at line 68 of file NCHelperMPAS.cpp.
References moab::ReadNC::dimNames.
Referenced by moab::NCHelper::get_nc_helper().
    std::vector< std::string >& dimNames = readNC->dimNames;
    // If dimension name "vertexDegree" exists then it should be the MPAS grid
    if( std::find( dimNames.begin(), dimNames.end(), std::string( "vertexDegree" ) ) != dimNames.end() ) return true;
    return false;
Implements moab::NCHelper.
Definition at line 247 of file NCHelperMPAS.cpp.
References moab::Range::begin(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TYPE_INTEGER, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    Interface*& mbImpl = _readNC->mbImpl;
    Tag& mGlobalIdTag  = _readNC->mGlobalIdTag;
    bool& noMesh       = _readNC->noMesh;
    if( noMesh )
        ErrorCode rval;
        // Restore numCellGroups
        if( 0 == numCellGroups )
            Tag numCellGroupsTag;
            rval = mbImpl->tag_get_handle( "__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag );MB_CHK_SET_ERR( rval, "Trouble getting __NUM_CELL_GROUPS tag" );
            if( MB_SUCCESS == rval ) rval = mbImpl->tag_get_data( numCellGroupsTag, &_fileSet, 1, &numCellGroups );MB_CHK_SET_ERR( rval, "Trouble getting data of __NUM_CELL_GROUPS tag" );
        if( localGidVerts.empty() )
            // Get all vertices from current file set (it is the input set in no_mesh scenario)
            Range local_verts;
            rval = mbImpl->get_entities_by_dimension( _fileSet, 0, local_verts );MB_CHK_SET_ERR( rval, "Trouble getting local vertices in current file set" );
            if( !local_verts.empty() )
                std::vector< int > gids( local_verts.size() );
                // !IMPORTANT : this has to be the GLOBAL_ID tag
                rval = mbImpl->tag_get_data( mGlobalIdTag, local_verts, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of vertices" );
                // Restore localGidVerts
                std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidVerts ) );
                nLocalVertices = localGidVerts.size();
        if( localGidEdges.empty() )
            // Get all edges from current file set (it is the input set in no_mesh scenario)
            Range local_edges;
            rval = mbImpl->get_entities_by_dimension( _fileSet, 1, local_edges );MB_CHK_SET_ERR( rval, "Trouble getting local edges in current file set" );
            if( !local_edges.empty() )
                std::vector< int > gids( local_edges.size() );
                rval = mbImpl->tag_get_data( mGlobalIdTag, local_edges, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of edges" );
                // Restore localGidEdges
                std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidEdges ) );
                nLocalEdges = localGidEdges.size();
        if( localGidCells.empty() )
            // Get all cells from current file set (it is the input set in no_mesh scenario)
            Range local_cells;
            rval = mbImpl->get_entities_by_dimension( _fileSet, 2, local_cells );MB_CHK_SET_ERR( rval, "Trouble getting local cells in current file set" );
            if( !local_cells.empty() )
                std::vector< int > gids( local_cells.size() );
                rval = mbImpl->tag_get_data( mGlobalIdTag, local_cells, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of cells" );
                // Restore localGidCells
                std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidCells ) );
                nLocalCells = localGidCells.size();
                if( numCellGroups > 1 )
                    // Restore cellHandleToGlobalID map
                    Range::const_iterator rit;
                    int i;
                    for( rit = local_cells.begin(), i = 0; rit != local_cells.end(); ++rit, i++ )
                        cellHandleToGlobalID[*rit] = gids[i];
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::create_gather_set_cells ( EntityHandle  gather_set,
) [private]
Definition at line 1629 of file NCHelperMPAS.cpp.
References moab::Interface::add_entities(), moab::DEFAULT_MAX_EDGES_PER_CELL, ErrorCode, moab::Range::insert(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBPOLYGON, NCDF_SIZE, NCFUNC, NCFUNCG, and moab::Range::size().
    // Read number of edges on each gather set cell
    int nEdgesOnCellVarId;
    int success = NCFUNC( inq_varid )( _fileId, "nEdgesOnCell", &nEdgesOnCellVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of nEdgesOnCell" );
    std::vector< int > num_edges_on_gather_set_cells( nCells );
    NCDF_SIZE read_start = 0;
    NCDF_SIZE read_count = static_cast< NCDF_SIZE >( nCells );
#ifdef MOAB_HAVE_PNETCDF
    // Enter independent I/O mode, since this read is only for the gather processor
    success = NCFUNC( begin_indep_data )( _fileId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
    success =
        NCFUNCG( _vara_int )( _fileId, nEdgesOnCellVarId, &read_start, &read_count, &num_edges_on_gather_set_cells[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read nEdgesOnCell data" );
    success = NCFUNC( end_indep_data )( _fileId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
#else
    success =
#endif
    // Read vertices on each gather set cell (connectivity)
    int verticesOnCellVarId;
    success = NCFUNC( inq_varid )( _fileId, "verticesOnCell", &verticesOnCellVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of verticesOnCell" );
    std::vector< int > vertices_on_gather_set_cells( nCells * maxEdgesPerCell );
    NCDF_SIZE read_starts[2] = { 0, 0 };
    NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( nCells ), static_cast< NCDF_SIZE >( maxEdgesPerCell ) };
    success = NCFUNCG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
                                    &vertices_on_gather_set_cells[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnCell data" );
#else
#endif
    // Divide gather set cells into groups based on the number of edges
    Range gather_set_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
    // Insert larger values before smaller values to increase efficiency
    for( int i = nCells - 1; i >= 0; i-- )
        int num_edges = num_edges_on_gather_set_cells[i];
        gather_set_cells_with_n_edges[num_edges].insert( i + 1 );  // 0 based -> 1 based
    // Create gather set cells
    EntityHandle* conn_arr_gather_set_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
    for( int num_edges_per_cell = 3; num_edges_per_cell <= maxEdgesPerCell; num_edges_per_cell++ )
        int num_group_cells = gather_set_cells_with_n_edges[num_edges_per_cell].size();
        if( num_group_cells > 0 )
            EntityHandle start_element;
            ErrorCode rval = _readNC->readMeshIface->get_element_connect(
                num_group_cells, num_edges_per_cell, MBPOLYGON, 0, start_element,
                conn_arr_gather_set_cells_with_n_edges[num_edges_per_cell], num_group_cells );MB_CHK_SET_ERR( rval, "Failed to create gather set cells" );
            // Add cells to the gather set
            Range gather_set_cells_range( start_element, start_element + num_group_cells - 1 );
            rval = mbImpl->add_entities( gather_set, gather_set_cells_range );MB_CHK_SET_ERR( rval, "Failed to add cells to the gather set" );
            for( int j = 0; j < num_group_cells; j++ )
                int gather_set_cell_idx =
                    gather_set_cells_with_n_edges[num_edges_per_cell][j];  // Global cell index, 1 based
                gather_set_cell_idx--;                                     // 1 based -> 0 based
                for( int k = 0; k < num_edges_per_cell; k++ )
                    EntityHandle gather_set_vert_idx =
                        vertices_on_gather_set_cells[gather_set_cell_idx * maxEdgesPerCell +
                                                     k];  // Global vertex index, 1 based
                    gather_set_vert_idx--;                // 1 based -> 0 based
                    // Connectivity array is shifted by where the gather set vertices start
                    conn_arr_gather_set_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
                        gather_set_start_vertex + gather_set_vert_idx;
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::create_gather_set_edges ( EntityHandle  gather_set,
) [private]
Definition at line 1576 of file NCHelperMPAS.cpp.
