moab::ReadCCMIO Class Reference
#include <ReadCCMIO.hpp>
+ Inheritance diagram for moab::ReadCCMIO:
+ Collaboration diagram for moab::ReadCCMIO:
Public Types
typedef std::map< int,
std::vector< EntityHandle > >
TupleList
std::vector< int > >
SenseList
Public Member Functions
 ReadCCMIO (Interface *impl)
 Constructor.
virtual ~ReadCCMIO ()
 Destructor.
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
 Load mesh from a file.
Static Public Member Functions
static ReaderIfacefactory (Interface *)
Private Member Functions
ErrorCode read_processor (CCMIOID rootID, CCMIOID problemID, CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID, CCMIOSize_t proc, Range *new_ents)
ErrorCode read_cells (CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID, TupleList &vert_map, Range *new_cells)
ErrorCode construct_cells (TupleList &face_map, SenseList &sense_map, TupleList &vert_map, std::map< int, int > &cell_topo_types, std::vector< EntityHandle > &new_cells)
ErrorCode ccmio_to_moab_type (int ccm_type, EntityType &moab_type, bool &has_mid_nodes)
ErrorCode create_cell_from_faces (std::vector< EntityHandle > &facehs, std::vector< int > &senses, EntityType this_type, bool has_mid_nodes, EntityHandle &cell)
ErrorCode read_gids_and_types (CCMIOID problemID, CCMIOID topologyID, std::vector< EntityHandle > &cells)
ErrorCode read_all_faces (CCMIOID topologyID, TupleList &vert_map, TupleList &face_map, SenseList &sense_map, Range *new_faces)
ErrorCode read_faces (CCMIOID faceID, CCMIOEntity bdy_or_int, TupleList &vert_map, TupleList &face_map, SenseList &sense_map, Range *new_faces)
ErrorCode make_faces (int *farray, TupleList &vert_map, std::vector< EntityHandle > &new_faces, int num_faces)
ErrorCode read_vertices (CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID, Range *verts, TupleList &vert_map)
ErrorCode get_processors (CCMIOID stateID, CCMIOID &processorID, CCMIOID &verticesID, CCMIOID &topologyID, CCMIOID &solutionID, std::vector< CCMIOSize_t > &procs, bool &has_solution)
ErrorCode get_state (CCMIOID rootID, CCMIOID &problemID, CCMIOID &stateID)
ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
ErrorCode load_matset_data (CCMIOID problemID)
ErrorCode load_neuset_data (CCMIOID problemID)
ErrorCode load_metadata (CCMIOID rootID, CCMIOID problemID, CCMIOID stateID, CCMIOID processorID, const EntityHandle *file_set)
ErrorCode read_topology_types (CCMIOID &topologyID, std::map< int, int > &cell_topo_types)
ErrorCode get_int_option (const char *opt_str, EntityHandle seth, Tag &tag, CCMIOID node)
ErrorCode get_dbl_option (const char *opt_str, EntityHandle seth, Tag &tag, CCMIOID node)
ErrorCode get_str_option (const char *opt_str, EntityHandle seth, Tag &tag, CCMIOID node, const char *tag_name=NULL)
Private Attributes
Tag mMaterialSetTag
 Cached tags for reading. Note that all these tags are defined when the core is initialized.
Tag mDirichletSetTag
Tag mNeumannSetTag
Tag mHasMidNodesTag
Tag mGlobalIdTag
Tag mNameTag
Tag mMaterialIdTag
Tag mMaterialTypeTag
Tag mRadiationTag
Tag mPorosityIdTag
Tag mSpinIdTag
Tag mGroupIdTag
Tag mColorIdxTag
Tag mProcessorIdTag
Tag mLightMaterialTag
Tag mFreeSurfaceMaterialTag
Tag mThicknessTag
Tag mProstarRegionNumberTag
Tag mBoundaryTypeTag
Tag mCreatingProgramTag
InterfacembImpl
ReadUtilIfacereadMeshIface
std::map< int, EntityHandlenewMatsets
std::map< int, EntityHandlenewNeusets
bool hasSolution
Detailed Description
Definition at line 27 of file ReadCCMIO.hpp.
Member Typedef Documentation
typedef std::map< int, std::vector< int > > moab::ReadCCMIO::SenseList
Definition at line 32 of file ReadCCMIO.hpp.
typedef std::map< int, std::vector< EntityHandle > > moab::ReadCCMIO::TupleList
Definition at line 31 of file ReadCCMIO.hpp.
Constructor.
Get and cache predefined tag handles
Definition at line 92 of file ReadCCMIO.cpp.
References DIRICHLET_SET_TAG_NAME, ErrorCode, moab::Interface::globalId_tag(), HAS_MID_NODES_TAG_NAME, MATERIAL_SET_TAG_NAME, MB_CHK_SET_ERR_RET, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mDirichletSetTag, mGlobalIdTag, mHasMidNodesTag, mMaterialSetTag, mNameTag, mNeumannSetTag, NAME_TAG_NAME, NAME_TAG_SIZE, NEUMANN_SET_TAG_NAME, moab::Interface::query_interface(), readMeshIface, and moab::Interface::tag_get_handle().
Referenced by factory().
    : mMaterialIdTag( 0 ), mMaterialTypeTag( 0 ), mRadiationTag( 0 ), mPorosityIdTag( 0 ), mSpinIdTag( 0 ),
      mGroupIdTag( 0 ), mColorIdxTag( 0 ), mProcessorIdTag( 0 ), mLightMaterialTag( 0 ), mFreeSurfaceMaterialTag( 0 ),
      mThicknessTag( 0 ), mProstarRegionNumberTag( 0 ), mBoundaryTypeTag( 0 ), mCreatingProgramTag( 0 ), mbImpl( impl ),
      hasSolution( false )
    assert( impl != NULL );
    impl->query_interface( readMeshIface );
    // Initialize in case tag_get_handle fails below
    mMaterialSetTag  = 0;
    mDirichletSetTag = 0;
    mNeumannSetTag   = 0;
    mHasMidNodesTag  = 0;
    mGlobalIdTag     = 0;
    mNameTag         = 0;
    //! Get and cache predefined tag handles
    const int negone = -1;
    ErrorCode result = impl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mMaterialSetTag,
                                             MB_TAG_CREAT | MB_TAG_SPARSE, &negone );MB_CHK_SET_ERR_RET( result, "Failed to get MATERIAL_SET tag" );
    result = impl->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mDirichletSetTag,
                                   MB_TAG_CREAT | MB_TAG_SPARSE, &negone );MB_CHK_SET_ERR_RET( result, "Failed to get DIRICHLET_SET tag" );
    result = impl->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mNeumannSetTag,
                                   MB_TAG_CREAT | MB_TAG_SPARSE, &negone );MB_CHK_SET_ERR_RET( result, "Failed to get NEUMANN_SET tag" );
    const int negonearr[] = { -1, -1, -1, -1 };
    result                = impl->tag_get_handle( HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER, mHasMidNodesTag,
                                                  MB_TAG_CREAT | MB_TAG_SPARSE, negonearr );MB_CHK_SET_ERR_RET( result, "Failed to get HAS_MID_NODES tag" );
    mGlobalIdTag = impl->globalId_tag();
    result =
        impl->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, mNameTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR_RET( result, "Failed to get NAME tag" );
Destructor.
