moab::ReadCGM Class Reference
#include <ReadCGM.hpp>
+ Inheritance diagram for moab::ReadCGM:
+ Collaboration diagram for moab::ReadCGM:
Public Member Functions
void tokenize (const std::string &str, std::vector< std::string > &tokens, const char *delimiters)
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
 load a CGM file
ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
 ReadCGM (Interface *impl=NULL)
 Constructor.
virtual ~ReadCGM ()
 Destructor.
int get_failed_curve_count ()
int get_failed_surface_count ()
Static Public Member Functions
static ReaderIfacefactory (Interface *)
Private Member Functions
ErrorCode set_options (const FileOptions &opts, int &norm_tol, double &faceting_tol, double &len_tol, bool &act_att, bool &verbose_warnings, bool &fatal_on_curves)
ErrorCode create_entity_sets (std::map< RefEntity *, EntityHandle >(&entmap)[5])
ErrorCode create_topology (std::map< RefEntity *, EntityHandle >(&entitymap)[5])
ErrorCode store_surface_senses (std::map< RefEntity *, EntityHandle > &surface_map, std::map< RefEntity *, EntityHandle > &volume_map)
ErrorCode store_curve_senses (std::map< RefEntity *, EntityHandle > &curve_map, std::map< RefEntity *, EntityHandle > &surface_map)
ErrorCode store_groups (std::map< RefEntity *, EntityHandle >(&entitymap)[5])
ErrorCode create_group_entsets (std::map< RefEntity *, EntityHandle > &group_map)
ErrorCode store_group_content (std::map< RefEntity *, EntityHandle >(&entitymap)[5])
void set_cgm_attributes (bool const act_attributes, bool const verbose)
ErrorCode create_vertices (std::map< RefEntity *, EntityHandle > &vertex_map)
ErrorCode create_curve_facets (std::map< RefEntity *, EntityHandle > &curve_map, std::map< RefEntity *, EntityHandle > &vertex_map, int norm_tol, double faceting_tol, bool verbose_warn=false, bool fatal_on_curves=false)
ErrorCode create_surface_facets (std::map< RefEntity *, EntityHandle > &surface_map, std::map< RefEntity *, EntityHandle > &vertex_map, int norm_tol, double facet_tol, double length_tol)
void dump_fail_counts ()
const char * get_geom_file_type (const char *filename)
const char * get_geom_fptr_type (FILE *file)
int is_cubit_file (FILE *file)
int is_step_file (FILE *file)
int is_iges_file (FILE *file)
int is_occ_brep_file (FILE *file)
int is_facet_file (FILE *file)
Private Attributes
ReadUtilIfacereadUtilIface
GeomTopoToolmyGeomTool
InterfacemdbImpl
 interface instance
Tag geom_tag
Tag id_tag
Tag name_tag
Tag category_tag
Tag faceting_tol_tag
Tag geometry_resabs_tag
int failed_curve_count
std::vector< int > failed_curves
int failed_surface_count
std::vector< int > failed_surfaces
Detailed Description
Definition at line 47 of file ReadCGM.hpp.
moab::ReadCGM::ReadCGM ( Interface impl = NULL)
Constructor.
Definition at line 69 of file ReadCGM.cpp.
References category_tag, CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, ErrorCode, faceting_tol_tag, failed_curve_count, failed_surface_count, GEOM_DIMENSION_TAG_NAME, geom_tag, geometry_resabs_tag, moab::Interface::globalId_tag(), id_tag, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mdbImpl, myGeomTool, name_tag, NAME_TAG_NAME, NAME_TAG_SIZE, moab::Interface::query_interface(), readUtilIface, and moab::Interface::tag_get_handle().
Referenced by factory().
    : geom_tag( 0 ), id_tag( 0 ), name_tag( 0 ), category_tag( 0 ), faceting_tol_tag( 0 ), geometry_resabs_tag( 0 )
    assert( NULL != impl );
    mdbImpl    = impl;
    myGeomTool = new GeomTopoTool( impl );
    impl->query_interface( readUtilIface );
    assert( NULL != readUtilIface );
    // initialise counters
    failed_curve_count   = 0;
    failed_surface_count = 0;
    ErrorCode rval;
    // get some tag handles
    int negone = -1, zero = 0 /*, negonearr[] = {-1, -1, -1, -1}*/;
    rval = mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag, MB_TAG_SPARSE | MB_TAG_CREAT,
                                    &negone );
    assert( !rval );
    id_tag = mdbImpl->globalId_tag();
    rval =
        mdbImpl->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, name_tag, MB_TAG_SPARSE | MB_TAG_CREAT );
    assert( !rval );
    rval = mdbImpl->tag_get_handle( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, MB_TYPE_OPAQUE, category_tag,
    assert( !rval );
    rval = mdbImpl->tag_get_handle( "FACETING_TOL", 1, MB_TYPE_DOUBLE, faceting_tol_tag, MB_TAG_SPARSE | MB_TAG_CREAT );
    assert( !rval );
    rval = mdbImpl->tag_get_handle( "GEOMETRY_RESABS", 1, MB_TYPE_DOUBLE, geometry_resabs_tag,
    assert( !rval );
#ifdef NDEBUG
    if( !rval )
    };  // Line to avoid compiler warning about variable set but not used
#endif
moab::ReadCGM::~ReadCGM ( ) [virtual]
Destructor.