References moab::Interface::add_entities(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBEDGE, NCDF_SIZE, NCFUNC, and NCFUNCG.
    // Create gather set edges
    EntityHandle start_edge;
    EntityHandle* conn_arr_gather_set_edges = NULL;
    // Don't need to specify allocation number here, because we know enough edges were created
    // before
    ErrorCode rval =
        _readNC->readMeshIface->get_element_connect( nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_set_edges );MB_CHK_SET_ERR( rval, "Failed to create gather set edges" );
    // Add edges to the gather set
    Range gather_set_edges_range( start_edge, start_edge + nEdges - 1 );
    rval = mbImpl->add_entities( gather_set, gather_set_edges_range );MB_CHK_SET_ERR( rval, "Failed to add edges to the gather set" );
    // Read vertices on each edge
    int verticesOnEdgeVarId;
    int success = NCFUNC( inq_varid )( _fileId, "verticesOnEdge", &verticesOnEdgeVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of verticesOnEdge" );
    // Utilize the memory storage pointed by conn_arr_gather_set_edges
    int* vertices_on_gather_set_edges = (int*)conn_arr_gather_set_edges;
    NCDF_SIZE read_counts[2]          = { static_cast< NCDF_SIZE >( nEdges ), 2 };
    success =
        NCFUNCG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts, vertices_on_gather_set_edges );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnEdge data" );
#else
    success =
#endif
    // Populate connectivity data for gather set edges
    // Convert in-place from int (stored in the first half) to EntityHandle
    // Reading backward is the trick
    for( int edge_vert = nEdges * 2 - 1; edge_vert >= 0; edge_vert-- )
        int gather_set_vert_idx = vertices_on_gather_set_edges[edge_vert];  // Global vertex index, 1 based
        conn_arr_gather_set_edges[edge_vert] = gather_set_start_vertex + gather_set_vert_idx;
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::create_gather_set_vertices ( EntityHandle  gather_set,
) [private]
Definition at line 1469 of file NCHelperMPAS.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::end(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, NCDF_SIZE, NCFUNC, NCFUNCG, moab::Interface::tag_get_bytes(), and moab::Interface::tag_iterate().
    const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
    // Create gather set vertices
    std::vector< double* > arrays;
    // Don't need to specify allocation number here, because we know enough vertices were created
    // before
    ErrorCode rval = _readNC->readMeshIface->get_node_coords( 3, nVertices, 0, gather_set_start_vertex, arrays );MB_CHK_SET_ERR( rval, "Failed to create gather set vertices" );
    // Add vertices to the gather set
    Range gather_set_verts_range( gather_set_start_vertex, gather_set_start_vertex + nVertices - 1 );
    rval = mbImpl->add_entities( gather_set, gather_set_verts_range );MB_CHK_SET_ERR( rval, "Failed to add vertices to the gather set" );
    // Read x coordinates for gather set vertices
    double* xptr = arrays[0];
    int xVertexVarId;
    int success = NCFUNC( inq_varid )( _fileId, "xVertex", &xVertexVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of xVertex" );
    NCDF_SIZE read_count = static_cast< NCDF_SIZE >( nVertices );
    success = NCFUNCG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, xptr );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read xVertex data" );
#else
#endif
    // Read y coordinates for gather set vertices
    double* yptr = arrays[1];
    int yVertexVarId;
    success = NCFUNC( inq_varid )( _fileId, "yVertex", &yVertexVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of yVertex" );
    success = NCFUNCG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, yptr );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read yVertex data" );
#else
#endif
    // Read z coordinates for gather set vertices
    double* zptr = arrays[2];
    int zVertexVarId;
    success = NCFUNC( inq_varid )( _fileId, "zVertex", &zVertexVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of zVertex" );
    success = NCFUNCG( _vara_double )( _fileId, zVertexVarId, &read_start, &read_count, zptr );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read zVertex data" );
#else
#endif
    // Get ptr to GID memory for gather set vertices
    int count  = 0;
    void* data = NULL;
    rval =
        mbImpl->tag_iterate( mGlobalIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on gather set vertices" );
    assert( count == nVertices );
    int* gid_data = (int*)data;
    for( int j = 1; j <= nVertices; j++ )
        gid_data[j - 1] = j;
    // Set the file id tag too, it should be bigger something not interfering with global id
    if( mpFileIdTag )
        rval = mbImpl->tag_iterate( *mpFileIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count,
                                    data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on gather set vertices" );
        int bytes_per_tag = 4;
        rval              = mbImpl->tag_get_bytes( *mpFileIdTag, bytes_per_tag );MB_CHK_SET_ERR( rval, "Can't get number of bytes for file id tag" );
        if( 4 == bytes_per_tag )
                gid_data[j - 1] = nVertices + j;  // Bigger than global id tag
        else if( 8 == bytes_per_tag )
        {  // Should be a handle tag on 64 bit machine?
            long* handle_tag_data = (long*)data;
                handle_tag_data[j - 1] = nVertices + j;  // Bigger than global id tag
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::create_local_cells ( const std::vector< int > &  vertices_on_local_cells,
const std::vector< int > &  num_edges_on_local_cells,
Range faces
) [private]
Definition at line 1340 of file NCHelperMPAS.cpp.