Definition at line 131 of file ReadCCMIO.cpp.
References mbImpl, readMeshIface, and moab::Interface::release_interface().
Member Function Documentation
ErrorCode moab::ReadCCMIO::ccmio_to_moab_type ( int  ccm_type,
EntityType &  moab_type,
bool &  has_mid_nodes
) [private]
Definition at line 621 of file ReadCCMIO.cpp.
References MB_SUCCESS, MBEDGE, MBHEX, MBMAXTYPE, MBPOLYHEDRON, MBPRISM, MBPYRAMID, MBQUAD, MBTET, and MBVERTEX.
Referenced by construct_cells().
    switch( ccm_type )
        case 1:
            moab_type = MBVERTEX;
            break;
        case 2:
        case 28:
            moab_type = MBEDGE;
            break;
        case 29:
            moab_type = MBMAXTYPE;
            break;
        case 3:
        case 4:
            moab_type = MBQUAD;
            break;
        case 11:
        case 21:
            moab_type = MBHEX;
            break;
        case 12:
        case 22:
            moab_type = MBPRISM;
            break;
        case 13:
        case 23:
            moab_type = MBTET;
            break;
        case 14:
        case 24:
            moab_type = MBPYRAMID;
            break;
        case 255:
            moab_type = MBPOLYHEDRON;
            break;
        default:
    switch( ccm_type )
        case 28:
        case 4:
        case 21:
        case 22:
        case 23:
        case 24:
            has_mid_nodes = true;
            break;
        default:
            break;
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::construct_cells ( TupleList face_map,
SenseList sense_map,
TupleList vert_map,
std::map< int, int > &  cell_topo_types,
std::vector< EntityHandle > &  new_cells
) [private]
Definition at line 552 of file ReadCCMIO.cpp.
References ccmio_to_moab_type(), create_cell_from_faces(), ErrorCode, MB_SUCCESS, mbImpl, MBMAXTYPE, mGlobalIdTag, and moab::Interface::tag_set_data().
Referenced by read_cells().
    std::vector< EntityHandle > facehs;
    std::vector< int > senses;
    EntityHandle cell;
    ErrorCode tmp_rval, rval = MB_SUCCESS;
    EntityType this_type = MBMAXTYPE;
    bool has_mid_nodes   = false;
#ifdef TUPLE_LIST
    unsigned int i = 0;
    while( i < face_map.n )
        // Pull out face handles bounding the same cell
        facehs.clear();
        int this_id        = face_map.get_int( i );
        unsigned int inext = i;
        while( face_map.get_int( inext ) == this_id && inext <= face_map.n )
            inext++;
            EntityHandle face = face_map.get_ulong( inext );
            facehs.push_back( face );
            senses.push_back( face_map.get_short( inext ) );
#else
    std::map< int, std::vector< EntityHandle > >::iterator fmit;
    std::map< int, std::vector< int > >::iterator smit;
    std::map< int, int >::iterator typeit;
    for( fmit = face_map.begin(), smit = sense_map.begin(); fmit != face_map.end(); ++fmit, ++smit )
        facehs.clear();
        int this_id = ( *fmit ).first;
        facehs      = ( *fmit ).second;
        senses.clear();
        senses = ( *smit ).second;
        typeit = cell_topo_types.find( this_id );
        if( typeit != cell_topo_types.end() )
            rval = ccmio_to_moab_type( typeit->second, this_type, has_mid_nodes );
        else
#endif
        tmp_rval = create_cell_from_faces( facehs, senses, this_type, has_mid_nodes, cell );
        if( MB_SUCCESS != tmp_rval )
            rval = tmp_rval;
        else
            new_cells.push_back( cell );
            // Tag cell with global id
            tmp_rval = mbImpl->tag_set_data( mGlobalIdTag, &cell, 1, &this_id );
            if( MB_SUCCESS != tmp_rval ) rval = tmp_rval;
    return rval;
ErrorCode moab::ReadCCMIO::create_cell_from_faces ( std::vector< EntityHandle > &  facehs,
std::vector< int > &  senses,
bool  has_mid_nodes,
EntityHandle cell
) [private]
Definition at line 679 of file ReadCCMIO.cpp.
References moab::Range::begin(), moab::Interface::create_element(), moab::CN::EntityTypeName(), moab::Range::erase(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBHEX, mbImpl, MBMAXTYPE, MBPOLYHEDRON, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, moab::MeshTopoUtil::opposite_entity(), moab::Range::size(), and moab::Interface::type_from_handle().
    ErrorCode rval;
    // Test up front to see if they're one type
    EntityType face_type = mbImpl->type_from_handle( facehs[0] );
    bool same_type       = true;
    for( std::vector< EntityHandle >::iterator vit = facehs.begin(); vit != facehs.end(); ++vit )
        if( face_type != mbImpl->type_from_handle( *vit ) )
            same_type = false;
            break;
    std::vector< EntityHandle > verts;
    EntityType input_type = this_type;
    std::vector< EntityHandle > storage;
    MeshTopoUtil mtu( mbImpl );
    // Preset this to maxtype, so we get an affirmative choice in loop
    if( ( MBTET == input_type || MBMAXTYPE == input_type ) && same_type && face_type == MBTRI && facehs.size() == 4 )
        // Try to get proper connectivity for tet
        // Get connectivity of first face, and reverse it if sense is forward, since
        // base face always points into entity
        rval = mbImpl->get_connectivity( &facehs[0], 1, verts );MB_CHK_SET_ERR( rval, "Couldn't get connectivity" );
        if( senses[0] > 0 ) std::reverse( verts.begin(), verts.end() );
        // Get the 4th vertex through the next tri
        const EntityHandle* conn;
        int conn_size;
        rval = mbImpl->get_connectivity( facehs[1], conn, conn_size, true, &storage );MB_CHK_SET_ERR( rval, "Couldn't get connectivity" );
        int i = 0;
        while( std::find( verts.begin(), verts.end(), conn[i] ) != verts.end() && i < conn_size )
            i++;
        // If i is not at the end of the verts, found the apex; otherwise fall back to polyhedron
        if( conn_size != i )
            this_type = MBTET;
            verts.push_back( conn[i] );
    else if( ( MBHEX == input_type || MBMAXTYPE == input_type ) && same_type && MBQUAD == face_type &&
             facehs.size() == 6 )
        // Build hex from quads
        // Algorithm:
        // - verts = vertices from 1st quad
