moab::ReadCCMIO Member List
This is the complete list of members for moab::ReadCCMIO, including all inherited members.
ccmio_to_moab_type(int ccm_type, EntityType &moab_type, bool &has_mid_nodes)moab::ReadCCMIO [private]
construct_cells(TupleList &face_map, SenseList &sense_map, TupleList &vert_map, std::map< int, int > &cell_topo_types, std::vector< EntityHandle > &new_cells)moab::ReadCCMIO [private]
create_cell_from_faces(std::vector< EntityHandle > &facehs, std::vector< int > &senses, EntityType this_type, bool has_mid_nodes, EntityHandle &cell)moab::ReadCCMIO [private]
factory(Interface *)moab::ReadCCMIO [static]
get_dbl_option(const char *opt_str, EntityHandle seth, Tag &tag, CCMIOID node)moab::ReadCCMIO [private]
get_int_option(const char *opt_str, EntityHandle seth, Tag &tag, CCMIOID node)moab::ReadCCMIO [private]
get_processors(CCMIOID stateID, CCMIOID &processorID, CCMIOID &verticesID, CCMIOID &topologyID, CCMIOID &solutionID, std::vector< CCMIOSize_t > &procs, bool &has_solution)moab::ReadCCMIO [private]
get_state(CCMIOID rootID, CCMIOID &problemID, CCMIOID &stateID)moab::ReadCCMIO [private]
get_str_option(const char *opt_str, EntityHandle seth, Tag &tag, CCMIOID node, const char *tag_name=NULL)moab::ReadCCMIO [private]
hasSolutionmoab::ReadCCMIO [private]
load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)moab::ReadCCMIO [virtual]
load_matset_data(CCMIOID problemID)moab::ReadCCMIO [private]
load_metadata(CCMIOID rootID, CCMIOID problemID, CCMIOID stateID, CCMIOID processorID, const EntityHandle *file_set)moab::ReadCCMIO [private]
load_neuset_data(CCMIOID problemID)moab::ReadCCMIO [private]
make_faces(int *farray, TupleList &vert_map, std::vector< EntityHandle > &new_faces, int num_faces)moab::ReadCCMIO [private]
mbImplmoab::ReadCCMIO [private]
mBoundaryTypeTagmoab::ReadCCMIO [private]
mColorIdxTagmoab::ReadCCMIO [private]
mCreatingProgramTagmoab::ReadCCMIO [private]
mDirichletSetTagmoab::ReadCCMIO [private]
mFreeSurfaceMaterialTagmoab::ReadCCMIO [private]
mGlobalIdTagmoab::ReadCCMIO [private]
mGroupIdTagmoab::ReadCCMIO [private]
mHasMidNodesTagmoab::ReadCCMIO [private]
mLightMaterialTagmoab::ReadCCMIO [private]
mMaterialIdTagmoab::ReadCCMIO [private]
mMaterialSetTagmoab::ReadCCMIO [private]
mMaterialTypeTagmoab::ReadCCMIO [private]
mNameTagmoab::ReadCCMIO [private]
mNeumannSetTagmoab::ReadCCMIO [private]
mPorosityIdTagmoab::ReadCCMIO [private]
mProcessorIdTagmoab::ReadCCMIO [private]
mProstarRegionNumberTagmoab::ReadCCMIO [private]
mRadiationTagmoab::ReadCCMIO [private]
mSpinIdTagmoab::ReadCCMIO [private]
mThicknessTagmoab::ReadCCMIO [private]
newMatsetsmoab::ReadCCMIO [private]
newNeusetsmoab::ReadCCMIO [private]
read_all_faces(CCMIOID topologyID, TupleList &vert_map, TupleList &face_map, SenseList &sense_map, Range *new_faces)moab::ReadCCMIO [private]
read_cells(CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID, TupleList &vert_map, Range *new_cells)moab::ReadCCMIO [private]
read_faces(CCMIOID faceID, CCMIOEntity bdy_or_int, TupleList &vert_map, TupleList &face_map, SenseList &sense_map, Range *new_faces)moab::ReadCCMIO [private]
read_gids_and_types(CCMIOID problemID, CCMIOID topologyID, std::vector< EntityHandle > &cells)moab::ReadCCMIO [private]
read_processor(CCMIOID rootID, CCMIOID problemID, CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID, CCMIOSize_t proc, Range *new_ents)moab::ReadCCMIO [private]
read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)moab::ReadCCMIO [private, virtual]
read_topology_types(CCMIOID &topologyID, std::map< int, int > &cell_topo_types)moab::ReadCCMIO [private]
read_vertices(CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID, Range *verts, TupleList &vert_map)moab::ReadCCMIO [private]
ReadCCMIO(Interface *impl)moab::ReadCCMIO
readMeshIfacemoab::ReadCCMIO [private]
SenseList typedefmoab::ReadCCMIO
TupleList typedefmoab::ReadCCMIO
~ReadCCMIO()moab::ReadCCMIO [virtual]
~ReaderIface()moab::ReaderIface [inline, virtual]