References moab::Range::begin(), moab::DEFAULT_MAX_EDGES_PER_CELL, moab::Range::end(), ErrorCode, moab::Range::index(), moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, MBPOLYGON, size, and moab::Interface::tag_iterate().
    // Divide local cells into groups based on the number of edges
    Range local_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
    // Insert larger values before smaller ones to increase efficiency
    for( int i = nLocalCells - 1; i >= 0; i-- )
        int num_edges = num_edges_on_local_cells[i];
        local_cells_with_n_edges[num_edges].insert( localGidCells[i] );  // Global cell index
    std::vector< int > num_edges_on_cell_groups;
    for( int i = 3; i <= maxEdgesPerCell; i++ )
        if( local_cells_with_n_edges[i].size() > 0 ) num_edges_on_cell_groups.push_back( i );
    numCellGroups = num_edges_on_cell_groups.size();
    EntityHandle* conn_arr_local_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
    for( int i = 0; i < numCellGroups; i++ )
        int num_edges_per_cell = num_edges_on_cell_groups[i];
        int num_group_cells    = (int)local_cells_with_n_edges[num_edges_per_cell].size();
        // Create local cells for each non-empty cell group
            conn_arr_local_cells_with_n_edges[num_edges_per_cell], num_group_cells );MB_CHK_SET_ERR( rval, "Failed to create local cells" );
        faces.insert( start_element, start_element + num_group_cells - 1 );
        // Add local cells to current file set
        Range local_cells_range( start_element, start_element + num_group_cells - 1 );
        rval = _readNC->mbImpl->add_entities( _fileSet, local_cells_range );MB_CHK_SET_ERR( rval, "Failed to add local cells to current file set" );
        // Get ptr to gid memory for local cells
        int count  = 0;
        void* data = NULL;
        rval = mbImpl->tag_iterate( mGlobalIdTag, local_cells_range.begin(), local_cells_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local cells" );
        assert( count == num_group_cells );
        std::copy( local_cells_with_n_edges[num_edges_per_cell].begin(),
                   local_cells_with_n_edges[num_edges_per_cell].end(), gid_data );
        // Set connectivity array with proper local vertices handles
            EntityHandle global_cell_idx =
                local_cells_with_n_edges[num_edges_per_cell][j];          // Global cell index, 1 based
            int local_cell_idx = localGidCells.index( global_cell_idx );  // Local cell index, 0 based
            assert( local_cell_idx != -1 );
                // Populate cellHandleToGlobalID map to read cell variables
                cellHandleToGlobalID[start_element + j] = global_cell_idx;
                EntityHandle global_vert_idx =
                    vertices_on_local_cells[local_cell_idx * maxEdgesPerCell + k];  // Global vertex index, 1 based
                int local_vert_idx = localGidVerts.index( global_vert_idx );        // Local vertex index, 0 based
                assert( local_vert_idx != -1 );
                conn_arr_local_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
                    start_vertex + local_vert_idx;
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::create_local_edges ( EntityHandle  start_vertex,
) [private]
Definition at line 1194 of file NCHelperMPAS.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBEDGE, NCDF_SIZE, NCFUNC, NCFUNCAG, moab::Interface::tag_iterate(), and moab::DebugOutput::tprintf().
    DebugOutput& dbgOut = _readNC->dbgOut;
    // Read edges on each local cell, to get localGidEdges
    int edgesOnCellVarId;
    int success = NCFUNC( inq_varid )( _fileId, "edgesOnCell", &edgesOnCellVarId );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of edgesOnCell" );
    std::vector< int > edges_on_local_cells( nLocalCells * maxEdgesPerCell );
    dbgOut.tprintf( 1, "   edges_on_local_cells.size() = %d\n", (int)edges_on_local_cells.size() );
    size_t nb_reads = localGidCells.psize();
    std::vector< int > requests( nb_reads );
    std::vector< int > statuss( nb_reads );
    size_t idxReq = 0;
#endif
    size_t indexInArray = 0;
    for( Range::pair_iterator pair_iter = localGidCells.pair_begin(); pair_iter != localGidCells.pair_end();
         ++pair_iter )
        EntityHandle starth      = pair_iter->first;
        EntityHandle endh        = pair_iter->second;
        NCDF_SIZE read_starts[2] = { static_cast< NCDF_SIZE >( starth - 1 ), 0 };
        NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ),
        // Do a partial read in each subrange
        success = NCFUNCREQG( _vara_int )( _fileId, edgesOnCellVarId, read_starts, read_counts,
                                           &( edges_on_local_cells[indexInArray] ), &requests[idxReq++] );
#else
        success = NCFUNCAG( _vara_int )( _fileId, edgesOnCellVarId, read_starts, read_counts,
                                         &( edges_on_local_cells[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read edgesOnCell data in a loop" );
        // Increment the index for next subrange
        indexInArray += ( endh - starth + 1 ) * maxEdgesPerCell;
    // Wait outside the loop
    success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
    if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
#endif
    // Correct local cell edges array in the same way as local cell vertices array, replace the
    // padded edges with the last edges in the corresponding cells
    for( int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++ )
        int num_edges             = num_edges_on_local_cells[local_cell_idx];
        int idx_in_local_edge_arr = local_cell_idx * maxEdgesPerCell;
        int last_edge_idx         = edges_on_local_cells[idx_in_local_edge_arr + num_edges - 1];
        for( int i = num_edges; i < maxEdgesPerCell; i++ )
            edges_on_local_cells[idx_in_local_edge_arr + i] = last_edge_idx;
    // Collect local edges
    std::sort( edges_on_local_cells.begin(), edges_on_local_cells.end() );
    std::copy( edges_on_local_cells.rbegin(), edges_on_local_cells.rend(), range_inserter( localGidEdges ) );
    dbgOut.tprintf( 1, "   localGidEdges.psize() = %d\n", (int)localGidEdges.psize() );
    dbgOut.tprintf( 1, "   localGidEdges.size() = %d\n", (int)localGidEdges.size() );
    // Create local edges
    EntityHandle* conn_arr_edges = NULL;
    ErrorCode rval =