        // - Find quad q1 sharing verts[0] and verts[1]
        // - Find quad q2 sharing other 2 verts in q1
        // - Find v1 = opposite vert from verts[1] in q1 , v2 = opposite from verts[0]
        // - Get i = offset of v1 in verts2 of q2, rotate verts2 by i
        // - If verts2[(i + 1) % 4] != v2, flip verts2 by switching verts2[1] and verts2[3]
        // - append verts2 to verts
        // Get the other vertices for this hex; need to find the quad with no common vertices
        Range tmp_faces, tmp_verts;
        // Get q1, which shares 2 vertices with q0
        std::copy( facehs.begin(), facehs.end(), range_inserter( tmp_faces ) );
        rval = mbImpl->get_adjacencies( &verts[0], 2, 2, false, tmp_faces );
        if( MB_SUCCESS != rval || tmp_faces.size() != 2 ) MB_SET_ERR( MB_FAILURE, "Couldn't get adj face" );
        tmp_faces.erase( facehs[0] );
        EntityHandle q1 = *tmp_faces.begin();
        // Get other 2 verts of q1
        rval = mbImpl->get_connectivity( &q1, 1, tmp_verts );MB_CHK_SET_ERR( rval, "Couldn't get adj verts" );
        tmp_verts.erase( verts[0] );
        tmp_verts.erase( verts[1] );
        // Get q2
        rval = mbImpl->get_adjacencies( tmp_verts, 2, false, tmp_faces );
        tmp_faces.erase( q1 );
        EntityHandle q2 = *tmp_faces.begin();
        // Get verts in q2
        rval = mbImpl->get_connectivity( &q2, 1, storage );MB_CHK_SET_ERR( rval, "Couldn't get adj vertices" );
        // Get verts in q1 opposite from v[1] and v[0] in q0
        EntityHandle v0 = 0, v1 = 0;
        rval = mtu.opposite_entity( q1, verts[1], v0 );MB_CHK_SET_ERR( rval, "Couldn't get the opposite side entity" );
        rval = mtu.opposite_entity( q1, verts[0], v1 );MB_CHK_SET_ERR( rval, "Couldn't get the opposite side entity" );
        if( v0 && v1 )
            // Offset of v0 in q2, then rotate and flip
            unsigned int ioff = std::find( storage.begin(), storage.end(), v0 ) - storage.begin();
            if( 4 == ioff ) MB_SET_ERR( MB_FAILURE, "Trouble finding offset" );
            if( storage[( ioff + 1 ) % 4] != v1 )
                std::reverse( storage.begin(), storage.end() );
            if( 0 != ioff ) std::rotate( storage.begin(), storage.begin() + ioff, storage.end() );
            // Copy into verts, and make hex
            std::copy( storage.begin(), storage.end(), std::back_inserter( verts ) );
            this_type = MBHEX;
    if( MBMAXTYPE == this_type && facehs.size() == 5 )
        // Some preliminaries
        std::vector< EntityHandle > tris, quads;
        for( unsigned int i = 0; i < 5; i++ )
            if( MBTRI == mbImpl->type_from_handle( facehs[i] ) )
                tris.push_back( facehs[i] );
            else if( MBQUAD == mbImpl->type_from_handle( facehs[i] ) )
                quads.push_back( facehs[i] );
        // Check for prisms
        if( 2 == tris.size() && 3 == quads.size() )
            // OK, we have the right number of tris and quads; try to find the proper verts
            // Get connectivity of first tri, and reverse if necessary
            int index = std::find( facehs.begin(), facehs.end(), tris[0] ) - facehs.begin();
            rval      = mbImpl->get_connectivity( &tris[0], 1, verts );MB_CHK_SET_ERR( rval, "Couldn't get connectivity" );
            if( senses[index] > 0 ) std::reverse( verts.begin(), verts.end() );
            // Now align vertices of other tri, through a quad, similar to how we did hexes
            // Get q1, which shares 2 vertices with t0
            tmp_faces.erase( tris[0] );
            // Get verts in q1
            rval = mbImpl->get_connectivity( &q1, 1, storage );MB_CHK_SET_ERR( rval, "Couldn't get adj vertices" );
            if( v0 && v1 )
                // Offset of v0 in t2, then rotate and flip
                storage.clear();
                rval = mbImpl->get_connectivity( &tris[1], 1, storage );MB_CHK_SET_ERR( rval, "Couldn't get connectivity" );
                index = std::find( facehs.begin(), facehs.end(), tris[1] ) - facehs.begin();
                if( senses[index] < 0 ) std::reverse( storage.begin(), storage.end() );
                if( 3 == ioff ) MB_SET_ERR( MB_FAILURE, "Trouble finding offset" );
                for( unsigned int i = 0; i < 3; i++ )
                    verts.push_back( storage[( ioff + i ) % 3] );
                this_type = MBPRISM;
        else if( tris.size() == 4 && quads.size() == 1 )
            // Check for pyramid
            int index = std::find( facehs.begin(), facehs.end(), quads[0] ) - facehs.begin();
            rval      = mbImpl->get_connectivity( &quads[0], 1, verts );MB_CHK_SET_ERR( rval, "Couldn't get connectivity" );
            // Get apex node
            rval = mbImpl->get_connectivity( &tris[0], 1, storage );MB_CHK_SET_ERR( rval, "Couldn't get connectivity" );
                if( std::find( verts.begin(), verts.end(), storage[i] ) == verts.end() )
                    verts.push_back( storage[i] );
                    break;
            if( 5 == verts.size() ) this_type = MBPYRAMID;
        else
            // Dummy else clause to stop in debugger
    if( MBMAXTYPE != input_type && input_type != this_type && this_type != MBMAXTYPE )
        std::cerr << "Warning: types disagree (cell_topo_type = " << CN::EntityTypeName( input_type )
                  << ", faces indicate type " << CN::EntityTypeName( this_type ) << std::endl;
    if( MBMAXTYPE != input_type && this_type == MBMAXTYPE && input_type != MBPOLYHEDRON )
        std::cerr << "Warning: couldn't find proper connectivity for specified topo_type = "
                  << CN::EntityTypeName( input_type ) << std::endl;
    // Now make the element; if we fell back to polyhedron, use faces, otherwise use verts
    if( MBPOLYHEDRON == this_type || MBMAXTYPE == this_type )
        rval = mbImpl->create_element( MBPOLYHEDRON, &facehs[0], facehs.size(), cell );MB_CHK_SET_ERR( rval, "create_element failed" );
    else
        rval = mbImpl->create_element( this_type, &verts[0], verts.size(), cell );MB_CHK_SET_ERR( rval, "create_element failed" );
    return MB_SUCCESS;
Definition at line 87 of file ReadCCMIO.cpp.