Definition at line 110 of file ReadCGM.cpp.
References mdbImpl, myGeomTool, readUtilIface, and moab::Interface::release_interface().
Member Function Documentation
ErrorCode moab::ReadCGM::create_curve_facets ( std::map< RefEntity *, EntityHandle > &  curve_map,
std::map< RefEntity *, EntityHandle > &  vertex_map,
int  norm_tol,
bool  verbose_warn = false,
bool  fatal_on_curves = false
) [private]
Definition at line 532 of file ReadCGM.cpp.
References moab::Interface::add_entities(), moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, failed_curve_count, failed_curves, GEOMETRY_RESABS, length(), MB_SUCCESS, MBEDGE, and mdbImpl.
Referenced by load_file().
    ErrorCode rval;
    CubitStatus s;
    // Maximum allowable curve-endpoint proximity warnings
    // If this integer becomes negative, then abs(curve_warnings) is the
    // number of warnings that were suppressed.
    int curve_warnings = 0;
    // Map iterator
    std::map< RefEntity*, EntityHandle >::iterator ci;
    // Create geometry for all curves
    GMem data;
    for( ci = curve_map.begin(); ci != curve_map.end(); ++ci )
        // Get the start and end points of the curve in the form of a reference edge
        RefEdge* edge = dynamic_cast< RefEdge* >( ci->first );
        // Get the edge's curve information
        Curve* curve = edge->get_curve_ptr();
        // Clean out previous curve information
        data.clean_out();
        // Facet curve according to parameters and CGM version
#if CGM_MAJOR_VERSION > 12
        s = edge->get_graphics( data, norm_tol, faceting_tol );
#else
        s = edge->get_graphics( data, faceting_tol );
#endif
        if( s != CUBIT_SUCCESS )
            // if we fatal on curves
            if( fatal_on_curves )
                std::cout << "Failed to facet the curve " << edge->id() << std::endl;
                return MB_FAILURE;
            // otherwise record them
            else
                failed_curve_count++;
                failed_curves.push_back( edge->id() );
            continue;
        std::vector< CubitVector > points;
        for( int i = 0; i < data.pointListCount; ++i )
            // Add Cubit vertext points to a list
            points.push_back( CubitVector( data.point_list()[i].x, data.point_list()[i].y, data.point_list()[i].z ) );
        // Need to reverse data?
        if( curve->bridge_sense() == CUBIT_REVERSED ) std::reverse( points.begin(), points.end() );
        // Check for closed curve
        RefVertex *start_vtx, *end_vtx;
        start_vtx = edge->start_vertex();
        end_vtx   = edge->end_vertex();
        // Special case for point curve
        if( points.size() < 2 )
            if( start_vtx != end_vtx || curve->measure() > GEOMETRY_RESABS )
                std::cerr << "Warning: No facetting for curve " << edge->id() << std::endl;
                continue;
            EntityHandle h = vertex_map[start_vtx];
            rval           = mdbImpl->add_entities( ci->second, &h, 1 );
            if( MB_SUCCESS != rval ) return MB_FAILURE;
            continue;
        // Check to see if the first and last interior vertices are considered to be
        // coincident by CUBIT
        const bool closed = ( points.front() - points.back() ).length() < GEOMETRY_RESABS;
        if( closed != ( start_vtx == end_vtx ) )
            std::cerr << "Warning: topology and geometry inconsistant for possibly closed curve " << edge->id()
                      << std::endl;
        // Check proximity of vertices to end coordinates
        if( ( start_vtx->coordinates() - points.front() ).length() > GEOMETRY_RESABS ||
            ( end_vtx->coordinates() - points.back() ).length() > GEOMETRY_RESABS )
            curve_warnings--;
            if( curve_warnings >= 0 || verbose_warn )
                std::cerr << "Warning: vertices not at ends of curve " << edge->id() << std::endl;
                if( curve_warnings == 0 && !verbose_warn )
                    std::cerr << "         further instances of this warning will be suppressed..." << std::endl;
        // Create interior points
        std::vector< EntityHandle > verts, edges;
        verts.push_back( vertex_map[start_vtx] );
        for( size_t i = 1; i < points.size() - 1; ++i )
            double coords[] = { points[i].x(), points[i].y(), points[i].z() };
            EntityHandle h;
            // Create vertex entity
            rval = mdbImpl->create_vertex( coords, h );
            verts.push_back( h );
        verts.push_back( vertex_map[end_vtx] );
        // Create edges
        for( size_t i = 0; i < verts.size() - 1; ++i )
            EntityHandle h;
            rval = mdbImpl->create_element( MBEDGE, &verts[i], 2, h );
            edges.push_back( h );
        // If closed, remove duplicate
        if( verts.front() == verts.back() ) verts.pop_back();
        // Add entities to the curve meshset from entitymap
        rval = mdbImpl->add_entities( ci->second, &verts[0], verts.size() );
        rval = mdbImpl->add_entities( ci->second, &edges[0], edges.size() );
    if( !verbose_warn && curve_warnings < 0 )
        std::cerr << "Suppressed " << -curve_warnings << " 'vertices not at ends of curve' warnings." << std::endl;
        std::cerr << "To see all warnings, use reader param VERBOSE_CGM_WARNINGS." << std::endl;
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::create_entity_sets ( std::map< RefEntity *, EntityHandle >(&)  entmap[5]) [private]
Definition at line 162 of file ReadCGM.cpp.