        _readNC->readMeshIface->get_element_connect( nLocalEdges, 2, MBEDGE, 0, start_edge, conn_arr_edges,
                                                     // Might have to create gather mesh later
                                                     ( createGatherSet ? nLocalEdges + nEdges : nLocalEdges ) );MB_CHK_SET_ERR( rval, "Failed to create local edges" );
    // Add local edges to current file set
    Range local_edges_range( start_edge, start_edge + nLocalEdges - 1 );
    rval = _readNC->mbImpl->add_entities( _fileSet, local_edges_range );MB_CHK_SET_ERR( rval, "Failed to add local edges to current file set" );
    // Get ptr to GID memory for edges
    int count  = 0;
    void* data = NULL;
    rval       = mbImpl->tag_iterate( mGlobalIdTag, local_edges_range.begin(), local_edges_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local edges" );
    assert( count == nLocalEdges );
    std::copy( localGidEdges.begin(), localGidEdges.end(), gid_data );
    // Read vertices on each local edge, to get edge connectivity
    // Utilize the memory storage pointed by conn_arr_edges
    int* vertices_on_local_edges = (int*)conn_arr_edges;
    nb_reads = localGidEdges.psize();
    requests.resize( nb_reads );
    statuss.resize( nb_reads );
    idxReq = 0;
#endif
    indexInArray = 0;
    for( Range::pair_iterator pair_iter = localGidEdges.pair_begin(); pair_iter != localGidEdges.pair_end();
         ++pair_iter )
        NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ), 2 };
        success = NCFUNCREQG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts,
                                           &( vertices_on_local_edges[indexInArray] ), &requests[idxReq++] );
#else
        success = NCFUNCAG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts,
                                         &( vertices_on_local_edges[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnEdge data in a loop" );
        indexInArray += ( endh - starth + 1 ) * 2;
#endif
    // Populate connectivity data for local edges
    for( int edge_vert = nLocalEdges * 2 - 1; edge_vert >= 0; edge_vert-- )
        int global_vert_idx = vertices_on_local_edges[edge_vert];      // Global vertex index, 1 based
        conn_arr_edges[edge_vert] = start_vertex + local_vert_idx;
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::create_local_vertices ( const std::vector< int > &  vertices_on_local_cells,
) [private]
Definition at line 1022 of file NCHelperMPAS.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, NCDF_SIZE, NCFUNC, NCFUNCAG, moab::Interface::tag_get_bytes(), moab::Interface::tag_iterate(), and moab::DebugOutput::tprintf().
    // Make a copy of vertices_on_local_cells for sorting (keep original one to set cell
    // connectivity later)
    std::vector< int > vertices_on_local_cells_sorted( vertices_on_local_cells );
    std::sort( vertices_on_local_cells_sorted.begin(), vertices_on_local_cells_sorted.end() );
    std::copy( vertices_on_local_cells_sorted.rbegin(), vertices_on_local_cells_sorted.rend(),
    dbgOut.tprintf( 1, "   localGidVerts.psize() = %d\n", (int)localGidVerts.psize() );
    dbgOut.tprintf( 1, "   localGidVerts.size() = %d\n", (int)localGidVerts.size() );
    // Create local vertices
    ErrorCode rval =
        _readNC->readMeshIface->get_node_coords( 3, nLocalVertices, 0, start_vertex, arrays,
                                                 ( createGatherSet ? nLocalVertices + nVertices : nLocalVertices ) );MB_CHK_SET_ERR( rval, "Failed to create local vertices" );
    // Add local vertices to current file set
    Range local_verts_range( start_vertex, start_vertex + nLocalVertices - 1 );
    rval = _readNC->mbImpl->add_entities( _fileSet, local_verts_range );MB_CHK_SET_ERR( rval, "Failed to add local vertices to current file set" );
    // Get ptr to GID memory for local vertices
    int count  = 0;
    void* data = NULL;
    rval       = mbImpl->tag_iterate( mGlobalIdTag, local_verts_range.begin(), local_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local vertices" );
    assert( count == nLocalVertices );
    std::copy( localGidVerts.begin(), localGidVerts.end(), gid_data );
    // Duplicate GID data, which will be used to resolve sharing
    if( mpFileIdTag )
        rval = mbImpl->tag_iterate( *mpFileIdTag, local_verts_range.begin(), local_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on local vertices" );
            std::copy( localGidVerts.begin(), localGidVerts.end(), handle_tag_data );
    size_t nb_reads = localGidVerts.psize();
    size_t idxReq = 0;
#endif
    // Read x coordinates for local vertices
    int xVertexVarId;
    for( Range::pair_iterator pair_iter = localGidVerts.pair_begin(); pair_iter != localGidVerts.pair_end();
         ++pair_iter )
        NCDF_SIZE read_start = (NCDF_SIZE)( starth - 1 );
        NCDF_SIZE read_count = (NCDF_SIZE)( endh - starth + 1 );
        success = NCFUNCREQG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, &( xptr[indexInArray] ),
#else
        success = NCFUNCAG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, &( xptr[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read xVertex data in a loop" );
        indexInArray += ( endh - starth + 1 );
#endif
    // Read y coordinates for local vertices
    int yVertexVarId;
    idxReq = 0;
#endif
    indexInArray = 0;
         ++pair_iter )
        success = NCFUNCREQG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, &( yptr[indexInArray] ),
#else
        success = NCFUNCAG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, &( yptr[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read yVertex data in a loop" );
#endif
    // Read z coordinates for local vertices
    int zVertexVarId;
    idxReq = 0;
#endif
    indexInArray = 0;
         ++pair_iter )
        success = NCFUNCREQG( _vara_double )( _fileId, zVertexVarId, &read_start, &read_count, &( zptr[indexInArray] ),
#else
        success = NCFUNCAG( _vara_double )( _fileId, zVertexVarId, &read_start, &read_count, &( zptr[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read zVertex data in a loop" );
#endif
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::create_mesh ( Range faces) [private, virtual]
Definition at line 335 of file NCHelperMPAS.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, NCDF_SIZE, NCFUNC, NCFUNCAG, moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::DebugOutput::tprintf().