References ReadCCMIO().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadCCMIO( iface );
ErrorCode moab::ReadCCMIO::get_dbl_option ( const char *  opt_str,
EntityHandle  seth,
Tag tag,
CCMIOID  node
) [private]
Definition at line 316 of file ReadCCMIO.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_DOUBLE, mbImpl, moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by load_matset_data().
    float fdum;
    if( kCCMIONoErr == CCMIOReadOptf( NULL, node, opt_str, &fdum ) )
        ErrorCode rval;
        if( !tag )
            rval = mbImpl->tag_get_handle( opt_str, 1, MB_TYPE_DOUBLE, tag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Failed to get tag handle" );
        double dum_dbl = fdum;
        rval           = mbImpl->tag_set_data( tag, &seth, 1, &dum_dbl );MB_CHK_SET_ERR( rval, "Failed to set tag data" );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::get_int_option ( const char *  opt_str,
EntityHandle  seth,
Tag tag,
CCMIOID  node
) [private]
Definition at line 299 of file ReadCCMIO.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, mbImpl, moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by load_matset_data(), and load_neuset_data().
    int idum;
    ErrorCode rval;
    if( kCCMIONoErr == CCMIOReadOpti( NULL, node, opt_str, &idum ) )
        if( !tag )
            rval = mbImpl->tag_get_handle( opt_str, 1, MB_TYPE_INTEGER, tag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Failed to get tag handle" );
        rval = mbImpl->tag_set_data( tag, &seth, 1, &idum );MB_CHK_SET_ERR( rval, "Failed to set tag data" );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::get_processors ( CCMIOID  stateID,
CCMIOID &  processorID,
CCMIOID &  verticesID,
CCMIOID &  topologyID,
CCMIOID &  solutionID,
std::vector< CCMIOSize_t > &  procs,
bool &  has_solution
) [private]
Definition at line 1176 of file ReadCCMIO.cpp.
References CHK_SET_CCMERR, hasSolution, and MB_SUCCESS.
Referenced by load_file().
    CCMIOSize_t proc = CCMIOSIZEC( 0 );
    CCMIOError error = kCCMIONoErr;
    CCMIONextEntity( &error, stateID, kCCMIOProcessor, &proc, &processorID );
    CHK_SET_CCMERR( error, "CCMIONextEntity() failed" );
    if( CCMIOReadProcessor( NULL, processorID, &verticesID, &topologyID, NULL, &solutionID ) != kCCMIONoErr )
        // Maybe no solution; try again
        CCMIOReadProcessor( &error, processorID, &verticesID, &topologyID, NULL, NULL );
        CHK_SET_CCMERR( error, "CCMIOReadProcessor() failed" );
        hasSolution = false;
    procs.push_back( proc );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::get_state ( CCMIOID  rootID,
CCMIOID &  problemID,
CCMIOID &  stateID
) [private]
Definition at line 182 of file ReadCCMIO.cpp.
References CHK_SET_CCMERR, moab::error(), and MB_SUCCESS.
    // First try default
    CCMIOGetState( &error, rootID, "default", &problemID, &stateID );
    if( kCCMIONoErr != error )
        CCMIOSize_t i        = CCMIOSIZEC( 0 );
        CCMIOError tmp_error = kCCMIONoErr;
        CCMIONextEntity( &tmp_error, rootID, kCCMIOState, &i, &stateID );
        if( kCCMIONoErr == tmp_error ) CCMIONextEntity( &error, rootID, kCCMIOProblemDescription, &i, &problemID );
    CHK_SET_CCMERR( error, "Couldn't find state" );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::get_str_option ( const char *  opt_str,
EntityHandle  seth,
Tag tag,
CCMIOID  node,
const char *  tag_name = NULL
) [private]
Definition at line 334 of file ReadCCMIO.cpp.
References moab::error(), ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_OPAQUE, mbImpl, NAME_TAG_SIZE, moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by load_matset_data(), load_metadata(), and load_neuset_data().
    int len;
    std::vector< char > opt_string;
    if( kCCMIONoErr != CCMIOReadOptstr( NULL, node, opt_str, &len, NULL ) ) return MB_SUCCESS;
    opt_string.resize( len );
    CCMIOReadOptstr( &error, node, opt_str, &len, &opt_string[0] );
    ErrorCode rval = MB_SUCCESS;
    if( !tag )
        rval = mbImpl->tag_get_handle( other_tag_name ? other_tag_name : opt_str, NAME_TAG_SIZE, MB_TYPE_OPAQUE, tag,
    if( opt_string.size() > NAME_TAG_SIZE )
        opt_string[NAME_TAG_SIZE - 1] = '\0';
    else
        ( opt_string.resize( NAME_TAG_SIZE, '\0' ) );
    rval = mbImpl->tag_set_data( tag, &seth, 1, &opt_string[0] );MB_CHK_SET_ERR( rval, "Failed to set tag data" );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::load_file ( const char *  file_name,
const EntityHandle file_set,
const FileOptions opts,
const SubsetList subset_list = 0,
const Tag file_id_tag = 0
) [virtual]
Method all readers must provide to import a mesh.
Parameters:
file_nameThe file to read.
file_setOptional pointer to entity set representing file. If this is not NULL, reader may optionally tag the pointed-to set with format-specific meta-data.
subset_listAn optional struct pointer specifying the tags identifying entity sets to be read.
file_id_tagIf specified, reader should store for each entity it reads, a unique integer ID for this tag.
Author:
Jason Kraftcheck
Implements moab::ReaderIface.
Definition at line 136 of file ReadCCMIO.cpp.
References moab::Interface::add_entities(), CHK_SET_CCMERR, moab::error(), ErrorCode, get_processors(), get_state(), load_metadata(), MB_CHK_SET_ERR, MB_SET_ERR, MB_UNSUPPORTED_OPERATION, mbImpl, and read_processor().
    CCMIOID rootID, problemID, stateID, processorID, verticesID, topologyID, solutionID;
    if( subset_list )
        MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for CCMOI data" );
    CCMIOOpenFile( &error, file_name, kCCMIORead, &rootID );
    CHK_SET_CCMERR( error, "Problem opening file" );
    // Get the file state
    ErrorCode rval = get_state( rootID, problemID, stateID );MB_CHK_SET_ERR( rval, "Failed to get state" );
    // Get processors
    std::vector< CCMIOSize_t > procs;
    bool has_solution = false;
    rval              = get_processors( stateID, processorID, verticesID, topologyID, solutionID, procs, has_solution );MB_CHK_SET_ERR( rval, "Failed to get processors" );
    std::vector< CCMIOSize_t >::iterator vit;
    Range new_ents, *new_ents_ptr = NULL;
    if( file_set ) new_ents_ptr = &new_ents;
    for( vit = procs.begin(); vit != procs.end(); ++vit )
        rval = read_processor( stateID, problemID, processorID, verticesID, topologyID, *vit, new_ents_ptr );MB_CHK_SET_ERR( rval, "Failed to read processors" );
    // Load some meta-data
    rval = load_metadata( rootID, problemID, stateID, processorID, file_set );MB_CHK_SET_ERR( rval, "Failed to load some meta-data" );
    // Now, put all this into the file set, if there is one
    if( file_set )
        rval = mbImpl->add_entities( *file_set, new_ents );MB_CHK_SET_ERR( rval, "Failed to add new entities to file set" );
    return rval;
ErrorCode moab::ReadCCMIO::load_matset_data ( CCMIOID  problemID) [private]
Definition at line 238 of file ReadCCMIO.cpp.
