moab::ReaderIface Class Reference
Interface for mesh reader implementations. More...
#include <ReaderIface.hpp>
+ Inheritance diagram for moab::ReaderIface:
Classes
struct  IDTag
struct  SubsetList
Public Member Functions
virtual ~ReaderIface ()
virtual ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)=0
 Load mesh from a file.
virtual ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)=0
 Read tag values from a file.
Detailed Description
Version:
1.00
Date:
2004-4-23
Author:
Jason Kraftcheck
Definition at line 34 of file ReaderIface.hpp.
virtual moab::ReaderIface::~ReaderIface ( ) [inline, virtual]
Definition at line 37 of file ReaderIface.hpp.
Member Function Documentation
virtual ErrorCode moab::ReaderIface::load_file ( const char *  file_name,
const EntityHandle file_set,
const FileOptions opts,
const SubsetList subset_list = 0,
const Tag file_id_tag = 0
) [pure virtual]
Method all readers must provide to import a mesh.
Parameters:
file_nameThe file to read.
file_setOptional pointer to entity set representing file. If this is not NULL, reader may optionally tag the pointed-to set with format-specific meta-data.
subset_listAn optional struct pointer specifying the tags identifying entity sets to be read.
file_id_tagIf specified, reader should store for each entity it reads, a unique integer ID for this tag.
Author:
Jason Kraftcheck
Implemented in moab::ReadABAQUS, moab::Tqdcfr, moab::ReadOBJ, moab::ReadRTT, moab::ReadNCDF, moab::ReadNC, moab::ReadSTL, moab::ReadHDF5, moab::ReadCGM, moab::ReadMCNP5, moab::ReadNASTRAN, moab::ReadSmf, moab::ReadTetGen, moab::ReadCCMIO, moab::ReadDamsel, moab::ReadGmsh, moab::ReadVtk, moab::ReadIDEAS, moab::ReadTemplate, moab::ReadCGNS, and moab::ReadSms.
Referenced by moab::Core::serial_load_file().
virtual ErrorCode moab::ReaderIface::read_tag_values ( const char *  file_name,
const char *  tag_name,
std::vector< int > &  tag_values_out,
) [pure virtual]
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Implemented in moab::ReadABAQUS, moab::Tqdcfr, moab::ReadOBJ, moab::ReadRTT, moab::ReadCCMIO, moab::ReadNC, moab::ReadNCDF, moab::ReadSTL, moab::ReadHDF5, moab::ReadCGM, moab::ReadNASTRAN, moab::ReadMCNP5, moab::ReadDamsel, moab::ReadSmf, moab::ReadTetGen, moab::ReadGmsh, moab::ReadVtk, moab::ReadIDEAS, moab::ReadTemplate, moab::ReadCGNS, and moab::ReadSms.
Referenced by moab::Core::serial_read_tag().
List of all members.