References category_tag, CATEGORY_TAG_SIZE, moab::Interface::create_meshset(), dim, ErrorCode, geom_tag, id_tag, MB_SUCCESS, mdbImpl, MESHSET_SET, and moab::Interface::tag_set_data().
    ErrorCode rval;
    const char geom_categories[][CATEGORY_TAG_SIZE] = { "Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0" };
    const char* const names[]                       = { "Vertex", "Curve", "Surface", "Volume" };
    DLIList< RefEntity* > entlist;
    for( int dim = 0; dim < 4; dim++ )
        entlist.clean_out();
        GeometryQueryTool::instance()->ref_entity_list( names[dim], entlist, true );
        entlist.reset();
        for( int i = entlist.size(); i--; )
            RefEntity* ent = entlist.get_and_step();
            EntityHandle handle;
            // Create the new meshset
            rval = mdbImpl->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle );
            if( MB_SUCCESS != rval ) return rval;
            // Map the geom reference entity to the corresponding moab meshset
            entmap[dim][ent] = handle;
            // Create tags for the new meshset
            rval = mdbImpl->tag_set_data( geom_tag, &handle, 1, &dim );
            int id = ent->id();
            rval   = mdbImpl->tag_set_data( id_tag, &handle, 1, &id );
            rval = mdbImpl->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] );
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::create_group_entsets ( std::map< RefEntity *, EntityHandle > &  group_map) [private]
Definition at line 333 of file ReadCGM.cpp.
References category_tag, CATEGORY_TAG_SIZE, moab::Interface::create_meshset(), ErrorCode, id_tag, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_OPAQUE, mdbImpl, MESHSET_SET, name_tag, NAME_TAG_NAME, NAME_TAG_SIZE, t, moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by store_groups().
    ErrorCode rval;
    DLIList< RefEntity* > entitylist;
    // Create entity sets for all ref groups
    std::vector< Tag > extra_name_tags;
#if CGM_MAJOR_VERSION > 13
    DLIList< CubitString > name_list;
#else
    DLIList< CubitString* > name_list;
#endif
    entitylist.clean_out();
    // Get all entity groups from the CGM model
    GeometryQueryTool::instance()->ref_entity_list( "group", entitylist );
    entitylist.reset();
    // Loop over all groups
    for( int i = entitylist.size(); i--; )
        // Take the next group
        RefEntity* grp = entitylist.get_and_step();
        name_list.clean_out();
// Get the names of all entities in this group from the solid model
        RefEntityName::instance()->get_refentity_name( grp, name_list );
#else
        // True argument is optional, but for large multi-names situation, it should save
        // some cpu time
        RefEntityName::instance()->get_refentity_name( grp, name_list, true );
#endif
        if( name_list.size() == 0 ) continue;
        // Set pointer to first name of the group and set the first name to name1
        name_list.reset();
        CubitString name1 = name_list.get();
#else
        CubitString name1 = *name_list.get();
#endif
        // Create entity handle for the group
        EntityHandle h;
        rval = mdbImpl->create_meshset( MESHSET_SET, h );
        // Set tag data for the group
        char namebuf[NAME_TAG_SIZE];
        memset( namebuf, '\0', NAME_TAG_SIZE );
        strncpy( namebuf, name1.c_str(), NAME_TAG_SIZE - 1 );
        if( name1.length() >= (unsigned)NAME_TAG_SIZE )
            std::cout << "WARNING: group name '" << name1.c_str() << "' truncated to '" << namebuf << "'" << std::endl;
        rval = mdbImpl->tag_set_data( name_tag, &h, 1, namebuf );
        int id = grp->id();
        rval   = mdbImpl->tag_set_data( id_tag, &h, 1, &id );
        rval = mdbImpl->tag_set_data( category_tag, &h, 1, &geom_categories[4] );
        // Check for extra group names
        if( name_list.size() > 1 )
            for( int j = extra_name_tags.size(); j < name_list.size(); ++j )
                sprintf( namebuf, "EXTRA_%s%d", NAME_TAG_NAME, j );
                Tag t;
                rval =
                    mdbImpl->tag_get_handle( namebuf, NAME_TAG_SIZE, MB_TYPE_OPAQUE, t, MB_TAG_SPARSE | MB_TAG_CREAT );
                assert( !rval );
                extra_name_tags.push_back( t );
            // Add extra group names to the group handle
            for( int j = 0; j < name_list.size(); ++j )
                name1 = name_list.get_and_step();
#else
                name1 = *name_list.get_and_step();
#endif
                              << std::endl;
                rval = mdbImpl->tag_set_data( extra_name_tags[j], &h, 1, namebuf );
        // Add the group handle
        group_map[grp] = h;
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::create_surface_facets ( std::map< RefEntity *, EntityHandle > &  surface_map,
int  norm_tol,
double  facet_tol,
double  length_tol
) [private]
Definition at line 678 of file ReadCGM.cpp.