References moab::error(), ErrorCode, get_dbl_option(), get_int_option(), get_str_option(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, mColorIdxTag, mFreeSurfaceMaterialTag, mGroupIdTag, mLightMaterialTag, mMaterialIdTag, mMaterialSetTag, mMaterialTypeTag, mNameTag, mPorosityIdTag, mProcessorIdTag, mRadiationTag, mSpinIdTag, mThicknessTag, NAME_TAG_SIZE, newMatsets, and moab::Interface::tag_set_data().
Referenced by load_metadata().
    // Make sure there are matsets
    if( newMatsets.empty() ) return MB_SUCCESS;
    // ... walk through each cell type
    CCMIOID next;
    while( CCMIONextEntity( NULL, problemID, kCCMIOCellType, &i, &next ) == kCCMIONoErr )
        // Get index, corresponding set, and label with material set tag
        int mindex;
        CCMIOGetEntityIndex( &error, next, &mindex );
        std::map< int, EntityHandle >::iterator mit = newMatsets.find( mindex );
        if( mit == newMatsets.end() )
            // No actual faces for this matset; continue to next
            continue;
        EntityHandle dum_ent = mit->second;
        ErrorCode rval       = mbImpl->tag_set_data( mMaterialSetTag, &dum_ent, 1, &mindex );MB_CHK_SET_ERR( rval, "Trouble setting material set tag" );
        // Set name
        CCMIOSize_t len;
        CCMIOEntityLabel( &error, next, &len, NULL );
        std::vector< char > opt_string2( GETINT32( len ) + 1, '\0' );
        CCMIOEntityLabel( &error, next, NULL, &opt_string2[0] );
        if( opt_string2.size() >= NAME_TAG_SIZE )
            opt_string2[NAME_TAG_SIZE - 1] = '\0';
        else
            ( opt_string2.resize( NAME_TAG_SIZE, '\0' ) );
        rval = mbImpl->tag_set_data( mNameTag, &dum_ent, 1, &opt_string2[0] );MB_CHK_SET_ERR( rval, "Trouble setting name tag for material set" );
        // Material id
        rval = get_int_option( "MaterialId", dum_ent, mMaterialIdTag, next );MB_CHK_SET_ERR( rval, "Trouble getting MaterialId tag" );
        rval = get_str_option( "MaterialType", dum_ent, mMaterialTypeTag, next );MB_CHK_SET_ERR( rval, "Trouble getting MaterialType tag" );
        rval = get_int_option( "Radiation", dum_ent, mRadiationTag, next );MB_CHK_SET_ERR( rval, "Trouble getting Radiation option" );
        rval = get_int_option( "PorosityId", dum_ent, mPorosityIdTag, next );MB_CHK_SET_ERR( rval, "Trouble getting PorosityId option" );
        rval = get_int_option( "SpinId", dum_ent, mSpinIdTag, next );MB_CHK_SET_ERR( rval, "Trouble getting SpinId option" );
        rval = get_int_option( "GroupId", dum_ent, mGroupIdTag, next );MB_CHK_SET_ERR( rval, "Trouble getting GroupId option" );
        rval = get_int_option( "ColorIdx", dum_ent, mColorIdxTag, next );MB_CHK_SET_ERR( rval, "Trouble getting ColorIdx option" );
        rval = get_int_option( "ProcessorId", dum_ent, mProcessorIdTag, next );MB_CHK_SET_ERR( rval, "Trouble getting ProcessorId option" );
        rval = get_int_option( "LightMaterial", dum_ent, mLightMaterialTag, next );MB_CHK_SET_ERR( rval, "Trouble getting LightMaterial option" );
        rval = get_int_option( "FreeSurfaceMaterial", dum_ent, mFreeSurfaceMaterialTag, next );MB_CHK_SET_ERR( rval, "Trouble getting FreeSurfaceMaterial option" );
        rval = get_dbl_option( "Thickness", dum_ent, mThicknessTag, next );MB_CHK_SET_ERR( rval, "Trouble getting Thickness option" );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::load_metadata ( CCMIOID  rootID,
CCMIOID  problemID,
CCMIOID  stateID,
) [private]
Definition at line 200 of file ReadCCMIO.cpp.
References moab::error(), ErrorCode, get_str_option(), load_matset_data(), load_neuset_data(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_OPAQUE, mbImpl, mCreatingProgramTag, moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
    // Read the simulation title.
    CCMIONode rootNode;
    if( kCCMIONoErr == CCMIOGetEntityNode( &error, rootID, &rootNode ) )
        char* name = NULL;
        CCMIOGetTitle( &error, rootNode, &name );
        if( NULL != name && strlen( name ) != 0 )
            // Make a tag for it and tag the read set
            Tag simname;
            rval = mbImpl->tag_get_handle( "Title", strlen( name ), MB_TYPE_OPAQUE, simname,
                                           MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR( rval, "Simulation name tag not found or created" );
            EntityHandle set = file_set ? *file_set : 0;
            rval             = mbImpl->tag_set_data( simname, &set, 1, name );MB_CHK_SET_ERR( rval, "Problem setting simulation name tag" );
        if( name ) free( name );
    // Creating program
    EntityHandle dumh = ( file_set ? *file_set : 0 );
    rval              = get_str_option( "CreatingProgram", dumh, mCreatingProgramTag, processorID );MB_CHK_SET_ERR( rval, "Trouble getting CreatingProgram tag" );
    rval = load_matset_data( problemID );MB_CHK_SET_ERR( rval, "Failure loading matset data" );
    rval = load_neuset_data( problemID );MB_CHK_SET_ERR( rval, "Failure loading neuset data" );
    return rval;
ErrorCode moab::ReadCCMIO::load_neuset_data ( CCMIOID  problemID) [private]
Definition at line 364 of file ReadCCMIO.cpp.
References moab::error(), ErrorCode, get_int_option(), get_str_option(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, mBoundaryTypeTag, mNameTag, mNeumannSetTag, mProstarRegionNumberTag, NAME_TAG_NAME, newNeusets, and moab::Interface::tag_set_data().
    CCMIOID next;
    if( newNeusets.empty() ) return MB_SUCCESS;
    while( CCMIONextEntity( NULL, problemID, kCCMIOBoundaryRegion, &i, &next ) == kCCMIONoErr )
        // Get index, corresponding set, and label with neumann set tag
        int mindex;
        std::map< int, EntityHandle >::iterator mit = newNeusets.find( mindex );
        if( mit == newNeusets.end() )
            // No actual faces for this neuset; continue to next
            continue;
        ErrorCode rval       = mbImpl->tag_set_data( mNeumannSetTag, &dum_ent, 1, &mindex );MB_CHK_SET_ERR( rval, "Trouble setting neumann set tag" );
        // Set name
        rval = get_str_option( "BoundaryName", dum_ent, mNameTag, next, NAME_TAG_NAME );MB_CHK_SET_ERR( rval, "Trouble creating BoundaryName tag" );
        // BoundaryType
        rval = get_str_option( "BoundaryType", dum_ent, mBoundaryTypeTag, next );MB_CHK_SET_ERR( rval, "Trouble creating BoundaryType tag" );
        // ProstarRegionNumber
        rval = get_int_option( "ProstarRegionNumber", dum_ent, mProstarRegionNumberTag, next );MB_CHK_SET_ERR( rval, "Trouble creating ProstarRegionNumber tag" );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::make_faces ( int *  farray,
TupleList vert_map,
std::vector< EntityHandle > &  new_faces,
int  num_faces
) [private]
Definition at line 1048 of file ReadCCMIO.cpp.