    bool& noMixedElements = _readNC->noMixedElements;
    bool& noEdges         = _readNC->noEdges;
#ifdef MOAB_HAVE_MPI
    int rank         = 0;
    int procs        = 1;
    bool& isParallel = _readNC->isParallel;
    ParallelComm* myPcomm = NULL;
    if( isParallel )
        myPcomm  = _readNC->myPcomm;
        rank                   = myPcomm->proc_config().proc_rank();
        procs                  = myPcomm->proc_config().proc_size();
    // Need to know whether we'll be creating gather mesh
    if( rank == _readNC->gatherSetRank ) createGatherSet = true;
    if( procs >= 2 )
        // Shift rank to obtain a rotated trivial partition
        int shifted_rank           = rank;
        int& trivialPartitionShift = _readNC->trivialPartitionShift;
        if( trivialPartitionShift > 0 ) shifted_rank = ( rank + trivialPartitionShift ) % procs;
        // Compute the number of local cells on this proc
        nLocalCells = int( std::floor( 1.0 * nCells / procs ) );
        // The starting global cell index in the MPAS file for this proc
        int start_cell_idx = shifted_rank * nLocalCells;
        // Number of extra cells after equal split over procs
        int iextra = nCells % procs;
        // Allocate extra cells over procs
        if( shifted_rank < iextra ) nLocalCells++;
        start_cell_idx += std::min( shifted_rank, iextra );
        start_cell_idx++;  // 0 based -> 1 based
        // Redistribute local cells after trivial partition (e.g. apply Zoltan partition)
        ErrorCode rval = redistribute_local_cells( start_cell_idx, myPcomm );MB_CHK_SET_ERR( rval, "Failed to redistribute local cells after trivial partition" );
    else
        nLocalCells = nCells;
        localGidCells.insert( 1, nLocalCells );
#else
#endif
    dbgOut.tprintf( 1, " localGidCells.psize() = %d\n", (int)localGidCells.psize() );
    dbgOut.tprintf( 1, " localGidCells.size() = %d\n", (int)localGidCells.size() );
    // Read number of edges on each local cell, to calculate actual maxEdgesPerCell
    std::vector< int > num_edges_on_local_cells( nLocalCells );
    size_t idxReq = 0;
#endif
         ++pair_iter )
        success = NCFUNCREQG( _vara_int )( _fileId, nEdgesOnCellVarId, &read_start, &read_count,
                                           &( num_edges_on_local_cells[indexInArray] ), &requests[idxReq++] );
#else
        success = NCFUNCAG( _vara_int )( _fileId, nEdgesOnCellVarId, &read_start, &read_count,
                                         &( num_edges_on_local_cells[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read nEdgesOnCell data in a loop" );
#endif
    // Get local maxEdgesPerCell on this proc
    int local_max_edges_per_cell =
        *( std::max_element( num_edges_on_local_cells.begin(), num_edges_on_local_cells.end() ) );
    maxEdgesPerCell = local_max_edges_per_cell;
    // If parallel, do a MPI_Allreduce to get global maxEdgesPerCell across all procs
    if( procs >= 2 )
        int global_max_edges_per_cell;
        ParallelComm*& myPcomm = _readNC->myPcomm;
        MPI_Allreduce( &local_max_edges_per_cell, &global_max_edges_per_cell, 1, MPI_INT, MPI_MAX,
                       myPcomm->proc_config().proc_comm() );
        assert( local_max_edges_per_cell <= global_max_edges_per_cell );
        maxEdgesPerCell = global_max_edges_per_cell;
        if( 0 == rank ) dbgOut.tprintf( 1, "  global_max_edges_per_cell = %d\n", global_max_edges_per_cell );
#endif
    // Read vertices on each local cell, to get localGidVerts and cell connectivity later
    std::vector< int > vertices_on_local_cells( nLocalCells * maxEdgesPerCell );
    idxReq = 0;
#endif
    indexInArray = 0;
         ++pair_iter )
        success = NCFUNCREQG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
                                           &( vertices_on_local_cells[indexInArray] ), &requests[idxReq++] );
#else
        success = NCFUNCAG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
                                         &( vertices_on_local_cells[indexInArray] ) );
#endif
        if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnCell data in a loop" );
#endif
    // Correct local cell vertices array, replace the padded vertices with the last vertices
    // in the corresponding cells; sometimes the padded vertices are 0, sometimes a large
    // vertex id. Make sure they are consistent to our padded option
        int idx_in_local_vert_arr = local_cell_idx * maxEdgesPerCell;
        int last_vert_idx         = vertices_on_local_cells[idx_in_local_vert_arr + num_edges - 1];
            vertices_on_local_cells[idx_in_local_vert_arr + i] = last_vert_idx;
    EntityHandle start_vertex;
    ErrorCode rval = create_local_vertices( vertices_on_local_cells, start_vertex );MB_CHK_SET_ERR( rval, "Failed to create local vertices for MPAS mesh" );
    // Create local edges (unless NO_EDGES read option is set)
    if( !noEdges )
        rval = create_local_edges( start_vertex, num_edges_on_local_cells );MB_CHK_SET_ERR( rval, "Failed to create local edges for MPAS mesh" );
    // Create local cells, either unpadded or padded
    if( noMixedElements )
        rval = create_padded_local_cells( vertices_on_local_cells, start_vertex, faces );MB_CHK_SET_ERR( rval, "Failed to create padded local cells for MPAS mesh" );
    else
        rval = create_local_cells( vertices_on_local_cells, num_edges_on_local_cells, start_vertex, faces );MB_CHK_SET_ERR( rval, "Failed to create local cells for MPAS mesh" );
    // Set tag for numCellGroups
    Tag numCellGroupsTag = 0;
    rval                 = mbImpl->tag_get_handle( "__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag,
                                                   MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating __NUM_CELL_GROUPS tag" );
    rval = mbImpl->tag_set_data( numCellGroupsTag, &_fileSet, 1, &numCellGroups );MB_CHK_SET_ERR( rval, "Trouble setting data to __NUM_CELL_GROUPS tag" );
    if( createGatherSet )
        EntityHandle gather_set;
        rval = _readNC->readMeshIface->create_gather_set( gather_set );MB_CHK_SET_ERR( rval, "Failed to create gather set" );
        EntityHandle start_gather_set_vertex;
        rval = create_gather_set_vertices( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set vertices for MPAS mesh" );
        // Create gather set edges (unless NO_EDGES read option is set)
        if( !noEdges )
            rval = create_gather_set_edges( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set edges for MPAS mesh" );
        // Create gather set cells, either unpadded or padded
            rval = create_padded_gather_set_cells( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create padded gather set cells for MPAS mesh" );
        else
            rval = create_gather_set_cells( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set cells for MPAS mesh" );
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::create_padded_gather_set_cells ( EntityHandle  gather_set,
) [private]
Definition at line 1726 of file NCHelperMPAS.cpp.