References moab::Interface::add_entities(), moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, failed_surface_count, failed_surfaces, GEOMETRY_RESABS, moab::Range::insert(), MB_SUCCESS, MBPOLYGON, MBQUAD, MBTRI, and mdbImpl.
    ErrorCode rval;
    CubitStatus s;
#if( ( CGM_MAJOR_VERSION == 14 && CGM_MINOR_VERSION > 2 ) || CGM_MAJOR_VERSION >= 15 )
    DLIList< TopologyEntity* > me_list;
#else
    DLIList< ModelEntity* > me_list;
#endif
    GMem data;
    // Create geometry for all surfaces
    for( ci = surface_map.begin(); ci != surface_map.end(); ++ci )
        RefFace* face = dynamic_cast< RefFace* >( ci->first );
        data.clean_out();
        s = face->get_graphics( data, norm_tol, facet_tol, length_tol );
        if( CUBIT_SUCCESS != s ) return MB_FAILURE;
        // Declare array of all vertex handles
        std::vector< EntityHandle > verts( data.pointListCount, 0 );
        // Get list of geometric vertices in surface
        ModelQueryEngine::instance()->query_model( *face, DagType::ref_vertex_type(), me_list );
        // For each geometric vertex, find a single coincident point in facets
        // Otherwise, print a warning
        for( int i = me_list.size(); i--; )
            // Assign geometric vertex
            RefVertex* vtx  = dynamic_cast< RefVertex* >( me_list.get_and_step() );
            CubitVector pos = vtx->coordinates();
            for( int j = 0; j < data.pointListCount; ++j )
                // Assign facet vertex
                CubitVector vpos( data.point_list()[j].x, data.point_list()[j].y, data.point_list()[j].z );
                // Check to see if they are considered coincident
                if( ( pos - vpos ).length_squared() < GEOMETRY_RESABS * GEOMETRY_RESABS )
                    // If this facet vertex has already been found coincident, print warning
                    if( verts[j] ) std::cerr << "Warning: Coincident vertices in surface " << face->id() << std::endl;
                    // If a coincidence is found, keep track of it in the verts vector
                    verts[j] = vertex_map[vtx];
                    break;
        // Now create vertices for the remaining points in the facetting
            if( verts[i] )  // If a geometric vertex
                continue;
            double coords[] = { data.point_list()[i].x, data.point_list()[i].y, data.point_list()[i].z };
            // Return vertex handle to verts to fill in all remaining facet
            // vertices
            rval = mdbImpl->create_vertex( coords, verts[i] );
        // record the failures for information
        if( data.fListCount == 0 )
            failed_surface_count++;
            failed_surfaces.push_back( face->id() );
        // Now create facets
        Range facets;
        std::vector< EntityHandle > corners;
        for( int i = 0; i < data.fListCount; i += data.facet_list()[i] + 1 )
            // Get number of facet verts
            int* facet = data.facet_list() + i;
            corners.resize( *facet );
            for( int j = 1; j <= *facet; ++j )
                if( facet[j] >= (int)verts.size() )
                    std::cerr << "ERROR: Invalid facet data for surface " << face->id() << std::endl;
                    return MB_FAILURE;
                corners[j - 1] = verts[facet[j]];
            EntityType type;
            if( *facet == 3 )
                type = MBTRI;
            else
                std::cerr << "Warning: non-triangle facet in surface " << face->id() << std::endl;
                std::cerr << "  entity has " << *facet << " edges" << std::endl;
                if( *facet == 4 )
                    type = MBQUAD;
                else
                    type = MBPOLYGON;
            // if (surf->bridge_sense() == CUBIT_REVERSED)
            // std::reverse(corners.begin(), corners.end());
            EntityHandle h;
            rval = mdbImpl->create_element( type, &corners[0], corners.size(), h );
            facets.insert( h );
        // Add vertices and facets to surface set
        rval = mdbImpl->add_entities( ci->second, facets );
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::create_topology ( std::map< RefEntity *, EntityHandle >(&)  entitymap[5]) [private]
Definition at line 202 of file ReadCGM.cpp.