References moab::Interface::create_element(), ErrorCode, MB_SUCCESS, mbImpl, MBPOLYGON, MBQUAD, and MBTRI.
Referenced by read_faces().
    ErrorCode tmp_rval = MB_SUCCESS, rval = MB_SUCCESS;
    for( int i = 0; i < num_faces; i++ )
        int num_verts = *farray++;
        verts.resize( num_verts );
        // Fill in connectivity by looking up by gid in vert tuple_list
        for( int j = 0; j < num_verts; j++ )
#ifdef TUPLE_LIST
            int tindex = vert_map.find( 1, farray[j] );
            if( -1 == tindex )
                tmp_rval = MB_FAILURE;
                break;
            verts[j] = vert_map.get_ulong( tindex, 0 );
#else
            verts[j] = ( vert_map[farray[j]] )[0];
#endif
        farray += num_verts;
        if( MB_SUCCESS == tmp_rval )
            // Make face
            EntityType ftype = ( 3 == num_verts ? MBTRI : ( 4 == num_verts ? MBQUAD : MBPOLYGON ) );
            EntityHandle faceh;
            tmp_rval = mbImpl->create_element( ftype, &verts[0], num_verts, faceh );
            if( faceh ) new_faces.push_back( faceh );
    return rval;
ErrorCode moab::ReadCCMIO::read_all_faces ( CCMIOID  topologyID,
TupleList vert_map,
TupleList face_map,
Range new_faces
) [private]
Definition at line 895 of file ReadCCMIO.cpp.
References CHK_SET_CCMERR, moab::error(), ErrorCode, MB_CHK_SET_ERR, and read_faces().
    CCMIOSize_t index;
    CCMIOID faceID;
    ErrorCode rval;
    // Get total # internal/bdy faces, size the face map accordingly
#ifdef TUPLE_LIST
    index          = CCMIOSIZEC( 0 );
    int nbdy_faces = 0;
    CCMIOSize_t nf;
    while( kCCMIONoErr == CCMIONextEntity( NULL, topologyID, kCCMIOBoundaryFaces, &index, &faceID ) )
        CCMIOEntitySize( &error, faceID, &nf, NULL );
        nbdy_faces += nf;
    CCMIOGetEntity( &error, topologyID, kCCMIOInternalFaces, 0, &faceID );
    int nint_faces = nf;
    face_map.resize( 2 * nint_faces + nbdy_faces );
#endif
    // Get multiple blocks of bdy faces
        rval = read_faces( faceID, kCCMIOBoundaryFaces, vert_map, face_map,
#ifndef TUPLE_LIST
                           sense_map,
#endif
                           new_faces );MB_CHK_SET_ERR( rval, "Trouble reading boundary faces" );
    // Now get internal faces
    CHK_SET_CCMERR( error, "Couldn't get internal faces" );
    rval = read_faces( faceID, kCCMIOInternalFaces, vert_map, face_map,
#ifndef TUPLE_LIST
                       sense_map,
#endif
                       new_faces );MB_CHK_SET_ERR( rval, "Trouble reading internal faces" );
    return rval;
ErrorCode moab::ReadCCMIO::read_cells ( CCMIOSize_t  proc,
CCMIOID  verticesID,
CCMIOID  topologyID,
TupleList vert_map,
Range new_cells
) [private]
Definition at line 419 of file ReadCCMIO.cpp.
References construct_cells(), ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, read_all_faces(), read_gids_and_types(), and read_topology_types().
Referenced by read_processor().
    // Read the faces.
    // face_map fields: s:forward/reverse, i: cell id, ul: face handle, r: none
    ErrorCode rval;
#ifdef TUPLE_LIST
    TupleList face_map( 1, 1, 1, 0, 0 );
#else
    TupleList face_map;
    SenseList sense_map;
#endif
    rval = read_all_faces( topologyID, vert_map, face_map,
#ifndef TUPLE_LIST
                           sense_map,
#endif
                           new_ents );MB_CHK_SET_ERR( rval, "Failed to read all cells" );
    // Read the cell topology types, if any exist in the file
    std::map< int, int > cell_topo_types;
    rval = read_topology_types( topologyID, cell_topo_types );MB_CHK_SET_ERR( rval, "Problem reading cell topo types" );
    // Now construct the cells; sort the face map by cell ids first
#ifdef TUPLE_LIST
    rval = face_map.sort( 1 );MB_CHK_SET_ERR( rval, "Couldn't sort face map by cell id" );
#endif
    std::vector< EntityHandle > new_cells;
    rval = construct_cells( face_map,
#ifndef TUPLE_LIST
                            sense_map,
#endif
                            vert_map, cell_topo_types, new_cells );MB_CHK_SET_ERR( rval, "Failed to construct cells" );
    if( new_ents )
        Range::iterator rit = new_ents->end();
        std::vector< EntityHandle >::reverse_iterator vit;
        for( vit = new_cells.rbegin(); vit != new_cells.rend(); ++vit )
            rit = new_ents->insert( rit, *vit );
    rval = read_gids_and_types( problemID, topologyID, new_cells );MB_CHK_SET_ERR( rval, "Failed to read gids and types" );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::read_faces ( CCMIOID  faceID,
TupleList vert_map,
TupleList face_map,
Range new_faces
) [private]
Definition at line 950 of file ReadCCMIO.cpp.
References moab::Interface::add_entities(), CHK_SET_CCMERR, moab::Interface::create_meshset(), moab::error(), ErrorCode, make_faces(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, MESHSET_SET, mGlobalIdTag, mNeumannSetTag, newNeusets, and moab::Interface::tag_set_data().
Referenced by read_all_faces().
    if( kCCMIOInternalFaces != bdy_or_int && kCCMIOBoundaryFaces != bdy_or_int )
        MB_SET_ERR( MB_FAILURE, "Face type isn't boundary or internal" );
    CCMIOSize_t dum_faces;
    CCMIOEntitySize( &error, faceID, &dum_faces, NULL );
    int num_faces = GETINT32( dum_faces );
    // Get the size of the face connectivity array (not really a straight connect
    // array, has n, connect(n), ...)