References moab::Interface::add_entities(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBPOLYGON, NCDF_SIZE, NCFUNC, and NCFUNCG.
    success =
#else
    success =
#endif
    EntityHandle* conn_arr_gather_set_cells = NULL;
    // Don't need to specify allocation number here, because we know enough cells were created
    // before
    ErrorCode rval = _readNC->readMeshIface->get_element_connect( nCells, maxEdgesPerCell, MBPOLYGON, 0, start_element,
        conn_arr_gather_set_cells );MB_CHK_SET_ERR( rval, "Failed to create gather set cells" );
    Range gather_set_cells_range( start_element, start_element + nCells - 1 );
    // Utilize the memory storage pointed by conn_arr_gather_set_cells
    int* vertices_on_gather_set_cells = (int*)conn_arr_gather_set_cells;
    success =
        NCFUNCG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts, vertices_on_gather_set_cells );
#else
    success =
#endif
    // Correct gather set cell vertices array in the same way as local cell vertices array,
    // replace the padded vertices with the last vertices in the corresponding cells
    for( int gather_set_cell_idx = 0; gather_set_cell_idx < nCells; gather_set_cell_idx++ )
        int num_edges                  = num_edges_on_gather_set_cells[gather_set_cell_idx];
        int idx_in_gather_set_vert_arr = gather_set_cell_idx * maxEdgesPerCell;
        int last_vert_idx              = vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + num_edges - 1];
            vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + i] = last_vert_idx;
    // Populate connectivity data for gather set cells
    for( int cell_vert = nCells * maxEdgesPerCell - 1; cell_vert >= 0; cell_vert-- )
        int gather_set_vert_idx = vertices_on_gather_set_cells[cell_vert];  // Global vertex index, 1 based
        conn_arr_gather_set_cells[cell_vert] = gather_set_start_vertex + gather_set_vert_idx;
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::create_padded_local_cells ( const std::vector< int > &  vertices_on_local_cells,
Range faces
) [private]
Definition at line 1419 of file NCHelperMPAS.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, MBPOLYGON, and moab::Interface::tag_iterate().
    // Only one group of cells (each cell is represented by a polygon with maxEdgesPerCell edges)
    numCellGroups = 1;
    // Create cells for this cell group
    EntityHandle* conn_arr_local_cells = NULL;
    ErrorCode rval =
        _readNC->readMeshIface->get_element_connect( nLocalCells, maxEdgesPerCell, MBPOLYGON, 0, start_element,
                                                     conn_arr_local_cells,
                                                     ( createGatherSet ? nLocalCells + nCells : nLocalCells ) );MB_CHK_SET_ERR( rval, "Failed to create local cells" );
    faces.insert( start_element, start_element + nLocalCells - 1 );
    Range local_cells_range( start_element, start_element + nLocalCells - 1 );
    // Get ptr to GID memory for local cells
    int count  = 0;
    void* data = NULL;
    assert( count == nLocalCells );
    std::copy( localGidCells.begin(), localGidCells.end(), gid_data );
    // vertices_on_local_cells array was already corrected to have the last vertices padded
    // no need for extra checks considering
        for( int i = 0; i < maxEdgesPerCell; i++ )
                vertices_on_local_cells[local_cell_idx * maxEdgesPerCell + i];  // Global vertex index, 1 based
            conn_arr_local_cells[local_cell_idx * maxEdgesPerCell + i] = start_vertex + local_vert_idx;
    return MB_SUCCESS;
virtual std::string moab::NCHelperMPAS::get_mesh_type_name ( ) [inline, private, virtual]
Definition at line 34 of file NCHelperMPAS.hpp.
        return "MPAS";
Definition at line 78 of file NCHelperMPAS.cpp.
References moab::NCHelper::_readNC, moab::UcdNCHelper::cDim, moab::DEFAULT_MAX_EDGES_PER_CELL, moab::ReadNC::dimLens, moab::ReadNC::dimNames, moab::UcdNCHelper::eDim, moab::ReadNC::VarData::entLoc, moab::ReadNC::ENTLOCEDGE, moab::ReadNC::ENTLOCFACE, moab::ReadNC::ENTLOCVERT, ErrorCode, moab::NCHelper::ignoredVarNames, moab::NCHelper::levDim, maxEdgesPerCell, MB_CHK_SET_ERR, MB_INVALID_SIZE, MB_SET_ERR, moab::UcdNCHelper::nCells, moab::UcdNCHelper::nEdges, moab::NCHelper::nLevels, moab::NCHelper::nTimeSteps, moab::ReadNC::VarData::numLev, moab::UcdNCHelper::nVertices, moab::NCHelper::read_coordinate(), t, moab::NCHelper::tDim, moab::NCHelper::tVals, moab::ReadNC::VarData::varDims, moab::ReadNC::varInfo, and moab::UcdNCHelper::vDim.
