moab::ReadABAQUS Member List
This is the complete list of members for moab::ReadABAQUS, including all inherited members.
abFilemoab::ReadABAQUS [private]
add_entity_set(EntityHandle parent_set, int ABQ_set_type, const std::string &set_name, EntityHandle &entity_set)moab::ReadABAQUS [private]
create_instance_of_part(const EntityHandle file_set, const EntityHandle parent_set, const std::string &part_name, const std::string &instance_name, EntityHandle &entity_set, const std::vector< double > &translation, const std::vector< double > &rotation)moab::ReadABAQUS [private]
cyl2rect(std::vector< double > coord_list)moab::ReadABAQUS [private]
extract_keyword_parameters(const std::vector< std::string > &tokens, std::map< std::string, std::string > &params)moab::ReadABAQUS [private]
factory(Interface *)moab::ReadABAQUS [static]
get_elements_by_id(EntityHandle parent_set, std::vector< int > element_ids_subset, Range &element_range)moab::ReadABAQUS [private]
get_keyword()moab::ReadABAQUS [private]
get_next_line_type()moab::ReadABAQUS [private]
get_nodes_by_id(EntityHandle parent_set, std::vector< int > node_ids_subset, Range &node_range)moab::ReadABAQUS [private]
get_set_by_name(EntityHandle parent_set, int ABQ_set_type, const std::string &set_name, EntityHandle &set_handle)moab::ReadABAQUS [private]
get_set_elements(EntityHandle set_handle, Range &element_range)moab::ReadABAQUS [private]
get_set_elements_by_name(EntityHandle parent_set, int ABQ_set_type, const std::string &set_name, Range &element_range)moab::ReadABAQUS [private]
get_set_nodes(EntityHandle parent_set, int ABQ_set_type, const std::string &set_name, Range &node_range)moab::ReadABAQUS [private]
get_tag(const char *tag_name, int tag_size, TagType tag_type, DataType tag_data_type, const void *def_val=0)moab::ReadABAQUS [private]
lineNomoab::ReadABAQUS [private]
load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)moab::ReadABAQUS [virtual]
mAssemblyHandleTagmoab::ReadABAQUS [private]
mat_idmoab::ReadABAQUS [private]
match(const std::string &token, std::map< std::string, T > &tokenList)moab::ReadABAQUS [private]
matIDmapmoab::ReadABAQUS [private]
mdbImplmoab::ReadABAQUS [private]
mDirichletSetTagmoab::ReadABAQUS [private]
mHasMidNodesTagmoab::ReadABAQUS [private]
mInstanceGIDTagmoab::ReadABAQUS [private]
mInstanceHandleTagmoab::ReadABAQUS [private]
mInstancePIDTagmoab::ReadABAQUS [private]
mLocalIDTagmoab::ReadABAQUS [private]
mMaterialSetTagmoab::ReadABAQUS [private]
mMatNameTagmoab::ReadABAQUS [private]
mNeumannSetTagmoab::ReadABAQUS [private]
mPartHandleTagmoab::ReadABAQUS [private]
mSetNameTagmoab::ReadABAQUS [private]
mSetTypeTagmoab::ReadABAQUS [private]
next_line_typemoab::ReadABAQUS [private]
num_assembly_instancesmoab::ReadABAQUS [private]
num_part_instancesmoab::ReadABAQUS [private]
read_assembly(EntityHandle file_set)moab::ReadABAQUS [private]
read_element_list(EntityHandle parent_set, EntityHandle assembly_set=0)moab::ReadABAQUS [private]
read_element_set(EntityHandle parent_set, EntityHandle file_set=0, EntityHandle assembly_set=0)moab::ReadABAQUS [private]
read_heading(EntityHandle file_set)moab::ReadABAQUS [private]
read_instance(EntityHandle assembly_set, EntityHandle file_set)moab::ReadABAQUS [private]
read_node_list(EntityHandle parent_set, EntityHandle assembly_set=0)moab::ReadABAQUS [private]
read_node_set(EntityHandle parent_set, EntityHandle file_set=0, EntityHandle assembly_set=0)moab::ReadABAQUS [private]
read_part(EntityHandle file_set)moab::ReadABAQUS [private]
read_solid_section(EntityHandle parent_set)moab::ReadABAQUS [private]
read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)moab::ReadABAQUS [virtual]
read_unsupported(EntityHandle file_set)moab::ReadABAQUS [private]
ReadABAQUS(Interface *impl=NULL)moab::ReadABAQUS
readlinemoab::ReadABAQUS [private]
readMeshIfacemoab::ReadABAQUS [private]
reset()moab::ReadABAQUS [private]
sph2rect(std::vector< double > coord_list)moab::ReadABAQUS [private]
stringToUpper(const std::string &toBeConverted, std::string &converted)moab::ReadABAQUS [private]
tokenize(const std::string &str, std::vector< std::string > &tokens, const char *delimiters)moab::ReadABAQUS
~ReadABAQUS()moab::ReadABAQUS [virtual]
~ReaderIface()moab::ReaderIface [inline, virtual]