    CCMIOSize_t farray_size = CCMIOSIZEC( 0 );
    CCMIOReadFaces( &error, faceID, bdy_or_int, NULL, &farray_size, NULL, CCMIOINDEXC( kCCMIOStart ),
                    CCMIOINDEXC( kCCMIOEnd ) );
    CHK_SET_CCMERR( error, "Trouble reading face connectivity length" );
    // Allocate vectors for holding farray and cells for each face; use new for finer
    // control of de-allocation
    int num_sides = ( kCCMIOInternalFaces == bdy_or_int ? 2 : 1 );
    int* farray   = new int[GETINT32( farray_size )];
    // Read farray and make the faces
    CCMIOID mapID;
    CCMIOReadFaces( &error, faceID, bdy_or_int, &mapID, NULL, farray, CCMIOINDEXC( kCCMIOStart ),
    CHK_SET_CCMERR( error, "Trouble reading face connectivity" );
    std::vector< EntityHandle > face_handles;
    ErrorCode rval = make_faces( farray, vert_map, face_handles, num_faces );MB_CHK_SET_ERR( rval, "Failed to make the faces" );
    // Read face cells and make tuples
    int* face_cells;
    if( num_sides * num_faces < farray_size )
        face_cells = new int[num_sides * num_faces];
    else
        face_cells = farray;
    CCMIOReadFaceCells( &error, faceID, bdy_or_int, face_cells, CCMIOINDEXC( kCCMIOStart ), CCMIOINDEXC( kCCMIOEnd ) );
    CHK_SET_CCMERR( error, "Trouble reading face cells" );
    int* tmp_ptr = face_cells;
    for( unsigned int i = 0; i < face_handles.size(); i++ )
#ifdef TUPLE_LIST
        short forward = 1, reverse = -1;
        face_map.push_back( &forward, tmp_ptr++, &face_handles[i], NULL );
        if( 2 == num_sides ) face_map.push_back( &reverse, tmp_ptr++, &face_handles[i], NULL );
#else
        face_map[*tmp_ptr].push_back( face_handles[i] );
        sense_map[*tmp_ptr++].push_back( 1 );
            sense_map[*tmp_ptr++].push_back( -1 );
#endif
    // Now read & set face gids, reuse face_cells 'cuz we know it's big enough
    CCMIOReadMap( &error, mapID, face_cells, CCMIOINDEXC( kCCMIOStart ), CCMIOINDEXC( kCCMIOEnd ) );
    CHK_SET_CCMERR( error, "Trouble reading face gids" );
    rval = mbImpl->tag_set_data( mGlobalIdTag, &face_handles[0], face_handles.size(), face_cells );MB_CHK_SET_ERR( rval, "Couldn't set face global ids" );
    // Make a neumann set for these faces if they're all in a boundary face set
    if( kCCMIOBoundaryFaces == bdy_or_int )
        EntityHandle neuset;
        rval = mbImpl->create_meshset( MESHSET_SET, neuset );MB_CHK_SET_ERR( rval, "Failed to create neumann set" );
        // Don't trust entity index passed in
        int index;
        CCMIOGetEntityIndex( &error, faceID, &index );
        newNeusets[index] = neuset;
        rval = mbImpl->add_entities( neuset, &face_handles[0], face_handles.size() );MB_CHK_SET_ERR( rval, "Failed to add faces to neumann set" );
        // Now tag as neumann set; will add id later
        int dum_val = 0;
        rval        = mbImpl->tag_set_data( mNeumannSetTag, &neuset, 1, &dum_val );MB_CHK_SET_ERR( rval, "Failed to tag neumann set" );
    if( new_faces )
        std::sort( face_handles.begin(), face_handles.end() );
        std::copy( face_handles.rbegin(), face_handles.rend(), range_inserter( *new_faces ) );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::read_gids_and_types ( CCMIOID  problemID,
CCMIOID  topologyID,
std::vector< EntityHandle > &  cells
) [private]
Definition at line 506 of file ReadCCMIO.cpp.
References moab::Interface::add_entities(), CHK_SET_CCMERR, moab::Interface::create_meshset(), moab::error(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, MESHSET_SET, mGlobalIdTag, newMatsets, and moab::Interface::tag_set_data().
    // Get the cells entity and number of cells
    CCMIOSize_t dum_cells;
    int num_cells;
    CCMIOID cellsID, mapID;
    CCMIOGetEntity( &error, topologyID, kCCMIOCells, 0, &cellsID );
    CCMIOEntitySize( &error, cellsID, &dum_cells, NULL );
    num_cells = GETINT32( dum_cells );
    // Check the number of cells against how many are in the cell array
    if( num_cells != (int)cells.size() ) MB_SET_ERR( MB_FAILURE, "Number of cells doesn't agree" );
    // Read the gid map and set global ids
    std::vector< int > cell_gids( num_cells );
    CCMIOReadCells( &error, cellsID, &mapID, NULL, CCMIOINDEXC( kCCMIOStart ), CCMIOINDEXC( kCCMIOEnd ) );
    CHK_SET_CCMERR( error, "Couldn't read cells" );
    CCMIOReadMap( &error, mapID, &cell_gids[0], CCMIOINDEXC( kCCMIOStart ), CCMIOINDEXC( kCCMIOEnd ) );
    CHK_SET_CCMERR( error, "Couldn't read cell id map" );
    ErrorCode rval = mbImpl->tag_set_data( mGlobalIdTag, &cells[0], cells.size(), &cell_gids[0] );MB_CHK_SET_ERR( rval, "Couldn't set gids tag" );
    // Now read cell material types; reuse cell_gids
    CCMIOReadCells( &error, cellsID, NULL, &cell_gids[0], CCMIOINDEXC( kCCMIOStart ), CCMIOINDEXC( kCCMIOEnd ) );
    CHK_SET_CCMERR( error, "Trouble reading cell types" );
    // Create the matsets
    std::map< int, Range > matset_ents;
    for( int i = 0; i < num_cells; i++ )
        matset_ents[cell_gids[i]].insert( cells[i] );
    for( std::map< int, Range >::iterator mit = matset_ents.begin(); mit != matset_ents.end(); ++mit )
        EntityHandle matset;
        rval = mbImpl->create_meshset( MESHSET_SET, matset );MB_CHK_SET_ERR( rval, "Couldn't create material set" );
        newMatsets[mit->first] = matset;
        rval = mbImpl->add_entities( matset, mit->second );MB_CHK_SET_ERR( rval, "Couldn't add entities to material set" );
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::read_processor ( CCMIOID  rootID,
CCMIOID  problemID,
CCMIOID  verticesID,
CCMIOID  topologyID,
CCMIOSize_t  proc,
Range new_ents
) [private]
Definition at line 399 of file ReadCCMIO.cpp.
References ErrorCode, MB_CHK_SET_ERR, read_cells(), and read_vertices().
    ErrorCode rval;
    // vert_map fields: s: none, i: gid, ul: vert handle, r: none
    // TupleList vert_map(0, 1, 1, 0, 0);
    TupleList vert_map;
    rval = read_vertices( proc, processorID, verticesID, topologyID, new_ents, vert_map );MB_CHK_SET_ERR( rval, "Failed to read vertices" );
    rval = read_cells( proc, problemID, verticesID, topologyID, vert_map, new_ents );MB_CHK_SET_ERR( rval, "Failed to read cells" );
    return rval;
ErrorCode moab::ReadCCMIO::read_tag_values ( const char *  file_name,
const char *  tag_name,
std::vector< int > &  tag_values_out,
) [private, virtual]
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Definition at line 1202 of file ReadCCMIO.cpp.
    return MB_FAILURE;
ErrorCode moab::ReadCCMIO::read_topology_types ( CCMIOID &  topologyID,
) [private]
Definition at line 468 of file ReadCCMIO.cpp.