References moab::Interface::add_parent_child(), dim, ErrorCode, MB_SUCCESS, and mdbImpl.
    ErrorCode rval;
    for( int dim = 1; dim < 4; ++dim )
        for( ci = entitymap[dim].begin(); ci != entitymap[dim].end(); ++ci )
            ci->first->get_child_ref_entities( entitylist );
            entitylist.reset();
                RefEntity* ent = entitylist.get_and_step();
                EntityHandle h = entitymap[dim - 1][ent];
                rval           = mdbImpl->add_parent_child( ci->second, h );
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::create_vertices ( std::map< RefEntity *, EntityHandle > &  vertex_map) [private]
Definition at line 508 of file ReadCGM.cpp.
References moab::Interface::add_entities(), moab::Interface::create_vertex(), ErrorCode, MB_SUCCESS, and mdbImpl.
    ErrorCode rval;
    for( ci = vertex_map.begin(); ci != vertex_map.end(); ++ci )
        CubitVector pos  = dynamic_cast< RefVertex* >( ci->first )->coordinates();
        double coords[3] = { pos.x(), pos.y(), pos.z() };
        EntityHandle vh;
        rval = mdbImpl->create_vertex( coords, vh );
        // Add the vertex to its tagged meshset
        rval = mdbImpl->add_entities( ci->second, &vh, 1 );
        // Replace the meshset handle with the vertex handle
        // This makes adding the vertex to higher dim sets easier
        ci->second = vh;
    return MB_SUCCESS;
void moab::ReadCGM::dump_fail_counts ( ) [private]
Dumps the failed faceting information to screen
Definition at line 913 of file ReadCGM.cpp.
References failed_curve_count, failed_curves, failed_surface_count, and failed_surfaces.
    std::cout << "***** Faceting Summary Information *****" << std::endl;
    std::cout << "----- Curve Fail Information -----" << std::endl;
    std::cout << "There were " << failed_curve_count << " curves that could not be faceted." << std::endl;
    if( failed_curve_count > 0 )
        std::cout << "The curves were ";
        for( int i = 0; i < failed_curve_count; i++ )
            std::cout << failed_curves[i] << " ";
            if( ( i % 10 == 0 ) & ( i > 0 ) ) std::cout << std::endl;
    std::cout << "----- Facet Fail Information -----" << std::endl;
    std::cout << "There were " << failed_surface_count << " surfaces that could not be faceted." << std::endl;
    if( failed_surface_count > 0 )
        std::cout << "The surfaces were ";
        for( int i = 0; i < failed_surface_count; i++ )
            std::cout << failed_surfaces[i] << " ";
    std::cout << "***** End of Faceting Summary Information *****" << std::endl;
    return;
ReaderIface * moab::ReadCGM::factory ( Interface iface) [static]
Definition at line 64 of file ReadCGM.cpp.
References ReadCGM().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadCGM( iface );
Definition at line 902 of file ReadCGM.cpp.
References failed_curve_count.
    return failed_curve_count;
Definition at line 908 of file ReadCGM.cpp.
References failed_surface_count.
const char * moab::ReadCGM::get_geom_file_type ( const char *  filename) [private]
Definition at line 945 of file ReadCGM.cpp.
References get_geom_fptr_type().
    FILE* file;
    const char* result = 0;
    file = fopen( name, "r" );
    if( file )
        result = get_geom_fptr_type( file );
        fclose( file );
    return result;
const char * moab::ReadCGM::get_geom_fptr_type ( FILE *  file) [private]
Definition at line 960 of file ReadCGM.cpp.
References GF_CUBIT_FILE_TYPE, GF_FACET_FILE_TYPE, GF_IGES_FILE_TYPE, GF_OCC_BREP_FILE_TYPE, GF_STEP_FILE_TYPE, is_cubit_file(), is_facet_file(), is_iges_file(), is_occ_brep_file(), and is_step_file().
Referenced by get_geom_file_type().
    static const char* CUBIT_NAME = GF_CUBIT_FILE_TYPE;
    static const char* STEP_NAME  = GF_STEP_FILE_TYPE;
    static const char* IGES_NAME  = GF_IGES_FILE_TYPE;
    static const char* BREP_NAME  = GF_OCC_BREP_FILE_TYPE;
    static const char* FACET_NAME = GF_FACET_FILE_TYPE;
    if( is_cubit_file( file ) )
        return CUBIT_NAME;
    else if( is_step_file( file ) )
        return STEP_NAME;
    else if( is_iges_file( file ) )
        return IGES_NAME;
    else if( is_occ_brep_file( file ) )
        return BREP_NAME;
    else if( is_facet_file( file ) )
        return FACET_NAME;
    else
        return NULL;
int moab::ReadCGM::is_cubit_file ( FILE *  file) [private]
Definition at line 982 of file ReadCGM.cpp.