    std::vector< std::string >& dimNames              = _readNC->dimNames;
    std::vector< int >& dimLens                       = _readNC->dimLens;
    std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo;
    ErrorCode rval;
    unsigned int idx;
    std::vector< std::string >::iterator vit;
    // Get max edges per cell reported in the MPAS file header
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "maxEdges" ) ) != dimNames.end() )
        idx             = vit - dimNames.begin();
        maxEdgesPerCell = dimLens[idx];
        if( maxEdgesPerCell > DEFAULT_MAX_EDGES_PER_CELL )
            MB_SET_ERR( MB_INVALID_SIZE,
                        "maxEdgesPerCell read from the MPAS file header has exceeded " << DEFAULT_MAX_EDGES_PER_CELL );
    // Look for time dimension
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "Time" ) ) != dimNames.end() )
    else if( ( vit = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'Time' or 'time' dimension" );
    tDim       = idx;
    nTimeSteps = dimLens[idx];
    // Get number of cells
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nCells" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'nCells' dimension" );
    cDim   = idx;
    nCells = dimLens[idx];
    // Get number of edges
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nEdges" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'nEdges' dimension" );
    eDim   = idx;
    nEdges = dimLens[idx];
    // Get number of vertices
    vDim = -1;
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nVertices" ) ) != dimNames.end() )
    else
        MB_SET_ERR( MB_FAILURE, "Couldn't find 'nVertices' dimension" );
    vDim      = idx;
    nVertices = dimLens[idx];
    // Get number of vertex levels
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nVertLevels" ) ) != dimNames.end() )
    else
        std::cerr << "Warning: dimension nVertLevels not found in header.\nThe file may contain "
                     "just the mesh"
                  << std::endl;
    levDim  = idx;
    nLevels = dimLens[idx];
    // Dimension indices for other optional levels
    std::vector< unsigned int > opt_lev_dims;
    // Get index of vertex levels P1
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nVertLevelsP1" ) ) != dimNames.end() )
        opt_lev_dims.push_back( idx );
    // Get index of vertex levels P2
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nVertLevelsP2" ) ) != dimNames.end() )
    // Get index of soil levels
    if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nSoilLevels" ) ) != dimNames.end() )
    std::map< std::string, ReadNC::VarData >::iterator vmit;
    // Store time coordinate values in tVals
    if( nTimeSteps > 0 )
        // Note, two possible types for xtime variable: double(Time) or char(Time, StrLen)
        if( ( vmit = varInfo.find( "xtime" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
            // If xtime variable is double type, read time coordinate values to tVals
            rval = read_coordinate( "xtime", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 'xtime' variable" );
        else
            // If xtime variable does not exist, or it is string type, set dummy values to tVals
            for( int t = 0; t < nTimeSteps; t++ )
                tVals.push_back( (double)t );
    // For each variable, determine the entity location type and number of levels
    for( vmit = varInfo.begin(); vmit != varInfo.end(); ++vmit )
        ReadNC::VarData& vd = ( *vmit ).second;
        // Default entLoc is ENTLOCSET
        if( std::find( vd.varDims.begin(), vd.varDims.end(), tDim ) != vd.varDims.end() )
            if( std::find( vd.varDims.begin(), vd.varDims.end(), vDim ) != vd.varDims.end() )
                vd.entLoc = ReadNC::ENTLOCVERT;
            else if( std::find( vd.varDims.begin(), vd.varDims.end(), eDim ) != vd.varDims.end() )
                vd.entLoc = ReadNC::ENTLOCEDGE;
            else if( std::find( vd.varDims.begin(), vd.varDims.end(), cDim ) != vd.varDims.end() )
                vd.entLoc = ReadNC::ENTLOCFACE;
        // Default numLev is 0
        if( std::find( vd.varDims.begin(), vd.varDims.end(), levDim ) != vd.varDims.end() )
            vd.numLev = nLevels;
        else
            // If nVertLevels dimension is not found, try other optional levels such as
            // nVertLevelsP1
            for( unsigned int i = 0; i < opt_lev_dims.size(); i++ )
                if( std::find( vd.varDims.begin(), vd.varDims.end(), opt_lev_dims[i] ) != vd.varDims.end() )
                    vd.numLev = dimLens[opt_lev_dims[i]];
                    break;
        // Hack: ignore variables with more than 3 dimensions, e.g. tracers(Time, nCells,
        // nVertLevels, nTracers)
        if( vd.varDims.size() > 3 ) ignoredVarNames.insert( vd.varName );
    // Hack: create dummy variables for dimensions (like nCells) with no corresponding coordinate
    // variables
    rval = create_dummy_variables();MB_CHK_SET_ERR( rval, "Failed to create dummy variables" );
    return MB_SUCCESS;
ErrorCode moab::NCHelperMPAS::read_ucd_variables_to_nonset ( std::vector< ReadNC::VarData > &  vdatas,
std::vector< int > &  tstep_nums
Implements moab::UcdNCHelper.
Definition at line 835 of file NCHelperMPAS.cpp.
References ErrorCode, moab::DebugOutput::get_verbosity(), MB_CHK_SET_ERR, MB_SET_ERR, NCDF_SIZE, NCFUNCAG, moab::Range::pair_begin(), moab::Range::pair_end(), moab::DebugOutput::printf(), moab::Range::psize(), t, moab::Interface::tag_iterate(), and moab::DebugOutput::tprintf().
    ErrorCode rval = read_ucd_variables_to_nonset_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read non-set variables" );
    // Finally, read into that space
    int success;
    Range* pLocalGid = NULL;
    for( unsigned int i = 0; i < vdatas.size(); i++ )
        // Skip edge variables, if specified by the read options
        if( noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE ) continue;
        switch( vdatas[i].entLoc )
            case ReadNC::ENTLOCVERT:
                pLocalGid = &localGidVerts;
                break;
            case ReadNC::ENTLOCFACE:
                pLocalGid = &localGidCells;
                break;
            case ReadNC::ENTLOCEDGE:
                pLocalGid = &localGidEdges;
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
        std::size_t sz = vdatas[i].sz;
        for( unsigned int t = 0; t < tstep_nums.size(); t++ )
            // Set readStart for each timestep along time dimension
            vdatas[i].readStarts[0] = tstep_nums[t];
            switch( vdatas[i].varDataType )
                case NC_FLOAT:
                case NC_DOUBLE: {
                    // Read float as double
                    std::vector< double > tmpdoubledata( sz );
                    // In the case of ucd mesh, and on multiple proc,
                    // we need to read as many times as subranges we have in the
                    // localGid range;
                    // basically, we have to give a different point
                    // for data to start, for every subrange :(
                    size_t indexInDoubleArray = 0;
                    size_t ic = 0;
                    for( Range::pair_iterator pair_iter = pLocalGid->pair_begin(); pair_iter != pLocalGid->pair_end();
                         ++pair_iter, ic++ )
                        EntityHandle endh = pair_iter->second;  // Inclusive
                        vdatas[i].readStarts[1] = (NCDF_SIZE)( starth - 1 );
                        vdatas[i].readCounts[1] = (NCDF_SIZE)( endh - starth + 1 );
                        success = NCFUNCAG( _vara_double )( _fileId, vdatas[i].varId, &( vdatas[i].readStarts[0] ),