    CCMIOID cellID, mapID;
    CCMIOSize_t ncells;
    CCMIOGetEntity( &error, topologyID, kCCMIOCells, 0, &cellID );
    CCMIOEntitySize( &error, cellID, &ncells, NULL );
    int num_cells = GETINT32( ncells );
    // First, do a dummy read to see if we even have topo types in this mesh
    int dum_int;
    CCMIOReadOpt1i( &error, cellID, "CellTopologyType", &dum_int, CCMIOINDEXC( kCCMIOStart ),
                    CCMIOINDEXC( kCCMIOStart ) + 1 );
    if( kCCMIONoErr != error ) return MB_SUCCESS;
    // OK, we have topo types; first get the map node
    std::vector< int > dum_ints( num_cells );
    CCMIOReadCells( &error, cellID, &mapID, &dum_ints[0], CCMIOINDEXC( kCCMIOStart ), CCMIOINDEXC( kCCMIOStart ) + 1 );
    CHK_SET_CCMERR( error, "Failed to get the map node" );
    // Now read the map
    CCMIOReadMap( &error, mapID, &dum_ints[0], CCMIOINDEXC( kCCMIOStart ), CCMIOINDEXC( kCCMIOEnd ) );
    CHK_SET_CCMERR( error, "Failed to get cell ids" );
    int i;
    for( i = 0; i < num_cells; i++ )
        cell_topo_types[dum_ints[i]] = 0;
    // Now read the cell topo types for real, reusing cell_topo_types
    std::vector< int > topo_types( num_cells );
    CCMIOReadOpt1i( &error, cellID, "CellTopologyType", &topo_types[0], CCMIOINDEXC( kCCMIOStart ),
    CHK_SET_CCMERR( error, "Failed to get cell topo types" );
        cell_topo_types[dum_ints[i]] = topo_types[i];
    return MB_SUCCESS;
ErrorCode moab::ReadCCMIO::read_vertices ( CCMIOSize_t  proc,
CCMIOID  verticesID,
CCMIOID  topologyID,
Range verts,
TupleList vert_map
) [private]
Definition at line 1093 of file ReadCCMIO.cpp.
References CHK_SET_CCMERR, moab::error(), ErrorCode, moab::ReadUtilIface::get_node_coords(), MB_CHK_SET_ERR, MB_START_ID, MB_SUCCESS, mbImpl, moab::Range::merge(), mGlobalIdTag, readMeshIface, and moab::Interface::tag_set_data().
    // Pre-read the number of vertices, so we can pre-allocate & read directly in
    CCMIOSize_t nverts = CCMIOSIZEC( 0 );
    CCMIOEntitySize( &error, verticesID, &nverts, NULL );
    CHK_SET_CCMERR( error, "Couldn't get number of vertices" );
    // Get # dimensions
    CCMIOSize_t dims;
    float scale;
    CCMIOReadVerticesf( &error, verticesID, &dims, NULL, NULL, NULL, CCMIOINDEXC( 0 ), CCMIOINDEXC( 1 ) );
    CHK_SET_CCMERR( error, "Couldn't get number of dimensions" );
    // Allocate vertex space
    EntityHandle node_handle = 0;
    std::vector< double* > arrays;
    readMeshIface->get_node_coords( 3, GETINT32( nverts ), MB_START_ID, node_handle, arrays );
    // Read vertex coords
    CCMIOID mapID;
    std::vector< double > tmp_coords( GETINT32( dims ) * GETINT32( nverts ) );
    CCMIOReadVerticesd( &error, verticesID, &dims, &scale, &mapID, &tmp_coords[0], CCMIOINDEXC( 0 ),
                        CCMIOINDEXC( 0 + nverts ) );
    CHK_SET_CCMERR( error, "Trouble reading vertex coordinates" );
    // Copy interleaved coords into moab blocked coordinate space
    int i = 0, threei = 0;
    for( ; i < nverts; i++ )
        arrays[0][i] = tmp_coords[threei++];
        arrays[1][i] = tmp_coords[threei++];
        if( 3 == GETINT32( dims ) )
            arrays[2][i] = tmp_coords[threei++];
        else
            arrays[2][i] = 0.0;
    // Scale, if necessary
    if( 1.0 != scale )
        for( i = 0; i < nverts; i++ )
            arrays[0][i] *= scale;
            arrays[1][i] *= scale;
            if( 3 == GETINT32( dims ) ) arrays[2][i] *= scale;
    // Read gids for vertices
    std::vector< int > gids( GETINT32( nverts ) );
    CCMIOReadMap( &error, mapID, &gids[0], CCMIOINDEXC( kCCMIOStart ), CCMIOINDEXC( kCCMIOEnd ) );
    CHK_SET_CCMERR( error, "Trouble reading vertex global ids" );
    // Put new vertex handles into range, and set gids for them
    Range new_verts( node_handle, node_handle + nverts - 1 );
    ErrorCode rval = mbImpl->tag_set_data( mGlobalIdTag, new_verts, &gids[0] );MB_CHK_SET_ERR( rval, "Couldn't set gids on vertices" );
    // Pack vert_map with global ids and handles for these vertices
#ifdef TUPLE_LIST
    vert_map.resize( GETINT32( nverts ) );
    for( i = 0; i < GETINT32( nverts ); i++ )
        vert_map.push_back( NULL, &gids[i], &node_handle, NULL );
#else
        ( vert_map[gids[i]] ).push_back( node_handle );
#endif
        node_handle += 1;
    if( verts ) verts->merge( new_verts );
    return MB_SUCCESS;
Member Data Documentation
Definition at line 169 of file ReadCCMIO.hpp.
Referenced by get_processors().
Definition at line 161 of file ReadCCMIO.hpp.
Referenced by load_neuset_data().
Definition at line 159 of file ReadCCMIO.hpp.
Definition at line 153 of file ReadCCMIO.hpp.
Referenced by ReadCCMIO().
Definition at line 155 of file ReadCCMIO.hpp.
Definition at line 158 of file ReadCCMIO.hpp.
Definition at line 152 of file ReadCCMIO.hpp.
Referenced by load_matset_data(), and ReadCCMIO().
Definition at line 157 of file ReadCCMIO.hpp.
Referenced by load_matset_data(), load_neuset_data(), and ReadCCMIO().
Definition at line 154 of file ReadCCMIO.hpp.
Referenced by load_neuset_data(), read_faces(), and ReadCCMIO().
std::map< int, EntityHandle > moab::ReadCCMIO::newMatsets [private]
Definition at line 167 of file ReadCCMIO.hpp.
Referenced by load_matset_data(), and read_gids_and_types().
std::map< int, EntityHandle > moab::ReadCCMIO::newNeusets [private]
Referenced by load_neuset_data(), and read_faces().
Definition at line 165 of file ReadCCMIO.hpp.
Referenced by read_vertices(), ReadCCMIO(), and ~ReadCCMIO().
List of all members.