References buffer.
Referenced by get_geom_fptr_type().
    unsigned char buffer[4];
    return !fseek( file, 0, SEEK_SET ) && fread( buffer, 4, 1, file ) && !memcmp( buffer, "CUBE", 4 );
int moab::ReadCGM::is_facet_file ( FILE *  file) [private]
Definition at line 1005 of file ReadCGM.cpp.
References buffer.
    unsigned char buffer[10];
    return !fseek( file, 0, SEEK_SET ) && fread( buffer, 10, 1, file ) && !memcmp( buffer, "MESH_BASED", 10 );
int moab::ReadCGM::is_iges_file ( FILE *  file) [private]
Definition at line 994 of file ReadCGM.cpp.
References buffer.
    return !fseek( file, 72, SEEK_SET ) && fread( buffer, 10, 1, file ) && !memcmp( buffer, "S      1", 8 );
int moab::ReadCGM::is_occ_brep_file ( FILE *  file) [private]
Definition at line 1000 of file ReadCGM.cpp.
References buffer.
    unsigned char buffer[6];
    return !fseek( file, 0, SEEK_SET ) && fread( buffer, 6, 1, file ) && !memcmp( buffer, "DBRep_", 6 );
int moab::ReadCGM::is_step_file ( FILE *  file) [private]
Definition at line 988 of file ReadCGM.cpp.
References buffer.
    unsigned char buffer[9];
    return !fseek( file, 0, SEEK_SET ) && fread( buffer, 9, 1, file ) && !memcmp( buffer, "ISO-10303", 9 );
ErrorCode moab::ReadCGM::load_file ( const char *  file_name,
const EntityHandle file_set,
const FileOptions opts,
const SubsetList subset_list = 0,
const Tag file_id_tag = 0
) [virtual]
load a CGM file
Implements moab::ReaderIface.
Definition at line 805 of file ReadCGM.cpp.
References create_curve_facets(), create_entity_sets(), create_surface_facets(), create_topology(), create_vertices(), dump_fail_counts(), ErrorCode, faceting_tol_tag, GEOMETRY_RESABS, geometry_resabs_tag, get_geom_file_type(), MB_SET_ERR, MB_SUCCESS, MB_UNSUPPORTED_OPERATION, mdbImpl, set_cgm_attributes(), set_options(), store_curve_senses(), store_groups(), store_surface_senses(), and moab::Interface::tag_set_data().
    // Blocks_to_load and num_blocks are ignored.
    ErrorCode rval;
    if( subset_list )
        MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for CGM data" );
    int norm_tol;
    double faceting_tol;
    double len_tol;
    bool act_att          = true;
    bool verbose_warnings = false;
    bool fatal_on_curves  = false;
    rval = set_options( opts, norm_tol, faceting_tol, len_tol, act_att, verbose_warnings, fatal_on_curves );
    // Always tag with the faceting_tol and geometry absolute resolution
    // If file_set is defined, use that, otherwise (file_set == NULL) tag the interface
    EntityHandle set = file_set ? *file_set : 0;
    rval             = mdbImpl->tag_set_data( faceting_tol_tag, &set, 1, &faceting_tol );
    rval = mdbImpl->tag_set_data( geometry_resabs_tag, &set, 1, &GEOMETRY_RESABS );
    // Initialize CGM
    InitCGMA::initialize_cgma();
    // Determine CGM settings and amount of output
    set_cgm_attributes( act_att, verbose_warnings );
    CubitStatus s;
    // Get CGM file type
    const char* file_type = 0;
    file_type             = get_geom_file_type( cgm_file_name );
    if( !file_type || !strcmp( file_type, "CUBIT" ) ) return MB_FAILURE;
    s = CubitCompat_import_solid_model( cgm_file_name, file_type );
        MB_SET_ERR( MB_FAILURE, cgm_file_name << ": Failed to read file of type \"" << file_type << "\"" );
    // Create entity sets for all geometric entities
    std::map< RefEntity*, EntityHandle > entmap[5];  // One for each dim, and one for groups
    rval = create_entity_sets( entmap );
    if( rval != MB_SUCCESS ) return rval;
    // Create topology for all geometric entities
    rval = create_topology( entmap );
    // Store CoFace senses
    rval = store_surface_senses( entmap[2], entmap[3] );
    // Store CoEdge senses
    rval = store_curve_senses( entmap[1], entmap[2] );
    // Get group information and store it in the mesh
    rval = store_groups( entmap );
    // Done with volumes and groups
    entmap[3].clear();
    entmap[4].clear();
    // Create geometry for all vertices and replace
    rval = create_vertices( entmap[0] );
    // Create facets for all curves
    rval = create_curve_facets( entmap[1], entmap[0], norm_tol, faceting_tol, verbose_warnings, fatal_on_curves );
    // Create facets for surfaces
    rval = create_surface_facets( entmap[2], entmap[0], norm_tol, faceting_tol, len_tol );
    // print the fail information
    dump_fail_counts();
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::read_tag_values ( const char *  file_name,
const char *  tag_name,
std::vector< int > &  tag_values_out,
) [virtual]
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
file_nameThe file to read.