                                                            &( vdatas[i].readCounts[0] ),
                                                            &( tmpdoubledata[indexInDoubleArray] ) );
                        if( success )
                                        "Failed to read double data in a loop for variable " << vdatas[i].varName );
                        // We need to increment the index in double array for the
                        // next subrange
                        indexInDoubleArray += ( endh - starth + 1 ) * 1 * vdatas[i].numLev;
                    assert( ic == pLocalGid->psize() );
                    if( vdatas[i].entLoc == ReadNC::ENTLOCFACE && numCellGroups > 1 )
                        // For a cell variable that is NOT on one contiguous chunk of faces,
                        // allocate tag space for each cell group, and utilize cellHandleToGlobalID
                        // map to read tag data
                        Range::iterator iter = facesOwned.begin();
                        while( iter != facesOwned.end() )
                            int count;
                            void* ptr;
                            rval = mbImpl->tag_iterate( vdatas[i].varTags[t], iter, facesOwned.end(), count, ptr );MB_CHK_SET_ERR( rval, "Failed to iterate tag on owned faces" );
                            for( int j = 0; j < count; j++ )
                                int global_cell_idx =
                                    cellHandleToGlobalID[*( iter + j )];  // Global cell index, 1 based
                                for( int level = 0; level < vdatas[i].numLev; level++ )
                                    ( (double*)ptr )[j * vdatas[i].numLev + level] =
                                        tmpdoubledata[local_cell_idx * vdatas[i].numLev + level];
                            iter += count;
                    else
                        void* data = vdatas[i].varDatas[t];
                        for( std::size_t idx = 0; idx != tmpdoubledata.size(); idx++ )
                            ( (double*)data )[idx] = tmpdoubledata[idx];
                    break;
                default:
                    MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName );
    // Debug output, if requested
    if( 1 == dbgOut.get_verbosity() )
        dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() );
        for( unsigned int i = 1; i < vdatas.size(); i++ )
            dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() );
        dbgOut.tprintf( 1, "\n" );
    return rval;
ErrorCode moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate ( std::vector< ReadNC::VarData > &  vdatas,
Definition at line 558 of file NCHelperMPAS.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_dimension(), MB_CHK_SET_ERR, MB_INDEX_OUT_OF_RANGE, MB_SET_ERR, moab::Range::psize(), PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Range::size(), t, moab::Interface::tag_iterate(), and moab::DebugOutput::tprintf().
    Range* range = NULL;
    // Get vertices
    Range verts;
    ErrorCode rval = mbImpl->get_entities_by_dimension( _fileSet, 0, verts );MB_CHK_SET_ERR( rval, "Trouble getting vertices in current file set" );
    assert( "Should only have a single vertex subrange, since they were read in one shot" && verts.psize() == 1 );
    // Get edges
    Range edges;
    rval = mbImpl->get_entities_by_dimension( _fileSet, 1, edges );MB_CHK_SET_ERR( rval, "Trouble getting edges in current file set" );
    // Get faces
    Range faces;
    rval = mbImpl->get_entities_by_dimension( _fileSet, 2, faces );MB_CHK_SET_ERR( rval, "Trouble getting faces in current file set" );
    // Note, for MPAS faces.psize() can be more than 1
    if( isParallel )
        rval                   = myPcomm->filter_pstatus( faces, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &facesOwned );MB_CHK_SET_ERR( rval, "Trouble getting owned faces in current file set" );
    else
        facesOwned = faces;  // not running in parallel, but still with MPI
#else
    facesOwned = faces;
#endif
        // Support non-set variables with 3 dimensions like (Time, nCells, nVertLevels), or
        // 2 dimensions like (Time, nCells)
        assert( 3 == vdatas[i].varDims.size() || 2 == vdatas[i].varDims.size() );
        // For a non-set variable, time should be the first dimension
        assert( tDim == vdatas[i].varDims[0] );
        // Set up readStarts and readCounts
        vdatas[i].readStarts.resize( 3 );
        vdatas[i].readCounts.resize( 3 );
        // First: Time
        vdatas[i].readStarts[0] = 0;  // This value is timestep dependent, will be set later
        vdatas[i].readCounts[0] = 1;
        // Next: nVertices / nCells / nEdges
                // Vertices
                // Start from the first localGidVerts
                // Actually, this will be reset later on in a loop
                vdatas[i].readStarts[1] = localGidVerts[0] - 1;
                vdatas[i].readCounts[1] = nLocalVertices;
                range                   = &verts;
                break;
                // Faces
                // Start from the first localGidCells
                vdatas[i].readStarts[1] = localGidCells[0] - 1;
                vdatas[i].readCounts[1] = nLocalCells;
                range                   = &facesOwned;
                break;
                // Edges
                // Start from the first localGidEdges
                vdatas[i].readStarts[1] = localGidEdges[0] - 1;
                vdatas[i].readCounts[1] = nLocalEdges;
                range                   = &edges;
                break;
            default:
        // Finally: nVertLevels or other optional levels, it is possible that there is no
        // level dimension (numLev is 0) for this non-set variable, e.g. (Time, nCells)
        if( vdatas[i].numLev < 1 ) vdatas[i].numLev = 1;
        vdatas[i].readStarts[2] = 0;
        vdatas[i].readCounts[2] = vdatas[i].numLev;
        // Get variable size
        vdatas[i].sz = 1;
        for( std::size_t idx = 0; idx != 3; idx++ )
            vdatas[i].sz *= vdatas[i].readCounts[idx];
            dbgOut.tprintf( 2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t] );
            if( tstep_nums[t] >= dimLens[tDim] )
                MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number " << tstep_nums[t] );
            // Get the tag to read into
            if( !vdatas[i].varTags[t] )
                rval = get_tag_to_nonset( vdatas[i], tstep_nums[t], vdatas[i].varTags[t], vdatas[i].numLev );MB_CHK_SET_ERR( rval, "Trouble getting tag for variable " << vdatas[i].varName );
            // Get ptr to tag space
                // For a cell variable that is NOT on one contiguous chunk of faces, defer its tag
                // space allocation
                vdatas[i].varDatas[t] = NULL;
            else
                assert( 1 == range->psize() );
                void* data;
                int count;
                rval = mbImpl->tag_iterate( vdatas[i].varTags[t], range->begin(), range->end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate tag for variable " << vdatas[i].varName );
                assert( (unsigned)count == range->size() );
                vdatas[i].varDatas[t] = data;
    return rval;
Member Data Documentation
Definition at line 92 of file NCHelperMPAS.hpp.
Definition at line 91 of file NCHelperMPAS.hpp.
Definition at line 93 of file NCHelperMPAS.hpp.
Definition at line 89 of file NCHelperMPAS.hpp.
Referenced by init_mesh_vals().
Definition at line 90 of file NCHelperMPAS.hpp.
List of all members.