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Definition at line 116 of file ReadCGM.cpp.
References MB_NOT_IMPLEMENTED.
    return MB_NOT_IMPLEMENTED;
void moab::ReadCGM::set_cgm_attributes ( bool const  act_attributes,
bool const  verbose
) [private]
Definition at line 494 of file ReadCGM.cpp.
    if( act_attributes )
        CGMApp::instance()->attrib_manager()->set_all_auto_read_flags( act_attributes );
        CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags( act_attributes );
    if( !verbose )
        CGMApp::instance()->attrib_manager()->silent_flag( true );
ErrorCode moab::ReadCGM::set_options ( const FileOptions opts,
int &  norm_tol,
double &  faceting_tol,
double &  len_tol,
bool &  act_att,
bool &  verbose_warnings,
bool &  fatal_on_curves
) [private]
Definition at line 126 of file ReadCGM.cpp.
References DEFAULT_NORM, ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_null_option(), moab::FileOptions::get_real_option(), moab::FileOptions::match_option(), and MB_SUCCESS.
    ErrorCode rval;
    // Default Values
    int DEFAULT_NORM         = 5;
    double DEFAULT_FACET_TOL = 0.001;
    double DEFAULT_LEN_TOL   = 0.0;
    act_att                  = true;
    // Check for the options.
    if( MB_SUCCESS != opts.get_int_option( "FACET_NORMAL_TOLERANCE", norm_tol ) ) norm_tol = DEFAULT_NORM;
    if( MB_SUCCESS != opts.get_real_option( "FACET_DISTANCE_TOLERANCE", faceting_tol ) )
        faceting_tol = DEFAULT_FACET_TOL;
    if( MB_SUCCESS != opts.get_real_option( "MAX_FACET_EDGE_LENGTH", len_tol ) ) len_tol = DEFAULT_LEN_TOL;
    if( MB_SUCCESS == opts.get_null_option( "VERBOSE_CGM_WARNINGS" ) ) verbose_warnings = true;
    if( MB_SUCCESS == opts.get_null_option( "FATAL_ON_CURVES" ) ) fatal_on_curves = true;
    const char* name  = "CGM_ATTRIBS";
    const char* value = "no";
    rval              = opts.match_option( name, value );
    if( MB_SUCCESS == rval ) act_att = false;
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::store_curve_senses ( std::map< RefEntity *, EntityHandle > &  curve_map,
) [private]
Definition at line 284 of file ReadCGM.cpp.
References ErrorCode, MB_SUCCESS, myGeomTool, SENSE_REVERSE, and moab::GeomTopoTool::set_senses().
    ErrorCode rval;
    std::vector< EntityHandle > ents;
    std::vector< int > senses;
        RefEdge* edge = (RefEdge*)( ci->first );
        ents.clear();
        senses.clear();
        for( SenseEntity* ce = edge->get_first_sense_entity_ptr(); ce; ce = ce->next_on_bte() )
            BasicTopologyEntity* fac = ce->get_parent_basic_topology_entity_ptr();
            EntityHandle face        = surface_map[fac];
            if( ce->get_sense() == CUBIT_UNKNOWN || ce->get_sense() != edge->get_curve_ptr()->bridge_sense() )
                ents.push_back( face );
                senses.push_back( SENSE_REVERSE );
            if( ce->get_sense() == CUBIT_UNKNOWN || ce->get_sense() == edge->get_curve_ptr()->bridge_sense() )
                senses.push_back( SENSE_FORWARD );
        rval = myGeomTool->set_senses( ci->second, ents, senses );
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::store_group_content ( std::map< RefEntity *, EntityHandle >(&)  entitymap[5]) [private]
Definition at line 426 of file ReadCGM.cpp.
References moab::Interface::add_entities(), dim, moab::Range::empty(), entities, ErrorCode, moab::Range::insert(), MB_SUCCESS, and mdbImpl.
    ErrorCode rval;
    // Store contents for each group
    entlist.reset();
    for( ci = entitymap[4].begin(); ci != entitymap[4].end(); ++ci )
        RefGroup* grp = (RefGroup*)( ci->first );
        grp->get_child_ref_entities( entlist );
        Range entities;
        while( entlist.size() )
            RefEntity* ent = entlist.pop();
            int dim        = ent->dimension();
            if( dim < 0 )
                Body* body;
                if( entitymap[4].find( ent ) != entitymap[4].end() )
                    // Child is another group; examine its contents
                    entities.insert( entitymap[4][ent] );
                else if( ( body = dynamic_cast< Body* >( ent ) ) != NULL )
                    // Child is a CGM Body, which presumably comprises some volumes--
                    // extract volumes as if they belonged to group.
                    DLIList< RefVolume* > vols;
                    body->ref_volumes( vols );
                    for( int vi = vols.size(); vi--; )
                        RefVolume* vol = vols.get_and_step();
                        if( entitymap[3].find( vol ) != entitymap[3].end() )
                            entities.insert( entitymap[3][vol] );
                        else
                            std::cerr << "Warning: CGM Body has orphan RefVolume" << std::endl;
                else
                    // Otherwise, warn user.
                    std::cerr << "Warning: A dim<0 entity is being ignored by ReadCGM." << std::endl;
            else if( dim < 4 )
                if( entitymap[dim].find( ent ) != entitymap[dim].end() ) entities.insert( entitymap[dim][ent] );
        if( !entities.empty() )
            rval = mdbImpl->add_entities( ci->second, entities );
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::store_groups ( std::map< RefEntity *, EntityHandle >(&)  entitymap[5]) [private]
Definition at line 318 of file ReadCGM.cpp.
References create_group_entsets(), ErrorCode, MB_SUCCESS, and store_group_content().
    ErrorCode rval;
    rval = create_group_entsets( entitymap[4] );
    // Store group names and entities in the mesh
    rval = store_group_content( entitymap );
    return MB_SUCCESS;
ErrorCode moab::ReadCGM::store_surface_senses ( std::map< RefEntity *, EntityHandle > &  surface_map,
std::map< RefEntity *, EntityHandle > &  volume_map
) [private]
Definition at line 229 of file ReadCGM.cpp.
References ErrorCode, MB_SUCCESS, myGeomTool, SENSE_REVERSE, and moab::GeomTopoTool::set_sense().
    ErrorCode rval;
        RefFace* face                = (RefFace*)( ci->first );
        BasicTopologyEntity *forward = 0, *reverse = 0;
        for( SenseEntity* cf = face->get_first_sense_entity_ptr(); cf; cf = cf->next_on_bte() )
            BasicTopologyEntity* vol = cf->get_parent_basic_topology_entity_ptr();
            // Allocate vol to the proper topology entity (forward or reverse)
            if( cf->get_sense() == CUBIT_UNKNOWN || cf->get_sense() != face->get_surface_ptr()->bridge_sense() )
                // Check that each surface has a sense for only one volume
                if( reverse )
                    std::cout << "Surface " << face->id() << " has reverse sense "
                              << "with multiple volume " << reverse->id() << " and "
                              << "volume " << vol->id() << std::endl;
                    return MB_FAILURE;
                reverse = vol;
            if( cf->get_sense() == CUBIT_UNKNOWN || cf->get_sense() == face->get_surface_ptr()->bridge_sense() )
                if( forward )
                    std::cout << "Surface " << face->id() << " has forward sense "
                              << "with multiple volume " << forward->id() << " and "
                    return MB_FAILURE;
                forward = vol;
        if( forward )
            rval = myGeomTool->set_sense( ci->second, volume_map[forward], SENSE_FORWARD );
        if( reverse )
            rval = myGeomTool->set_sense( ci->second, volume_map[reverse], SENSE_REVERSE );
    return MB_SUCCESS;
void moab::ReadCGM::tokenize ( const std::string &  str,
std::vector< std::string > &  tokens,
const char *  delimiters
Definition at line 1011 of file ReadCGM.cpp.
    std::string::size_type last = str.find_first_not_of( delimiters, 0 );
    std::string::size_type pos  = str.find_first_of( delimiters, last );
    while( std::string::npos != pos && std::string::npos != last )
        tokens.push_back( str.substr( last, pos - last ) );
        last = str.find_first_not_of( delimiters, pos );
        if( std::string::npos == pos ) pos = str.size();
Member Data Documentation
Definition at line 147 of file ReadCGM.hpp.
Referenced by create_entity_sets(), create_group_entsets(), and ReadCGM().
Referenced by load_file(), and ReadCGM().
std::vector< int > moab::ReadCGM::failed_curves [private]
Definition at line 150 of file ReadCGM.hpp.
Referenced by create_curve_facets(), and dump_fail_counts().
std::vector< int > moab::ReadCGM::failed_surfaces [private]
Definition at line 153 of file ReadCGM.hpp.
Referenced by create_surface_facets(), and dump_fail_counts().
Referenced by create_entity_sets(), and ReadCGM().
Referenced by create_group_entsets(), and ReadCGM().
Definition at line 129 of file ReadCGM.hpp.
Referenced by ReadCGM(), and ~ReadCGM().
List of all members.
